QuadLagrangeShapeTest.cpp File Reference
#include "Mesquite.hpp"
#include "QuadLagrangeShape.hpp"
#include "TopologyInfo.hpp"
#include "MsqError.hpp"
#include "IdealElements.hpp"
#include "JacobianCalculator.hpp"
#include "UnitUtil.hpp"
#include <vector>
#include <algorithm>
#include <iostream>
#include <sstream>
+ Include dependency graph for QuadLagrangeShapeTest.cpp:
Classes
class  QuadLagrangeShapeTest
Defines
#define ASSERT_VALUES_EQUAL(v1, v2, location, bits)   ASSERT_MESSAGE( value_message( ( location ), ( bits ), ( v1 ), ( v2 ) ), ( fabs( ( v1 ) - ( v2 ) ) < epsilon ) )
Typedefs
typedef double(* N_t )(double, double)
typedef double(* f_t )(unsigned, double, double)
Enumerations
enum  { XI = 0, ETA = 1 }
Functions
static CppUnit::Message value_message (unsigned location, NodeSet bits, double v1, double v2)
 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (QuadLagrangeShapeTest,"QuadLagrangeShapeTest")
 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION (QuadLagrangeShapeTest,"Unit")
static double l11 (double xi)
static double l12 (double xi)
static double l22 (double xi)
static double dl11 (double)
static double dl12 (double)
static double dl22 (double xi)
static double N0 (double xi, double eta)
static double N1 (double xi, double eta)
static double N2 (double xi, double eta)
static double N3 (double xi, double eta)
static double N4 (double xi, double eta)
static double N5 (double xi, double eta)
static double N6 (double xi, double eta)
static double N7 (double xi, double eta)
static double N8 (double xi, double eta)
static double dN0dxi (double xi, double eta)
static double dN1dxi (double xi, double eta)
static double dN2dxi (double xi, double eta)
static double dN3dxi (double xi, double eta)
static double dN4dxi (double xi, double eta)
static double dN5dxi (double xi, double eta)
static double dN6dxi (double xi, double eta)
static double dN7dxi (double xi, double eta)
static double dN8dxi (double xi, double eta)
static double dN0deta (double xi, double eta)
static double dN1deta (double xi, double eta)
static double dN2deta (double xi, double eta)
static double dN3deta (double xi, double eta)
static double dN4deta (double xi, double eta)
static double dN5deta (double xi, double eta)
static double dN6deta (double xi, double eta)
static double dN7deta (double xi, double eta)
static double dN8deta (double xi, double eta)
static double N (unsigned i, double xi, double eta)
static double dNdxi (unsigned i, double xi, double eta)
static double dNdeta (unsigned i, double xi, double eta)
static void eval (f_t function, NodeSet nodeset, double xi, double eta, double results[9])
static void get_coeffs (NodeSet nodebits, double xi, double eta, double coeffs_out[9])
static void get_partial_wrt_xi (NodeSet nodebits, double xi, double eta, double derivs_out[9])
static void get_partial_wrt_eta (NodeSet nodebits, double xi, double eta, double derivs_out[9])
static void check_valid_indices (const size_t *vertices, size_t num_vtx, NodeSet nodeset)
static void check_no_zeros (const MsqVector< 2 > *derivs, size_t num_vtx)
static void compare_coefficients (const double *coeffs, const size_t *indices, size_t num_coeff, const double *expected_coeffs, unsigned loc, NodeSet bits)
static void compare_derivatives (const size_t *vertices, size_t num_vtx, const MsqVector< 2 > *derivs, const double *expected_dxi, const double *expected_deta, unsigned loc, NodeSet bits)
static NodeSet nodeset_from_bits (unsigned bits)
Variables
const double epsilon = 1e-6
const double min_xi = 0
const double max_xi = 1
const double mid_xi = 0.5 * ( min_xi + max_xi )
static const N_t N_a [9] = { &N0, &N1, &N2, &N3, &N4, &N5, &N6, &N7, &N8 }
static const N_t dNdxi_a [9] = { &dN0dxi, &dN1dxi, &dN2dxi, &dN3dxi, &dN4dxi, &dN5dxi, &dN6dxi, &dN7dxi, &dN8dxi }
static const N_t dNdeta_a [9]
static const double corners [4][2] = { { min_xi, min_xi }, { max_xi, min_xi }, { max_xi, max_xi }, { min_xi, max_xi } }
static const double midedge [4][2] = { { mid_xi, min_xi }, { max_xi, mid_xi }, { mid_xi, max_xi }, { min_xi, mid_xi } }
static const double midelem [2] = { mid_xi, mid_xi }
Detailed Description
Author:
Jason Kraftcheck
Definition in file QuadLagrangeShapeTest.cpp.
