MBMesquite::ConditionNumberQualityMetric Class Reference
Computes the condition number of given element. More...
#include <ConditionNumberQualityMetric.hpp>
+ Inheritance diagram for MBMesquite::ConditionNumberQualityMetric:
+ Collaboration diagram for MBMesquite::ConditionNumberQualityMetric:
Public Member Functions
MESQUITE_EXPORT ConditionNumberQualityMetric ()
virtual MESQUITE_EXPORT ~ConditionNumberQualityMetric ()
 virtual destructor ensures use of polymorphism during destruction
virtual MESQUITE_EXPORT std::string get_name () const
virtual MESQUITE_EXPORT int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
virtual MESQUITE_EXPORT bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
Detailed Description
The metric does not use the sample point functionality or the compute_weighted_jacobian. It evaluates the metric at the element vertices, and uses the isotropic ideal element. It does require a feasible region, and the metric needs to be minimized.
Definition at line 56 of file ConditionNumberQualityMetric.hpp.
Definition at line 62 of file ConditionNumberQualityMetric.hpp.
Member Function Documentation
bool ConditionNumberQualityMetric::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 54 of file ConditionNumberQualityMetric.cpp.
References MBMesquite::AveragingQM::average_metrics(), MBMesquite::condition_number_2d(), MBMesquite::condition_number_3d(), MBMesquite::PatchData::element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::HEXAHEDRON, MSQ_ERRZERO, MBMesquite::MSQ_MAX_CAP, MBMesquite::MSQ_MAX_NUM_VERT_PER_ENT, MSQ_SETERR, MBMesquite::MSQ_SQRT_THREE, MBMesquite::MSQ_SQRT_THREE_INV, MBMesquite::MSQ_SQRT_TWO, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
    const MsqMeshEntity* const element = &pd.element_by_index( handle );
    bool return_flag;
    double met_vals[MSQ_MAX_NUM_VERT_PER_ENT];
    fval              = MSQ_MAX_CAP;
    const size_t* v_i = element->get_vertex_index_array();
    // only 3 temp_vec will be sent to cond-num calculator, but the
    // additional vector3Ds may be needed during the calculations
    Vector3D temp_vec[6];
    const MsqVertex* vertices = pd.get_vertex_array( err );
    EntityTopology type       = element->get_element_type();
    switch( type )
        case TRIANGLE:
            temp_vec[0] = vertices[v_i[1]] - vertices[v_i[0]];
            temp_vec[2] = vertices[v_i[2]] - vertices[v_i[0]];
            // make relative to equilateral
            temp_vec[1] = ( ( 2 * temp_vec[2] ) - temp_vec[0] ) * MSQ_SQRT_THREE_INV;
            return_flag = condition_number_2d( temp_vec, handle, pd, fval, err );
            MSQ_ERRZERO( err );
            return return_flag;
        case QUADRILATERAL:
            temp_vec[1] = vertices[v_i[3]] - vertices[v_i[0]];
            return_flag = condition_number_2d( temp_vec, handle, pd, met_vals[0], err );
            MSQ_ERRZERO( err );
            if( !return_flag ) return return_flag;
            temp_vec[0] = vertices[v_i[2]] - vertices[v_i[1]];
            temp_vec[1] = vertices[v_i[0]] - vertices[v_i[1]];
            return_flag = condition_number_2d( temp_vec, handle, pd, met_vals[1], err );
            MSQ_ERRZERO( err );
            temp_vec[0] = vertices[v_i[3]] - vertices[v_i[2]];
            temp_vec[1] = vertices[v_i[1]] - vertices[v_i[2]];
            return_flag = condition_number_2d( temp_vec, handle, pd, met_vals[2], err );
            MSQ_ERRZERO( err );
            temp_vec[0] = vertices[v_i[0]] - vertices[v_i[3]];
            temp_vec[1] = vertices[v_i[2]] - vertices[v_i[3]];
            return_flag = condition_number_2d( temp_vec, handle, pd, met_vals[3], err );
            MSQ_ERRZERO( err );
            fval = average_metrics( met_vals, 4, err );
            return return_flag;
        case TETRAHEDRON:
            temp_vec[3] = vertices[v_i[2]] - vertices[v_i[0]];
            temp_vec[4] = vertices[v_i[3]] - vertices[v_i[0]];
            // transform to equilateral tet
            temp_vec[1] = ( ( 2 * temp_vec[3] ) - temp_vec[0] ) / MSQ_SQRT_THREE;
            temp_vec[2] = ( ( 3 * temp_vec[4] ) - temp_vec[0] - temp_vec[3] ) / ( MSQ_SQRT_THREE * MSQ_SQRT_TWO );
            return_flag = condition_number_3d( temp_vec, pd, fval, err );
