TagVertexMesh.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2006 Lawrence Livermore National Laboratory.  Under
00005     the terms of Contract B545069 with the University of Wisconsin --
00006     Madison, Lawrence Livermore National Laboratory retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2006) [email protected]
00024
00025   ***************************************************************** */
00026
00027 /** \file TagVertexMesh.cpp
00028  *  \brief Implementation of MBMesquite::TagVertexMesh class
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "TagVertexMesh.hpp"
00034 #include "MsqError.hpp"
00035 #include "MsqVertex.hpp"
00036
00037 namespace MBMesquite
00038 {
00039
00040 std::string TagVertexMesh::get_name() const
00041 {
00042     std::string result( "TagVertexMesh(\"" );
00043     result += tagName;
00044     result += "\")";
00045     return result;
00046 }
00047
00048 void TagVertexMesh::initialize( Mesh* mesh, std::string name, MsqError& err )
00049 {
00050     MeshDecorator::set_mesh( mesh );
00051     tagName = name;
00052
00053     tagHandle = get_mesh()->tag_get( tagName, err );
00054     // If tag isn't defined yet, we're done for now.
00055     if( err.error_code() == MsqError::TAG_NOT_FOUND )
00056     {
00057         err.clear();
00058         return;
00059     }
00060     else if( MSQ_CHKERR( err ) )
00061         return;
00062
00063     // If tag is already defined, make sure it is the correct type.
00064     std::string t_name;
00065     Mesh::TagType type;
00066     unsigned length;
00067     tag_properties( tagHandle, t_name, type, length, err );MSQ_ERRRTN( err );
00068     if( !( type == Mesh::DOUBLE && length == 3 ) && !( type == Mesh::BYTE && length == 3 * sizeof( double ) ) )
00069         MSQ_SETERR( err )
00070     ( MsqError::TAG_ALREADY_EXISTS, "Tag \"%s\" has invalid type or size.", tagName.c_str() );
00071
00072     // If tag is already defined and init was true, reset tag
00073     // values.
00074     haveTagHandle = true;
00075 }
00076
00077 double TagVertexMesh::loop_over_mesh( MeshDomainAssoc* mesh_and_domain, const Settings*, MsqError& err )
00078 {
00079     Mesh* mesh = mesh_and_domain->get_mesh();
00080     if( mesh != get_mesh() )
00081     {
00082         MSQ_SETERR( err )
00083         ( "InstructionQueue and TagVertexMesh have different "
00084           "MBMesquite::Mesh instances.  Cannot initialize TagVertexMesh",
00085           MsqError::INVALID_MESH );
00086         return 0.0;
00087     }
00088
00089     copy_all_coordinates( err );
00090     MSQ_ERRZERO( err );
00091     return 0.0;
00092 }
00093
00094 void TagVertexMesh::copy_all_coordinates( MsqError& err )
00095 {
00096     if( !haveTagHandle )
00097     {
00098         tagHandle = get_mesh()->tag_create( tagName, Mesh::DOUBLE, 3, 0, err );MSQ_ERRRTN( err );
00099         haveTagHandle = true;
00100     }
00101
00102     std::vector< Mesh::VertexHandle > handles;
00103     get_all_vertices( handles, err );MSQ_ERRRTN( err );
00104     if( handles.empty() ) return;
00105
00106     std::vector< MsqVertex > coords( handles.size() );
00107     get_mesh()->vertices_get_coordinates( arrptr( handles ), arrptr( coords ), handles.size(), err );MSQ_ERRRTN( err );
00108
00109     std::vector< double > data( 3 * handles.size() );
00110     std::vector< double >::iterator j          = data.begin();
00111     std::vector< MsqVertex >::const_iterator i = coords.begin();
00112     while( i != coords.end() )
00113     {
00114         i->get_coordinates( &*j );
00115         ++i;
00116         j += 3;
00117     }
00118
00119     tag_set_vertex_data( tagHandle, handles.size(), arrptr( handles ), arrptr( data ), err );MSQ_ERRRTN( err );
00120 }
00121
00122 void TagVertexMesh::check_remove_tag( MsqError& err )
00123 {
00124     if( cleanUpTag && haveTagHandle )
00125     {
00126         tag_delete( tagHandle, err );MSQ_ERRRTN( err );
00127     }
00128     haveTagHandle = false;
00129 }
00130
00131 TagVertexMesh::TagVertexMesh( MsqError& err, Mesh* real_mesh, bool clean_up, std::string name )
00132     : tagHandle( 0 ), haveTagHandle( false ), cleanUpTag( clean_up )
00133 {
00134     if( name.size() == 0 ) name = "MsqAltCoords";
