AveragingQMTest Class Reference
+ Inheritance diagram for AveragingQMTest:
+ Collaboration diagram for AveragingQMTest:
Public Member Functions
void test_average_metrics_liner ()
void test_average_metrics_rms ()
void test_average_metrics_hms ()
void test_average_metrics_minimum ()
void test_average_metrics_maximum ()
void test_average_metrics_harmonic ()
void test_average_metrics_geometric ()
void test_average_metrics_sum ()
void test_average_metrics_sum_squared ()
void test_average_metrics_standard_deviation ()
void test_average_metrics_max_over_min ()
void test_average_metrics_max_minus_min ()
void test_average_metrics_sum_of_ratios_squared ()
void test_average_and_weights_linear ()
void test_average_and_weights_rms ()
void test_average_and_weights_hms ()
void test_average_and_weights_minimum ()
void test_average_and_weights_maximum ()
void test_average_and_weights_harmonic ()
void test_average_and_weights_geometric ()
void test_average_and_weights_sum ()
void test_average_and_weights_sum_squared ()
void test_average_and_weights_standard_deviation ()
void test_average_and_weights_max_over_min ()
void test_average_and_weights_max_minus_min ()
void test_average_and_weights_sum_of_ratios_squared ()
void test_average_corner_gradients_linear ()
void test_average_corner_gradients_rms ()
void test_average_corner_gradients_hms ()
void test_average_corner_gradients_minimum ()
void test_average_corner_gradients_maximum ()
void test_average_corner_gradients_harmonic ()
void test_average_corner_gradients_geometric ()
void test_average_corner_gradients_sum ()
void test_average_corner_gradients_sum_squared ()
void test_average_corner_gradients_standard_deviation ()
void test_average_corner_gradients_max_over_min ()
void test_average_corner_gradients_max_minus_min ()
void test_average_corner_gradients_sum_of_ratios_squared ()
void test_average_corner_hessians_linear ()
void test_average_corner_hessians_rms ()
void test_average_corner_hessians_hms ()
void test_average_corner_hessians_minimum ()
void test_average_corner_hessians_maximum ()
void test_average_corner_hessians_harmonic ()
void test_average_corner_hessians_geometric ()
void test_average_corner_hessians_sum ()
void test_average_corner_hessians_sum_squared ()
void test_average_corner_hessians_standard_deviation ()
void test_average_corner_hessians_max_over_min ()
void test_average_corner_hessians_max_minus_min ()
void test_average_corner_hessians_sum_of_ratios_squared ()
void test_average_corner_hessian_diagonals_linear ()
void test_average_corner_hessian_diagonals_rms ()
void test_average_corner_hessian_diagonals_hms ()
void test_average_corner_hessian_diagonals_minimum ()
void test_average_corner_hessian_diagonals_maximum ()
void test_average_corner_hessian_diagonals_harmonic ()
void test_average_corner_hessian_diagonals_geometric ()
void test_average_corner_hessian_diagonals_sum ()
void test_average_corner_hessian_diagonals_sum_squared ()
void test_average_corner_hessian_diagonals_standard_deviation ()
void test_average_corner_hessian_diagonals_max_over_min ()
void test_average_corner_hessian_diagonals_max_minus_min ()
void test_average_corner_hessian_diagonals_sum_of_ratios_squared ()
Private Member Functions
 CPPUNIT_TEST_SUITE (AveragingQMTest)
 CPPUNIT_TEST (test_average_metrics_liner)
 CPPUNIT_TEST (test_average_metrics_rms)
 CPPUNIT_TEST (test_average_metrics_hms)
 CPPUNIT_TEST (test_average_metrics_minimum)
 CPPUNIT_TEST (test_average_metrics_maximum)
 CPPUNIT_TEST (test_average_metrics_harmonic)
 CPPUNIT_TEST (test_average_metrics_geometric)
 CPPUNIT_TEST (test_average_metrics_sum)
 CPPUNIT_TEST (test_average_metrics_sum_squared)
 CPPUNIT_TEST (test_average_metrics_standard_deviation)
 CPPUNIT_TEST (test_average_metrics_max_over_min)
 CPPUNIT_TEST (test_average_metrics_max_minus_min)
 CPPUNIT_TEST (test_average_metrics_sum_of_ratios_squared)
 CPPUNIT_TEST (test_average_and_weights_linear)
 CPPUNIT_TEST (test_average_and_weights_rms)
