MBMesquite::MeshImpl Class Reference
MeshImpl is a Mesquite implementation of the Mesh interface. Applications can also provide their own implementation of the interface. More...
#include <MeshImpl.hpp>
+ Inheritance diagram for MBMesquite::MeshImpl:
+ Collaboration diagram for MBMesquite::MeshImpl:
Public Member Functions
 MeshImpl ()
virtual ~MeshImpl ()
 MeshImpl (int num_vertex, int num_elem, EntityTopology entity_topology, const bool *fixed, const double *coords, const int *conn)
 Initialize mesh by copying data from arrays.
 MeshImpl (int num_vertex, int num_elem, const EntityTopology *element_topologies, const bool *fixed, const double *coords, const int *conn)
void read_vtk (const char *in_filename, MBMesquite::MsqError &err)
 Read mesh from VTK file format version 3.0 or earlier.
void write_vtk (const char *out_filename, MBMesquite::MsqError &err)
 Write mesh to VTK file format version 3.0.
void read_exodus (const char *in_filename, MBMesquite::MsqError &err)
 Read mesh from ExodusII file.
void write_exodus (const char *out_filename, MBMesquite::MsqError &err)
 Write mesh to ExodusII file.
void set_all_fixed_flags (bool value, MsqError &err)
 Set the value returned by vertices_get_fixed_flag for all vertices.
void set_all_slaved_flags (bool value, MsqError &err)
 Set the value returned by vertices_get_slaved_flag for all vertices.
void set_skin_flags (bool corner_fixed_flag, bool midnode_fixed_flag, bool midnode_slaved_flag, MsqError &err)
 Set values for vertices_get_fixed_flag and vertices_get_slaved_flag on skin vertices.
void mark_skin_fixed (MsqError &err, bool clear_existing=true)
 Find the vertices in the skin (i.e bounary) of the mesh and mark them as 'fixed'.
virtual int get_geometric_dimension (MsqError &err)
 Returns whether this mesh lies in a 2D or 3D coordinate system.
virtual void get_all_elements (std::vector< ElementHandle > &handles, MsqError &err)
 Get all elements in mesh.
virtual void get_all_vertices (std::vector< VertexHandle > &vertices, MsqError &err)
 Get all vertices in mesh.
virtual VertexIteratorvertex_iterator (MsqError &err)
virtual ElementIteratorelement_iterator (MsqError &err)
virtual void vertices_get_fixed_flag (const VertexHandle vert_array[], std::vector< bool > &fixed_flag_array, size_t num_vtx, MsqError &err)
void vertices_set_fixed_flag (const VertexHandle vert_array[], const std::vector< bool > &fixed_flag_array, size_t num_vtx, MsqError &err)
virtual void vertices_get_slaved_flag (const VertexHandle vert_array[], std::vector< bool > &slaved_flag_array, size_t num_vtx, MsqError &err)
virtual void vertices_get_coordinates (const Mesh::VertexHandle vert_array[], MBMesquite::MsqVertex *coordinates, size_t num_vtx, MsqError &err)
 Get/set location of a vertex.
virtual void vertex_set_coordinates (VertexHandle vertex, const Vector3D &coordinates, MsqError &err)
virtual void vertex_set_byte (VertexHandle vertex, unsigned char byte, MsqError &err)
virtual void vertices_set_byte (const VertexHandle *vert_array, const unsigned char *byte_array, size_t array_size, MsqError &err)
virtual void vertex_get_byte (const VertexHandle vertex, unsigned char *byte, MsqError &err)
virtual void vertices_get_byte (const VertexHandle *vertex, unsigned char *byte_array, size_t array_size, MsqError &err)
virtual void vertices_get_attached_elements (const VertexHandle *vertex_array, size_t num_vertex, std::vector< ElementHandle > &elements, std::vector< size_t > &offsets, MsqError &err)
 get elements adjacent to vertices
virtual void elements_get_attached_vertices (const ElementHandle *elem_handles, size_t num_elems, std::vector< VertexHandle > &vert_handles, std::vector< size_t > &offsets, MsqError &err)
 Get element connectivity.
