adj_time.cpp
00001 #include "moab/Core.hpp"
00002 #include "moab/Range.hpp"
00003 #include "TestUtil.hpp"
00004 #include <iostream>
00005 #include <cassert>
00006 #include <ctime>
00007
00008 using namespace moab;
00009
00010 static const std::string default_input_file = TestDir + "unittest/64bricks_512hex.h5m";
00011
00012 int main()
00013 {
00014     ErrorCode rval;
00015     Core moab;
00016     Interface& mb = moab;
00017
00018     // load test file
00019     rval = mb.load_file( default_input_file.c_str() );
00020     if( MB_SUCCESS != rval )
00021     {
00022         std::cerr << default_input_file << ": failed to load file." << std::endl;
00023         return 1;
00024     }
00025
00026     // get all region elements
00027     Range vols;
00028     rval = mb.get_entities_by_dimension( 0, 3, vols );
00029     if( MB_SUCCESS != rval ) return 2;
00030     if( vols.empty() ) return 1;
00031
00032     // create internal face elements
00033     Range faces;
00034     rval = mb.get_adjacencies( vols, 2, true, faces, Interface::UNION );
00035     if( MB_SUCCESS != rval ) return 2;
00036     assert( faces.size() > vols.size() );
00037
00038     // time query of all adjacent volumes
00039     std::vector< EntityHandle > adj;
00040     clock_t t_0 = clock();
00041     for( Range::iterator i = faces.begin(); i != faces.end(); ++i )
00042     {
00043         adj.clear();
00044         rval = mb.get_adjacencies( &*i, 1, 3, false, adj );
00045         if( MB_SUCCESS != rval ) return 2;
00046         assert( adj.size() == 1 || adj.size() == 2 );
00047     }
00048     clock_t t_up = clock() - t_0;
00049     std::cout << "Querying of volumes for " << faces.size() << " faces: " << t_up / (double)CLOCKS_PER_SEC << " seconds"
00050               << std::endl;
00051
00052     // time downward adjacency query from volumes to faces
00053     t_0 = clock();
00054     for( Range::iterator i = vols.begin(); i != vols.end(); ++i )
00055     {
00056         adj.clear();
00057         rval = mb.get_adjacencies( &*i, 1, 1, false, adj );
00058         if( MB_SUCCESS != rval ) return 2;
00059         assert( adj.size() > 3 );
00060     }
00061     clock_t t_down = clock() - t_0;
00062     std::cout << "Querying of faces for " << vols.size() << " volumes: " << t_down / (double)CLOCKS_PER_SEC
00063               << " seconds" << std::endl;
00064
00065     return 0;
00066 }