 CPPUNIT_TEST (test_average_and_weights_hms)
 CPPUNIT_TEST (test_average_and_weights_minimum)
 CPPUNIT_TEST (test_average_and_weights_maximum)
 CPPUNIT_TEST (test_average_and_weights_harmonic)
 CPPUNIT_TEST (test_average_and_weights_geometric)
 CPPUNIT_TEST (test_average_and_weights_sum)
 CPPUNIT_TEST (test_average_and_weights_sum_squared)
 CPPUNIT_TEST (test_average_and_weights_standard_deviation)
 CPPUNIT_TEST (test_average_and_weights_max_over_min)
 CPPUNIT_TEST (test_average_and_weights_max_minus_min)
 CPPUNIT_TEST (test_average_and_weights_sum_of_ratios_squared)
 CPPUNIT_TEST (test_average_corner_gradients_linear)
 CPPUNIT_TEST (test_average_corner_gradients_rms)
 CPPUNIT_TEST (test_average_corner_gradients_hms)
 CPPUNIT_TEST (test_average_corner_gradients_minimum)
 CPPUNIT_TEST (test_average_corner_gradients_maximum)
 CPPUNIT_TEST (test_average_corner_gradients_harmonic)
 CPPUNIT_TEST (test_average_corner_gradients_geometric)
 CPPUNIT_TEST (test_average_corner_gradients_sum)
 CPPUNIT_TEST (test_average_corner_gradients_sum_squared)
 CPPUNIT_TEST (test_average_corner_gradients_standard_deviation)
 CPPUNIT_TEST (test_average_corner_gradients_max_over_min)
 CPPUNIT_TEST (test_average_corner_gradients_max_minus_min)
 CPPUNIT_TEST (test_average_corner_gradients_sum_of_ratios_squared)
 CPPUNIT_TEST (test_average_corner_hessians_linear)
 CPPUNIT_TEST (test_average_corner_hessians_rms)
 CPPUNIT_TEST (test_average_corner_hessians_hms)
 CPPUNIT_TEST (test_average_corner_hessians_minimum)
 CPPUNIT_TEST (test_average_corner_hessians_maximum)
 CPPUNIT_TEST (test_average_corner_hessians_harmonic)
 CPPUNIT_TEST (test_average_corner_hessians_geometric)
 CPPUNIT_TEST (test_average_corner_hessians_sum)
 CPPUNIT_TEST (test_average_corner_hessians_sum_squared)
 CPPUNIT_TEST (test_average_corner_hessians_standard_deviation)
 CPPUNIT_TEST (test_average_corner_hessians_max_over_min)
 CPPUNIT_TEST (test_average_corner_hessians_max_minus_min)
 CPPUNIT_TEST (test_average_corner_hessians_sum_of_ratios_squared)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_linear)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_rms)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_hms)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_minimum)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_maximum)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_harmonic)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_geometric)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_sum)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_sum_squared)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_standard_deviation)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_max_over_min)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_max_minus_min)
 CPPUNIT_TEST (test_average_corner_hessian_diagonals_sum_of_ratios_squared)
 CPPUNIT_TEST_SUITE_END ()
void check_average_and_weights_fails (QualityMetric::AveragingMethod scheme)
void check_average_gradients (QualityMetric::AveragingMethod scheme)
void check_average_gradient_fails (QualityMetric::AveragingMethod scheme)
void check_pmean_hessian_diagonals (QualityMetric::AveragingMethod scheme, double inner_power, double outer_power, bool scale)
void check_hessian_diagonal_fails (QualityMetric::AveragingMethod scheme)
void check_pmean_hessian (QualityMetric::AveragingMethod scheme, double inner_power, double outer_power, bool scale)
void check_hessian_fails (QualityMetric::AveragingMethod scheme)
void check_average_and_weights (const double *vals, unsigned n, QualityMetric::AveragingMethod method, const double *weights)
Static Private Attributes
static const double VAL_LIST_1 [5] = { 1, 2, -1, -2, 5 }
static const double VAL_LIST_2 [8]
static const unsigned LEN_LIST_1 = sizeof( VAL_LIST_1 ) / sizeof( double )
static const unsigned LEN_LIST_2 = sizeof( VAL_LIST_2 ) / sizeof( double )
Detailed Description
Definition at line 42 of file AveragingQMTest.cpp.
