SimplexTemplateRefiner.cpp
00001 #include "SimplexTemplateRefiner.hpp"
00002
00003 #include "EdgeSizeEvaluator.hpp"
00004 #include "RefinerTagManager.hpp"
00005
00006 #include "moab/Interface.hpp"
00007
00008 #include <iostream>
00009 #include <stack>
00010
00011 // Static arrays holding parametric coordinates of element vertices
00012 static double MBVertexParametric[] = { 0., 0., 0. };
00013 static double MBEdgeParametric[]   = { 0., 0., 0., 1., 0., 0. };
00014 static double MBTriParametric[]    = { 0., 0., 0., 1., 0., 0., 0., 1., 0. };
00015 static double MBTetParametric[]    = { 0., 0., 0., 1., 0., 0., 0., 1., 0., 0., 0., 1. };
00016
00017 #ifdef MB_DEBUG_TESSELLATOR
00018 #define MB_TESSELLATOR_INCR_CASE_COUNT( cs )        this->case_counts[cs]++
00019 #define MB_TESSELLATOR_INCR_SUBCASE_COUNT( cs, sc ) this->subcase_counts[cs][sc]++
00020 #else  // MB_DEBUG_TESSELLATOR
00021 #define MB_TESSELLATOR_INCR_CASE_COUNT( cs )
00022 #define MB_TESSELLATOR_INCR_SUBCASE_COUNT( cs, sc )
00023 #endif  // MB_DEBUG_TESSELLATOR
00024
00025 namespace moab
00026 {
00027
00028 /// Construct a template refiner.
00029 SimplexTemplateRefiner::SimplexTemplateRefiner()
00030 {
00031     this->tag_manager  = 0;
00032     this->tag_assigner = new SimplexTemplateTagAssigner( this );
00033     this->corner_coords.resize( 6 * 8 );  // Hex has 8 verts w/ 6 coordinates each
00034     this->corner_tags.resize( 8 );        // Hex has 8 verts (this is a pointer, not the actual tag data)
00035     this->corner_handles.resize( 8 );     // Hex has 8 verts (this is a pointer, not actual hash data)
00036     this->input_is_output = false;        // Until we know better
00037 }
00038
00039 /// Empty destructor for good form.
00040 SimplexTemplateRefiner::~SimplexTemplateRefiner()
00041 {
00042     delete this->tag_assigner;
00043 }
00044
00045 /**\brief Stream a single mesh entity through the refiner.
00046  */
00047 bool SimplexTemplateRefiner::refine_entity( EntityType etyp, EntityHandle entity )
00048 {
00049     this->reset_heap_pointers();
00050     bool rval = true;
00051     const EntityHandle* conn;
00052     int num_nodes;
00053     Interface* imesh = this->tag_manager->get_input_mesh();
00054     if( imesh->get_connectivity( entity, conn, num_nodes ) != MB_SUCCESS )
00055     {
00056         return false;
00057     }
00058     this->corner_coords.resize( 6 * num_nodes );
00059     this->corner_tags.resize( num_nodes );
00060     this->corner_handles.resize( num_nodes );
00061
00062     // Have to make num_nodes calls to get_coords() because we need xyz interleaved with rst coords.
00063     Tag tag_handle;
00064     int tag_offset;
00065     void* tag_data;
00066     for( int n = 0; n < num_nodes; ++n )
00067     {
00068         if( imesh->get_coords( &conn[n], 1, &corner_coords[6 * n + 3] ) != MB_SUCCESS )
00069         {
00070             return false;
00071         }
00072         tag_data = this->heap_tag_storage();
00073         for( int i = 0; i < this->tag_manager->get_number_of_vertex_tags(); ++i )
00074         {
00075             this->tag_manager->get_input_vertex_tag( i, tag_handle, tag_offset );
00076             if( imesh->tag_get_data( tag_handle, &conn[n], 1, (char*)tag_data + tag_offset ) != MB_SUCCESS )
00077             {
00078                 return false;
00079             }
00080         }
00081         if( this->input_is_output )
00082         {
00083             this->corner_handles[n] = conn[n];
00084         }
00085         else
00086         {
00087             this->corner_handles[n] = this->output_functor->map_vertex( conn[n], &corner_coords[6 * n], tag_data );
00088 #if 0
00089       std::cout << "#+# " << this->corner_handles[n] << " < "
00090         << corner_coords[ 6 * n + 3 ] << ", "
00091         << corner_coords[ 6 * n + 4 ] << ", "
00092         << corner_coords[ 6 * n + 5 ] << ">\n";
00093 #endif  // 0
00094         }
00095         this->corner_tags[n] = tag_data;
00096     }
00097
00098     switch( etyp )
00099     {
00100         case MBVERTEX:
00101             this->assign_parametric_coordinates( 1, MBVertexParametric, &this->corner_coords[0] );
00102             this->refine_0_simplex( &this->corner_coords[0], this->corner_tags[0], this->corner_handles[0] );
00103             rval = false;
00104             break;
00105         case MBEDGE:
00106             this->assign_parametric_coordinates( 2, MBEdgeParametric, &this->corner_coords[0] );
00107             rval = this->refine_1_simplex( this->maximum_number_of_subdivisions, &this->corner_coords[0],
00108                                            this->corner_tags[0], this->corner_handles[0], &this->corner_coords[6],
00109                                            this->corner_tags[1], this->corner_handles[1] );
00110             break;
00111         case MBTRI:
00112             this->assign_parametric_coordinates( 3, MBTriParametric, &this->corner_coords[0] );
00113             rval = this->refine_2_simplex( this->maximum_number_of_subdivisions, 7, &this->corner_coords[0],
00114                                            this->corner_tags[0], this->corner_handles[0], &this->corner_coords[6],
00115                                            this->corner_tags[1], this->corner_handles[1], &this->corner_coords[12],
00116                                            this->corner_tags[2], this->corner_handles[2] );
00117             break;
00118         case MBQUAD:
00119             std::cerr << "Quadrilaterals not handled yet\n";
00120             rval = false;
00121             break;
00122         case MBPOLYGON:
00123             std::cerr << "Polygons not handled yet\n";
00124             rval = false;
00125             break;
00126         case MBTET:
00127             this->assign_parametric_coordinates( 4, MBTetParametric, &this->corner_coords[0] );
00128             rval = this->refine_3_simplex( this->maximum_number_of_subdivisions, &this->corner_coords[0],
00129                                            this->corner_tags[0], this->corner_handles[0], &this->corner_coords[6],
00130                                            this->corner_tags[1], this->corner_handles[1], &this->corner_coords[12],
00131                                            this->corner_tags[2], this->corner_handles[2], &this->corner_coords[18],
00132                                            this->corner_tags[3], this->corner_handles[3] );
00133             break;
00134         case MBPYRAMID:
00135             std::cerr << "Pyramid schemes not handled yet\n";
00136             rval = false;
00137             break;
00138         case MBPRISM:
00139             std::cerr << "Prisms not handled yet\n";
00140             rval = false;
00141             break;
00142         case MBKNIFE:
00143             std::cerr << "Knifahedra not handled yet\n";
00144             rval = false;
00145             break;
00146         case MBHEX:
00147             std::cerr << "Hexahedra not handled yet\n";
00148             rval = false;
00149             break;
00150         case MBPOLYHEDRON:
00151             std::cerr << "Polyhedra not handled yet\n";
00152             rval = false;
00153             break;
00154         case MBENTITYSET:
00155             std::cerr << "How should entity sets be handled? We might iterate over its entries or "
00156                          "skip it."
00157                          "Must coordinate with MeshRefiner's loop over entities...\n";
00158             rval = false;
00159             break;
00160         case MBMAXTYPE:
00161             rval = false;
00162             break;
00163     }
00164     return rval;
00165 }
00166
00167 /**\brief Set the function object used to decide which tag values an edge or face midpoint is
00168  * assigned.
00169  *
00170  * This will change the tag assigner's edge size evaluator to match the refiner's.
00171  * @param[in] ta The new tag assigner. This must be non-NULL.
00172  * @retval True if the tag assigner was changed and false otherwise.
00173  */
00174 bool SimplexTemplateRefiner::set_tag_assigner( SimplexTemplateTagAssigner* ta )
00175 {
00176     if( !ta || ta == this->tag_assigner ) return false;
00177
00178     this->tag_assigner = ta;
00179     return true;
00180 }
00181
00182 /**\brief Set the function object used to decide whether an edge is subdivided or not.
00183  */
00184 bool SimplexTemplateRefiner::prepare( RefinerTagManager* tmgr, EntityRefinerOutputFunctor* ofunc )
00185 {
00186     this->tag_manager = tmgr;
00187     this->tag_assigner->set_tag_manager( tmgr );
00188     this->input_is_output = ( this->tag_manager->get_input_mesh() == this->tag_manager->get_output_mesh() );
00189     // this->tag_assigner->set_edge_size_evaluator( this->edge_size_evaluator );
00190     return this->EntityRefiner::prepare( tmgr, ofunc );
00191 }
00192
00193 /**\fn unsigned long SimplexTemplateRefiner::get_heap_size_bound( int max_recursions ) const
00194  *\brief Bound on the number of new vertices used to allocate the heap.
00195  *
00196  * This bound is based on a hexahedron that is divided into 48 tetrahedra (a point is added to
00197  * the center of each face so that compatible boundaries are guaranteed on neighboring hexahedra),
00198  * each of which has 4 edges.
00199  */
00200
00201 /**\brief "Refine" a vertex by passing it through to the output.
00202  *
00203  * FIXME: There is some question as to whether this should pass vertices through
00204  * since there does not appear to be a distinction between vertices as points
00205  * in space and vertices as degrees-of-freedom in a mesh (i.e. a vertex that is
00206  * treated as a lumped-parameter model).
00207  */
00208 void SimplexTemplateRefiner::refine_0_simplex( const double* v0, const void* t0, EntityHandle h0 )
00209 {
00210     // Ignore these arguments... the caller is responsible for calling the output functor to ensure
00211     // the vertex exists on the output.
00212     (void)v0;
00213     (void)t0;
00214
00215     ( *this->output_functor )( h0 );
00216     ( *this->output_functor )( MBVERTEX );
00217 }
00218
00219 /**\brief Refine an edge.
00220  */
00221 bool SimplexTemplateRefiner::refine_1_simplex( int max_depth,
00222                                                const double* v0,
00223                                                const void* t0,
00224                                                EntityHandle h0,
00225                                                const double* v1,
00226                                                const void* t1,
00227                                                EntityHandle h1 )
00228 {
00229     int edge_code = 0;
00230
00231     double* midptc;
00232     void* midptt;
00233     // NB: If support for multiple recursive subdivisions (without a merge in between) is required,
00234     //     this will have to change as it assumes that h0 and h1 have only a single entry.
00235     EntityHandle midpth = 0;
00236
00237     if( max_depth-- > 0 )
00238     {
00239         midptc = this->heap_coord_storage();
00240         midptt = this->heap_tag_storage();
00241         int i;
00242         // make valgrind happy
00243         // vtkstd::fill( midpt0, midpt0 + 6, 0. );
00244         for( i = 0; i < 6; i++ )
00245             midptc[i] = ( v0[i] + v1[i] ) / 2.;
00246
00247         ( *this->tag_assigner )( v0, t0, h0, midptc, midptt, v1, t1, h1 );
00248         if( this->edge_size_evaluator->evaluate_edge( v0, t0, midptc, midptt, v1, t1 ) )
00249         {
00250             edge_code = 1;
00251             midpth    = ( *this->output_functor )( h0, h1, midptc, midptt );
00252         }
00253     }
00254
00255     switch( edge_code )
00256     {
00257             // No edges to subdivide
00258         case 0:
00259             ( *this->output_functor )( h0 );
00260             ( *this->output_functor )( h1 );
00261             ( *this->output_functor )( MBEDGE );
00262             break;
00263
00264             // One edge to subdivide
00265         case 1:
00266             this->refine_1_simplex( max_depth, v0, t0, h0, midptc, midptt, midpth );
00267             this->refine_1_simplex( max_depth, midptc, midptt, midpth, v1, t1, h1 );
00268             break;
00269     }
00270
00271     return ( 0 == edge_code ) ? false : true;
00272 }
00273
00274 /**\brief Refine a triangle.
