WriteDamsel.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : WriteDamsel.hpp
00003 //
00004 // Purpose       : ExodusII writer
00005 //
00006 // Special Notes : Lots of code taken from verde implementation
00007 //
00008 // Creator       : Corey Ernst
00009 //
00010 // Date          : 8/02
00011 //
00012 // Owner         : Corey Ernst
00013 //-------------------------------------------------------------------------
00014
00015 #ifndef WRITEDAMSEL_HPP
00016 #define WRITEDAMSEL_HPP
00017
00018 #ifndef IS_BUILDING_MB
00019 #error "WriteDamsel.hpp isn't supposed to be included into an application"
00020 #endif
00021
00022 #include <vector>
00023 #include <string>
00024
00025 #include "moab/Interface.hpp"
00026 #include "moab/Range.hpp"
00027 #include "moab/WriterIface.hpp"
00028 #include "RangeSeqIntersectIter.hpp"
00029 #include "moab/FileOptions.hpp"
00030 #include "DamselUtil.hpp"
00031
00032 #include "damsel.h"
00033
00034 namespace moab
00035 {
00036
00037 class WriteUtilIface;
00038 class SequenceManager;
00039 class Error;
00040
00041 class WriteDamsel : public WriterIface
00042 {
00043   public:
00044     //! Factory function, for ReaderWriter
00045     static WriterIface* factory( Interface* iface );
00046
00047     //! Constructor
00048     WriteDamsel( Interface* impl );
00049
00050     //! Destructor
00051     virtual ~WriteDamsel();
00052
00053     //! Primary interface function
00054     //! \param file_name Filename being written
00055     //! \param overwrite If true and the file exists, an error is returned
00056     //! \param opts File options, e.g. whether and how to write in parallel
00057     //! \param meshset_list If non-NULL, a vector of sets defining what is to be written
00058     //! \param num_sets The number of sets to be written, only used if meshset_list is non-NULL
00059     //! \param qa_records Strings defining provenance information
00060     //! \param tag_list If non-NULL, only these tags should be written
00061     //! \param num_tags The number of tag handles in tag_list, used only if tag_list is non-NULL
00062     //! \param requested_output_dimension Dimension used for coordinates
00063     ErrorCode write_file( const char* file_name,
00064                           const bool /* overwrite */,
00065                           const FileOptions& opts,
00066                           const EntityHandle* meshset_list,
00067                           const int num_sets,
00068                           const std::vector< std::string >& /* qa_records */,
00069                           const Tag* /* tag_list */            = NULL,
00070                           int /* num_tags */                   = 0,
00071                           int /* requested_output_dimension */ = 3 );
00072
00073     enum
00074     {
00075         DAMSEL_IS_TRACKING = 0x1
00076     } DAMSEL_FLAGS;
00077
00078   private:
00079     //! Initialize global information about dense/sparse/conventional tags, once for entire
00080     //! write_file call
00081     ErrorCode init_tag_info();
00082
00083     //! Write a subrange of entities/sets; just a wrapper to write_[vertices, entities, sets]
00084     ErrorCode write_subrange( RangeSeqIntersectIter& rsi );
00085
00086     //! Write the vertices in the model, for the handles in the specified RangeSeqIntersectIter
00087     //! \param rsi Range sequence iterator defining range of entities/sets to be written
00088     ErrorCode write_vertices( RangeSeqIntersectIter& rsi );
00089
00090     //! Write the entities in the model, for the handles in the specified RangeSeqIntersectIter
00091     //! \param rsi Range sequence iterator defining range of entities/sets to be written
00092     ErrorCode write_entities( RangeSeqIntersectIter& rsi );
00093
00094     //! Write the sets in the model, for the handles in the specified RangeSeqIntersectIter
00095     //! \param rsi Range sequence iterator defining range of entities/sets to be written
00096     ErrorCode write_sets( RangeSeqIntersectIter& rsi );
00097
00098     //! Map dense tags for the specified entities, using the specified damsel entity container
00099     ErrorCode map_dense_tags( RangeSeqIntersectIter& rsi, damsel_container& ent_cont );
00100
00101     //! Map sparse tags for all entities
00102     ErrorCode map_sparse_tags();
00103
00104     //! Interface instance
00105     Interface* mbImpl;
00106
00107     //! WriteUtil object used in this writer
00108     WriteUtilIface* mWriteIface;
00109
00110     //! Used to initialize the RangeSeqIntersectIter
00111     SequenceManager* sequenceManager;
00112
00113     //! File name
00114     std::string fileName;
00115
00116     //! Utility for storing damsel-specific stuff
00117     DamselUtil dU;
00118 };
00119
00120 inline ErrorCode WriteDamsel::write_subrange( RangeSeqIntersectIter& rsi )
00121 {
00122     ErrorCode rval = MB_SUCCESS;
00123
00124     if( MBVERTEX == mbImpl->type_from_handle( rsi.get_start_handle() ) )
00125         rval = write_vertices( rsi );
00126     else if( MBENTITYSET > mbImpl->type_from_handle( rsi.get_start_handle() ) )
00127         rval = write_entities( rsi );
00128     // else
00129     //  rval = write_sets(rsi);
00130
00131     return rval;
00132 }
00133
00134 }  // namespace moab
00135
00136 #endif
