MBMesquite::IdealWeightMeanRatio Class Reference
Computes the mean ratio quality metric of given element. More...
#include <IdealWeightMeanRatio.hpp>
+ Inheritance diagram for MBMesquite::IdealWeightMeanRatio:
+ Collaboration diagram for MBMesquite::IdealWeightMeanRatio:
Public Member Functions
MESQUITE_EXPORT IdealWeightMeanRatio ()
virtual MESQUITE_EXPORT ~IdealWeightMeanRatio ()
 virtual destructor ensures use of polymorphism during destruction
virtual std::string get_name () const
virtual int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
virtual bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
virtual bool evaluate_with_gradient (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, MsqError &err)
 Get metric value and gradient at a logical location in the patch.
virtual bool evaluate_with_Hessian_diagonal (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< SymMatrix3D > &Hessian, MsqError &err)
virtual bool evaluate_with_Hessian (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< Matrix3D > &Hessian, MsqError &err)
 Get metric value and deravitives at a logical location in the patch.
Private Attributes
Vector3D mCoords [4]
Vector3D mGradients [32]
Matrix3D mHessians [80]
double mMetrics [8]
const double a2Con
const Exponent b2Con
const Exponent c2Con
const double a3Con
const Exponent b3Con
const Exponent c3Con
Detailed Description
The metric does not use the sample point functionality or the compute_weighted_jacobian. It evaluates the metric at the element vertices, and uses the isotropic ideal element. It does require a feasible region, and the metric needs to be maximized.
Definition at line 62 of file IdealWeightMeanRatio.hpp.
Definition at line 65 of file IdealWeightMeanRatio.hpp.
        : AveragingQM( QualityMetric::LINEAR ), a2Con( 2.0 ), b2Con( -1.0 ), c2Con( 1.0 ), a3Con( 3.0 ), b3Con( -1.0 ),
          c3Con( 2.0 / 3.0 )
Definition at line 72 of file IdealWeightMeanRatio.hpp.
Member Function Documentation
bool IdealWeightMeanRatio::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 58 of file IdealWeightMeanRatio.cpp.
References a2Con, a3Con, MBMesquite::AveragingQM::average_metrics(), b2Con, b3Con, c2Con, c3Con, MBMesquite::PatchData::element_by_index(), MBMesquite::PatchData::get_domain_normal_at_element(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::HEXAHEDRON, MBMesquite::Vector3D::length(), MBMesquite::m_fcn_2e(), MBMesquite::m_fcn_2i(), MBMesquite::m_fcn_3e(), MBMesquite::m_fcn_3i(), MBMesquite::m_fcn_3p(), MBMesquite::m_fcn_3w(), mCoords, mMetrics, MSQ_ERRZERO, MSQ_SETERR, n, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
    const MsqMeshEntity* e = &pd.element_by_index( handle );
    EntityTopology topo    = e->get_element_type();
    const MsqVertex* vertices = pd.get_vertex_array( err );
    const size_t* v_i         = e->get_vertex_index_array();
    Vector3D n;  // Surface normal for 2D objects
    // Prism and Hex element descriptions
    static const int locs_pri[6][4] = { { 0, 1, 2, 3 }, { 1, 2, 0, 4 }, { 2, 0, 1, 5 },
                                        { 3, 5, 4, 0 }, { 4, 3, 5, 1 }, { 5, 4, 3, 2 } };
    static const int locs_hex[8][4] = { { 0, 1, 3, 4 }, { 1, 2, 0, 5 }, { 2, 3, 1, 6 }, { 3, 0, 2, 7 },