            MSQ_ERRZERO( err );
            return return_flag;
        case HEXAHEDRON:
            // transform to v_i[0]
            temp_vec[2] = vertices[v_i[4]] - vertices[v_i[0]];
            return_flag = condition_number_3d( temp_vec, pd, met_vals[0], err );
            MSQ_ERRZERO( err );
            temp_vec[2] = vertices[v_i[5]] - vertices[v_i[1]];
            return_flag = condition_number_3d( temp_vec, pd, met_vals[1], err );
            MSQ_ERRZERO( err );
            temp_vec[2] = vertices[v_i[6]] - vertices[v_i[2]];
            return_flag = condition_number_3d( temp_vec, pd, met_vals[2], err );
            MSQ_ERRZERO( err );
            temp_vec[2] = vertices[v_i[7]] - vertices[v_i[3]];
            return_flag = condition_number_3d( temp_vec, pd, met_vals[3], err );
            MSQ_ERRZERO( err );
            temp_vec[0] = vertices[v_i[7]] - vertices[v_i[4]];
            temp_vec[1] = vertices[v_i[5]] - vertices[v_i[4]];
            temp_vec[2] = vertices[v_i[0]] - vertices[v_i[4]];
            return_flag = condition_number_3d( temp_vec, pd, met_vals[4], err );
            MSQ_ERRZERO( err );
            temp_vec[0] = vertices[v_i[4]] - vertices[v_i[5]];
            temp_vec[1] = vertices[v_i[6]] - vertices[v_i[5]];
            temp_vec[2] = vertices[v_i[1]] - vertices[v_i[5]];
            return_flag = condition_number_3d( temp_vec, pd, met_vals[5], err );
            MSQ_ERRZERO( err );
            temp_vec[0] = vertices[v_i[5]] - vertices[v_i[6]];
            temp_vec[1] = vertices[v_i[7]] - vertices[v_i[6]];
            temp_vec[2] = vertices[v_i[2]] - vertices[v_i[6]];
            return_flag = condition_number_3d( temp_vec, pd, met_vals[6], err );
            MSQ_ERRZERO( err );
            temp_vec[0] = vertices[v_i[6]] - vertices[v_i[7]];
            temp_vec[1] = vertices[v_i[4]] - vertices[v_i[7]];
            temp_vec[2] = vertices[v_i[3]] - vertices[v_i[7]];
            return_flag = condition_number_3d( temp_vec, pd, met_vals[7], err );
            MSQ_ERRZERO( err );
            fval = average_metrics( met_vals, 8, err );
            MSQ_ERRZERO( err );
            return return_flag;
        case PYRAMID: {
            unsigned num_adj;
            const unsigned* adj_idx;
            return_flag = true;
            for( size_t j = 0; j < 4; ++j )  // skip fifth vertex (apex)
                adj_idx = TopologyInfo::adjacent_vertices( type, j, num_adj );
                assert( num_adj == 3 );
                temp_vec[0] = vertices[v_i[adj_idx[0]]] - vertices[v_i[j]];
                temp_vec[1] = vertices[v_i[adj_idx[1]]] - vertices[v_i[j]];
                // calculate last vect map to right tetrahedron
                temp_vec[3] = vertices[v_i[adj_idx[2]]] - vertices[v_i[adj_idx[0]]];
                temp_vec[4] = vertices[v_i[adj_idx[2]]] - vertices[v_i[adj_idx[1]]];
                temp_vec[2] = 0.5 * ( temp_vec[3] + temp_vec[4] );
                return_flag = return_flag && condition_number_3d( temp_vec, pd, met_vals[j], err );
            MSQ_ERRZERO( err );
            return return_flag;
        case PRISM: {
            unsigned num_adj;
            return_flag = true;
            for( size_t j = 0; j < 6; ++j )
                temp_vec[2] = vertices[v_i[adj_idx[2]]] - vertices[v_i[j]];
                // map to right tetrahedron
                temp_vec[1] += vertices[v_i[adj_idx[1]]];
                temp_vec[1] -= vertices[v_i[adj_idx[0]]];
                temp_vec[1] *= MSQ_SQRT_THREE_INV;
            fval = average_metrics( met_vals, 6, err );
            MSQ_ERRZERO( err );
            return return_flag;
        default:
            MSQ_SETERR( err )
            ( MsqError::UNSUPPORTED_ELEMENT, "Unsupported cell type (%d) for Condition Number quality metric.", type );
            fval = MSQ_MAX_CAP;
            return false;
    }  // end switch over element type
    return false;
std::string ConditionNumberQualityMetric::get_name ( ) const [virtual]
Definition at line 44 of file ConditionNumberQualityMetric.cpp.
Referenced by QualityAssessorTest::test_print_stats().
    return "Condition Number";
Definition at line 49 of file ConditionNumberQualityMetric.cpp.
    return 1;
List of all members.
