ReadABAQUS.hpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 //-------------------------------------------------------------------------
00017 // Filename      : ReadABAQUS.hpp
00018 //
00019 // Purpose       : ABAQUS inp file reader
00020 //
00021 // Special Notes : Started with NetCDF EXODUS II reader
00022 //
00023 // Creator       : Paul Wilson & Patrick Snouffer
00024 //
00025 // Date          : 08/2009
00026 //
00027 // Owner         : Paul Wilson
00028 //-------------------------------------------------------------------------
00029
00030 /** Implementation of ABAQUS mesh hierarchy and meta-data on MOAB
00031
00032
00033 This reader processes data written by the ABAQUS computer-aided engineering
00034 front-end.  While that tool writes binary files in its own proprietary format,
00035 it also writes an ASCII input file that is the fundamental input to the
00036 ABAQUS solver itself.  A published syntax for this format is available from Simulia.
00037
00038 This reader only supports a subset of the mesh syntax necessary to support
00039 a basic thermal analysis of solid systems.
00040
00041 An ABAQUS mesh makes use of the common paradigms of building a
00042 geometry as an "assembly" of "instances" of "parts".
00043
00044 A "part" is defined as a set of "nodes" and "elements" connecting
00045 those nodes. The nodes and elements can be arranged in "node sets" and
00046 "element sets" and specific "materials" can be assigned to "element
00047 sets" other features of parts are not currently used by applications
00048 and are not implemented.
00049
00050
00051 Overview of supported structure
00052
00053 * File:
00054    * Heading
00055    * Part
00056       * Nodes
00057       * Elements
00058       * Node Sets
00059       * Element Sets
00060       * Solid Sections
00061    * Assembly
00062       * Instance
00063         * Nodes
00064         * Elements
00065         * Node Sets
00066         * Element Sets
00067         * Solid Sections
00068       * Node Sets
00069
00070
00071 An "instance" is a full copy of a "part" with a linear geometric
00072 transformation. To create a full copy:
00073 • a duplicate set of nodes is created by copying the coordinates of
00074   the part nodes and applying a linear geometric transformation - the
00075   new coords are used to define the new nodes
00076 • a new node set is created for each node set in the part and the set
00077   of nodes among the duplicates are assigned to the new node set
00078 • a duplicate set of elements is defined by creating a new element
00079   with a connectivity made up of the duplicate nodes that correspond
00080   to the appropriate original element
00081 • a new element set is created for each element set in the part and
00082   the set of elements among the duplicates are assigned to the new
00083   element set; the corresponding material is also assigned go the new
00084   element sets
00085
00086 It is also possible for an "instance" to contain the complete
00087 definition of the mesh, copying nothing from the "part" (the "part"
00088 may have no mesh defined).  It is unclear whether an "instance" can
00089 combine mesh from the "part" definition with mesh contained only in
00090 the "instance" definition. (Not appropriately documented in ABAUQUS
00091 Reference Manual.)
00092
00093 In order to provide convenient access to the data and mesh structures
00094 the following data model is used:
00095
00096 • EntitySet file_set
00097    • tags
00098        • NONE
00099    • members
00100        • all nodes of all parts and all instances
00101        • all elements of all parts and all instances
00102        • all assembly_sets
00103        • all part_sets
00104 • EntitySet part_set
00105    • tags
00106        • mSetNameTag (opaque=char*)
00107          name of entity set
00108    • members
00109        • part nodes
00110        • part elements
00111        • part node sets
00112        • part element sets
00113 • EntitySet assembly_set
00114    • tags
00115        • mSetNameTag (opaque=char*)
00116          name of entity set
00117    • members
00118       • instance_sets
00119       • instance element_sets
00120       • instance node_sets
00121       • instance nodes
00122       • instance elements
00123 • EntitySet instance_set
00124    • tags
00125        • mSetNameTag (opaque=char*)
