HigherOrderTest Class Reference
+ Inheritance diagram for HigherOrderTest:
+ Collaboration diagram for HigherOrderTest:
Public Member Functions
 HigherOrderTest ()
bool hit_iteration_limit () const
void test_tri_basic_ideal ()
void test_tri_basic_mid_spin ()
void test_tri_basic_mid_convex ()
void test_tri_basic_peak_up ()
void test_tri_basic_peak_down ()
void test_tri_basic_peak_over ()
void test_quad_basic_ideal ()
void test_quad_basic_mid_spin ()
void test_quad_basic_mid_convex ()
void test_quad_basic_left_down ()
void test_quad_basic_top_down ()
void test_quad_basic_right_up ()
void test_quad_basic_left_over ()
void test_tet_basic_ideal ()
void test_tet_basic_mid_spin ()
void test_tet_basic_mid_convex ()
void test_tet_basic_apex_up ()
void test_tet_basic_apex_down ()
void test_tet_basic_apex_over ()
void test_hex_basic ()
void test_tri_open_domain ()
void test_tri_slac ()
void test_tri_open_domain (double &x1, double &x3, double &x4, double y2, double y5, double &y4)
void basic_tri_test (double &x2, double &y2, double &x3, double &y3, double &x4, double &y4, double &x5, double &y5, MsqError &err)
void basic_tet_test (Vector3D &p3, Vector3D &p4, Vector3D &p5, Vector3D &p6, Vector3D &p7, Vector3D &p8, Vector3D &p9, MsqError &err)
void basic_quad_test (Vector3D &p2, Vector3D &p3, Vector3D &p4, Vector3D &p5, Vector3D &p6, Vector3D &p7, MsqError &err)
void basic_hex_test (Vector3D &p4, Vector3D &p5, Vector3D &p6, Vector3D &p7, Vector3D &p8, Vector3D &p9, Vector3D &p10, Vector3D &p11, Vector3D &p12, Vector3D &p13, Vector3D &p14, Vector3D &p15, Vector3D &p16, Vector3D &p17, Vector3D &p18, Vector3D &p19, MsqError &err)
Private Member Functions
 CPPUNIT_TEST_SUITE (HigherOrderTest)
 CPPUNIT_TEST (test_tri_basic_ideal)
 CPPUNIT_TEST (test_tri_basic_mid_spin)
 CPPUNIT_TEST (test_tri_basic_mid_convex)
 CPPUNIT_TEST (test_tri_basic_peak_up)
 CPPUNIT_TEST (test_tri_basic_peak_down)
 CPPUNIT_TEST (test_tri_basic_peak_over)
 CPPUNIT_TEST (test_quad_basic_ideal)
 CPPUNIT_TEST (test_quad_basic_mid_spin)
 CPPUNIT_TEST (test_quad_basic_mid_convex)
 CPPUNIT_TEST (test_quad_basic_left_down)
 CPPUNIT_TEST (test_quad_basic_top_down)
 CPPUNIT_TEST (test_quad_basic_right_up)
 CPPUNIT_TEST (test_quad_basic_left_over)
 CPPUNIT_TEST (test_tet_basic_ideal)
 CPPUNIT_TEST (test_tet_basic_mid_spin)
 CPPUNIT_TEST (test_tet_basic_mid_convex)
 CPPUNIT_TEST (test_tet_basic_apex_up)
 CPPUNIT_TEST (test_tet_basic_apex_down)
 CPPUNIT_TEST (test_tet_basic_apex_over)
 CPPUNIT_TEST (test_hex_basic)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
HexLagrangeShape hex_shape
InstructionQueue q
TShapeSizeNB3 tm
IdealShapeTarget tc
TQualityMetric metric
PMeanPTemplate func
SteepestDescent solver
TerminationCriterion crit
TerminationCriterion outer
Detailed Description
Definition at line 75 of file HigherOrderTest.cpp.
Definition at line 122 of file HigherOrderTest.cpp.
References MAX_ITERATIONS, MBMesquite::outer(), and MBMesquite::Settings::SLAVE_NONE.
