Tqdcfr.cpp File Reference
#include "Tqdcfr.hpp"
#include "moab/Core.hpp"
#include "moab/Range.hpp"
#include "moab/FileOptions.hpp"
#include <iostream>
#include <string>
#include "moab/ReadUtilIface.hpp"
#include "SequenceManager.hpp"
#include "moab/GeomTopoTool.hpp"
#include "MBTagConventions.hpp"
#include "moab/CN.hpp"
#include "Internals.hpp"
#include "moab/HigherOrderFactory.hpp"
#include "exodus_order.h"
#include <sstream>
#include <cassert>
#include <cstring>
+ Include dependency graph for Tqdcfr.cpp:
Namespaces
namespace  moab
Class representing axis-aligned bounding box.
Defines
#define RR   if( MB_SUCCESS != result ) return result
#define IO_ASSERT(C)   INT_IO_ERROR( C, __LINE__ )
#define MAX(a, b)   ( ( a ) > ( b ) ? ( a ) : ( b ) )
#define MIN(a, b)   ( ( a ) < ( b ) ? ( a ) : ( b ) )
#define REC   records[current_record]
Functions
static void moab::INT_IO_ERROR (bool condition, unsigned line)
static void moab::swap8_voff (long *data)
static void moab::swap4_uint (unsigned int *data)
Variables
static int moab::major = -1
static int moab::minor = -1
const int *const *const *const moab::cub_elem_order_map = exodus_elem_order_map
const char *const moab::BLOCK_NODESET_OFFSET_TAG_NAME = "BLOCK_NODESET_OFFSET"
const char *const moab::BLOCK_SIDESET_OFFSET_TAG_NAME = "BLOCK_SIDESET_OFFSET"
Define Documentation
#define IO_ASSERT (   C)    INT_IO_ERROR( C, __LINE__ )
#define MAX (   a,
#define MIN (   a,
Definition at line 106 of file Tqdcfr.cpp.
Referenced by moab::Tqdcfr::load_file(), and moab::Tqdcfr::read_nodes().
