SweptElementData.cpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 #include "SweptElementData.hpp"
00017 #include "SweptVertexData.hpp"
00018 #include "moab/Interface.hpp"
00019 #include "moab/ReadUtilIface.hpp"
00020 #include "moab/CN.hpp"
00021 #include "Internals.hpp"
00022 #include <cassert>
00023
00024 namespace moab
00025 {
00026
00027 EntityID SweptElementData::calc_num_entities( EntityHandle start_handle, int irange, int jrange, int krange )
00028 {
00029     size_t result = 1;
00030     auto dim      = CN::Dimension( TYPE_FROM_HANDLE( start_handle ) );
00031     switch( dim )
00032     {
00033         case 3:
00034             result *= krange;
00035             // fall through
00036         case 2:
00037             result *= jrange;
00038             // fall through
00039         case 1:
00040             result *= irange;
00041             break;
00042         default:
00043             result = 0;
00044             assert( false );
00045             break;
00046     }
00047     return result;
00048 }
00049
00050 SweptElementData::SweptElementData( EntityHandle shandle,
00051                                     const int imin,
00052                                     const int jmin,
00053                                     const int kmin,
00054                                     const int imax,
00055                                     const int jmax,
00056                                     const int kmax,
00057                                     const int* /*Cq*/ )
00058     : SequenceData( 0, shandle, shandle + calc_num_entities( shandle, imax - imin, jmax - jmin, kmax - kmin ) - 1 )
00059 {
00060     // need to have meaningful parameters
00061     assert( imax >= imin && jmax >= jmin && kmax >= kmin );
00062
00063     elementParams[0] = HomCoord( imin, jmin, kmin );
00064     elementParams[1] = HomCoord( imax, jmax, kmax );
00065     elementParams[2] = HomCoord( 1, 1, 1 );
00066
00067     // assign and compute parameter stuff
00068     dIJK[0]   = elementParams[1][0] - elementParams[0][0] + 1;
00069     dIJK[1]   = elementParams[1][1] - elementParams[0][1] + 1;
00070     dIJK[2]   = elementParams[1][2] - elementParams[0][2] + 1;
00071     dIJKm1[0] = dIJK[0] - 1;
00072     dIJKm1[1] = dIJK[1] - 1;
00073     dIJKm1[2] = dIJK[2] - 1;
00074 }
00075
00076 SweptElementData::~SweptElementData() {}
00077
00078 bool SweptElementData::boundary_complete() const
00079 {
00080     // test the bounding vertex sequences to see if they fully define the
00081     // vertex parameter space for this rectangular block of elements
00082
00083     int p;
00084     std::vector< VertexDataRef > minlist, maxlist;
00085
00086     // pseudo code:
00087     // for each vertex sequence v:
00088     for( std::vector< VertexDataRef >::const_iterator vseq = vertexSeqRefs.begin(); vseq != vertexSeqRefs.end();
00089          ++vseq )
00090     {
00091         //   test min corner mincorner:
00092         bool mincorner = true;
00093         //   for each p = (i-1,j,k), (i,j-1,k), (i,j,k-1):
00094         for( p = 0; p < 3; p++ )
00095         {
00096
00097             //     for each vsequence v' != v:
00098             for( std::vector< VertexDataRef >::const_iterator othervseq = vertexSeqRefs.begin();
00099                  othervseq != vertexSeqRefs.end(); ++othervseq )
00100             {
00101                 if( othervseq == vseq ) continue;
00102                 //       if v.min-p contained in v'
00103                 if( ( *othervseq ).contains( ( *vseq ).minmax[0] - HomCoord::unitv[p] ) )
00104                 {
00105                     //         mincorner = false
00106                     mincorner = false;
00107                     break;
00108                 }
00109             }
00110             if( !mincorner ) break;
00111         }
00112
00113         bool maxcorner = true;
00114         //   for each p = (i-1,j,k), (i,j-1,k), (i,j,k-1):
00115         for( p = 0; p < 3; p++ )
00116         {
00117
00118             //     for each vsequence v' != v:
00119             for( std::vector< VertexDataRef >::const_iterator othervseq = vertexSeqRefs.begin();
00120                  othervseq != vertexSeqRefs.end(); ++othervseq )
00121             {
00122                 if( othervseq == vseq ) continue;
00123                 //       if v.max+p contained in v'
00124                 if( ( *othervseq ).contains( ( *vseq ).minmax[1] + HomCoord::unitv[p] ) )
00125                 {
00126                     //         maxcorner = false
00127                     maxcorner = false;
00128                     break;
00129                 }
00130             }
00131             if( !maxcorner ) break;
00132         }
00133
00134         //   if mincorner add to min corner list minlist
00135         if( mincorner ) minlist.push_back( *vseq );
00136         //   if maxcorner add to max corner list maxlist
00137         if( maxcorner ) maxlist.push_back( *vseq );
00138     }
00139
00140     //
00141     // if minlist.size = 1 & maxlist.size = 1 & minlist[0] = esequence.min &
00142     //         maxlist[0] = esequence.max+(1,1,1)
00143     if( minlist.size() == 1 && maxlist.size() == 1 && minlist[0].minmax[0] == elementParams[0] &&
00144         maxlist[0].minmax[1] == elementParams[1] )
00145         //   complete
00146         return true;
00147     // else
00148
00149     return false;
00150 }
00151
00152 SequenceData* SweptElementData::subset( EntityHandle /*start*/,
00153                                         EntityHandle /*end*/,
00154                                         const int* /*sequence_data_sizes*/,
00155                                         const int* /*tag_data_sizes*/ ) const
00156 {
00157     return 0;
00158 }
00159
00160 unsigned long SweptElementData::get_memory_use() const
00161 {
00162     return sizeof( *this ) + vertexSeqRefs.capacity() * sizeof( VertexDataRef );
00163 }
00164
00165 }  // namespace moab
