ConstantElementMetric Class Reference
Fake quality metric for testing numerial gradient. More...
+ Inheritance diagram for ConstantElementMetric:
+ Collaboration diagram for ConstantElementMetric:
Public Member Functions
std::string get_name () const
int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
bool evaluate (PatchData &pd, size_t, double &value, MsqError &)
 Get metric value at a logical location in the patch.
bool evaluate_with_indices (PatchData &pd, size_t elem_idx, double &value, std::vector< size_t > &indices, MsqError &)
 Default implementation for all element-based metrics.
Detailed Description
Implement an element metric for which the "quality" is always 1.0. The resulting gradient and Hessian should always be zero.
Definition at line 156 of file QualityMetricTest.cpp.
Member Function Documentation
bool ConstantElementMetric::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [inline, virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 167 of file QualityMetricTest.cpp.
        value = 1.0;
        return true;
bool ConstantElementMetric::evaluate_with_indices ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
MsqError err
) [inline, virtual]
Fill 'indices' with all free vertex indices in element, and call 'evaluate'.
Reimplemented from MBMesquite::ElementQM.
Definition at line 172 of file QualityMetricTest.cpp.
References conn, MBMesquite::PatchData::element_by_index(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::MsqMeshEntity::node_count(), and MBMesquite::PatchData::num_free_vertices().
        MsqMeshEntity& elem = pd.element_by_index( elem_idx );
        unsigned nv         = elem.node_count();
        const size_t* conn  = elem.get_vertex_index_array();
        indices.clear();
        for( unsigned i = 0; i < nv; ++i )
            if( conn[i] < pd.num_free_vertices() ) indices.push_back( conn[i] );
        value = 1.0;
        return true;
std::string ConstantElementMetric::get_name ( ) const [inline, virtual]
Definition at line 159 of file QualityMetricTest.cpp.
        return "Fake metric for testing numerical gradient";
int ConstantElementMetric::get_negate_flag ( ) const [inline, virtual]
Definition at line 163 of file QualityMetricTest.cpp.
        return 1;
List of all members.
