ReadTemplate.hpp
00001 #ifndef READ_TEMPLATE_HPP
00002 #define READ_TEMPLATE_HPP
00003
00004 #include "moab/ReaderIface.hpp"
00005 #include "moab/Range.hpp"
00006
00007 namespace moab
00008 {
00009
00010 class ReadUtilIface;
00011 class Interface;
00012
00013 /**
00014  * \brief Template for implementing new file readers in MOAB
00015  * This class is a template for writing new file readers in MOAB.  This shows how to efficiently
00016  * create vertices and elements using the ReadUtilIface class, and to translate indices in
00017  * connectivity lists into vertex handles created during the read.
00018  *
00019  * After writing the new reader class, you should also modify src/ReaderWriterSet.cpp, to register
00020  * the new reader along with the file extensions that it reads.  This will turn on automatic
00021  * creating of this reader based on file extension, which is done in Core::serial_load_file.
00022  */
00023 class ReadTemplate : public ReaderIface
00024 {
00025
00026   public:
00027     //! factory method
00028     static ReaderIface* factory( Interface* );
00029
00030     ErrorCode load_file( const char* file_name,
00031                          const EntityHandle* file_set,
00032                          const FileOptions& opts,
00033                          const SubsetList* subset_list = 0,
00034                          const Tag* file_id_tag        = 0 );
00035
00036     ErrorCode read_tag_values( const char* file_name,
00037                                const char* tag_name,
00038                                const FileOptions& opts,
00039                                std::vector< int >& tag_values_out,
00040                                const SubsetList* subset_list = 0 );
00041
00042     //! Constructor
00043     ReadTemplate( Interface* impl = NULL );
00044
00045     //! Destructor
00046     virtual ~ReadTemplate();
00047
00048   private:
00049     /** \brief Read vertex data and create vertices in MOAB database
00050      * \param num_verts Number of vertices to be read
00051      * \param start_vertex Starting vertex handle; used later to offset connectivity indices
00052      * \param read_ents Range storing all entities read from this file
00053      */
00054     ErrorCode read_vertices( int num_verts, EntityHandle& start_vertex, Range& read_ents );
00055
00056     /** \brief Read element data and create elements in MOAB database
00057      * \param num_elems Number of elements to be read
00058      * \param start_vertex Starting vertex handle; used to offset connectivity indices
00059      * \param start_elem Starting element handle; may be used later to offset set entities
00060      * \param read_ents Range storing all entities read from this file
00061      */
00062     ErrorCode read_elements( int num_elems, EntityHandle start_vertex, EntityHandle& start_elem, Range& read_ents );
00063
00064     /** \brief Read entity set data and create/populate sets in MOAB database
00065      * \param num_sets Number of sets to be read
00066      * \param start_vertex Starting vertex handle
00067      * \param num_verts Total number of vertices read from file
00068      * \param start_elem Starting element handle
00069      * \param num_elems Total number of elements read from file
00070      * \param read_ents Range storing all entities read from this file
00071      */
00072     ErrorCode create_sets( int num_sets,
00073                            EntityHandle start_vertex,
00074                            int num_verts,
00075                            EntityHandle start_elem,
00076                            int num_elems,
00077                            Range& read_ents );
00078
00079     /** \brief Process options passed into the reader
00080      * \param opts Options passed into this read
00081      */
00082     ErrorCode process_options( const FileOptions& opts );
00083
00084     ReadUtilIface* readMeshIface;
00085
00086     //! interface instance
00087     Interface* mbImpl;
00088
00089     const char* fileName;
00090 };
00091
00092 }  // namespace moab
00093
00094 #endif