                      : metric( &tc, &tm ), func( 1, &metric ), solver( &func )
        MsqError err;
//    q.set_mapping_function( &tri_shape );
//    q.set_mapping_function( &tet_shape );
//    q.set_mapping_function( &quad_shape );
#ifdef HAVE_HO_HEX
        q.set_mapping_function( &hex_shape );
#endif
        q.set_master_quality_improver( &solver, err );
        q.set_slaved_ho_node_mode( Settings::SLAVE_NONE );
        outer.add_iteration_limit( 1 );
        crit.add_absolute_vertex_movement( 1e-6 );
        crit.add_iteration_limit( MAX_ITERATIONS );
        solver.set_outer_termination_criterion( &outer );
        solver.set_inner_termination_criterion( &crit );
Member Function Documentation
void HigherOrderTest::basic_hex_test ( Vector3D p4,
Vector3D p5,
Vector3D p6,
Vector3D p7,
Vector3D p8,
Vector3D p9,
Vector3D p10,
Vector3D p11,
Vector3D p12,
Vector3D p13,
Vector3D p14,
Vector3D p15,
Vector3D p16,
Vector3D p17,
Vector3D p18,
Vector3D p19,
MsqError err
Definition at line 1038 of file HigherOrderTest.cpp.
References conn, CPPUNIT_ASSERT, fixed, MBMesquite::HEXAHEDRON, mesh, MSQ_ERRRTN, MBMesquite::Vector3D::set(), MBMesquite::Vector3D::x(), MBMesquite::Vector3D::y(), and MBMesquite::Vector3D::z().
    // Construct Mesh instance
    const int DIM             = 3;
    const int NVTX            = 20;
    const int NELEM           = 1;
    double coords[DIM * NVTX] = { 0.0,     0.0,     0,       2.0,     0.0,     0,       2.0,     2.0,     0,
                                  0.0,     2.0,     0,       p4.x(),  p4.y(),  p4.z(),  p5.x(),  p5.y(),  p5.z(),
                                  p6.x(),  p6.y(),  p6.z(),  p7.x(),  p7.y(),  p7.z(),  p8.x(),  p8.y(),  p8.z(),
                                  p9.x(),  p9.y(),  p9.z(),  p10.x(), p10.y(), p10.z(), p11.x(), p11.y(), p11.z(),
                                  p12.x(), p12.y(), p12.z(), p13.x(), p13.y(), p13.z(), p14.x(), p14.y(), p14.z(),
                                  p15.x(), p15.y(), p15.z(), p16.x(), p16.y(), p16.z(), p17.x(), p17.y(), p17.z(),
                                  p18.x(), p18.y(), p18.z(), p19.x(), p19.y(), p19.z() };
    const int fixed[NVTX]     = { 1, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
    const unsigned long conn[NVTX * NELEM] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19 };
    ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, HEXAHEDRON, conn, false, NVTX );
    // Solve
    q.run_instructions( &mesh, err );MSQ_ERRRTN( err );
    CPPUNIT_ASSERT( !hit_iteration_limit() );
    // Pass back modified coordinates
    p4.set( coords + 4 * DIM );
    p5.set( coords + 5 * DIM );
    p6.set( coords + 6 * DIM );
    p7.set( coords + 7 * DIM );
    p8.set( coords + 8 * DIM );
    p9.set( coords + 9 * DIM );
    p10.set( coords + 10 * DIM );
    p11.set( coords + 11 * DIM );
    p12.set( coords + 12 * DIM );
    p13.set( coords + 13 * DIM );
    p14.set( coords + 14 * DIM );
    p15.set( coords + 15 * DIM );
    p16.set( coords + 16 * DIM );
    p17.set( coords + 17 * DIM );
    p18.set( coords + 18 * DIM );
    p19.set( coords + 19 * DIM );
void HigherOrderTest::basic_quad_test ( Vector3D p2,
Vector3D p3,
Vector3D p4,
Vector3D p5,
Vector3D p6,
Vector3D p7,
MsqError err
Definition at line 1002 of file HigherOrderTest.cpp.
