TestRunner.hpp File Reference
#include "TestUtil.hpp"
+ Include dependency graph for TestRunner.hpp:
+ This graph shows which files directly or indirectly include this file:
Classes
struct  RunnerTest
Defines
#define REGISTER_TEST(TEST_FUNC)   runner_register_test( __FILE__, __LINE__, #TEST_FUNC, ( TEST_FUNC ), NULL )
#define REGISTER_DEP_TEST(TEST_FUNC, REQUIRED_FUNC)   runner_register_test( __FILE__, __LINE__, #TEST_FUNC, ( TEST_FUNC ), ( REQUIRED_FUNC ) )
#define RUN_TESTS(ARGC, ARGV)   runner_run_tests( ( ARGC ), ( ARGV ) )
Enumerations
enum  RunnerStatus { PASSED, FAILED, DESELECTED, SELECTED }
Functions
static void runner_register_test (const char *filename, int line_number, const char *name, test_func function, test_func requisite=0)
static int runner_run_tests (int argc, char *argv[])
static void runner_usage (FILE *str, int argc, char *argv[])
static void runner_list_tests (int long_format)
static void runner_help (int argc, char *argv[])
static size_t runner_find_test_func (test_func f)
static size_t runner_find_test_name (const char *name)
static size_t runner_add_test (test_func f, const char *name)
static void runner_add_requisite (size_t idx, size_t req)
static void free_test_list ()
Variables
struct RunnerTestRunnerTestList = 0
size_t RunnerTestCount = 0
const size_t RUNNER_NOT_FOUND = ~(size_t)0
Define Documentation
#define REGISTER_DEP_TEST (   TEST_FUNC,
  REQUIRED_FUNC
Definition at line 22 of file TestRunner.hpp.
#define REGISTER_TEST (   TEST_FUNC)    runner_register_test( __FILE__, __LINE__, #TEST_FUNC, ( TEST_FUNC ), NULL )
Definition at line 14 of file TestRunner.hpp.
Referenced by main().
#define RUN_TESTS (   ARGC,
  ARGV
Definition at line 31 of file TestRunner.hpp.
Enumeration Type Documentation
Enumerator:
PASSED
FAILED
DESELECTED
SELECTED
Definition at line 49 of file TestRunner.hpp.
Function Documentation
static void free_test_list ( ) [static]
Definition at line 120 of file TestRunner.hpp.
References RunnerTestCount, testName, and RunnerTest::testRequisites.
Referenced by runner_add_test().
    for( size_t i = 0; i < RunnerTestCount; ++i )
        free( RunnerTestList[i].testName );
        free( RunnerTestList[i].testRequisites );
    free( RunnerTestList );
static void runner_add_requisite ( size_t  idx,
size_t  req
) [static]
Definition at line 109 of file TestRunner.hpp.
References RunnerTest::numRequisites, and RunnerTest::testRequisites.
Referenced by runner_register_test().
    size_t i;
    for( i = 0; i < RunnerTestList[idx].numRequisites; ++i )
        if( RunnerTestList[idx].testRequisites[i] == (int)req ) return;
    ++RunnerTestList[idx].numRequisites;
    RunnerTestList[idx].testRequisites =
        (int*)realloc( RunnerTestList[idx].testRequisites,
                       RunnerTestList[idx].numRequisites * sizeof( *RunnerTestList[idx].testRequisites ) );
    RunnerTestList[idx].testRequisites[RunnerTestList[idx].numRequisites - 1] = req;
static size_t runner_add_test ( test_func  f,
const char *  name
) [static]
Definition at line 86 of file TestRunner.hpp.
