addncdata.cpp
00001 /*
00002  * addncdata.cpp
00003  * this tool will take an existing h5m file and add data from an nc type file
00004  * will support mainly showing the data associated with unstructured meshes (Homme, MPAS) with Visit
00005  *
00006  * example of usage:
00007  * ./mbaddnc -i wholeFineATM.h5m -n surfdata_ne11np4_simyr1850_c160614.nc -o
00008  * whole_LONGXY_surfdata.h5m -v LONGXY
00009  *
00010  * Basically, will output a new h5m file (whole_LONGXY_surfdata.h5m), which has an extra tag,
00011  * corresponding to the variable LONGXY from the file surfdata_ne11np4_simyr1850_c160614.nc;
00012  * matching is based on the global ids between what we think is the order on the original file
00013  * (wholeFineATM.h5m) and the order of surfdata_ne11np4_simyr1850_c160614.nc
00014  *
00015  *  file  wholeFineATM.h5m is obtained from a coupled run in e3sm, with the ne 11, np 4,
00016  *
00017  *  add an option to output the nc data to the original coarse ATM file, the one that also has the
00018  * GLOBAL_DOFS tag with the global DOFs of the GLL points
00019  */
00020
00021 #include "moab/ProgOptions.hpp"
00022 #include "moab/Core.hpp"
00023
00024 #include "netcdf.h"
00025 #include <cmath>
00026 #include <sstream>
00027
00028 using namespace moab;
00029
00030 // copy from ReadNCDF.cpp some useful macros for reading from a netcdf file (exodus?)
00031 // ncFile is an integer initialized when opening the nc file in read mode
00032
00033 int ncFile;
00034
00035 #define INS_ID( stringvar, prefix, id ) sprintf( stringvar, prefix, id )
00036
00037 #define GET_DIM( ncdim, name, val )                                                    \
00038     {        \
00039         int gdfail = nc_inq_dimid( ncFile, name, &( ncdim ) );                         \
00040         if( NC_NOERR == gdfail )                                                       \
00041         {        \
00042             size_t tmp_val;                                                            \
00043             gdfail = nc_inq_dimlen( ncFile, ncdim, &tmp_val );                         \
00044             if( NC_NOERR != gdfail )                                                   \
00045             {        \
00046                 MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get dimension length" ); \
00047             }        \
00048             else        \
00049                 ( val ) = tmp_val;                                                     \
00050         }        \
00051         else        \
00052             ( val ) = 0;                                                               \
00053     }
00054
00055 #define GET_DIMB( ncdim, name, varname, id, val ) \
00056     INS_ID( name, varname, id );                  \
00057     GET_DIM( ncdim, name, val );
00058
00059 #define GET_VAR( name, id, dims )        \
00060     {        \
00061         ( id )     = -1;        \
00062         int gvfail = nc_inq_varid( ncFile, name, &( id ) );                                      \
00063         if( NC_NOERR == gvfail )        \
00064         {        \
00065             int ndims;        \
00066             gvfail = nc_inq_varndims( ncFile, id, &ndims );                                      \
00067             if( NC_NOERR == gvfail )                                                             \
00068             {        \
00069                 ( dims ).resize( ndims );                                                        \
00070                 gvfail = nc_inq_vardimid( ncFile, id, &( dims )[0] );                            \
00071                 if( NC_NOERR != gvfail )                                                         \
00072                 {        \
00073                     MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get variable dimension IDs" ); \
00074                 }        \
00075             }        \
00076         }        \
00077     }
00078
00079 #define GET_1D_INT_VAR( name, id, vals )                                                       \
00080     {        \
00081         GET_VAR( name, id, vals );                                                             \
00082         if( -1 != ( id ) )        \
00083         {        \
00084             size_t ntmp;        \
00085             int ivfail = nc_inq_dimlen( ncFile, ( vals )[0], &ntmp );                          \
00086             if( NC_NOERR != ivfail )                                                           \
00087             {        \