Member Function Documentation
void AveragingQMTest::check_average_and_weights ( const double *  vals,
unsigned  n,
const double *  weights
) [private]
Definition at line 499 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metric_and_weights(), MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, and n.
    MsqPrintError err( std::cout );
    AveragingQM aqm( method );
    CPPUNIT_ASSERT( n > 0 );
    std::vector< double > working( n );
    std::copy( vals, vals + n, working.begin() );
    double avg1, avg2;
    avg1 = aqm.average_metrics( vals, n, err );
    ASSERT_NO_ERROR( err );
    avg2 = aqm.average_metric_and_weights( arrptr( working ), n, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( avg1, avg2, 1e-6 );
    for( unsigned i = 0; i < n; ++i )
        CPPUNIT_ASSERT_DOUBLES_EQUAL( weights[i], working[i], 1e-6 );
Definition at line 662 of file AveragingQMTest.cpp.
References MBMesquite::AveragingQM::average_metric_and_weights(), and CPPUNIT_ASSERT.
    MsqError err;
    AveragingQM aqm( scheme );
    double w[] = { 1.0, 2.0 };
    aqm.average_metric_and_weights( w, 2, err );
    CPPUNIT_ASSERT( err );
Definition at line 767 of file AveragingQMTest.cpp.
References MBMesquite::AveragingQM::average_corner_gradients(), CPPUNIT_ASSERT, and MBMesquite::QUADRILATERAL.
    double vals[] = { 1, 2, -1, 0.5 };
    Vector3D grads[12], vtxgrads[4];
    for( unsigned i = 0; i < 12; ++i )
        grads[i] = Vector3D( (double)i );
    MsqError err;
    aqm.average_corner_gradients( QUADRILATERAL, 0, 4, vals, grads, vtxgrads, err );
Definition at line 691 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_corner_gradients(), MBMesquite::AveragingQM::average_metric_and_weights(), CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, fixed, and MBMesquite::QUADRILATERAL.
    double vals1[] = { 1, -2, -1, 0.5 };
    double vals2[] = { 1, -2, -1, 0.5 };
    uint32_t fixed = 0x2;  // mark second vertex as fixed
    Vector3D exp;
    MsqError err;
    double a1 = aqm.average_metric_and_weights( vals1, 4, err );
    double a2 = aqm.average_corner_gradients( QUADRILATERAL, fixed, 4, vals2, grads, vtxgrads, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( a1, a2, 1e-8 );
    exp = vals1[0] * grads[0] + vals1[1] * grads[5] + vals1[3] * grads[10];
    CPPUNIT_ASSERT_VECTORS_EQUAL( exp, vtxgrads[0], 1e-6 );
    exp = vals1[1] * grads[4] + vals1[2] * grads[6] + vals1[3] * grads[11];
    CPPUNIT_ASSERT_VECTORS_EQUAL( exp, vtxgrads[2], 1e-6 );
    exp = vals1[0] * grads[2] + vals1[2] * grads[7] + vals1[3] * grads[9];
    CPPUNIT_ASSERT_VECTORS_EQUAL( exp, vtxgrads[3], 1e-6 );
Definition at line 920 of file AveragingQMTest.cpp.
References MBMesquite::AveragingQM::average_corner_hessian_diagonals(), CPPUNIT_ASSERT, fixed, and MBMesquite::TRIANGLE.
