MsqVertexTest.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2004 Sandia Corporation and Argonne National
00005     Laboratory.  Under the terms of Contract DE-AC04-94AL85000
00006     with Sandia Corporation, the U.S. Government retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     [email protected], [email protected], [email protected],
00024     [email protected], [email protected], [email protected]
00025
00026   ***************************************************************** */
00027 // -*- Mode : c++; tab-width: 3; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 3
00028 // -*-
00029 //
00030 //   SUMMARY:
00031 //     USAGE:
00032 //
00033 //    AUTHOR: Thomas Leurent <[email protected]>
00034 //       ORG: Argonne National Laboratory
00035 //    E-MAIL: [email protected]
00036 //
00037 // ORIG-DATE: 12-Nov-02 at 18:05:56
00038 //  LAST-MOD:  9-Apr-03 at 10:05:06 by Thomas Leurent
00039 //
00040 // DESCRIPTION:
00041 // ============
00042 /*! \file MsqVertexTest.cpp
00043
00044 Unit testing of various functions in the MsqVertex class.
00045
00046  */
00047 // DESCRIP-END.
00048 //
00049
00050 #include "MsqVertex.hpp"
00051 #include "PatchData.hpp"
00052 #include "PatchDataInstances.hpp"
00053
00054 #include <cmath>
00055 #include <iostream>
00056
00057 #include "cppunit/extensions/HelperMacros.h"
00058
00059 using namespace MBMesquite;
00060 using std::cerr;
00061 using std::cout;
00062 using std::endl;
00063
00064 class MsqVertexTest : public CppUnit::TestFixture
00065 {
00066
00067   private:
00068     CPPUNIT_TEST_SUITE( MsqVertexTest );
00069     CPPUNIT_TEST( test_flags );
00070     CPPUNIT_TEST_SUITE_END();
00071
00072   private:
00073     PatchData one_hex_patch;
00074     PatchData one_tet_patch;
00075     PatchData one_qua_patch;
00076     PatchData one_tri_patch;
00077     Vector3D e1, e2, e3;
00078     double tolEps;
00079
00080   public:
00081     void setUp()
00082     {
00083         tolEps = 1.e-12;
00084         // set up the unit vectors
00085         e1.set( 1, 0, 0 );
00086         e2.set( 0, 1, 0 );
00087         e3.set( 0, 0, 1 );
00088
00089         MsqPrintError err( cout );
00090
00091         double hcoords[] = { 1.0, 1.0, 1.0, 2.0, 1.0, 1.0, 2.0, 2.0, 1.0, 1.0, 2.0, 1.0,
00092                              1.0, 1.0, 2.0, 2.0, 1.0, 2.0, 2.0, 2.0, 2.0, 1.0, 2.0, 2.0 };
00093         size_t hconn[]   = { 0, 1, 2, 3, 4, 5, 6, 7 };
00094         one_hex_patch.fill( 8, hcoords, 1, HEXAHEDRON, hconn, 0, err );
00095
00096         double tcoords[] = { 1.0,
00097                              1.0,
00098                              1.0,
00099                              2.0,
00100                              1.0,
00101                              1.0,
00102                              1.5,
00103                              1 + sqrt( 3.0 ) / 2.0,
00104                              1.0,
00105                              1.5,
00106                              1 + sqrt( 3.0 ) / 6.0,
00107                              1 + sqrt( 2.0 ) / sqrt( 3.0 ) };
00108         size_t tconn[]   = { 0, 1, 2, 3 };
00109         one_tet_patch.fill( 4, tcoords, 1, TETRAHEDRON, tconn, 0, err );
00110
00111         double qcoords[] = { 1.0, 1.0, 1.0, 2.0, 1.0, 1.0, 2.0, 2.0, 1.0, 1.0, 2.0, 1.0 };
00112         size_t qconn[]   = { 0, 1, 2, 3 };
00113         one_qua_patch.fill( 4, qcoords, 1, QUADRILATERAL, qconn, 0, err );
00114
00115         double rcoords[] = { 1.0, 1.0, 1.0, 2.0, 1.0, 1.0, 1.5, 1 + sqrt( 3.0 ) / 2.0, 1.0 };
00116         size_t rconn[]   = { 0, 1, 2 };
00117         one_tri_patch.fill( 3, rcoords, 1, TRIANGLE, rconn, 0, err );
00118     }
00119
00120     void tearDown() {}
00121
00122   public:
00123     MsqVertexTest() {}
00124
00125     void test_hex_vertices()
00126     {
00127         MsqPrintError err( cout );
00128         // prints out the vertices.
00129         const MsqVertex* ideal_vertices = one_hex_patch.get_vertex_array( err );
00130         CPPUNIT_ASSERT( !err );
00131         int num_vtx = one_hex_patch.num_nodes();
00132         CPPUNIT_ASSERT_EQUAL( 8, num_vtx );
00133
00134         MsqVertex vtx;
00135
00136         vtx.set( 1, 1, 1 );
00137         CPPUNIT_ASSERT_EQUAL( vtx, ideal_vertices[0] );
00138
00139         vtx.set( 2, 2, 2 );
00140         CPPUNIT_ASSERT_EQUAL( vtx, ideal_vertices[6] );
00141
00142         vtx.set( 1, 2, 2 );
00143         CPPUNIT_ASSERT_EQUAL( vtx, ideal_vertices[7] );
00144     }
00145
00146     void test_flags()
00147     {
00148         MsqVertex vtx( 1, 2, 3 );
00149         CPPUNIT_ASSERT( vtx.is_flag_set( MsqVertex::MSQ_HARD_FIXED ) == false );
00150         vtx.set_hard_fixed_flag();
00151         CPPUNIT_ASSERT( vtx.is_flag_set( MsqVertex::MSQ_CULLED ) == false );
00152         CPPUNIT_ASSERT( vtx.is_flag_set( MsqVertex::MSQ_HARD_FIXED ) == true );
00153         CPPUNIT_ASSERT( ( vtx.is_flag_set( MsqVertex::MSQ_CULLED ) || vtx.is_flag_set( MsqVertex::MSQ_HARD_FIXED ) ) ==
00154                         true );
00155         CPPUNIT_ASSERT( ( vtx.is_flag_set( MsqVertex::MSQ_CULLED ) && vtx.is_flag_set( MsqVertex::MSQ_HARD_FIXED ) ) ==
00156                         false );
00157     }
00158 };
00159
00160 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( MsqVertexTest, "MsqVertexTest" );
00161 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( MsqVertexTest, "Unit" );