00126          name of entity set
00127        • mPartHandleTag (handle)
00128          pointer to part from which this instance was generated
00129        • mAssemblyHandleTag (handle)
00130          pointer to assembly in which this instance exists
00131        • mInstancePIDTag (int)
00132          ordinal number indicating which instance of this part
00133        • mInstanceGIDTag (int)
00134          ordinal number indicating which instance in this assembly
00135    • members
00136       • instance nodes
00137       • instance elements
00138       • instance node_sets
00139       • instance element_sets
00140 • EntitySet node_set
00141    • tags
00142        • mSetNameTag (opaque=char*)
00143          name of entity set
00144        • mPartHandleTag (handle)
00145          pointer to part in which this node set exists
00146      (only defined for node sets that are in an instance and
00147           derive from a part)
00148        • mInstanceHandleTag (handle)
00149          pointer back to instance set in which this node set exists
00150          (NULL if this node_set is not in an instance)
00151        • mAssemblyHandleTag (handle)
00152          pointer to assembly in which this node set exists
00153          (NULL if this node_set is not in an assembly)
00154    • members
00155       • nodes
00156 • EntitySet element_set
00157    • tags
00158        • mSetNameTag (opaque=char*)
00159          name of entity set
00160        • mPartHandleTag (handle)
00161          pointer to part in which this element set exists
00162      (only defined for node sets that are in an instance and
00163           derive from a part)
00164        • mInstanceHandleTag (handle)
00165          pointer back to instance set in which this element set exists
00166          (NULL if this node_set is not in an instance)
00167        • mAssemblyHandleTag (handle)
00168          pointer to assembly in which this element set exists
00169          (NULL if this node_set is not in an assembly)
00170        • mMatNameTag (opaque=char*)
00171          name of material in these elements
00172        • mMaterialSetTag (integer)
00173          material id in these elements
00174    • members
00175       • elements
00176 • Entity node
00177    • tags
00178        • mLocalIDTag (int)
00179          numerical ID of node in local scope (part, instance)
00180        • mInstanceHandleTag (handle)
00181          pointer back to instance set in which this node exists
00182          (NULL if this node is not in an instance)
00183 • Entity element
00184    • tags
00185        • mLocalIDTag (int)
00186          numerical ID of element in local scope (part, instance)
00187        • mInstanceHandleTag (handle)
00188          pointer back to instance set in which this element exists
00189          (NULL if this element is not in an instance)
00190
00191
00192  **/
00193
00194 #ifndef READABAQUS_HPP
00195 #define READABAQUS_HPP
00196
00197 #ifndef IS_BUILDING_MB
00198 #error "ReadABAQUS.hpp isn't supposed to be included into an application"
00199 #endif
00200
00201 #include <vector>
00202 #include <map>
00203 #include <string>
00204 #include <iostream>
00205 #include <fstream>
00206
00207 #include "moab/Forward.hpp"
00208 #include "moab/ReaderIface.hpp"
00209 #include "moab/Range.hpp"
00210
00211 namespace moab
00212 {
00213
00214 #define ABAQUS_SET_TYPE_TAG_NAME "abaqus_set_type"
00215 #define ABAQUS_SET_NAME_TAG_NAME "abaqus_set_name"
00216 #define ABAQUS_SET_NAME_LENGTH   100
00217 #define ABAQUS_LOCAL_ID_TAG_NAME "abaqus_local_id"
00218
00219 // Many sets should know who contains them
00220 #define ABAQUS_INSTANCE_HANDLE_TAG_NAME "abaqus_instance_handle"
00221 #define ABAQUS_ASSEMBLY_HANDLE_TAG_NAME "abaqus_assembly_handle"
00222 #define ABAQUS_PART_HANDLE_TAG_NAME     "abaqus_part_handle"
00223
00224 // Instances should know things about themselves:
00225 //  * which part they derive from (see ABAQUS_PART_HANDLE_TAG_NAME above)
00226 //  * which instance of a part this is
00227 //  * which instance of an assembly this is
00228 #define ABAQUS_INSTANCE_PART_ID_TAG_NAME   "abaqus_instance_part_id"
00229 #define ABAQUS_INSTANCE_GLOBAL_ID_TAG_NAME "abaqus_instance_global_id"
00230
00231 // Element sets have material name
00232 // Using MOAB's general MATERIAL_SET to store material id
