ReadCGM.hpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 //-------------------------------------------------------------------------
00017 // Filename      : ReadCGM.hpp
00018 //
00019 // Purpose       :  .step and .brep and .facet file reader
00020 //
00021 // Special Notes : Lots of code taken from cgm2moab implementation
00022 //
00023 // Creator       : Jane Hu
00024 //
00025 // Date          : 3/09
00026 //
00027 //-------------------------------------------------------------------------
00028
00029 #ifndef READCGM_HPP
00030 #define READCGM_HPP
00031
00032 #include "moab/MOABConfig.h"
00033 #ifndef MOAB_HAVE_CGM
00034 #error "ReadCGM.hpp isn't supposed to be included without building CGM"
00035 #endif
00036
00037 #include <string>
00038 #include "moab/ReaderIface.hpp"
00039 #include "RefEntityName.hpp"
00040
00041 namespace moab
00042 {
00043
00044 class ReadUtilIface;
00045 class GeomTopoTool;
00046
00047 class ReadCGM : public ReaderIface
00048 {
00049
00050   public:
00051     static ReaderIface* factory( Interface* );
00052
00053     void tokenize( const std::string& str, std::vector< std::string >& tokens, const char* delimiters );
00054
00055     //! load a CGM file
00056     //  Supported FileOptions:
00057     //  * FACET_NORMAL_TOLERANCE=<int> (default: 5)
00058     //  * FACET_DISTANCE_TOLERANCE=<real> (default: 0.001)
00059     //  * MAX_FACET_EDGE_LENGTH=<real> (default: 0.0)
00060     //  * CGM_ATTRIBS=<yes|no>         (default: no)
00061     ErrorCode load_file( const char* file_name,
00062                          const EntityHandle* file_set,
00063                          const FileOptions& opts,
00064                          const SubsetList* subset_list = 0,
00065                          const Tag* file_id_tag        = 0 );
00066
00067     ErrorCode read_tag_values( const char* file_name,
00068                                const char* tag_name,
00069                                const FileOptions& opts,
00070                                std::vector< int >& tag_values_out,
00071                                const SubsetList* subset_list = 0 );
00072
00073     //! Constructor
00074     ReadCGM( Interface* impl = NULL );
00075
00076     //! Destructor
00077     virtual ~ReadCGM();
00078
00079     // access private vars
00080     int get_failed_curve_count();
00081     int get_failed_surface_count();
00082
00083   private:
00084     ErrorCode set_options( const FileOptions& opts,
00085                            int& norm_tol,
00086                            double& faceting_tol,
00087                            double& len_tol,
00088                            bool& act_att,
00089                            bool& verbose_warnings,
00090                            bool& fatal_on_curves );
00091
00092     ErrorCode create_entity_sets( std::map< RefEntity*, EntityHandle > ( &entmap )[5] );
00093
00094     ErrorCode create_topology( std::map< RefEntity*, EntityHandle > ( &entitymap )[5] );
00095
00096     ErrorCode store_surface_senses( std::map< RefEntity*, EntityHandle >& surface_map,
00097                                     std::map< RefEntity*, EntityHandle >& volume_map );
00098
00099     ErrorCode store_curve_senses( std::map< RefEntity*, EntityHandle >& curve_map,
00100                                   std::map< RefEntity*, EntityHandle >& surface_map );
00101
00102     ErrorCode store_groups( std::map< RefEntity*, EntityHandle > ( &entitymap )[5] );
00103
00104     ErrorCode create_group_entsets( std::map< RefEntity*, EntityHandle >& group_map );
00105
00106     ErrorCode store_group_content( std::map< RefEntity*, EntityHandle > ( &entitymap )[5] );
00107
00108     void set_cgm_attributes( bool const act_attributes, bool const verbose );
00109
00110     ErrorCode create_vertices( std::map< RefEntity*, EntityHandle >& vertex_map );
00111
00112     ErrorCode create_curve_facets( std::map< RefEntity*, EntityHandle >& curve_map,
00113                                    std::map< RefEntity*, EntityHandle >& vertex_map,
00114                                    int norm_tol,
00115                                    double faceting_tol,
00116                                    bool verbose_warn    = false,
00117                                    bool fatal_on_curves = false );
00118
00119     ErrorCode create_surface_facets( std::map< RefEntity*, EntityHandle >& surface_map,
00120                                      std::map< RefEntity*, EntityHandle >& vertex_map,
00121                                      int norm_tol,
00122                                      double facet_tol,
00123                                      double length_tol );
00124     /**
00125      * Dumps the failed faceting information to screen
00126      */
00127     void dump_fail_counts();
00128
00129     ReadUtilIface* readUtilIface;
00130
00131     GeomTopoTool* myGeomTool;
00132
00133     const char* get_geom_file_type( const char* filename );
00134     const char* get_geom_fptr_type( FILE* file );
00135
00136     int is_cubit_file( FILE* file );
00137     int is_step_file( FILE* file );
00138     int is_iges_file( FILE* file );
00139     int is_occ_brep_file( FILE* file );
00140     int is_facet_file( FILE* file );
00141
00142     //------------member variables ------------//
00143
00144     //! interface instance
00145     Interface* mdbImpl;
00146
00147     Tag geom_tag, id_tag, name_tag, category_tag, faceting_tol_tag, geometry_resabs_tag;
00148
00149     int failed_curve_count;            // the number of curves that failed to facet
00150     std::vector< int > failed_curves;  // the curve ids of the curves that failed to facet
00151
00152     int failed_surface_count;            // the number of surfaces that have 0 facets
00153     std::vector< int > failed_surfaces;  // the surface ids of the surfaces that have 0 facets
00154 };
00155
00156 }  // namespace moab
00157
00158 #endif
