NCHelperMPAS.cpp
00001 #include "NCHelperMPAS.hpp"
00002 #include "moab/ReadUtilIface.hpp"
00003 #include "moab/FileOptions.hpp"
00004 #include "moab/SpectralMeshTool.hpp"
00005 #include "MBTagConventions.hpp"
00006
00007 #ifdef MOAB_HAVE_ZOLTAN
00008 #include "moab/ZoltanPartitioner.hpp"
00009 #endif
00010
00011 #include <cmath>
00012
00013 namespace moab
00014 {
00015
00016 const int DEFAULT_MAX_EDGES_PER_CELL = 10;
00017
00018 NCHelperMPAS::NCHelperMPAS( ReadNC* readNC, int fileId, const FileOptions& opts, EntityHandle fileSet )
00019     : UcdNCHelper( readNC, fileId, opts, fileSet ), maxEdgesPerCell( DEFAULT_MAX_EDGES_PER_CELL ), numCellGroups( 0 ),
00020       createGatherSet( false )
00021 {
00022     // Ignore variables containing topological information
00023     ignoredVarNames.insert( "nEdgesOnEdge" );
00024     ignoredVarNames.insert( "nEdgesOnCell" );
00025     ignoredVarNames.insert( "edgesOnVertex" );
00026     ignoredVarNames.insert( "cellsOnVertex" );
00027     ignoredVarNames.insert( "verticesOnEdge" );
00028     ignoredVarNames.insert( "edgesOnEdge" );
00029     ignoredVarNames.insert( "cellsOnEdge" );
00030     ignoredVarNames.insert( "verticesOnCell" );
00031     ignoredVarNames.insert( "edgesOnCell" );
00032     ignoredVarNames.insert( "cellsOnCell" );
00033     // ignore variables containing mesh related info, that are currently saved as variable tags on
00034     // file set ; if needed, these should be saved as dense tags, and read accordingly, in parallel
00035     ignoredVarNames.insert( "weightsOnEdge" );
00036     ignoredVarNames.insert( "angleEdge" );
00037     ignoredVarNames.insert( "areaCell" );
00038     ignoredVarNames.insert( "areaTriangle" );
00039     ignoredVarNames.insert( "dcEdge" );
00040     ignoredVarNames.insert( "dv1Edge" );
00041     ignoredVarNames.insert( "dv2Edge" );
00042     ignoredVarNames.insert( "fEdge" );
00043     ignoredVarNames.insert( "fVertex" );
00044     ignoredVarNames.insert( "h_s" );
00045     ignoredVarNames.insert( "kiteAreasOnVertex" );
00046     ignoredVarNames.insert( "latCell" );
00047     ignoredVarNames.insert( "latEdge" );
00048     ignoredVarNames.insert( "latVertex" );
00049     ignoredVarNames.insert( "lonCell" );
00050     ignoredVarNames.insert( "lonEdge" );
00051     ignoredVarNames.insert( "lonVertex" );
00052     ignoredVarNames.insert( "meshDensity" );
00053     ignoredVarNames.insert( "xCell" );
00054     ignoredVarNames.insert( "xEdge" );
00055     ignoredVarNames.insert( "xVertex" );
00056     ignoredVarNames.insert( "yCell" );
00057     ignoredVarNames.insert( "yEdge" );
00058     ignoredVarNames.insert( "yVertex" );
00059     ignoredVarNames.insert( "zCell" );
00060     ignoredVarNames.insert( "zEdge" );
00061     ignoredVarNames.insert( "zVertex" );
00062     // Ignore variables for index conversion
00063     ignoredVarNames.insert( "indexToVertexID" );
00064     ignoredVarNames.insert( "indexToEdgeID" );
00065     ignoredVarNames.insert( "indexToCellID" );
00066 }
00067
00068 bool NCHelperMPAS::can_read_file( ReadNC* readNC )
00069 {
00070     std::vector< std::string >& dimNames = readNC->dimNames;
00071
00072     // If dimension name "vertexDegree" exists then it should be the MPAS grid
00073     if( std::find( dimNames.begin(), dimNames.end(), std::string( "vertexDegree" ) ) != dimNames.end() ) return true;
00074
00075     return false;
00076 }
00077
00078 ErrorCode NCHelperMPAS::init_mesh_vals()
00079 {
00080     std::vector< std::string >& dimNames              = _readNC->dimNames;
00081     std::vector< int >& dimLens                       = _readNC->dimLens;
00082     std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo;
00083
00084     ErrorCode rval;
00085     unsigned int idx;
00086     std::vector< std::string >::iterator vit;
00087
00088     // Get max edges per cell reported in the MPAS file header
00089     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "maxEdges" ) ) != dimNames.end() )
00090     {
00091         idx             = vit - dimNames.begin();
00092         maxEdgesPerCell = dimLens[idx];
00093         if( maxEdgesPerCell > DEFAULT_MAX_EDGES_PER_CELL )
00094         {
00095             MB_SET_ERR( MB_INVALID_SIZE,
00096                         "maxEdgesPerCell read from the MPAS file header has exceeded " << DEFAULT_MAX_EDGES_PER_CELL );
00097         }
00098     }
00099
00100     // Look for time dimension
00101     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "Time" ) ) != dimNames.end() )
00102         idx = vit - dimNames.begin();
00103     else if( ( vit = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() )
00104         idx = vit - dimNames.begin();
00105     else
00106     {
00107         MB_SET_ERR( MB_FAILURE, "Couldn't find 'Time' or 'time' dimension" );
00108     }
00109     tDim       = idx;
00110     nTimeSteps = dimLens[idx];
00111
00112     // Get number of cells
00113     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nCells" ) ) != dimNames.end() )
00114         idx = vit - dimNames.begin();
00115     else
00116     {
00117         MB_SET_ERR( MB_FAILURE, "Couldn't find 'nCells' dimension" );
00118     }
00119     cDim   = idx;
00120     nCells = dimLens[idx];
00121
00122     // Get number of edges
00123     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nEdges" ) ) != dimNames.end() )
00124         idx = vit - dimNames.begin();
00125     else
00126     {
00127         MB_SET_ERR( MB_FAILURE, "Couldn't find 'nEdges' dimension" );
00128     }
00129     eDim   = idx;
00130     nEdges = dimLens[idx];
00131
00132     // Get number of vertices
00133     vDim = -1;
00134     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nVertices" ) ) != dimNames.end() )
00135         idx = vit - dimNames.begin();
00136     else
00137     {
00138         MB_SET_ERR( MB_FAILURE, "Couldn't find 'nVertices' dimension" );
00139     }
00140     vDim      = idx;
00141     nVertices = dimLens[idx];
00142
00143     // Get number of vertex levels
00144     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nVertLevels" ) ) != dimNames.end() )
00145         idx = vit - dimNames.begin();
00146     else
00147     {
00148         std::cerr << "Warning: dimension nVertLevels not found in header.\nThe file may contain "
00149                      "just the mesh"
00150                   << std::endl;
00151     }
00152     levDim  = idx;
00153     nLevels = dimLens[idx];
00154
00155     // Dimension indices for other optional levels
00156     std::vector< unsigned int > opt_lev_dims;
00157
00158     // Get index of vertex levels P1
00159     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nVertLevelsP1" ) ) != dimNames.end() )
00160     {
00161         idx = vit - dimNames.begin();
00162         opt_lev_dims.push_back( idx );
00163     }
00164
00165     // Get index of vertex levels P2
00166     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nVertLevelsP2" ) ) != dimNames.end() )
00167     {
00168         idx = vit - dimNames.begin();
00169         opt_lev_dims.push_back( idx );
00170     }
00171
00172     // Get index of soil levels
00173     if( ( vit = std::find( dimNames.begin(), dimNames.end(), "nSoilLevels" ) ) != dimNames.end() )
00174     {
00175         idx = vit - dimNames.begin();
00176         opt_lev_dims.push_back( idx );
00177     }
00178
00179     std::map< std::string, ReadNC::VarData >::iterator vmit;
00180
00181     // Store time coordinate values in tVals
00182     if( nTimeSteps > 0 )
00183     {
00184         // Note, two possible types for xtime variable: double(Time) or char(Time, StrLen)
00185         if( ( vmit = varInfo.find( "xtime" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 )
00186         {
00187             // If xtime variable is double type, read time coordinate values to tVals
00188             rval = read_coordinate( "xtime", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 'xtime' variable" );
00189         }
00190         else
00191         {
00192             // If xtime variable does not exist, or it is string type, set dummy values to tVals
00193             for( int t = 0; t < nTimeSteps; t++ )
00194                 tVals.push_back( (double)t );
00195         }
00196     }
00197
00198     // For each variable, determine the entity location type and number of levels
00199     for( vmit = varInfo.begin(); vmit != varInfo.end(); ++vmit )
00200     {
00201         ReadNC::VarData& vd = ( *vmit ).second;
00202
00203         // Default entLoc is ENTLOCSET
00204         if( std::find( vd.varDims.begin(), vd.varDims.end(), tDim ) != vd.varDims.end() )
00205         {
00206             if( std::find( vd.varDims.begin(), vd.varDims.end(), vDim ) != vd.varDims.end() )
00207                 vd.entLoc = ReadNC::ENTLOCVERT;
00208             else if( std::find( vd.varDims.begin(), vd.varDims.end(), eDim ) != vd.varDims.end() )
00209                 vd.entLoc = ReadNC::ENTLOCEDGE;
00210             else if( std::find( vd.varDims.begin(), vd.varDims.end(), cDim ) != vd.varDims.end() )
00211                 vd.entLoc = ReadNC::ENTLOCFACE;
00212         }
00213
00214         // Default numLev is 0
00215         if( std::find( vd.varDims.begin(), vd.varDims.end(), levDim ) != vd.varDims.end() )
00216             vd.numLev = nLevels;
00217         else
00218         {
00219             // If nVertLevels dimension is not found, try other optional levels such as
00220             // nVertLevelsP1
00221             for( unsigned int i = 0; i < opt_lev_dims.size(); i++ )
00222             {
00223                 if( std::find( vd.varDims.begin(), vd.varDims.end(), opt_lev_dims[i] ) != vd.varDims.end() )
00224                 {
00225                     vd.numLev = dimLens[opt_lev_dims[i]];
00226                     break;
00227                 }
00228             }
00229         }
00230
00231         // Hack: ignore variables with more than 3 dimensions, e.g. tracers(Time, nCells,
00232         // nVertLevels, nTracers)
00233         if( vd.varDims.size() > 3 ) ignoredVarNames.insert( vd.varName );
00234     }
00235
00236     // Hack: create dummy variables for dimensions (like nCells) with no corresponding coordinate
00237     // variables
00238     rval = create_dummy_variables();MB_CHK_SET_ERR( rval, "Failed to create dummy variables" );
00239
00240     return MB_SUCCESS;
00241 }
00242
00243 // When noMesh option is used on this read, the old ReadNC class instance for last read can get out
00244 // of scope (and deleted). The old instance initialized some variables properly when the mesh was
00245 // created, but they are now lost. The new instance (will not create the mesh with noMesh option)
00246 // has to restore them based on the existing mesh from last read
00247 ErrorCode NCHelperMPAS::check_existing_mesh()
00248 {
00249     Interface*& mbImpl = _readNC->mbImpl;
00250     Tag& mGlobalIdTag  = _readNC->mGlobalIdTag;
00251     bool& noMesh       = _readNC->noMesh;
00252
00253     if( noMesh )
00254     {
00255         ErrorCode rval;
00256
00257         // Restore numCellGroups
00258         if( 0 == numCellGroups )
00259         {
00260             Tag numCellGroupsTag;
00261             rval = mbImpl->tag_get_handle( "__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag );MB_CHK_SET_ERR( rval, "Trouble getting __NUM_CELL_GROUPS tag" );