00233 #define ABAQUS_MAT_NAME_TAG_NAME "abaqus_mat_name"
00234 #define ABAQUS_MAT_NAME_LENGTH   100
00235
00236 #define ABQ_ASSEMBLY_SET 1
00237 #define ABQ_PART_SET     2
00238 #define ABQ_INSTANCE_SET 3
00239 #define ABQ_NODE_SET     4
00240 #define ABQ_ELEMENT_SET  5
00241
00242 enum abaqus_line_types
00243 {
00244     abq_undefined_line = 0,
00245     abq_blank_line,
00246     abq_comment_line,
00247     abq_keyword_line,
00248     abq_data_line,
00249     abq_eof
00250 };
00251
00252 enum abaqus_keyword_type
00253 {
00254     abq_undefined = 0,
00255     abq_unsupported,
00256     abq_ambiguous,
00257     abq_heading,
00258     abq_part,
00259     abq_end_part,
00260     abq_assembly,
00261     abq_end_assembly,
00262     abq_node,
00263     abq_element,
00264     abq_nset,
00265     abq_elset,
00266     abq_instance,
00267     abq_end_instance,
00268     abq_solid_section
00269 };
00270
00271 enum abaqus_part_params
00272 {
00273     abq_part_undefined = 0,
00274     abq_part_ambiguous,
00275     abq_part_name
00276 };
00277
00278 enum abaqus_instance_params
00279 {
00280     abq_instance_undefined = 0,
00281     abq_instance_ambiguous,
00282     abq_instance_name,
00283     abq_instance_part
00284 };
00285
00286 enum abaqus_assembly_params
00287 {
00288     abq_assembly_undefined = 0,
00289     abq_assembly_ambiguous,
00290     abq_assembly_name
00291 };
00292
00293 enum abaqus_node_params
00294 {
00295     abq_node_undefined = 0,
00296     abq_node_ambiguous,
00297     abq_node_nset,
00298     abq_node_system
00299 };
00300
00301 enum abaqus_element_params
00302 {
00303     abq_element_undefined = 0,
00304     abq_element_ambiguous,
00305     abq_element_elset,
00306     abq_element_type
00307 };
00308
00309 enum abaqus_element_type
00310 {
00311     abq_eletype_unsupported = 0,
00312     abq_eletype_dc3d8,
00313     abq_eletype_c3d8r,
00314     abq_eletype_dcc3d8,
00315     abq_eletype_c3d4,
00316     abq_eletype_dc3d4,
00317     abq_eletype_ds4
00318 };
00319
00320 enum abaqus_nset_params
00321 {
00322     abq_nset_undefined = 0,
00323     abq_nset_ambiguous,
00324     abq_nset_nset,
00325     abq_nset_elset,
00326     abq_nset_generate,
00327     abq_nset_instance
00328 };
00329
00330 enum abaqus_elset_params
00331 {
00332     abq_elset_undefined = 0,
00333     abq_elset_ambiguous,
00334     abq_elset_elset,
00335     abq_elset_generate,
00336     abq_elset_instance
00337 };
00338
00339 enum abaqus_solid_section_params
00340 {
00341     abq_solid_section_undefined = 0,
00342     abq_solid_section_ambiguous,
00343     abq_solid_section_elset,
00344     abq_solid_section_matname
00345 };
00346
00347 class ReadUtilIface;
00348
00349 class ReadABAQUS : public ReaderIface
00350 {
00351   public:
00352     static ReaderIface* factory( Interface* );
00353
00354     void tokenize( const std::string& str, std::vector< std::string >& tokens, const char* delimiters );
00355
00356     //! Load an ABAQUS file
00357     ErrorCode load_file( const char* file_name,
00358                          const EntityHandle* file_set,
00359                          const FileOptions& opts,
00360                          const SubsetList* subset_list = 0,
00361                          const Tag* file_id_tag        = 0 );
00362
00363     ErrorCode read_tag_values( const char* file_name,
00364                                const char* tag_name,
00365                                const FileOptions& opts,
00366                                std::vector< int >& tag_values_out,
00367                                const SubsetList* subset_list = 0 );
00368
00369     //! Constructor
00370     ReadABAQUS( Interface* impl = NULL );
00371
00372     //! Destructor
00373     virtual ~ReadABAQUS();
00374
00375   private:
00376     void reset();
00377
00378     ErrorCode read_heading( EntityHandle file_set );
00379     ErrorCode read_part( EntityHandle file_set );
00380     ErrorCode read_assembly( EntityHandle file_set );
00381     ErrorCode read_unsupported( EntityHandle file_set );
00382     ErrorCode read_node_list( EntityHandle parent_set, EntityHandle assembly_set = 0 );
00383     ErrorCode read_element_list( EntityHandle parent_set, EntityHandle assembly_set = 0 );
00384     ErrorCode read_node_set( EntityHandle parent_set, EntityHandle file_set = 0, EntityHandle assembly_set = 0 );