00088                 MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get dimension length" );         \
00089             }        \
00090             ( vals ).resize( ntmp );                                                           \
00091             size_t ntmp1 = 0;        \
00092             ivfail       = nc_get_vara_int( ncFile, id, &ntmp1, &ntmp, &( vals )[0] );         \
00093             if( NC_NOERR != ivfail )                                                           \
00094             {        \
00095                 MB_SET_ERR( MB_FAILURE, "addncdata:: Problem getting variable " << ( name ) ); \
00096             }        \
00097         }        \
00098     }
00099
00100 #define GET_1D_DBL_VAR( name, id, vals )                                                       \
00101     {        \
00102         std::vector< int > dum_dims;                                                           \
00103         GET_VAR( name, id, dum_dims );                                                         \
00104         if( -1 != ( id ) )        \
00105         {        \
00106             size_t ntmp;        \
00107             int dvfail = nc_inq_dimlen( ncFile, dum_dims[0], &ntmp );                          \
00108             if( NC_NOERR != dvfail )                                                           \
00109             {        \
00110                 MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get dimension length" );         \
00111             }        \
00112             ( vals ).resize( ntmp );                                                           \
00113             size_t ntmp1 = 0;        \
00114             dvfail       = nc_get_vara_double( ncFile, id, &ntmp1, &ntmp, &( vals )[0] );      \
00115             if( NC_NOERR != dvfail )                                                           \
00116             {        \
00117                 MB_SET_ERR( MB_FAILURE, "addncdata:: Problem getting variable " << ( name ) ); \
00118             }        \
00119         }        \
00120     }
00121
00122 #define GET_1D_FLT_VAR( name, id, vals )                                                       \
00123     {        \
00124         std::vector< int > dum_dims;                                                           \
00125         GET_VAR( name, id, dum_dims );                                                         \
00126         if( -1 != ( id ) )        \
00127         {        \
00128             size_t ntmp;        \
00129             int dvfail = nc_inq_dimlen( ncFile, dum_dims[0], &ntmp );                          \
00130             if( NC_NOERR != dvfail )                                                           \
00131             {        \
00132                 MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get dimension length" );         \
00133             }        \
00134             ( vals ).resize( ntmp );                                                           \
00135             size_t ntmp1 = 0;        \
00136             dvfail       = nc_get_vara_float( ncFile, id, &ntmp1, &ntmp, &( vals )[0] );       \
00137             if( NC_NOERR != dvfail )                                                           \
00138             {        \
00139                 MB_SET_ERR( MB_FAILURE, "addncdata:: Problem getting variable " << ( name ) ); \
00140             }        \
00141         }        \
00142     }
00143
00144 int main( int argc, char* argv[] )
00145 {
00146     ErrorCode rval;
00147     ProgOptions opts;
00148
00149     std::string inputfile, outfile( "out.h5m" ), netcdfFile, variable_name, sefile_name;
00150
00151     opts.addOpt< std::string >( "input,i", "input mesh filename", &inputfile );
00152     opts.addOpt< std::string >( "netcdfFile,n", "netcdf file aligned with the mesh input file", &netcdfFile );
00153     opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile );
00154
00155     opts.addOpt< std::string >( "var,v", "variable to extract and add to output file", &variable_name );
00156
00157     opts.addOpt< std::string >( "sefile,s", "spectral elements file (coarse SE mesh)", &sefile_name );
00158     opts.parseCommandLine( argc, argv );
00159
00160     Core* mb = new Core();
00161
00162     rval = mb->load_file( inputfile.c_str() );MB_CHK_SET_ERR( rval, "can't load input file" );
00163
00164     std::cout << " opened " << inputfile << " with initial h5m data.\n";
00165     // open the netcdf file, and see if it has that variable we are looking for
00166
00167     Range nodes;