00262             if( MB_SUCCESS == rval ) rval = mbImpl->tag_get_data( numCellGroupsTag, &_fileSet, 1, &numCellGroups );MB_CHK_SET_ERR( rval, "Trouble getting data of __NUM_CELL_GROUPS tag" );
00263         }
00264
00265         if( localGidVerts.empty() )
00266         {
00267             // Get all vertices from current file set (it is the input set in no_mesh scenario)
00268             Range local_verts;
00269             rval = mbImpl->get_entities_by_dimension( _fileSet, 0, local_verts );MB_CHK_SET_ERR( rval, "Trouble getting local vertices in current file set" );
00270
00271             if( !local_verts.empty() )
00272             {
00273                 std::vector< int > gids( local_verts.size() );
00274
00275                 // !IMPORTANT : this has to be the GLOBAL_ID tag
00276                 rval = mbImpl->tag_get_data( mGlobalIdTag, local_verts, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of vertices" );
00277
00278                 // Restore localGidVerts
00279                 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidVerts ) );
00280                 nLocalVertices = localGidVerts.size();
00281             }
00282         }
00283
00284         if( localGidEdges.empty() )
00285         {
00286             // Get all edges from current file set (it is the input set in no_mesh scenario)
00287             Range local_edges;
00288             rval = mbImpl->get_entities_by_dimension( _fileSet, 1, local_edges );MB_CHK_SET_ERR( rval, "Trouble getting local edges in current file set" );
00289
00290             if( !local_edges.empty() )
00291             {
00292                 std::vector< int > gids( local_edges.size() );
00293
00294                 // !IMPORTANT : this has to be the GLOBAL_ID tag
00295                 rval = mbImpl->tag_get_data( mGlobalIdTag, local_edges, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of edges" );
00296
00297                 // Restore localGidEdges
00298                 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidEdges ) );
00299                 nLocalEdges = localGidEdges.size();
00300             }
00301         }
00302
00303         if( localGidCells.empty() )
00304         {
00305             // Get all cells from current file set (it is the input set in no_mesh scenario)
00306             Range local_cells;
00307             rval = mbImpl->get_entities_by_dimension( _fileSet, 2, local_cells );MB_CHK_SET_ERR( rval, "Trouble getting local cells in current file set" );
00308
00309             if( !local_cells.empty() )
00310             {
00311                 std::vector< int > gids( local_cells.size() );
00312
00313                 // !IMPORTANT : this has to be the GLOBAL_ID tag
00314                 rval = mbImpl->tag_get_data( mGlobalIdTag, local_cells, &gids[0] );MB_CHK_SET_ERR( rval, "Trouble getting local gid values of cells" );
00315
00316                 // Restore localGidCells
00317                 std::copy( gids.rbegin(), gids.rend(), range_inserter( localGidCells ) );
00318                 nLocalCells = localGidCells.size();
00319
00320                 if( numCellGroups > 1 )
00321                 {
00322                     // Restore cellHandleToGlobalID map
00323                     Range::const_iterator rit;
00324                     int i;
00325                     for( rit = local_cells.begin(), i = 0; rit != local_cells.end(); ++rit, i++ )
00326                         cellHandleToGlobalID[*rit] = gids[i];
00327                 }
00328             }
00329         }
00330     }
00331
00332     return MB_SUCCESS;
00333 }
00334
00335 ErrorCode NCHelperMPAS::create_mesh( Range& faces )
00336 {
00337     Interface*& mbImpl    = _readNC->mbImpl;
00338     bool& noMixedElements = _readNC->noMixedElements;
00339     bool& noEdges         = _readNC->noEdges;
00340     DebugOutput& dbgOut   = _readNC->dbgOut;
00341
00342 #ifdef MOAB_HAVE_MPI
00343     int rank         = 0;
00344     int procs        = 1;
00345     bool& isParallel = _readNC->isParallel;
00346     ParallelComm* myPcomm = NULL;
00347     if( isParallel )
00348     {
00349         myPcomm  = _readNC->myPcomm;
00350         rank                   = myPcomm->proc_config().proc_rank();
00351         procs                  = myPcomm->proc_config().proc_size();
00352     }
00353
00354     // Need to know whether we'll be creating gather mesh
00355     if( rank == _readNC->gatherSetRank ) createGatherSet = true;
00356
00357     if( procs >= 2 )
00358     {
00359         // Shift rank to obtain a rotated trivial partition
00360         int shifted_rank           = rank;
00361         int& trivialPartitionShift = _readNC->trivialPartitionShift;
00362         if( trivialPartitionShift > 0 ) shifted_rank = ( rank + trivialPartitionShift ) % procs;
00363
00364         // Compute the number of local cells on this proc
00365         nLocalCells = int( std::floor( 1.0 * nCells / procs ) );
00366
00367         // The starting global cell index in the MPAS file for this proc
00368         int start_cell_idx = shifted_rank * nLocalCells;
00369
00370         // Number of extra cells after equal split over procs
00371         int iextra = nCells % procs;
00372
00373         // Allocate extra cells over procs
00374         if( shifted_rank < iextra ) nLocalCells++;
00375         start_cell_idx += std::min( shifted_rank, iextra );
00376
00377         start_cell_idx++;  // 0 based -> 1 based
00378
00379         // Redistribute local cells after trivial partition (e.g. apply Zoltan partition)
00380         ErrorCode rval = redistribute_local_cells( start_cell_idx, myPcomm );MB_CHK_SET_ERR( rval, "Failed to redistribute local cells after trivial partition" );
00381     }
00382     else
00383     {
00384         nLocalCells = nCells;
00385         localGidCells.insert( 1, nLocalCells );
00386     }
00387 #else
00388     nLocalCells = nCells;
00389     localGidCells.insert( 1, nLocalCells );
00390 #endif
00391     dbgOut.tprintf( 1, " localGidCells.psize() = %d\n", (int)localGidCells.psize() );
00392     dbgOut.tprintf( 1, " localGidCells.size() = %d\n", (int)localGidCells.size() );
00393
00394     // Read number of edges on each local cell, to calculate actual maxEdgesPerCell
00395     int nEdgesOnCellVarId;
00396     int success = NCFUNC( inq_varid )( _fileId, "nEdgesOnCell", &nEdgesOnCellVarId );
00397     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of nEdgesOnCell" );
00398     std::vector< int > num_edges_on_local_cells( nLocalCells );
00399 #ifdef MOAB_HAVE_PNETCDF
00400     size_t nb_reads = localGidCells.psize();
00401     std::vector< int > requests( nb_reads );
00402     std::vector< int > statuss( nb_reads );
00403     size_t idxReq = 0;
00404 #endif
00405     size_t indexInArray = 0;
00406     for( Range::pair_iterator pair_iter = localGidCells.pair_begin(); pair_iter != localGidCells.pair_end();
00407          ++pair_iter )
00408     {
00409         EntityHandle starth  = pair_iter->first;
00410         EntityHandle endh    = pair_iter->second;
00411         NCDF_SIZE read_start = (NCDF_SIZE)( starth - 1 );
00412         NCDF_SIZE read_count = (NCDF_SIZE)( endh - starth + 1 );
00413
00414         // Do a partial read in each subrange
00415 #ifdef MOAB_HAVE_PNETCDF
00416         success = NCFUNCREQG( _vara_int )( _fileId, nEdgesOnCellVarId, &read_start, &read_count,
00417                                            &( num_edges_on_local_cells[indexInArray] ), &requests[idxReq++] );
00418 #else
00419         success = NCFUNCAG( _vara_int )( _fileId, nEdgesOnCellVarId, &read_start, &read_count,
00420                                          &( num_edges_on_local_cells[indexInArray] ) );
00421 #endif
00422         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read nEdgesOnCell data in a loop" );
00423
00424         // Increment the index for next subrange
00425         indexInArray += ( endh - starth + 1 );
00426     }
00427
00428 #ifdef MOAB_HAVE_PNETCDF
00429     // Wait outside the loop
00430     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
00431     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
00432 #endif
00433
00434     // Get local maxEdgesPerCell on this proc
00435     int local_max_edges_per_cell =
00436         *( std::max_element( num_edges_on_local_cells.begin(), num_edges_on_local_cells.end() ) );
00437     maxEdgesPerCell = local_max_edges_per_cell;
00438
00439     // If parallel, do a MPI_Allreduce to get global maxEdgesPerCell across all procs
00440 #ifdef MOAB_HAVE_MPI
00441     if( procs >= 2 )
00442     {
00443         int global_max_edges_per_cell;
00444         ParallelComm*& myPcomm = _readNC->myPcomm;
00445         MPI_Allreduce( &local_max_edges_per_cell, &global_max_edges_per_cell, 1, MPI_INT, MPI_MAX,
00446                        myPcomm->proc_config().proc_comm() );
00447         assert( local_max_edges_per_cell <= global_max_edges_per_cell );
00448         maxEdgesPerCell = global_max_edges_per_cell;
00449         if( 0 == rank ) dbgOut.tprintf( 1, "  global_max_edges_per_cell = %d\n", global_max_edges_per_cell );
00450     }
00451 #endif
00452
00453     // Read vertices on each local cell, to get localGidVerts and cell connectivity later
00454     int verticesOnCellVarId;
00455     success = NCFUNC( inq_varid )( _fileId, "verticesOnCell", &verticesOnCellVarId );
00456     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of verticesOnCell" );
00457     std::vector< int > vertices_on_local_cells( nLocalCells * maxEdgesPerCell );
00458 #ifdef MOAB_HAVE_PNETCDF
00459     idxReq = 0;
00460 #endif
00461     indexInArray = 0;
00462     for( Range::pair_iterator pair_iter = localGidCells.pair_begin(); pair_iter != localGidCells.pair_end();
00463          ++pair_iter )
00464     {
00465         EntityHandle starth      = pair_iter->first;
00466         EntityHandle endh        = pair_iter->second;
00467         NCDF_SIZE read_starts[2] = { static_cast< NCDF_SIZE >( starth - 1 ), 0 };
00468         NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ),
00469                                      static_cast< NCDF_SIZE >( maxEdgesPerCell ) };
00470
00471         // Do a partial read in each subrange
00472 #ifdef MOAB_HAVE_PNETCDF
00473         success = NCFUNCREQG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
00474                                            &( vertices_on_local_cells[indexInArray] ), &requests[idxReq++] );
00475 #else
00476         success = NCFUNCAG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
00477                                          &( vertices_on_local_cells[indexInArray] ) );
00478 #endif
00479         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnCell data in a loop" );
00480
00481         // Increment the index for next subrange
00482         indexInArray += ( endh - starth + 1 ) * maxEdgesPerCell;
00483     }
00484
00485 #ifdef MOAB_HAVE_PNETCDF
00486     // Wait outside the loop
00487     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
00488     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
00489 #endif
00490
00491     // Correct local cell vertices array, replace the padded vertices with the last vertices
00492     // in the corresponding cells; sometimes the padded vertices are 0, sometimes a large
00493     // vertex id. Make sure they are consistent to our padded option
00494     for( int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++ )
00495     {
00496         int num_edges             = num_edges_on_local_cells[local_cell_idx];
