TShape3DB2.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2009 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2009) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file TShape3DB2.cpp
00028  *  \brief
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "TShape3DB2.hpp"
00034 #include "MsqMatrix.hpp"
00035 #include "MsqError.hpp"
00036 #include "TMPDerivs.hpp"
00037
00038 namespace MBMesquite
00039 {
00040
00041 TShape3DB2::~TShape3DB2() {}
00042
00043 std::string TShape3DB2::get_name() const
00044 {
00045     return "TShape3DB2";
00046 }
00047
00048 // \mu_3(T) = \frac{ |T|^2 |adj(T)|^2 } {9 \tau^2} - 1
00049 bool TShape3DB2::evaluate( const MsqMatrix< 3, 3 >& T, double& result, MsqError& err )
00050 {
00051     double f = sqr_Frobenius( T );
00052     double g = sqr_Frobenius( adj( T ) );
00053     double d = det( T );
00054     if( invalid_determinant( d ) )
00055     {
00056         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00057         return false;
00058     }
00059     result = ( f * g ) / ( 9 * d * d ) - 1;
00060     return true;
00061 }
00062
00063 bool TShape3DB2::evaluate_with_grad( const MsqMatrix< 3, 3 >& T,
00064                                      double& result,
00065                                      MsqMatrix< 3, 3 >& wrt_T,
00066                                      MsqError& err )
00067 {
00068     double f = sqr_Frobenius( T );
00069     double g = sqr_Frobenius( adj( T ) );
00070     double d = det( T );
00071     if( invalid_determinant( d ) )
00072     {
00073         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00074         return false;
00075     }
00076     result = ( f * g ) / ( 9 * d * d ) - 1;
00077
00078     wrt_T = T;
00079     wrt_T *= ( g + f * f );
00080     wrt_T -= f * ( T * transpose( T ) * T );
00081     wrt_T -= f * g / d * transpose_adj( T );
00082     wrt_T *= 2 / ( 9 * d * d );
00083
00084     return true;
00085 }
00086
00087 bool TShape3DB2::evaluate_with_hess( const MsqMatrix< 3, 3 >& T,
00088                                      double& result,
00089                                      MsqMatrix< 3, 3 >& wrt_T,
00090                                      MsqMatrix< 3, 3 > second[6],
00091                                      MsqError& err )
00092 {
00093     double f = sqr_Frobenius( T );
00094     double g = sqr_Frobenius( adj( T ) );
00095     double d = det( T );
00096     if( invalid_determinant( d ) )
00097     {
00098         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00099         return false;
00100     }
00101     const double den = 1.0 / ( 9 * d * d );
00102     result           = f * g * den - 1;
00103
00104     MsqMatrix< 3, 3 > dg   = 2 * ( f * T - T * transpose( T ) * T );
00105     MsqMatrix< 3, 3 > df   = 2 * T;
00106     MsqMatrix< 3, 3 > dtau = transpose_adj( T );
00107
00108     wrt_T = g * df + f * dg - 2 * f * g / d * transpose_adj( T );
00109     wrt_T *= den;
00110
00111     set_scaled_2nd_deriv_norm_sqr_adj( second, den * f, T );
00112     pluseq_scaled_I( second, 2 * den * g );
00113     pluseq_scaled_sum_outer_product( second, den, dg, df );
00114     pluseq_scaled_sum_outer_product( second, -2 * den * g / d, df, dtau );
00115     pluseq_scaled_sum_outer_product( second, -2 * den * f / d, dg, dtau );
00116     pluseq_scaled_outer_product( second, 6 * den * f * g / ( d * d ), dtau );
00117     pluseq_scaled_2nd_deriv_of_det( second, -2 * den * f * g / d, T );
00118
00119     return true;
00120 }
00121
00122 }  // namespace MBMesquite
