MBMesquite::MaxTemplate Class Reference
Computes the maximum quality metric value. More...
#include <MaxTemplate.hpp>
+ Inheritance diagram for MBMesquite::MaxTemplate:
+ Collaboration diagram for MBMesquite::MaxTemplate:
Public Member Functions
 MaxTemplate (QualityMetric *)
virtual ~MaxTemplate ()
virtual bool evaluate (EvalType type, PatchData &pd, double &value_out, bool free, MsqError &err)
 Evaluate objective function for specified patch.
virtual ObjectiveFunctionclone () const
 Create copy with same state.
virtual void clear ()
Private Attributes
std::vector< size_t > qmHandles
Detailed Description
This function is the same as the LInfTemplate except that no absolute values are used.
Definition at line 52 of file MaxTemplate.hpp.
Definition at line 44 of file MaxTemplate.cpp.
Referenced by clone().
: ObjectiveFunctionTemplate( qualitymetric ) {}
Definition at line 47 of file MaxTemplate.cpp.
Member Function Documentation
void MBMesquite::MaxTemplate::clear ( ) [virtual]
Clear any values accumulated for BCD-related eval calls
Implements MBMesquite::ObjectiveFunction.
Definition at line 54 of file MaxTemplate.cpp.
Create a new instance of the objective function that is a copy of the callee with the same accumulated values, parameters, etc.
Definition at line 49 of file MaxTemplate.cpp.
References MBMesquite::ObjectiveFunctionTemplate::get_quality_metric(), and MaxTemplate().
    return new MaxTemplate( get_quality_metric() );
bool MBMesquite::MaxTemplate::evaluate ( EvalType  type,
PatchData pd,
double &  value_out,
bool  free,
MsqError err
) [virtual]
Either evaluate the objective function over the passed patch or update the accumulated, global objective function value for changes in the passed patch, depending on the value of the EvalType.
Parameters:
typeEvaluation type.
pdThe patch.
value_outThe passed-back value of the objective fuction.
freeIf true, incorporate the quality metric values only for those metric evaluations that depend on at least one free vertex
Returns:
false if any QualityMetric evaluation returned false, true otherwise.
Definition at line 56 of file MaxTemplate.cpp.
References MBMesquite::ObjectiveFunction::CALCULATE, MBMesquite::QualityMetric::evaluate(), MBMesquite::QualityMetric::get_evaluations(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::ObjectiveFunctionTemplate::get_quality_metric(), MBMesquite::MsqError::INVALID_STATE, MSQ_CHKERR, MSQ_ERRFALSE, MSQ_SETERR, qmHandles, MBMesquite::sign, and value().
    if( type != ObjectiveFunction::CALCULATE )
        MSQ_SETERR( err )
        ( "MaxTemplate does not support block coodinate descent algoritms", MsqError::INVALID_STATE );
        return false;
    QualityMetric* qm = get_quality_metric();
    qm->get_evaluations( pd, qmHandles, free, err );
    MSQ_ERRFALSE( err );
    const double sign = qm->get_negate_flag();
    // calculate OF value for just the patch
    std::vector< size_t >::const_iterator i;
    double value;
    value_out = -HUGE_VAL;
    for( i = qmHandles.begin(); i != qmHandles.end(); ++i )
        bool result = qm->evaluate( pd, *i, value, err );
        if( MSQ_CHKERR( err ) || !result ) return false;
        value *= sign;
        if( value > value_out ) value_out = value;
    return true;
Member Data Documentation
std::vector< size_t > MBMesquite::MaxTemplate::qmHandles [mutable, private]
Temporary storage for qm sample handles
Definition at line 63 of file MaxTemplate.hpp.
Referenced by evaluate().
List of all members.