00275  */
00276 bool SimplexTemplateRefiner::refine_2_simplex( int max_depth,
00277                                                int move,
00278                                                const double* v0,
00279                                                const void* t0,
00280                                                EntityHandle h0,
00281                                                const double* v1,
00282                                                const void* t1,
00283                                                EntityHandle h1,
00284                                                const double* v2,
00285                                                const void* t2,
00286                                                EntityHandle h2 )
00287 {
00288     int edge_code = 0;
00289
00290     double* midpt0c;
00291     double* midpt1c;
00292     double* midpt2c;
00293     void* midpt0t;
00294     void* midpt1t;
00295     void* midpt2t;
00296     EntityHandle midpt0h = 0;
00297     EntityHandle midpt1h = 0;
00298     EntityHandle midpt2h = 0;
00299
00300     if( max_depth-- > 0 )
00301     {
00302         int i;
00303         midpt0c = this->heap_coord_storage();
00304         midpt1c = this->heap_coord_storage();
00305         midpt2c = this->heap_coord_storage();
00306         midpt0t = this->heap_tag_storage();
00307         midpt1t = this->heap_tag_storage();
00308         midpt2t = this->heap_tag_storage();
00309         midpt0h = 0;
00310         midpt1h = 0;
00311         midpt2h = 0;
00312         for( i = 0; i < 6; ++i )
00313         {
00314             midpt0c[i] = ( v0[i] + v1[i] ) / 2.;
00315             midpt1c[i] = ( v1[i] + v2[i] ) / 2.;
00316             midpt2c[i] = ( v2[i] + v0[i] ) / 2.;
00317         }
00318         ( *this->tag_assigner )( v0, t0, h0, midpt0c, midpt0t, v1, t1, h1 );
00319         ( *this->tag_assigner )( v1, t1, h1, midpt1c, midpt1t, v2, t2, h2 );
00320         ( *this->tag_assigner )( v2, t2, h2, midpt2c, midpt2t, v0, t0, h0 );
00321         if( ( move & 1 ) && this->edge_size_evaluator->evaluate_edge( v0, t0, midpt0c, midpt0t, v1, t1 ) )
00322         {
00323             edge_code += 1;
00324             midpt0h = ( *this->output_functor )( h0, h1, midpt0c, midpt0t );
00325         }
00326         if( ( move & 2 ) && this->edge_size_evaluator->evaluate_edge( v1, t1, midpt1c, midpt1t, v2, t2 ) )
00327         {
00328             edge_code += 2;
00329             midpt1h = ( *this->output_functor )( h1, h2, midpt1c, midpt1t );
00330         }
00331         if( ( move & 4 ) && this->edge_size_evaluator->evaluate_edge( v2, t2, midpt2c, midpt2t, v0, t0 ) )
00332         {
00333             edge_code += 4;
00334             midpt2h = ( *this->output_functor )( h2, h0, midpt2c, midpt2t );
00335         }
00336     }
00337
00338     switch( edge_code )
00339     {
00340             // No edges to subdivide
00341         case 0:
00342             ( *this->output_functor )( h0 );
00343             ( *this->output_functor )( h1 );
00344             ( *this->output_functor )( h2 );
00345             ( *this->output_functor )( MBTRI );
00346             break;
00347
00348             // One edge to subdivide
00349         case 1:
00350             this->refine_2_simplex( max_depth, move | 2, v0, t0, h0, midpt0c, midpt0t, midpt0h, v2, t2, h2 );
00351             this->refine_2_simplex( max_depth, move | 4, midpt0c, midpt0t, midpt0h, v1, t1, h1, v2, t2, h2 );
00352             break;
00353         case 2:
00354             this->refine_2_simplex( max_depth, move | 4, v0, t0, h0, v1, t1, h1, midpt1c, midpt1t, midpt1h );
00355             this->refine_2_simplex( max_depth, move | 1, v0, t0, h0, midpt1c, midpt1t, midpt1h, v2, t2, h2 );
00356             break;
00357         case 4:
00358             this->refine_2_simplex( max_depth, move | 2, v0, t0, h0, v1, t1, h1, midpt2c, midpt2t, midpt2h );
00359             this->refine_2_simplex( max_depth, move | 1, midpt2c, midpt2t, midpt2h, v1, t1, h1, v2, t2, h2 );
00360             break;
00361
00362             // Two edges to subdivide
00363         case 3:
00364             this->refine_2_simplex( max_depth, move | 4, midpt0c, midpt0t, midpt0h, v1, t1, h1, midpt1c, midpt1t,
00365                                     midpt1h );
00366             if( this->compare_Hopf_cross_string_dist( v2, midpt0c, v0, midpt1c ) )
00367             {
00368                 this->refine_2_simplex( max_depth, move | 5, midpt0c, midpt0t, midpt0h, midpt1c, midpt1t, midpt1h, v2,
00369                                         t2, h2 );
00370                 this->refine_2_simplex( max_depth, move | 2, v0, t0, h0, midpt0c, midpt0t, midpt0h, v2, t2, h2 );
00371             }
00372             else
00373             {
00374                 this->refine_2_simplex( max_depth, move | 6, v0, t0, h0, midpt0c, midpt0t, midpt0h, midpt1c, midpt1t,
00375                                         midpt1h );
00376                 this->refine_2_simplex( max_depth, move | 1, v0, t0, h0, midpt1c, midpt1t, midpt1h, v2, t2, h2 );
00377             }
00378             break;
00379         case 5:
00380             this->refine_2_simplex( max_depth, move | 2, v0, t0, h0, midpt0c, midpt0t, midpt0h, midpt2c, midpt2t,
00381                                     midpt2h );
00382             if( this->compare_Hopf_cross_string_dist( v2, midpt0c, v1, midpt2c ) )
00383             {
00384                 this->refine_2_simplex( max_depth, move | 4, midpt0c, midpt0t, midpt0h, v1, t1, h1, v2, t2, h2 );
00385                 this->refine_2_simplex( max_depth, move | 3, midpt2c, midpt2t, midpt2h, midpt0c, midpt0t, midpt0h, v2,
00386                                         t2, h2 );
00387             }
00388             else
00389             {
00390                 this->refine_2_simplex( max_depth, move | 6, midpt0c, midpt0t, midpt0h, v1, t1, h1, midpt2c, midpt2t,
00391                                         midpt2h );
00392                 this->refine_2_simplex( max_depth, move | 1, midpt2c, midpt2t, midpt2h, v1, t1, h1, v2, t2, h2 );
00393             }
00394             break;
00395         case 6:
00396             this->refine_2_simplex( max_depth, move | 1, midpt2c, midpt2t, midpt2h, midpt1c, midpt1t, midpt1h, v2, t2,
00397                                     h2 );
00398             if( this->compare_Hopf_cross_string_dist( v0, midpt1c, v1, midpt2c ) )
00399             {
00400                 this->refine_2_simplex( max_depth, move | 3, v0, t0, h0, midpt1c, midpt1t, midpt1h, midpt2c, midpt2t,
00401                                         midpt2h );
00402                 this->refine_2_simplex( max_depth, move | 4, v0, t0, h0, v1, t1, h1, midpt1c, midpt1t, midpt1h );
00403             }
00404             else
00405             {
00406                 this->refine_2_simplex( max_depth, move | 2, v0, t0, h0, v1, t1, h1, midpt2c, midpt2t, midpt2h );
00407                 this->refine_2_simplex( max_depth, move | 5, midpt2c, midpt2t, midpt2h, v1, t1, h1, midpt1c, midpt1t,
00408                                         midpt1h );
00409             }
00410             break;
00411
00412             // Three edges to subdivide
00413         case 7:
00414             this->refine_2_simplex( max_depth, 7, midpt0c, midpt0t, midpt0h, midpt1c, midpt1t, midpt1h, midpt2c,
00415                                     midpt2t, midpt2h );
00416             this->refine_2_simplex( max_depth, move | 2, v0, t0, h0, midpt0c, midpt0t, midpt0h, midpt2c, midpt2t,
00417                                     midpt2h );
00418             this->refine_2_simplex( max_depth, move | 4, midpt0c, midpt0t, midpt0h, v1, t1, h1, midpt1c, midpt1t,
00419                                     midpt1h );
00420             this->refine_2_simplex( max_depth, move | 1, midpt2c, midpt2t, midpt2h, midpt1c, midpt1t, midpt1h, v2, t2,
00421                                     h2 );
00422             break;
00423     }
00424
00425     return true;
00426 }
00427
00428 /**\brief Refine a tetrahedron.
00429  */
00430 bool SimplexTemplateRefiner::refine_3_simplex( int max_depth,
00431                                                double* v0,
00432                                                void* t0,
00433                                                EntityHandle h0,
00434                                                double* v1,
00435                                                void* t1,
00436                                                EntityHandle h1,
00437                                                double* v2,
00438                                                void* t2,
00439                                                EntityHandle h2,
00440                                                double* v3,
00441                                                void* t3,
00442                                                EntityHandle h3 )
00443 {
00444     int edge_code = 0;
00445
00446     double* midpt0c;
00447     double* midpt1c;
00448     double* midpt2c;
00449     double* midpt3c;
00450     double* midpt4c;
00451     double* midpt5c;
00452
00453     void* midpt0t;
00454     void* midpt1t;
00455     void* midpt2t;
00456     void* midpt3t;
00457     void* midpt4t;
00458     void* midpt5t;
00459
00460     EntityHandle midpt0h = 0;
00461     EntityHandle midpt1h = 0;
00462     EntityHandle midpt2h = 0;
00463     EntityHandle midpt3h = 0;
00464     EntityHandle midpt4h = 0;
00465     EntityHandle midpt5h = 0;
00466
00467     if( max_depth-- > 0 )
00468     {
00469         midpt0c = this->heap_coord_storage();
00470         midpt1c = this->heap_coord_storage();
00471         midpt2c = this->heap_coord_storage();
00472         midpt3c = this->heap_coord_storage();
00473         midpt4c = this->heap_coord_storage();
00474         midpt5c = this->heap_coord_storage();
00475
00476         midpt0t = this->heap_tag_storage();
00477         midpt1t = this->heap_tag_storage();
00478         midpt2t = this->heap_tag_storage();
00479         midpt3t = this->heap_tag_storage();
00480         midpt4t = this->heap_tag_storage();
00481         midpt5t = this->heap_tag_storage();
00482
00483         for( int i = 0; i < 6; ++i )
00484         {
00485             midpt0c[i] = ( v0[i] + v1[i] ) * .5;
00486             midpt1c[i] = ( v1[i] + v2[i] ) * .5;
00487             midpt2c[i] = ( v2[i] + v0[i] ) * .5;
00488             midpt3c[i] = ( v0[i] + v3[i] ) * .5;
00489             midpt4c[i] = ( v1[i] + v3[i] ) * .5;
00490             midpt5c[i] = ( v2[i] + v3[i] ) * .5;
00491         }
00492
00493         ( *this->tag_assigner )( v0, t0, h0, midpt0c, midpt0t, v1, t1, h1 );
00494         ( *this->tag_assigner )( v1, t1, h1, midpt1c, midpt1t, v2, t2, h2 );
00495         ( *this->tag_assigner )( v2, t2, h2, midpt2c, midpt2t, v0, t0, h0 );
00496         ( *this->tag_assigner )( v0, t0, h0, midpt3c, midpt3t, v3, t3, h3 );
00497         ( *this->tag_assigner )( v1, t1, h1, midpt4c, midpt4t, v3, t3, h3 );
00498         ( *this->tag_assigner )( v2, t2, h2, midpt5c, midpt5t, v3, t3, h3 );
00499
00500         if( this->edge_size_evaluator->evaluate_edge( v0, t0, midpt0c, midpt0t, v1, t1 ) )
00501         {
00502             edge_code |= 1;
00503             midpt0h = ( *this->output_functor )( h0, h1, midpt0c, midpt0t );
00504         }
00505         if( this->edge_size_evaluator->evaluate_edge( v1, t1, midpt1c, midpt1t, v2, t2 ) )
00506         {
00507             edge_code |= 2;
00508             midpt1h = ( *this->output_functor )( h1, h2, midpt1c, midpt1t );
00509         }
00510         if( this->edge_size_evaluator->evaluate_edge( v2, t2, midpt2c, midpt2t, v0, t0 ) )
00511         {
00512             edge_code |= 4;
00513             midpt2h = ( *this->output_functor )( h2, h0, midpt2c, midpt2t );
00514         }
00515         if( this->edge_size_evaluator->evaluate_edge( v0, t0, midpt3c, midpt3t, v3, t3 ) )
00516         {
00517             edge_code |= 8;
00518             midpt3h = ( *this->output_functor )( h0, h3, midpt3c, midpt3t );
00519         }
00520         if( this->edge_size_evaluator->evaluate_edge( v1, t1, midpt4c, midpt4t, v3, t3 ) )
00521         {
00522             edge_code |= 16;
00523             midpt4h = ( *this->output_functor )( h1, h3, midpt4c, midpt4t );
00524         }
00525         if( this->edge_size_evaluator->evaluate_edge( v2, t2, midpt5c, midpt5t, v3, t3 ) )
00526         {
00527             edge_code |= 32;
00528             midpt5h = ( *this->output_functor )( h2, h3, midpt5c, midpt5t );
00529         }
00530     }
00531
00532     double edge_length2[6];
00533     for( int ei = 0; ei < 6; ++ei )
00534         edge_length2[ei] = 0.;
00535
00536     for( int c = 0; c < 3; ++c )
00537     {
00538         double tmp;
00539         tmp = v1[c] - v0[c];
00540         edge_length2[0] += tmp * tmp;
00541         tmp = v2[c] - v1[c];
00542         edge_length2[1] += tmp * tmp;
00543         tmp = v2[c] - v0[c];
00544         edge_length2[2] += tmp * tmp;
00545         tmp = v3[c] - v0[c];
00546         edge_length2[3] += tmp * tmp;
00547         tmp = v3[c] - v1[c];
00548         edge_length2[4] += tmp * tmp;
00549         tmp = v3[c] - v2[c];
00550         edge_length2[5] += tmp * tmp;
00551     }
00552
00553     if( 0 == edge_code )
00554     {
00555         // No edges to subdivide
00556         ( *this->output_functor )( h0 );
00557         ( *this->output_functor )( h1 );
00558         ( *this->output_functor )( h2 );
00559         ( *this->output_functor )( h3 );
00560         ( *this->output_functor )( MBTET );
00561
00562         return false;
00563     }
00564
00565     double* facept0c;
00566     double* facept1c;
00567     double* facept2c;
00568     double* facept3c;
00569     facept0c                  = this->heap_coord_storage();
00570     facept1c                  = this->heap_coord_storage();
00571     facept2c                  = this->heap_coord_storage();
00572     facept3c                  = this->heap_coord_storage();
00573     double* vertex_coords[14] = { v0,      v1,      v2,      v3,       midpt0c,  midpt1c,  midpt2c,
00574                                   midpt3c, midpt4c, midpt5c, facept0c, facept1c, facept2c, facept3c };
00575
00576     void* facept0t        = this->heap_tag_storage();
00577     void* facept1t        = this->heap_tag_storage();
00578     void* facept2t        = this->heap_tag_storage();
00579     void* facept3t        = this->heap_tag_storage();
00580     void* vertex_tags[14] = { t0,      t1,      t2,      t3,       midpt0t,  midpt1t,  midpt2t,
00581                               midpt3t, midpt4t, midpt5t, facept0t, facept1t, facept2t, facept3t };
00582
00583     EntityHandle vertex_hash[14] = { h0, h1, h2, h3, midpt0h, midpt1h, midpt2h, midpt3h, midpt4h, midpt5h, 0, 0, 0, 0 };
00584
00585     // Generate tetrahedra that are compatible except when edge
00586     // lengths are equal on indeterminately subdivided faces.
