RefinerTagManager.hpp
00001 /*
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #ifndef MOAB_REFINER_TAG_MANAGER_HPP
00017 #define MOAB_REFINER_TAG_MANAGER_HPP
00018
00019 #include "moab/Types.hpp"  // for MB_DLL_EXPORT
00020
00021 #include "ProcessSet.hpp"
00022
00023 #include <vector>
00024
00025 namespace moab
00026 {
00027
00028 class Interface;
00029
00030 /**
00031  * This a class that manages which tags an edge refiner should include
00032  * on output vertices created during mesh refinement.
00033  * The
00034  *
00035  * \author David Thompson
00036  *
00037  * \date 12 June 2008
00038  */
00039 class RefinerTagManager
00040 {
00041   public:
00042     RefinerTagManager( Interface* in_mesh, Interface* out_mesh );
00043     virtual ~RefinerTagManager();
00044
00045     void reset_vertex_tags();
00046     int add_vertex_tag( Tag tag_handle );
00047     int get_vertex_tag_size() const
00048     {
00049         return this->vertex_size;
00050     }
00051     int get_number_of_vertex_tags() const
00052     {
00053         return this->input_vertex_tags.size();
00054     }
00055
00056     void reset_element_tags();
00057     int add_element_tag( Tag tag_handle );
00058     int get_element_tag_size() const
00059     {
00060         return this->element_size;
00061     }
00062     int get_number_of_element_tags() const
00063     {
00064         return this->input_element_tags.size();
00065     }
00066
00067     void create_output_tags();
00068
00069     void get_input_vertex_tag( int i, Tag& tag, int& byte_offset );
00070     void get_output_vertex_tag( int i, Tag& tag, int& byte_offset );
00071
00072     void get_input_element_tag( int i, Tag& tag, int& byte_offset );
00073     void get_output_element_tag( int i, Tag& tag, int& byte_offset );
00074
00075     Interface* get_input_mesh()
00076     {
00077         return this->input_mesh;
00078     }
00079     Interface* get_output_mesh()
00080     {
00081         return this->output_mesh;
00082     }
00083
00084     Tag input_parallel_status()
00085     {
00086         return this->tag_ipstatus;
00087     }
00088     Tag input_shared_proc()
00089     {
00090         return this->tag_ipsproc;
00091     }
00092     Tag input_shared_procs()
00093     {
00094         return this->tag_ipsprocs;
00095     }
00096
00097     int get_input_gids( int n, const EntityHandle* ents, std::vector< int >& gids );
00098     int get_output_gids( int n, const EntityHandle* ents, std::vector< int >& gids );
00099     int set_gid( EntityHandle ent, int gid );
00100     int copy_gid( EntityHandle ent_input, EntityHandle ent_output );
00101
00102     void set_sharing( EntityHandle ent_handle, ProcessSet& procs );
00103     void get_common_processes( int num,
00104                                const EntityHandle* src,
00105                                ProcessSet& common_shared_procs,
00106                                bool on_output_mesh = true );
00107
00108     void set_element_tags_from_ent( EntityHandle ent_input );
00109     void assign_element_tags( EntityHandle ent_output );
00110
00111     void set_element_procs_from_ent( EntityHandle ent_input )
00112     {
00113         this->get_common_processes( 1, &ent_input, this->current_element_procs, false );
00114     }
00115     ProcessSet& get_element_procs()
00116     {
00117         return this->current_element_procs;
00118     }
00119     void set_element_sharing( EntityHandle ent_output )
00120     {
00121         this->set_sharing( ent_output, this->current_element_procs );
00122     }
00123
00124   protected:
00125     void create_tag_internal( Tag, int );
00126
00127     std::vector< std::pair< Tag, int > > input_vertex_tags;
00128     std::vector< std::pair< Tag, int > > output_vertex_tags;
00129     std::vector< std::pair< Tag, int > > input_element_tags;
00130     std::vector< std::pair< Tag, int > > output_element_tags;
00131     int vertex_size;
00132     int element_size;
00133     Interface* input_mesh;
00134     Interface* output_mesh;
00135     Tag tag_ipstatus;  // Handle for PARALLEL_STATUS on mesh_in
00136     Tag tag_ipsprocs;  // Handle for PARALLEL_SHARED_PROCS on mesh_in
00137     Tag tag_ipsproc;   // Handle for PARALLEL_SHARED_PROC on mesh_in
00138     Tag tag_ipshands;  // Handle for PARALLEL_SHARED_HANDLES on mesh_in
00139     Tag tag_ipshand;   // Handle for PARALLEL_SHARED_HANDLE on mesh_in
00140     Tag tag_igid;      // Handle for global IDs on mesh_in
00141     Tag tag_opstatus;  // Handle for PARALLEL_STATUS on mesh_out
00142     Tag tag_opsprocs;  // Handle for PARALLEL_SHARED_PROCS on mesh_out
00143     Tag tag_opsproc;   // Handle for PARALLEL_SHARED_PROC on mesh_out
00144     Tag tag_opshands;  // Handle for PARALLEL_SHARED_HANDLES on mesh_out
00145     Tag tag_opshand;   // Handle for PARALLEL_SHARED_HANDLE on mesh_out
00146     Tag tag_ogid;      // Handle for global IDs on mesh_out
00147     int rank;
00148     std::vector< int > shared_procs_in;    // Used to hold procs sharing an input vert.
00149     std::vector< int > shared_procs_out;   // Used to hold procs sharing an output entity.
00150     ProcessSet current_shared_procs;       // Holds process list as it is being accumulated
00151     ProcessSet current_element_procs;      // The list of processes which should share an output element.
00152     std::vector< char > element_tag_data;  // Holds tag data for per-element tags
00153 };
00154
00155 }  // namespace moab
00156
00157 #endif  // MOAB_REFINER_TAG_MANAGER_HPP