                                        { 4, 7, 5, 0 }, { 5, 4, 6, 1 }, { 6, 5, 7, 2 }, { 7, 6, 4, 3 } };
    const Vector3D d_con( 1.0, 1.0, 1.0 );
    int i;
    m                 = 0.0;
    bool metric_valid = false;
    switch( topo )
        case TRIANGLE:
            pd.get_domain_normal_at_element( e, n, err );
            MSQ_ERRZERO( err );
            n            = n / n.length();  // Need unit normal
            mCoords[0]   = vertices[v_i[0]];
            mCoords[1]   = vertices[v_i[1]];
            mCoords[2]   = vertices[v_i[2]];
            metric_valid = m_fcn_2e( m, mCoords, n, a2Con, b2Con, c2Con );
            if( !metric_valid ) return false;
            break;
        case QUADRILATERAL:
            MSQ_ERRZERO( err );
            for( i = 0; i < 4; ++i )
                mCoords[0]   = vertices[v_i[locs_hex[i][0]]];
                mCoords[1]   = vertices[v_i[locs_hex[i][1]]];
                mCoords[2]   = vertices[v_i[locs_hex[i][2]]];
                metric_valid = m_fcn_2i( mMetrics[i], mCoords, n, a2Con, b2Con, c2Con, d_con );
            m = average_metrics( mMetrics, 4, err );
            MSQ_ERRZERO( err );
            break;
        case TETRAHEDRON:
            mCoords[3]   = vertices[v_i[3]];
            metric_valid = m_fcn_3e( m, mCoords, a3Con, b3Con, c3Con );
            break;
        case PYRAMID:
                mCoords[0]   = vertices[v_i[i]];
                mCoords[1]   = vertices[v_i[( i + 1 ) % 4]];
                mCoords[2]   = vertices[v_i[( i + 3 ) % 4]];
                mCoords[3]   = vertices[v_i[4]];
                metric_valid = m_fcn_3p( mMetrics[i], mCoords, a3Con, b3Con, c3Con );
            MSQ_ERRZERO( err );
            break;
        case PRISM:
            for( i = 0; i < 6; ++i )
                mCoords[0]   = vertices[v_i[locs_pri[i][0]]];
                mCoords[1]   = vertices[v_i[locs_pri[i][1]]];
                mCoords[2]   = vertices[v_i[locs_pri[i][2]]];
                mCoords[3]   = vertices[v_i[locs_pri[i][3]]];
                metric_valid = m_fcn_3w( mMetrics[i], mCoords, a3Con, b3Con, c3Con );
            m = average_metrics( mMetrics, 6, err );
            MSQ_ERRZERO( err );
            break;
        case HEXAHEDRON:
            for( i = 0; i < 8; ++i )
                mCoords[3]   = vertices[v_i[locs_hex[i][3]]];
                metric_valid = m_fcn_3i( mMetrics[i], mCoords, a3Con, b3Con, c3Con, d_con );
            m = average_metrics( mMetrics, 8, err );
            MSQ_ERRZERO( err );
            break;
        default:
            MSQ_SETERR( err )
            ( MsqError::UNSUPPORTED_ELEMENT, "Element type (%d) not supported in IdealWeightMeanRatio", (int)topo );
            return false;
    }  // end switch over element type
    return true;
bool IdealWeightMeanRatio::evaluate_with_gradient ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
std::vector< Vector3D > &  gradient,
MsqError err
) [virtual]
Parameters:
pdThe patch.
indicesThe free vertices that the evaluation is a function of, specified as vertex indices in the PatchData.
gradientThe gradient of the metric as a function of the coordinates of the free vertices passed back in the indices list.
Reimplemented from MBMesquite::QualityMetric.
Definition at line 168 of file IdealWeightMeanRatio.cpp.
