TopologyInfoTest.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2004 Lawrence Livermore National Laboratory.  Under
00005     the terms of Contract B545069 with the University of Wisconsin --
00006     Madison, Lawrence Livermore National Laboratory retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     [email protected]
00024
00025   ***************************************************************** */
00026
00027 #include <algorithm>
00028 #include <iostream>
00029 using std::cout;
00030 #include "cppunit/extensions/HelperMacros.h"
00031
00032 #include "Mesquite.hpp"
00033 #include "MsqError.hpp"
00034 #include "TopologyInfo.hpp"
00035
00036 using namespace MBMesquite;
00037
00038 class TopologyInfoTest : public CppUnit::TestFixture
00039 {
00040   private:
00041     CPPUNIT_TEST_SUITE( TopologyInfoTest );
00042
00043     CPPUNIT_TEST( tri );
00044     CPPUNIT_TEST( tri3 );
00045     CPPUNIT_TEST( tri4 );
00046     CPPUNIT_TEST( tri6 );
00047     CPPUNIT_TEST( tri7 );
00048
00049     CPPUNIT_TEST( quad );
00050     CPPUNIT_TEST( quad4 );
00051     CPPUNIT_TEST( quad5 );
00052     CPPUNIT_TEST( quad8 );
00053     CPPUNIT_TEST( quad9 );
00054
00055     CPPUNIT_TEST( tet );
00056     CPPUNIT_TEST( tet4 );
00057     CPPUNIT_TEST( tet5 );
00058     CPPUNIT_TEST( tet8 );
00059     CPPUNIT_TEST( tet9 );
00060     CPPUNIT_TEST( tet10 );
00061     CPPUNIT_TEST( tet11 );
00062     CPPUNIT_TEST( tet14 );
00063     CPPUNIT_TEST( tet15 );
00064
00065     CPPUNIT_TEST( hex );
00066     CPPUNIT_TEST( hex8 );
00067     CPPUNIT_TEST( hex9 );
00068     CPPUNIT_TEST( hex14 );
00069     CPPUNIT_TEST( hex15 );
00070     CPPUNIT_TEST( hex20 );
00071     CPPUNIT_TEST( hex21 );
00072     CPPUNIT_TEST( hex26 );
00073     CPPUNIT_TEST( hex27 );
00074
00075     CPPUNIT_TEST( pyramid );
00076     CPPUNIT_TEST( pyramid5 );
00077     CPPUNIT_TEST( pyramid13 );
00078
00079     CPPUNIT_TEST( wedge );
00080     CPPUNIT_TEST( wedge6 );
00081     CPPUNIT_TEST( wedge15 );
00082
00083     CPPUNIT_TEST( polygon );
00084     CPPUNIT_TEST( polyhedron );
00085
00086     CPPUNIT_TEST( bad_type );
00087
00088     CPPUNIT_TEST( tri_adj_vert );
00089     CPPUNIT_TEST( quad_adj_vert );
00090     CPPUNIT_TEST( tet_adj_vert );
00091     CPPUNIT_TEST( hex_adj_vert );
00092     CPPUNIT_TEST( pyr_adj_vert );
00093     CPPUNIT_TEST( wdg_adj_vert );
00094
00095     CPPUNIT_TEST( tri_rev_adj_vert );
00096     CPPUNIT_TEST( quad_rev_adj_vert );
00097     CPPUNIT_TEST( tet_rev_adj_vert );
00098     CPPUNIT_TEST( hex_rev_adj_vert );
00099     CPPUNIT_TEST( pyr_rev_adj_vert );
00100     CPPUNIT_TEST( wdg_rev_adj_vert );
00101
00102     CPPUNIT_TEST( higher_order_from_side );
00103     CPPUNIT_TEST( side_from_higher_order );
00104     CPPUNIT_TEST( find_edge );
00105     CPPUNIT_TEST( find_face );
00106     CPPUNIT_TEST( find_side );
00107     CPPUNIT_TEST( compare_sides );
00108
00109     CPPUNIT_TEST_SUITE_END();
00110
00111   public:
00112     void setUp() {}
00113
00114     void tearDown() {}
00115
00116     TopologyInfoTest() {}
00117
00118     bool compare_edge( const unsigned* a, const unsigned* b );
00119
00120     bool compare_face( unsigned len, const unsigned* a, const unsigned* b );
00121
00122     bool compare_vol( unsigned len, const unsigned* a, const unsigned* b );
00123
00124     void test_face_elem( EntityTopology topo, unsigned num_nodes, unsigned num_sides );
00125
00126     void test_vol_elem( EntityTopology topo,
00127                         unsigned num_nodes,
00128                         unsigned num_verts,
00129                         unsigned num_edges,
00130                         unsigned num_faces );
00131
00132     void test_poly( EntityTopology topo );
00133
00134     void tri();
00135     void tri3();
00136     void tri4();
00137     void tri6();
00138     void tri7();
00139
00140     void quad();
00141     void quad4();
00142     void quad5();
00143     void quad8();
00144     void quad9();
00145
00146     void tet();
00147     void tet4();
00148     void tet5();
00149     void tet8();
00150     void tet9();
00151     void tet10();
00152     void tet11();
00153     void tet14();
00154     void tet15();
00155
00156     void hex();
00157     void hex8();
00158     void hex9();
00159     void hex14();
00160     void hex15();
00161     void hex20();
00162     void hex21();
00163     void hex26();
00164     void hex27();
00165
00166     void pyramid();
00167     void pyramid5();
00168     void pyramid13();
00169
00170     void wedge();
00171     void wedge6();
00172     void wedge15();
00173
00174     void polygon();
00175     void polyhedron();
00176
00177     void bad_type();
00178
00179     void tri_adj_vert();
00180     void quad_adj_vert();
00181     void tet_adj_vert();
00182     void hex_adj_vert();
00183     void pyr_adj_vert();
00184     void wdg_adj_vert();
00185     void test_adj( MBMesquite::EntityTopology, const unsigned expected[][5] );
00186
00187     void tri_rev_adj_vert()
00188     {
00189         test_rev_adj( MBMesquite::TRIANGLE );
00190     }
00191     void quad_rev_adj_vert()
00192     {
00193         test_rev_adj( MBMesquite::QUADRILATERAL );
00194     }
00195     void tet_rev_adj_vert()
00196     {
00197         test_rev_adj( MBMesquite::TETRAHEDRON );
00198     }
00199     void hex_rev_adj_vert()
00200     {
00201         test_rev_adj( MBMesquite::HEXAHEDRON );
00202     }
00203     void pyr_rev_adj_vert()
00204     {
00205         test_rev_adj( MBMesquite::PYRAMID );
00206     }
00207     void wdg_rev_adj_vert()
00208     {
00209         test_rev_adj( MBMesquite::PRISM );
00210     }
00211     void test_rev_adj( MBMesquite::EntityTopology type );
00212
00213     void higher_order_from_side();
00214     void side_from_higher_order();
00215     void find_edge();
00216     void find_face();
00217     void find_side();
00218     void compare_sides();
00219 };
00220
00221 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TopologyInfoTest, "TopologyInfoTest" );
00222 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( TopologyInfoTest, "Unit" );
00223
00224 bool TopologyInfoTest::compare_edge( const unsigned* a, const unsigned* b )
00225 {
00226     return ( a[0] == b[0] && a[1] == b[1] ) || ( a[0] == b[1] && a[1] == b[0] );
00227 }
00228
00229 bool TopologyInfoTest::compare_face( unsigned len, const unsigned* a, const unsigned* b )
00230 {
00231     unsigned i, j;
00232     for( i = 0; i < len; ++i )
00233     {
00234         for( j = 0; j < len; ++j )
00235         {
00236             if( a[j] != b[( i + j ) % len] ) break;
00237         }
00238         if( j == len ) return true;
00239     }
00240     return false;
00241 }
00242
00243 bool TopologyInfoTest::compare_vol( unsigned len, const unsigned* a, const unsigned* b )
00244 {
00245     for( unsigned i = 0; i < len; ++i )
00246         if( a[i] != b[i] ) return false;
00247     return true;
00248 }
00249
00250 void TopologyInfoTest::test_face_elem( EntityTopology topo, unsigned num_nodes, unsigned num_sides )
00251 {
00252     MsqPrintError err( cout );
00253     bool edge, face, vol;
00254     unsigned index = 0;
00255     TopologyInfo::higher_order( topo, num_nodes, edge, face, vol, err );
00256     CPPUNIT_ASSERT( !err );
00257     CPPUNIT_ASSERT( !vol );
00258
00259     unsigned nodes = num_sides + edge * num_sides + face;
00260     CPPUNIT_ASSERT( num_nodes == nodes );
00261
00262     unsigned side, dim;