00587     double* permuted_coords[14];
00588     void* permuted_tags[14];
00589     EntityHandle permuted_hash[14];
00590     double permlen[6];  // permuted edge lengths
00591     int C = SimplexTemplateRefiner::template_index[edge_code][0];
00592     int P = SimplexTemplateRefiner::template_index[edge_code][1];
00593
00594     // 1. Permute the tetrahedron into our canonical configuration
00595     for( int i = 0; i < 14; ++i )
00596     {
00597         permuted_coords[i] = vertex_coords[SimplexTemplateRefiner::permutations_from_index[P][i]];
00598         permuted_tags[i]   = vertex_tags[SimplexTemplateRefiner::permutations_from_index[P][i]];
00599         permuted_hash[i]   = vertex_hash[SimplexTemplateRefiner::permutations_from_index[P][i]];
00600     }
00601
00602     for( int i = 4; i < 10; ++i )
00603     {
00604         // permute edge lengths too
00605         permlen[i - 4] = edge_length2[SimplexTemplateRefiner::permutations_from_index[P][i] - 4];
00606     }
00607
00608     int comparison_bits;
00609     std::stack< int* > output_tets;
00610     std::stack< int* > output_perm;
00611     std::stack< int > output_sign;
00612
00613     // cout << "Case " << C << "  Permutation " << P << endl;
00614     // 2. Generate tetrahedra based on the configuration.
00615     //    Note that case 0 is handled above (edgeCode == 0).
00616
00617     switch( C )
00618     {
00619         case 1:  // Ruprecht-Müller Case 1
00620             MB_TESSELLATOR_INCR_CASE_COUNT( 0 );
00621             output_tets.push( SimplexTemplateRefiner::templates + 0 );
00622             output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00623             output_sign.push( 1 );
00624             MB_TESSELLATOR_INCR_SUBCASE_COUNT( 0, 0 );
00625             break;
00626         case 2:  // Ruprecht-Müller Case 2a
00627             comparison_bits = ( permlen[0] <= permlen[1] ? 1 : 0 ) | ( permlen[0] >= permlen[1] ? 2 : 0 ) | 0;
00628             if( ( comparison_bits & 3 ) == 3 )
00629             {
00630                 // Compute face point and tag
00631                 for( int i = 0; i < 6; ++i )
00632                 {
00633                     permuted_coords[10][i] =
00634                         ( permuted_coords[0][i] + permuted_coords[2][i] ) * .375 + permuted_coords[1][i] * .25;
00635                 }
00636                 ( *this->tag_assigner )( permuted_tags[0], permuted_tags[2], permuted_tags[1], permuted_tags[10] );
00637                 permuted_hash[10] = ( *this->output_functor )( permuted_hash[0], permuted_hash[2], permuted_hash[1],
00638        permuted_coords[10], permuted_tags[10] );
00639             }
00640             MB_TESSELLATOR_INCR_CASE_COUNT( 1 );
00641             output_tets.push( SimplexTemplateRefiner::templates + 9 );
00642             output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00643             output_sign.push( 1 );
00644             MB_TESSELLATOR_INCR_SUBCASE_COUNT( 1, 0 );
00645             switch( comparison_bits )
00646             {
00647                 case 2:  // 0>1
00648                     output_tets.push( SimplexTemplateRefiner::templates + 14 );
00649                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00650                     output_sign.push( 1 );
00651                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 1, 1 );
00652                     break;
00653                 case 1:  // 1>0
00654                     output_tets.push( SimplexTemplateRefiner::templates + 14 );
00655                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[13] );
00656                     output_sign.push( -1 );
00657                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 1, 2 );
00658                     break;
00659                 case 3:  // 0=1
00660                     output_tets.push( SimplexTemplateRefiner::templates + 23 );
00661                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00662                     output_sign.push( 1 );
00663                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 1, 3 );
00664                     break;
00665             }
00666             break;
00667         case 3:  // Ruprecht-Müller Case 2b
00668             MB_TESSELLATOR_INCR_CASE_COUNT( 2 );
00669             output_tets.push( SimplexTemplateRefiner::templates + 40 );
00670             output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00671             output_sign.push( 1 );
00672             MB_TESSELLATOR_INCR_SUBCASE_COUNT( 2, 0 );
00673             break;
00674         case 4:  // Ruprecht-Müller Case 3a
00675             comparison_bits = ( permlen[0] <= permlen[3] ? 1 : 0 ) | ( permlen[0] >= permlen[3] ? 2 : 0 ) |
00676                               ( permlen[2] <= permlen[3] ? 4 : 0 ) | ( permlen[2] >= permlen[3] ? 8 : 0 ) |
00677                               ( permlen[0] <= permlen[2] ? 16 : 0 ) | ( permlen[0] >= permlen[2] ? 32 : 0 ) | 0;
00678             if( ( comparison_bits & 3 ) == 3 )
00679             {
00680                 // Compute face point and tag
00681                 for( int i = 0; i < 6; ++i )
00682                 {
00683                     permuted_coords[11][i] =
00684                         ( permuted_coords[1][i] + permuted_coords[3][i] ) * .375 + permuted_coords[0][i] * .25;
00685                 }
00686                 ( *this->tag_assigner )( permuted_tags[1], permuted_tags[3], permuted_tags[0], permuted_tags[11] );
00687                 permuted_hash[11] = ( *this->output_functor )( permuted_hash[1], permuted_hash[3], permuted_hash[0],
00688        permuted_coords[11], permuted_tags[11] );
00689             }
00690             if( ( comparison_bits & 12 ) == 12 )
00691             {
00692                 // Compute face point and tag
00693                 for( int i = 0; i < 6; ++i )
00694                 {
00695                     permuted_coords[13][i] =
00696                         ( permuted_coords[2][i] + permuted_coords[3][i] ) * .375 + permuted_coords[0][i] * .25;
00697                 }
00698                 ( *this->tag_assigner )( permuted_tags[2], permuted_tags[3], permuted_tags[0], permuted_tags[13] );
00699                 permuted_hash[13] = ( *this->output_functor )( permuted_hash[2], permuted_hash[3], permuted_hash[0],
00700        permuted_coords[13], permuted_tags[13] );
00701             }
00702             if( ( comparison_bits & 48 ) == 48 )
00703             {
00704                 // Compute face point and tag
00705                 for( int i = 0; i < 6; ++i )
00706                 {
00707                     permuted_coords[10][i] =
00708                         ( permuted_coords[1][i] + permuted_coords[2][i] ) * .375 + permuted_coords[0][i] * .25;
00709                 }
00710                 ( *this->tag_assigner )( permuted_tags[1], permuted_tags[2], permuted_tags[0], permuted_tags[10] );
00711                 permuted_hash[10] = ( *this->output_functor )( permuted_hash[1], permuted_hash[2], permuted_hash[0],
00712        permuted_coords[10], permuted_tags[10] );
00713             }
00714             MB_TESSELLATOR_INCR_CASE_COUNT( 3 );
00715             output_tets.push( SimplexTemplateRefiner::templates + 57 );
00716             output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00717             output_sign.push( 1 );
00718             MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 0 );
00719             switch( comparison_bits )
00720             {
00721                 case 42:  // 0>2>3<0
00722                     output_tets.push( SimplexTemplateRefiner::templates + 62 );
00723                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00724                     output_sign.push( 1 );
00725                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 1 );
00726                     break;
00727                 case 25:  // 2>3>0<2
00728                     output_tets.push( SimplexTemplateRefiner::templates + 62 );
00729                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[11] );
00730                     output_sign.push( 1 );
00731                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 2 );
00732                     break;
00733                 case 37:  // 3>0>2<3
00734                     output_tets.push( SimplexTemplateRefiner::templates + 62 );
00735                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[3] );
00736                     output_sign.push( 1 );
00737                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 3 );
00738                     break;
00739                 case 21:  // 3>2>0<3
00740                     output_tets.push( SimplexTemplateRefiner::templates + 62 );
00741                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[22] );
00742                     output_sign.push( -1 );
00743                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 4 );
00744                     break;
00745                 case 26:  // 2>0>3<2
00746                     output_tets.push( SimplexTemplateRefiner::templates + 62 );
00747                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[12] );
00748                     output_sign.push( -1 );
00749                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 5 );
00750                     break;
00751                 case 38:  // 0>3>2<0
00752                     output_tets.push( SimplexTemplateRefiner::templates + 62 );
00753                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
00754                     output_sign.push( -1 );
00755                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 6 );
00756                     break;
00757                 case 58:  // 0=2>3<0
00758                     output_tets.push( SimplexTemplateRefiner::templates + 75 );
00759                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00760                     output_sign.push( 1 );
00761                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 7 );
00762                     break;
00763                 case 29:  // 2=3>0<2
00764                     output_tets.push( SimplexTemplateRefiner::templates + 75 );
00765                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[11] );
00766                     output_sign.push( 1 );
00767                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 8 );
00768                     break;
00769                 case 39:  // 0=3>2<0
00770                     output_tets.push( SimplexTemplateRefiner::templates + 75 );
00771                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[3] );
00772                     output_sign.push( 1 );
00773                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 9 );
00774                     break;
00775                 case 53:  // 3>0=2<3
00776                     output_tets.push( SimplexTemplateRefiner::templates + 96 );
00777                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00778                     output_sign.push( 1 );
00779                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 10 );
00780                     break;
00781                 case 46:  // 0>2=3<0
00782                     output_tets.push( SimplexTemplateRefiner::templates + 96 );
00783                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[11] );
00784                     output_sign.push( 1 );
00785                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 11 );
00786                     break;
00787                 case 27:  // 2>0=3<2
00788                     output_tets.push( SimplexTemplateRefiner::templates + 96 );
00789                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[3] );
00790                     output_sign.push( 1 );
00791                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 12 );
00792                     break;
00793                 case 63:  // 0=2=3=0
00794                     output_tets.push( SimplexTemplateRefiner::templates + 117 );
00795                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00796                     output_sign.push( 1 );
00797                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 3, 13 );
00798                     break;
00799             }
00800             break;
00801         case 5:  // Ruprecht-Müller Case 3b
00802             MB_TESSELLATOR_INCR_CASE_COUNT( 4 );
00803             output_tets.push( SimplexTemplateRefiner::templates + 162 );
00804             output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00805             output_sign.push( 1 );
00806             MB_TESSELLATOR_INCR_SUBCASE_COUNT( 4, 0 );
00807             break;
00808         case 6:  // Ruprecht-Müller Case 3c
00809             comparison_bits = ( permlen[0] <= permlen[1] ? 1 : 0 ) | ( permlen[0] >= permlen[1] ? 2 : 0 ) |
00810                               ( permlen[0] <= permlen[3] ? 4 : 0 ) | ( permlen[0] >= permlen[3] ? 8 : 0 ) | 0;
00811             if( ( comparison_bits & 3 ) == 3 )
00812             {
00813                 // Compute face point and tag
00814                 for( int i = 0; i < 6; ++i )
00815                 {
00816                     permuted_coords[10][i] =
00817                         ( permuted_coords[0][i] + permuted_coords[2][i] ) * .375 + permuted_coords[1][i] * .25;
00818                 }
00819                 ( *this->tag_assigner )( permuted_tags[0], permuted_tags[2], permuted_tags[1], permuted_tags[10] );
00820                 permuted_hash[10] = ( *this->output_functor )( permuted_hash[0], permuted_hash[2], permuted_hash[1],
00821        permuted_coords[10], permuted_tags[10] );
00822             }
00823             if( ( comparison_bits & 12 ) == 12 )
00824             {
00825                 // Compute face point and tag
00826                 for( int i = 0; i < 6; ++i )
00827                 {
00828                     permuted_coords[11][i] =
00829                         ( permuted_coords[1][i] + permuted_coords[3][i] ) * .375 + permuted_coords[0][i] * .25;
00830                 }
00831                 ( *this->tag_assigner )( permuted_tags[1], permuted_tags[3], permuted_tags[0], permuted_tags[11] );
00832                 permuted_hash[11] = ( *this->output_functor )( permuted_hash[1], permuted_hash[3], permuted_hash[0],
00833        permuted_coords[11], permuted_tags[11] );
00834             }
00835             MB_TESSELLATOR_INCR_CASE_COUNT( 5 );
00836             switch( comparison_bits )
00837             {
00838                 case 10:  // 0>1,0>3
00839                     output_tets.push( SimplexTemplateRefiner::templates + 179 );
00840                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00841                     output_sign.push( 1 );
00842                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 5, 0 );
00843                     break;
00844                 case 5:  // 1>0,3>0
00845                     output_tets.push( SimplexTemplateRefiner::templates + 200 );
00846                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00847                     output_sign.push( 1 );
00848                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 5, 1 );
00849                     break;
00850                 case 6:  // 0>1,3>0
00851                     output_tets.push( SimplexTemplateRefiner::templates + 221 );
00852                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00853                     output_sign.push( 1 );
00854                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 5, 2 );
00855                     break;
00856                 case 9:  // 1>0,0>3
00857                     output_tets.push( SimplexTemplateRefiner::templates + 242 );
00858                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00859                     output_sign.push( 1 );
00860                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 5, 3 );
00861                     break;
00862                 case 11:  // 0=1,0>3
00863                     output_tets.push( SimplexTemplateRefiner::templates + 263 );
00864                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00865                     output_sign.push( 1 );
00866                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 5, 4 );
00867                     break;
00868                 case 14:  // 0=3,0>1
00869                     output_tets.push( SimplexTemplateRefiner::templates + 263 );
00870                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
00871                     output_sign.push( 1 );
00872                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 5, 5 );
00873                     break;
00874                 case 7:  // 3>0,0=1
00875                     output_tets.push( SimplexTemplateRefiner::templates + 292 );
00876                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00877                     output_sign.push( 1 );
00878                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 5, 6 );
00879                     break;
00880                 case 13:  // 1>0,0=3