References free_test_list(), RunnerTest::numRequisites, runner_find_test_func(), RUNNER_NOT_FOUND, RunnerTestCount, SELECTED, RunnerTest::testFunc, RunnerTest::testName, RunnerTest::testRequisites, and RunnerTest::testStatus.
    size_t idx = runner_find_test_func( f );
    if( idx == RUNNER_NOT_FOUND )
        if( !RunnerTestCount ) atexit( &free_test_list );
        idx                            = RunnerTestCount++;
        RunnerTest* new_RunnerTestList = (RunnerTest*)realloc( RunnerTestList, RunnerTestCount * sizeof( RunnerTest ) );
        if( !new_RunnerTestList )
            fprintf( stderr, "TestRunner::runner_add_test(): reallocation of RunnerTestList failed\n" );
        else
            RunnerTestList = new_RunnerTestList;
        RunnerTestList[idx].testFunc       = f;
        RunnerTestList[idx].testName       = strdup( name );
        RunnerTestList[idx].testStatus     = SELECTED;
        RunnerTestList[idx].testRequisites = 0;
        RunnerTestList[idx].numRequisites  = 0;
    return idx;
static size_t runner_find_test_func ( test_func  f) [static]
Definition at line 74 of file TestRunner.hpp.
References RUNNER_NOT_FOUND, RunnerTestCount, and testFunc.
Referenced by runner_add_test(), and runner_register_test().
        if( RunnerTestList[i].testFunc == f ) return i;
    return RUNNER_NOT_FOUND;
static size_t runner_find_test_name ( const char *  name) [static]
Definition at line 80 of file TestRunner.hpp.
References RUNNER_NOT_FOUND, RunnerTestCount, and testName.
Referenced by runner_run_tests().
        if( !strcmp( RunnerTestList[i].testName, name ) ) return i;
void runner_help ( int  argc,
char *  argv[]
) [static]
Definition at line 155 of file TestRunner.hpp.
References runner_usage().
    runner_usage( stdout, argc, argv );
    fprintf( stdout, "-l : List test names and exit\n"
                     "-L : List test names and requisites and exit\n"
                     "-h : This help text\n"
                     "-r : Recursively run requisite tests for any specified test\n"
                     "\n" );
void runner_list_tests ( int  long_format) [static]
Definition at line 165 of file TestRunner.hpp.
References DESELECTED, RunnerTest::numRequisites, RunnerTestCount, testName, RunnerTest::testRequisites, and RunnerTest::testStatus.
    size_t i, j;
    printf( "Test List:\n" );
    for( i = 0; i < RunnerTestCount; ++i )
        if( RunnerTestList[i].testStatus == DESELECTED ) continue;
        printf( " o %s\n", RunnerTestList[i].testName );
        if( !long_format || !RunnerTestList[i].numRequisites ) continue;
        if( RunnerTestList[i].numRequisites == 1 )
            printf( "  Requires : %s\n", RunnerTestList[RunnerTestList[i].testRequisites[0]].testName );
        else
            printf( "  Requires : \n" );
            for( j = 0; j < RunnerTestList[i].numRequisites; ++j )
                printf( "    - %s\n", RunnerTestList[RunnerTestList[i].testRequisites[j]].testName );
void runner_register_test ( const char *  filename,
int  line_number,
const char *  name,
test_func  function,
test_func  requisite = 0
) [static]
Definition at line 130 of file TestRunner.hpp.
References runner_add_requisite(), runner_add_test(), runner_find_test_func(), and RUNNER_NOT_FOUND.
    size_t i = runner_add_test( test, name );
    size_t req_idx;
    if( req )
        req_idx = runner_find_test_func( req );
        if( RUNNER_NOT_FOUND == req_idx )
            fprintf( stderr,
                     "Error registering requisite for test: \"%s\"\n"
                     "\tat %s:%d\n"
                     "\tRequisite test function not registered.\n",
                     name, filename, line_number );
            abort();
        runner_add_requisite( i, req_idx );
int runner_run_tests ( int  argc,
char *  argv[]
) [static]
Definition at line 185 of file TestRunner.hpp.
References DESELECTED, error_count, fail(), FAILED, list_tests(), MPI_COMM_WORLD, RunnerTest::numRequisites, PASSED, rank, run_test(), runner_find_test_name(), runner_help(), runner_list_tests(), RUNNER_NOT_FOUND, runner_usage(), RunnerTestCount, SELECTED, testFunc, testName, RunnerTest::testRequisites, and RunnerTest::testStatus.
