V_WedgeMetric.cpp
00001 /*=========================================================================
00002
00003   Module:    $RCSfile: V_WedgeMetric.cpp,v $
00004
00005   Copyright (c) 2006 Sandia Corporation.
00006   All rights reserved.
00007   See Copyright.txt or http://www.kitware.com/Copyright.htm for details.
00008
00009      This software is distributed WITHOUT ANY WARRANTY; without even
00010      the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
00011      PURPOSE.  See the above copyright notice for more information.
00012
00013 =========================================================================*/
00014
00015 /*
00016  *
00017  * WedgeMetric.cpp contains quality calculations for wedges
00018  *
00019  * This file is part of VERDICT
00020  *
00021  */
00022
00023 #define VERDICT_EXPORTS
00024
00025 #include "moab/verdict.h"
00026 #include "VerdictVector.hpp"
00027 #include <memory.h>
00028
00029 /*
00030   the wedge element
00031
00032
00033         5
00034         ^
00035        / \
00036       / | \
00037      / /2\ \
00038    6/_______\4
00039     | /   \ |
00040     |/_____\|
00041    3         1
00042
00043 */
00044
00045 /*!
00046
00047   calculate the volume of a wedge
00048
00049   this is done by dividing the wedge into 3 tets
00050   and summing the volume of each tet
00051
00052 */
00053
00054 C_FUNC_DEF double v_wedge_volume( int num_nodes, double coordinates[][3] )
00055 {
00056
00057     double volume = 0;
00058     VerdictVector side1, side2, side3;
00059
00060     if( num_nodes == 6 )
00061     {
00062
00063         // divide the wedge into 3 tets and calculate each volume
00064
00065         side1.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1],
00066                    coordinates[1][2] - coordinates[0][2] );
00067
00068         side2.set( coordinates[2][0] - coordinates[0][0], coordinates[2][1] - coordinates[0][1],
00069                    coordinates[2][2] - coordinates[0][2] );
00070
00071         side3.set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1],
00072                    coordinates[3][2] - coordinates[0][2] );
00073
00074         volume = side3 % ( side1 * side2 ) / 6;
00075
00076         side1.set( coordinates[4][0] - coordinates[1][0], coordinates[4][1] - coordinates[1][1],
00077                    coordinates[4][2] - coordinates[1][2] );
00078
00079         side2.set( coordinates[5][0] - coordinates[1][0], coordinates[5][1] - coordinates[1][1],
00080                    coordinates[5][2] - coordinates[1][2] );
00081
00082         side3.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1],
00083                    coordinates[3][2] - coordinates[1][2] );
00084
00085         volume += side3 % ( side1 * side2 ) / 6;
00086
00087         side1.set( coordinates[5][0] - coordinates[1][0], coordinates[5][1] - coordinates[1][1],
00088                    coordinates[5][2] - coordinates[1][2] );
00089
00090         side2.set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1],
00091                    coordinates[2][2] - coordinates[1][2] );
00092
00093         side3.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1],
00094                    coordinates[3][2] - coordinates[1][2] );
00095
00096         volume += side3 % ( side1 * side2 ) / 6;
00097     }
00098
00099     return (double)volume;
00100 }
00101
00102 C_FUNC_DEF void v_wedge_quality( int num_nodes,
00103                                  double coordinates[][3],
00104                                  unsigned int metrics_request_flag,
00105                                  WedgeMetricVals* metric_vals )
00106 {
00107     memset( metric_vals, 0, sizeof( WedgeMetricVals ) );
00108
00109     if( metrics_request_flag & V_WEDGE_VOLUME ) metric_vals->volume = v_wedge_volume( num_nodes, coordinates );
00110 }