Define Documentation
#define ASSERT_VALUES_EQUAL (   v1,
  v2,
  location,
  bits
Definition at line 49 of file QuadLagrangeShapeTest.cpp.
Referenced by compare_coefficients(), and compare_derivatives().
Typedef Documentation
typedef double( * f_t)(unsigned, double, double)
Definition at line 315 of file QuadLagrangeShapeTest.cpp.
typedef double( * N_t)(double, double)
Definition at line 292 of file QuadLagrangeShapeTest.cpp.
Enumeration Type Documentation
anonymous enum
Enumerator:
XI
ETA
Definition at line 125 of file QuadLagrangeShapeTest.cpp.
    XI  = 0,
    ETA = 1
Function Documentation
static void check_no_zeros ( const MsqVector< 2 > *  derivs,
size_t  num_vtx
) [static]
Definition at line 399 of file QuadLagrangeShapeTest.cpp.
References CPPUNIT_ASSERT.
Referenced by compare_derivatives().
    for( unsigned i = 0; i < num_vtx; ++i )
        double dxi  = derivs[i][0];
        double deta = derivs[i][1];
        CPPUNIT_ASSERT( fabs( dxi ) > 1e-6 || fabs( deta ) > 1e-6 );
static void check_valid_indices ( const size_t *  vertices,
size_t  num_vtx,
NodeSet  nodeset
) [static]
Definition at line 375 of file QuadLagrangeShapeTest.cpp.
References CPPUNIT_ASSERT, MBMesquite::NodeSet::mid_edge_node(), and MBMesquite::NodeSet::mid_face_node().
    // check valid size of list (at least three, at most all nodes)
    CPPUNIT_ASSERT( num_vtx <= 9 );
    CPPUNIT_ASSERT( num_vtx >= 3 );
    // make sure vertex indices are valid (in [0,8])
    size_t vertcopy[9];
    std::copy( vertices, vertices + num_vtx, vertcopy );
    std::sort( vertcopy, vertcopy + num_vtx );
    CPPUNIT_ASSERT( vertcopy[num_vtx - 1] <= 8 );  // max value less than 9
                                                   // make sure there are no duplicates in the list
    const size_t* iter = std::unique( vertcopy, vertcopy + num_vtx );
    CPPUNIT_ASSERT( iter == vertcopy + num_vtx );
    // make all vertices are present in element
        if( vertcopy[i] == 8 )
            CPPUNIT_ASSERT( nodeset.mid_face_node( 0 ) );
        else if( vertcopy[i] >= 4 )
            CPPUNIT_ASSERT( nodeset.mid_edge_node( vertcopy[i] - 4 ) );
static void compare_coefficients ( const double *  coeffs,
const size_t *  indices,
size_t  num_coeff,
const double *  expected_coeffs,
unsigned  loc,
NodeSet  bits
) [static]
Definition at line 409 of file QuadLagrangeShapeTest.cpp.
References ASSERT_VALUES_EQUAL, CPPUNIT_ASSERT, MBMesquite::NodeSet::mid_edge_node(), and MBMesquite::NodeSet::mid_face_node().
Referenced by QuadLagrangeShapeTest::test_corner_coeff(), QuadLagrangeShapeTest::test_edge_coeff(), and QuadLagrangeShapeTest::test_mid_coeff().
    // find the location in the returned list for each node
    size_t revidx[9];
    double test_vals[9];
    for( size_t i = 0; i < 9; ++i )
        revidx[i]    = std::find( indices, indices + num_coeff, i ) - indices;
        test_vals[i] = ( revidx[i] == num_coeff ) ? 0.0 : coeffs[revidx[i]];
    // Check that index list doesn't contain any nodes not actually
    // present in the element.