00881                     output_tets.push( SimplexTemplateRefiner::templates + 292 );
00882                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
00883                     output_sign.push( 1 );
00884                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 5, 7 );
00885                     break;
00886                 case 15:  // 0=1,0=3
00887                     output_tets.push( SimplexTemplateRefiner::templates + 321 );
00888                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00889                     output_sign.push( 1 );
00890                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 5, 8 );
00891                     break;
00892             }
00893             break;
00894         case 7:  // Ruprecht-Müller Case 3d
00895             comparison_bits = ( permlen[0] <= permlen[2] ? 1 : 0 ) | ( permlen[0] >= permlen[2] ? 2 : 0 ) |
00896                               ( permlen[0] <= permlen[4] ? 4 : 0 ) | ( permlen[0] >= permlen[4] ? 8 : 0 ) | 0;
00897             if( ( comparison_bits & 3 ) == 3 )
00898             {
00899                 // Compute face point and tag
00900                 for( int i = 0; i < 6; ++i )
00901                 {
00902                     permuted_coords[10][i] =
00903                         ( permuted_coords[1][i] + permuted_coords[2][i] ) * .375 + permuted_coords[0][i] * .25;
00904                 }
00905                 ( *this->tag_assigner )( permuted_tags[1], permuted_tags[2], permuted_tags[0], permuted_tags[10] );
00906                 permuted_hash[10] = ( *this->output_functor )( permuted_hash[1], permuted_hash[2], permuted_hash[0],
00907        permuted_coords[10], permuted_tags[10] );
00908             }
00909             if( ( comparison_bits & 12 ) == 12 )
00910             {
00911                 // Compute face point and tag
00912                 for( int i = 0; i < 6; ++i )
00913                 {
00914                     permuted_coords[11][i] =
00915                         ( permuted_coords[0][i] + permuted_coords[3][i] ) * .375 + permuted_coords[1][i] * .25;
00916                 }
00917                 ( *this->tag_assigner )( permuted_tags[0], permuted_tags[3], permuted_tags[1], permuted_tags[11] );
00918                 permuted_hash[11] = ( *this->output_functor )( permuted_hash[0], permuted_hash[3], permuted_hash[1],
00919        permuted_coords[11], permuted_tags[11] );
00920             }
00921             MB_TESSELLATOR_INCR_CASE_COUNT( 6 );
00922             switch( comparison_bits )
00923             {
00924                 case 10:  // 0>4,0>2
00925                     output_tets.push( SimplexTemplateRefiner::templates + 362 );
00926                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00927                     output_sign.push( 1 );
00928                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 6, 0 );
00929                     break;
00930                 case 5:  // 4>0,2>0
00931                     output_tets.push( SimplexTemplateRefiner::templates + 383 );
00932                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00933                     output_sign.push( 1 );
00934                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 6, 1 );
00935                     break;
00936                 case 9:  // 0>4,2>0
00937                     output_tets.push( SimplexTemplateRefiner::templates + 404 );
00938                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00939                     output_sign.push( 1 );
00940                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 6, 2 );
00941                     break;
00942                 case 6:  // 4>0,0>2
00943                     output_tets.push( SimplexTemplateRefiner::templates + 425 );
00944                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00945                     output_sign.push( 1 );
00946                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 6, 3 );
00947                     break;
00948                 case 14:  // 0=4,0>2
00949                     output_tets.push( SimplexTemplateRefiner::templates + 446 );
00950                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00951                     output_sign.push( 1 );
00952                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 6, 4 );
00953                     break;
00954                 case 11:  // 0=2,0>4
00955                     output_tets.push( SimplexTemplateRefiner::templates + 446 );
00956                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
00957                     output_sign.push( 1 );
00958                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 6, 5 );
00959                     break;
00960                 case 13:  // 2>0,0=4
00961                     output_tets.push( SimplexTemplateRefiner::templates + 475 );
00962                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00963                     output_sign.push( 1 );
00964                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 6, 6 );
00965                     break;
00966                 case 7:  // 4>0,0=2
00967                     output_tets.push( SimplexTemplateRefiner::templates + 475 );
00968                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
00969                     output_sign.push( 1 );
00970                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 6, 7 );
00971                     break;
00972                 case 15:  // 0=4,0=2
00973                     output_tets.push( SimplexTemplateRefiner::templates + 504 );
00974                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
00975                     output_sign.push( 1 );
00976                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 6, 8 );
00977                     break;
00978             }
00979             break;
00980         case 8:  // Ruprecht-Müller Case 4a
00981             comparison_bits = ( permlen[4] <= permlen[5] ? 1 : 0 ) | ( permlen[4] >= permlen[5] ? 2 : 0 ) |
00982                               ( permlen[3] <= permlen[4] ? 4 : 0 ) | ( permlen[3] >= permlen[4] ? 8 : 0 ) | 0;
00983             if( ( comparison_bits & 3 ) == 3 )
00984             {
00985                 // Compute face point and tag
00986                 for( int i = 0; i < 6; ++i )
00987                 {
00988                     permuted_coords[12][i] =
00989                         ( permuted_coords[1][i] + permuted_coords[2][i] ) * .375 + permuted_coords[3][i] * .25;
00990                 }
00991                 ( *this->tag_assigner )( permuted_tags[1], permuted_tags[2], permuted_tags[3], permuted_tags[12] );
00992                 permuted_hash[12] = ( *this->output_functor )( permuted_hash[1], permuted_hash[2], permuted_hash[3],
00993        permuted_coords[12], permuted_tags[12] );
00994             }
00995             if( ( comparison_bits & 12 ) == 12 )
00996             {
00997                 // Compute face point and tag
00998                 for( int i = 0; i < 6; ++i )
00999                 {
01000                     permuted_coords[11][i] =
01001                         ( permuted_coords[0][i] + permuted_coords[1][i] ) * .375 + permuted_coords[3][i] * .25;
01002                 }
01003                 ( *this->tag_assigner )( permuted_tags[0], permuted_tags[1], permuted_tags[3], permuted_tags[11] );
01004                 permuted_hash[11] = ( *this->output_functor )( permuted_hash[0], permuted_hash[1], permuted_hash[3],
01005        permuted_coords[11], permuted_tags[11] );
01006             }
01007             MB_TESSELLATOR_INCR_CASE_COUNT( 7 );
01008             output_tets.push( SimplexTemplateRefiner::templates + 545 );
01009             output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01010             output_sign.push( 1 );
01011             MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 0 );
01012             switch( comparison_bits )
01013             {
01014                 case 5:  // 5>4>3
01015                     output_tets.push( SimplexTemplateRefiner::templates + 554 );
01016                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01017                     output_sign.push( 1 );
01018                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 1 );
01019                     break;
01020                 case 10:  // 3>4>5
01021                     output_tets.push( SimplexTemplateRefiner::templates + 554 );
01022                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[13] );
01023                     output_sign.push( -1 );
01024                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 2 );
01025                     break;
01026                 case 6:  // 3<4>5
01027                     output_tets.push( SimplexTemplateRefiner::templates + 571 );
01028                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01029                     output_sign.push( 1 );
01030                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 3 );
01031                     break;
01032                 case 9:  // 3>4<5
01033                     output_tets.push( SimplexTemplateRefiner::templates + 588 );
01034                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01035                     output_sign.push( 1 );
01036                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 4 );
01037                     break;
01038                 case 14:  // 3=4>5
01039                     output_tets.push( SimplexTemplateRefiner::templates + 605 );
01040                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01041                     output_sign.push( 1 );
01042                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 5 );
01043                     break;
01044                 case 7:  // 4=5,4>3
01045                     output_tets.push( SimplexTemplateRefiner::templates + 605 );
01046                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[13] );
01047                     output_sign.push( -1 );
01048                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 6 );
01049                     break;
01050                 case 13:  // 5>4,3=4
01051                     output_tets.push( SimplexTemplateRefiner::templates + 630 );
01052                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01053                     output_sign.push( 1 );
01054                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 7 );
01055                     break;
01056                 case 11:  // 3>4=5
01057                     output_tets.push( SimplexTemplateRefiner::templates + 630 );
01058                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[13] );
01059                     output_sign.push( -1 );
01060                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 8 );
01061                     break;
01062                 case 15:  // 3=4=5
01063                     output_tets.push( SimplexTemplateRefiner::templates + 655 );
01064                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01065                     output_sign.push( 1 );
01066                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 7, 9 );
01067                     break;
01068             }
01069             break;
01070         case 9:  // Ruprecht-Müller Case 4b
01071             comparison_bits = ( permlen[1] <= permlen[2] ? 1 : 0 ) | ( permlen[1] >= permlen[2] ? 2 : 0 ) |
01072                               ( permlen[2] <= permlen[3] ? 4 : 0 ) | ( permlen[2] >= permlen[3] ? 8 : 0 ) |
01073                               ( permlen[3] <= permlen[4] ? 16 : 0 ) | ( permlen[3] >= permlen[4] ? 32 : 0 ) |
01074                               ( permlen[1] <= permlen[4] ? 64 : 0 ) | ( permlen[1] >= permlen[4] ? 128 : 0 ) | 0;
01075             if( ( comparison_bits & 3 ) == 3 )
01076             {
01077                 // Compute face point and tag
01078                 for( int i = 0; i < 6; ++i )
01079                 {
01080                     permuted_coords[10][i] =
01081                         ( permuted_coords[1][i] + permuted_coords[0][i] ) * .375 + permuted_coords[2][i] * .25;
01082                 }
01083                 ( *this->tag_assigner )( permuted_tags[1], permuted_tags[0], permuted_tags[2], permuted_tags[10] );
01084                 permuted_hash[10] = ( *this->output_functor )( permuted_hash[1], permuted_hash[0], permuted_hash[2],
01085        permuted_coords[10], permuted_tags[10] );
01086             }
01087             if( ( comparison_bits & 12 ) == 12 )
01088             {
01089                 // Compute face point and tag
01090                 for( int i = 0; i < 6; ++i )
01091                 {
01092                     permuted_coords[13][i] =
01093                         ( permuted_coords[2][i] + permuted_coords[3][i] ) * .375 + permuted_coords[0][i] * .25;
01094                 }
01095                 ( *this->tag_assigner )( permuted_tags[2], permuted_tags[3], permuted_tags[0], permuted_tags[13] );
01096                 permuted_hash[13] = ( *this->output_functor )( permuted_hash[2], permuted_hash[3], permuted_hash[0],
01097        permuted_coords[13], permuted_tags[13] );
01098             }
01099             if( ( comparison_bits & 48 ) == 48 )
01100             {
01101                 // Compute face point and tag
01102                 for( int i = 0; i < 6; ++i )
01103                 {
01104                     permuted_coords[11][i] =
01105                         ( permuted_coords[0][i] + permuted_coords[1][i] ) * .375 + permuted_coords[3][i] * .25;
01106                 }
01107                 ( *this->tag_assigner )( permuted_tags[0], permuted_tags[1], permuted_tags[3], permuted_tags[11] );
01108                 permuted_hash[11] = ( *this->output_functor )( permuted_hash[0], permuted_hash[1], permuted_hash[3],
01109        permuted_coords[11], permuted_tags[11] );
01110             }
01111             if( ( comparison_bits & 192 ) == 192 )
01112             {
01113                 // Compute face point and tag
01114                 for( int i = 0; i < 6; ++i )
01115                 {
01116                     permuted_coords[12][i] =
01117                         ( permuted_coords[2][i] + permuted_coords[3][i] ) * .375 + permuted_coords[1][i] * .25;
01118                 }
01119                 ( *this->tag_assigner )( permuted_tags[2], permuted_tags[3], permuted_tags[1], permuted_tags[12] );
01120                 permuted_hash[12] = ( *this->output_functor )( permuted_hash[2], permuted_hash[3], permuted_hash[1],
01121        permuted_coords[12], permuted_tags[12] );
01122             }
01123             MB_TESSELLATOR_INCR_CASE_COUNT( 8 );
01124             switch( comparison_bits )
01125             {
01126                 case 85:  // 2>1,3>2,4>3,4>1
01127                     output_tets.push( SimplexTemplateRefiner::templates + 688 );
01128                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01129                     output_sign.push( 1 );
01130                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 0 );
01131                     break;
01132                 case 102:  // 1>2,3>2,3>4,4>1
01133                     output_tets.push( SimplexTemplateRefiner::templates + 688 );
01134                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01135                     output_sign.push( -1 );
01136                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 1 );
01137                     break;
01138                 case 170:  // 1>2,2>3,3>4,1>4
01139                     output_tets.push( SimplexTemplateRefiner::templates + 688 );
01140                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01141                     output_sign.push( -1 );
01142                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 2 );
01143                     break;
01144                 case 153:  // 2>1,2>3,4>3,1>4
01145                     output_tets.push( SimplexTemplateRefiner::templates + 688 );
01146                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
01147                     output_sign.push( 1 );
01148                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 3 );
01149                     break;
01150                 case 90:  // 1>2,2>3,4>3,4>1
01151                     output_tets.push( SimplexTemplateRefiner::templates + 688 );
01152                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[9] );
01153                     output_sign.push( 1 );
01154                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 4 );
01155                     break;
01156                 case 105:  // 2>1,2>3,3>4,4>1
01157                     output_tets.push( SimplexTemplateRefiner::templates + 688 );
01158                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[7] );
01159                     output_sign.push( 1 );
01160                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 5 );
01161                     break;
01162                 case 165:  // 2>1,3>2,3>4,1>4
01163                     output_tets.push( SimplexTemplateRefiner::templates + 688 );