00263     for( index = 0; index < num_sides; ++index )
00264     {
00265         TopologyInfo::side_number( topo, num_nodes, index, dim, side, err );
00266         CPPUNIT_ASSERT( !err );
00267         CPPUNIT_ASSERT( dim == 0 && side == index );
00268     }
00269
00270     if( edge )
00271     {
00272         for( unsigned s = 0; s < num_sides; ++s )
00273         {
00274             TopologyInfo::side_number( topo, num_nodes, index++, dim, side, err );
00275             CPPUNIT_ASSERT( !err );
00276             CPPUNIT_ASSERT( dim == 1 && side == s );
00277         }
00278     }
00279     if( face )
00280     {
00281         TopologyInfo::side_number( topo, num_nodes, index++, dim, side, err );
00282         CPPUNIT_ASSERT( !err );
00283         CPPUNIT_ASSERT( dim == 2 && side == 0 );
00284     }
00285 }
00286
00287 void TopologyInfoTest::test_vol_elem( EntityTopology topo,
00288                                       unsigned num_nodes,
00289                                       unsigned num_verts,
00290                                       unsigned num_edges,
00291                                       unsigned num_faces )
00292 {
00293     MsqPrintError err( cout );
00294     bool edge, face, vol;
00295     unsigned index = 0;
00296     TopologyInfo::higher_order( topo, num_nodes, edge, face, vol, err );
00297     CPPUNIT_ASSERT( !err );
00298
00299     unsigned nodes = num_verts + edge * num_edges + face * num_faces + vol;
00300     CPPUNIT_ASSERT( num_nodes == nodes );
00301
00302     unsigned side, dim;
00303     for( index = 0; index < num_verts; ++index )
00304     {
00305         TopologyInfo::side_number( topo, num_nodes, index, dim, side, err );
00306         CPPUNIT_ASSERT( !err );
00307         CPPUNIT_ASSERT( dim == 0 && side == index );
00308     }
00309
00310     if( edge )
00311     {
00312         for( unsigned s = 0; s < num_edges; ++s )
00313         {
00314             TopologyInfo::side_number( topo, num_nodes, index++, dim, side, err );
00315             CPPUNIT_ASSERT( !err );
00316             CPPUNIT_ASSERT( dim == 1 && side == s );
00317         }
00318     }
00319     if( face )
00320     {
00321         for( unsigned s = 0; s < num_faces; ++s )
00322         {
00323             TopologyInfo::side_number( topo, num_nodes, index++, dim, side, err );
00324             CPPUNIT_ASSERT( !err );
00325             CPPUNIT_ASSERT( dim == 2 && side == s );
00326         }
00327     }
00328     if( vol )
00329     {
00330         TopologyInfo::side_number( topo, num_nodes, index++, dim, side, err );
00331         CPPUNIT_ASSERT( !err );
00332         CPPUNIT_ASSERT( dim == 3 && side == 0 );
00333     }
00334 }
00335
00336 void TopologyInfoTest::tri()
00337 {
00338     MsqPrintError err( cout );
00339
00340     CPPUNIT_ASSERT( 2 == TopologyInfo::dimension( TRIANGLE ) );
00341     CPPUNIT_ASSERT( 3 == TopologyInfo::adjacent( TRIANGLE, 1 ) );
00342     CPPUNIT_ASSERT( 3 == TopologyInfo::adjacent( TRIANGLE, 0 ) );
00343     CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( TRIANGLE, 2 ) );
00344     CPPUNIT_ASSERT( 0 == TopologyInfo::adjacent( TRIANGLE, 3 ) );
00345
00346     CPPUNIT_ASSERT( 3 == TopologyInfo::sides( TRIANGLE ) );
00347     CPPUNIT_ASSERT( 3 == TopologyInfo::corners( TRIANGLE ) );
00348     CPPUNIT_ASSERT( 3 == TopologyInfo::edges( TRIANGLE ) );
00349     CPPUNIT_ASSERT( 1 == TopologyInfo::faces( TRIANGLE ) );
00350
00351     const unsigned num_edges = 3;
00352     const unsigned* side;
00353     const unsigned edges[num_edges][2] = { { 0, 1 }, { 1, 2 }, { 2, 0 } };
00354     unsigned count;
00355     const unsigned face[] = { 0, 1, 2 };
00356
00357     for( unsigned i = 0; i < num_edges; ++i )
00358     {
00359         side = TopologyInfo::edge_vertices( TRIANGLE, i, err );
00360         CPPUNIT_ASSERT( !err );
00361         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00362
00363         side = TopologyInfo::side_vertices( TRIANGLE, 1, i, count, err );
00364         CPPUNIT_ASSERT( !err );
00365         CPPUNIT_ASSERT( 2 == count );
00366         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00367     }
00368
00369     side = TopologyInfo::side_vertices( TRIANGLE, 2, 0, count, err );
00370     CPPUNIT_ASSERT( !err );
00371     CPPUNIT_ASSERT( 3 == count );
00372     CPPUNIT_ASSERT( compare_face( 3, side, face ) );
00373 }
00374
00375 void TopologyInfoTest::tri3()
00376 {
00377     MsqPrintError err( cout );
00378     bool edge, face, vol;
00379     const int num_nodes = 3;
00380
00381     TopologyInfo::higher_order( TRIANGLE, num_nodes, edge, face, vol, err );
00382     CPPUNIT_ASSERT( !err );
00383     CPPUNIT_ASSERT( !edge );
00384     CPPUNIT_ASSERT( !face );
00385
00386     test_face_elem( TRIANGLE, num_nodes, 3 );
00387 }
00388
00389 void TopologyInfoTest::tri4()
00390 {
00391     MsqPrintError err( cout );
00392     bool edge, face, vol;
00393     const int num_nodes = 4;
00394
00395     TopologyInfo::higher_order( TRIANGLE, num_nodes, edge, face, vol, err );
00396     CPPUNIT_ASSERT( !err );
00397     CPPUNIT_ASSERT( !edge );
00398     CPPUNIT_ASSERT( face );
00399     CPPUNIT_ASSERT( !vol );
00400
00401     test_face_elem( TRIANGLE, num_nodes, 3 );
00402 }
00403
00404 void TopologyInfoTest::tri6()
00405 {
00406     MsqPrintError err( cout );
00407     bool edge, face, vol;
00408     const int num_nodes = 6;
00409
00410     TopologyInfo::higher_order( TRIANGLE, num_nodes, edge, face, vol, err );
00411     CPPUNIT_ASSERT( !err );
00412     CPPUNIT_ASSERT( edge );
00413     CPPUNIT_ASSERT( !face );
00414     CPPUNIT_ASSERT( !vol );
00415
00416     test_face_elem( TRIANGLE, num_nodes, 3 );
00417 }
00418
00419 void TopologyInfoTest::tri7()
00420 {
00421     MsqPrintError err( cout );
00422     bool edge, face, vol;
00423     const int num_nodes = 7;
00424
00425     TopologyInfo::higher_order( TRIANGLE, num_nodes, edge, face, vol, err );
00426     CPPUNIT_ASSERT( !err );
00427     CPPUNIT_ASSERT( edge );
00428     CPPUNIT_ASSERT( face );
00429     CPPUNIT_ASSERT( !vol );
00430
00431     test_face_elem( TRIANGLE, num_nodes, 3 );
00432 }
00433
00434 void TopologyInfoTest::quad()
00435 {
00436     MsqPrintError err( cout );
00437
00438     CPPUNIT_ASSERT( 2 == TopologyInfo::dimension( QUADRILATERAL ) );
00439     CPPUNIT_ASSERT( 4 == TopologyInfo::adjacent( QUADRILATERAL, 1 ) );
00440     CPPUNIT_ASSERT( 4 == TopologyInfo::adjacent( QUADRILATERAL, 0 ) );
00441     CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( QUADRILATERAL, 2 ) );
00442     CPPUNIT_ASSERT( 0 == TopologyInfo::adjacent( QUADRILATERAL, 3 ) );
00443
00444     CPPUNIT_ASSERT( 4 == TopologyInfo::sides( QUADRILATERAL ) );
00445     CPPUNIT_ASSERT( 4 == TopologyInfo::corners( QUADRILATERAL ) );
00446     CPPUNIT_ASSERT( 4 == TopologyInfo::edges( QUADRILATERAL ) );
00447     CPPUNIT_ASSERT( 1 == TopologyInfo::faces( QUADRILATERAL ) );
00448
00449     const unsigned num_edges = 4;
00450     const unsigned* side;
00451     const unsigned edges[num_edges][2] = { { 0, 1 }, { 1, 2 }, { 2, 3 }, { 3, 0 } };
00452     unsigned count;
00453     const unsigned face[] = { 0, 1, 2, 3 };
00454
00455     for( unsigned i = 0; i < num_edges; ++i )
00456     {
00457         side = TopologyInfo::edge_vertices( QUADRILATERAL, i, err );
00458         CPPUNIT_ASSERT( !err );
00459         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00460
00461         side = TopologyInfo::side_vertices( QUADRILATERAL, 1, i, count, err );