    // define corner values, gradients and Hessians for a triangle
    double vals[]            = { 1, 2, 0.5 };
    const Vector3D grads[9]  = { Vector3D( 1.0 ), Vector3D( 2.0 ), Vector3D( 3.0 ), Vector3D( 4.0 ), Vector3D( 5.0 ),
                                Vector3D( 6.0 ), Vector3D( 7.0 ), Vector3D( 8.0 ), Vector3D( 9.0 ) };
    const Matrix3D hesss[18] = { Matrix3D( 1.0 ), Matrix3D( 2.0 ), Matrix3D( -1. ), Matrix3D( 0.5 ),  Matrix3D( 6.0 ),
                                 Matrix3D( 1.1 ), Matrix3D( 1.2 ), Matrix3D( 0.3 ), Matrix3D( 0.0 ),  Matrix3D( 22. ),
                                 Matrix3D( -2. ), Matrix3D( 4.3 ), Matrix3D( 0.8 ), Matrix3D( 1, 7 ), Matrix3D( -.2 ),
                                 Matrix3D( 0.5 ), Matrix3D( 7.0 ), Matrix3D( 1.5 ) };
    Vector3D vtx_grad[3];
    SymMatrix3D vtx_hess[6];
    MsqError err;
    uint32_t fixed = 0x4;  // mark third vertex as fixed
    aqm.average_corner_hessian_diagonals( TRIANGLE, fixed, 3, vals, grads, hesss, vtx_grad, vtx_hess, err );
    const SymMatrix3D diags[9] = { SymMatrix3D( 1.0 ), SymMatrix3D( 0.5 ), SymMatrix3D( 1.0 ),
                                   SymMatrix3D( 1.2 ), SymMatrix3D( 22. ), SymMatrix3D( 4.3 ),
                                   SymMatrix3D( 0.8 ), SymMatrix3D( 0.5 ), SymMatrix3D( 1.5 ) };
    aqm.average_corner_hessian_diagonals( TRIANGLE, fixed, 3, vals, grads, diags, vtx_grad, vtx_hess, err );
Definition at line 1057 of file AveragingQMTest.cpp.
References MBMesquite::AveragingQM::average_corner_hessians(), CPPUNIT_ASSERT, fixed, and MBMesquite::TRIANGLE.
    MsqError err;
    aqm.average_corner_hessians( TRIANGLE, fixed, 3, vals, grads, hesss, vtx_grad, vtx_hess, err );
void AveragingQMTest::check_pmean_hessian ( QualityMetric::AveragingMethod  scheme,
double  inner_power,
double  outer_power,
bool  scale
) [private]
Definition at line 1013 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_corner_hessians(), CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, fixed, pmean_of_triangle_corner_hessians(), and MBMesquite::TRIANGLE.
    const Vector3D grads[9] = { Vector3D( 0, 1, 1 ), Vector3D( 0, 2, 2 ), Vector3D( 0, 3, 3 ),
                                Vector3D( 0, 4, 4 ), Vector3D( 0, 5, 5 ), Vector3D( 0, 6, 6 ),
                                Vector3D( 0, 7, 7 ), Vector3D( 0, 8, 8 ), Vector3D( 0, 9, 9 ) };
    // change some values so we catch transpositional errors
    for( unsigned i = 0; i < sizeof( hesss ) / sizeof( hesss[0] ); ++i )
        hesss[i][2][2] = 0.0;
    Vector3D aqm_grad[3], exp_grad[3];
    Matrix3D aqm_hess[6], exp_hess[6];
    double aqm_avg, exp_avg;
    exp_avg =
        pmean_of_triangle_corner_hessians( inner_power, outer_power, vals, grads, hesss, exp_grad, exp_hess, scale );
    aqm_avg = aqm.average_corner_hessians( TRIANGLE, fixed, 3, vals, grads, hesss, aqm_grad, aqm_hess, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( exp_avg, aqm_avg, 1e-6 );
    // only check gradient terms for free vertices
    CPPUNIT_ASSERT_VECTORS_EQUAL( exp_grad[0], aqm_grad[0], 1e-6 );
    CPPUNIT_ASSERT_VECTORS_EQUAL( exp_grad[1], aqm_grad[1], 1e-6 );
    // only check Hessian terms for free vertices
    CPPUNIT_ASSERT_MATRICES_EQUAL( exp_hess[0], aqm_hess[0], 1e-6 );
    CPPUNIT_ASSERT_MATRICES_EQUAL( exp_hess[1], aqm_hess[1], 1e-6 );
    CPPUNIT_ASSERT_MATRICES_EQUAL( exp_hess[3], aqm_hess[3], 1e-6 );
void AveragingQMTest::check_pmean_hessian_diagonals ( QualityMetric::AveragingMethod  scheme,
double  inner_power,
double  outer_power,
bool  scale
) [private]
Definition at line 858 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_corner_hessian_diagonals(), CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, fixed, pmean_of_triangle_corner_hessians(), MBMesquite::TRIANGLE, and MBMesquite::Matrix3D::upper().
    uint32_t fixed = 0;  // mark no vertices as fixed
    // Calculate expected values
    Matrix3D exp_hess[6];
    exp_avg =
    // Test calculation of diagonal from full corner hessian data.