    CPPUNIT_ASSERT( bits.mid_edge_node( 0 ) || ( revidx[4] == num_coeff ) );
    CPPUNIT_ASSERT( bits.mid_edge_node( 1 ) || ( revidx[5] == num_coeff ) );
    CPPUNIT_ASSERT( bits.mid_edge_node( 2 ) || ( revidx[6] == num_coeff ) );
    CPPUNIT_ASSERT( bits.mid_edge_node( 3 ) || ( revidx[7] == num_coeff ) );
    CPPUNIT_ASSERT( bits.mid_face_node( 0 ) || ( revidx[8] == num_coeff ) );
    // compare expected and actual coefficient values
    ASSERT_VALUES_EQUAL( expected_coeffs[0], test_vals[0], loc, bits );
    ASSERT_VALUES_EQUAL( expected_coeffs[1], test_vals[1], loc, bits );
    ASSERT_VALUES_EQUAL( expected_coeffs[2], test_vals[2], loc, bits );
    ASSERT_VALUES_EQUAL( expected_coeffs[3], test_vals[3], loc, bits );
    ASSERT_VALUES_EQUAL( expected_coeffs[4], test_vals[4], loc, bits );
    ASSERT_VALUES_EQUAL( expected_coeffs[5], test_vals[5], loc, bits );
    ASSERT_VALUES_EQUAL( expected_coeffs[6], test_vals[6], loc, bits );
    ASSERT_VALUES_EQUAL( expected_coeffs[7], test_vals[7], loc, bits );
    ASSERT_VALUES_EQUAL( expected_coeffs[8], test_vals[8], loc, bits );
static void compare_derivatives ( const size_t *  vertices,
size_t  num_vtx,
const double *  expected_dxi,
const double *  expected_deta,
unsigned  loc,
NodeSet  bits
) [static]
Definition at line 445 of file QuadLagrangeShapeTest.cpp.
References ASSERT_VALUES_EQUAL, check_no_zeros(), check_valid_indices(), and CPPUNIT_ASSERT.
Referenced by QuadLagrangeShapeTest::test_corner_derivs(), QuadLagrangeShapeTest::test_edge_derivs(), and QuadLagrangeShapeTest::test_mid_derivs().
    check_valid_indices( vertices, num_vtx, bits );
    check_no_zeros( derivs, num_vtx );
    // Input has values in dxi & deta only for nodes in 'vertices'
    // Convert to values for every possible node, with zero's for
    // nodes that are not present.
    double expanded_dxi[9], expanded_deta[9];
    std::fill( expanded_dxi, expanded_dxi + 9, 0.0 );
    std::fill( expanded_deta, expanded_deta + 9, 0.0 );
        CPPUNIT_ASSERT( vertices[i] <= 9 );
        expanded_dxi[vertices[i]]  = derivs[i][0];
        expanded_deta[vertices[i]] = derivs[i][1];
    ASSERT_VALUES_EQUAL( expected_dxi[0], expanded_dxi[0], loc, bits );
    ASSERT_VALUES_EQUAL( expected_dxi[1], expanded_dxi[1], loc, bits );
    ASSERT_VALUES_EQUAL( expected_dxi[2], expanded_dxi[2], loc, bits );
    ASSERT_VALUES_EQUAL( expected_dxi[3], expanded_dxi[3], loc, bits );
    ASSERT_VALUES_EQUAL( expected_dxi[4], expanded_dxi[4], loc, bits );
    ASSERT_VALUES_EQUAL( expected_dxi[5], expanded_dxi[5], loc, bits );
    ASSERT_VALUES_EQUAL( expected_dxi[6], expanded_dxi[6], loc, bits );
    ASSERT_VALUES_EQUAL( expected_dxi[7], expanded_dxi[7], loc, bits );
    ASSERT_VALUES_EQUAL( expected_dxi[8], expanded_dxi[8], loc, bits );
    ASSERT_VALUES_EQUAL( expected_deta[0], expanded_deta[0], loc, bits );
    ASSERT_VALUES_EQUAL( expected_deta[1], expanded_deta[1], loc, bits );
    ASSERT_VALUES_EQUAL( expected_deta[2], expanded_deta[2], loc, bits );
    ASSERT_VALUES_EQUAL( expected_deta[3], expanded_deta[3], loc, bits );
    ASSERT_VALUES_EQUAL( expected_deta[4], expanded_deta[4], loc, bits );
    ASSERT_VALUES_EQUAL( expected_deta[5], expanded_deta[5], loc, bits );
    ASSERT_VALUES_EQUAL( expected_deta[6], expanded_deta[6], loc, bits );
    ASSERT_VALUES_EQUAL( expected_deta[7], expanded_deta[7], loc, bits );
    ASSERT_VALUES_EQUAL( expected_deta[8], expanded_deta[8], loc, bits );
CPPUNIT_TEST_SUITE_NAMED_REGISTRATION ( QuadLagrangeShapeTest  ,
static double dl11 ( double  ) [static]
Definition at line 160 of file QuadLagrangeShapeTest.cpp.