00497         int idx_in_local_vert_arr = local_cell_idx * maxEdgesPerCell;
00498         int last_vert_idx         = vertices_on_local_cells[idx_in_local_vert_arr + num_edges - 1];
00499         for( int i = num_edges; i < maxEdgesPerCell; i++ )
00500             vertices_on_local_cells[idx_in_local_vert_arr + i] = last_vert_idx;
00501     }
00502
00503     // Create local vertices
00504     EntityHandle start_vertex;
00505     ErrorCode rval = create_local_vertices( vertices_on_local_cells, start_vertex );MB_CHK_SET_ERR( rval, "Failed to create local vertices for MPAS mesh" );
00506
00507     // Create local edges (unless NO_EDGES read option is set)
00508     if( !noEdges )
00509     {
00510         rval = create_local_edges( start_vertex, num_edges_on_local_cells );MB_CHK_SET_ERR( rval, "Failed to create local edges for MPAS mesh" );
00511     }
00512
00513     // Create local cells, either unpadded or padded
00514     if( noMixedElements )
00515     {
00516         rval = create_padded_local_cells( vertices_on_local_cells, start_vertex, faces );MB_CHK_SET_ERR( rval, "Failed to create padded local cells for MPAS mesh" );
00517     }
00518     else
00519     {
00520         rval = create_local_cells( vertices_on_local_cells, num_edges_on_local_cells, start_vertex, faces );MB_CHK_SET_ERR( rval, "Failed to create local cells for MPAS mesh" );
00521     }
00522
00523     // Set tag for numCellGroups
00524     Tag numCellGroupsTag = 0;
00525     rval                 = mbImpl->tag_get_handle( "__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag,
00526                                                    MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating __NUM_CELL_GROUPS tag" );
00527     rval = mbImpl->tag_set_data( numCellGroupsTag, &_fileSet, 1, &numCellGroups );MB_CHK_SET_ERR( rval, "Trouble setting data to __NUM_CELL_GROUPS tag" );
00528
00529     if( createGatherSet )
00530     {
00531         EntityHandle gather_set;
00532         rval = _readNC->readMeshIface->create_gather_set( gather_set );MB_CHK_SET_ERR( rval, "Failed to create gather set" );
00533
00534         // Create gather set vertices
00535         EntityHandle start_gather_set_vertex;
00536         rval = create_gather_set_vertices( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set vertices for MPAS mesh" );
00537
00538         // Create gather set edges (unless NO_EDGES read option is set)
00539         if( !noEdges )
00540         {
00541             rval = create_gather_set_edges( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set edges for MPAS mesh" );
00542         }
00543
00544         // Create gather set cells, either unpadded or padded
00545         if( noMixedElements )
00546         {
00547             rval = create_padded_gather_set_cells( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create padded gather set cells for MPAS mesh" );
00548         }
00549         else
00550         {
00551             rval = create_gather_set_cells( gather_set, start_gather_set_vertex );MB_CHK_SET_ERR( rval, "Failed to create gather set cells for MPAS mesh" );
00552         }
00553     }
00554
00555     return MB_SUCCESS;
00556 }
00557
00558 ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_allocate( std::vector< ReadNC::VarData >& vdatas,
00559        std::vector< int >& tstep_nums )
00560 {
00561     Interface*& mbImpl          = _readNC->mbImpl;
00562     std::vector< int >& dimLens = _readNC->dimLens;
00563     bool& noEdges               = _readNC->noEdges;
00564     DebugOutput& dbgOut         = _readNC->dbgOut;
00565
00566     Range* range = NULL;
00567
00568     // Get vertices
00569     Range verts;
00570     ErrorCode rval = mbImpl->get_entities_by_dimension( _fileSet, 0, verts );MB_CHK_SET_ERR( rval, "Trouble getting vertices in current file set" );
00571     assert( "Should only have a single vertex subrange, since they were read in one shot" && verts.psize() == 1 );
00572
00573     // Get edges
00574     Range edges;
00575     rval = mbImpl->get_entities_by_dimension( _fileSet, 1, edges );MB_CHK_SET_ERR( rval, "Trouble getting edges in current file set" );
00576
00577     // Get faces
00578     Range faces;
00579     rval = mbImpl->get_entities_by_dimension( _fileSet, 2, faces );MB_CHK_SET_ERR( rval, "Trouble getting faces in current file set" );
00580     // Note, for MPAS faces.psize() can be more than 1
00581
00582 #ifdef MOAB_HAVE_MPI
00583     bool& isParallel = _readNC->isParallel;
00584     if( isParallel )
00585     {
00586         ParallelComm*& myPcomm = _readNC->myPcomm;
00587         rval                   = myPcomm->filter_pstatus( faces, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &facesOwned );MB_CHK_SET_ERR( rval, "Trouble getting owned faces in current file set" );
00588     }
00589     else
00590         facesOwned = faces;  // not running in parallel, but still with MPI
00591 #else
00592     facesOwned = faces;
00593 #endif
00594
00595     for( unsigned int i = 0; i < vdatas.size(); i++ )
00596     {
00597         // Skip edge variables, if specified by the read options
00598         if( noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE ) continue;
00599
00600         // Support non-set variables with 3 dimensions like (Time, nCells, nVertLevels), or
00601         // 2 dimensions like (Time, nCells)
00602         assert( 3 == vdatas[i].varDims.size() || 2 == vdatas[i].varDims.size() );
00603
00604         // For a non-set variable, time should be the first dimension
00605         assert( tDim == vdatas[i].varDims[0] );
00606
00607         // Set up readStarts and readCounts
00608         vdatas[i].readStarts.resize( 3 );
00609         vdatas[i].readCounts.resize( 3 );
00610
00611         // First: Time
00612         vdatas[i].readStarts[0] = 0;  // This value is timestep dependent, will be set later
00613         vdatas[i].readCounts[0] = 1;
00614
00615         // Next: nVertices / nCells / nEdges
00616         switch( vdatas[i].entLoc )
00617         {
00618             case ReadNC::ENTLOCVERT:
00619                 // Vertices
00620                 // Start from the first localGidVerts
00621                 // Actually, this will be reset later on in a loop
00622                 vdatas[i].readStarts[1] = localGidVerts[0] - 1;
00623                 vdatas[i].readCounts[1] = nLocalVertices;
00624                 range                   = &verts;
00625                 break;
00626             case ReadNC::ENTLOCFACE:
00627                 // Faces
00628                 // Start from the first localGidCells
00629                 // Actually, this will be reset later on in a loop
00630                 vdatas[i].readStarts[1] = localGidCells[0] - 1;
00631                 vdatas[i].readCounts[1] = nLocalCells;
00632                 range                   = &facesOwned;
00633                 break;
00634             case ReadNC::ENTLOCEDGE:
00635                 // Edges
00636                 // Start from the first localGidEdges
00637                 // Actually, this will be reset later on in a loop
00638                 vdatas[i].readStarts[1] = localGidEdges[0] - 1;
00639                 vdatas[i].readCounts[1] = nLocalEdges;
00640                 range                   = &edges;
00641                 break;
00642             default:
00643                 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
00644         }
00645
00646         // Finally: nVertLevels or other optional levels, it is possible that there is no
00647         // level dimension (numLev is 0) for this non-set variable, e.g. (Time, nCells)
00648         if( vdatas[i].numLev < 1 ) vdatas[i].numLev = 1;
00649         vdatas[i].readStarts[2] = 0;
00650         vdatas[i].readCounts[2] = vdatas[i].numLev;
00651
00652         // Get variable size
00653         vdatas[i].sz = 1;
00654         for( std::size_t idx = 0; idx != 3; idx++ )
00655             vdatas[i].sz *= vdatas[i].readCounts[idx];
00656
00657         for( unsigned int t = 0; t < tstep_nums.size(); t++ )
00658         {
00659             dbgOut.tprintf( 2, "Reading variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t] );
00660
00661             if( tstep_nums[t] >= dimLens[tDim] )
00662             {
00663                 MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "Wrong value for timestep number " << tstep_nums[t] );
00664             }
00665
00666             // Get the tag to read into
00667             if( !vdatas[i].varTags[t] )
00668             {
00669                 rval = get_tag_to_nonset( vdatas[i], tstep_nums[t], vdatas[i].varTags[t], vdatas[i].numLev );MB_CHK_SET_ERR( rval, "Trouble getting tag for variable " << vdatas[i].varName );
00670             }
00671
00672             // Get ptr to tag space
00673             if( vdatas[i].entLoc == ReadNC::ENTLOCFACE && numCellGroups > 1 )
00674             {
00675                 // For a cell variable that is NOT on one contiguous chunk of faces, defer its tag
00676                 // space allocation
00677                 vdatas[i].varDatas[t] = NULL;
00678             }
00679             else
00680             {
00681                 assert( 1 == range->psize() );
00682                 void* data;
00683                 int count;
00684                 rval = mbImpl->tag_iterate( vdatas[i].varTags[t], range->begin(), range->end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate tag for variable " << vdatas[i].varName );
00685                 assert( (unsigned)count == range->size() );
00686                 vdatas[i].varDatas[t] = data;
00687             }
00688         }
00689     }
00690
00691     return rval;
00692 }
00693
00694 #ifdef MOAB_HAVE_PNETCDF
00695 ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset_async( std::vector< ReadNC::VarData >& vdatas,
00696                                                             std::vector< int >& tstep_nums )
00697 {
00698     Interface*& mbImpl  = _readNC->mbImpl;
00699     bool& noEdges       = _readNC->noEdges;
00700     DebugOutput& dbgOut = _readNC->dbgOut;
00701
00702     ErrorCode rval = read_ucd_variables_to_nonset_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read non-set variables" );
00703
00704     // Finally, read into that space
00705     int success;
00706     Range* pLocalGid = NULL;
00707
00708     for( unsigned int i = 0; i < vdatas.size(); i++ )
00709     {
00710         // Skip edge variables, if specified by the read options
00711         if( noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE ) continue;
00712
00713         switch( vdatas[i].entLoc )
00714         {
00715             case ReadNC::ENTLOCVERT:
00716                 pLocalGid = &localGidVerts;
00717                 break;
00718             case ReadNC::ENTLOCFACE:
00719                 pLocalGid = &localGidCells;
00720                 break;
00721             case ReadNC::ENTLOCEDGE:
00722                 pLocalGid = &localGidEdges;
00723                 break;
00724             default:
00725                 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
00726         }
00727
00728         std::size_t sz = vdatas[i].sz;
00729
00730         for( unsigned int t = 0; t < tstep_nums.size(); t++ )
00731         {
00732             // We will synchronize all these reads with the other processors,
00733             // so the wait will be inside this double loop; is it too much?