00462         CPPUNIT_ASSERT( !err );
00463         CPPUNIT_ASSERT( 2 == count );
00464         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00465     }
00466
00467     side = TopologyInfo::side_vertices( QUADRILATERAL, 2, 0, count, err );
00468     CPPUNIT_ASSERT( !err );
00469     CPPUNIT_ASSERT( 4 == count );
00470     CPPUNIT_ASSERT( compare_face( 4, side, face ) );
00471 }
00472
00473 void TopologyInfoTest::quad4()
00474 {
00475     MsqPrintError err( cout );
00476     bool edge, face, vol;
00477     const int num_nodes = 4;
00478
00479     TopologyInfo::higher_order( QUADRILATERAL, num_nodes, edge, face, vol, err );
00480     CPPUNIT_ASSERT( !err );
00481     CPPUNIT_ASSERT( !edge );
00482     CPPUNIT_ASSERT( !face );
00483     CPPUNIT_ASSERT( !vol );
00484
00485     test_face_elem( QUADRILATERAL, num_nodes, 4 );
00486 }
00487
00488 void TopologyInfoTest::quad5()
00489 {
00490     MsqPrintError err( cout );
00491     bool edge, face, vol;
00492     const int num_nodes = 5;
00493
00494     TopologyInfo::higher_order( QUADRILATERAL, num_nodes, edge, face, vol, err );
00495     CPPUNIT_ASSERT( !err );
00496     CPPUNIT_ASSERT( !edge );
00497     CPPUNIT_ASSERT( face );
00498     CPPUNIT_ASSERT( !vol );
00499
00500     test_face_elem( QUADRILATERAL, num_nodes, 4 );
00501 }
00502
00503 void TopologyInfoTest::quad8()
00504 {
00505     MsqPrintError err( cout );
00506     bool edge, face, vol;
00507     const int num_nodes = 8;
00508
00509     TopologyInfo::higher_order( QUADRILATERAL, num_nodes, edge, face, vol, err );
00510     CPPUNIT_ASSERT( !err );
00511     CPPUNIT_ASSERT( edge );
00512     CPPUNIT_ASSERT( !face );
00513     CPPUNIT_ASSERT( !vol );
00514
00515     test_face_elem( QUADRILATERAL, num_nodes, 4 );
00516 }
00517
00518 void TopologyInfoTest::quad9()
00519 {
00520     MsqPrintError err( cout );
00521     bool edge, face, vol;
00522     const int num_nodes = 9;
00523
00524     TopologyInfo::higher_order( QUADRILATERAL, num_nodes, edge, face, vol, err );
00525     CPPUNIT_ASSERT( !err );
00526     CPPUNIT_ASSERT( edge );
00527     CPPUNIT_ASSERT( face );
00528     CPPUNIT_ASSERT( !vol );
00529
00530     test_face_elem( QUADRILATERAL, num_nodes, 4 );
00531 }
00532
00533 void TopologyInfoTest::tet()
00534 {
00535     MsqPrintError err( cout );
00536
00537     const unsigned num_verts = 4;
00538     const unsigned num_edges = 6;
00539     const unsigned num_faces = 4;
00540     CPPUNIT_ASSERT( 3 == TopologyInfo::dimension( TETRAHEDRON ) );
00541     CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( TETRAHEDRON, 3 ) );
00542     CPPUNIT_ASSERT( num_faces == TopologyInfo::adjacent( TETRAHEDRON, 2 ) );
00543     CPPUNIT_ASSERT( num_edges == TopologyInfo::adjacent( TETRAHEDRON, 1 ) );
00544     CPPUNIT_ASSERT( num_verts == TopologyInfo::adjacent( TETRAHEDRON, 0 ) );
00545
00546     CPPUNIT_ASSERT( num_faces == TopologyInfo::sides( TETRAHEDRON ) );
00547     CPPUNIT_ASSERT( num_verts == TopologyInfo::corners( TETRAHEDRON ) );
00548     CPPUNIT_ASSERT( num_edges == TopologyInfo::edges( TETRAHEDRON ) );
00549     CPPUNIT_ASSERT( num_faces == TopologyInfo::faces( TETRAHEDRON ) );
00550
00551     const unsigned* side;
00552     unsigned i, count;
00553     const unsigned vert_per_face             = 3;
00554     unsigned edges[num_edges][2]             = { { 0, 1 }, { 1, 2 }, { 2, 0 }, { 0, 3 }, { 1, 3 }, { 2, 3 } };
00555     unsigned faces[num_faces][vert_per_face] = { { 0, 1, 3 }, { 1, 2, 3 }, { 2, 0, 3 }, { 2, 1, 0 } };
00556
00557     for( i = 0; i < num_edges; ++i )
00558     {
00559         side = TopologyInfo::edge_vertices( TETRAHEDRON, i, err );
00560         CPPUNIT_ASSERT( !err );
00561         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00562
00563         side = TopologyInfo::side_vertices( TETRAHEDRON, 1, i, count, err );
00564         CPPUNIT_ASSERT( !err );
00565         CPPUNIT_ASSERT( 2 == count );
00566         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00567     }
00568
00569     for( i = 0; i < num_faces; ++i )
00570     {
00571         side = TopologyInfo::face_vertices( TETRAHEDRON, i, count, err );
00572         CPPUNIT_ASSERT( !err );
00573         CPPUNIT_ASSERT( count == vert_per_face );
00574         CPPUNIT_ASSERT( compare_face( vert_per_face, side, faces[i] ) );
00575
00576         side = TopologyInfo::side_vertices( TETRAHEDRON, 2, i, count, err );
00577         CPPUNIT_ASSERT( !err );
00578         CPPUNIT_ASSERT( count == vert_per_face );
00579         CPPUNIT_ASSERT( compare_face( vert_per_face, side, faces[i] ) );
00580     }
00581
00582     side = TopologyInfo::side_vertices( TETRAHEDRON, 3, 0, count, err );
00583     CPPUNIT_ASSERT( !err );
00584     CPPUNIT_ASSERT( count == num_verts );
00585     for( i = 0; i < num_verts; ++i )
00586         CPPUNIT_ASSERT( side[i] == i );
00587 }
00588
00589 void TopologyInfoTest::tet4()
00590 {
00591     MsqPrintError err( cout );
00592     bool edge, face, vol;
00593     const int num_nodes = 4;
00594
00595     TopologyInfo::higher_order( TETRAHEDRON, num_nodes, edge, face, vol, err );
00596     CPPUNIT_ASSERT( !err );
00597     CPPUNIT_ASSERT( !edge );
00598     CPPUNIT_ASSERT( !face );
00599     CPPUNIT_ASSERT( !vol );
00600
00601     test_vol_elem( TETRAHEDRON, num_nodes, 4, 6, 4 );
00602 }
00603
00604 void TopologyInfoTest::tet5()
00605 {
00606     MsqPrintError err( cout );
00607     bool edge, face, vol;
00608     const int num_nodes = 5;
00609
00610     TopologyInfo::higher_order( TETRAHEDRON, num_nodes, edge, face, vol, err );
00611     CPPUNIT_ASSERT( !err );
00612     CPPUNIT_ASSERT( !edge );
00613     CPPUNIT_ASSERT( !face );
00614     CPPUNIT_ASSERT( vol );
00615
00616     test_vol_elem( TETRAHEDRON, num_nodes, 4, 6, 4 );
00617 }
00618
00619 void TopologyInfoTest::tet8()
00620 {
00621     MsqPrintError err( cout );
00622     bool edge, face, vol;
00623     const int num_nodes = 8;
00624
00625     TopologyInfo::higher_order( TETRAHEDRON, num_nodes, edge, face, vol, err );
00626     CPPUNIT_ASSERT( !err );
00627     CPPUNIT_ASSERT( !edge );
00628     CPPUNIT_ASSERT( face );
00629     CPPUNIT_ASSERT( !vol );
00630
00631     test_vol_elem( TETRAHEDRON, num_nodes, 4, 6, 4 );
00632 }
00633
00634 void TopologyInfoTest::tet9()
00635 {
00636     MsqPrintError err( cout );
00637     bool edge, face, vol;
00638     const int num_nodes = 9;
00639
00640     TopologyInfo::higher_order( TETRAHEDRON, num_nodes, edge, face, vol, err );
00641     CPPUNIT_ASSERT( !err );
00642     CPPUNIT_ASSERT( !edge );
00643     CPPUNIT_ASSERT( face );
00644     CPPUNIT_ASSERT( vol );
00645
00646     test_vol_elem( TETRAHEDRON, num_nodes, 4, 6, 4 );
00647 }
00648
00649 void TopologyInfoTest::tet10()
00650 {
00651     MsqPrintError err( cout );
00652     bool edge, face, vol;
00653     const int num_nodes = 10;
00654
00655     TopologyInfo::higher_order( TETRAHEDRON, num_nodes, edge, face, vol, err );
00656     CPPUNIT_ASSERT( !err );
00657     CPPUNIT_ASSERT( edge );
00658     CPPUNIT_ASSERT( !face );
00659     CPPUNIT_ASSERT( !vol );
00660
00661     test_vol_elem( TETRAHEDRON, num_nodes, 4, 6, 4 );
00662 }
00663
00664 void TopologyInfoTest::tet11()
00665 {
00666     MsqPrintError err( cout );
00667     bool edge, face, vol;
00668     const int num_nodes = 11;
00669
00670     TopologyInfo::higher_order( TETRAHEDRON, num_nodes, edge, face, vol, err );
00671     CPPUNIT_ASSERT( !err );