00168     rval = mb->get_entities_by_dimension( 0, 0, nodes );MB_CHK_SET_ERR( rval, "can't get nodes" );
00169
00170     Range edges;
00171     rval = mb->get_entities_by_dimension( 0, 1, edges );MB_CHK_SET_ERR( rval, "can't get edges" );
00172
00173     Range cells;
00174     rval = mb->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "can't get cells" );
00175
00176     std::cout << " it has " << nodes.size() << " vertices " << edges.size() << " edges " << cells.size() << " cells\n";
00177
00178     // construct maps between global id and handles
00179     std::map< int, EntityHandle > vGidHandle;
00180     std::map< int, EntityHandle > eGidHandle;
00181     std::map< int, EntityHandle > cGidHandle;
00182     std::vector< int > gids;
00183     Tag gid;
00184     rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_SET_ERR( rval, "can't get global id tag" );
00185     gids.resize( nodes.size() );
00186     rval = mb->tag_get_data( gid, nodes, &gids[0] );MB_CHK_SET_ERR( rval, "can't get global id on vertices" );
00187     int i = 0;
00188     for( Range::iterator vit = nodes.begin(); vit != nodes.end(); vit++ )
00189     {
00190         vGidHandle[gids[i++]] = *vit;
00191     }
00192
00193     gids.resize( edges.size() );
00194     rval = mb->tag_get_data( gid, edges, &gids[0] );MB_CHK_SET_ERR( rval, "can't get global id on edges" );
00195     i = 0;
00196     for( Range::iterator vit = edges.begin(); vit != edges.end(); vit++ )
00197     {
00198         eGidHandle[gids[i++]] = *vit;
00199     }
00200
00201     gids.resize( cells.size() );
00202     rval = mb->tag_get_data( gid, cells, &gids[0] );MB_CHK_SET_ERR( rval, "can't get global id on cells" );
00203     i = 0;
00204     for( Range::iterator vit = cells.begin(); vit != cells.end(); vit++ )
00205     {
00206         cGidHandle[gids[i++]] = *vit;
00207     }
00208
00209     // Open netcdf/exodus file
00210     int fail = nc_open( netcdfFile.c_str(), 0, &ncFile );
00211     if( NC_NOWRITE != fail )
00212     {
00213         MB_SET_ERR( MB_FILE_DOES_NOT_EXIST, "ReadNCDF:: problem opening Netcdf II file " << netcdfFile );
00214     }
00215
00216     std::cout << " opened " << netcdfFile << " with new data \n";
00217     std::vector< int > dims;
00218     int nc_var;
00219
00220     size_t recs;
00221     char recname[NC_MAX_NAME + 1];
00222
00223     std::cout << " looking for variable " << variable_name << "\n";
00224     GET_VAR( variable_name.c_str(), nc_var, dims );
00225     std::cout << " it has " << dims.size() << " dimensions\n";
00226
00227     int dimIndex     = -1;  // index of the dimension of interest
00228     bool vertex_data = false;
00229     bool cell_data   = false;
00230     for( size_t j = 0; j < dims.size(); j++ )
00231     {
00232         fail = nc_inq_dim( ncFile, dims[j], recname, &recs );
00233         if( NC_NOERR != fail ) MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get dimension" );
00234         std::string name_dim( recname );
00235         std::cout << " dimension index " << j << " in file: " << dims[j] << " name: " << name_dim << " recs:" << recs
00236                   << "\n";
00237         if( recs == nodes.size() )
00238         {
00239             dimIndex    = j;
00240             vertex_data = true;
00241         }
00242         if( recs == cells.size() )
00243         {
00244             dimIndex  = j;
00245             cell_data = true;
00246         }
00247     }
00248
00249     int otherDim    = 1 - dimIndex;  // used only if 2 dimensions ; could be 0 or 1;
00250     size_t size_tag = 1;             // good for one dimension
00251     std::vector< int > evals;        // size of size_tag
00252     std::vector< double > dvals;     // size of size_tag
00253     nc_type dataType;
00254
00255     // read the variable, and set it to the tag
00256     fail            = nc_inq_vartype( ncFile, nc_var, &dataType );
00257     if( NC_NOERR != fail ) MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get variable type" );
00258     DataType mbtype = MB_TYPE_DOUBLE;
00259     bool float_var  = false;
00260     if( NC_INT == dataType )
00261         mbtype = MB_TYPE_INTEGER;
00262     else if( NC_DOUBLE != dataType && NC_FLOAT != dataType )
00263         MB_CHK_SET_ERR( MB_FAILURE, "unknown type" );
00264
00265     if( NC_FLOAT == dataType ) float_var = true;
00266
00267     bool use_time = false;
00268     int time_id = -1;
00269     std::vector< float > times;
00270     fail        = nc_inq_varid( ncFile, "time", &time_id );
00271     if( NC_NOERR == fail )
00272     {
00273         use_time = true;