References ASSERT_NO_ERROR, conn, CPPUNIT_ASSERT, fixed, mesh, QEL, MBMesquite::QUADRILATERAL, MBMesquite::Vector3D::set(), MBMesquite::Vector3D::x(), MBMesquite::PlanarDomain::XY, MBMesquite::Vector3D::y(), and MBMesquite::Vector3D::z().
    const int DIM             = 3;
    const int NVTX            = 8;
    double coords[DIM * NVTX] = { 0.0,    0.0,    0.0,    QEL,    0.0,    0.0,    p2.x(), p2.y(),
                                  p2.z(), p3.x(), p3.y(), p3.z(), p4.x(), p4.y(), p4.z(), p5.x(),
                                  p5.y(), p5.z(), p6.x(), p6.y(), p6.z(), p7.x(), p7.y(), p7.z() };
    const int fixed[NVTX]                  = { 1, 1, 0, 0, 0, 0, 0, 0 };
    const unsigned long conn[NVTX * NELEM] = { 0, 1, 2, 3, 4, 5, 6, 7 };
    ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, QUADRILATERAL, conn, false, NVTX );
    PlanarDomain xy( PlanarDomain::XY );
    // Solve
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &xy );
    q.run_instructions( &mesh_and_domain, err );
    ASSERT_NO_ERROR( err );
    p2.set( coords + 2 * DIM );
    p3.set( coords + 3 * DIM );
void HigherOrderTest::basic_tet_test ( Vector3D p3,
Vector3D p4,
Vector3D p5,
Vector3D p6,
Vector3D p7,
Vector3D p8,
Vector3D p9,
MsqError err
Definition at line 965 of file HigherOrderTest.cpp.
References conn, fixed, IDEAL_TET_BASE, IDEAL_TET_SIDE, mesh, MSQ_ERRRTN, MBMesquite::Vector3D::set(), MBMesquite::TETRAHEDRON, MBMesquite::Vector3D::x(), MBMesquite::Vector3D::y(), and MBMesquite::Vector3D::z().
    const int DIM   = 3;
    const int NVTX  = 10;
    const Vector3D p0( 0.0, 0.0, 0.0 );
    const Vector3D p1( IDEAL_TET_SIDE, 0.0, 0.0 );
    const Vector3D p2( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE, 0.0 );
    double coords[DIM * NVTX] = { p0.x(), p0.y(), p0.z(), p1.x(), p1.y(), p1.z(), p2.x(), p2.y(), p2.z(), p3.x(),
                                  p3.y(), p3.z(), p4.x(), p4.y(), p4.z(), p5.x(), p5.y(), p5.z(), p6.x(), p6.y(),
                                  p6.z(), p7.x(), p7.y(), p7.z(), p8.x(), p8.y(), p8.z(), p9.x(), p9.y(), p9.z() };
    const int fixed[NVTX]                  = { 1, 1, 1, 0, 0, 0, 0, 0, 0, 0 };
    const unsigned long conn[NVTX * NELEM] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9 };
    ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, TETRAHEDRON, conn, false, NVTX );
    // Solve
void HigherOrderTest::basic_tri_test ( double &  x2,
double &  y2,
double &  x3,
double &  y3,
double &  x4,
double &  y4,
double &  x5,
double &  y5,
MsqError err
Definition at line 928 of file HigherOrderTest.cpp.
References conn, fixed, IDEAL_TRI_SIDE, mesh, MSQ_ERRRTN, MBMesquite::TRIANGLE, and MBMesquite::PlanarDomain::XY.
    const int DIM             = 3;
    const int NVTX            = 6;
    double coords[DIM * NVTX] = { 0., 0., 0, IDEAL_TRI_SIDE, 0., 0, x2, y2, 0, x3, y3, 0, x4, y4, 0, x5, y5, 0 };
    const int fixed[NVTX]     = { 1, 1, 0, 0, 0, 0 };
        0, 1, 2, 3, 4, 5,
    ArrayMesh mesh( DIM, NVTX, coords, fixed, NELEM, TRIANGLE, conn, false, NVTX );
    // Solve
    q.run_instructions( &mesh_and_domain, err );MSQ_ERRRTN( err );
    x2 = coords[2 * DIM + 0];
    y2 = coords[2 * DIM + 1];
    x3 = coords[3 * DIM + 0];
    y3 = coords[3 * DIM + 1];
    x4 = coords[4 * DIM + 0];
    y4 = coords[4 * DIM + 1];
    x5 = coords[5 * DIM + 0];
    y5 = coords[5 * DIM + 1];
bool HigherOrderTest::hit_iteration_limit ( ) const [inline]
Definition at line 142 of file HigherOrderTest.cpp.