00672     CPPUNIT_ASSERT( edge );
00673     CPPUNIT_ASSERT( !face );
00674     CPPUNIT_ASSERT( vol );
00675
00676     test_vol_elem( TETRAHEDRON, num_nodes, 4, 6, 4 );
00677 }
00678
00679 void TopologyInfoTest::tet14()
00680 {
00681     MsqPrintError err( cout );
00682     bool edge, face, vol;
00683     const int num_nodes = 14;
00684
00685     TopologyInfo::higher_order( TETRAHEDRON, num_nodes, edge, face, vol, err );
00686     CPPUNIT_ASSERT( !err );
00687     CPPUNIT_ASSERT( edge );
00688     CPPUNIT_ASSERT( face );
00689     CPPUNIT_ASSERT( !vol );
00690
00691     test_vol_elem( TETRAHEDRON, num_nodes, 4, 6, 4 );
00692 }
00693
00694 void TopologyInfoTest::tet15()
00695 {
00696     MsqPrintError err( cout );
00697     bool edge, face, vol;
00698     const int num_nodes = 15;
00699
00700     TopologyInfo::higher_order( TETRAHEDRON, num_nodes, edge, face, vol, err );
00701     CPPUNIT_ASSERT( !err );
00702     CPPUNIT_ASSERT( edge );
00703     CPPUNIT_ASSERT( face );
00704     CPPUNIT_ASSERT( vol );
00705
00706     test_vol_elem( TETRAHEDRON, num_nodes, 4, 6, 4 );
00707 }
00708
00709 void TopologyInfoTest::hex()
00710 {
00711     MsqPrintError err( cout );
00712
00713     const unsigned num_verts = 8;
00714     const unsigned num_edges = 12;
00715     const unsigned num_faces = 6;
00716     CPPUNIT_ASSERT( 3 == TopologyInfo::dimension( HEXAHEDRON ) );
00717     CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( HEXAHEDRON, 3 ) );
00718     CPPUNIT_ASSERT( num_faces == TopologyInfo::adjacent( HEXAHEDRON, 2 ) );
00719     CPPUNIT_ASSERT( num_edges == TopologyInfo::adjacent( HEXAHEDRON, 1 ) );
00720     CPPUNIT_ASSERT( num_verts == TopologyInfo::adjacent( HEXAHEDRON, 0 ) );
00721
00722     CPPUNIT_ASSERT( num_faces == TopologyInfo::sides( HEXAHEDRON ) );
00723     CPPUNIT_ASSERT( num_verts == TopologyInfo::corners( HEXAHEDRON ) );
00724     CPPUNIT_ASSERT( num_edges == TopologyInfo::edges( HEXAHEDRON ) );
00725     CPPUNIT_ASSERT( num_faces == TopologyInfo::faces( HEXAHEDRON ) );
00726
00727     const unsigned* side;
00728     unsigned i, count;
00729     const unsigned vert_per_face             = 4;
00730     unsigned edges[num_edges][2]             = { { 0, 1 }, { 1, 2 }, { 2, 3 }, { 3, 0 }, { 0, 4 }, { 1, 5 },
00731                                      { 2, 6 }, { 3, 7 }, { 4, 5 }, { 5, 6 }, { 6, 7 }, { 7, 4 } };
00732     unsigned faces[num_faces][vert_per_face] = { { 0, 1, 5, 4 }, { 1, 2, 6, 5 }, { 2, 3, 7, 6 },
00733                                                  { 3, 0, 4, 7 }, { 3, 2, 1, 0 }, { 4, 5, 6, 7 } };
00734
00735     for( i = 0; i < num_edges; ++i )
00736     {
00737         side = TopologyInfo::edge_vertices( HEXAHEDRON, i, err );
00738         CPPUNIT_ASSERT( !err );
00739         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00740
00741         side = TopologyInfo::side_vertices( HEXAHEDRON, 1, i, count, err );
00742         CPPUNIT_ASSERT( !err );
00743         CPPUNIT_ASSERT( 2 == count );
00744         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00745     }
00746
00747     for( i = 0; i < num_faces; ++i )
00748     {
00749         side = TopologyInfo::face_vertices( HEXAHEDRON, i, count, err );
00750         CPPUNIT_ASSERT( !err );
00751         CPPUNIT_ASSERT( count == vert_per_face );
00752         CPPUNIT_ASSERT( compare_face( vert_per_face, side, faces[i] ) );
00753
00754         side = TopologyInfo::side_vertices( HEXAHEDRON, 2, i, count, err );
00755         CPPUNIT_ASSERT( !err );
00756         CPPUNIT_ASSERT( count == vert_per_face );
00757         CPPUNIT_ASSERT( compare_face( vert_per_face, side, faces[i] ) );
00758     }
00759
00760     side = TopologyInfo::side_vertices( HEXAHEDRON, 3, 0, count, err );
00761     CPPUNIT_ASSERT( !err );
00762     CPPUNIT_ASSERT( count == num_verts );
00763     for( i = 0; i < num_verts; ++i )
00764         CPPUNIT_ASSERT( side[i] == i );
00765 }
00766
00767 void TopologyInfoTest::hex8()
00768 {
00769     MsqPrintError err( cout );
00770     bool edge, face, vol;
00771     const int num_nodes = 8;
00772
00773     TopologyInfo::higher_order( HEXAHEDRON, num_nodes, edge, face, vol, err );
00774     CPPUNIT_ASSERT( !err );
00775     CPPUNIT_ASSERT( !edge );
00776     CPPUNIT_ASSERT( !face );
00777     CPPUNIT_ASSERT( !vol );
00778
00779     test_vol_elem( HEXAHEDRON, num_nodes, 8, 12, 6 );
00780 }
00781
00782 void TopologyInfoTest::hex9()
00783 {
00784     MsqPrintError err( cout );
00785     bool edge, face, vol;
00786     const int num_nodes = 9;
00787
00788     TopologyInfo::higher_order( HEXAHEDRON, num_nodes, edge, face, vol, err );
00789     CPPUNIT_ASSERT( !err );
00790     CPPUNIT_ASSERT( !edge );
00791     CPPUNIT_ASSERT( !face );
00792     CPPUNIT_ASSERT( vol );
00793
00794     test_vol_elem( HEXAHEDRON, num_nodes, 8, 12, 6 );
00795 }
00796
00797 void TopologyInfoTest::hex14()
00798 {
00799     MsqPrintError err( cout );
00800     bool edge, face, vol;
00801     const int num_nodes = 14;
00802
00803     TopologyInfo::higher_order( HEXAHEDRON, num_nodes, edge, face, vol, err );
00804     CPPUNIT_ASSERT( !err );
00805     CPPUNIT_ASSERT( !edge );
00806     CPPUNIT_ASSERT( face );
00807     CPPUNIT_ASSERT( !vol );
00808
00809     test_vol_elem( HEXAHEDRON, num_nodes, 8, 12, 6 );
00810 }
00811
00812 void TopologyInfoTest::hex15()
00813 {
00814     MsqPrintError err( cout );
00815     bool edge, face, vol;
00816     const int num_nodes = 15;
00817
00818     TopologyInfo::higher_order( HEXAHEDRON, num_nodes, edge, face, vol, err );
00819     CPPUNIT_ASSERT( !err );
00820     CPPUNIT_ASSERT( !edge );
00821     CPPUNIT_ASSERT( face );
00822     CPPUNIT_ASSERT( vol );
00823
00824     test_vol_elem( HEXAHEDRON, num_nodes, 8, 12, 6 );
00825 }
00826
00827 void TopologyInfoTest::hex20()
00828 {
00829     MsqPrintError err( cout );
00830     bool edge, face, vol;
00831     const int num_nodes = 20;
00832
00833     TopologyInfo::higher_order( HEXAHEDRON, num_nodes, edge, face, vol, err );
00834     CPPUNIT_ASSERT( !err );
00835     CPPUNIT_ASSERT( edge );
00836     CPPUNIT_ASSERT( !face );
00837     CPPUNIT_ASSERT( !vol );
00838
00839     test_vol_elem( HEXAHEDRON, num_nodes, 8, 12, 6 );
00840 }
00841
00842 void TopologyInfoTest::hex21()
00843 {
00844     MsqPrintError err( cout );
00845     bool edge, face, vol;
00846     const int num_nodes = 21;
00847
00848     TopologyInfo::higher_order( HEXAHEDRON, num_nodes, edge, face, vol, err );
00849     CPPUNIT_ASSERT( !err );
00850     CPPUNIT_ASSERT( edge );
00851     CPPUNIT_ASSERT( !face );
00852     CPPUNIT_ASSERT( vol );
00853
00854     test_vol_elem( HEXAHEDRON, num_nodes, 8, 12, 6 );
00855 }
00856
00857 void TopologyInfoTest::hex26()
00858 {
00859     MsqPrintError err( cout );
00860     bool edge, face, vol;
00861     const int num_nodes = 26;
00862
00863     TopologyInfo::higher_order( HEXAHEDRON, num_nodes, edge, face, vol, err );
00864     CPPUNIT_ASSERT( !err );
00865     CPPUNIT_ASSERT( edge );
00866     CPPUNIT_ASSERT( face );
00867     CPPUNIT_ASSERT( !vol );
00868
00869     test_vol_elem( HEXAHEDRON, num_nodes, 8, 12, 6 );
00870 }
00871
00872 void TopologyInfoTest::hex27()
00873 {
00874     MsqPrintError err( cout );
00875     bool edge, face, vol;
00876     const int num_nodes = 27;
00877
00878     TopologyInfo::higher_order( HEXAHEDRON, num_nodes, edge, face, vol, err );
00879     CPPUNIT_ASSERT( !err );
00880     CPPUNIT_ASSERT( edge );
00881     CPPUNIT_ASSERT( face );