00135     initialize( real_mesh, name, err );MSQ_CHKERR( err );
00136 }
00137
00138 TagVertexMesh::~TagVertexMesh()
00139 {
00140     MsqError err;
00141     check_remove_tag( err );
00142 }
00143
00144 void TagVertexMesh::set_mesh( Mesh* mesh, MsqError& err )
00145 {
00146     check_remove_tag( err );MSQ_ERRRTN( err );
00147     initialize( mesh, tagName, err );MSQ_ERRRTN( err );
00148 }
00149
00150 void TagVertexMesh::set_tag_name( std::string name, MsqError& err )
00151 {
00152     check_remove_tag( err );MSQ_ERRRTN( err );
00153     initialize( get_mesh(), name, err );MSQ_ERRRTN( err );
00154 }
00155
00156 void TagVertexMesh::clear( MsqError& err )
00157 {
00158     if( haveTagHandle )
00159     {
00160         copy_all_coordinates( err );MSQ_CHKERR( err );
00161     }
00162 }
00163
00164 void TagVertexMesh::vertices_get_coordinates( const VertexHandle vert_array[],
00165                                               MsqVertex* coordinates,
00166                                               size_t num_vtx,
00167                                               MsqError& err )
00168 {
00169     if( !num_vtx ) return;
00170     if( !haveTagHandle )
00171     {
00172         get_mesh()->vertices_get_coordinates( vert_array, coordinates, num_vtx, err );MSQ_ERRRTN( err );
00173     }
00174     else
00175     {
00176         std::vector< double > coords( num_vtx * 3 );
00177         get_mesh()->tag_get_vertex_data( tagHandle, num_vtx, vert_array, arrptr( coords ), err );MSQ_ERRRTN( err );
00178         MsqVertex* coordinates_end              = coordinates + num_vtx;
00179         std::vector< double >::const_iterator i = coords.begin();
00180         while( coordinates != coordinates_end )
00181         {
00182             coordinates->set( &*i );
00183             i += 3;
00184             ++coordinates;
00185         }
00186     }
00187 }
00188
00189 void TagVertexMesh::vertex_set_coordinates( VertexHandle vertex, const Vector3D& coordinates, MsqError& err )
00190 {
00191     if( !haveTagHandle )
00192     {
00193         tagHandle = get_mesh()->tag_create( tagName, Mesh::DOUBLE, 3, 0, err );MSQ_ERRRTN( err );
00194         haveTagHandle = true;
00195         copy_all_coordinates( err );MSQ_ERRRTN( err );
00196     }
00197
00198     get_mesh()->tag_set_vertex_data( tagHandle, 1, &vertex, coordinates.to_array(), err );MSQ_ERRRTN( err );
00199 }
00200
00201 //***************  Tags  ***********
00202
00203 TagHandle TagVertexMesh::tag_create( const std::string& tag_name,
00204                                      TagType type,
00205                                      unsigned length,
00206                                      const void* default_value,
00207                                      MsqError& err )
00208 {
00209     // Don't allow access to internal tag for vertex coordinates.
00210     // This prevents accidental layering of multiple instances of
00211     // TagVertexMesh with the same tag name.
00212     if( tag_name == tagName )
00213     {
00214         MSQ_SETERR( err )
00215         ( "Attempt to access internal tag data using tag interface.", MsqError::TAG_ALREADY_EXISTS );
00216         return (TagHandle)0;
00217     }
00218
00219     return get_mesh()->tag_create( tag_name, type, length, default_value, err );
00220 }
00221
00222 TagHandle TagVertexMesh::tag_get( const std::string& name, MsqError& err )
00223 {
00224     // Don't allow access to internal tag for vertex coordinates.
00225     // This prevents accidental layering of multiple instances of
00226     // TagVertexMesh with the same tag name.
00227     if( name == tagName )
00228     {
00229         MSQ_SETERR( err )
00230         ( "Attempt to access internal tag data using tag interface.", MsqError::INVALID_ARG );
00231         return (TagHandle)0;
00232     }
00233
00234     return get_mesh()->tag_get( name, err );
00235 }
00236
00237 void TagVertexMesh::release()
00238 {
00239     MsqError err;
00240     clear( err );
00241     check_remove_tag( err );
00242     haveTagHandle = false;
00243     MeshDecorator::release();
00244 }
00245
00246 void TagVertexMesh::initialize_queue( MeshDomainAssoc*, const Settings*, MsqError& ) {}
00247
00248 }  // namespace MBMesquite
