MOAB: Mesh Oriented datABase
(version 5.4.1)
Public Member Functions | |
ConstantTarget (MsqMatrix< 3, 3 > val3D, MsqMatrix< 3, 2 > val2D) | |
ConstantTarget (MsqMatrix< 3, 3 > val3D, MsqMatrix< 2, 2 > val2D) | |
ConstantTarget (double C, bool surf) | |
ConstantTarget (MsqMatrix< 3, 3 > val3D) | |
ConstantTarget (MsqMatrix< 3, 2 > val2D) | |
ConstantTarget (MsqMatrix< 2, 2 > val2D) | |
virtual bool | get_3D_target (PatchData &, size_t, Sample, MsqMatrix< 3, 3 > &result, MsqError &err) |
Get a target matrix. | |
virtual bool | get_surface_target (PatchData &, size_t, Sample, MsqMatrix< 3, 2 > &result, MsqError &err) |
virtual bool | get_2D_target (PatchData &, size_t, Sample, MsqMatrix< 2, 2 > &result, MsqError &err) |
virtual bool | have_surface_orient () const |
Use 3x2 W for surface elements if true, 2x2 W if false. | |
Private Attributes | |
MsqMatrix< 3, 3 > | target3D |
MsqMatrix< 3, 2 > | targetSurf |
MsqMatrix< 2, 2 > | target2D |
bool | have3D |
bool | haveSurf |
bool | have2D |
bool | flagError |
Definition at line 97 of file LVQDTargetTest.cpp.
LVQDTargetTest::ConstantTarget::ConstantTarget | ( | MsqMatrix< 3, 3 > | val3D, |
MsqMatrix< 3, 2 > | val2D | ||
) | [inline] |
Definition at line 107 of file LVQDTargetTest.cpp.
: target3D( val3D ), targetSurf( val2D ), have3D( true ), haveSurf( true ), have2D( false ) { }
MsqMatrix< 2, 2 > | val2D | ||
) | [inline] |
LVQDTargetTest::ConstantTarget::ConstantTarget | ( | double | C, |
bool | surf | ||
) | [inline] |
LVQDTargetTest::ConstantTarget::ConstantTarget | ( | MsqMatrix< 3, 3 > | val3D | ) | [inline] |
LVQDTargetTest::ConstantTarget::ConstantTarget | ( | MsqMatrix< 3, 2 > | val2D | ) | [inline] |
Definition at line 123 of file LVQDTargetTest.cpp.
: targetSurf( val2D ), have3D( false ), haveSurf( true ), have2D( false ) { }
LVQDTargetTest::ConstantTarget::ConstantTarget | ( | MsqMatrix< 2, 2 > | val2D | ) | [inline] |
virtual bool LVQDTargetTest::ConstantTarget::get_2D_target | ( | PatchData & | pd, |
size_t | element, | ||
Sample | sample, | ||
MsqMatrix< 2, 2 > & | W_out, | ||
MsqError & | err | ||
) | [inline, virtual] |
pd | The current PatchData |
element | The index an element within the patch data. |
sample | The sample point in the element. |
W_out | The resulting target matrix. |
Implements MBMesquite::TargetCalculator.
Definition at line 146 of file LVQDTargetTest.cpp.
References CPPUNIT_ASSERT.
{ CPPUNIT_ASSERT( have2D ); result = target2D; return have2D; }
virtual bool LVQDTargetTest::ConstantTarget::get_3D_target | ( | PatchData & | pd, |
MsqMatrix< 3, 3 > & | W_out, | ||
Definition at line 132 of file LVQDTargetTest.cpp.
{ CPPUNIT_ASSERT( have3D ); result = target3D; return have3D; }
virtual bool LVQDTargetTest::ConstantTarget::get_surface_target | ( | PatchData & | pd, |
MsqMatrix< 3, 2 > & | W_out, | ||
Definition at line 139 of file LVQDTargetTest.cpp.
{ CPPUNIT_ASSERT( haveSurf ); result = targetSurf; return haveSurf; }
virtual bool LVQDTargetTest::ConstantTarget::have_surface_orient | ( | ) | const [inline, virtual] |
If true, then the targets for surface elements attempt some control of orientation and therefore get_surface_target must be used to get the targets. If false, then the target contains no orientation data and is therefore the same as the corresponding 2D target for surface elements. In this case, get_2D_target should be used.
Definition at line 153 of file LVQDTargetTest.cpp.
{ return haveSurf; }
bool LVQDTargetTest::ConstantTarget::flagError [private] |
Definition at line 104 of file LVQDTargetTest.cpp.
bool LVQDTargetTest::ConstantTarget::have2D [private] |
Definition at line 103 of file LVQDTargetTest.cpp.
bool LVQDTargetTest::ConstantTarget::have3D [private] |
bool LVQDTargetTest::ConstantTarget::haveSurf [private] |
MsqMatrix< 2, 2 > LVQDTargetTest::ConstantTarget::target2D [private] |
Definition at line 102 of file LVQDTargetTest.cpp.
MsqMatrix< 3, 3 > LVQDTargetTest::ConstantTarget::target3D [private] |
Definition at line 100 of file LVQDTargetTest.cpp.
MsqMatrix< 3, 2 > LVQDTargetTest::ConstantTarget::targetSurf [private] |
Definition at line 101 of file LVQDTargetTest.cpp.