00882     CPPUNIT_ASSERT( vol );
00883
00884     test_vol_elem( HEXAHEDRON, num_nodes, 8, 12, 6 );
00885 }
00886
00887 void TopologyInfoTest::pyramid()
00888 {
00889     MsqPrintError err( cout );
00890
00891     const unsigned num_verts = 5;
00892     const unsigned num_edges = 8;
00893     const unsigned num_faces = 5;
00894     CPPUNIT_ASSERT( 3 == TopologyInfo::dimension( PYRAMID ) );
00895     CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( PYRAMID, 3 ) );
00896     CPPUNIT_ASSERT( num_faces == TopologyInfo::adjacent( PYRAMID, 2 ) );
00897     CPPUNIT_ASSERT( num_edges == TopologyInfo::adjacent( PYRAMID, 1 ) );
00898     CPPUNIT_ASSERT( num_verts == TopologyInfo::adjacent( PYRAMID, 0 ) );
00899
00900     CPPUNIT_ASSERT( num_faces == TopologyInfo::sides( PYRAMID ) );
00901     CPPUNIT_ASSERT( num_verts == TopologyInfo::corners( PYRAMID ) );
00902     CPPUNIT_ASSERT( num_edges == TopologyInfo::edges( PYRAMID ) );
00903     CPPUNIT_ASSERT( num_faces == TopologyInfo::faces( PYRAMID ) );
00904
00905     const unsigned* side;
00906     unsigned i, count;
00907     const unsigned num_tri_faces  = 4;
00908     const unsigned num_quad_faces = 1;
00909     const bool tri_before_quad    = true;
00910     CPPUNIT_ASSERT( num_tri_faces + num_quad_faces == num_faces );
00911     unsigned edges[num_edges][2] = { { 0, 1 }, { 1, 2 }, { 2, 3 }, { 3, 0 }, { 0, 4 }, { 1, 4 }, { 2, 4 }, { 3, 4 } };
00912     unsigned tris[num_tri_faces][3]   = { { 0, 1, 4 }, { 1, 2, 4 }, { 2, 3, 4 }, { 3, 0, 4 } };
00913     unsigned quads[num_quad_faces][4] = { { 3, 2, 1, 0 } };
00914
00915     for( i = 0; i < num_edges; ++i )
00916     {
00917         side = TopologyInfo::edge_vertices( PYRAMID, i, err );
00918         CPPUNIT_ASSERT( !err );
00919         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00920
00921         side = TopologyInfo::side_vertices( PYRAMID, 1, i, count, err );
00922         CPPUNIT_ASSERT( !err );
00923         CPPUNIT_ASSERT( 2 == count );
00924         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
00925     }
00926
00927     const unsigned tri_off = num_quad_faces * !tri_before_quad;
00928     for( i = 0; i < num_tri_faces; ++i )
00929     {
00930         side = TopologyInfo::face_vertices( PYRAMID, i + tri_off, count, err );
00931         CPPUNIT_ASSERT( !err );
00932         CPPUNIT_ASSERT( count == 3 );
00933         CPPUNIT_ASSERT( compare_face( 3, side, tris[i] ) );
00934
00935         side = TopologyInfo::side_vertices( PYRAMID, 2, i + tri_off, count, err );
00936         CPPUNIT_ASSERT( !err );
00937         CPPUNIT_ASSERT( count == 3 );
00938         CPPUNIT_ASSERT( compare_face( 3, side, tris[i] ) );
00939     }
00940
00941     const unsigned quad_off = num_tri_faces * tri_before_quad;
00942     for( i = 0; i < num_quad_faces; ++i )
00943     {
00944         side = TopologyInfo::face_vertices( PYRAMID, i + quad_off, count, err );
00945         CPPUNIT_ASSERT( !err );
00946         CPPUNIT_ASSERT( count == 4 );
00947         CPPUNIT_ASSERT( compare_face( 4, side, quads[i] ) );
00948
00949         side = TopologyInfo::side_vertices( PYRAMID, 2, i + quad_off, count, err );
00950         CPPUNIT_ASSERT( !err );
00951         CPPUNIT_ASSERT( count == 4 );
00952         CPPUNIT_ASSERT( compare_face( 4, side, quads[i] ) );
00953     }
00954
00955     side = TopologyInfo::side_vertices( PYRAMID, 3, 0, count, err );
00956     CPPUNIT_ASSERT( !err );
00957     CPPUNIT_ASSERT( count == num_verts );
00958     for( i = 0; i < num_verts; ++i )
00959         CPPUNIT_ASSERT( side[i] == i );
00960 }
00961
00962 void TopologyInfoTest::pyramid5()
00963 {
00964     MsqPrintError err( cout );
00965     bool edge, face, vol;
00966     const int num_nodes = 5;
00967
00968     TopologyInfo::higher_order( PYRAMID, num_nodes, edge, face, vol, err );
00969     CPPUNIT_ASSERT( !err );
00970     CPPUNIT_ASSERT( !edge );
00971     CPPUNIT_ASSERT( !face );
00972     CPPUNIT_ASSERT( !vol );
00973
00974     test_vol_elem( PYRAMID, num_nodes, 5, 8, 5 );
00975 }
00976
00977 void TopologyInfoTest::pyramid13()
00978 {
00979     MsqPrintError err( cout );
00980     bool edge, face, vol;
00981     const int num_nodes = 13;
00982
00983     TopologyInfo::higher_order( PYRAMID, num_nodes, edge, face, vol, err );
00984     CPPUNIT_ASSERT( !err );
00985     CPPUNIT_ASSERT( edge );
00986     CPPUNIT_ASSERT( !face );
00987     CPPUNIT_ASSERT( !vol );
00988
00989     test_vol_elem( PYRAMID, num_nodes, 5, 8, 5 );
00990 }
00991
00992 void TopologyInfoTest::wedge()
00993 {
00994     MsqPrintError err( cout );
00995
00996     const unsigned num_verts = 6;
00997     const unsigned num_edges = 9;
00998     const unsigned num_faces = 5;
00999     CPPUNIT_ASSERT( 3 == TopologyInfo::dimension( PRISM ) );
01000     CPPUNIT_ASSERT( 1 == TopologyInfo::adjacent( PRISM, 3 ) );
01001     CPPUNIT_ASSERT( num_faces == TopologyInfo::adjacent( PRISM, 2 ) );
01002     CPPUNIT_ASSERT( num_edges == TopologyInfo::adjacent( PRISM, 1 ) );
01003     CPPUNIT_ASSERT( num_verts == TopologyInfo::adjacent( PRISM, 0 ) );
01004
01005     CPPUNIT_ASSERT( num_faces == TopologyInfo::sides( PRISM ) );
01006     CPPUNIT_ASSERT( num_verts == TopologyInfo::corners( PRISM ) );
01007     CPPUNIT_ASSERT( num_edges == TopologyInfo::edges( PRISM ) );
01008     CPPUNIT_ASSERT( num_faces == TopologyInfo::faces( PRISM ) );
01009
01010     const unsigned* side;
01011     unsigned i, count;
01012     const unsigned num_tri_faces  = 2;
01013     const unsigned num_quad_faces = 3;
01014     const bool tri_before_quad    = false;
01015     CPPUNIT_ASSERT( num_tri_faces + num_quad_faces == num_faces );
01016     unsigned edges[num_edges][2]      = { { 0, 1 }, { 1, 2 }, { 2, 0 }, { 0, 3 }, { 1, 4 },
01017                                      { 2, 5 }, { 3, 4 }, { 4, 5 }, { 5, 3 } };
01018     unsigned tris[num_tri_faces][3]   = { { 2, 1, 0 }, { 3, 4, 5 } };
01019     unsigned quads[num_quad_faces][4] = { { 0, 1, 4, 3 }, { 1, 2, 5, 4 }, { 2, 0, 3, 5 } };
01020
01021     for( i = 0; i < num_edges; ++i )
01022     {
01023         side = TopologyInfo::edge_vertices( PRISM, i, err );
01024         CPPUNIT_ASSERT( !err );
01025         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
01026
01027         side = TopologyInfo::side_vertices( PRISM, 1, i, count, err );
01028         CPPUNIT_ASSERT( !err );
01029         CPPUNIT_ASSERT( 2 == count );
01030         CPPUNIT_ASSERT( compare_edge( side, edges[i] ) );
01031     }
01032
01033     const unsigned tri_off = num_quad_faces * !tri_before_quad;
01034     for( i = 0; i < num_tri_faces; ++i )
01035     {
01036         side = TopologyInfo::face_vertices( PRISM, i + tri_off, count, err );
01037         CPPUNIT_ASSERT( !err );
01038         CPPUNIT_ASSERT( count == 3 );
01039         CPPUNIT_ASSERT( compare_face( 3, side, tris[i] ) );
01040
01041         side = TopologyInfo::side_vertices( PRISM, 2, i + tri_off, count, err );
01042         CPPUNIT_ASSERT( !err );
01043         CPPUNIT_ASSERT( count == 3 );
01044         CPPUNIT_ASSERT( compare_face( 3, side, tris[i] ) );
01045     }
01046
01047     const unsigned quad_off = num_tri_faces * tri_before_quad;
01048     for( i = 0; i < num_quad_faces; ++i )
01049     {
01050         side = TopologyInfo::face_vertices( PRISM, i + quad_off, count, err );
01051         CPPUNIT_ASSERT( !err );
01052         CPPUNIT_ASSERT( count == 4 );
01053         CPPUNIT_ASSERT( compare_face( 4, side, quads[i] ) );