01164                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[19] );
01165                     output_sign.push( -1 );
01166                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 6 );
01167                     break;
01168                 case 150:  // 1>2,3>2,4>3,1>4
01169                     output_tets.push( SimplexTemplateRefiner::templates + 688 );
01170                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[23] );
01171                     output_sign.push( -1 );
01172                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 7 );
01173                     break;
01174                 case 101:  // 2>1,3>2,3>4,4>1
01175                 {
01176                     int alternates[] = { 713, 738, -1 };
01177                     output_tets.push( SimplexTemplateRefiner::templates +
01178                                       this->best_tets( alternates, permuted_coords, 0, 1 ) );
01179                 }
01180                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01181                     output_sign.push( 1 );
01182                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 8 );
01183                     break;
01184                 case 86:  // 1>2,3>2,4>3,4>1
01185                 {
01186                     int alternates[] = { 713, 738, -1 };
01187                     output_tets.push( SimplexTemplateRefiner::templates +
01188                                       this->best_tets( alternates, permuted_coords, 14, -1 ) );
01189                 }
01190                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01191                     output_sign.push( -1 );
01192                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 9 );
01193                     break;
01194                 case 154:  // 1>2,2>3,4>3,1>4
01195                 {
01196                     int alternates[] = { 713, 738, -1 };
01197                     output_tets.push( SimplexTemplateRefiner::templates +
01198                                       this->best_tets( alternates, permuted_coords, 5, 1 ) );
01199                 }
01200                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
01201                     output_sign.push( 1 );
01202                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 10 );
01203                     break;
01204                 case 169:  // 2>1,2>3,3>4,1>4
01205                 {
01206                     int alternates[] = { 713, 738, -1 };
01207                     output_tets.push( SimplexTemplateRefiner::templates +
01208                                       this->best_tets( alternates, permuted_coords, 15, -1 ) );
01209                 }
01210                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01211                     output_sign.push( -1 );
01212                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 11 );
01213                     break;
01214                 case 89:  // 2>1,2>3,4>3,4>1
01215                     output_tets.push( SimplexTemplateRefiner::templates + 763 );
01216                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01217                     output_sign.push( 1 );
01218                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 12 );
01219                     break;
01220                 case 166:  // 1>2,3>2,3>4,1>4
01221                     output_tets.push( SimplexTemplateRefiner::templates + 763 );
01222                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01223                     output_sign.push( -1 );
01224                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 13 );
01225                     break;
01226                 case 103:  // 1=2,3>2,3>4,4>1
01227                     output_tets.push( SimplexTemplateRefiner::templates + 788 );
01228                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01229                     output_sign.push( 1 );
01230                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 14 );
01231                     break;
01232                 case 87:  // 1=2,3>2,4>3,4>1
01233                     output_tets.push( SimplexTemplateRefiner::templates + 788 );
01234                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01235                     output_sign.push( -1 );
01236                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 15 );
01237                     break;
01238                 case 185:  // 2>1,2>3,3=4,1>4
01239                     output_tets.push( SimplexTemplateRefiner::templates + 788 );
01240                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01241                     output_sign.push( -1 );
01242                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 16 );
01243                     break;
01244                 case 186:  // 1>2,2>3,3=4,1>4
01245                     output_tets.push( SimplexTemplateRefiner::templates + 788 );
01246                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
01247                     output_sign.push( 1 );
01248                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 17 );
01249                     break;
01250                 case 158:  // 1>2,2=3,4>3,1>4
01251                     output_tets.push( SimplexTemplateRefiner::templates + 788 );
01252                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[9] );
01253                     output_sign.push( 1 );
01254                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 18 );
01255                     break;
01256                 case 229:  // 2>1,3>2,3>4,1=4
01257                     output_tets.push( SimplexTemplateRefiner::templates + 788 );
01258                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[7] );
01259                     output_sign.push( 1 );
01260                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 19 );
01261                     break;
01262                 case 233:  // 2>1,2>3,3>4,1=4
01263                     output_tets.push( SimplexTemplateRefiner::templates + 788 );
01264                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[19] );
01265                     output_sign.push( -1 );
01266                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 20 );
01267                     break;
01268                 case 94:  // 1>2,2=3,4>3,4>1
01269                     output_tets.push( SimplexTemplateRefiner::templates + 788 );
01270                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[23] );
01271                     output_sign.push( -1 );
01272                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 21 );
01273                     break;
01274                 case 155:  // 1=2,2>3,4>3,1>4
01275                     output_tets.push( SimplexTemplateRefiner::templates + 825 );
01276                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01277                     output_sign.push( 1 );
01278                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 22 );
01279                     break;
01280                 case 171:  // 1=2,2>3,3>4,1>4
01281                     output_tets.push( SimplexTemplateRefiner::templates + 825 );
01282                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01283                     output_sign.push( -1 );
01284                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 23 );
01285                     break;
01286                 case 118:  // 1>2,3>2,3=4,4>1
01287                     output_tets.push( SimplexTemplateRefiner::templates + 825 );
01288                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01289                     output_sign.push( -1 );
01290                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 24 );
01291                     break;
01292                 case 117:  // 2>1,3>2,3=4,4>1
01293                     output_tets.push( SimplexTemplateRefiner::templates + 825 );
01294                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
01295                     output_sign.push( 1 );
01296                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 25 );
01297                     break;
01298                 case 109:  // 2>1,2=3,3>4,4>1
01299                     output_tets.push( SimplexTemplateRefiner::templates + 825 );
01300                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[9] );
01301                     output_sign.push( 1 );
01302                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 26 );
01303                     break;
01304                 case 218:  // 1>2,2>3,4>3,1=4
01305                     output_tets.push( SimplexTemplateRefiner::templates + 825 );
01306                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[7] );
01307                     output_sign.push( 1 );
01308                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 27 );
01309                     break;
01310                 case 214:  // 1>2,3>2,4>3,1=4
01311                     output_tets.push( SimplexTemplateRefiner::templates + 825 );
01312                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[19] );
01313                     output_sign.push( -1 );
01314                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 28 );
01315                     break;
01316                 case 173:  // 2>1,2=3,3>4,1>4
01317                     output_tets.push( SimplexTemplateRefiner::templates + 825 );
01318                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[23] );
01319                     output_sign.push( -1 );
01320                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 29 );
01321                     break;
01322                 case 91:  // 1=2,2>3,4>3,4>1
01323                     output_tets.push( SimplexTemplateRefiner::templates + 862 );
01324                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01325                     output_sign.push( 1 );
01326                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 30 );
01327                     break;
01328                 case 167:  // 1=2,3>2,3>4,1>4
01329                     output_tets.push( SimplexTemplateRefiner::templates + 862 );
01330                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01331                     output_sign.push( -1 );
01332                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 31 );
01333                     break;
01334                 case 182:  // 1>2,3>2,3=4,1>4
01335                     output_tets.push( SimplexTemplateRefiner::templates + 862 );
01336                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01337                     output_sign.push( -1 );
01338                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 32 );
01339                     break;
01340                 case 121:  // 2>1,2>3,3=4,4>1
01341                     output_tets.push( SimplexTemplateRefiner::templates + 862 );
01342                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
01343                     output_sign.push( 1 );
01344                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 33 );
01345                     break;
01346                 case 93:  // 2>1,2=3,4>3,4>1
01347                     output_tets.push( SimplexTemplateRefiner::templates + 862 );
01348                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[9] );
01349                     output_sign.push( 1 );
01350                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 34 );
01351                     break;
01352                 case 217:  // 2>1,2>3,4>3,1=4
01353                     output_tets.push( SimplexTemplateRefiner::templates + 862 );
01354                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[7] );
01355                     output_sign.push( 1 );
01356                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 35 );
01357                     break;
01358                 case 230:  // 1>2,3>2,3>4,1=4
01359                     output_tets.push( SimplexTemplateRefiner::templates + 862 );
01360                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[19] );
01361                     output_sign.push( -1 );
01362                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 36 );
01363                     break;
01364                 case 174:  // 1>2,2=3,3>4,1>4
01365                     output_tets.push( SimplexTemplateRefiner::templates + 862 );
01366                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[23] );
01367                     output_sign.push( -1 );
01368                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 37 );
01369                     break;
01370                 case 119:  // 1=2,3>2,3=4,4>1
01371                     output_tets.push( SimplexTemplateRefiner::templates + 899 );
01372                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01373                     output_sign.push( 1 );
01374                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 38 );
01375                     break;
01376                 case 187:  // 1=2>3=4,1>4
01377                     output_tets.push( SimplexTemplateRefiner::templates + 899 );
01378                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01379                     output_sign.push( -1 );
01380                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 39 );
01381                     break;
01382                 case 222:  // 1>2,2=3,4>3,1=4
01383                     output_tets.push( SimplexTemplateRefiner::templates + 899 );
01384                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[9] );
01385                     output_sign.push( 1 );
01386                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 40 );
01387                     break;
01388                 case 237:  // 2>1,2=3,3>4,1=4
01389                     output_tets.push( SimplexTemplateRefiner::templates + 899 );
01390                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[7] );
01391                     output_sign.push( 1 );
01392                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 41 );
01393                     break;
01394                 case 95:  // 4>1=2=3,4>3
01395                     output_tets.push( SimplexTemplateRefiner::templates + 944 );
01396                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01397                     output_sign.push( 1 );
01398                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 42 );
01399                     break;
01400                 case 231:  // 1=2,3>2,3>4,1=4
01401                     output_tets.push( SimplexTemplateRefiner::templates + 944 );
01402                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01403                     output_sign.push( -1 );
01404                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 43 );
01405                     break;
01406                 case 190:  // 1>2=3=4,1>4
01407                     output_tets.push( SimplexTemplateRefiner::templates + 944 );
01408                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01409                     output_sign.push( -1 );
01410                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 44 );
01411                     break;
01412                 case 249:  // 2>1,2>3,3=4,1=4
01413                     output_tets.push( SimplexTemplateRefiner::templates + 944 );
01414                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
01415                     output_sign.push( 1 );
01416                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 45 );
01417                     break;
01418                 case 175:  // 1=2=3>4,1>4
01419                     output_tets.push( SimplexTemplateRefiner::templates + 993 );
01420                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01421                     output_sign.push( 1 );
01422                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 46 );
01423                     break;
01424                 case 219:  // 1=2>3,4>3,1=4
01425                     output_tets.push( SimplexTemplateRefiner::templates + 993 );
01426                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01427                     output_sign.push( -1 );
01428                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 47 );
01429                     break;
01430                 case 125:  // 2>1,2=3=4>1
01431                     output_tets.push( SimplexTemplateRefiner::templates + 993 );
01432                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01433                     output_sign.push( -1 );
01434                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 48 );
01435                     break;
01436                 case 246:  // 1>2,3>2,3=4=1
01437                     output_tets.push( SimplexTemplateRefiner::templates + 993 );
01438                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