virtual void elements_get_topologies (const ElementHandle *element_handle_array, EntityTopology *element_topologies, size_t num_elements, MsqError &err)
virtual TagHandle tag_create (const std::string &tag_name, TagType type, unsigned length, const void *default_value, MsqError &err)
 Create a tag.
virtual void tag_delete (TagHandle handle, MsqError &err)
 Remove a tag and all corresponding data.
virtual TagHandle tag_get (const std::string &name, MsqError &err)
 Get handle for existing tag, by name.
virtual void tag_properties (TagHandle handle, std::string &name_out, TagType &type_out, unsigned &length_out, MsqError &err)
 Get properites of tag.
virtual void tag_set_element_data (TagHandle handle, size_t num_elems, const ElementHandle *elem_array, const void *tag_data, MsqError &err)
 Set tag values on elements.
virtual void tag_set_vertex_data (TagHandle handle, size_t num_elems, const VertexHandle *node_array, const void *tag_data, MsqError &err)
 Set tag values on vertices.
virtual void tag_get_element_data (TagHandle handle, size_t num_elems, const ElementHandle *elem_array, void *tag_data, MsqError &err)
 Get tag values on elements.
virtual void tag_get_vertex_data (TagHandle handle, size_t num_elems, const VertexHandle *node_array, void *tag_data, MsqError &err)
 Get tag values on vertices.
virtual void release_entity_handles (const EntityHandle *handle_array, size_t num_handles, MsqError &err)
virtual void release ()
void clear ()
Protected Attributes
int numCoords
MeshImplDatamyMesh
MeshImplTagsmyTags
Private Member Functions
void vtk_read_dataset (FileTokenizer &file, MsqError &err)
void vtk_read_structured_points (FileTokenizer &file, MsqError &err)
void vtk_read_structured_grid (FileTokenizer &file, MsqError &err)
void vtk_read_rectilinear_grid (FileTokenizer &file, MsqError &err)
void vtk_read_polydata (FileTokenizer &file, MsqError &err)
void vtk_read_unstructured_grid (FileTokenizer &file, MsqError &err)
void vtk_read_field (FileTokenizer &file, MsqError &err)
void vtk_read_polygons (FileTokenizer &file, MsqError &err)
void vtk_create_structured_elems (const long *dims, MsqError &err)
void vtk_read_point_data (FileTokenizer &file, MsqError &err)
void vtk_read_cell_data (FileTokenizer &file, MsqError &err)
void vtk_store_point_data (const void *data, TagDescription &desc, MsqError &)
void vtk_store_cell_data (const void *data, TagDescription &desc, MsqError &)
void * vtk_read_attrib_data (FileTokenizer &file, long num_data_to_read, TagDescription &tag_out, MsqError &err)
void * vtk_read_typed_data (FileTokenizer &file, int type, size_t per_elem, size_t num_elem, TagDescription &tag_out, MsqError &err)
void * vtk_read_field_data (FileTokenizer &file, size_t count, size_t field_count, const std::string &field_name, TagDescription &tag, MsqError &err)
void * vtk_read_scalar_attrib (FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err)
void * vtk_read_color_attrib (FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err)
void * vtk_read_vector_attrib (FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err)
void * vtk_read_texture_attrib (FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err)
void * vtk_read_tensor_attrib (FileTokenizer &file, long count, TagDescription &tag_out, MsqError &err)
void vtk_write_attrib_data (std::ostream &file, const TagDescription &desc, const void *data, size_t count, MsqError &err) const
void tag_to_bool (const char *tag_name, std::vector< bool > &vertex_vals, MsqError &err)
Detailed Description
MeshImpl can read in mesh files in VTK format and ExodusII format.
Definition at line 60 of file MeshImpl.hpp.
Definition at line 80 of file MeshImpl.cpp.