01054
01055         side = TopologyInfo::side_vertices( PRISM, 2, i + quad_off, count, err );
01056         CPPUNIT_ASSERT( !err );
01057         CPPUNIT_ASSERT( count == 4 );
01058         CPPUNIT_ASSERT( compare_face( 4, side, quads[i] ) );
01059     }
01060
01061     side = TopologyInfo::side_vertices( PRISM, 3, 0, count, err );
01062     CPPUNIT_ASSERT( !err );
01063     CPPUNIT_ASSERT( count == num_verts );
01064     for( i = 0; i < num_verts; ++i )
01065         CPPUNIT_ASSERT( side[i] == i );
01066 }
01067
01068 void TopologyInfoTest::wedge6()
01069 {
01070     MsqPrintError err( cout );
01071     bool edge, face, vol;
01072     const int num_nodes = 6;
01073
01074     TopologyInfo::higher_order( PRISM, num_nodes, edge, face, vol, err );
01075     CPPUNIT_ASSERT( !err );
01076     CPPUNIT_ASSERT( !edge );
01077     CPPUNIT_ASSERT( !face );
01078     CPPUNIT_ASSERT( !vol );
01079
01080     test_vol_elem( PRISM, num_nodes, 6, 9, 5 );
01081 }
01082
01083 void TopologyInfoTest::wedge15()
01084 {
01085     MsqPrintError err( cout );
01086     bool edge, face, vol;
01087     const int num_nodes = 15;
01088
01089     TopologyInfo::higher_order( PRISM, num_nodes, edge, face, vol, err );
01090     CPPUNIT_ASSERT( !err );
01091     CPPUNIT_ASSERT( edge );
01092     CPPUNIT_ASSERT( !face );
01093     CPPUNIT_ASSERT( !vol );
01094
01095     test_vol_elem( PRISM, num_nodes, 6, 9, 5 );
01096 }
01097
01098 void TopologyInfoTest::test_poly( EntityTopology topo )
01099 {
01100     CPPUNIT_ASSERT( TopologyInfo::adjacent( topo, 1 ) == 0 );
01101     CPPUNIT_ASSERT( TopologyInfo::sides( topo ) == 0 );
01102     CPPUNIT_ASSERT( TopologyInfo::corners( topo ) == 0 );
01103     CPPUNIT_ASSERT( TopologyInfo::edges( topo ) == 0 );
01104     CPPUNIT_ASSERT( TopologyInfo::faces( topo ) == 0 );
01105 }
01106
01107 void TopologyInfoTest::polygon()
01108 {
01109     CPPUNIT_ASSERT( TopologyInfo::dimension( POLYGON ) == 2 );
01110     test_poly( POLYGON );
01111 }
01112
01113 void TopologyInfoTest::polyhedron()
01114 {
01115     CPPUNIT_ASSERT( TopologyInfo::dimension( POLYHEDRON ) == 3 );
01116     test_poly( POLYHEDRON );
01117 }
01118
01119 void TopologyInfoTest::bad_type()
01120 {
01121     MBMesquite::MsqError err;
01122     EntityTopology bad_types[] = { (EntityTopology)0, (EntityTopology)1, MIXED, (EntityTopology)( MIXED + 1 ) };
01123
01124     for( unsigned i = 0; i < ( sizeof( bad_types ) / sizeof( EntityTopology ) ); ++i )
01125     {
01126         CPPUNIT_ASSERT( TopologyInfo::dimension( bad_types[i] ) == 0 );
01127         CPPUNIT_ASSERT( TopologyInfo::adjacent( bad_types[i], 1 ) == 0 );
01128         CPPUNIT_ASSERT( TopologyInfo::sides( bad_types[i] ) == 0 );
01129         CPPUNIT_ASSERT( TopologyInfo::corners( bad_types[i] ) == 0 );
01130         CPPUNIT_ASSERT( TopologyInfo::edges( bad_types[i] ) == 0 );
01131         CPPUNIT_ASSERT( TopologyInfo::faces( bad_types[i] ) == 0 );
01132
01133         bool a, b, c;
01134         TopologyInfo::higher_order( bad_types[i], 20, a, b, c, err );
01135         CPPUNIT_ASSERT( err );
01136
01137         const unsigned* ptr;
01138         ptr = TopologyInfo::edge_vertices( bad_types[i], 0, err );
01139         CPPUNIT_ASSERT( err );
01140
01141         unsigned count;
01142         ptr = TopologyInfo::face_vertices( bad_types[i], 0, count, err );
01143         CPPUNIT_ASSERT( err );
01144
01145         for( unsigned j = 0; j < 4; ++j )
01146         {
01147             ptr = TopologyInfo::side_vertices( bad_types[i], j, 0, count, err );
01148             CPPUNIT_ASSERT( err );
01149         }
01150
01151         unsigned dim, side;
01152         for( unsigned idx = 0; idx < 20; ++idx )
01153         {
01154             TopologyInfo::side_number( bad_types[i], idx, idx / 2, dim, side, err );
01155             CPPUNIT_ASSERT( err );
01156         }
01157     }
01158 }
01159
01160 void TopologyInfoTest::tri_adj_vert()
01161 {
01162     unsigned data[][5] = { { 2, 1, 2, 0, 0 }, { 2, 2, 0, 0, 0 }, { 2, 0, 1, 0, 0 } };
01163     test_adj( MBMesquite::TRIANGLE, data );
01164 }
01165
01166 void TopologyInfoTest::quad_adj_vert()
01167 {
01168     unsigned data[][5] = { { 2, 1, 3, 0, 0 }, { 2, 2, 0, 0, 0 }, { 2, 3, 1, 0, 0 }, { 2, 0, 2, 0, 0 } };
01169     test_adj( MBMesquite::QUADRILATERAL, data );
01170 }
01171
01172 void TopologyInfoTest::tet_adj_vert()
01173 {
01174     unsigned data[][5] = { { 3, 1, 2, 3, 0 }, { 3, 2, 0, 3, 0 }, { 3, 0, 1, 3, 0 }, { 3, 2, 1, 0, 0 } };
01175     test_adj( MBMesquite::TETRAHEDRON, data );
01176 }
01177
01178 void TopologyInfoTest::hex_adj_vert()
01179 {
01180     unsigned data[][5] = { { 3, 1, 3, 4, 0 }, { 3, 2, 0, 5, 0 }, { 3, 3, 1, 6, 0 }, { 3, 0, 2, 7, 0 },
01181                            { 3, 7, 5, 0, 0 }, { 3, 4, 6, 1, 0 }, { 3, 5, 7, 2, 0 }, { 3, 6, 4, 3, 0 } };
01182     test_adj( MBMesquite::HEXAHEDRON, data );
01183 }
01184
01185 void TopologyInfoTest::pyr_adj_vert()
01186 {
01187     unsigned data[][5] = {
01188         { 3, 1, 3, 4, 0 }, { 3, 2, 0, 4, 0 }, { 3, 3, 1, 4, 0 }, { 3, 0, 2, 4, 0 }, { 4, 3, 2, 1, 0 } };
01189     test_adj( MBMesquite::PYRAMID, data );
01190 }
01191
01192 void TopologyInfoTest::wdg_adj_vert()
01193 {
01194     unsigned data[][5] = { { 3, 1, 2, 3, 0 }, { 3, 2, 0, 4, 0 }, { 3, 0, 1, 5, 0 },
01195                            { 3, 5, 4, 0, 0 }, { 3, 3, 5, 1, 0 }, { 3, 4, 3, 2, 0 } };
01196     test_adj( MBMesquite::PRISM, data );
01197 }
01198
01199 void TopologyInfoTest::test_adj( MBMesquite::EntityTopology type, const unsigned data[][5] )
01200 {
01201     // Get num vertices from type
01202     unsigned n = TopologyInfo::corners( type );
01203     CPPUNIT_ASSERT( n > 0 );
01204
01205     // The first index into data is the vertex.
01206     // Each column of "data", indexed by vertex, is a
01207     // vector containing the number of adjacent vertices
01208     // followed by the list if adjacent vertex indices.
01209
01210     // for each vertex
01211     for( unsigned i = 0; i < n; ++i )
01212     {
01213         // Get the data corresponding to this vertex of the element
01214         unsigned const* corner  = data[i];
01215         unsigned expected_count = corner[0];
01216         // Query TopologyInfo for the same data
01217         unsigned actual_count;
01218         unsigned const* actual_adj = TopologyInfo::adjacent_vertices( type, i, actual_count );
01219         // Check result is valid and counts match
01220         CPPUNIT_ASSERT( actual_adj != NULL );
01221         CPPUNIT_ASSERT( expected_count == actual_count );
01222
01223         // For 3-D elements, returned vertices are expected to be oriented
01224         // such that  a face bounded by the vertices in the counter-clockwise
01225         // order will have a normal pointing away from the input vertex.
01226         // So the vertices must be in a certain order, but may begin with
01227         // any of the adjacent vertices.
01228
01229         // Find the location in the result list at which the first
01230         // vertex in the expected list occurs.
01231         unsigned j;
01232         for( j = 0; j < actual_count; ++j )
01233             if( corner[1] == actual_adj[j] ) break;
01234         // Asssert that the first expected vertex was somewhere in
01235         // the result list.
01236         CPPUNIT_ASSERT( j < actual_count );
01237         // Compare the remaining vertices, enforcing the order.