    SymMatrix3D aqm_hess[3] = { 1, 2, 3 };
    aqm_avg = aqm.average_corner_hessian_diagonals( TRIANGLE, fixed, 3, vals, grads, hesss, aqm_grad, aqm_hess, err );
    CPPUNIT_ASSERT_VECTORS_EQUAL( exp_grad[2], aqm_grad[2], 1e-6 );
    CPPUNIT_ASSERT_MATRICES_EQUAL( exp_hess[0], Matrix3D( aqm_hess[0] ), 1e-6 );
    CPPUNIT_ASSERT_MATRICES_EQUAL( exp_hess[3], Matrix3D( aqm_hess[1] ), 1e-6 );
    CPPUNIT_ASSERT_MATRICES_EQUAL( exp_hess[5], Matrix3D( aqm_hess[2] ), 1e-6 );
    // Test calculation of diagonal from diagonal corner hessian data.
    SymMatrix3D diags[9] = { hesss[0].upper(),  hesss[3].upper(),  hesss[5].upper(),
                             hesss[6].upper(),  hesss[9].upper(),  hesss[11].upper(),
                             hesss[12].upper(), hesss[15].upper(), hesss[17].upper() };
    aqm_avg = aqm.average_corner_hessian_diagonals( TRIANGLE, fixed, 3, vals, grads, diags, aqm_grad, aqm_hess, err );
Definition at line 620 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), MBMesquite::QualityMetric::GEOMETRIC, and geometric_mean().
    std::vector< double > weights1( LEN_LIST_1 ), weights2( LEN_LIST_2 );
    unsigned i;
    double g;
    g = geometric_mean( VAL_LIST_1, LEN_LIST_1 );
    for( i = 0; i < LEN_LIST_1; ++i )
        weights1[i] = g / VAL_LIST_1[i] / LEN_LIST_1;
    check_average_and_weights( VAL_LIST_1, LEN_LIST_1, QualityMetric::GEOMETRIC, arrptr( weights1 ) );
    g = geometric_mean( VAL_LIST_2, LEN_LIST_2 );
    for( i = 0; i < LEN_LIST_2; ++i )
        weights2[i] = g / VAL_LIST_2[i] / LEN_LIST_2;
    check_average_and_weights( VAL_LIST_2, LEN_LIST_2, QualityMetric::GEOMETRIC, arrptr( weights2 ) );
Definition at line 597 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), MBMesquite::QualityMetric::HARMONIC, and pmean().
    unsigned i;
    double h, tmp;
    h = pmean( VAL_LIST_1, LEN_LIST_1, -1.0 );
        tmp         = h / VAL_LIST_1[i];
        weights1[i] = tmp * tmp / LEN_LIST_1;
    check_average_and_weights( VAL_LIST_1, LEN_LIST_1, QualityMetric::HARMONIC, arrptr( weights1 ) );
    h = pmean( VAL_LIST_2, LEN_LIST_2, -1.0 );
        tmp         = h / VAL_LIST_2[i];
        weights2[i] = tmp * tmp / LEN_LIST_2;
    check_average_and_weights( VAL_LIST_2, LEN_LIST_2, QualityMetric::HARMONIC, arrptr( weights2 ) );
Definition at line 546 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), MBMesquite::QualityMetric::HMS, and pmean().
    unsigned i;
    double hms, tmp;
    hms = pmean( VAL_LIST_1, LEN_LIST_1, -2.0 );
        tmp         = hms / VAL_LIST_1[i];
        weights1[i] = tmp * tmp * tmp / LEN_LIST_1;
    check_average_and_weights( VAL_LIST_1, LEN_LIST_1, QualityMetric::HMS, arrptr( weights1 ) );
    hms = pmean( VAL_LIST_2, LEN_LIST_2, -2.0 );
        tmp         = hms / VAL_LIST_2[i];
        weights2[i] = tmp * tmp * tmp / LEN_LIST_2;
    check_average_and_weights( VAL_LIST_2, LEN_LIST_2, QualityMetric::HMS, arrptr( weights2 ) );
Definition at line 522 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), and MBMesquite::QualityMetric::LINEAR.