Referenced by dN0deta(), dN0dxi(), dN1deta(), dN3dxi(), dN4deta(), and dN7dxi().
    return -1;
static double dl12 ( double  ) [static]
Definition at line 164 of file QuadLagrangeShapeTest.cpp.
Referenced by dN1dxi(), dN2deta(), dN2dxi(), dN3deta(), dN5dxi(), and dN6deta().
    return 1;
static double dl22 ( double  xi) [static]
Definition at line 168 of file QuadLagrangeShapeTest.cpp.
References MBMesquite::xi.
Referenced by dN4dxi(), dN5deta(), dN6dxi(), dN7deta(), dN8deta(), and dN8dxi().
    return 4 - 8 * xi;
static double dN0deta ( double  xi,
double  eta
) [static]
Definition at line 255 of file QuadLagrangeShapeTest.cpp.
References dl11(), and l11().
    return l11( xi ) * dl11( eta );
static double dN0dxi ( double  xi,
double  eta
) [static]
Definition at line 218 of file QuadLagrangeShapeTest.cpp.
    return dl11( xi ) * l11( eta );
static double dN1deta ( double  xi,
double  eta
) [static]
Definition at line 259 of file QuadLagrangeShapeTest.cpp.
References dl11(), and l12().
    return l12( xi ) * dl11( eta );
static double dN1dxi ( double  xi,
double  eta
) [static]
Definition at line 222 of file QuadLagrangeShapeTest.cpp.
References dl12(), and l11().
    return dl12( xi ) * l11( eta );
static double dN2deta ( double  xi,
double  eta
) [static]
Definition at line 263 of file QuadLagrangeShapeTest.cpp.
References dl12(), and l12().
    return l12( xi ) * dl12( eta );
static double dN2dxi ( double  xi,
double  eta
) [static]
Definition at line 226 of file QuadLagrangeShapeTest.cpp.
    return dl12( xi ) * l12( eta );
static double dN3deta ( double  xi,
double  eta
) [static]
Definition at line 267 of file QuadLagrangeShapeTest.cpp.
    return l11( xi ) * dl12( eta );
static double dN3dxi ( double  xi,
double  eta
) [static]
Definition at line 230 of file QuadLagrangeShapeTest.cpp.
    return dl11( xi ) * l12( eta );
static double dN4deta ( double  xi,
double  eta
) [static]
Definition at line 271 of file QuadLagrangeShapeTest.cpp.
References dl11(), and l22().
    return l22( xi ) * dl11( eta );
static double dN4dxi ( double  xi,
double  eta
) [static]
Definition at line 234 of file QuadLagrangeShapeTest.cpp.
References dl22(), and l11().
    return dl22( xi ) * l11( eta );
static double dN5deta ( double  xi,
double  eta
) [static]
Definition at line 275 of file QuadLagrangeShapeTest.cpp.
References dl22(), and l12().
    return l12( xi ) * dl22( eta );
static double dN5dxi ( double  xi,
double  eta
) [static]
Definition at line 238 of file QuadLagrangeShapeTest.cpp.