: numCoords( 0 ), myMesh( new MeshImplData ), myTags( new MeshImplTags ) {}
Definition at line 82 of file MeshImpl.cpp.
References myMesh, and myTags.
    delete myMesh;
    delete myTags;
MBMesquite::MeshImpl::MeshImpl ( int  num_vertex,
int  num_elem,
const bool *  fixed,
const double *  coords,
const int *  conn
Parameters:
num_vertexNumber of vertices in the mesh
num_elemNumber of elements in the mesh
entity_topologyType of all elements in the mesh
fixedValue of fixed flag for each vertex
coordsInterleaved vertex coordinates.
connElement corner vertices specified as indices into vertex list
Definition at line 88 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::allocate_elements(), MBMesquite::MeshImplData::allocate_vertices(), corners, MSQ_ERRRTN, myMesh, MBMesquite::MeshImplData::reset_element(), and MBMesquite::MeshImplData::reset_vertex().
    : numCoords( 3 ), myMesh( new MeshImplData ), myTags( new MeshImplTags )
    MsqError err;
    myMesh->allocate_vertices( num_nodes, err );MSQ_ERRRTN( err );
    myMesh->allocate_elements( num_elem, err );MSQ_ERRRTN( err );
    // Fill in the data
    if( fixed )
        for( int i = 0; i < num_nodes; ++i )
            myMesh->reset_vertex( i, Vector3D( coords + 3 * i ), fixed[i], err );
    else
            myMesh->reset_vertex( i, Vector3D( coords + 3 * i ), false, err );
    const int verts_per_elem = TopologyInfo::corners( entity_topology );
    std::vector< long > connect( verts_per_elem );
    const int* conn_iter = connectivity;
    for( int i = 0; i < num_elem; i++, conn_iter += verts_per_elem )
        std::copy( conn_iter, conn_iter + verts_per_elem, connect.begin() );
        myMesh->reset_element( i, connect, entity_topology, err );
int  num_elem,
const EntityTopology element_topologies,
const bool *  fixed,
const int *  conn
Parameters:
entity_topologiesThe types of each element in the mesh
Definition at line 127 of file MeshImpl.cpp.
    MsqError err;
    // Fill in the data
    if( fixed )
    else
    int num_indices = 0;
    std::vector< long > connect;
    // Count the number of indices
    for( int i = 0; i < num_elem; ++i )
        num_indices = TopologyInfo::corners( element_topologies[i] );
        connect.resize( num_indices );
        std::copy( conn_iter, conn_iter + num_indices, connect.begin() );
        myMesh->reset_element( i, connect, element_topologies[i], err );
        conn_iter += num_indices;
Member Function Documentation
Definition at line 1101 of file MeshImpl.cpp.
References myMesh.
Referenced by ExodusTest::check_mesh().
    return new MeshImplElemIter( myMesh );
void MBMesquite::MeshImpl::elements_get_attached_vertices ( const ElementHandle elem_handles,
size_t  num_elems,
std::vector< VertexHandle > &  vert_handles,
std::vector< size_t > &  offsets,
MsqError err
) [virtual]
Get the connectivity (ordered list of vertex handles) for each element in the input array.
Parameters:
elem_handlesThe array of element handles for which to retrieve the connectivity list.
num_elemsThe length of #elem_handles
vert_handlesArray in which to place the vertex handles in each elements connectivity.
offsetsFor each element in #elem_handles, the value in the same position in this array is the index into #vert_handles at which the connectivity list for that element begins.
Implements MBMesquite::Mesh.
Definition at line 1239 of file MeshImpl.cpp.
References conn, MBMesquite::MeshImplData::element_connectivity(), MSQ_ERRRTN, and myMesh.