    std::vector< double > weights1( LEN_LIST_1, 1.0 / LEN_LIST_1 ), weights2( LEN_LIST_2, 1.0 / LEN_LIST_2 );
    check_average_and_weights( VAL_LIST_1, LEN_LIST_1, QualityMetric::LINEAR, arrptr( weights1 ) );
    check_average_and_weights( VAL_LIST_2, LEN_LIST_2, QualityMetric::LINEAR, arrptr( weights2 ) );
Definition at line 583 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), and MBMesquite::QualityMetric::MAXIMUM.
    std::vector< double > weights1( LEN_LIST_1, 0.0 ), weights2( LEN_LIST_2, 0.0 );
    const double* ptr;
    ptr                        = std::max_element( VAL_LIST_1, VAL_LIST_1 + LEN_LIST_1 );
    weights1[ptr - VAL_LIST_1] = 1.0;
    check_average_and_weights( VAL_LIST_1, LEN_LIST_1, QualityMetric::MAXIMUM, arrptr( weights1 ) );
    ptr                        = std::max_element( VAL_LIST_2, VAL_LIST_2 + LEN_LIST_2 );
    weights2[ptr - VAL_LIST_2] = 1.0;
    check_average_and_weights( VAL_LIST_2, LEN_LIST_2, QualityMetric::MAXIMUM, arrptr( weights2 ) );
Definition at line 569 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), and MBMesquite::QualityMetric::MINIMUM.
    const double* ptr;
    ptr                        = std::min_element( VAL_LIST_1, VAL_LIST_1 + LEN_LIST_1 );
    check_average_and_weights( VAL_LIST_1, LEN_LIST_1, QualityMetric::MINIMUM, arrptr( weights1 ) );
    ptr                        = std::min_element( VAL_LIST_2, VAL_LIST_2 + LEN_LIST_2 );
    check_average_and_weights( VAL_LIST_2, LEN_LIST_2, QualityMetric::MINIMUM, arrptr( weights2 ) );
Definition at line 529 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), pmean(), and MBMesquite::QualityMetric::RMS.
    unsigned i;
    double rms;
    rms = pmean( VAL_LIST_1, LEN_LIST_1, 2.0 );
        weights1[i] = VAL_LIST_1[i] / ( LEN_LIST_1 * rms );
    check_average_and_weights( VAL_LIST_1, LEN_LIST_1, QualityMetric::RMS, arrptr( weights1 ) );
    rms = pmean( VAL_LIST_2, LEN_LIST_2, 2.0 );
        weights2[i] = VAL_LIST_2[i] / ( LEN_LIST_2 * rms );
    check_average_and_weights( VAL_LIST_2, LEN_LIST_2, QualityMetric::RMS, arrptr( weights2 ) );
Definition at line 641 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), and MBMesquite::QualityMetric::SUM.
    std::vector< double > weights1( LEN_LIST_1, 1.0 ), weights2( LEN_LIST_2, 1.0 );
    check_average_and_weights( VAL_LIST_1, LEN_LIST_1, QualityMetric::SUM, arrptr( weights1 ) );
    check_average_and_weights( VAL_LIST_2, LEN_LIST_2, QualityMetric::SUM, arrptr( weights2 ) );
Definition at line 648 of file AveragingQMTest.cpp.
References MBMesquite::arrptr(), and MBMesquite::QualityMetric::SUM_SQUARED.
    unsigned i;
        weights1[i] = 2 * VAL_LIST_1[i];
    check_average_and_weights( VAL_LIST_1, LEN_LIST_1, QualityMetric::SUM_SQUARED, arrptr( weights1 ) );
        weights2[i] = 2 * VAL_LIST_2[i];
    check_average_and_weights( VAL_LIST_2, LEN_LIST_2, QualityMetric::SUM_SQUARED, arrptr( weights2 ) );
Definition at line 973 of file AveragingQMTest.cpp.
References MBMesquite::QualityMetric::HARMONIC.
    check_pmean_hessian_diagonals( QualityMetric::HARMONIC, -1, -1, true );
Definition at line 958 of file AveragingQMTest.cpp.