References dl12(), and l22().
    return dl12( xi ) * l22( eta );
static double dN6deta ( double  xi,
double  eta
) [static]
Definition at line 279 of file QuadLagrangeShapeTest.cpp.
    return l22( xi ) * dl12( eta );
static double dN6dxi ( double  xi,
double  eta
) [static]
Definition at line 242 of file QuadLagrangeShapeTest.cpp.
    return dl22( xi ) * l12( eta );
static double dN7deta ( double  xi,
double  eta
) [static]
Definition at line 283 of file QuadLagrangeShapeTest.cpp.
    return l11( xi ) * dl22( eta );
static double dN7dxi ( double  xi,
double  eta
) [static]
Definition at line 246 of file QuadLagrangeShapeTest.cpp.
    return dl11( xi ) * l22( eta );
static double dN8deta ( double  xi,
double  eta
) [static]
Definition at line 287 of file QuadLagrangeShapeTest.cpp.
References dl22(), and l22().
    return l22( xi ) * dl22( eta );
static double dN8dxi ( double  xi,
double  eta
) [static]
Definition at line 250 of file QuadLagrangeShapeTest.cpp.
    return dl22( xi ) * l22( eta );
static double dNdeta ( unsigned  i,
double  xi,
double  eta
) [static]
Definition at line 309 of file QuadLagrangeShapeTest.cpp.
References dNdeta_a, MBMesquite::eta, and MBMesquite::xi.
Referenced by get_partial_wrt_eta().
    return dNdeta_a[i]( xi, eta );
static double dNdxi ( unsigned  i,
double  xi,
double  eta
) [static]
Definition at line 305 of file QuadLagrangeShapeTest.cpp.
References dNdxi_a, MBMesquite::eta, and MBMesquite::xi.
Referenced by get_partial_wrt_xi().
    return dNdxi_a[i]( xi, eta );
static void eval ( f_t  function,
NodeSet  nodeset,
double  xi,
double  eta,
double  results[9]
) [static]
Definition at line 316 of file QuadLagrangeShapeTest.cpp.
References MBMesquite::NodeSet::mid_edge_node(), and MBMesquite::NodeSet::mid_face_node().
Referenced by moab::SpatialLocator::elem_eval(), moab::FileOptions::get_ints_option(), main(), moab::Tree::set_eval(), and TestMeshRefiner().
    // Initial values are a) linear values for corners,
    // b) values for mid edges assuming no mid-face node,
    // and c) the mid-face value for a fully quadratic element.
    for( unsigned i = 0; i < 9; ++i )
        results[i] = function( i, xi, eta );
    // if center node is present, adjust mid-edge coefficients
    if( !nodeset.mid_face_node( 0 ) )
        results[8] = 0;
    else
        for( unsigned i = 0; i < 4; ++i )
            results[i] -= 0.25 * results[8];
        for( unsigned i = 4; i < 8; ++i )
            results[i] -= 0.5 * results[8];
    // if mid-edge nodes are present, adjust values for adjacent corners
        if( !nodeset.mid_edge_node( i ) )
            results[i + 4] = 0.0;
        else
            results[i] -= 0.5 * results[i + 4];              // 1st adjacent corner
            results[( i + 1 ) % 4] -= 0.5 * results[i + 4];  // 2nd adjacent corner
static void get_coeffs ( NodeSet  nodebits,
double  xi,
double  eta,
) [static]
static void get_partial_wrt_eta ( NodeSet  nodebits,
double  xi,
double  eta,
) [static]
static void get_partial_wrt_xi ( NodeSet  nodebits,
double  xi,
double  eta,
) [static]
static double l11 ( double  xi) [static]
Definition at line 143 of file QuadLagrangeShapeTest.cpp.
Referenced by dN0deta(), dN0dxi(), dN1dxi(), dN3deta(), dN4dxi(), dN7deta(), get_hex_3d_part_example(), N0(), N1(), N3(), N4(), and N7().
    return 1 - xi;
static double l12 ( double  xi) [static]
Definition at line 147 of file QuadLagrangeShapeTest.cpp.
Referenced by dN1deta(), dN2deta(), dN2dxi(), dN3dxi(), dN5deta(), dN6dxi(), get_hex_3d_part_example(), N1(), N2(), N3(), N5(), and N6().
    return xi;
static double l22 ( double  xi) [static]
Definition at line 151 of file QuadLagrangeShapeTest.cpp.
Referenced by dN4deta(), dN5dxi(), dN6deta(), dN7dxi(), dN8deta(), dN8dxi(), N4(), N5(), N6(), N7(), and N8().
    return 4 * xi * ( 1 - xi );
static double N ( unsigned  i,
double  xi,
double  eta
) [static]
Definition at line 299 of file QuadLagrangeShapeTest.cpp.