00734             size_t nb_reads = pLocalGid->psize();
00735             std::vector< int > requests( nb_reads ), statuss( nb_reads );
00736             size_t idxReq = 0;
00737
00738             // Set readStart for each timestep along time dimension
00739             vdatas[i].readStarts[0] = tstep_nums[t];
00740
00741             switch( vdatas[i].varDataType )
00742             {
00743                 case NC_FLOAT:
00744                 case NC_DOUBLE: {
00745                     // Read float as double
00746                     std::vector< double > tmpdoubledata( sz );
00747
00748                     // In the case of ucd mesh, and on multiple proc,
00749                     // we need to read as many times as subranges we have in the
00750                     // localGid range;
00751                     // basically, we have to give a different point
00752                     // for data to start, for every subrange :(
00753                     size_t indexInDoubleArray = 0;
00754                     size_t ic                 = 0;
00755                     for( Range::pair_iterator pair_iter = pLocalGid->pair_begin(); pair_iter != pLocalGid->pair_end();
00756                          ++pair_iter, ic++ )
00757                     {
00758                         EntityHandle starth     = pair_iter->first;
00759                         EntityHandle endh       = pair_iter->second;  // Inclusive
00760                         vdatas[i].readStarts[1] = (NCDF_SIZE)( starth - 1 );
00761                         vdatas[i].readCounts[1] = (NCDF_SIZE)( endh - starth + 1 );
00762
00763                         // Do a partial read, in each subrange
00764                         // Wait outside this loop
00765                         success =
00766                             NCFUNCREQG( _vara_double )( _fileId, vdatas[i].varId, &( vdatas[i].readStarts[0] ),
00767                                                         &( vdatas[i].readCounts[0] ),
00768                                                         &( tmpdoubledata[indexInDoubleArray] ), &requests[idxReq++] );
00769                         if( success )
00770                             MB_SET_ERR( MB_FAILURE,
00771                                         "Failed to read double data in a loop for variable " << vdatas[i].varName );
00772                         // We need to increment the index in double array for the
00773                         // next subrange
00774                         indexInDoubleArray += ( endh - starth + 1 ) * 1 * vdatas[i].numLev;
00775                     }
00776                     assert( ic == pLocalGid->psize() );
00777
00778                     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
00779                     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
00780
00781                     if( vdatas[i].entLoc == ReadNC::ENTLOCFACE && numCellGroups > 1 )
00782                     {
00783                         // For a cell variable that is NOT on one contiguous chunk of faces,
00784                         // allocate tag space for each cell group, and utilize cellHandleToGlobalID
00785                         // map to read tag data
00786                         Range::iterator iter = facesOwned.begin();
00787                         while( iter != facesOwned.end() )
00788                         {
00789                             int count;
00790                             void* ptr;
00791                             rval = mbImpl->tag_iterate( vdatas[i].varTags[t], iter, facesOwned.end(), count, ptr );MB_CHK_SET_ERR( rval, "Failed to iterate tag on owned faces" );
00792
00793                             for( int j = 0; j < count; j++ )
00794                             {
00795                                 int global_cell_idx =
00796                                     cellHandleToGlobalID[*( iter + j )];  // Global cell index, 1 based
00797                                 int local_cell_idx =
00798                                     localGidCells.index( global_cell_idx );  // Local cell index, 0 based
00799                                 assert( local_cell_idx != -1 );
00800                                 for( int level = 0; level < vdatas[i].numLev; level++ )
00801                                     ( (double*)ptr )[j * vdatas[i].numLev + level] =
00802                                         tmpdoubledata[local_cell_idx * vdatas[i].numLev + level];
00803                             }
00804
00805                             iter += count;
00806                         }
00807                     }
00808                     else
00809                     {
00810                         void* data = vdatas[i].varDatas[t];
00811                         for( std::size_t idx = 0; idx != tmpdoubledata.size(); idx++ )
00812                             ( (double*)data )[idx] = tmpdoubledata[idx];
00813                     }
00814
00815                     break;
00816                 }
00817                 default:
00818                     MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName );
00819             }
00820         }
00821     }
00822
00823     // Debug output, if requested
00824     if( 1 == dbgOut.get_verbosity() )
00825     {
00826         dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() );
00827         for( unsigned int i = 1; i < vdatas.size(); i++ )
00828             dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() );
00829         dbgOut.tprintf( 1, "\n" );
00830     }
00831
00832     return rval;
00833 }
00834 #else
00835 ErrorCode NCHelperMPAS::read_ucd_variables_to_nonset( std::vector< ReadNC::VarData >& vdatas,
00836                                                       std::vector< int >& tstep_nums )
00837 {
00838     Interface*& mbImpl = _readNC->mbImpl;
00839     bool& noEdges = _readNC->noEdges;
00840     DebugOutput& dbgOut = _readNC->dbgOut;
00841
00842     ErrorCode rval = read_ucd_variables_to_nonset_allocate( vdatas, tstep_nums );MB_CHK_SET_ERR( rval, "Trouble allocating space to read non-set variables" );
00843
00844     // Finally, read into that space
00845     int success;
00846     Range* pLocalGid = NULL;
00847
00848     for( unsigned int i = 0; i < vdatas.size(); i++ )
00849     {
00850         // Skip edge variables, if specified by the read options
00851         if( noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE ) continue;
00852
00853         switch( vdatas[i].entLoc )
00854         {
00855             case ReadNC::ENTLOCVERT:
00856                 pLocalGid = &localGidVerts;
00857                 break;
00858             case ReadNC::ENTLOCFACE:
00859                 pLocalGid = &localGidCells;
00860                 break;
00861             case ReadNC::ENTLOCEDGE:
00862                 pLocalGid = &localGidEdges;
00863                 break;
00864             default:
00865                 MB_SET_ERR( MB_FAILURE, "Unexpected entity location type for variable " << vdatas[i].varName );
00866         }
00867
00868         std::size_t sz = vdatas[i].sz;
00869
00870         for( unsigned int t = 0; t < tstep_nums.size(); t++ )
00871         {
00872             // Set readStart for each timestep along time dimension
00873             vdatas[i].readStarts[0] = tstep_nums[t];
00874
00875             switch( vdatas[i].varDataType )
00876             {
00877                 case NC_FLOAT:
00878                 case NC_DOUBLE: {
00879                     // Read float as double
00880                     std::vector< double > tmpdoubledata( sz );
00881
00882                     // In the case of ucd mesh, and on multiple proc,
00883                     // we need to read as many times as subranges we have in the
00884                     // localGid range;
00885                     // basically, we have to give a different point
00886                     // for data to start, for every subrange :(
00887                     size_t indexInDoubleArray = 0;
00888                     size_t ic = 0;
00889                     for( Range::pair_iterator pair_iter = pLocalGid->pair_begin(); pair_iter != pLocalGid->pair_end();
00890                          ++pair_iter, ic++ )
00891                     {
00892                         EntityHandle starth = pair_iter->first;
00893                         EntityHandle endh = pair_iter->second;  // Inclusive
00894                         vdatas[i].readStarts[1] = (NCDF_SIZE)( starth - 1 );
00895                         vdatas[i].readCounts[1] = (NCDF_SIZE)( endh - starth + 1 );
00896
00897                         success = NCFUNCAG( _vara_double )( _fileId, vdatas[i].varId, &( vdatas[i].readStarts[0] ),
00898                                                             &( vdatas[i].readCounts[0] ),
00899                                                             &( tmpdoubledata[indexInDoubleArray] ) );
00900                         if( success )
00901                             MB_SET_ERR( MB_FAILURE,
00902                                         "Failed to read double data in a loop for variable " << vdatas[i].varName );
00903                         // We need to increment the index in double array for the
00904                         // next subrange
00905                         indexInDoubleArray += ( endh - starth + 1 ) * 1 * vdatas[i].numLev;
00906                     }
00907                     assert( ic == pLocalGid->psize() );
00908
00909                     if( vdatas[i].entLoc == ReadNC::ENTLOCFACE && numCellGroups > 1 )
00910                     {
00911                         // For a cell variable that is NOT on one contiguous chunk of faces,
00912                         // allocate tag space for each cell group, and utilize cellHandleToGlobalID
00913                         // map to read tag data
00914                         Range::iterator iter = facesOwned.begin();
00915                         while( iter != facesOwned.end() )
00916                         {
00917                             int count;
00918                             void* ptr;
00919                             rval = mbImpl->tag_iterate( vdatas[i].varTags[t], iter, facesOwned.end(), count, ptr );MB_CHK_SET_ERR( rval, "Failed to iterate tag on owned faces" );
00920
00921                             for( int j = 0; j < count; j++ )
00922                             {
00923                                 int global_cell_idx =
00924                                     cellHandleToGlobalID[*( iter + j )];  // Global cell index, 1 based
00925                                 int local_cell_idx =
00926                                     localGidCells.index( global_cell_idx );  // Local cell index, 0 based
00927                                 assert( local_cell_idx != -1 );
00928                                 for( int level = 0; level < vdatas[i].numLev; level++ )
00929                                     ( (double*)ptr )[j * vdatas[i].numLev + level] =
00930                                         tmpdoubledata[local_cell_idx * vdatas[i].numLev + level];
00931                             }
00932
00933                             iter += count;
00934                         }
00935                     }
00936                     else
00937                     {
00938                         void* data = vdatas[i].varDatas[t];
00939                         for( std::size_t idx = 0; idx != tmpdoubledata.size(); idx++ )
00940                             ( (double*)data )[idx] = tmpdoubledata[idx];
00941                     }
00942
00943                     break;
00944                 }
00945                 default:
00946                     MB_SET_ERR( MB_FAILURE, "Unexpected data type for variable " << vdatas[i].varName );
00947             }
00948         }
00949     }
00950
00951     // Debug output, if requested
00952     if( 1 == dbgOut.get_verbosity() )
00953     {
00954         dbgOut.printf( 1, "Read variables: %s", vdatas.begin()->varName.c_str() );
00955         for( unsigned int i = 1; i < vdatas.size(); i++ )
00956             dbgOut.printf( 1, ", %s ", vdatas[i].varName.c_str() );
00957         dbgOut.tprintf( 1, "\n" );
00958     }
00959
00960     return rval;
00961 }
00962 #endif
00963
00964 #ifdef MOAB_HAVE_MPI
00965 ErrorCode NCHelperMPAS::redistribute_local_cells( int start_cell_idx, ParallelComm * pco )
00966 {
00967     // If possible, apply Zoltan partition
00968 #ifdef MOAB_HAVE_ZOLTAN
00969     if( ScdParData::RCBZOLTAN == _readNC->partMethod )
00970     {
00971         // Read x coordinates of cell centers
00972         int xCellVarId;
00973         int success = NCFUNC( inq_varid )( _fileId, "xCell", &xCellVarId );
00974         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of xCell" );
00975         std::vector< double > xCell( nLocalCells );
00976         NCDF_SIZE read_start = static_cast< NCDF_SIZE >( start_cell_idx - 1 );
00977         NCDF_SIZE read_count = static_cast< NCDF_SIZE >( nLocalCells );
00978         success              = NCFUNCAG( _vara_double )( _fileId, xCellVarId, &read_start, &read_count, &xCell[0] );
00979         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read xCell data" );
00980
00981         // Read y coordinates of cell centers
00982         int yCellVarId;
00983         success = NCFUNC( inq_varid )( _fileId, "yCell", &yCellVarId );
00984         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of yCell" );
00985         std::vector< double > yCell( nLocalCells );
00986         success = NCFUNCAG( _vara_double )( _fileId, yCellVarId, &read_start, &read_count, &yCell[0] );
00987         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read yCell data" );
00988
00989         // Read z coordinates of cell centers
00990         int zCellVarId;
00991         success = NCFUNC( inq_varid )( _fileId, "zCell", &zCellVarId );
00992         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of zCell" );
00993         std::vector< double > zCell( nLocalCells );
00994         success = NCFUNCAG( _vara_double )( _fileId, zCellVarId, &read_start, &read_count, &zCell[0] );
00995         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read zCell data" );
00996
00997         // Zoltan partition using RCB; maybe more studies would be good, as to which partition
00998         // is better
00999         Interface*& mbImpl         = _readNC->mbImpl;
01000         DebugOutput& dbgOut        = _readNC->dbgOut;
01001         ZoltanPartitioner* mbZTool = new ZoltanPartitioner( mbImpl, pco, false, 0, NULL );
01002         ErrorCode rval             = mbZTool->repartition( xCell, yCell, zCell, start_cell_idx, "RCB", localGidCells );MB_CHK_SET_ERR( rval, "Error in Zoltan partitioning" );
01003         delete mbZTool;
01004
01005         dbgOut.tprintf( 1, "After Zoltan partitioning, localGidCells.psize() = %d\n", (int)localGidCells.psize() );
01006         dbgOut.tprintf( 1, "                           localGidCells.size() = %d\n", (int)localGidCells.size() );
01007
01008         // This is important: local cells are now redistributed, so nLocalCells might be different!