References MBMesquite::QualityMetric::HMS.
    check_pmean_hessian_diagonals( QualityMetric::HMS, -2, -0.5, true );
Definition at line 948 of file AveragingQMTest.cpp.
References MBMesquite::QualityMetric::LINEAR.
    check_pmean_hessian_diagonals( QualityMetric::LINEAR, 1, 1, true );
Definition at line 953 of file AveragingQMTest.cpp.
References MBMesquite::QualityMetric::RMS.
    check_pmean_hessian_diagonals( QualityMetric::RMS, 2, 0.5, true );
Definition at line 983 of file AveragingQMTest.cpp.
References MBMesquite::QualityMetric::SUM.
    check_pmean_hessian_diagonals( QualityMetric::SUM, 1, 1, false );
Definition at line 1103 of file AveragingQMTest.cpp.
    check_pmean_hessian( QualityMetric::HARMONIC, -1, -1, true );
Definition at line 1088 of file AveragingQMTest.cpp.
    check_pmean_hessian( QualityMetric::HMS, -2, -0.5, true );
Definition at line 1078 of file AveragingQMTest.cpp.
    check_pmean_hessian( QualityMetric::LINEAR, 1, 1, true );
Definition at line 1098 of file AveragingQMTest.cpp.
References MBMesquite::QualityMetric::MAXIMUM.
    check_hessian_fails( QualityMetric::MAXIMUM );
Definition at line 1093 of file AveragingQMTest.cpp.
References MBMesquite::QualityMetric::MINIMUM.
    check_hessian_fails( QualityMetric::MINIMUM );
Definition at line 1083 of file AveragingQMTest.cpp.
    check_pmean_hessian( QualityMetric::RMS, 2, 0.5, true );
Definition at line 1113 of file AveragingQMTest.cpp.
    check_pmean_hessian( QualityMetric::SUM, 1, 1, false );
Definition at line 1118 of file AveragingQMTest.cpp.
References MBMesquite::QualityMetric::SUM_SQUARED.
    check_pmean_hessian( QualityMetric::SUM_SQUARED, 2, 1, false );
Definition at line 373 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::QualityMetric::GEOMETRIC, and geometric_mean().
    AveragingQM aqm( QualityMetric::GEOMETRIC );
    double exp, act;
    exp = geometric_mean( VAL_LIST_1, LEN_LIST_1 );
    act = aqm.average_metrics( VAL_LIST_1, LEN_LIST_1, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( exp, act, 1e-8 );
    exp = geometric_mean( VAL_LIST_2, LEN_LIST_2 );
    act = aqm.average_metrics( VAL_LIST_2, LEN_LIST_2, err );
Definition at line 356 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::QualityMetric::HARMONIC, and pmean().
    AveragingQM aqm( QualityMetric::HARMONIC );
    double exp, act;
    exp = pmean( VAL_LIST_1, LEN_LIST_1, -1.0 );
    exp = pmean( VAL_LIST_2, LEN_LIST_2, -1.0 );
Definition at line 305 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::QualityMetric::HMS, and pmean().
    AveragingQM aqm( QualityMetric::HMS );
    double exp, act;
    exp = pmean( VAL_LIST_1, LEN_LIST_1, -2.0 );
    exp = pmean( VAL_LIST_2, LEN_LIST_2, -2.0 );
Definition at line 271 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::QualityMetric::LINEAR, and pmean().
    AveragingQM aqm( QualityMetric::LINEAR );
    double exp, act;
    exp = pmean( VAL_LIST_1, LEN_LIST_1, 1 );
    exp = pmean( VAL_LIST_2, LEN_LIST_2, 1 );
Definition at line 465 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, list_max(), list_min(), and MBMesquite::QualityMetric::MAX_MINUS_MIN.
    AveragingQM aqm( QualityMetric::MAX_MINUS_MIN );
    double exp, act;
    exp = list_max( VAL_LIST_1, LEN_LIST_1 ) - list_min( VAL_LIST_1, LEN_LIST_1 );
    exp = list_max( VAL_LIST_2, LEN_LIST_2 ) - list_min( VAL_LIST_2, LEN_LIST_2 );
Definition at line 448 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, list_max(), list_min(), and MBMesquite::QualityMetric::MAX_OVER_MIN.
