AspectRatioGammaTest Class Reference
+ Inheritance diagram for AspectRatioGammaTest:
+ Collaboration diagram for AspectRatioGammaTest:
Public Member Functions
 AspectRatioGammaTest ()
void test_supported_types ()
void test_ideal_element_eval ()
void test_ideal_element_grad ()
void test_measures_quality ()
void test_gradient_reflects_quality ()
void test_inverted_elements ()
void test_degenerate_elements ()
void test_get_evaluations ()
void test_get_element_indices ()
void test_get_fixed_indices ()
void test_eval_with_indices ()
void test_location_invariant ()
void test_scale_invariant ()
void test_orient_invariant ()
Private Member Functions
 CPPUNIT_TEST_SUITE (AspectRatioGammaTest)
 CPPUNIT_TEST (test_supported_types)
 CPPUNIT_TEST (test_ideal_element_eval)
 CPPUNIT_TEST (test_ideal_element_grad)
 CPPUNIT_TEST (test_measures_quality)
 CPPUNIT_TEST (test_gradient_reflects_quality)
 CPPUNIT_TEST (test_inverted_elements)
 CPPUNIT_TEST (test_degenerate_elements)
 CPPUNIT_TEST (test_get_evaluations)
 CPPUNIT_TEST (test_get_element_indices)
 CPPUNIT_TEST (test_get_fixed_indices)
 CPPUNIT_TEST (test_eval_with_indices)
 CPPUNIT_TEST (test_location_invariant)
 CPPUNIT_TEST (test_scale_invariant)
 CPPUNIT_TEST (test_orient_invariant)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
AspectRatioGammaQualityMetric mMetric
QualityMetricTester tester
Detailed Description
Definition at line 39 of file AspectRatioGammaTest.cpp.
Member Function Documentation
Definition at line 78 of file AspectRatioGammaTest.cpp.
References mMetric.
Definition at line 93 of file AspectRatioGammaTest.cpp.
References mMetric.
Definition at line 83 of file AspectRatioGammaTest.cpp.
References mMetric.
Definition at line 130 of file AspectRatioGammaTest.cpp.
References mMetric.
Member Data Documentation
List of all members.