00274         int ii;
00275         GET_1D_FLT_VAR( "time", ii, times );
00276     }
00277     Tag newTag;
00278
00279     if( ( dims.size() >= 1 && dims.size() <= 2 ) && ( vertex_data || cell_data ) )
00280     {
00281
00282         if( dims.size() == 2 )
00283         {
00284             fail = nc_inq_dim( ncFile, dims[otherDim], recname, &size_tag );
00285             if( NC_NOERR != fail ) MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get dimension" );
00286         }
00287
00288         int def_val = 0;
00289         rval = mb->tag_get_handle( variable_name.c_str(), (int)size_tag, mbtype, newTag, MB_TAG_CREAT | MB_TAG_DENSE,
00290                                    &def_val );MB_CHK_SET_ERR( rval, "can't define new tag" );
00291
00292         if( NC_INT == dataType )
00293         {
00294             std::vector< int > vals;
00295             if( 1 == dims.size() )
00296             {
00297                 GET_1D_INT_VAR( variable_name.c_str(), dims[0], vals );
00298                 if( vertex_data )
00299                 {
00300                     for( size_t k = 0; k < vals.size(); k++ )
00301                     {
00302                         EntityHandle vh = vGidHandle[k + 1];
00303                         rval            = mb->tag_set_data( newTag, &vh, 1, &vals[k] );MB_CHK_SET_ERR( rval, "can't set tag on vertex" );
00304                     }
00305                 }
00306                 else  // cell_data
00307                 {
00308                     for( size_t k = 0; k < vals.size(); k++ )
00309                     {
00310                         EntityHandle ch = cGidHandle[k + 1];  // cell handle
00311                         rval            = mb->tag_set_data( newTag, &ch, 1, &vals[k] );MB_CHK_SET_ERR( rval, "can't set tag on cell" );
00312                     }
00313                 }
00314             }
00315             else  // dims.size() == 2
00316             {
00317                 // Single var for all coords
00318                 size_t start[2] = { 0, 0 }, count[2] = { 1, 1 };
00319                 count[dimIndex] = recs;
00320                 count[otherDim] = size_tag;
00321                 vals.resize( recs * size_tag );
00322                 fail = nc_get_vara_int( ncFile, nc_var, start, count, &vals[0] );
00323                 evals.resize( size_tag );
00324
00325                 if( vertex_data )
00326                 {
00327                     for( size_t k = 0; k < recs; k++ )
00328                     {
00329                         EntityHandle vh      = vGidHandle[k + 1];
00330                         size_t start_in_vals = k * size_tag, stride = 1;
00331                         for( size_t j = 0; j < size_tag; j++ )
00332                             evals[j] = vals[start_in_vals + j * stride];
00333                         rval = mb->tag_set_data( newTag, &vh, 1, &evals[0] );MB_CHK_SET_ERR( rval, "can't set tag on vertex" );
00334                     }
00335                 }
00336                 else  // cell_data
00337                 {
00338                     for( size_t k = 0; k < recs; k++ )
00339                     {
00340                         EntityHandle ch      = cGidHandle[k + 1];  // cell handle
00341                         size_t start_in_vals = k * size_tag, stride = 1;
00342                         for( size_t j = 0; j < size_tag; j++ )
00343                             evals[j] = vals[start_in_vals + j * stride];
00344                         rval = mb->tag_set_data( newTag, &ch, 1, &evals[0] );MB_CHK_SET_ERR( rval, "can't set tag on cell" );
00345                     }
00346                 }
00347             }
00348         }
00349         else
00350         {
00351             std::vector< double > vals;
00352             if( 1 == dims.size() )
00353             {
00354                 GET_1D_DBL_VAR( variable_name.c_str(), dims[0], vals );
00355                 if( vertex_data )
00356                 {
00357                     for( size_t k = 0; k < vals.size(); k++ )
00358                     {
00359                         EntityHandle vh = vGidHandle[k + 1];
00360                         rval            = mb->tag_set_data( newTag, &vh, 1, &vals[k] );MB_CHK_SET_ERR( rval, "can't set tag on vertex" );
00361                     }
00362                 }
00363                 else  // cell_data
00364                 {
00365                     for( size_t k = 0; k < vals.size(); k++ )
00366                     {
00367                         EntityHandle ch = cGidHandle[k + 1];  // cell handle
