MOAB: Mesh Oriented datABase
(version 5.1.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /********************************************** 00017 * Filename : SparseTagSuperCollection.hpp 00018 * 00019 * Purpose : To store any size data with 00020 * any entity handle 00021 * 00022 * Creator : Clinton Stimpson 00023 * 00024 * Date : 3 April 2002 00025 * 00026 * ********************************************/ 00027 00028 #ifndef SPARSE_TAG_SUPER_COLLECTION_HPP 00029 #define SPARSE_TAG_SUPER_COLLECTION_HPP 00030 00031 #ifndef IS_BUILDING_MB 00032 #error "SparseTagSuperCollection.hpp isn't supposed to be included into an application" 00033 #endif 00034 00035 #ifdef WIN32 00036 #pragma warning( disable : 4786 ) 00037 #endif 00038 00039 #include <map> 00040 #include <vector> 00041 00042 #include "moab/Types.hpp" 00043 #include "Internals.hpp" 00044 #include "moab/Range.hpp" 00045 #include "TagInfo.hpp" 00046 00047 #define get_collection( A ) ( ( A ) < mDataTags.size() ? mDataTags[( A )] : 0 ) 00048 00049 namespace moab 00050 { 00051 00052 class SparseTagCollection; 00053 00054 //! a collection of SparseTagCollections 00055 class SparseTagSuperCollection 00056 { 00057 public: 00058 //! constructor 00059 SparseTagSuperCollection() {} 00060 00061 //! destructor 00062 virtual ~SparseTagSuperCollection(); 00063 00064 void reset_data(); 00065 00066 //! allocate new tag id 00067 ErrorCode reserve_tag_id( int data_size, TagId tag_id ); 00068 00069 //! releases an TagId 00070 ErrorCode release_tag_id( TagId tag_id ); 00071 00072 //! size of data tag 00073 int tag_size( const TagId tag_id ) const; 00074 00075 /** Set fixed-length tag values. 00076 *\NOTE Will fail for variable-length tag data. 00077 */ 00078 ErrorCode set_data( TagId tag_handle, const EntityHandle* handles, int num_handles, const void* data ); 00079 00080 /** Set tag values for array of entity handles 00081 *\param tag_id The tag. 00082 *\param handles Array of entity handles. 00083 *\param num_handles Length of 'handles' array. 00084 *\param values Array of pointers to tag values, one pointer for each handle 00085 *\param lengths Length of each tag value. Ignored for fixed-length tags. 00086 *\param one_value If true, tag on all entities is set to the (same) 00087 * first passed tag value. 00088 */ 00089 ErrorCode set_data( TagId tag_handle, const EntityHandle* handles, int num_handles, 00090 void const* const* data_pointers, const int* lengths = 0, bool one_value = false ); 00091 00092 /** Set fixed-length tag value for an Range of entities 00093 *\NOTE Will fail for variable-length tag data 00094 */ 00095 ErrorCode set_data( TagId tag_handle, const Range& handles, const void* data ); 00096 00097 /** Set tag data for an Range of entities. 00098 * 00099 *\param tag_id The tag 00100 *\param handles The entities 00101 *\param values An array of pointers, one per entity, pointing to the 00102 * tag value for the corresponding entity. 00103 *\param lengths An array of integers, one per entity, indicating the 00104 * length of the tag value for each entity. Ingored 00105 * for fixed-length tags. 00106 *\param one_value If true, tag on all entities is set to the (same) 00107 * first passed tag value. 00108 */ 00109 ErrorCode set_data( TagId tag_handle, const Range& handles, void const* const* data_pointers, 00110 const int* lengths = 0, bool one_value = false ); 00111 00112 /**\brief Access tag data via direct pointer into contiguous blocks 00113 * 00114 * Iteratively obtain direct access to contiguous blocks of tag 00115 * storage. This function cannot be used with bit tags because 00116 * of the compressed bit storage. This function cannot be used 00117 * with variable length tags because it does not provide a mechanism 00118 * to determine the length of the value for each entity. This 00119 * function may be used with sparse tags, but if it is used, it 00120 * will return data for a single entity at a time. 00121 * 00122 *\param tag_handle The handle of the tag for which to access data 00123 *\param iter As input, the first entity for which to return 00124 * data. As output, one past the last entity for 00125 * which data was returned. 00126 *\param end One past the last entity for which data is desired 00127 *\param data_ptr Output: pointer to tag storage. 