IdealWeightMeanRatioTest Class Reference
+ Inheritance diagram for IdealWeightMeanRatioTest:
+ Collaboration diagram for IdealWeightMeanRatioTest:
Public Member Functions
 IdealWeightMeanRatioTest ()
void test_supported_types ()
void test_ideal_element_eval ()
void test_ideal_element_grad ()
void test_ideal_element_hess ()
void test_valid_hessian ()
void test_measures_quality ()
void test_gradient_reflects_quality ()
void test_domain_deviation ()
void test_inverted_elements ()
void test_degenerate_elements ()
void test_get_evaluations ()
void test_get_element_indices ()
void test_get_fixed_indices ()
void test_eval_with_indices ()
void test_eval_with_gradient ()
void test_eval_with_hessian ()
void test_eval_with_hessian_diagonal ()
void test_location_invariant ()
void test_scale_invariant ()
void test_orient_invariant ()
Private Member Functions
 CPPUNIT_TEST_SUITE (IdealWeightMeanRatioTest)
 CPPUNIT_TEST (test_supported_types)
 CPPUNIT_TEST (test_ideal_element_eval)
 CPPUNIT_TEST (test_ideal_element_grad)
 CPPUNIT_TEST (test_ideal_element_hess)
 CPPUNIT_TEST (test_valid_hessian)
 CPPUNIT_TEST (test_measures_quality)
 CPPUNIT_TEST (test_gradient_reflects_quality)
 CPPUNIT_TEST (test_domain_deviation)
 CPPUNIT_TEST (test_inverted_elements)
 CPPUNIT_TEST (test_degenerate_elements)
 CPPUNIT_TEST (test_get_evaluations)
 CPPUNIT_TEST (test_get_element_indices)
 CPPUNIT_TEST (test_get_fixed_indices)
 CPPUNIT_TEST (test_eval_with_indices)
 CPPUNIT_TEST (test_eval_with_gradient)
 CPPUNIT_TEST (test_eval_with_hessian)
 CPPUNIT_TEST (test_eval_with_hessian_diagonal)
 CPPUNIT_TEST (test_location_invariant)
 CPPUNIT_TEST (test_scale_invariant)
 CPPUNIT_TEST (test_orient_invariant)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
IdealWeightMeanRatio mMetric
QualityMetricTester tester
Detailed Description
Definition at line 39 of file IdealWeightMeanRatioTest.cpp.
Member Function Documentation
Member Data Documentation
List of all members.