01009         nLocalCells = localGidCells.size();
01010
01011         return MB_SUCCESS;
01012     }
01013 #endif
01014
01015     // By default, apply trivial partition
01016     localGidCells.insert( start_cell_idx, start_cell_idx + nLocalCells - 1 );
01017
01018     return MB_SUCCESS;
01019 }
01020 #endif
01021
01022 ErrorCode NCHelperMPAS::create_local_vertices( const std::vector< int >& vertices_on_local_cells,
01023                                                EntityHandle& start_vertex )
01024 {
01025     Interface*& mbImpl      = _readNC->mbImpl;
01026     Tag& mGlobalIdTag       = _readNC->mGlobalIdTag;
01027     const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
01028     DebugOutput& dbgOut     = _readNC->dbgOut;
01029
01030     // Make a copy of vertices_on_local_cells for sorting (keep original one to set cell
01031     // connectivity later)
01032     std::vector< int > vertices_on_local_cells_sorted( vertices_on_local_cells );
01033     std::sort( vertices_on_local_cells_sorted.begin(), vertices_on_local_cells_sorted.end() );
01034     std::copy( vertices_on_local_cells_sorted.rbegin(), vertices_on_local_cells_sorted.rend(),
01035                range_inserter( localGidVerts ) );
01036     nLocalVertices = localGidVerts.size();
01037
01038     dbgOut.tprintf( 1, "   localGidVerts.psize() = %d\n", (int)localGidVerts.psize() );
01039     dbgOut.tprintf( 1, "   localGidVerts.size() = %d\n", (int)localGidVerts.size() );
01040
01041     // Create local vertices
01042     std::vector< double* > arrays;
01043     ErrorCode rval =
01044         _readNC->readMeshIface->get_node_coords( 3, nLocalVertices, 0, start_vertex, arrays,
01045                                                  // Might have to create gather mesh later
01046                                                  ( createGatherSet ? nLocalVertices + nVertices : nLocalVertices ) );MB_CHK_SET_ERR( rval, "Failed to create local vertices" );
01047
01048     // Add local vertices to current file set
01049     Range local_verts_range( start_vertex, start_vertex + nLocalVertices - 1 );
01050     rval = _readNC->mbImpl->add_entities( _fileSet, local_verts_range );MB_CHK_SET_ERR( rval, "Failed to add local vertices to current file set" );
01051
01052     // Get ptr to GID memory for local vertices
01053     int count  = 0;
01054     void* data = NULL;
01055     rval       = mbImpl->tag_iterate( mGlobalIdTag, local_verts_range.begin(), local_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local vertices" );
01056     assert( count == nLocalVertices );
01057     int* gid_data = (int*)data;
01058     std::copy( localGidVerts.begin(), localGidVerts.end(), gid_data );
01059
01060     // Duplicate GID data, which will be used to resolve sharing
01061     if( mpFileIdTag )
01062     {
01063         rval = mbImpl->tag_iterate( *mpFileIdTag, local_verts_range.begin(), local_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on local vertices" );
01064         assert( count == nLocalVertices );
01065         int bytes_per_tag = 4;
01066         rval              = mbImpl->tag_get_bytes( *mpFileIdTag, bytes_per_tag );MB_CHK_SET_ERR( rval, "Can't get number of bytes for file id tag" );
01067         if( 4 == bytes_per_tag )
01068         {
01069             gid_data = (int*)data;
01070             std::copy( localGidVerts.begin(), localGidVerts.end(), gid_data );
01071         }
01072         else if( 8 == bytes_per_tag )
01073         {  // Should be a handle tag on 64 bit machine?
01074             long* handle_tag_data = (long*)data;
01075             std::copy( localGidVerts.begin(), localGidVerts.end(), handle_tag_data );
01076         }
01077     }
01078
01079 #ifdef MOAB_HAVE_PNETCDF
01080     size_t nb_reads = localGidVerts.psize();
01081     std::vector< int > requests( nb_reads );
01082     std::vector< int > statuss( nb_reads );
01083     size_t idxReq = 0;
01084 #endif
01085
01086     // Read x coordinates for local vertices
01087     double* xptr = arrays[0];
01088     int xVertexVarId;
01089     int success = NCFUNC( inq_varid )( _fileId, "xVertex", &xVertexVarId );
01090     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of xVertex" );
01091     size_t indexInArray = 0;
01092     for( Range::pair_iterator pair_iter = localGidVerts.pair_begin(); pair_iter != localGidVerts.pair_end();
01093          ++pair_iter )
01094     {
01095         EntityHandle starth  = pair_iter->first;
01096         EntityHandle endh    = pair_iter->second;
01097         NCDF_SIZE read_start = (NCDF_SIZE)( starth - 1 );
01098         NCDF_SIZE read_count = (NCDF_SIZE)( endh - starth + 1 );
01099
01100         // Do a partial read in each subrange
01101 #ifdef MOAB_HAVE_PNETCDF
01102         success = NCFUNCREQG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, &( xptr[indexInArray] ),
01103                                               &requests[idxReq++] );
01104 #else
01105         success = NCFUNCAG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, &( xptr[indexInArray] ) );
01106 #endif
01107         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read xVertex data in a loop" );
01108
01109         // Increment the index for next subrange
01110         indexInArray += ( endh - starth + 1 );
01111     }
01112
01113 #ifdef MOAB_HAVE_PNETCDF
01114     // Wait outside the loop
01115     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
01116     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
01117 #endif
01118
01119     // Read y coordinates for local vertices
01120     double* yptr = arrays[1];
01121     int yVertexVarId;
01122     success = NCFUNC( inq_varid )( _fileId, "yVertex", &yVertexVarId );
01123     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of yVertex" );
01124 #ifdef MOAB_HAVE_PNETCDF
01125     idxReq = 0;
01126 #endif
01127     indexInArray = 0;
01128     for( Range::pair_iterator pair_iter = localGidVerts.pair_begin(); pair_iter != localGidVerts.pair_end();
01129          ++pair_iter )
01130     {
01131         EntityHandle starth  = pair_iter->first;
01132         EntityHandle endh    = pair_iter->second;
01133         NCDF_SIZE read_start = (NCDF_SIZE)( starth - 1 );
01134         NCDF_SIZE read_count = (NCDF_SIZE)( endh - starth + 1 );
01135
01136         // Do a partial read in each subrange
01137 #ifdef MOAB_HAVE_PNETCDF
01138         success = NCFUNCREQG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, &( yptr[indexInArray] ),
01139                                               &requests[idxReq++] );
01140 #else
01141         success = NCFUNCAG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, &( yptr[indexInArray] ) );
01142 #endif
01143         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read yVertex data in a loop" );
01144
01145         // Increment the index for next subrange
01146         indexInArray += ( endh - starth + 1 );
01147     }
01148
01149 #ifdef MOAB_HAVE_PNETCDF
01150     // Wait outside the loop
01151     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
01152     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
01153 #endif
01154
01155     // Read z coordinates for local vertices
01156     double* zptr = arrays[2];
01157     int zVertexVarId;
01158     success = NCFUNC( inq_varid )( _fileId, "zVertex", &zVertexVarId );
01159     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of zVertex" );
01160 #ifdef MOAB_HAVE_PNETCDF
01161     idxReq = 0;
01162 #endif
01163     indexInArray = 0;
01164     for( Range::pair_iterator pair_iter = localGidVerts.pair_begin(); pair_iter != localGidVerts.pair_end();
01165          ++pair_iter )
01166     {
01167         EntityHandle starth  = pair_iter->first;
01168         EntityHandle endh    = pair_iter->second;
01169         NCDF_SIZE read_start = (NCDF_SIZE)( starth - 1 );
01170         NCDF_SIZE read_count = (NCDF_SIZE)( endh - starth + 1 );
01171
01172         // Do a partial read in each subrange
01173 #ifdef MOAB_HAVE_PNETCDF
01174         success = NCFUNCREQG( _vara_double )( _fileId, zVertexVarId, &read_start, &read_count, &( zptr[indexInArray] ),
01175                                               &requests[idxReq++] );
01176 #else
01177         success = NCFUNCAG( _vara_double )( _fileId, zVertexVarId, &read_start, &read_count, &( zptr[indexInArray] ) );
01178 #endif
01179         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read zVertex data in a loop" );
01180
01181         // Increment the index for next subrange
01182         indexInArray += ( endh - starth + 1 );
01183     }
01184
01185 #ifdef MOAB_HAVE_PNETCDF
01186     // Wait outside the loop
01187     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
01188     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
01189 #endif
01190
01191     return MB_SUCCESS;
01192 }
01193
01194 ErrorCode NCHelperMPAS::create_local_edges( EntityHandle start_vertex,
01195                                             const std::vector< int >& num_edges_on_local_cells )
01196 {
01197     Interface*& mbImpl  = _readNC->mbImpl;
01198     Tag& mGlobalIdTag   = _readNC->mGlobalIdTag;
01199     DebugOutput& dbgOut = _readNC->dbgOut;
01200
01201     // Read edges on each local cell, to get localGidEdges
01202     int edgesOnCellVarId;
01203     int success = NCFUNC( inq_varid )( _fileId, "edgesOnCell", &edgesOnCellVarId );
01204     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of edgesOnCell" );
01205
01206     std::vector< int > edges_on_local_cells( nLocalCells * maxEdgesPerCell );
01207     dbgOut.tprintf( 1, "   edges_on_local_cells.size() = %d\n", (int)edges_on_local_cells.size() );
01208
01209 #ifdef MOAB_HAVE_PNETCDF
01210     size_t nb_reads = localGidCells.psize();
01211     std::vector< int > requests( nb_reads );
01212     std::vector< int > statuss( nb_reads );