01439                     output_sign.push( 1 );
01440                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 49 );
01441                     break;
01442                 case 255:  // 1=2=3=4=1
01443                     output_tets.push( SimplexTemplateRefiner::templates + 1042 );
01444                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01445                     output_sign.push( 1 );
01446                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 8, 50 );
01447                     break;
01448             }
01449             break;
01450         case 10:  // Ruprecht-Müller Case 5
01451             comparison_bits = ( permlen[1] <= permlen[2] ? 1 : 0 ) | ( permlen[1] >= permlen[2] ? 2 : 0 ) |
01452                               ( permlen[3] <= permlen[4] ? 4 : 0 ) | ( permlen[3] >= permlen[4] ? 8 : 0 ) | 0;
01453             if( ( comparison_bits & 3 ) == 3 )
01454             {
01455                 // Compute face point and tag
01456                 for( int i = 0; i < 6; ++i )
01457                 {
01458                     permuted_coords[10][i] =
01459                         ( permuted_coords[1][i] + permuted_coords[0][i] ) * .375 + permuted_coords[2][i] * .25;
01460                 }
01461                 ( *this->tag_assigner )( permuted_tags[1], permuted_tags[0], permuted_tags[2], permuted_tags[10] );
01462                 permuted_hash[10] = ( *this->output_functor )( permuted_hash[1], permuted_hash[0], permuted_hash[2],
01463        permuted_coords[10], permuted_tags[10] );
01464             }
01465             if( ( comparison_bits & 12 ) == 12 )
01466             {
01467                 // Compute face point and tag
01468                 for( int i = 0; i < 6; ++i )
01469                 {
01470                     permuted_coords[11][i] =
01471                         ( permuted_coords[0][i] + permuted_coords[1][i] ) * .375 + permuted_coords[3][i] * .25;
01472                 }
01473                 ( *this->tag_assigner )( permuted_tags[0], permuted_tags[1], permuted_tags[3], permuted_tags[11] );
01474                 permuted_hash[11] = ( *this->output_functor )( permuted_hash[0], permuted_hash[1], permuted_hash[3],
01475        permuted_coords[11], permuted_tags[11] );
01476             }
01477             MB_TESSELLATOR_INCR_CASE_COUNT( 9 );
01478             output_tets.push( SimplexTemplateRefiner::templates + 1107 );
01479             output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01480             output_sign.push( 1 );
01481             MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 0 );
01482             switch( comparison_bits )
01483             {
01484                 case 10:  // 1>2,3>4
01485                     output_tets.push( SimplexTemplateRefiner::templates + 1116 );
01486                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01487                     output_sign.push( 1 );
01488                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 1 );
01489                     break;
01490                 case 5:  // 2>1,4>3
01491                     output_tets.push( SimplexTemplateRefiner::templates + 1116 );
01492                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01493                     output_sign.push( -1 );
01494                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 2 );
01495                     break;
01496                 case 6:  // 1>2,4>3
01497                 {
01498                     int alternates[] = { 1137, 1158, -1 };
01499                     output_tets.push( SimplexTemplateRefiner::templates +
01500                                       this->best_tets( alternates, permuted_coords, 0, 1 ) );
01501                 }
01502                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01503                     output_sign.push( 1 );
01504                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 3 );
01505                     break;
01506                 case 9:  // 2>1,3>4
01507                 {
01508                     int alternates[] = { 1137, 1158, -1 };
01509                     output_tets.push( SimplexTemplateRefiner::templates +
01510                                       this->best_tets( alternates, permuted_coords, 14, -1 ) );
01511                 }
01512                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01513                     output_sign.push( -1 );
01514                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 4 );
01515                     break;
01516                 case 11:  // 1=2,3>4
01517                 {
01518                     int alternates[] = { 1179, 1212, 1245, -1 };
01519                     output_tets.push( SimplexTemplateRefiner::templates +
01520                                       this->best_tets( alternates, permuted_coords, 0, 1 ) );
01521                 }
01522                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01523                     output_sign.push( 1 );
01524                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 5 );
01525                     break;
01526                 case 7:  // 1=2,4>3
01527                 {
01528                     int alternates[] = { 1179, 1212, 1245, -1 };
01529                     output_tets.push( SimplexTemplateRefiner::templates +
01530                                       this->best_tets( alternates, permuted_coords, 14, -1 ) );
01531                 }
01532                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[14] );
01533                     output_sign.push( -1 );
01534                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 6 );
01535                     break;
01536                 case 14:  // 3=4,1>2
01537                 {
01538                     int alternates[] = { 1179, 1212, 1245, -1 };
01539                     output_tets.push( SimplexTemplateRefiner::templates +
01540                                       this->best_tets( alternates, permuted_coords, 5, 1 ) );
01541                 }
01542                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[5] );
01543                     output_sign.push( 1 );
01544                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 7 );
01545                     break;
01546                 case 13:  // 3=4,2>1
01547                 {
01548                     int alternates[] = { 1179, 1212, 1245, -1 };
01549                     output_tets.push( SimplexTemplateRefiner::templates +
01550                                       this->best_tets( alternates, permuted_coords, 15, -1 ) );
01551                 }
01552                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[15] );
01553                     output_sign.push( -1 );
01554                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 8 );
01555                     break;
01556                 case 15:  // 1=2,3=4
01557                     output_tets.push( SimplexTemplateRefiner::templates + 1278 );
01558                     output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01559                     output_sign.push( 1 );
01560                     MB_TESSELLATOR_INCR_SUBCASE_COUNT( 9, 9 );
01561                     break;
01562             }
01563             break;
01564         case 11:  // Ruprecht-Müller Case 6
01565             MB_TESSELLATOR_INCR_CASE_COUNT( 10 );
01566             output_tets.push( SimplexTemplateRefiner::templates + 1319 );
01567             output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01568             output_sign.push( 1 );
01569             MB_TESSELLATOR_INCR_SUBCASE_COUNT( 10, 0 );
01570             {
01571                 int alternates[] = { 1336, 1353, 1370, -1 };
01572                 output_tets.push( SimplexTemplateRefiner::templates +
01573                                   this->best_tets( alternates, permuted_coords, 0, 1 ) );
01574             }
01575             output_perm.push( SimplexTemplateRefiner::permutations_from_index[0] );
01576             output_sign.push( 1 );
01577             MB_TESSELLATOR_INCR_SUBCASE_COUNT( 10, 1 );
01578             break;
01579     }
01580
01581     int* tets;
01582     int ntets;
01583     int* perm;
01584     int sgn;
01585 #ifdef MB_DEBUG_TESSELLATOR
01586     if( output_tets.empty() )
01587     {
01588         cout << "Argh! Case " << C << " Perm " << P << " has no output!" << endl;
01589     }
01590 #endif  // MB_DEBUG_TESSELLATOR
01591     while( !output_tets.empty() )
01592     {
01593         tets  = output_tets.top();
01594         ntets = *tets;
01595         tets++;
01596         perm = output_perm.top();
01597         sgn  = output_sign.top();
01598
01599         output_tets.pop();
01600         output_perm.pop();
01601         output_sign.pop();
01602
01603         int t;
01604         if( sgn > 0 )
01605         {
01606             for( t = 0; t < ntets; ++t )
01607             {
01608                 this->refine_3_simplex( max_depth, permuted_coords[perm[tets[0]]], permuted_tags[perm[tets[0]]],
01609                                         permuted_hash[perm[tets[0]]], permuted_coords[perm[tets[1]]],
01610                                         permuted_tags[perm[tets[1]]], permuted_hash[perm[tets[1]]],
01611                                         permuted_coords[perm[tets[2]]], permuted_tags[perm[tets[2]]],
01612                                         permuted_hash[perm[tets[2]]], permuted_coords[perm[tets[3]]],
01613                                         permuted_tags[perm[tets[3]]], permuted_hash[perm[tets[3]]] );
01614                 tets += 4;
01615             }
01616         }
01617         else
01618         {
01619             // we have an inverted tet... reverse the first 2 vertices
01620             // so the orientation is positive.
01621             for( t = 0; t < ntets; ++t )
01622             {
01623                 this->refine_3_simplex( max_depth, permuted_coords[perm[tets[1]]], permuted_tags[perm[tets[1]]],
01624                                         permuted_hash[perm[tets[1]]], permuted_coords[perm[tets[0]]],
01625                                         permuted_tags[perm[tets[0]]], permuted_hash[perm[tets[0]]],
01626                                         permuted_coords[perm[tets[2]]], permuted_tags[perm[tets[2]]],
01627                                         permuted_hash[perm[tets[2]]], permuted_coords[perm[tets[3]]],
01628                                         permuted_tags[perm[tets[3]]], permuted_hash[perm[tets[3]]] );
01629                 tets += 4;
01630             }
01631         }
01632     }
01633
01634     return true;
01635 }
01636
01637 /**\brief This is used by refine_entity to assign parametric coordinates to corners of each element.
01638  */
01639 void SimplexTemplateRefiner::assign_parametric_coordinates( int num_nodes, const double* src, double* tgt )
01640 {
01641     for( int i = 0; i < num_nodes; ++i, src += 3, tgt += 6 )
01642         for( int j = 0; j < 3; ++j )
01643             tgt[j] = src[j];
01644 }
01645
01646 /**\brief Returns true if || a0a1 || < || b0b1 ||
01647  *
01648  * We use this to test which triangulation has the best
01649  * aspect ratio when there are 2 to choose from.
01650  */
01651 bool SimplexTemplateRefiner::compare_Hopf_cross_string_dist( const double* a0,
01652                                                              const double* a1,
01653                                                              const double* b0,
01654                                                              const double* b1 )
01655 {
01656     double sq_mag_a = 0.;
01657     double sq_mag_b = 0.;
01658     for( int i = 0; i < 3; ++i )
01659     {
01660         double tmp;
01661         tmp = a0[i] - a1[i];
01662         sq_mag_a += tmp * tmp;
01663         tmp = b0[i] - b1[i];
01664         sq_mag_b += tmp * tmp;
01665     }
01666     return sq_mag_a < sq_mag_b;
01667 }
01668
01669 /*
01670  * The array below is indexed by the edge code for a tetrahedron.
01671  * Looking up a row with a tet's edge code will return C and P.
01672  * C is a configuration number and P is a permutation index.
01673  *
01674  * C is based on the case number from Ruprecht and
01675  * Müller's (1998) paper on adaptive tetrahedra. (The case
01676  * numbers are shown to the left of the row in the column
01677  * labeled case. The only difference is that we introduce
01678  * a case 3d which is part of case 3c in the paper.)
01679  *
01680  * P is an index into the permutations_from_index array below,
01681  * and is used to transform the current tetrahedron into
01682  * the canonical configuration associated with C.
01683  *
01684  * The 6-digit binary number to the left (which is shown in
01685  * the horribly UNconventional LSB->MSB order) is the edge
01686  * code for the row. The 6 digits correspond to the 6 edges
01687  * of the tetrahedron; a '0' implies no subdivision while
01688  * a '1' implies subdivision should occur. The ordering of
01689  * the bits is
01690  *
01691  * Edge 0-1, Edge 1-2, Edge 2-0, Edge 0-3, Edge 1-3, Edge 2-3,
01692  *
01693  * where the numbers are vertices of the tetrahedron 0-1-2-3.
01694  * Note that Tet 0-1-2-3 must be positive (i.e., the plane
01695  * specified by Triangle 0-1-2 must have a normal pointing
01696  * towards vertex 3, and Triangle 0-1-2's normal must be
01697  * calculated using the cross-product (Edge 0-1) x (Edge 0-2)).
01698  *
01699  * ===========
01700  * References:
01701  * (Ruprect and Müller, 1998) A Scheme for Edge-based Adaptive
01702  *   Tetrahedron Subdivision, Mathematical Visualization (eds.
01703  *   Hege and Polthier), pp. 61--70. Springer-Verlag. 1998.
01704  */
01705 int SimplexTemplateRefiner::template_index[64][2] = {
01706     /*      code case      C    P */
01707     /* 000000  0  0  */ { 0, 0 },
01708     /* 100000  1  1  */ { 1, 0 },
01709     /* 010000  2  1  */ { 1, 1 },
01710     /* 110000  3  2a */ { 2, 0 },
01711     /* 001000  4  1  */ { 1, 2 },
01712     /* 101000  5  2a */ { 2, 2 },
01713     /* 011000  6  2a */ { 2, 1 },
01714     /* 111000  7  3b */ { 5, 11 },
01715     /* 000100  8  1  */ { 1, 10 },
01716     /* 100100  9  2a */ { 2, 5 },
01717     /* 010100 10  2b */ { 3, 1 },
01718     /* 110100 11  3c */ { 6, 0 },
01719     /* 001100 12  2a */ { 2, 10 },
01720     /* 101100 13  3a */ { 4, 0 },
01721     /* 011100 14  3d */ { 7, 2 },
01722     /* 111100 15  4a */ { 8, 6 },
01723     /* 000010 16  1  */ { 1, 6 },
01724     /* 100010 17  2a */ { 2, 4 },
01725     /* 010010 18  2a */ { 2, 8 },
01726     /* 110010 19  3a */ { 4, 1 },
01727     /* 001010 20  2b */ { 3, 2 },
01728     /* 101010 21  3d */ { 7, 0 },
01729     /* 011010 22  3c */ { 6, 1 },
01730     /* 111010 23  4a */ { 8, 9 },
01731     /* 000110 24  2a */ { 2, 3 },
01732     /* 100110 25  3b */ { 5, 0 },
01733     /* 010110 26  3d */ { 7, 4 },
01734     /* 110110 27  4a */ { 8, 11 },
01735     /* 001110 28  3c */ { 6, 10 },
01736     /* 101110 29  4a */ { 8, 7 },
01737     /* 011110 30  4b */ { 9, 0 },
01738     /* 111110 31  5  */ { 10, 7 },
01739     /* 000001 32  1  */ { 1, 7 },
01740     /* 100001 33  2b */ { 3, 0 },
01741     /* 010001 34  2a */ { 2, 7 },
01742     /* 110001 35  3d */ { 7, 1 },
01743     /* 001001 36  2a */ { 2, 11 },
01744     /* 101001 37  3c */ { 6, 2 },
01745     /* 011001 38  3a */ { 4, 2 },
01746     /* 111001 39  4a */ { 8, 3 },
01747     /* 000101 40  2a */ { 2, 9 },
01748     /* 100101 41  3d */ { 7, 10 },
01749     /* 010101 42  3c */ { 6, 7 },
01750     /* 110101 43  4b */ { 9, 2 },
01751     /* 001101 44  3b */ { 5, 7 },
01752     /* 101101 45  4a */ { 8, 8 },
01753     /* 011101 46  4a */ { 8, 4 },
01754     /* 111101 47  5  */ { 10, 6 },
01755     /* 000011 48  2a */ { 2, 6 },
01756     /* 100011 49  3c */ { 6, 4 },
01757     /* 010011 50  3b */ { 5, 1 },
01758     /* 110011 51  4a */ { 8, 10 },
01759     /* 001011 52  3d */ { 7, 7 },
01760     /* 101011 53  4b */ { 9, 1 },
01761     /* 011011 54  4a */ { 8, 5 },
01762     /* 111011 55  5  */ { 10, 10 },
01763     /* 000111 56  3a */ { 4, 10 },
01764     /* 100111 57  4a */ { 8, 1 },
01765     /* 010111 58  4a */ { 8, 2 },
01766     /* 110111 59  5  */ { 10, 2 },
01767     /* 001111 60  4a */ { 8, 0 },
01768     /* 101111 61  5  */ { 10, 1 },
01769     /* 011111 62  5  */ { 10, 0 },
01770     /* 111111 63  6  */ { 11, 0 },
01771 };
01772
01773 /* Does this mean anything? If so, then you are either
01774  * superstitious or much more clever than I (or both?).
01775  */
01776 /* permutation index, P:  0  1  2  3  4  5  6  7  8  9 10 11 */
01777 /* number of references: 12  9  9  3  4  2  5  6  2  3  7  2 */
01778
01779 /*
01780  * The array below is a list of all the _positive_
01781  * permutations of Tetrahedron 0-1-2-3. Given a
01782  * permutation index, it returns a row of 14 values:
01783  * these are the vertex numbers of the permuted
01784  * tetrahedron. The first 4 values are the permuted
01785  * corner indices, the next 6 values are the
01786  * permuted edge midpoint indices, and the final
01787  * entries reference mid-face points inserted
01788  * to maintain a compatible tetrahedralization.
