V_WedgeMetric.cpp File Reference
#include "moab/verdict.h"
#include "VerdictVector.hpp"
#include <memory.h>
+ Include dependency graph for V_WedgeMetric.cpp:
Defines
#define VERDICT_EXPORTS
Functions
C_FUNC_DEF double v_wedge_volume (int num_nodes, double coordinates[][3])
 Calculates wedge volume.
C_FUNC_DEF void v_wedge_quality (int num_nodes, double coordinates[][3], unsigned int metrics_request_flag, WedgeMetricVals *metric_vals)
 Calculates quality metrics for wedge elements.
Define Documentation
Definition at line 23 of file V_WedgeMetric.cpp.
Function Documentation
C_FUNC_DEF void v_wedge_quality ( int  num_nodes,
WedgeMetricVals metric_vals
Definition at line 102 of file V_WedgeMetric.cpp.
References V_WEDGE_VOLUME, v_wedge_volume(), and WedgeMetricVals::volume.
    memset( metric_vals, 0, sizeof( WedgeMetricVals ) );
    if( metrics_request_flag & V_WEDGE_VOLUME ) metric_vals->volume = v_wedge_volume( num_nodes, coordinates );
C_FUNC_DEF double v_wedge_volume ( int  num_nodes,
calculate the volume of a wedge
this is done by dividing the wedge into 3 tets and summing the volume of each tet
Definition at line 54 of file V_WedgeMetric.cpp.
References VerdictVector::set().
Referenced by moab::VerdictWrapper::all_quality_measures(), moab::VerdictWrapper::quality_measure(), and v_wedge_quality().
    double volume = 0;
    VerdictVector side1, side2, side3;
    if( num_nodes == 6 )
        // divide the wedge into 3 tets and calculate each volume
        side1.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
                   coordinates[1][2] - coordinates[0][2] );
        side2.set( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1],
                   coordinates[2][2] - coordinates[0][2] );
        side3.set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1],
                   coordinates[3][2] - coordinates[0][2] );
        volume = side3 % ( side1 * side2 ) / 6;
        side1.set( coordinates[4][0] - coordinates[1][0], coordinates[4][1] - coordinates[1][1],
                   coordinates[4][2] - coordinates[1][2] );
        side2.set( coordinates[5][0] - coordinates[1][0], coordinates[5][1] - coordinates[1][1],
                   coordinates[5][2] - coordinates[1][2] );
        side3.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1],
                   coordinates[3][2] - coordinates[1][2] );
        volume += side3 % ( side1 * side2 ) / 6;
        side1.set( coordinates[5][0] - coordinates[1][0], coordinates[5][1] - coordinates[1][1],
        side2.set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1],
                   coordinates[2][2] - coordinates[1][2] );
    return (double)volume;