01238         for( unsigned k = 1; k < actual_count; ++k )
01239             CPPUNIT_ASSERT( corner[k + 1] == actual_adj[( k + j ) % actual_count] );
01240     }
01241 }
01242
01243 void TopologyInfoTest::test_rev_adj( MBMesquite::EntityTopology type )
01244 {
01245     // Get num vertices from type
01246     unsigned n = TopologyInfo::corners( type );
01247     CPPUNIT_ASSERT( n > 0 );
01248
01249     // for each vertex
01250     for( unsigned i = 0; i < n; ++i )
01251     {
01252         // get adjacent vertex list
01253         unsigned num_adj_idx;
01254         unsigned const* adj_idx = TopologyInfo::adjacent_vertices( type, i, num_adj_idx );
01255         CPPUNIT_ASSERT( adj_idx != NULL );
01256         CPPUNIT_ASSERT( num_adj_idx > 1 );
01257
01258         // make sure adjacent vertex list is unique
01259         std::vector< unsigned > adj_idx_copy( num_adj_idx );
01260         std::copy( adj_idx, adj_idx + num_adj_idx, adj_idx_copy.begin() );
01261         std::sort( adj_idx_copy.begin(), adj_idx_copy.end() );
01262         std::vector< unsigned >::iterator iter;
01263         iter = std::unique( adj_idx_copy.begin(), adj_idx_copy.end() );
01264         CPPUNIT_ASSERT( iter == adj_idx_copy.end() );
01265
01266         // Get reverse mapping indices
01267         unsigned num_rev_idx;
01268         unsigned const* rev_idx = TopologyInfo::reverse_vertex_adjacency_offsets( type, i, num_rev_idx );
01269         CPPUNIT_ASSERT( rev_idx != NULL );
01270         CPPUNIT_ASSERT( num_rev_idx == num_adj_idx );
01271
01272         // for each adjacent vertex, test reverse mapping
01273         for( unsigned j = 0; j < num_adj_idx; ++j )
01274         {
01275             unsigned num_adj_adj_idx;
01276             unsigned const* adj_adj_idx = TopologyInfo::adjacent_vertices( type, adj_idx[j], num_adj_adj_idx );
01277
01278             CPPUNIT_ASSERT( rev_idx[j] < num_adj_adj_idx );
01279             CPPUNIT_ASSERT( adj_adj_idx[rev_idx[j]] == i );
01280         }
01281     }
01282 }
01283
01284 struct ho_result
01285 {
01286     unsigned dim;
01287     unsigned num;
01288     unsigned idx;
01289 };
01290
01291 const ho_result HEX27[] = { { 1, 0, 8 },   { 1, 1, 9 },   { 1, 2, 10 }, { 1, 3, 11 }, { 1, 4, 12 },
01292                             { 1, 5, 13 },  { 1, 6, 14 },  { 1, 7, 15 }, { 1, 8, 16 }, { 1, 9, 17 },
01293                             { 1, 10, 18 }, { 1, 11, 19 }, { 2, 0, 20 }, { 2, 1, 21 }, { 2, 2, 22 },
01294                             { 2, 3, 23 },  { 2, 4, 24 },  { 2, 5, 25 }, { 3, 0, 26 } };
01295
01296 const ho_result* const HEX20 = HEX27;
01297 const ho_result* const HEX26 = HEX27;
01298
01299 const ho_result HEX15[] = { { 2, 0, 8 },  { 2, 1, 9 },  { 2, 2, 10 }, { 2, 3, 11 },
01300                             { 2, 4, 12 }, { 2, 5, 13 }, { 3, 0, 14 } };
01301
01302 const ho_result* const HEX14 = HEX15;
01303
01304 const ho_result HEX9[] = { { 3, 0, 8 } };
01305
01306 void TopologyInfoTest::higher_order_from_side()
01307 {
01308     MsqPrintError err( std::cerr );
01309     // HEX-27
01310     for( unsigned i = 0; i < 19; ++i )
01311     {
01312         unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 27, HEX27[i].dim, HEX27[i].num, err );
01313         CPPUNIT_ASSERT( !err );
01314         CPPUNIT_ASSERT_EQUAL( HEX27[i].idx, result );
01315     }
01316     // HEX-26
01317     for( unsigned i = 0; i < 18; ++i )
01318     {
01319         unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 26, HEX26[i].dim, HEX26[i].num, err );
01320         CPPUNIT_ASSERT( !err );
01321         CPPUNIT_ASSERT_EQUAL( HEX26[i].idx, result );
01322     }
01323     // HEX-20
01324     for( unsigned i = 0; i < 12; ++i )
01325     {
01326         unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 20, HEX20[i].dim, HEX20[i].num, err );
01327         CPPUNIT_ASSERT( !err );
01328         CPPUNIT_ASSERT_EQUAL( HEX20[i].idx, result );
01329     }
01330     // HEX-15
01331     for( unsigned i = 0; i < 7; ++i )
01332     {
01333         unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 15, HEX15[i].dim, HEX15[i].num, err );
01334         CPPUNIT_ASSERT( !err );
01335         CPPUNIT_ASSERT_EQUAL( HEX15[i].idx, result );
01336     }
01337     // HEX-14
01338     for( unsigned i = 0; i < 6; ++i )
01339     {
01340         unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 14, HEX14[i].dim, HEX14[i].num, err );
01341         CPPUNIT_ASSERT( !err );
01342         CPPUNIT_ASSERT_EQUAL( HEX14[i].idx, result );
01343     }
01344     // HEX-9
01345     for( unsigned i = 0; i < 1; ++i )
01346     {
01347         unsigned result = TopologyInfo::higher_order_from_side( HEXAHEDRON, 9, HEX9[i].dim, HEX9[i].num, err );
01348         CPPUNIT_ASSERT( !err );
01349         CPPUNIT_ASSERT_EQUAL( HEX9[i].idx, result );
01350     }
01351 }
01352
01353 void TopologyInfoTest::side_from_higher_order()
01354 {
01355     MsqPrintError err( std::cerr );
01356     unsigned dim, num;
01357     // HEX-27
01358     for( unsigned i = 0; i < 19; ++i )
01359     {
01360         TopologyInfo::side_from_higher_order( HEXAHEDRON, 27, HEX27[i].idx, dim, num, err );
01361         CPPUNIT_ASSERT( !err );
01362         CPPUNIT_ASSERT_EQUAL( HEX27[i].dim, dim );
01363         CPPUNIT_ASSERT_EQUAL( HEX27[i].num, num );
01364     }
01365     // HEX-26
01366     for( unsigned i = 0; i < 18; ++i )
01367     {
01368         TopologyInfo::side_from_higher_order( HEXAHEDRON, 26, HEX26[i].idx, dim, num, err );
01369         CPPUNIT_ASSERT( !err );
01370         CPPUNIT_ASSERT_EQUAL( HEX26[i].dim, dim );
01371         CPPUNIT_ASSERT_EQUAL( HEX26[i].num, num );
01372     }
01373     // HEX-20
01374     for( unsigned i = 0; i < 12; ++i )
01375     {
01376         TopologyInfo::side_from_higher_order( HEXAHEDRON, 20, HEX20[i].idx, dim, num, err );
01377         CPPUNIT_ASSERT( !err );
01378         CPPUNIT_ASSERT_EQUAL( HEX20[i].dim, dim );
01379         CPPUNIT_ASSERT_EQUAL( HEX20[i].num, num );
01380     }
01381     // HEX-15
01382     for( unsigned i = 0; i < 7; ++i )
01383     {
01384         TopologyInfo::side_from_higher_order( HEXAHEDRON, 15, HEX15[i].idx, dim, num, err );
01385         CPPUNIT_ASSERT( !err );
01386         CPPUNIT_ASSERT_EQUAL( HEX15[i].dim, dim );
01387         CPPUNIT_ASSERT_EQUAL( HEX15[i].num, num );
01388     }
01389     // HEX-14
01390     for( unsigned i = 0; i < 6; ++i )
01391     {
01392         TopologyInfo::side_from_higher_order( HEXAHEDRON, 14, HEX14[i].idx, dim, num, err );
01393         CPPUNIT_ASSERT( !err );
01394         CPPUNIT_ASSERT_EQUAL( HEX14[i].dim, dim );
01395         CPPUNIT_ASSERT_EQUAL( HEX14[i].num, num );
01396     }
01397     // HEX-9
01398     for( unsigned i = 0; i < 1; ++i )
01399     {
01400         TopologyInfo::side_from_higher_order( HEXAHEDRON, 9, HEX9[i].idx, dim, num, err );
01401         CPPUNIT_ASSERT( !err );
01402         CPPUNIT_ASSERT_EQUAL( HEX9[i].dim, dim );
01403         CPPUNIT_ASSERT_EQUAL( HEX9[i].num, num );
01404     }
01405 }
01406
01407 void TopologyInfoTest::find_edge()
01408 {
01409     MsqPrintError err( std::cerr );
01410     bool reversed;
01411
01412     EntityTopology types[]   = { TRIANGLE, QUADRILATERAL, TETRAHEDRON, HEXAHEDRON, PRISM, PYRAMID };
01413     const unsigned num_types = sizeof( types ) / sizeof( types[0] );
01414     unsigned idx;
01415     for( unsigned t = 0; t < num_types; ++t )
01416     {
01417         const EntityTopology type = types[t];
01418
01419         for( unsigned e = 0; e < TopologyInfo::edges( type ); ++e )
01420         {
01421
01422             const unsigned* const v = TopologyInfo::edge_vertices( type, e, err );
01423             CPPUNIT_ASSERT( !err );
01424             idx = TopologyInfo::find_edge( type, v, reversed, err );
01425             CPPUNIT_ASSERT( !err );
01426             CPPUNIT_ASSERT_EQUAL( e, idx );
01427             CPPUNIT_ASSERT( !reversed );
01428
01429             const unsigned switched[2] = { v[1], v[0] };
01430             idx                        = TopologyInfo::find_edge( type, switched, reversed, err );
01431             CPPUNIT_ASSERT( !err );
01432             CPPUNIT_ASSERT_EQUAL( e, idx );
01433             CPPUNIT_ASSERT( reversed );
01434         }
01435     }
01436 }
01437
01438 static void shift( const unsigned* in, unsigned* out, unsigned size, unsigned offset )
01439 {
01440     for( unsigned i = 0; i < size; ++i )