00385     ErrorCode read_element_set( EntityHandle parent_set, EntityHandle file_set = 0, EntityHandle assembly_set = 0 );
00386     ErrorCode read_solid_section( EntityHandle parent_set );
00387     ErrorCode read_instance( EntityHandle assembly_set, EntityHandle file_set );
00388
00389     ErrorCode get_elements_by_id( EntityHandle parent_set,
00390                                   std::vector< int > element_ids_subset,
00391                                   Range& element_range );
00392
00393     ErrorCode get_nodes_by_id( EntityHandle parent_set, std::vector< int > node_ids_subset, Range& node_range );
00394
00395     ErrorCode get_set_by_name( EntityHandle parent_set,
00396                                int ABQ_set_type,
00397                                const std::string& set_name,
00398                                EntityHandle& set_handle );
00399
00400     ErrorCode get_set_elements( EntityHandle set_handle, Range& element_range );
00401
00402     ErrorCode get_set_elements_by_name( EntityHandle parent_set,
00403                                         int ABQ_set_type,
00404                                         const std::string& set_name,
00405                                         Range& element_range );
00406
00407     ErrorCode get_set_nodes( EntityHandle parent_set,
00408                              int ABQ_set_type,
00409                              const std::string& set_name,
00410                              Range& node_range );
00411
00412     ErrorCode add_entity_set( EntityHandle parent_set,
00413                               int ABQ_set_type,
00414                               const std::string& set_name,
00415                               EntityHandle& entity_set );
00416
00417     ErrorCode create_instance_of_part( const EntityHandle file_set,
00418                                        const EntityHandle parent_set,
00419                                        const std::string& part_name,
00420                                        const std::string& instance_name,
00421                                        EntityHandle& entity_set,
00422                                        const std::vector< double >& translation,
00423                                        const std::vector< double >& rotation );
00424
00425     Tag get_tag( const char* tag_name,
00426                  int tag_size,
00427                  TagType tag_type,
00428                  DataType tag_data_type,
00429                  const void* def_val = 0 );
00430
00431     void cyl2rect( std::vector< double > coord_list );
00432
00433     void sph2rect( std::vector< double > coord_list );
00434
00435     abaqus_line_types get_next_line_type();
00436     abaqus_keyword_type get_keyword();
00437
00438     template < class T >
00439     std::string match( const std::string& token, std::map< std::string, T >& tokenList );
00440
00441     void stringToUpper( const std::string& toBeConverted, std::string& converted );
00442
00443     void extract_keyword_parameters( const std::vector< std::string >& tokens,
00444                                      std::map< std::string, std::string >& params );
00445
00446     //! Interface instance
00447     Interface* mdbImpl;
00448
00449     //! Read mesh interface
00450     ReadUtilIface* readMeshIface;
00451
00452     std::ifstream abFile;  // abaqus file
00453
00454     std::string readline;
00455
00456     unsigned lineNo;
00457
00458     //! Cached tags for reading. Note that all these tags are defined when the
00459     //! core is initialized.
00460     Tag mMaterialSetTag;
00461     Tag mDirichletSetTag;
00462     Tag mNeumannSetTag;
00463     Tag mHasMidNodesTag;
00464
00465     Tag mSetTypeTag;
00466     Tag mPartHandleTag;
00467     Tag mInstancePIDTag;
00468     Tag mInstanceGIDTag;
00469
00470     Tag mLocalIDTag;
00471     Tag mInstanceHandleTag;
00472     Tag mAssemblyHandleTag;
00473
00474     Tag mSetNameTag;
00475     Tag mMatNameTag;
00476
00477     abaqus_line_types next_line_type;
00478
00479     std::map< EntityHandle, unsigned int > num_part_instances;
00480     std::map< EntityHandle, unsigned int > num_assembly_instances;
00481     std::map< std::string, unsigned int > matIDmap;
00482     unsigned mat_id;
00483 };
00484
00485 }  // namespace moab
00486
00487 #endif
