MBMesquite::CylinderDomain Class Reference
#include <CylinderDomain.hpp>
+ Inheritance diagram for MBMesquite::CylinderDomain:
+ Collaboration diagram for MBMesquite::CylinderDomain:
Public Member Functions
 CylinderDomain (double p_radius, Vector3D axis_direction=Vector3D(0, 0, 1), Vector3D axis_point=Vector3D(0, 0, 0), bool outward_normal=true)
virtual ~CylinderDomain ()
virtual void snap_to (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const
virtual void vertex_normal_at (Mesh::VertexHandle entity_handle, Vector3D &coordinate) const
virtual void element_normal_at (Mesh::ElementHandle entity_handle, Vector3D &coordinate) const
virtual void vertex_normal_at (const Mesh::VertexHandle *handle, Vector3D coords[], unsigned count, MsqError &err) const
 evaluate surface normals
virtual void closest_point (Mesh::VertexHandle handle, const Vector3D &position, Vector3D &closest, Vector3D &normal, MsqError &err) const
 evaluate closest point and normal
virtual void domain_DoF (const Mesh::VertexHandle *handle_array, unsigned short *dof_array, size_t count, MsqError &err) const
const Vector3Daxis () const
const Vector3Dcenter () const
double radius () const
Protected Member Functions
virtual void evaluate (Mesh::VertexHandle handle, const Vector3D &point, Vector3D &closest, Vector3D &normal) const
Private Attributes
Vector3D mAxis
Vector3D mCenter
double mRadius
double outwardSign
Detailed Description
Define the geometry of an unbounded cylinder.
Definition at line 39 of file CylinderDomain.hpp.
MBMesquite::CylinderDomain::CylinderDomain ( double  p_radius,
Vector3D  axis_direction = Vector3D( 0, 0, 1 ),
Vector3D  axis_point = Vector3D( 0, 0, 0 ),
bool  outward_normal = true
) [inline]
Parameters:
radius- Radius of the cylinder
axis_direction- Vector defining the direction of the axis
axis_point- A point through which the axis passes.
Definition at line 47 of file CylinderDomain.hpp.
        : mAxis( axis_direction / axis_direction.length() ), mCenter( axis_point ), mRadius( p_radius ),
          outwardSign( outward_normal ? 1.0 : -1.0 )
Definition at line 37 of file CylinderDomain.cpp.
Member Function Documentation
const Vector3D& MBMesquite::CylinderDomain::axis ( ) const [inline]
Definition at line 80 of file CylinderDomain.hpp.
Referenced by MBMesquite::BoundedCylinderDomain::evaluate().
        return mAxis;
const Vector3D& MBMesquite::CylinderDomain::center ( ) const [inline]
Definition at line 84 of file CylinderDomain.hpp.
        return mCenter;
void MBMesquite::CylinderDomain::closest_point ( Mesh::VertexHandle  handle,
const Vector3D position,
Vector3D closest,
Vector3D normal,
MsqError err
) const [virtual]
Given a position in space, return the closest position in the domain and the domain normal at that point.
Parameters:
entity_handleEvaluate the subset of the domain contianing this entity
positionInput position for which to evaluate
closestClosest position in the domain.
normalDomain normal at the location of 'closest'
Implements MBMesquite::MeshDomain.
Definition at line 89 of file CylinderDomain.cpp.
References evaluate().
    evaluate( handle, position, closest, normal );
void MBMesquite::CylinderDomain::domain_DoF ( const Mesh::VertexHandle handle_array,
unsigned short *  dof_array,
size_t  count,
MsqError err
) const [virtual]
Reimplemented in MBMesquite::BoundedCylinderDomain.
Definition at line 98 of file CylinderDomain.cpp.
    std::fill( dof_array, dof_array + count, (unsigned short)2 );
void MBMesquite::CylinderDomain::element_normal_at ( Mesh::ElementHandle  entity_handle,
Vector3D coordinate
) const [virtual]
Definition at line 75 of file CylinderDomain.cpp.
