WriteGMV.hpp
00001 /**
00002  * MOAB, a Mesh-Oriented datABase, is a software component for creating,
00003  * storing and accessing finite element mesh data.
00004  *
00005  * Copyright 2004 Sandia Corporation.  Under the terms of Contract
00006  * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government
00007  * retains certain rights in this software.
00008  *
00009  * This library is free software; you can redistribute it and/or
00010  * modify it under the terms of the GNU Lesser General Public
00011  * License as published by the Free Software Foundation; either
00012  * version 2.1 of the License, or (at your option) any later version.
00013  *
00014  */
00015
00016 //-------------------------------------------------------------------------
00017 // Filename      : WriteGMV.hpp
00018 //
00019 // Purpose       : Writer template
00020 //
00021 // Special Notes :
00022 //
00023 // Creator       : Tim Tautges
00024 //
00025 // Date          : 2/04
00026 //
00027 //-------------------------------------------------------------------------
00028
00029 #ifndef WRITEGMV_HPP
00030 #define WRITEGMV_HPP
00031
00032 #include "moab/Forward.hpp"
00033 #include "moab/WriterIface.hpp"
00034
00035 namespace moab
00036 {
00037
00038 class WriteUtilIface;
00039
00040 //! Output Exodus File for VERDE
00041 class WriteGMV : public WriterIface
00042 {
00043
00044   public:
00045     //! Constructor
00046     WriteGMV( Interface* impl );
00047
00048     //! Destructor
00049     virtual ~WriteGMV();
00050
00051     static WriterIface* factory( Interface* );
00052
00053     ErrorCode write_file( const char* filename,
00054                           const bool overwite,
00055                           const FileOptions& opts,
00056                           const EntityHandle* output_sets,
00057                           const int num_output_sets,
00058                           const std::vector< std::string >& qa_list,
00059                           const Tag* tag_list     = NULL,
00060                           int num_tags            = 0,
00061                           int requested_dimension = 3 );
00062
00063     //! writes out a mesh file
00064     ErrorCode write_file( const char* file_name,
00065                           const EntityHandle output_set,
00066                           const int user_dimension = 3,
00067                           const bool mesh          = true,
00068                           const bool poly_mesh     = true );
00069
00070   protected:
00071   private:
00072     //! interface instance
00073     Interface* mbImpl;
00074     WriteUtilIface* mWriteIface;
00075
00076     //! Cached tags for reading.  Note that all these tags are defined when the
00077     //! core is initialized.
00078     Tag mMaterialSetTag;
00079     Tag mDirichletSetTag;
00080     Tag mNeumannSetTag;
00081     Tag mHasMidNodesTag;
00082     Tag mGeomDimensionTag;
00083     Tag mGlobalIdTag;
00084
00085     static const char* gmvTypeNames[MBMAXTYPE];
00086
00087     ErrorCode local_write_mesh( const char* file_name,
00088                                 const EntityHandle output_set,
00089                                 const int user_dimension,
00090                                 const bool mesh,
00091                                 const bool poly_mesh );
00092 };
00093
00094 }  // namespace moab
00095
00096 #endif