References MAX_ITERATIONS.
Definition at line 832 of file HigherOrderTest.cpp.
References ASSERT_NO_ERROR, conn, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::EPSILON, fixed, MBMesquite::HEXAHEDRON, and MBMesquite::P.
    MsqError err;
    const double P              = 0.25;  // fraction to perturb higher-order nodes: 0.5->optimal
    const double Q              = 1 - P;
    const double EPSILON        = 1e-4;
    const unsigned long num_vtx = 27;
    // Define a 27-node hex with corner nodes fixed and higher-order
    // nodes perturbed a bit.  Smooth to see if HO nodes are moved
    // to center of edge/face/volume.
    double coords[3 * num_vtx] = { // bottom corners
                                   0, 0, 0, 1, 0, 0, 1, 1, 0, 0, 1, 0,
                                   // top corners
                                   0, 0, 1, 1, 0, 1, 1, 1, 1, 0, 1, 1,
                                   // bottom mid-edge
                                   P, 0, 0, 1, Q, 0, Q, 1, 0, 0, P, 0,
                                   // vertical mid-edge
                                   0, 0, P, 1, 0, P, 1, 1, Q, 0, 1, Q,
                                   // top mid-edge
                                   Q, 0, 1, 1, P, 1, P, 1, 1, 0, Q, 1,
                                   // vertical faces
                                   P, 0, Q, 1, Q, P, Q, 1, P, 0, P, Q,
                                   // bottom and top mid-face
                                   P, Q, 0, Q, P, 1,
                                   // mid-element
                                   P, Q, P };
    unsigned long conn[num_vtx];
    for( unsigned i = 0; i < num_vtx; i++ )
        conn[i] = i;
    int fixed[num_vtx];
    std::fill( fixed, fixed + 8, 1 );
    std::fill( fixed + 8, fixed + num_vtx, 0 );
    const EntityTopology type = HEXAHEDRON;
    unsigned long offsets[]   = { 0, num_vtx };
    ArrayMesh one_hex( 3, num_vtx, coords, fixed, 1, &type, conn, offsets );
    // smooth
    q.run_instructions( &one_hex, err );
    // test that higher-order nodes were moved to the expected locations
    // bottom mid-edge
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.0, 0 ), Vector3D( coords + 3 * 8 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1.0, 0.5, 0 ), Vector3D( coords + 3 * 9 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 1.0, 0 ), Vector3D( coords + 3 * 10 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.0, 0.5, 0 ), Vector3D( coords + 3 * 11 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 0.5 ), Vector3D( coords + 3 * 12 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1, 0, 0.5 ), Vector3D( coords + 3 * 13 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1, 1, 0.5 ), Vector3D( coords + 3 * 14 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 1, 0.5 ), Vector3D( coords + 3 * 15 ), EPSILON );
    // top mid-edge
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.0, 1 ), Vector3D( coords + 3 * 16 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1.0, 0.5, 1 ), Vector3D( coords + 3 * 17 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 1.0, 1 ), Vector3D( coords + 3 * 18 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.0, 0.5, 1 ), Vector3D( coords + 3 * 19 ), EPSILON );
    // vertical faces
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.0, 0.5 ), Vector3D( coords + 3 * 20 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1.0, 0.5, 0.5 ), Vector3D( coords + 3 * 21 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 1.0, 0.5 ), Vector3D( coords + 3 * 22 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.0, 0.5, 0.5 ), Vector3D( coords + 3 * 23 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.5, 0 ), Vector3D( coords + 3 * 24 ), EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.5, 1 ), Vector3D( coords + 3 * 25 ), EPSILON );
    // mid-element
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0.5, 0.5, 0.5 ), Vector3D( coords + 3 * 26 ), EPSILON );
Definition at line 464 of file HigherOrderTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, eps, get_ideal_quad(), QEL, quad_all_in_xy_plane(), and quad_mid_edge_nodes_edge_center().