References evaluate(), and l.
    Vector3D p( v ), l;
    // NOTE: Explicitly invoke this class's evaluate method for elements.
    //       BoundedCylindarDomain overrides evaluate for vertices only.
    CylinderDomain::evaluate( h, p, l, v );
void MBMesquite::CylinderDomain::evaluate ( Mesh::VertexHandle  handle,
const Vector3D point,
Vector3D closest,
Vector3D normal
) const [protected, virtual]
Definition at line 39 of file CylinderDomain.cpp.
References MBMesquite::EPSILON, epsilon, MBMesquite::Vector3D::length(), MBMesquite::length(), mAxis, mCenter, mRadius, MBMesquite::Vector3D::normalize(), outwardSign, MBMesquite::Vector3D::set(), and t.
Referenced by closest_point(), element_normal_at(), snap_to(), and vertex_normal_at().
    const double EPSILON      = std::numeric_limits< double >::epsilon();
    double t                  = mAxis % ( point - mCenter );
    const Vector3D axis_point = mCenter + t * mAxis;
    normal           = point - axis_point;
    const double len = normal.length();
    if( len < EPSILON )
        Vector3D v( 1, 0, 0 );
        if( ( v * mAxis ).length() < EPSILON ) v.set( 0, 1, 0 );
        normal = v * mAxis;
        normal.normalize();
    else
        normal /= len;
    closest = axis_point + mRadius * normal;
    normal *= outwardSign;
void MBMesquite::CylinderDomain::snap_to ( Mesh::VertexHandle  entity_handle,
Vector3D coordinate
) const [virtual]
Modifies "coordinate" so that it lies on the domain to which "entity_handle" is constrained. The handle determines the domain. The coordinate is the proposed new position on that domain.
Definition at line 63 of file CylinderDomain.cpp.
References evaluate(), and n.
Referenced by BoundedCylinderDomainTest::test_x_snap_to(), and BoundedCylinderDomainTest::test_z_snap_to().
    Vector3D p( v ), n;
    evaluate( h, p, v, n );
void MBMesquite::CylinderDomain::vertex_normal_at ( Mesh::VertexHandle  entity_handle,
Vector3D coordinate
) const [virtual]
Returns the normal of the domain to which "entity_handle" is constrained. For non-planar surfaces, the normal is calculated at the point on the domain that is closest to the passed in value of "coordinate". If the domain does not have a normal, or the normal cannot be determined, "coordinate" is set to (0,0,0). Otherwise, "coordinate" is set to the domain's normal at the appropriate point. In summary, the handle determines the domain. The coordinate determines the point of interest on that domain.
User should see also PatchData::get_domain_normal_at_vertex and PatchData::get_domain_normal_at_element .
Definition at line 69 of file CylinderDomain.cpp.
Referenced by vertex_normal_at().
    Vector3D p( v ), l;
void MBMesquite::CylinderDomain::vertex_normal_at ( const Mesh::VertexHandle handles,
Vector3D  coordinates[],
unsigned  count,
MsqError err
) const [virtual]
Returns normals for a domain.
Parameters:
handlesThe domain evaluated is the one in which this mesh entity is constrained.
coordinatesAs input, a list of positions at which to evaluate the domain. As output, the resulting domain normals.
countThe length of the coordinates array.
Definition at line 83 of file CylinderDomain.cpp.
References vertex_normal_at().
    for( unsigned i = 0; i < count; ++i )
        vertex_normal_at( h[i], coords[i] );
Member Data Documentation
Definition at line 100 of file CylinderDomain.hpp.
Referenced by evaluate().
Definition at line 101 of file CylinderDomain.hpp.
Definition at line 102 of file CylinderDomain.hpp.
Definition at line 103 of file CylinderDomain.hpp.
List of all members.