01789  *
01790  * There are 24 entries, 6 for each of the 4 faces of
01791  * the tetrahedron.
01792  */
01793 int SimplexTemplateRefiner::permutations_from_index[24][14] = {
01794     /* corners      midpoints          face points   */
01795     /* POSITIVE ARRANGEMENTS                         */
01796     { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 }, /* Face 0-1-2 */
01797     { 1, 2, 0, 3, 5, 6, 4, 8, 9, 7, 10, 12, 13, 11 },
01798     { 2, 0, 1, 3, 6, 4, 5, 9, 7, 8, 10, 13, 11, 12 },
01799
01800     { 0, 3, 1, 2, 7, 8, 4, 6, 9, 5, 11, 13, 12, 10 }, /* Face 0-3-1 */
01801     { 3, 1, 0, 2, 8, 4, 7, 9, 5, 6, 11, 12, 10, 13 },
01802     { 1, 0, 3, 2, 4, 7, 8, 5, 6, 9, 11, 10, 13, 12 },
01803
01804     { 1, 3, 2, 0, 8, 9, 5, 4, 7, 6, 12, 11, 13, 10 }, /* Face 1-3-2 */
01805     { 3, 2, 1, 0, 9, 5, 8, 7, 6, 4, 12, 13, 10, 11 },
01806     { 2, 1, 3, 0, 5, 8, 9, 6, 4, 7, 12, 10, 11, 13 },
01807
01808     { 2, 3, 0, 1, 9, 7, 6, 5, 8, 4, 13, 12, 11, 10 }, /* Face 2-3-0 */
01809     { 3, 0, 2, 1, 7, 6, 9, 8, 4, 5, 13, 11, 10, 12 },
01810     { 0, 2, 3, 1, 6, 9, 7, 4, 5, 8, 13, 10, 12, 11 },
01811
01812     /* NEGATIVE ARRANGEMENTS                         */
01813     { 0, 2, 1, 3, 6, 5, 4, 7, 9, 8, 10, 13, 12, 11 }, /* Face 0-1-2 */
01814     { 2, 1, 0, 3, 5, 4, 6, 9, 8, 7, 10, 12, 11, 13 },
01815     { 1, 0, 2, 3, 4, 6, 5, 8, 7, 9, 10, 11, 13, 12 },
01816
01817     { 0, 1, 3, 2, 4, 8, 7, 6, 5, 9, 11, 10, 12, 13 }, /* Face 0-3-1 */
01818     { 1, 3, 0, 2, 8, 7, 4, 5, 9, 6, 11, 12, 13, 10 },
01819     { 3, 0, 1, 2, 7, 4, 8, 9, 6, 5, 11, 13, 10, 12 },
01820
01821     { 1, 2, 3, 0, 5, 9, 8, 4, 6, 7, 12, 10, 13, 11 }, /* Face 1-3-2 */
01822     { 2, 3, 1, 0, 9, 8, 5, 6, 7, 4, 12, 13, 11, 10 },
01823     { 3, 1, 2, 0, 8, 5, 9, 7, 4, 6, 12, 11, 10, 13 },
01824
01825     { 2, 0, 3, 1, 6, 7, 9, 5, 4, 8, 13, 10, 11, 12 }, /* Face 2-3-0 */
01826     { 0, 3, 2, 1, 7, 9, 6, 4, 8, 5, 13, 11, 12, 10 },
01827     { 3, 2, 0, 1, 9, 6, 7, 8, 5, 4, 13, 12, 10, 11 } };
01828
01829 /*
01830  * Below is a list of output tetrahedra. The array is
01831  * generated by TessellatorGenerator.py
01832  * which also generates the code that references it.
01833  * Each set of tetrahedra begins with a single integer
01834  * that is the number of tetrahedra for that particular
01835  * case. It is followed by 5 integers for each output
01836  * tetrahedron; the first four numbers on each row are
01837  * indices of the output tetrahedron. The final number
01838  * is a bit vector specifying which edges of the
01839  * tetrahedron are internal to the parent tetrahedron
01840  * being decomposed.
01841  *
01842  * Multiple lists of output tetrahedra may be
01843  * combined to create the tessellation of a single
01844  * input tetrahedron.
01845  */
01846
01847 int SimplexTemplateRefiner::templates[] = {
01848     // case 1_0
01849     2,
01850     0,
01851     4,
01852     2,
01853     3,
01854     4,
01855     1,
01856     2,
01857     3,
01858
01859     // case 2a_0
01860     1,
01861     3,
01862     4,
01863     5,
01864     1,
01865
01866     // case 2a, 0>1
01867     2,
01868     0,
01869     4,
01870     2,
01871     3,
01872     4,
01873     5,
01874     2,
01875     3,
01876
01877     // case 2a, 0=1
01878     4,
01879     10,
01880     3,
01881     0,
01882     4,
01883     10,
01884     3,
01885     4,
01886     5,
01887     10,
01888     3,
01889     5,
01890     2,
01891     10,
01892     3,
01893     2,
01894     0,
01895
01896     // case 2b_0
01897     4,
01898     0,
01899     4,
01900     9,
01901     3,
01902     4,
01903     1,
01904     9,
01905     3,
01906     0,
01907     4,
01908     2,
01909     9,
01910     4,
01911     1,
01912     2,
01913     9,
01914
01915     // case 3a_0
01916     1,
01917     4,
01918     7,
01919     6,
01920     0,
01921
01922     // case 3a, 0>2>3<0
01923     3,
01924     1,
01925     3,
01926     2,
01927     4,
01928     4,
01929     6,
01930     3,
01931     2,
01932     4,
01933     6,
01934     7,
01935     3,
01936
01937     // case 3a, 0=2>3<0
01938     5,
01939     4,
01940     6,
01941     7,
01942     3,
01943     10,
01944     1,
01945     2,
01946     3,
01947     10,
01948     2,
01949     6,
01950     3,
01951     10,
01952     6,
01953     4,
01954     3,
01955     10,
01956     4,
01957     1,
01958     3,
01959
01960     // case 3a, 3>0=2<3
01961     5,
01962     1,
01963     3,
01964     2,
01965     7,
01966     10,
01967     1,
01968     2,
01969     7,
01970     10,
01971     2,
01972     6,
01973     7,
01974     10,
01975     6,
01976     4,
01977     7,
01978     10,
01979     4,
01980     1,
01981     7,
01982
01983     // case 3a, 0=2=3=0
01984     11,
01985     2,
01986     6,
01987     10,
01988     13,
01989     3,
01990     7,
01991     13,
01992     11,
01993     4,
01994     1,
01995     10,
01996     11,
01997     11,
01998     6,
01999     10,
02000     4,
02001     11,
02002     6,
02003     13,
02004     10,
02005     11,
02006     6,
02007     7,
02008     13,
02009     11,
02010     6,
02011     4,
02012     7,
02013     2,
02014     10,
02015     11,
02016     13,
02017     1,
02018     10,
02019     11,
02020     2,
02021     2,
02022     11,
02023     3,
02024     13,
02025     3,
02026     2,
02027     1,
02028     11,
02029
02030     // case 3b_0
02031     4,
02032     0,
02033     7,
02034     4,
02035     2,
02036     4,
02037     7,
02038     8,
02039     2,
02040     4,
02041     8,
02042     1,
02043     2,
02044     7,
02045     3,
02046     8,
02047     2,
02048
02049     // case 3c, 0>1,0>3
02050     5,
02051     4,
02052     2,
02053     7,
02054     5,
02055     4,
02056     2,
02057     0,
02058     7,
02059     4,
02060     3,
02061     1,
02062     5,
02063     4,
02064     3,
02065     5,
02066     7,
02067     3,
02068     5,
02069     7,
02070     2,
02071
02072     // case 3c, 1>0,3>0
02073     5,
02074     0,
02075     5,
02076     2,
02077     7,
02078     0,
02079     5,
02080     7,
02081     4,
02082     7,
02083     1,
02084     4,
02085     5,
02086     7,
02087     1,
02088     5,
02089     3,
02090     3,
02091     5,
02092     7,
02093     2,
02094
02095     // case 3c, 0>1,3>0
02096     5,
02097     4,
02098     2,
02099     7,
02100     5,
02101     4,
02102     2,
02103     0,
02104     7,
02105     7,
02106     1,
02107     4,
02108     5,
02109     7,
02110     1,
02111     5,
02112     3,
02113     3,
02114     5,
02115     7,
02116     2,
02117
02118     // case 3c, 1>0,0>3
02119     5,
02120     0,
02121     5,
02122     2,
02123     7,
02124     0,
02125     5,
02126     7,
02127     4,
02128     4,
02129     3,
02130     1,
02131     5,
02132     4,
02133     3,
02134     5,
02135     7,
02136     3,
02137     5,
02138     7,
02139     2,
02140
02141     // case 3c, 0=1,0>3
02142     7,
02143     4,
02144     1,
02145     5,
02146     3,
02147     10,
02148     0,
02149     4,
02150     7,
02151     10,
02152     2,
02153     0,
02154     7,
02155     10,
02156     7,
02157     4,
02158     3,
02159     10,
02160     2,
02161     7,
02162     3,
02163     10,
02164     5,
02165     2,
02166     3,
02167     10,
02168     4,
02169     5,
02170     3,
02171
02172     // case 3c, 3>0,0=1
02173     7,
02174     7,
02175     1,
02176     5,
02177     3,
02178     7,
02179     5,
02180     2,
02181     3,
02182     10,
02183     0,
02184     4,
02185     7,
02186     10,
02187     2,
02188     0,
02189     7,
02190     10,
02191     5,
02192     2,
02193     7,
02194     10,
02195     4,
02196     5,
02197     7,
02198     1,
02199     5,
02200     4,
02201     7,
02202
02203     // case 3c, 0=1,0=3
02204     10,
02205     4,
02206     1,
02207     5,
02208     11,
02209     11,
02210     1,
02211     5,
02212     3,
02213     10,
02214     0,
02215     4,
02216     7,
02217     10,
02218     2,
02219     0,
02220     7,
02221     10,
02222     5,
02223     2,
02224     3,
02225     10,
02226     2,
02227     7,
02228     3,
02229     10,
02230     7,
02231     4,
02232     11,
02233     10,
02234     7,
02235     11,
02236     3,
02237     10,
02238     4,
02239     5,
02240     11,
02241     10,
02242     11,
02243     5,
02244     3,
02245
02246     // case 3d, 0>4,0>2
02247     5,
02248     4,
02249     3,
02250     6,
02251     0,
02252     4,
02253     3,
02254     8,
02255     6,
02256     4,
02257     2,
02258     8,
02259     1,
02260     4,
02261     2,
02262     6,
02263     8,
02264     2,
02265     3,
02266     6,
02267     8,
02268
02269     // case 3d, 4>0,2>0
02270     5,
02271     8,
02272     0,
02273     6,
02274     4,
02275     8,
02276     0,
02277     3,
02278     6,
02279     6,
02280     1,
02281     8,
02282     4,
02283     6,
02284     1,
02285     2,
02286     8,
02287     2,
02288     3,
02289     6,
02290     8,
02291
02292     // case 3d, 0>4,2>0
02293     5,
02294     4,
02295     3,
02296     6,
02297     0,
02298     4,
02299     3,
02300     8,
02301     6,
02302     6,
02303     1,
02304     8,
02305     4,
02306     6,
02307     1,
02308     2,
02309     8,
02310     2,
02311     3,
02312     6,
02313     8,
02314
02315     // case 3d, 4>0,0>2
02316     5,
02317     8,
02318     0,
02319     6,
02320     4,
02321     8,
02322     0,
02323     3,
02324     6,
02325     4,
02326     2,
02327     8,
02328     1,
02329     4,
02330     2,
02331     6,
02332     8,
02333     2,
02334     3,
02335     6,
02336     8,
02337
02338     // case 3d, 0=4,0>2
02339     7,
02340     4,
02341     1,
02342     2,
02343     8,
02344     11,
02345     4,
02346     0,
02347     6,
02348     11,
02349     0,
02350     3,
02351     6,
02352     11,
02353     2,
02354     4,
02355     6,
02356     11,
02357     3,
02358     2,
02359     6,
02360     11,
02361     3,
02362     8,
02363     2,
02364     11,
02365     8,
02366     4,
02367     2,
02368
02369     // case 3d, 2>0,0=4
02370     7,
02371     6,
02372     2,
02373     8,
02374     1,
02375     6,
02376     8,
02377     2,
02378     3,
02379     11,
02380     4,
02381     0,
02382     6,
02383     11,
02384     0,
02385     3,
02386     6,
02387     8,
02388     11,
02389     3,
02390     6,
02391     8,
02392     4,
02393     11,
02394     6,
02395     1,
02396     6,
02397     4,
02398     8,
02399
02400     // case 3d, 0=4,0=2
02401     10,
02402     4,
02403     1,
02404     10,
02405     8,
02406     10,
02407     2,
02408     8,
02409     1,
02410     11,
02411     4,
02412     0,
02413     6,
02414     11,
02415     0,
02416     3,
02417     6,
02418     11,
02419     3,
02420     8,
02421     2,
02422     11,
02423     3,
02424     2,
02425     6,
02426     11,
02427     10,
02428     4,
02429     6,
02430     11,
02431     10,
02432     6,
02433     2,
02434     8,
02435     4,
02436     11,
02437     10,
02438     11,
02439     10,
02440     2,
02441     8,
02442
02443     // case 4a_0
02444     2,
02445     7,
02446     8,
02447     9,
02448     3,
02449     7,
02450     9,
02451     8,
02452     6,
02453
02454     // case 4a, 5>4>3
02455     4,
02456     8,
02457     0,
02458     6,
02459     1,
02460     8,
02461     0,
02462     7,
02463     6,
02464     9,
02465     1,
02466     6,
02467     2,
02468     9,
02469     1,
02470     8,
02471     6,
02472
02473     // case 4a, 3<4>5
02474     4,
02475     8,
02476     0,
02477     6,
02478     1,
02479     8,
02480     0,
02481     7,
02482     6,
02483     8,
02484     2,
02485     6,
02486     9,
02487     8,
02488     2,
02489     1,
02490     6,
02491
02492     // case 4a, 3>4<5