    MsqPrintError err( cerr );
    const double eps = 5e-2;
    Vector3D p2, p3, p4, p5, p6, p7;
    const Vector3D p1( QEL, 0.0, 0.0 );
    // try starting with the optimal result
    get_ideal_quad( p2, p3, p4, p5, p6, p7 );
    basic_quad_test( p2, p3, p4, p5, p6, p7, err );
    CPPUNIT_ASSERT_EQUAL( 0, quad_all_in_xy_plane( p2, p3, p4, p5, p6, p7, eps ) );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( QEL, QEL, 0 ), p2, eps );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, QEL, 0 ), p3, eps );
    int midok = quad_mid_edge_nodes_edge_center( p2, p3, p4, p5, p6, p7, eps );
    CPPUNIT_ASSERT_EQUAL( 0, midok );
Definition at line 538 of file HigherOrderTest.cpp.
    // try moving the top left vertex down, also move mid-edge nodes proportionally
    p3 -= Vector3D( 0.0, 0.0, QEL / 2 );
    p6 = 0.5 * ( p2 + p3 );
    p7 = 0.5 * ( p0 + p3 );
Definition at line 609 of file HigherOrderTest.cpp.
    // try moving the top left vertex to the right, also move mid-edge nodes proportionally
    p3 -= Vector3D( QEL / 2, 0.0, 0.0 );
Definition at line 512 of file HigherOrderTest.cpp.
    // try square corners with all egdes convex
    p4 += Vector3D( 0.0, -0.2 * QEL, 0 );
    p5 += Vector3D( 0.2 * QEL, 0.0, 0 );
    p6 += Vector3D( 0.0, 0.2 * QEL, 0 );
    p7 += Vector3D( -0.2 * QEL, 0.0, 0 );
    //  crit.write_mesh_steps( "quad_basic_mid_convex", TerminationCriterion::VTK );
    //  crit.write_mesh_steps( "", TerminationCriterion::NOTYPE );
Definition at line 484 of file HigherOrderTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, eps, QEL, quad_all_in_xy_plane(), quad_mid_edge_nodes_edge_center(), and MBMesquite::Vector3D::set().
    // try moving the mid-edge nodes along the edge away from the edge center
    p2.set( QEL, QEL, 0 );
    p3.set( 0, QEL, 0 );
    double f = 0.4;
    p4       = f * p0 + ( 1 - f ) * p1;
    p5       = f * p1 + ( 1 - f ) * p2;
    p6       = f * p2 + ( 1 - f ) * p3;
    p7       = f * p3 + ( 1 - f ) * p0;
    //  crit.write_mesh_steps( "quad_basic_mid_spin", TerminationCriterion::VTK );
Definition at line 586 of file HigherOrderTest.cpp.
    // try moving the top right vertex up, also move mid-edge nodes proportionally
    p2 += Vector3D( 0.0, QEL * 2, 0.0 );
    p5 = 0.5 * ( p1 + p2 );
Definition at line 561 of file HigherOrderTest.cpp.
    // try moving the top two vertices down, also move mid-edge nodes proportionally
    p2 -= Vector3D( 0.0, QEL / 2, 0.0 );
    p3 -= Vector3D( 0.0, QEL / 2, 0.0 );
Definition at line 760 of file HigherOrderTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, eps, get_ideal_tet(), IDEAL_TET_BASE, IDEAL_TET_HEIGHT, IDEAL_TET_SIDE, and tet_mid_edge_nodes_edge_center().