00368                         rval            = mb->tag_set_data( newTag, &ch, 1, &vals[k] );MB_CHK_SET_ERR( rval, "can't set tag on vertex" );
00369                     }
00370                 }
00371             }
00372             else  // dims.size() == 2
00373             {
00374                 // Single var for all coords
00375                 size_t start[2] = { 0, 0 }, count[2] = { 1, 1 };
00376                 count[dimIndex] = recs;
00377                 count[otherDim] = size_tag;
00378                 vals.resize( recs * size_tag );
00379                 fail = nc_get_vara_double( ncFile, nc_var, start, count, &vals[0] );
00380                 dvals.resize( size_tag );
00381
00382                 if( vertex_data )
00383                 {
00384                     for( size_t k = 0; k < recs; k++ )
00385                     {
00386                         EntityHandle vh      = vGidHandle[k + 1];
00387                         size_t start_in_vals = k * size_tag, stride = 1;
00388                         for( size_t j = 0; j < size_tag; j++ )
00389                             dvals[j] = vals[start_in_vals + j * stride];
00390                         rval = mb->tag_set_data( newTag, &vh, 1, &dvals[0] );MB_CHK_SET_ERR( rval, "can't set tag on vertex" );
00391                     }
00392                 }
00393                 else  // cell_data
00394                 {
00395                     for( size_t k = 0; k < recs; k++ )
00396                     {
00397                         EntityHandle ch      = cGidHandle[k + 1];  // cell handle
00398                         size_t start_in_vals = k * size_tag, stride = 1;
00399                         for( size_t j = 0; j < size_tag; j++ )
00400                             dvals[j] = vals[start_in_vals + j * stride];
00401                         rval = mb->tag_set_data( newTag, &ch, 1, &dvals[0] );MB_CHK_SET_ERR( rval, "can't set tag on cell" );
00402                     }
00403                 }
00404             }
00405         }
00406     }
00407     else if( ( dims.size() == 3 ) && vertex_data && dimIndex == 2 &&
00408              mbtype == MB_TYPE_DOUBLE && use_time)  // the last one is the vertex
00409     {
00410         // the case when the last dim is ncol (for homme type mesh))
00411         size_t dim0, dim1;  // dim 2 is ncol..
00412         char recname0[NC_MAX_NAME + 1], recname1[NC_MAX_NAME + 1];
00413         fail = nc_inq_dim( ncFile, dims[0], recname0, &dim0 );
00414         if( NC_NOERR != fail ) MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get dimension" );
00415         fail = nc_inq_dim( ncFile, dims[1], recname1, &dim1 );
00416         if( NC_NOERR != fail ) MB_SET_ERR( MB_FAILURE, "addncdata:: Couldn't get dimension" );
00417         std::string name0( recname0 );
00418         std::string name1( recname1 );
00419         std::string timestr( "time" );
00420         size_t start[3] = { 0, 0, 0 };
00421         size_t count[3] = { 1, 0, 0 };
00422         count[1]        = dim1;
00423         count[2]        = nodes.size();
00424         // create a few tags, with name inserted
00425         if( name0.compare( "time" ) == 0 )
00426         {
00427
00428             std::vector< double > dvalues( dim1 * count[2] );
00429             std::vector< float > fvalues( dim1 * count[2] );
00430             std::vector< double > transp( dim1 * count[2] );
00431             // get the variable time
00432             for( size_t k = 0; k < dim0; k++ )
00433             {
00434                 // create a tag for each time, and
00435                 std::stringstream tag_name;
00436                 tag_name << variable_name << "_t" << times[k];
00437                 std::vector< double > defvals( dim1, 0. );
00438                 rval = mb->tag_get_handle( tag_name.str().c_str(), (int)dim1, mbtype, newTag,
00439                                            MB_TAG_CREAT | MB_TAG_DENSE, &defvals[0] );MB_CHK_SET_ERR( rval, "can't define new tag" );
00440                 start[0] = k;
00441
00442                 if( float_var )
00443                 {
00444                     fail = nc_get_vara_float( ncFile, nc_var, start, count, &fvalues[0] );
00445                     // now arrange them in a tag, transpose data
00446                     for( size_t ii = 0; ii < dim1; ii++ )
00447                         for( size_t j = 0; j < count[2]; j++ )
00448                         {
00449                             transp[j * dim1 + ii] = fvalues[ii * count[2] + j];
00450                         }