00128 * 00129 *\Note If this function is called for entities for which no tag value 00130 * has been set, but for which a default value exists, it will 00131 * force the allocation of explicit storage for each such entity 00132 * even though MOAB would normally not explicitly store tag values 00133 * for such entities. 00134 */ 00135 ErrorCode tag_iterate( TagId tag_handle, Range::iterator& iter, const Range::iterator& end, void*& data_ptr, 00136 const void* default_value ); 00137 00138 /** Get fixed-length tag values for array of entities 00139 *\NOTE Will fail with MB_VARIABLE_DATA_LENGTH if called 00140 * for variable-length tag. 00141 */ 00142 ErrorCode get_data( TagId tag_handle, const EntityHandle* handles, int num_handles, void* data, 00143 const void* default_value ) const; 00144 00145 /** Get pointers to tag data for array of entities 00146 *\param tag_id The Tag. 00147 *\param handles Array of entity handles. 00148 *\param num_handles Length of 'handles' array. 00149 *\param tag_ptrs Pointers to tag values, one pointer for each input handle. 00150 *\param lengths Length of each tag value. Ignored for fixed-length tags. 00151 *\param default_value Pointer to default value for tag, or NULL if none. 00152 *\param default_value_length Length of default tag value. Ingored for 00153 * fixed-length tags. 00154 */ 00155 ErrorCode get_data( TagId tag_handle, const EntityHandle* handles, int num_handles, const void** data, int* lengths, 00156 const void* default_value, int default_value_length ) const; 00157 00158 /** Get fixed-length tag value for an Range of entities 00159 *\NOTE Will fail with MB_VARIABLE_DATA_LENGTH if called 00160 * for variable-length tag. 00161 */ 00162 ErrorCode get_data( TagId tag_handle, const Range& handles, void* data, const void* default_value ) const; 00163 00164 /** Get pointers to tag data for an Range of entities. 00165 * 00166 *\param tag_id The tag. 00167 *\param handles The entities. 00168 *\param values Array of pointers of type 'const void*'. Array 00169 * must be the same length as the size of 'entities'. 00170 * The array will be populated with pointers to the 00171 * internal storage of the tag data for each entity. 00172 *\param lengths Array of integers. Will be populated with the 00173 * length of the tag value for each entity. Argument 00174 * is optional for fixed-length tags. 00175 *\param default_value The default value for the tag. 00176 *\param default_value_length The length of the default tag value. 00177 */ 00178 ErrorCode get_data( TagId tag_handle, const Range& handles, const void** data, int* lengths, 00179 const void* default_value, int default_value_length ) const; 00180 00181 //! removes data 00182 ErrorCode remove_data( const TagId tag_handle, const EntityHandle entity_handle ); 00183 00184 //! gets all entity handles that match a type and tag 00185 ErrorCode get_entities( const TagId tag_handle, Range& entities ); 00186 00187 //! gets all entity handles that match a tag 00188 ErrorCode get_entities( const TagId tag_handle, const EntityType type, Range& entities ); 00189 00190 //! gets all entity handles that match a tag 00191 ErrorCode get_entities( const Range& range, const TagId tag_handle, const EntityType type, Range& entities ); 00192 00193 //! gets all tags on a given entity handle 00194 ErrorCode get_tags( const EntityHandle entity, std::vector< Tag >& all_tags ); 00195 00196 //! gets all entity handles that match a tag 00197 ErrorCode get_entities_with_tag_value( const TagId tag_handle, const TagInfo& tag_info, const EntityType type, 00198 Range& entities, const void* tag_value, int value_size ); 00199 00200 //! gets all entity handles that match a tag 00201 ErrorCode get_entities_with_tag_value( const Range& range, const TagId tag_handle, const TagInfo& tag_info, 00202 const EntityType type, Range& entities, const void* tag_value, 00203 int value_size ); 00204 00205 //! gets the number of entities that match a tag 00206 ErrorCode get_number_entities( const TagId tag_handle, const EntityType type, int& num_ent ); 00207 00208 //! gets the number of entities that match a tag 00209 ErrorCode get_number_entities( const Range& range, const TagId tag_handle, const EntityType type, int& num_ent ); 00210 00211 ErrorCode get_memory_use( TagId tag_id, unsigned long& total, unsigned long& per_entity ); 00212 00213 private: 00214 std::vector< SparseTagCollection* > mDataTags; 00215 }; 00216 00217 } // namespace moab 00218 00219 #endif // SPARSE_TAG_SUPER_COLLECTION_HPP