01213     size_t idxReq = 0;
01214 #endif
01215     size_t indexInArray = 0;
01216     for( Range::pair_iterator pair_iter = localGidCells.pair_begin(); pair_iter != localGidCells.pair_end();
01217          ++pair_iter )
01218     {
01219         EntityHandle starth      = pair_iter->first;
01220         EntityHandle endh        = pair_iter->second;
01221         NCDF_SIZE read_starts[2] = { static_cast< NCDF_SIZE >( starth - 1 ), 0 };
01222         NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ),
01223                                      static_cast< NCDF_SIZE >( maxEdgesPerCell ) };
01224
01225         // Do a partial read in each subrange
01226 #ifdef MOAB_HAVE_PNETCDF
01227         success = NCFUNCREQG( _vara_int )( _fileId, edgesOnCellVarId, read_starts, read_counts,
01228                                            &( edges_on_local_cells[indexInArray] ), &requests[idxReq++] );
01229 #else
01230         success = NCFUNCAG( _vara_int )( _fileId, edgesOnCellVarId, read_starts, read_counts,
01231                                          &( edges_on_local_cells[indexInArray] ) );
01232 #endif
01233         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read edgesOnCell data in a loop" );
01234
01235         // Increment the index for next subrange
01236         indexInArray += ( endh - starth + 1 ) * maxEdgesPerCell;
01237     }
01238
01239 #ifdef MOAB_HAVE_PNETCDF
01240     // Wait outside the loop
01241     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
01242     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
01243 #endif
01244
01245     // Correct local cell edges array in the same way as local cell vertices array, replace the
01246     // padded edges with the last edges in the corresponding cells
01247     for( int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++ )
01248     {
01249         int num_edges             = num_edges_on_local_cells[local_cell_idx];
01250         int idx_in_local_edge_arr = local_cell_idx * maxEdgesPerCell;
01251         int last_edge_idx         = edges_on_local_cells[idx_in_local_edge_arr + num_edges - 1];
01252         for( int i = num_edges; i < maxEdgesPerCell; i++ )
01253             edges_on_local_cells[idx_in_local_edge_arr + i] = last_edge_idx;
01254     }
01255
01256     // Collect local edges
01257     std::sort( edges_on_local_cells.begin(), edges_on_local_cells.end() );
01258     std::copy( edges_on_local_cells.rbegin(), edges_on_local_cells.rend(), range_inserter( localGidEdges ) );
01259     nLocalEdges = localGidEdges.size();
01260
01261     dbgOut.tprintf( 1, "   localGidEdges.psize() = %d\n", (int)localGidEdges.psize() );
01262     dbgOut.tprintf( 1, "   localGidEdges.size() = %d\n", (int)localGidEdges.size() );
01263
01264     // Create local edges
01265     EntityHandle start_edge;
01266     EntityHandle* conn_arr_edges = NULL;
01267     ErrorCode rval =
01268         _readNC->readMeshIface->get_element_connect( nLocalEdges, 2, MBEDGE, 0, start_edge, conn_arr_edges,
01269                                                      // Might have to create gather mesh later
01270                                                      ( createGatherSet ? nLocalEdges + nEdges : nLocalEdges ) );MB_CHK_SET_ERR( rval, "Failed to create local edges" );
01271
01272     // Add local edges to current file set
01273     Range local_edges_range( start_edge, start_edge + nLocalEdges - 1 );
01274     rval = _readNC->mbImpl->add_entities( _fileSet, local_edges_range );MB_CHK_SET_ERR( rval, "Failed to add local edges to current file set" );
01275
01276     // Get ptr to GID memory for edges
01277     int count  = 0;
01278     void* data = NULL;
01279     rval       = mbImpl->tag_iterate( mGlobalIdTag, local_edges_range.begin(), local_edges_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local edges" );
01280     assert( count == nLocalEdges );
01281     int* gid_data = (int*)data;
01282     std::copy( localGidEdges.begin(), localGidEdges.end(), gid_data );
01283
01284     int verticesOnEdgeVarId;
01285
01286     // Read vertices on each local edge, to get edge connectivity
01287     success = NCFUNC( inq_varid )( _fileId, "verticesOnEdge", &verticesOnEdgeVarId );
01288     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of verticesOnEdge" );
01289     // Utilize the memory storage pointed by conn_arr_edges
01290     int* vertices_on_local_edges = (int*)conn_arr_edges;
01291 #ifdef MOAB_HAVE_PNETCDF
01292     nb_reads = localGidEdges.psize();
01293     requests.resize( nb_reads );
01294     statuss.resize( nb_reads );
01295     idxReq = 0;
01296 #endif
01297     indexInArray = 0;
01298     for( Range::pair_iterator pair_iter = localGidEdges.pair_begin(); pair_iter != localGidEdges.pair_end();
01299          ++pair_iter )
01300     {
01301         EntityHandle starth      = pair_iter->first;
01302         EntityHandle endh        = pair_iter->second;
01303         NCDF_SIZE read_starts[2] = { static_cast< NCDF_SIZE >( starth - 1 ), 0 };
01304         NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( endh - starth + 1 ), 2 };
01305
01306         // Do a partial read in each subrange
01307 #ifdef MOAB_HAVE_PNETCDF
01308         success = NCFUNCREQG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts,
01309                                            &( vertices_on_local_edges[indexInArray] ), &requests[idxReq++] );
01310 #else
01311         success = NCFUNCAG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts,
01312                                          &( vertices_on_local_edges[indexInArray] ) );
01313 #endif
01314         if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnEdge data in a loop" );
01315
01316         // Increment the index for next subrange
01317         indexInArray += ( endh - starth + 1 ) * 2;
01318     }
01319
01320 #ifdef MOAB_HAVE_PNETCDF
01321     // Wait outside the loop
01322     success = NCFUNC( wait_all )( _fileId, requests.size(), &requests[0], &statuss[0] );
01323     if( success ) MB_SET_ERR( MB_FAILURE, "Failed on wait_all" );
01324 #endif
01325
01326     // Populate connectivity data for local edges
01327     // Convert in-place from int (stored in the first half) to EntityHandle
01328     // Reading backward is the trick
01329     for( int edge_vert = nLocalEdges * 2 - 1; edge_vert >= 0; edge_vert-- )
01330     {
01331         int global_vert_idx = vertices_on_local_edges[edge_vert];      // Global vertex index, 1 based
01332         int local_vert_idx  = localGidVerts.index( global_vert_idx );  // Local vertex index, 0 based
01333         assert( local_vert_idx != -1 );
01334         conn_arr_edges[edge_vert] = start_vertex + local_vert_idx;
01335     }
01336
01337     return MB_SUCCESS;
01338 }
01339
01340 ErrorCode NCHelperMPAS::create_local_cells( const std::vector< int >& vertices_on_local_cells,
01341                                             const std::vector< int >& num_edges_on_local_cells,
01342                                             EntityHandle start_vertex,
01343                                             Range& faces )
01344 {
01345     Interface*& mbImpl = _readNC->mbImpl;
01346     Tag& mGlobalIdTag  = _readNC->mGlobalIdTag;
01347
01348     // Divide local cells into groups based on the number of edges
01349     Range local_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
01350     // Insert larger values before smaller ones to increase efficiency
01351     for( int i = nLocalCells - 1; i >= 0; i-- )
01352     {
01353         int num_edges = num_edges_on_local_cells[i];
01354         local_cells_with_n_edges[num_edges].insert( localGidCells[i] );  // Global cell index
01355     }
01356
01357     std::vector< int > num_edges_on_cell_groups;
01358     for( int i = 3; i <= maxEdgesPerCell; i++ )
01359     {
01360         if( local_cells_with_n_edges[i].size() > 0 ) num_edges_on_cell_groups.push_back( i );
01361     }
01362     numCellGroups = num_edges_on_cell_groups.size();
01363
01364     EntityHandle* conn_arr_local_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
01365     for( int i = 0; i < numCellGroups; i++ )
01366     {
01367         int num_edges_per_cell = num_edges_on_cell_groups[i];
01368         int num_group_cells    = (int)local_cells_with_n_edges[num_edges_per_cell].size();
01369
01370         // Create local cells for each non-empty cell group
01371         EntityHandle start_element;
01372         ErrorCode rval = _readNC->readMeshIface->get_element_connect(
01373             num_group_cells, num_edges_per_cell, MBPOLYGON, 0, start_element,
01374             conn_arr_local_cells_with_n_edges[num_edges_per_cell], num_group_cells );MB_CHK_SET_ERR( rval, "Failed to create local cells" );
01375         faces.insert( start_element, start_element + num_group_cells - 1 );
01376
01377         // Add local cells to current file set
01378         Range local_cells_range( start_element, start_element + num_group_cells - 1 );
01379         rval = _readNC->mbImpl->add_entities( _fileSet, local_cells_range );MB_CHK_SET_ERR( rval, "Failed to add local cells to current file set" );
01380
01381         // Get ptr to gid memory for local cells
01382         int count  = 0;
01383         void* data = NULL;
01384         rval = mbImpl->tag_iterate( mGlobalIdTag, local_cells_range.begin(), local_cells_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local cells" );
01385         assert( count == num_group_cells );
01386         int* gid_data = (int*)data;
01387         std::copy( local_cells_with_n_edges[num_edges_per_cell].begin(),
01388                    local_cells_with_n_edges[num_edges_per_cell].end(), gid_data );
01389
01390         // Set connectivity array with proper local vertices handles
01391         for( int j = 0; j < num_group_cells; j++ )
01392         {