    const Vector3D p3eq( 0.5 * IDEAL_TET_SIDE, IDEAL_TET_BASE / 3.0, IDEAL_TET_HEIGHT );
    Vector3D p3, p4, p5, p6, p7, p8, p9;
    // try moving the top vertex down, also move mid-edge nodes proportionally
    get_ideal_tet( p3, p4, p5, p6, p7, p8, p9 );
    p3 -= Vector3D( 0.0, 0.0, 0.5 );
    p7 -= Vector3D( 0.0, 0.0, 0.25 );
    p8 -= Vector3D( 0.0, 0.0, 0.25 );
    p9 -= Vector3D( 0.0, 0.0, 0.25 );
    basic_tet_test( p3, p4, p5, p6, p7, p8, p9, err );
    CPPUNIT_ASSERT_VECTORS_EQUAL( p3eq, p3, eps );
    int midok = tet_mid_edge_nodes_edge_center( p3, p4, p5, p6, p7, p8, p9, eps );
Definition at line 808 of file HigherOrderTest.cpp.
    // try moving the top vertex to the right, also move mid-edge nodes proportionally
    p3 -= Vector3D( 0.3, 0.0, 0.0 );
    p8 = 0.5 * ( p1 + p3 );
    p9 = 0.5 * ( p2 + p3 );
Definition at line 784 of file HigherOrderTest.cpp.
    // try moving the top vertex up, also move mid-edge nodes proportionally
    p3 += Vector3D( 0.0, 0.0, 3.0 );
    p7 += Vector3D( 0.0, 0.0, 1.5 );
    p8 += Vector3D( 0.0, 0.0, 1.5 );
    p9 += Vector3D( 0.0, 0.0, 1.5 );
Definition at line 688 of file HigherOrderTest.cpp.
Definition at line 734 of file HigherOrderTest.cpp.
    // try equilateral corners with all egdes convex
    p4 += Vector3D( 0.0, -0.2, -0.2 );
    p5 += Vector3D( 0.2, 0.2, -0.2 );
    p6 += Vector3D( -0.2, 0.2, -0.2 );
    p7 += Vector3D( -0.2, -0.2, 0.2 );
    p8 += Vector3D( 0.2, -0.2, 0.2 );
    p9 += Vector3D( 0.0, 0.2, 0.2 );
Definition at line 708 of file HigherOrderTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, eps, IDEAL_TET_BASE, IDEAL_TET_HEIGHT, IDEAL_TET_SIDE, and tet_mid_edge_nodes_edge_center().
    p3 = p3eq;
    p4 = 0.6 * p0 + 0.4 * p1;
    p5 = 0.6 * p1 + 0.4 * p2;
    p6 = 0.6 * p2 + 0.4 * p0;
    p7 = 0.6 * p0 + 0.4 * p3;
    p8 = 0.4 * p1 + 0.6 * p3;
    p9 = 0.3 * p2 + 0.7 * p3;
Definition at line 257 of file HigherOrderTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, eps, IDEAL_TRI_HEIGHT, IDEAL_TRI_SIDE, and tri_mid_edge_nodes_edge_center().
    const double eps  = 1e-4;
    const double x2eq = 0.5 * IDEAL_TRI_SIDE;
    const double y2eq = IDEAL_TRI_HEIGHT;
    double x2 = x2eq;
    double y2 = y2eq;
    double x3 = 0.5 * IDEAL_TRI_SIDE;
    double y3 = 0.0;
    double x4 = 0.75 * IDEAL_TRI_SIDE;
    double y4 = 0.5 * IDEAL_TRI_HEIGHT;
    double x5 = 0.25 * IDEAL_TRI_SIDE;
    double y5 = 0.5 * IDEAL_TRI_HEIGHT;
    //  crit.write_mesh_steps( "test_tri_basic_ideal", TerminationCriterion::VTK );
    basic_tri_test( x2, y2, x3, y3, x4, y4, x5, y5, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( x2eq, x2, eps );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( y2eq, y2, eps );
    int midok = tri_mid_edge_nodes_edge_center( x2, y2, x3, y3, x4, y4, x5, y5, eps );
Definition at line 314 of file HigherOrderTest.cpp.
    double x2 = x2eq;
    double y2 = y2eq;
    double y3 = -0.3;
    double x4 = IDEAL_TRI_SIDE;
    double y4 = 0.5;
    double x5 = 0.0;
    double y5 = 0.5;
    // CPPUNIT_ASSERT_DOUBLES_EQUAL( y2eq, y2, eps );
Definition at line 284 of file HigherOrderTest.cpp.
