TSizeB1.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2006 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2006) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file TSizeB1.cpp
00028  *  \brief
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "TSizeB1.hpp"
00034 #include "MsqMatrix.hpp"
00035 #include "MsqError.hpp"
00036 #include "TMPDerivs.hpp"
00037 #include "TMPCommon.hpp"
00038
00039 namespace MBMesquite
00040 {
00041
00042 std::string TSizeB1::get_name() const
00043 {
00044     return "TSizeB1";
00045 }
00046
00047 TSizeB1::~TSizeB1() {}
00048
00049 bool TSizeB1::evaluate( const MsqMatrix< 2, 2 >& T, double& result, MsqError& err )
00050 {
00051     double d = det( T );
00052     if( TMetric::invalid_determinant( d ) )
00053     {
00054         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00055         return false;
00056     }
00057     result = d + 1.0 / d - 2.0;
00058     return true;
00059 }
00060
00061 bool TSizeB1::evaluate_with_grad( const MsqMatrix< 2, 2 >& T,
00062                                   double& result,
00063                                   MsqMatrix< 2, 2 >& deriv_wrt_T,
00064                                   MsqError& err )
00065 {
00066     double d = det( T );
00067     if( TMetric::invalid_determinant( d ) )
00068     {
00069         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00070         return false;
00071     }
00072     result      = d + 1.0 / d - 2.0;
00073     deriv_wrt_T = ( 1 - 1 / ( d * d ) ) * transpose_adj( T );
00074     return true;
00075 }
00076
00077 bool TSizeB1::evaluate_with_hess( const MsqMatrix< 2, 2 >& T,
00078                                   double& result,
00079                                   MsqMatrix< 2, 2 >& deriv_wrt_T,
00080                                   MsqMatrix< 2, 2 > second_wrt_T[3],
00081                                   MsqError& err )
00082 {
00083     double d = det( T );
00084     if( TMetric::invalid_determinant( d ) )
00085     {
00086         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00087         return false;
00088     }
00089     result                 = d + 1.0 / d - 2.0;
00090     MsqMatrix< 2, 2 > adjt = transpose_adj( T );
00091     const double f         = 1 - 1 / ( d * d );
00092     deriv_wrt_T            = f * adjt;
00093
00094     set_scaled_outer_product( second_wrt_T, 2 / ( d * d * d ), adjt );
00095     pluseq_scaled_2nd_deriv_of_det( second_wrt_T, f, T );
00096     return true;
00097 }
00098
00099 bool TSizeB1::evaluate( const MsqMatrix< 3, 3 >& T, double& result, MsqError& err )
00100 {
00101     double d = det( T );
00102     if( TMetric::invalid_determinant( d ) )
00103     {
00104         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00105         return false;
00106     }
00107     result = d + 1.0 / d - 2.0;
00108     return true;
00109 }
00110
00111 bool TSizeB1::evaluate_with_grad( const MsqMatrix< 3, 3 >& T,
00112                                   double& result,
00113                                   MsqMatrix< 3, 3 >& deriv_wrt_T,
00114                                   MsqError& err )
00115 {
00116     double d = det( T );
00117     if( TMetric::invalid_determinant( d ) )
00118     {
00119         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00120         return false;
00121     }
00122     result      = d + 1.0 / d - 2.0;
00123     deriv_wrt_T = ( 1 - 1 / ( d * d ) ) * transpose_adj( T );
00124     return true;
00125 }
00126
00127 bool TSizeB1::evaluate_with_hess( const MsqMatrix< 3, 3 >& T,
00128                                   double& result,
00129                                   MsqMatrix< 3, 3 >& deriv_wrt_T,
00130                                   MsqMatrix< 3, 3 > second_wrt_T[6],
00131                                   MsqError& err )
00132 {
00133     double d = det( T );
00134     if( TMetric::invalid_determinant( d ) )
00135     {
00136         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00137         return false;
00138     }
00139     result                 = d + 1.0 / d - 2.0;
00140     MsqMatrix< 3, 3 > adjt = transpose_adj( T );
00141     const double f         = 1 - 1 / ( d * d );
00142     deriv_wrt_T            = f * adjt;
00143
00144     set_scaled_outer_product( second_wrt_T, 2 / ( d * d * d ), adjt );
00145     pluseq_scaled_2nd_deriv_of_det( second_wrt_T, f, T );
00146     return true;
00147 }
00148
00149 }  // namespace MBMesquite