References a2Con, a3Con, MBMesquite::AveragingQM::analytical_average_gradient(), MBMesquite::arrptr(), MBMesquite::AveragingQM::average_corner_gradients(), b2Con, b3Con, c2Con, c3Con, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::fixed_vertex_bitmap(), MBMesquite::g_fcn_2e(), MBMesquite::g_fcn_2i(), MBMesquite::g_fcn_3e(), MBMesquite::g_fcn_3i(), MBMesquite::g_fcn_3p(), MBMesquite::g_fcn_3w(), MBMesquite::PatchData::get_domain_normal_at_element(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::HEXAHEDRON, MBMesquite::Vector3D::length(), mCoords, mGradients, mMetrics, MSQ_DBGOUT, MSQ_ERRZERO, MSQ_SETERR, n, MBMesquite::print(), MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::QualityMetric::remove_fixed_gradients(), MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
    //  FUNCTION_TIMER_START(__FUNC__);
    if( !analytical_average_gradient() && topo != TRIANGLE && topo != TETRAHEDRON )
        static bool print = true;
        if( print )
            MSQ_DBGOUT( 1 ) << "Analyical gradient not available for selected averaging scheme. "
                            << "Using (possibly much slower) numerical approximation of gradient"
                            << " of quality metric. " << std::endl;
            print = false;
        return QualityMetric::evaluate_with_gradient( pd, handle, m, indices, g, err );
    // double   nm, t=0;
    int i;
    const uint32_t fm = fixed_vertex_bitmap( pd, e, indices );
    m = 0.0;
    switch( topo )
        case TRIANGLE:
            MSQ_ERRZERO( err );
            g.resize( 3 );
            if( !g_fcn_2e( m, arrptr( g ), mCoords, n, a2Con, b2Con, c2Con ) ) return false;
            break;
        case QUADRILATERAL:
            MSQ_ERRZERO( err );
            n /= n.length();  // Need unit normal
                if( !g_fcn_2i( mMetrics[i], mGradients + 3 * i, mCoords, n, a2Con, b2Con, c2Con, d_con ) ) return false;
            g.resize( 4 );
            m = average_corner_gradients( QUADRILATERAL, fm, 4, mMetrics, mGradients, arrptr( g ), err );
            MSQ_ERRZERO( err );
            break;
        case TETRAHEDRON:
            g.resize( 4 );
            metric_valid = g_fcn_3e( m, arrptr( g ), mCoords, a3Con, b3Con, c3Con );
            break;
        case PYRAMID:
                metric_valid = g_fcn_3p( mMetrics[i], mGradients + 4 * i, mCoords, a3Con, b3Con, c3Con );
            g.resize( 5 );
            m = average_corner_gradients( PYRAMID, fm, 4, mMetrics, mGradients, arrptr( g ), err );
            MSQ_ERRZERO( err );
            break;
        case PRISM:
                if( !g_fcn_3w( mMetrics[i], mGradients + 4 * i, mCoords, a3Con, b3Con, c3Con ) ) return false;
            g.resize( 6 );
            m = average_corner_gradients( PRISM, fm, 6, mMetrics, mGradients, arrptr( g ), err );
            MSQ_ERRZERO( err );
            break;
        case HEXAHEDRON:
                if( !g_fcn_3i( mMetrics[i], mGradients + 4 * i, mCoords, a3Con, b3Con, c3Con, d_con ) ) return false;
            g.resize( 8 );
            m = average_corner_gradients( HEXAHEDRON, fm, 8, mMetrics, mGradients, arrptr( g ), err );
            MSQ_ERRZERO( err );
            break;
        default:
            MSQ_SETERR( err )
            return false;
    remove_fixed_gradients( topo, fm, g );
    return true;
bool IdealWeightMeanRatio::evaluate_with_Hessian ( PatchData pd,
size_t  handle,
double &  value,
std::vector< Matrix3D > &  Hessian,
MsqError err
) [virtual]
Parameters:
pdThe patch.
HessianThe Hessian of the metric as a function of the coordinates. The Hessian is passed back as the upper-triangular portion of the matrix in row-major order, where each Matrix3D is the portion of the Hessian with respect to the vertices at the corresponding positions in the indices list.
Definition at line 464 of file IdealWeightMeanRatio.cpp.