References MBMesquite::eta, N_a, and MBMesquite::xi.
    return N_a[i]( xi, eta );
static double N0 ( double  xi,
double  eta
) [static]
Definition at line 179 of file QuadLagrangeShapeTest.cpp.
References l11().
    return l11( xi ) * l11( eta );
static double N1 ( double  xi,
double  eta
) [static]
Definition at line 183 of file QuadLagrangeShapeTest.cpp.
References l11(), and l12().
    return l12( xi ) * l11( eta );
static double N2 ( double  xi,
double  eta
) [static]
Definition at line 187 of file QuadLagrangeShapeTest.cpp.
References l12().
    return l12( xi ) * l12( eta );
static double N3 ( double  xi,
double  eta
) [static]
Definition at line 191 of file QuadLagrangeShapeTest.cpp.
    return l11( xi ) * l12( eta );
static double N4 ( double  xi,
double  eta
) [static]
Definition at line 196 of file QuadLagrangeShapeTest.cpp.
References l11(), and l22().
    return l22( xi ) * l11( eta );
static double N5 ( double  xi,
double  eta
) [static]
Definition at line 200 of file QuadLagrangeShapeTest.cpp.
References l12(), and l22().
    return l12( xi ) * l22( eta );
static double N6 ( double  xi,
double  eta
) [static]
Definition at line 204 of file QuadLagrangeShapeTest.cpp.
    return l22( xi ) * l12( eta );
static double N7 ( double  xi,
double  eta
) [static]
Definition at line 208 of file QuadLagrangeShapeTest.cpp.
    return l11( xi ) * l22( eta );
static double N8 ( double  xi,
double  eta
) [static]
Definition at line 213 of file QuadLagrangeShapeTest.cpp.
References l22().
    return l22( xi ) * l22( eta );
static CppUnit::Message value_message ( unsigned  location,
NodeSet  bits,
double  v1,
double  v2
) [inline, static]
Definition at line 52 of file QuadLagrangeShapeTest.cpp.
    CppUnit::Message m( "equality assertion failed" );
    std::ostringstream buffer1;
    buffer1 << "Expected : " << v1;
    m.addDetail( buffer1.str() );
    std::ostringstream buffer2;
    buffer2 << "Actual   : " << v2;
    m.addDetail( buffer2.str() );
    std::ostringstream buffer3;
    buffer3 << "Location : ";
    if( location < 4 )
        buffer3 << "Corner " << location;
    else if( location < 8 )
        buffer3 << "Edge " << location - 4;
    else if( location == 8 )
        buffer3 << "Mid-element";
    else
        buffer3 << "INVALID!!";
    m.addDetail( buffer3.str() );
    std::ostringstream buffer4;
    buffer4 << "Node Bits: " << bits;
    m.addDetail( buffer4.str() );
    return m;
Variable Documentation
const double corners[4][2] = { { min_xi, min_xi }, { max_xi, min_xi }, { max_xi, max_xi }, { min_xi, max_xi } } [static]
Definition at line 371 of file QuadLagrangeShapeTest.cpp.
const N_t dNdeta_a[9] [static]
Initial value:
Definition at line 295 of file QuadLagrangeShapeTest.cpp.
Referenced by dNdeta().
const N_t dNdxi_a[9] = { &dN0dxi, &dN1dxi, &dN2dxi, &dN3dxi, &dN4dxi, &dN5dxi, &dN6dxi, &dN7dxi, &dN8dxi } [static]
Definition at line 294 of file QuadLagrangeShapeTest.cpp.
Referenced by dNdxi().
Definition at line 48 of file QuadLagrangeShapeTest.cpp.
Definition at line 135 of file QuadLagrangeShapeTest.cpp.
Definition at line 136 of file QuadLagrangeShapeTest.cpp.
const double midelem[2] = { mid_xi, mid_xi } [static]
Definition at line 134 of file QuadLagrangeShapeTest.cpp.
const N_t N_a[9] = { &N0, &N1, &N2, &N3, &N4, &N5, &N6, &N7, &N8 } [static]
Definition at line 293 of file QuadLagrangeShapeTest.cpp.
Referenced by N().