00451                 }
00452                 else  // double
00453                 {
00454                     fail = nc_get_vara_double( ncFile, nc_var, start, count, &dvalues[0] );
00455                     // now arrange them in a tag, transpose data
00456                     for( size_t ii = 0; ii < dim1; ii++ )
00457                         for( size_t j = 0; j < count[2]; j++ )
00458                         {
00459                             transp[j * dim1 + ii] = dvalues[ii * count[2] + j];
00460                         }
00461                 }
00462                 for( size_t ii = 0; ii < nodes.size(); ii++ )
00463                 {
00464                     EntityHandle vh = vGidHandle[ii + 1];
00465                     rval            = mb->tag_set_data( newTag, &vh, 1, &transp[ii * dim1] );MB_CHK_SET_ERR( rval, "can't set tag on nodes" );
00466                 }
00467             }
00468         }
00469     }
00470     rval = mb->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "can't write file" );
00471     std::cout << " wrote file " << outfile << "\n";
00472
00473     // now, if s option, load the coarse mesh and put data on each element, according to a matrix
00474     if( !sefile_name.empty() )
00475     {
00476         // load the file, check for GLOBAL_DOFS tag, and create a new tag with the data associated
00477         Core* mb2 = new Core();
00478         rval      = mb2->load_file( sefile_name.c_str() );MB_CHK_SET_ERR( rval, "can't load spectral element file" );
00479         std::cout << " loaded spectral file " << sefile_name << "\n";
00480         // look for GLOBAL_DOFS tag
00481         Tag gdofeTag;
00482         rval = mb2->tag_get_handle( "GLOBAL_DOFS", gdofeTag );MB_CHK_SET_ERR( rval, "file does not have GLOBAL_DOFS file" );
00483         int sizeTag;
00484         rval = mb2->tag_get_length( gdofeTag, sizeTag );MB_CHK_SET_ERR( rval, "can't get size of tag" );
00485         int np = (int)sqrt( 1.0 * sizeTag );
00486         std::cout << " size of tag: " << sizeTag << " np = " << np << "\n";
00487         std::vector< int > gdofs;
00488         Range cells2;
00489         rval = mb2->get_entities_by_dimension( 0, 2, cells2 );MB_CHK_SET_ERR( rval, "can't get cells on spectral mesh" );
00490         gdofs.resize( cells2.size() * sizeTag );
00491         rval = mb2->tag_get_data( gdofeTag, cells2, &gdofs[0] );MB_CHK_SET_ERR( rval, "can't get global dofs tag" );
00492         // create a new tag for element data arranged as DFIELD
00493
00494         std::vector< double > dfield;
00495         dfield.resize( sizeTag, 0.0 );
00496         Tag newTag2;
00497         rval = mb2->tag_get_handle( variable_name.c_str(), (int)sizeTag, mbtype, newTag2, MB_TAG_CREAT | MB_TAG_DENSE,
00498                                     &dfield[0] );MB_CHK_SET_ERR( rval, "can't define new tag" );
00499
00500         int i1 = 0;  // index in the gdofs array, per element
00501
00502         // get the tag values from the other moab core, for newTag
00503         int dataTagLen;
00504         rval = mb->tag_get_length( newTag, dataTagLen );MB_CHK_SET_ERR( rval, "can't get size of newTag" );
00505         //
00506         std::vector< double > oldData;
00507         oldData.resize( dataTagLen * nodes.size() );  //
00508
00509         // get the "old" values
00510         rval = mb->tag_get_data( newTag, nodes, &oldData[0] );MB_CHK_SET_ERR( rval, "can't get old values" );
00511         for( Range::iterator it = cells2.begin(); it != cells2.end(); it++ )
00512         {
00513             EntityHandle cel = *it;
00514             // gdofs per element are gdofs[i:i+np*np];
00515             for( int k = 0; k < sizeTag; k++ )
00516             {
00517                 int gdof          = gdofs[i1 + k];
00518                 EntityHandle node = vGidHandle[gdof];
00519                 int index         = nodes.index( node );
00520                 // get last layer of data
00521                 double val = oldData[index * dataTagLen + dataTagLen - 1];  //
00522                 dfield[k]  = val;
00523             }
00524             i1   = i1 + sizeTag;
00525             rval = mb2->tag_set_data( newTag2, &cel, 1, &dfield[0] );MB_CHK_SET_ERR( rval, "can't set new tag" );
00526         }
00527
00528         // write the appended file with the new field:
00529         rval = mb2->write_file( "atm2.h5m" );MB_CHK_SET_ERR( rval, "can't write new spectral file" );
00530         std::cout << " wrote file atm2.h5m \n";
00531     }
00532     return 0;
00533 }
00534
