ZoltanPartitioner.hpp File Reference
#include <cstdlib>
#include "moab/PartitionerBase.hpp"
#include "zoltan_cpp.h"
#include <ctime>
#include <vector>
+ Include dependency graph for ZoltanPartitioner.hpp:
+ This graph shows which files directly or indirectly include this file:
Classes
class  ZoltanPartitioner
Namespaces
namespace  moab
Class representing axis-aligned bounding box.
Functions
int mbGetNumberOfAssignedObjects (void *userDefinedData, int *err)
void mbGetObjectList (void *userDefinedData, int numGlobalIds, int numLids, ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int wgt_dim, float *obj_wgts, int *err)
int mbGetObjectSize (void *userDefinedData, int *err)
void mbGetObject (void *userDefinedData, int numGlobalIds, int numLids, int numObjs, ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int numDim, double *pts, int *err)
void mbGetNumberOfEdges (void *userDefinedData, int numGlobalIds, int numLids, int numObjs, ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int *numEdges, int *err)
void mbGetEdgeList (void *userDefinedData, int numGlobalIds, int numLids, int numObjs, ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int *numEdges, ZOLTAN_ID_PTR nborGlobalIds, int *nborProcs, int wgt_dim, float *edge_wgts, int *err)
void mbGetPart (void *userDefinedData, int numGlobalIds, int numLids, int numObjs, ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int *part, int *err)
void mbShowError (int val, const char *s, int me)
void mbPrintGlobalResult (const char *s, int begin, int import, int exp, int change)
Function Documentation
void mbGetEdgeList ( void *  userDefinedData,
int  numGlobalIds,
int  numLids,
int  numObjs,
ZOLTAN_ID_PTR  gids,
ZOLTAN_ID_PTR  lids,
int *  numEdges,
int *  nborProcs,
int  wgt_dim,
float *  edge_wgts,
int *  err
Definition at line 2204 of file ZoltanPartitioner.cpp.
References EdgeWeights, NborGlobalId, NborProcs, NumEdges, and NumPoints.
Referenced by ZoltanPartitioner::balance_mesh(), ZoltanPartitioner::partition_mesh_and_geometry(), ZoltanPartitioner::partition_owned_cells(), and ZoltanPartitioner::repartition().
    int i, id, idSum, j;
    int next = 0;
    for( i = 0; i < numObjs; i++ )
        id = lids[i];
        if( ( id < 0 ) || ( id >= NumPoints ) )
            *err = 1;
            return;
        idSum = 0;
        for( j = 0; j < id; j++ )
            idSum += NumEdges[j];
        for( j = 0; j < NumEdges[id]; j++ )
            nborGlobalIds[next] = NborGlobalId[idSum];
            nborProcs[next]     = NborProcs[idSum];
            if( wgt_dim > 0 ) edge_wgts[next] = EdgeWeights[idSum];
            next++;
            idSum++;
int mbGetNumberOfAssignedObjects ( void *  userDefinedData,
int *  err
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version. Zoltan: class to get a mesh from MOAB and write a Zoltan partition set for that mesh back into MOAB and to a file
Definition at line 2110 of file ZoltanPartitioner.cpp.
References NumPoints.
    *err = 0;
    return NumPoints;
void mbGetNumberOfEdges ( void *  userDefinedData,
int  numGlobalIds,
int  numLids,
int  numObjs,
ZOLTAN_ID_PTR  gids,
ZOLTAN_ID_PTR  lids,
int *  numEdges,
int *  err
Definition at line 2178 of file ZoltanPartitioner.cpp.
References NumEdges, and NumPoints.
    int i, id;
    int next = 0;
        id = lids[i];
            *err = 1;
            return;
        numEdges[next++] = NumEdges[id];
void mbGetObject ( void *  userDefinedData,
int  numGlobalIds,
int  numLids,
int  numObjs,
ZOLTAN_ID_PTR  gids,
ZOLTAN_ID_PTR  lids,
int  numDim,
double *  pts,
int *  err
Definition at line 2141 of file ZoltanPartitioner.cpp.
References NumPoints, and Points.
    int i, id, id3;
    int next = 0;
    if( numDim != 3 )
        *err = 1;
        return;
        id = lids[i];
            *err = 1;
            return;
        id3 = lids[i] * 3;
        pts[next++] = Points[id3];
        pts[next++] = Points[id3 + 1];
        pts[next++] = Points[id3 + 2];
void mbGetObjectList ( void *  userDefinedData,
int  numGlobalIds,
int  numLids,
ZOLTAN_ID_PTR  gids,
ZOLTAN_ID_PTR  lids,
int  wgt_dim,
float *  obj_wgts,
int *  err
Definition at line 2116 of file ZoltanPartitioner.cpp.
References GlobalIds, NumPoints, and ObjWeights.
    for( int i = 0; i < NumPoints; i++ )
        gids[i] = GlobalIds[i];
        lids[i] = i;
        if( wgt_dim > 0 ) obj_wgts[i] = ObjWeights[i];
    *err = 0;
int mbGetObjectSize ( void *  userDefinedData,
int *  err
void mbGetPart ( void *  userDefinedData,
int  numGlobalIds,
int  numLids,
int  numObjs,
ZOLTAN_ID_PTR  gids,
ZOLTAN_ID_PTR  lids,
int *  part,
int *  err
Definition at line 2246 of file ZoltanPartitioner.cpp.
References NumPoints, and Parts.
Referenced by ZoltanPartitioner::partition_mesh_and_geometry().
    int i, id;
    int next = 0;
        id = lids[i];
            *err = 1;
            return;
        part[next++] = Parts[id];
void mbPrintGlobalResult ( const char *  s,
int  begin,
int  import,
int  exp,
int  change
void mbShowError ( int  val,
const char *  s,
int  me