    AveragingQM aqm( QualityMetric::MAX_OVER_MIN );
    double exp, act;
    exp = list_max( VAL_LIST_1, LEN_LIST_1 ) / list_min( VAL_LIST_1, LEN_LIST_1 );
    exp = list_max( VAL_LIST_2, LEN_LIST_2 ) / list_min( VAL_LIST_2, LEN_LIST_2 );
Definition at line 339 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, list_max(), and MBMesquite::QualityMetric::MAXIMUM.
    AveragingQM aqm( QualityMetric::MAXIMUM );
    double exp, act;
    exp = list_max( VAL_LIST_1, LEN_LIST_1 );
    exp = list_max( VAL_LIST_2, LEN_LIST_2 );
Definition at line 322 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, list_min(), and MBMesquite::QualityMetric::MINIMUM.
    AveragingQM aqm( QualityMetric::MINIMUM );
    double exp, act;
    exp = list_min( VAL_LIST_1, LEN_LIST_1 );
    exp = list_min( VAL_LIST_2, LEN_LIST_2 );
Definition at line 288 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, pmean(), and MBMesquite::QualityMetric::RMS.
    AveragingQM aqm( QualityMetric::RMS );
    double exp, act;
    exp = pmean( VAL_LIST_1, LEN_LIST_1, 2 );
    exp = pmean( VAL_LIST_2, LEN_LIST_2, 2 );
Definition at line 427 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, pmean(), MBMesquite::QualityMetric::STANDARD_DEVIATION, and sum_sqr().
    AveragingQM aqm( QualityMetric::STANDARD_DEVIATION );
    double exp, act, tmp;
    tmp = pmean( VAL_LIST_1, LEN_LIST_1, 1.0 );
    exp = sum_sqr( VAL_LIST_1, LEN_LIST_1 );
    exp = exp / LEN_LIST_1 - tmp * tmp;
    tmp = pmean( VAL_LIST_2, LEN_LIST_2, 1.0 );
    exp = sum_sqr( VAL_LIST_2, LEN_LIST_2 );
    exp = exp / LEN_LIST_2 - tmp * tmp;
Definition at line 390 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, and MBMesquite::QualityMetric::SUM.
    AveragingQM aqm( QualityMetric::SUM );
    double exp, act;
    unsigned i;
    for( exp = 0.0, i = 0; i < LEN_LIST_1; exp += VAL_LIST_1[i++] )
    for( exp = 0.0, i = 0; i < LEN_LIST_2; exp += VAL_LIST_2[i++] )
Definition at line 482 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, sum_of_ratios_squared(), and MBMesquite::QualityMetric::SUM_OF_RATIOS_SQUARED.
    AveragingQM aqm( QualityMetric::SUM_OF_RATIOS_SQUARED );
    double exp, act;
    exp = sum_of_ratios_squared( VAL_LIST_1, LEN_LIST_1 );
    exp = sum_of_ratios_squared( VAL_LIST_2, LEN_LIST_2 );
Definition at line 410 of file AveragingQMTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::AveragingQM::average_metrics(), CPPUNIT_ASSERT_DOUBLES_EQUAL, sum_sqr(), and MBMesquite::QualityMetric::SUM_SQUARED.
    AveragingQM aqm( QualityMetric::SUM_SQUARED );
    double exp, act;
Member Data Documentation
const unsigned AveragingQMTest::LEN_LIST_1 = sizeof( VAL_LIST_1 ) / sizeof( double ) [static, private]
Definition at line 114 of file AveragingQMTest.cpp.
const unsigned AveragingQMTest::LEN_LIST_2 = sizeof( VAL_LIST_2 ) / sizeof( double ) [static, private]
Definition at line 115 of file AveragingQMTest.cpp.
const double AveragingQMTest::VAL_LIST_1 = { 1, 2, -1, -2, 5 } [static, private]
Definition at line 112 of file AveragingQMTest.cpp.
const double AveragingQMTest::VAL_LIST_2 [static, private]
Initial value:
    M_PI, std::exp( 1.0 ), -20, 8, M_PI / 4, std::log( 2.0 ), std::sqrt( 2.0 ), -1 }
Definition at line 113 of file AveragingQMTest.cpp.
List of all members.