01393             EntityHandle global_cell_idx =
01394                 local_cells_with_n_edges[num_edges_per_cell][j];          // Global cell index, 1 based
01395             int local_cell_idx = localGidCells.index( global_cell_idx );  // Local cell index, 0 based
01396             assert( local_cell_idx != -1 );
01397
01398             if( numCellGroups > 1 )
01399             {
01400                 // Populate cellHandleToGlobalID map to read cell variables
01401                 cellHandleToGlobalID[start_element + j] = global_cell_idx;
01402             }
01403
01404             for( int k = 0; k < num_edges_per_cell; k++ )
01405             {
01406                 EntityHandle global_vert_idx =
01407                     vertices_on_local_cells[local_cell_idx * maxEdgesPerCell + k];  // Global vertex index, 1 based
01408                 int local_vert_idx = localGidVerts.index( global_vert_idx );        // Local vertex index, 0 based
01409                 assert( local_vert_idx != -1 );
01410                 conn_arr_local_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
01411                     start_vertex + local_vert_idx;
01412             }
01413         }
01414     }
01415
01416     return MB_SUCCESS;
01417 }
01418
01419 ErrorCode NCHelperMPAS::create_padded_local_cells( const std::vector< int >& vertices_on_local_cells,
01420                                                    EntityHandle start_vertex,
01421                                                    Range& faces )
01422 {
01423     Interface*& mbImpl = _readNC->mbImpl;
01424     Tag& mGlobalIdTag  = _readNC->mGlobalIdTag;
01425
01426     // Only one group of cells (each cell is represented by a polygon with maxEdgesPerCell edges)
01427     numCellGroups = 1;
01428
01429     // Create cells for this cell group
01430     EntityHandle start_element;
01431     EntityHandle* conn_arr_local_cells = NULL;
01432     ErrorCode rval =
01433         _readNC->readMeshIface->get_element_connect( nLocalCells, maxEdgesPerCell, MBPOLYGON, 0, start_element,
01434                                                      conn_arr_local_cells,
01435                                                      // Might have to create gather mesh later
01436                                                      ( createGatherSet ? nLocalCells + nCells : nLocalCells ) );MB_CHK_SET_ERR( rval, "Failed to create local cells" );
01437     faces.insert( start_element, start_element + nLocalCells - 1 );
01438
01439     // Add local cells to current file set
01440     Range local_cells_range( start_element, start_element + nLocalCells - 1 );
01441     rval = _readNC->mbImpl->add_entities( _fileSet, local_cells_range );MB_CHK_SET_ERR( rval, "Failed to add local cells to current file set" );
01442
01443     // Get ptr to GID memory for local cells
01444     int count  = 0;
01445     void* data = NULL;
01446     rval       = mbImpl->tag_iterate( mGlobalIdTag, local_cells_range.begin(), local_cells_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on local cells" );
01447     assert( count == nLocalCells );
01448     int* gid_data = (int*)data;
01449     std::copy( localGidCells.begin(), localGidCells.end(), gid_data );
01450
01451     // Set connectivity array with proper local vertices handles
01452     // vertices_on_local_cells array was already corrected to have the last vertices padded
01453     // no need for extra checks considering
01454     for( int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++ )
01455     {
01456         for( int i = 0; i < maxEdgesPerCell; i++ )
01457         {
01458             EntityHandle global_vert_idx =
01459                 vertices_on_local_cells[local_cell_idx * maxEdgesPerCell + i];  // Global vertex index, 1 based
01460             int local_vert_idx = localGidVerts.index( global_vert_idx );        // Local vertex index, 0 based
01461             assert( local_vert_idx != -1 );
01462             conn_arr_local_cells[local_cell_idx * maxEdgesPerCell + i] = start_vertex + local_vert_idx;
01463         }
01464     }
01465
01466     return MB_SUCCESS;
01467 }
01468
01469 ErrorCode NCHelperMPAS::create_gather_set_vertices( EntityHandle gather_set, EntityHandle& gather_set_start_vertex )
01470 {
01471     Interface*& mbImpl      = _readNC->mbImpl;
01472     Tag& mGlobalIdTag       = _readNC->mGlobalIdTag;
01473     const Tag*& mpFileIdTag = _readNC->mpFileIdTag;
01474
01475     // Create gather set vertices
01476     std::vector< double* > arrays;
01477     // Don't need to specify allocation number here, because we know enough vertices were created
01478     // before
01479     ErrorCode rval = _readNC->readMeshIface->get_node_coords( 3, nVertices, 0, gather_set_start_vertex, arrays );MB_CHK_SET_ERR( rval, "Failed to create gather set vertices" );
01480
01481     // Add vertices to the gather set
01482     Range gather_set_verts_range( gather_set_start_vertex, gather_set_start_vertex + nVertices - 1 );
01483     rval = mbImpl->add_entities( gather_set, gather_set_verts_range );MB_CHK_SET_ERR( rval, "Failed to add vertices to the gather set" );
01484
01485     // Read x coordinates for gather set vertices
01486     double* xptr = arrays[0];
01487     int xVertexVarId;
01488     int success = NCFUNC( inq_varid )( _fileId, "xVertex", &xVertexVarId );
01489     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of xVertex" );
01490     NCDF_SIZE read_start = 0;
01491     NCDF_SIZE read_count = static_cast< NCDF_SIZE >( nVertices );
01492 #ifdef MOAB_HAVE_PNETCDF
01493     // Enter independent I/O mode, since this read is only for the gather processor
01494     success = NCFUNC( begin_indep_data )( _fileId );
01495     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01496     success = NCFUNCG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, xptr );
01497     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read xVertex data" );
01498     success = NCFUNC( end_indep_data )( _fileId );
01499     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01500 #else
01501     success = NCFUNCG( _vara_double )( _fileId, xVertexVarId, &read_start, &read_count, xptr );
01502     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read xVertex data" );
01503 #endif
01504
01505     // Read y coordinates for gather set vertices
01506     double* yptr = arrays[1];
01507     int yVertexVarId;
01508     success = NCFUNC( inq_varid )( _fileId, "yVertex", &yVertexVarId );
01509     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of yVertex" );
01510 #ifdef MOAB_HAVE_PNETCDF
01511     // Enter independent I/O mode, since this read is only for the gather processor
01512     success = NCFUNC( begin_indep_data )( _fileId );
01513     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01514     success = NCFUNCG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, yptr );
01515     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read yVertex data" );
01516     success = NCFUNC( end_indep_data )( _fileId );
01517     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01518 #else
01519     success = NCFUNCG( _vara_double )( _fileId, yVertexVarId, &read_start, &read_count, yptr );
01520     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read yVertex data" );
01521 #endif
01522
01523     // Read z coordinates for gather set vertices
01524     double* zptr = arrays[2];
01525     int zVertexVarId;
01526     success = NCFUNC( inq_varid )( _fileId, "zVertex", &zVertexVarId );
01527     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of zVertex" );
01528 #ifdef MOAB_HAVE_PNETCDF
01529     // Enter independent I/O mode, since this read is only for the gather processor
01530     success = NCFUNC( begin_indep_data )( _fileId );
01531     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01532     success = NCFUNCG( _vara_double )( _fileId, zVertexVarId, &read_start, &read_count, zptr );
01533     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read zVertex data" );
01534     success = NCFUNC( end_indep_data )( _fileId );
01535     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01536 #else
01537     success = NCFUNCG( _vara_double )( _fileId, zVertexVarId, &read_start, &read_count, zptr );
01538     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read zVertex data" );
01539 #endif
01540
01541     // Get ptr to GID memory for gather set vertices
01542     int count  = 0;
01543     void* data = NULL;
01544     rval =
01545         mbImpl->tag_iterate( mGlobalIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count, data );MB_CHK_SET_ERR( rval, "Failed to iterate global id tag on gather set vertices" );
01546     assert( count == nVertices );
01547     int* gid_data = (int*)data;
01548     for( int j = 1; j <= nVertices; j++ )
01549         gid_data[j - 1] = j;
01550
01551     // Set the file id tag too, it should be bigger something not interfering with global id
01552     if( mpFileIdTag )
01553     {
01554         rval = mbImpl->tag_iterate( *mpFileIdTag, gather_set_verts_range.begin(), gather_set_verts_range.end(), count,
01555                                     data );MB_CHK_SET_ERR( rval, "Failed to iterate file id tag on gather set vertices" );
01556         assert( count == nVertices );
01557         int bytes_per_tag = 4;
01558         rval              = mbImpl->tag_get_bytes( *mpFileIdTag, bytes_per_tag );MB_CHK_SET_ERR( rval, "Can't get number of bytes for file id tag" );
01559         if( 4 == bytes_per_tag )
01560         {
01561             gid_data = (int*)data;
01562             for( int j = 1; j <= nVertices; j++ )
01563                 gid_data[j - 1] = nVertices + j;  // Bigger than global id tag
01564         }
01565         else if( 8 == bytes_per_tag )
01566         {  // Should be a handle tag on 64 bit machine?