    /* Counters */
    int error_count  = 0;
    int fail_count   = 0;
    int num_selected = 0;
    int num_run      = 0;
    /* Flags from parsed arguments */
    int run_requisites = 0;
    int list_tests     = 0;
    int first_selected = 1;
    /* Misc iterator vars and such */
    int changed_some, ran_some, can_run, fail;
    int k;
    const char* c;
    size_t i, j;
    /* Process command line arguments */
    for( k = 1; k < argc; ++k )
        if( argv[k][0] == '-' )
            for( c = argv[k] + 1; *c; ++c )
                switch( *c )
                    case 'l':
                        list_tests = 1;
                        break;
                    case 'L':
                        list_tests = 2;
                        break;
                    case 'r':
                        run_requisites = true;
                        break;
                    case 'h':
                        runner_help( argc, argv );
                        return 0;
                    default:
                        runner_usage( stderr, argc, argv );
                        fprintf( stderr, "Unknown flag: '%c'\n", *c );
                        return 1;
        else
            // If user has specified some tests to run, begin
            // by marking all tests as de-selected.
            if( first_selected )
                    RunnerTestList[i].testStatus = DESELECTED;
                first_selected = 0;
            // Mark specified test as selected.
            i = runner_find_test_name( argv[k] );
            if( RUNNER_NOT_FOUND == i )
                fprintf( stderr, "Unknown test name: \"%s\"\n", argv[k] );
                ++error_count;
            else
                RunnerTestList[i].testStatus = SELECTED;
    /* If recursively running requisite tests, select those also. */
    if( run_requisites )
        do
            changed_some = 0;
                    if( RunnerTestList[RunnerTestList[i].testRequisites[j]].testStatus == DESELECTED )
                        RunnerTestList[RunnerTestList[i].testRequisites[j]].testStatus = SELECTED;
                        changed_some                                                   = 1;
        } while( changed_some );
    // Count number of selected tests
    num_selected = 0;
        if( RunnerTestList[i].testStatus == SELECTED ) ++num_selected;
    if( list_tests )
        runner_list_tests( list_tests - 1 );
        return error_count;
    // Now run the tests
    num_run = 0;
    do
        ran_some = 0;
            if( RunnerTestList[i].testStatus != SELECTED ) continue;
            can_run = 1;
                k = RunnerTestList[i].testRequisites[j];
                if( RunnerTestList[k].testStatus != PASSED && RunnerTestList[k].testStatus != DESELECTED )
                    can_run = 0;
                    break;
            if( !can_run ) continue;
            ran_some = 1;
            ++num_run;
            fail = run_test( RunnerTestList[i].testFunc, RunnerTestList[i].testName );
            if( fail )
                error_count++;
                fail_count++;
                RunnerTestList[i].testStatus = FAILED;
            else
                RunnerTestList[i].testStatus = PASSED;
    } while( ran_some );
    // check if we are running parallel MPI tests
    int rank = 0;
#ifdef MOAB_HAVE_MPI
    int isInit;
    MPI_Initialized( &isInit );
    if( isInit )
        MPI_Comm_rank( MPI_COMM_WORLD, &rank );
#endif
    // Print brief summary
    if( rank == 0 )
        if( num_run == (int)RunnerTestCount && !fail_count )
            printf( "All %d tests passed.\n", num_run );
        else if( num_run == num_selected && !fail_count )
            printf( "All %d selected tests passed.\n", num_run );
            printf( "Skipped %d non-selected tests\n", (int)( RunnerTestCount - num_selected ) );
        else
            printf( "%2d tests registered\n", (int)RunnerTestCount );
            if( num_selected == num_run )
                printf( "%2d tests selected\n", num_selected );
            else
                printf( "%2d of %2d tests ran\n", num_run, num_selected );
            if( num_run < (int)RunnerTestCount )
                printf( "%2d of %2d tests skipped\n", (int)RunnerTestCount - num_run, (int)RunnerTestCount );
            printf( "%2d of %2d tests passed\n", num_run - fail_count, num_run );
            if( fail_count ) printf( "%2d of %2d tests FAILED\n", fail_count, num_run );
    return error_count;
void runner_usage ( FILE *  str,
int  argc,
char *  argv[]
) [static]
Definition at line 150 of file TestRunner.hpp.
Referenced by runner_help(), and runner_run_tests().
    fprintf( str, "%s [-l|-L] [-h] [-r] [<test_name> [<test_name> ...]]\n", argv[0] );
Variable Documentation
Definition at line 65 of file TestRunner.hpp.