01441         out[i] = in[( i + offset ) % size];
01442 }
01443
01444 static void reverse( const unsigned* in, unsigned* out, unsigned size, unsigned offset )
01445 {
01446     for( unsigned i = 0; i < size; ++i )
01447         out[i] = in[( offset + size - i - 1 ) % size];
01448 }
01449
01450 void TopologyInfoTest::find_face()
01451 {
01452     MsqPrintError err( std::cerr );
01453     bool reversed;
01454     unsigned switched[4], idx;
01455
01456     EntityTopology types[]   = { TETRAHEDRON, HEXAHEDRON, PRISM, PYRAMID };
01457     const unsigned num_types = sizeof( types ) / sizeof( types[0] );
01458     for( unsigned t = 0; t < num_types; ++t )
01459     {
01460         const EntityTopology type = types[t];
01461
01462         for( unsigned f = 0; f < TopologyInfo::faces( type ); ++f )
01463         {
01464
01465             unsigned n;
01466             const unsigned* const v = TopologyInfo::face_vertices( type, f, n, err );
01467             CPPUNIT_ASSERT( !err );
01468             CPPUNIT_ASSERT( n == 3 || n == 4 );
01469
01470             idx = TopologyInfo::find_face( type, v, n, reversed, err );
01471             CPPUNIT_ASSERT( !err );
01472             CPPUNIT_ASSERT_EQUAL( f, idx );
01473             CPPUNIT_ASSERT( !reversed );
01474
01475             // advance by 1 and try again
01476             shift( v, switched, n, 1 );
01477             idx = TopologyInfo::find_face( type, switched, n, reversed, err );
01478             CPPUNIT_ASSERT( !err );
01479             CPPUNIT_ASSERT_EQUAL( f, idx );
01480             CPPUNIT_ASSERT( !reversed );
01481
01482             // advance by 2 and try again
01483             shift( v, switched, n, 2 );
01484             idx = TopologyInfo::find_face( type, switched, n, reversed, err );
01485             CPPUNIT_ASSERT( !err );
01486             CPPUNIT_ASSERT_EQUAL( f, idx );
01487             CPPUNIT_ASSERT( !reversed );
01488
01489             // advance by 3 and try again
01490             shift( v, switched, n, 3 );
01491             idx = TopologyInfo::find_face( type, switched, n, reversed, err );
01492             CPPUNIT_ASSERT( !err );
01493             CPPUNIT_ASSERT_EQUAL( f, idx );
01494             CPPUNIT_ASSERT( !reversed );
01495
01496             // reverse and try again
01497             reverse( v, switched, n, 0 );
01498             idx = TopologyInfo::find_face( type, switched, n, reversed, err );
01499             CPPUNIT_ASSERT( !err );
01500             CPPUNIT_ASSERT_EQUAL( f, idx );
01501             CPPUNIT_ASSERT( reversed );
01502
01503             // reverse, advance by 1 and try again
01504             reverse( v, switched, n, 1 );
01505             idx = TopologyInfo::find_face( type, switched, n, reversed, err );
01506             CPPUNIT_ASSERT( !err );
01507             CPPUNIT_ASSERT_EQUAL( f, idx );
01508             CPPUNIT_ASSERT( reversed );
01509
01510             // reverse, advance by 2 and try again
01511             reverse( v, switched, n, 2 );
01512             idx = TopologyInfo::find_face( type, switched, n, reversed, err );
01513             CPPUNIT_ASSERT( !err );
01514             CPPUNIT_ASSERT_EQUAL( f, idx );
01515             CPPUNIT_ASSERT( reversed );
01516
01517             // reverse, advance by 3 and try again
01518             reverse( v, switched, n, 3 );
01519             idx = TopologyInfo::find_face( type, switched, n, reversed, err );
01520             CPPUNIT_ASSERT( !err );
01521             CPPUNIT_ASSERT_EQUAL( f, idx );
01522             CPPUNIT_ASSERT( reversed );
01523         }
01524     }
01525 }
01526
01527 void TopologyInfoTest::find_side()
01528 {
01529     MsqPrintError err( std::cerr );
01530     bool reversed;
01531     unsigned i, dim, switched[4];
01532
01533     EntityTopology types[]   = { TRIANGLE, QUADRILATERAL, TETRAHEDRON, HEXAHEDRON, PRISM, PYRAMID };
01534     const unsigned num_types = sizeof( types ) / sizeof( types[0] );
01535     for( unsigned t = 0; t < num_types; ++t )
01536     {
01537         const EntityTopology type = types[t];
01538
01539         for( unsigned e = 0; e < TopologyInfo::edges( type ); ++e )
01540         {
01541
01542             const unsigned* const v = TopologyInfo::edge_vertices( type, e, err );
01543             CPPUNIT_ASSERT( !err );
01544             TopologyInfo::find_side( type, v, 2, dim, i, reversed, err );
01545             CPPUNIT_ASSERT( !err );
01546             CPPUNIT_ASSERT_EQUAL( e, i );
01547             CPPUNIT_ASSERT_EQUAL( 1u, dim );
01548             CPPUNIT_ASSERT( !reversed );
01549
01550             switched[0] = v[1];
01551             switched[1] = v[0];
01552             TopologyInfo::find_side( type, switched, 2, dim, i, reversed, err );
01553             CPPUNIT_ASSERT( !err );
01554             CPPUNIT_ASSERT_EQUAL( e, i );
01555             CPPUNIT_ASSERT_EQUAL( 1u, dim );
01556             CPPUNIT_ASSERT( reversed );
01557         }
01558     }
01559
01560     for( unsigned t = 2; t < num_types; ++t )
01561     {
01562         const EntityTopology type = types[t];
01563
01564         for( unsigned f = 0; f < TopologyInfo::faces( type ); ++f )
01565         {
01566
01567             unsigned n;
01568             const unsigned* const v = TopologyInfo::face_vertices( type, f, n, err );
01569             CPPUNIT_ASSERT( !err );
01570             CPPUNIT_ASSERT( n == 3 || n == 4 );
01571
01572             TopologyInfo::find_side( type, v, n, dim, i, reversed, err );
01573             CPPUNIT_ASSERT( !err );
01574             CPPUNIT_ASSERT_EQUAL( f, i );
01575             CPPUNIT_ASSERT_EQUAL( 2u, dim );
01576             CPPUNIT_ASSERT( !reversed );
01577
01578             // reverse and try again
01579             reverse( v, switched, n, 0 );
01580             TopologyInfo::find_side( type, switched, n, dim, i, reversed, err );
01581             CPPUNIT_ASSERT( !err );
01582             CPPUNIT_ASSERT_EQUAL( f, i );
01583             CPPUNIT_ASSERT_EQUAL( 2u, dim );
01584             CPPUNIT_ASSERT( reversed );
01585         }
01586     }
01587 }
01588
01589 void TopologyInfoTest::compare_sides()
01590 {
01591     // define two hexes sharing a face:
01592     //    6-------7-------8
01593     //   /|      /|      /|
01594     //  0-------1-------2 |
01595     //  | |     | |     | |
01596     //  | 9-----|-10----|-11
01597     //  |/      |/      |/
01598     //  3-------4-------5
01599
01600     const size_t hex1[] = { 3, 4, 10, 9, 0, 1, 7, 6 };
01601     const size_t hex2[] = { 4, 5, 11, 10, 1, 2, 8, 7 };
01602     // shared edges: { hex1_edge, hex2_edge }
01603     const unsigned edges[][2] = { { 1, 3 }, { 5, 4 }, { 6, 7 }, { 9, 11 } };
01604     const unsigned num_edges  = sizeof( edges ) / sizeof( edges[0] );
01605     // shared faces: { hex1_face, hex2_face }
01606     const unsigned faces[][2] = { { 1, 3 } };
01607     const unsigned num_faces  = sizeof( faces ) / sizeof( faces[0] );
01608
01609     MsqPrintError err( std::cerr );
01610
01611     // try every possible edge combination
01612     for( unsigned e1 = 0; e1 < 12; ++e1 )
01613     {
01614         unsigned match;
01615         for( match = 0; match < num_edges; ++match )
01616             if( edges[match][0] == e1 ) break;
01617
01618         for( unsigned e2 = 0; e2 < 12; ++e2 )
01619         {
01620             const bool expected = ( match < num_edges ) && ( edges[match][1] == e2 );
01621
01622             const bool result = TopologyInfo::compare_sides( hex1, HEXAHEDRON, e1, hex2, HEXAHEDRON, e2, 1, err );
01623
01624             CPPUNIT_ASSERT( !err );
01625             CPPUNIT_ASSERT_EQUAL( expected, result );
01626         }
01627     }
01628
01629     // try every possible face combination
01630     for( unsigned f1 = 0; f1 < 6; ++f1 )
01631     {
01632         unsigned match;
01633         for( match = 0; match < num_faces; ++match )
01634             if( faces[match][0] == f1 ) break;
01635
01636         for( unsigned f2 = 0; f2 < 6; ++f2 )
01637         {
01638             const bool expected = ( match < num_faces ) && ( faces[match][1] == f2 );
01639
01640             const bool result = TopologyInfo::compare_sides( hex1, HEXAHEDRON, f1, hex2, HEXAHEDRON, f2, 2, err );
01641
01642             CPPUNIT_ASSERT( !err );
01643             CPPUNIT_ASSERT_EQUAL( expected, result );
01644         }
01645     }
01646 }