02493     4,
02494     6,
02495     9,
02496     8,
02497     1,
02498     6,
02499     9,
02500     1,
02501     2,
02502     6,
02503     7,
02504     0,
02505     1,
02506     6,
02507     7,
02508     1,
02509     8,
02510
02511     // case 4a, 3=4>5
02512     6,
02513     6,
02514     7,
02515     0,
02516     11,
02517     6,
02518     0,
02519     1,
02520     11,
02521     6,
02522     7,
02523     11,
02524     8,
02525     6,
02526     11,
02527     1,
02528     8,
02529     1,
02530     2,
02531     6,
02532     8,
02533     2,
02534     6,
02535     8,
02536     9,
02537
02538     // case 4a, 5>4,3=4
02539     6,
02540     6,
02541     7,
02542     0,
02543     11,
02544     6,
02545     0,
02546     1,
02547     11,
02548     6,
02549     7,
02550     11,
02551     8,
02552     6,
02553     11,
02554     1,
02555     8,
02556     1,
02557     2,
02558     6,
02559     9,
02560     1,
02561     6,
02562     8,
02563     9,
02564
02565     // case 4a, 3=4=5
02566     8,
02567     6,
02568     7,
02569     0,
02570     11,
02571     6,
02572     0,
02573     1,
02574     11,
02575     6,
02576     7,
02577     11,
02578     8,
02579     6,
02580     11,
02581     1,
02582     8,
02583     6,
02584     1,
02585     2,
02586     12,
02587     6,
02588     2,
02589     9,
02590     12,
02591     6,
02592     9,
02593     8,
02594     12,
02595     6,
02596     8,
02597     1,
02598     12,
02599
02600     // case 4b, 2>1,3>2,4>3,4>1
02601     6,
02602     6,
02603     8,
02604     1,
02605     5,
02606     6,
02607     8,
02608     0,
02609     1,
02610     6,
02611     8,
02612     7,
02613     0,
02614     6,
02615     8,
02616     2,
02617     7,
02618     7,
02619     8,
02620     2,
02621     3,
02622     6,
02623     8,
02624     5,
02625     2,
02626
02627     // case 4b, 2>1,3>2,3>4,4>1
02628     6,
02629     6,
02630     8,
02631     1,
02632     5,
02633     6,
02634     8,
02635     7,
02636     1,
02637     6,
02638     7,
02639     0,
02640     1,
02641     8,
02642     7,
02643     3,
02644     2,
02645     6,
02646     8,
02647     5,
02648     2,
02649     6,
02650     8,
02651     2,
02652     7,
02653
02654     // case 4b, 2>1,3>2,3>4,4>1, a
02655     6,
02656     7,
02657     8,
02658     1,
02659     5,
02660     6,
02661     5,
02662     7,
02663     1,
02664     6,
02665     7,
02666     0,
02667     1,
02668     8,
02669     7,
02670     3,
02671     2,
02672     7,
02673     8,
02674     5,
02675     2,
02676     6,
02677     5,
02678     2,
02679     7,
02680
02681     // case 4b, 2>1,2>3,4>3,4>1
02682     6,
02683     6,
02684     8,
02685     5,
02686     2,
02687     6,
02688     8,
02689     2,
02690     3,
02691     6,
02692     8,
02693     3,
02694     7,
02695     6,
02696     8,
02697     7,
02698     0,
02699     6,
02700     8,
02701     0,
02702     1,
02703     6,
02704     8,
02705     1,
02706     5,
02707
02708     // case 4b, 1=2,3>2,3>4,4>1
02709     9,
02710     10,
02711     6,
02712     0,
02713     7,
02714     10,
02715     1,
02716     5,
02717     8,
02718     10,
02719     0,
02720     1,
02721     7,
02722     10,
02723     7,
02724     1,
02725     8,
02726     6,
02727     7,
02728     10,
02729     8,
02730     6,
02731     10,
02732     5,
02733     8,
02734     6,
02735     2,
02736     7,
02737     8,
02738     6,
02739     5,
02740     2,
02741     8,
02742     7,
02743     8,
02744     2,
02745     3,
02746
02747     // case 4b, 1=2,2>3,4>3,1>4
02748     9,
02749     10,
02750     6,
02751     0,
02752     7,
02753     10,
02754     1,
02755     5,
02756     8,
02757     10,
02758     0,
02759     1,
02760     8,
02761     10,
02762     7,
02763     0,
02764     8,
02765     6,
02766     7,
02767     10,
02768     8,
02769     6,
02770     10,
02771     5,
02772     8,
02773     6,
02774     3,
02775     7,
02776     8,
02777     6,
02778     5,
02779     3,
02780     8,
02781     6,
02782     5,
02783     2,
02784     3,
02785
02786     // case 4b, 1=2,2>3,4>3,4>1
02787     9,
02788     10,
02789     6,
02790     0,
02791     7,
02792     10,
02793     1,
02794     5,
02795     8,
02796     10,
02797     0,
02798     1,
02799     8,
02800     10,
02801     7,
02802     0,
02803     8,
02804     6,
02805     7,
02806     10,
02807     8,
02808     6,
02809     10,
02810     5,
02811     8,
02812     6,
02813     3,
02814     7,
02815     8,
02816     6,
02817     5,
02818     2,
02819     8,
02820     6,
02821     2,
02822     3,
02823     8,
02824
02825     // case 4b, 1=2,3>2,3=4,4>1
02826     11,
02827     10,
02828     6,
02829     0,
02830     7,
02831     10,
02832     1,
02833     5,
02834     8,
02835     10,
02836     0,
02837     1,
02838     11,
02839     10,
02840     11,
02841     1,
02842     8,
02843     10,
02844     0,
02845     11,
02846     7,
02847     10,
02848     7,
02849     11,
02850     8,
02851     6,
02852     7,
02853     10,
02854     8,
02855     6,
02856     10,
02857     5,
02858     8,
02859     6,
02860     2,
02861     7,
02862     8,
02863     6,
02864     5,
02865     2,
02866     8,
02867     7,
02868     8,
02869     2,
02870     3,
02871
02872     // case 4b, 4>1=2=3,4>3
02873     12,
02874     10,
02875     6,
02876     0,
02877     7,
02878     10,
02879     1,
02880     5,
02881     8,
02882     10,
02883     0,
02884     1,
02885     8,
02886     10,
02887     7,
02888     0,
02889     8,
02890     13,
02891     6,
02892     2,
02893     5,
02894     13,
02895     3,
02896     7,
02897     8,
02898     13,
02899     2,
02900     3,
02901     8,
02902     13,
02903     2,
02904     8,
02905     5,
02906     6,
02907     7,
02908     10,
02909     8,
02910     6,
02911     10,
02912     5,
02913     8,
02914     6,
02915     13,
02916     7,
02917     8,
02918     6,
02919     5,
02920     13,
02921     8,
02922
02923     // case 4b, 1=2=3>4,1>4
02924     12,
02925     10,
02926     6,
02927     0,
02928     7,
02929     10,
02930     1,
02931     5,
02932     8,
02933     10,
02934     0,
02935     1,
02936     7,
02937     10,
02938     7,
02939     1,
02940     8,
02941     13,
02942     6,
02943     2,
02944     5,
02945     13,
02946     3,
02947     7,
02948     8,
02949     13,
02950     2,
02951     3,
02952     5,
02953     13,
02954     3,
02955     8,
02956     5,
02957     6,
02958     7,
02959     10,
02960     8,
02961     6,
02962     10,
02963     5,
02964     8,
02965     6,
02966     13,
02967     7,
02968     8,
02969     6,
02970     5,
02971     13,
02972     8,
02973
02974     // case 4b, 1=2=3=4=1
02975     16,
02976     10,
02977     6,
02978     0,
02979     7,
02980     10,
02981     1,
02982     5,
02983     8,
02984     10,
02985     0,
02986     1,
02987     11,
02988     10,
02989     11,
02990     1,
02991     8,
02992     10,
02993     0,
02994     11,
02995     7,
02996     10,
02997     7,
02998     11,
02999     8,
03000     13,
03001     6,
03002     2,
03003     5,
03004     13,
03005     3,
03006     7,
03007     8,
03008     13,
03009     2,
03010     3,
03011     12,
03012     13,
03013     2,
03014     12,
03015     5,
03016     13,
03017     12,
03018     3,
03019     8,
03020     13,
03021     12,
03022     5,
03023     8,
03024     6,
03025     7,
03026     10,
03027     8,
03028     6,
03029     10,
03030     5,
03031     8,
03032     6,
03033     5,
03034     13,
03035     8,
03036     6,
03037     13,
03038     7,
03039     8,
03040
03041     // case 5_0
03042     2,
03043     7,
03044     8,
03045     9,
03046     3,
03047     6,
03048     5,
03049     2,
03050     9,
03051
03052     // case 5, 1>2,3>4
03053     5,
03054     5,
03055     7,
03056     1,
03057     8,
03058     5,
03059     7,
03060     0,
03061     1,
03062     5,
03063     7,
03064     6,
03065     0,
03066     5,
03067     7,
03068     9,
03069     6,
03070     5,
03071     7,
03072     8,
03073     9,
03074
03075     // case 5, 1>2,4>3
03076     5,
03077     0,
03078     5,
03079     6,
03080     7,
03081     0,
03082     5,
03083     7,
03084     8,
03085     0,
03086     5,
03087     8,
03088     1,
03089     5,
03090     7,
03091     9,
03092     6,
03093     5,
03094     7,
03095     8,
03096     9,
03097
03098     // case 5, 1>2,4>3, a
03099     5,
03100     0,
03101     5,
03102     6,
03103     8,
03104     0,
03105     6,
03106     7,
03107     8,
03108     0,
03109     5,
03110     8,
03111     1,
03112     5,
03113     8,
03114     9,
03115     6,
03116     6,
03117     7,
03118     8,
03119     9,
03120
03121     // case 5, 1=2,3>4
03122     8,
03123     10,
03124     6,
03125     0,
03126     7,
03127     10,
03128     1,
03129     5,
03130     8,
03131     10,
03132     0,
03133     1,
03134     7,
03135     10,
03136     7,
03137     1,
03138     8,
03139     10,
03140     8,
03141     5,
03142     9,
03143     10,
03144     6,
03145     7,
03146     9,
03147     10,
03148     7,
03149     8,
03150     9,
03151     10,
03152     5,
03153     6,
03154     9,
03155
03156     // case 5, 1=2,3>4, a
03157     8,
03158     10,
03159     6,
03160     0,
03161     7,
03162     10,
03163     1,
03164     5,
03165     8,
03166     10,
03167     0,
03168     1,
03169     7,
03170     10,
03171     7,
03172     1,
03173     8,
03174     7,
03175     8,
03176     5,
03177     9,
03178     10,
03179     6,
03180     7,
03181     5,
03182     10,
03183     7,
03184     8,
03185     5,
03186     5,
03187     9,
03188     6,
03189     7,
03190
03191     // case 5, 1=2,3>4, b
03192     8,
03193     10,
03194     6,
03195     0,
03196     7,
03197     10,
03198     1,
03199     5,
03200     8,
03201     10,
03202     0,
03203     1,
03204     7,
03205     10,
03206     7,
03207     1,
03208     8,
03209     6,
03210     8,
03211     5,
03212     9,
03213     10,
03214     6,
03215     7,
03216     8,
03217     10,
03218     6,
03219     8,
03220     5,
03221     8,
03222     9,
03223     6,
03224     7,
03225
03226     // case 5, 1=2,3=4
03227     10,
03228     10,
03229     6,
03230     0,
03231     7,
03232     10,
03233     1,
03234     5,
03235     8,
03236     10,
03237     0,
03238     1,
03239     11,
03240     10,
03241     11,
03242     1,
03243     8,
03244     10,
03245     0,
03246     11,
03247     7,
03248     10,
03249     7,
03250     11,
03251     8,
03252     10,
03253     8,
03254     5,
03255     9,
03256     10,
03257     6,
03258     7,
03259     9,
03260     10,
03261     7,
03262     8,
03263     9,
03264     10,
03265     5,
03266     6,
03267     9,
03268
03269     // case 6_0
03270     4,
03271     7,
03272     8,
03273     9,
03274     3,
03275     6,
03276     5,
03277     2,
03278     9,
03279     4,
03280     1,
03281     5,
03282     8,
03283     0,
03284     4,
03285     6,
03286     7,
03287
03288     // case 6_1
03289     4,
03290     6,
03291     4,
03292     5,
03293     8,
03294     6,
03295     5,
03296     9,
03297     8,
03298     6,
03299     9,
03300     7,
03301     8,
03302     6,
03303     7,
03304     4,
03305     8,
03306
03307     // case 6_1, a
03308     4,
03309     5,
03310     8,
03311     9,
03312     7,
03313     5,
03314     9,
03315     6,
03316     7,
03317     5,
03318     6,
03319     4,
03320     7,
03321     5,
03322     4,
03323     8,
03324     7,
03325
03326     // case 6_1, b
03327     4,
03328     4,
03329     5,
03330     6,
03331     9,
03332     4,
03333     6,
03334     7,
03335     9,
03336     4,
03337     7,
03338     8,
03339     9,
03340     4,
03341     8,
03342     5,
03343     9,
03344
03345 };
03346
03347 }  // namespace moab