01567             long* handle_tag_data = (long*)data;
01568             for( int j = 1; j <= nVertices; j++ )
01569                 handle_tag_data[j - 1] = nVertices + j;  // Bigger than global id tag
01570         }
01571     }
01572
01573     return MB_SUCCESS;
01574 }
01575
01576 ErrorCode NCHelperMPAS::create_gather_set_edges( EntityHandle gather_set, EntityHandle gather_set_start_vertex )
01577 {
01578     Interface*& mbImpl = _readNC->mbImpl;
01579
01580     // Create gather set edges
01581     EntityHandle start_edge;
01582     EntityHandle* conn_arr_gather_set_edges = NULL;
01583     // Don't need to specify allocation number here, because we know enough edges were created
01584     // before
01585     ErrorCode rval =
01586         _readNC->readMeshIface->get_element_connect( nEdges, 2, MBEDGE, 0, start_edge, conn_arr_gather_set_edges );MB_CHK_SET_ERR( rval, "Failed to create gather set edges" );
01587
01588     // Add edges to the gather set
01589     Range gather_set_edges_range( start_edge, start_edge + nEdges - 1 );
01590     rval = mbImpl->add_entities( gather_set, gather_set_edges_range );MB_CHK_SET_ERR( rval, "Failed to add edges to the gather set" );
01591
01592     // Read vertices on each edge
01593     int verticesOnEdgeVarId;
01594     int success = NCFUNC( inq_varid )( _fileId, "verticesOnEdge", &verticesOnEdgeVarId );
01595     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of verticesOnEdge" );
01596     // Utilize the memory storage pointed by conn_arr_gather_set_edges
01597     int* vertices_on_gather_set_edges = (int*)conn_arr_gather_set_edges;
01598     NCDF_SIZE read_starts[2]          = { 0, 0 };
01599     NCDF_SIZE read_counts[2]          = { static_cast< NCDF_SIZE >( nEdges ), 2 };
01600 #ifdef MOAB_HAVE_PNETCDF
01601     // Enter independent I/O mode, since this read is only for the gather processor
01602     success = NCFUNC( begin_indep_data )( _fileId );
01603     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01604     success =
01605         NCFUNCG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts, vertices_on_gather_set_edges );
01606     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnEdge data" );
01607     success = NCFUNC( end_indep_data )( _fileId );
01608     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01609 #else
01610     success =
01611         NCFUNCG( _vara_int )( _fileId, verticesOnEdgeVarId, read_starts, read_counts, vertices_on_gather_set_edges );
01612     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnEdge data" );
01613 #endif
01614
01615     // Populate connectivity data for gather set edges
01616     // Convert in-place from int (stored in the first half) to EntityHandle
01617     // Reading backward is the trick
01618     for( int edge_vert = nEdges * 2 - 1; edge_vert >= 0; edge_vert-- )
01619     {
01620         int gather_set_vert_idx = vertices_on_gather_set_edges[edge_vert];  // Global vertex index, 1 based
01621         gather_set_vert_idx--;                                              // 1 based -> 0 based
01622         // Connectivity array is shifted by where the gather set vertices start
01623         conn_arr_gather_set_edges[edge_vert] = gather_set_start_vertex + gather_set_vert_idx;
01624     }
01625
01626     return MB_SUCCESS;
01627 }
01628
01629 ErrorCode NCHelperMPAS::create_gather_set_cells( EntityHandle gather_set, EntityHandle gather_set_start_vertex )
01630 {
01631     Interface*& mbImpl = _readNC->mbImpl;
01632
01633     // Read number of edges on each gather set cell
01634     int nEdgesOnCellVarId;
01635     int success = NCFUNC( inq_varid )( _fileId, "nEdgesOnCell", &nEdgesOnCellVarId );
01636     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of nEdgesOnCell" );
01637     std::vector< int > num_edges_on_gather_set_cells( nCells );
01638     NCDF_SIZE read_start = 0;
01639     NCDF_SIZE read_count = static_cast< NCDF_SIZE >( nCells );
01640 #ifdef MOAB_HAVE_PNETCDF
01641     // Enter independent I/O mode, since this read is only for the gather processor
01642     success = NCFUNC( begin_indep_data )( _fileId );
01643     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01644     success =
01645         NCFUNCG( _vara_int )( _fileId, nEdgesOnCellVarId, &read_start, &read_count, &num_edges_on_gather_set_cells[0] );
01646     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read nEdgesOnCell data" );
01647     success = NCFUNC( end_indep_data )( _fileId );
01648     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01649 #else
01650     success =
01651         NCFUNCG( _vara_int )( _fileId, nEdgesOnCellVarId, &read_start, &read_count, &num_edges_on_gather_set_cells[0] );
01652     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read nEdgesOnCell data" );
01653 #endif
01654
01655     // Read vertices on each gather set cell (connectivity)
01656     int verticesOnCellVarId;
01657     success = NCFUNC( inq_varid )( _fileId, "verticesOnCell", &verticesOnCellVarId );
01658     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of verticesOnCell" );
01659     std::vector< int > vertices_on_gather_set_cells( nCells * maxEdgesPerCell );
01660     NCDF_SIZE read_starts[2] = { 0, 0 };
01661     NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( nCells ), static_cast< NCDF_SIZE >( maxEdgesPerCell ) };
01662 #ifdef MOAB_HAVE_PNETCDF
01663     // Enter independent I/O mode, since this read is only for the gather processor
01664     success = NCFUNC( begin_indep_data )( _fileId );
01665     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01666     success = NCFUNCG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
01667                                     &vertices_on_gather_set_cells[0] );
01668     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnCell data" );
01669     success = NCFUNC( end_indep_data )( _fileId );
01670     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01671 #else
01672     success = NCFUNCG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts,
01673                                     &vertices_on_gather_set_cells[0] );
01674     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnCell data" );
01675 #endif
01676
01677     // Divide gather set cells into groups based on the number of edges
01678     Range gather_set_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
01679     // Insert larger values before smaller values to increase efficiency
01680     for( int i = nCells - 1; i >= 0; i-- )
01681     {
01682         int num_edges = num_edges_on_gather_set_cells[i];
01683         gather_set_cells_with_n_edges[num_edges].insert( i + 1 );  // 0 based -> 1 based
01684     }
01685
01686     // Create gather set cells
01687     EntityHandle* conn_arr_gather_set_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
01688     for( int num_edges_per_cell = 3; num_edges_per_cell <= maxEdgesPerCell; num_edges_per_cell++ )
01689     {
01690         int num_group_cells = gather_set_cells_with_n_edges[num_edges_per_cell].size();
01691         if( num_group_cells > 0 )
01692         {
01693             EntityHandle start_element;
01694             ErrorCode rval = _readNC->readMeshIface->get_element_connect(
01695                 num_group_cells, num_edges_per_cell, MBPOLYGON, 0, start_element,
01696                 conn_arr_gather_set_cells_with_n_edges[num_edges_per_cell], num_group_cells );MB_CHK_SET_ERR( rval, "Failed to create gather set cells" );
01697
01698             // Add cells to the gather set
01699             Range gather_set_cells_range( start_element, start_element + num_group_cells - 1 );
01700             rval = mbImpl->add_entities( gather_set, gather_set_cells_range );MB_CHK_SET_ERR( rval, "Failed to add cells to the gather set" );
01701
01702             for( int j = 0; j < num_group_cells; j++ )
01703             {
01704                 int gather_set_cell_idx =
01705                     gather_set_cells_with_n_edges[num_edges_per_cell][j];  // Global cell index, 1 based
01706                 gather_set_cell_idx--;                                     // 1 based -> 0 based
01707
01708                 for( int k = 0; k < num_edges_per_cell; k++ )
01709                 {
01710                     EntityHandle gather_set_vert_idx =
01711                         vertices_on_gather_set_cells[gather_set_cell_idx * maxEdgesPerCell +
01712                                                      k];  // Global vertex index, 1 based
01713                     gather_set_vert_idx--;                // 1 based -> 0 based
01714
01715                     // Connectivity array is shifted by where the gather set vertices start
01716                     conn_arr_gather_set_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
01717                         gather_set_start_vertex + gather_set_vert_idx;
01718                 }
01719             }
01720         }
01721     }
01722
01723     return MB_SUCCESS;
01724 }
01725
01726 ErrorCode NCHelperMPAS::create_padded_gather_set_cells( EntityHandle gather_set, EntityHandle gather_set_start_vertex )
01727 {
01728     Interface*& mbImpl = _readNC->mbImpl;
01729
01730     // Read number of edges on each gather set cell
01731     int nEdgesOnCellVarId;
01732     int success = NCFUNC( inq_varid )( _fileId, "nEdgesOnCell", &nEdgesOnCellVarId );
01733     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of nEdgesOnCell" );
01734     std::vector< int > num_edges_on_gather_set_cells( nCells );
01735     NCDF_SIZE read_start = 0;
01736     NCDF_SIZE read_count = static_cast< NCDF_SIZE >( nCells );
01737 #ifdef MOAB_HAVE_PNETCDF
01738     // Enter independent I/O mode, since this read is only for the gather processor
01739     success = NCFUNC( begin_indep_data )( _fileId );
01740     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01741     success =
01742         NCFUNCG( _vara_int )( _fileId, nEdgesOnCellVarId, &read_start, &read_count, &num_edges_on_gather_set_cells[0] );
01743     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read nEdgesOnCell data" );
01744     success = NCFUNC( end_indep_data )( _fileId );
01745     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01746 #else
01747     success =
01748         NCFUNCG( _vara_int )( _fileId, nEdgesOnCellVarId, &read_start, &read_count, &num_edges_on_gather_set_cells[0] );
01749     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read nEdgesOnCell data" );
01750 #endif
01751
01752     // Create gather set cells
01753     EntityHandle start_element;
01754     EntityHandle* conn_arr_gather_set_cells = NULL;
01755     // Don't need to specify allocation number here, because we know enough cells were created
01756     // before
01757     ErrorCode rval = _readNC->readMeshIface->get_element_connect( nCells, maxEdgesPerCell, MBPOLYGON, 0, start_element,
01758        conn_arr_gather_set_cells );MB_CHK_SET_ERR( rval, "Failed to create gather set cells" );
01759
01760     // Add cells to the gather set
01761     Range gather_set_cells_range( start_element, start_element + nCells - 1 );
01762     rval = mbImpl->add_entities( gather_set, gather_set_cells_range );MB_CHK_SET_ERR( rval, "Failed to add cells to the gather set" );
01763
01764     // Read vertices on each gather set cell (connectivity)
01765     int verticesOnCellVarId;
01766     success = NCFUNC( inq_varid )( _fileId, "verticesOnCell", &verticesOnCellVarId );
01767     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to get variable id of verticesOnCell" );
01768     // Utilize the memory storage pointed by conn_arr_gather_set_cells
01769     int* vertices_on_gather_set_cells = (int*)conn_arr_gather_set_cells;
01770     NCDF_SIZE read_starts[2]          = { 0, 0 };
01771     NCDF_SIZE read_counts[2] = { static_cast< NCDF_SIZE >( nCells ), static_cast< NCDF_SIZE >( maxEdgesPerCell ) };
01772 #ifdef MOAB_HAVE_PNETCDF
01773     // Enter independent I/O mode, since this read is only for the gather processor
01774     success = NCFUNC( begin_indep_data )( _fileId );
01775     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to begin independent I/O mode" );
01776     success =
01777         NCFUNCG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts, vertices_on_gather_set_cells );
01778     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnCell data" );
01779     success = NCFUNC( end_indep_data )( _fileId );
01780     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to end independent I/O mode" );
01781 #else
01782     success =
01783         NCFUNCG( _vara_int )( _fileId, verticesOnCellVarId, read_starts, read_counts, vertices_on_gather_set_cells );
01784     if( success ) MB_SET_ERR( MB_FAILURE, "Failed to read verticesOnCell data" );
01785 #endif
01786
01787     // Correct gather set cell vertices array in the same way as local cell vertices array,
01788     // replace the padded vertices with the last vertices in the corresponding cells
01789     for( int gather_set_cell_idx = 0; gather_set_cell_idx < nCells; gather_set_cell_idx++ )
01790     {
01791         int num_edges                  = num_edges_on_gather_set_cells[gather_set_cell_idx];
01792         int idx_in_gather_set_vert_arr = gather_set_cell_idx * maxEdgesPerCell;
01793         int last_vert_idx              = vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + num_edges - 1];
01794         for( int i = num_edges; i < maxEdgesPerCell; i++ )
01795             vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + i] = last_vert_idx;
01796     }
01797
01798     // Populate connectivity data for gather set cells
01799     // Convert in-place from int (stored in the first half) to EntityHandle
01800     // Reading backward is the trick
01801     for( int cell_vert = nCells * maxEdgesPerCell - 1; cell_vert >= 0; cell_vert-- )
01802     {
01803         int gather_set_vert_idx = vertices_on_gather_set_cells[cell_vert];  // Global vertex index, 1 based
01804         gather_set_vert_idx--;                                              // 1 based -> 0 based
01805         // Connectivity array is shifted by where the gather set vertices start
01806         conn_arr_gather_set_cells[cell_vert] = gather_set_start_vertex + gather_set_vert_idx;
01807     }
01808
01809     return MB_SUCCESS;
01810 }
01811
01812 }  // namespace moab