    double x0 = 0.0, y0 = 0.0;
    double x1 = IDEAL_TRI_SIDE, y1 = 0.0;
    double x2      = x2eq;
    double y2      = y2eq;
    const double f = 0.7;
    double x3      = f * x0 + ( 1 - f ) * x1;
    double y3      = f * y0 + ( 1 - f ) * y1;
    double x4      = f * x1 + ( 1 - f ) * x2;
    double y4      = f * y1 + ( 1 - f ) * y2;
    double x5      = f * x2 + ( 1 - f ) * x0;
    double y5      = f * y2 + ( 1 - f ) * y0;
    // crit.write_mesh_steps( "test_tri_basic_mid_spin", TerminationCriterion::VTK );
Definition at line 364 of file HigherOrderTest.cpp.
    double x2 = x2eq;
    double y2 = 0.5 * y2eq;
    double y3 = 0.0;
    double x4 = 1.5 * x2;
    double y4 = 0.5 * y2;
    double x5 = 0.5 * x2;
    double y5 = 0.5 * y2;
Definition at line 389 of file HigherOrderTest.cpp.
    double x2 = x2eq + 0.5;
    double y2 = y2eq;
    double y3 = 0.0;
Definition at line 339 of file HigherOrderTest.cpp.
    double x2 = x2eq;
    double y2 = 2.0 * y2eq;
    double y3 = 0.0;
Definition at line 1178 of file HigherOrderTest.cpp.
References CPPUNIT_ASSERT_DOUBLES_EQUAL.
    double x1 = 2;
    double y2 = 2;
    double x3 = 1;
    double y5 = 1;
    double x4 = 1;
    double y4 = 1;
    test_tri_open_domain( x1, x3, x4, y2, y5, y4 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 2.0, x1, 1e-3 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 2.0, y2, 1e-3 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, x3, 1e-3 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, x4, 1e-3 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 1.0, y4, 1e-3 );
void HigherOrderTest::test_tri_open_domain ( double &  x1,
double &  x3,
double &  x4,
double  y2,
double  y5,
double &  y4
Definition at line 1119 of file HigherOrderTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::DomainClassifier::classify_by_handle(), conn, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::DomainClassifier::DomainSet::elements, fixed, geom, MBMesquite::ArrayMesh::get_all_elements(), MBMesquite::ArrayMesh::get_all_vertices(), mesh, MBMesquite::TRIANGLE, MBMesquite::DomainClassifier::DomainSet::vertices, and MBMesquite::PlanarDomain::XY.
    // Validate input
    CPPUNIT_ASSERT( x3 < x1 );
    CPPUNIT_ASSERT( y5 < y2 );
    CPPUNIT_ASSERT( x3 > 0.0 );
    CPPUNIT_ASSERT( y5 > 0.0 );
    const int DIM                          = 3;
    const int NVTX                         = 6;
    double coords[DIM * NVTX]              = { 0, 0, 0, x1, 0, 0, 0, y2, 0, x3, 0, 0, x4, y4, 0, 0, y5, 0 };
    const int fixed[NVTX]                  = { 1, 0, 1, 0, 0, 0 };
        0, 1, 2, 3, 4, 5,
    // Construct Geometry
    LineDomain xaxis( Vector3D( 0, 0, 0 ), Vector3D( 1, 0, 0 ) );
    LineDomain yaxis( Vector3D( 0, 0, 0 ), Vector3D( 0, 1, 0 ) );
    PlanarDomain xyplane( PlanarDomain::XY );
    DomainClassifier::DomainSet sets[] = { &xaxis, &yaxis, &xyplane };
    vector< Mesh::VertexHandle > verts;
    vector< Mesh::ElementHandle > elems;
    mesh.get_all_vertices( verts, err );
    mesh.get_all_elements( elems, err );
    CPPUNIT_ASSERT_EQUAL( (size_t)1, elems.size() );
    // Associate mesh with geometry
    sets[0].vertices.push_back( verts[1] );
    sets[0].vertices.push_back( verts[3] );
    sets[1].vertices.push_back( verts[2] );
    sets[1].vertices.push_back( verts[5] );
    sets[2].elements.push_back( elems[0] );
    sets[2].vertices.push_back( verts[4] );
    DomainClassifier geom;
    DomainClassifier::classify_by_handle( geom, &mesh, sets, 3, err );
    // Solve
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &geom );
    // Pass back modified coordinate values
    x1 = coords[DIM * 1 + 0];
    x3 = coords[DIM * 3 + 0];
    x4 = coords[DIM * 4 + 0];
    y4 = coords[DIM * 4 + 1];
Definition at line 1225 of file HigherOrderTest.cpp.