References a2Con, a3Con, MBMesquite::AveragingQM::analytical_average_hessian(), MBMesquite::arrptr(), MBMesquite::AveragingQM::average_corner_hessians(), b2Con, b3Con, c2Con, c3Con, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::fixed_vertex_bitmap(), MBMesquite::PatchData::get_domain_normal_at_element(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::h_fcn_2e(), MBMesquite::h_fcn_2i(), MBMesquite::h_fcn_3e(), MBMesquite::h_fcn_3i(), MBMesquite::h_fcn_3p(), MBMesquite::h_fcn_3w(), MBMesquite::HEXAHEDRON, MBMesquite::Vector3D::length(), mCoords, mGradients, mHessians, mMetrics, MSQ_DBGOUT, MSQ_ERRZERO, MSQ_SETERR, n, MBMesquite::print(), MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::QualityMetric::remove_fixed_gradients(), MBMesquite::QualityMetric::remove_fixed_hessians(), MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
    if( !analytical_average_hessian() && topo != TRIANGLE && topo != TETRAHEDRON )
        if( print )
            print = false;
        return QualityMetric::evaluate_with_Hessian( pd, handle, m, indices, g, h, err );
    int i;
    m = 0.0;
    switch( topo )
        case TRIANGLE:
            MSQ_ERRZERO( err );
            g.resize( 3 ), h.resize( 6 );
            if( !h_fcn_2e( m, arrptr( g ), arrptr( h ), mCoords, n, a2Con, b2Con, c2Con ) ) return false;
            break;
        case QUADRILATERAL:
            MSQ_ERRZERO( err );
                if( !h_fcn_2i( mMetrics[i], mGradients + 3 * i, mHessians + 6 * i, mCoords, n, a2Con, b2Con, c2Con,
                               d_con ) )
                    return false;
            g.resize( 4 ), h.resize( 10 );
            m = average_corner_hessians( QUADRILATERAL, fm, 4, mMetrics, mGradients, mHessians, arrptr( g ),
                                         arrptr( h ), err );
            MSQ_ERRZERO( err );
            break;
        case TETRAHEDRON:
            metric_valid = h_fcn_3e( m, arrptr( g ), arrptr( h ), mCoords, a3Con, b3Con, c3Con );
            break;
        case PYRAMID:
                metric_valid =
                    h_fcn_3p( mMetrics[i], mGradients + 4 * i, mHessians + 10 * i, mCoords, a3Con, b3Con, c3Con );
            g.resize( 5 ), h.resize( 15 );
            m = average_corner_hessians( PYRAMID, fm, 4, mMetrics, mGradients, mHessians, arrptr( g ), arrptr( h ),
                                         err );
            MSQ_ERRZERO( err );
            break;
        case PRISM:
                if( !h_fcn_3w( mMetrics[i], mGradients + 4 * i, mHessians + 10 * i, mCoords, a3Con, b3Con, c3Con ) )
                    return false;
            g.resize( 6 ), h.resize( 21 );
            m = average_corner_hessians( PRISM, fm, 6, mMetrics, mGradients, mHessians, arrptr( g ), arrptr( h ), err );
            MSQ_ERRZERO( err );
            break;
        case HEXAHEDRON:
                if( !h_fcn_3i( mMetrics[i], mGradients + 4 * i, mHessians + 10 * i, mCoords, a3Con, b3Con, c3Con,
                               d_con ) )
                    return false;
            g.resize( 8 ), h.resize( 36 );
            m = average_corner_hessians( HEXAHEDRON, fm, 8, mMetrics, mGradients, mHessians, arrptr( g ), arrptr( h ),
                                         err );
            MSQ_ERRZERO( err );
            break;
        default:
            MSQ_SETERR( err )
            return false;
    remove_fixed_hessians( topo, fm, h );
    //  FUNCTION_TIMER_END();
    return true;
bool IdealWeightMeanRatio::evaluate_with_Hessian_diagonal ( PatchData pd,
size_t  handle,
double &  value,
std::vector< SymMatrix3D > &  Hessian_diagonal,
MsqError err
) [virtual]
Parameters:
pdThe patch.
Hessian_diagonalThe 3x3 blocks along the diagonal of the Hessian matrix.
