MBMesquite::ExtraUserData< T > Class Template Reference
#include <ExtraDataUser.hpp>
+ Inheritance diagram for MBMesquite::ExtraUserData< T >:
+ Collaboration diagram for MBMesquite::ExtraUserData< T >:
Public Member Functions
 ExtraUserData (PatchData &patch, ExtraDataUser< T > *owner, ExtraUserData< T > *next, const T &data)
 ExtraUserData (PatchData &patch, ExtraDataUser< T > *owner, ExtraUserData< T > *next)
virtual void notify_patch_destroyed ()
 Notify that the owning PatchData is being destroyed.
virtual void notify_new_patch ()
 Notify that the patch (mesh) in the PatchData is changing.
virtual void notify_sub_patch (PatchData &sub_patch, const size_t *vtx_index_map, const size_t *elm_index_map, MsqError &err)
 Nofity that a subpatch is being created from this patch.
Public Attributes
ExtraDataUser< T > * dataOwner
ExtraUserData< T > * userNext
T userData
Detailed Description
template<typename T>
class MBMesquite::ExtraUserData< T >
Definition at line 94 of file ExtraDataUser.hpp.
MBMesquite::ExtraUserData< T >::ExtraUserData ( PatchData patch,
ExtraDataUser< T > *  owner,
ExtraUserData< T > *  next,
const T data
) [inline]
Definition at line 101 of file ExtraDataUser.hpp.
        : ExtraData( patch ), dataOwner( owner ), userNext( next ), userData( data )
) [inline]
Definition at line 106 of file ExtraDataUser.hpp.
Member Function Documentation
template<typename T >
void MBMesquite::ExtraUserData< T >::notify_new_patch ( ) [virtual]
Notify attached ExtraData that the PatchData is being changed to contain an new patch (set of mesh entities.)
Implements MBMesquite::ExtraData.
Definition at line 128 of file ExtraDataUser.hpp.
    dataOwner->notify_new_patch( *get_patch_data(), userData );
void MBMesquite::ExtraUserData< T >::notify_patch_destroyed ( ) [virtual]
Notify an ExtraData object that the patch it is attached to is being destroyed. The ExtraData will have been removed from the PatchData before being notified. Therefore this->get_patch_data() will return NULL.
ExtraData instances will also be notified via this method and removed and removed from the PatchData if the attached MBMesquite::Mesh or MBMesquite::MeshDomain instance is changed.
Definition at line 122 of file ExtraDataUser.hpp.
    dataOwner->notify_patch_destroyed( this );
void MBMesquite::ExtraUserData< T >::notify_sub_patch ( PatchData sub_patch,
const size_t *  vertex_index_map,
const size_t *  element_index_map,
MsqError err
) [virtual]
Parameters:
sub_patchThe new, populated subpatch
vertex_index_mapThe indices in the original patch for each vertex in the subpatch.
element_index_mapThe indices in the original patch for each element in the subpatch.
Definition at line 134 of file ExtraDataUser.hpp.
    dataOwner->notify_sub_patch( *get_patch_data(), userData, sub, vertex_map, element_map, err );
Member Data Documentation
ExtraDataUser< T >* MBMesquite::ExtraUserData< T >::dataOwner
Definition at line 97 of file ExtraDataUser.hpp.
T MBMesquite::ExtraUserData< T >::userData
List of all members.