References ASSERT_NO_ERROR, conn, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, fixed, MBMesquite::length(), mesh, MBMesquite::TRIANGLE, MBMesquite::Vector3D::x(), MBMesquite::PlanarDomain::XY, and MBMesquite::Vector3D::y().
    const int DIM                          = 3;
    const int NVTX                         = 6;
    double coords[DIM * NVTX]              = { 0.00, 0.00, 0, 1.00, 0.00, 0, 0.50, 10.0, 0,
                                  0.50, 0.30, 0, 0.75, 4.50, 0, 0.25, 4.50, 0 };
    const int fixed[NVTX]                  = { 1, 1, 0, 1, 0, 0 };
        0, 1, 2, 3, 4, 5,
    // Solve
    const Vector3D v0( coords + 0 * DIM );
    const Vector3D v1( coords + 1 * DIM );
    const Vector3D v2( coords + 2 * DIM );
    const Vector3D v3( coords + 3 * DIM );
    const Vector3D v4( coords + 4 * DIM );
    const Vector3D v5( coords + 5 * DIM );
    // Expect vertex 2 to have moved downwards signficantly
    CPPUNIT_ASSERT( v2.y() < 2.0 );
    CPPUNIT_ASSERT( v2.y() > 0.5 );
    // Expect it to have stayed in the center along the X axis
    CPPUNIT_ASSERT_DOUBLES_EQUAL( 0.5, v2.x(), 1e-3 );
    // Expect free mid-edge nodes to be "between" adjacent corners
    CPPUNIT_ASSERT( v4.x() > 0.5 );
    CPPUNIT_ASSERT( v4.x() < 1.0 );
    CPPUNIT_ASSERT( v5.x() > 0.0 );
    CPPUNIT_ASSERT( v5.x() < 0.5 );
    // Expect two free mid-edge nodes to be slightly above the
    // line between adjacent corners (slightly convex edge)
    // because the fixed mid-edge node on the bottom is moved upward
    Vector3D m12 = v2 - v1;
    Vector3D m02 = v2 - v0;
    double t1    = ( m12 % ( v4 - v0 ) ) / ( m12 % m12 );
    double t2    = ( m02 % ( v5 - v0 ) ) / ( m02 % m02 );
    Vector3D l4  = v0 * t1 * m12;  // closed point to v4 on line v1,v2
    Vector3D l5  = v0 * t2 * m02;  // closed point to v5 on line v0,v2
                                   // Check not to far from line
    CPPUNIT_ASSERT( ( l4 - v4 ).length() < 0.1 );
    CPPUNIT_ASSERT( ( l5 - v5 ).length() < 0.1 );
    // Check that edges are convex
    CPPUNIT_ASSERT( l4.x() < v4.x() );
    CPPUNIT_ASSERT( l5.x() > v5.x() );
Member Data Documentation
Definition at line 119 of file HigherOrderTest.cpp.
Definition at line 117 of file HigherOrderTest.cpp.
Definition at line 111 of file HigherOrderTest.cpp.
Definition at line 116 of file HigherOrderTest.cpp.
Definition at line 113 of file HigherOrderTest.cpp.
Definition at line 118 of file HigherOrderTest.cpp.
Definition at line 115 of file HigherOrderTest.cpp.
Definition at line 114 of file HigherOrderTest.cpp.
List of all members.