Definition at line 307 of file IdealWeightMeanRatio.cpp.
References a2Con, a3Con, MBMesquite::AveragingQM::analytical_average_hessian(), MBMesquite::arrptr(), MBMesquite::AveragingQM::average_corner_hessian_diagonals(), b2Con, b3Con, c2Con, c3Con, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::fixed_vertex_bitmap(), MBMesquite::PatchData::get_domain_normal_at_element(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::h_fcn_2e(), MBMesquite::h_fcn_2i(), MBMesquite::h_fcn_3e(), MBMesquite::h_fcn_3i(), MBMesquite::h_fcn_3p(), MBMesquite::h_fcn_3w(), MBMesquite::HEXAHEDRON, MBMesquite::Vector3D::length(), mCoords, mGradients, mHessians, mMetrics, MSQ_DBGOUT, MSQ_ERRZERO, MSQ_SETERR, n, MBMesquite::print(), MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::QualityMetric::remove_fixed_diagonals(), MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, MBMesquite::MsqError::UNSUPPORTED_ELEMENT, and MBMesquite::Matrix3D::upper().
        if( print )
            print = false;
        return QualityMetric::evaluate_with_Hessian_diagonal( pd, handle, m, indices, g, h, err );
    int i;
    m = 0.0;
    switch( topo )
        case TRIANGLE:
            MSQ_ERRZERO( err );
            g.resize( 3 ), h.resize( 3 );
            if( !h_fcn_2e( m, arrptr( g ), mHessians, mCoords, n, a2Con, b2Con, c2Con ) ) return false;
            h[0] = mHessians[0].upper();
            h[1] = mHessians[3].upper();
            h[2] = mHessians[5].upper();
            break;
        case QUADRILATERAL:
            MSQ_ERRZERO( err );
                               d_con ) )
                    return false;
            g.resize( 4 ), h.resize( 4 );
            m = average_corner_hessian_diagonals( QUADRILATERAL, fm, 4, mMetrics, mGradients, mHessians, arrptr( g ),
                                                  arrptr( h ), err );
            MSQ_ERRZERO( err );
            break;
        case TETRAHEDRON:
            metric_valid = h_fcn_3e( m, arrptr( g ), mHessians, mCoords, a3Con, b3Con, c3Con );
            h[1] = mHessians[4].upper();
            h[2] = mHessians[7].upper();
            h[3] = mHessians[9].upper();
            break;
        case PYRAMID:
                metric_valid =
            g.resize( 5 ), h.resize( 5 );
            m = average_corner_hessian_diagonals( PYRAMID, fm, 4, mMetrics, mGradients, mHessians, arrptr( g ),
                                                  arrptr( h ), err );
            MSQ_ERRZERO( err );
            break;
        case PRISM:
                    return false;
            g.resize( 6 ), h.resize( 6 );
            m = average_corner_hessian_diagonals( PRISM, fm, 6, mMetrics, mGradients, mHessians, arrptr( g ),
                                                  arrptr( h ), err );
            MSQ_ERRZERO( err );
            break;
        case HEXAHEDRON:
                               d_con ) )
                    return false;
            g.resize( 8 ), h.resize( 8 );
            m = average_corner_hessian_diagonals( HEXAHEDRON, fm, 8, mMetrics, mGradients, mHessians, arrptr( g ),
                                                  arrptr( h ), err );
            MSQ_ERRZERO( err );
            break;
        default:
            MSQ_SETERR( err )
            return false;
    remove_fixed_diagonals( topo, fm, g, h );
    return true;
std::string IdealWeightMeanRatio::get_name ( ) const [virtual]
Definition at line 48 of file IdealWeightMeanRatio.cpp.
    return "Mean Ratio";
int IdealWeightMeanRatio::get_negate_flag ( ) const [virtual]
Definition at line 53 of file IdealWeightMeanRatio.cpp.
    return -1;
Member Data Documentation
List of all members.