Referenced by ExodusTest::check_mesh(), main(), MeshInterfaceTest::setUp(), VtkTest::test_read_fixed_attrib(), VtkTest::test_read_quadratic(), VtkTest::test_read_unstructured(), and SlaveBoundaryVerticesTest::test_slaved_common().
    vertices.clear();
    offsets.clear();
    size_t prev_offset = 0;
    offsets.reserve( num_elems + 1 );
    offsets.push_back( prev_offset );
    const ElementHandle* const elem_end = elements + num_elems;
    for( ; elements < elem_end; ++elements )
        const std::vector< size_t >& conn = myMesh->element_connectivity( (size_t)*elements, err );MSQ_ERRRTN( err );
        prev_offset = prev_offset + conn.size();
        std::transform( conn.begin(), conn.end(), std::back_inserter( vertices ), cast_handle< VertexHandle >() );
void MBMesquite::MeshImpl::elements_get_topologies ( const ElementHandle element_handle_array,
MsqError err
) [virtual]
Returns the topologies of the given entities. The "entity_topologies" array must be at least "num_elements" in size.
Definition at line 1264 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::element_topology(), MSQ_CHKERR, and myMesh.
Referenced by ExodusTest::check_mesh(), main(), process_domain_args(), MeshInterfaceTest::test_element_get_attached_vertex_indices(), MeshInterfaceTest::test_elements_get_topology(), VtkTest::test_read_quadratic(), and SlaveBoundaryVerticesTest::test_slaved_common().
    for( size_t i = 0; i < num_elements; i++ )
        element_topologies[i] = myMesh->element_topology( (size_t)element_handle_array[i], err );MSQ_CHKERR( err );
void MBMesquite::MeshImpl::get_all_elements ( std::vector< ElementHandle > &  handles,
MsqError err
) [virtual]
Get the handles of every element in the active mesh.
Definition at line 1068 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::all_elements(), MBMesquite::arrptr(), MSQ_ERRRTN, and myMesh.
Referenced by VtkTest::check_field_attrib(), ExodusTest::check_mesh(), get_planar_example(), main(), process_domain_args(), MeshInterfaceTest::setUp(), VtkTest::test_read_fixed_attrib(), VtkTest::test_read_quadratic(), VtkTest::test_read_simple_scalar_attrib(), VtkTest::test_read_unstructured(), VtkTest::test_read_vector_attrib(), SlaveBoundaryVerticesTest::test_slaved_common(), and MeshImplTest::test_zero_length_data().
    assert( sizeof( ElementHandle ) == sizeof( size_t ) );
    std::vector< size_t > temp;
    myMesh->all_elements( temp, err );MSQ_ERRRTN( err );
    elems.resize( temp.size() );
    if( !elems.empty() ) memcpy( arrptr( elems ), arrptr( temp ), sizeof( size_t ) * temp.size() );
void MBMesquite::MeshImpl::get_all_vertices ( std::vector< VertexHandle > &  vertices,
MsqError err
) [virtual]
Get the handles of every vertex in the active mesh
Definition at line 1077 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::all_vertices(), MBMesquite::arrptr(), MSQ_ERRRTN, and myMesh.
Referenced by BCDTest::compare_bcd(), exp_1_init(), get_planar_example(), main(), run(), MeshImplTest::skin_mesh_2D(), MeshImplTest::skin_mesh_3D(), MeshImplTest::skin_mesh_higher_order(), MeshImplTest::skin_mesh_mixed(), BoundedCylinderDomainTest::test_create_curve_from_mesh(), SlaveBoundaryVerticesTest::test_slaved_common(), MeshImplTest::test_zero_length_data(), and uwt().
    assert( sizeof( VertexHandle ) == sizeof( size_t ) );
    myMesh->all_vertices( temp, err );MSQ_ERRRTN( err );
    verts.resize( temp.size() );
    if( !verts.empty() ) memcpy( arrptr( verts ), arrptr( temp ), sizeof( size_t ) * temp.size() );
Definition at line 1063 of file MeshImpl.cpp.
References numCoords.
Referenced by MeshInterfaceTest::test_get_geometric_dimension().
    return numCoords;
void MBMesquite::MeshImpl::mark_skin_fixed ( MsqError err,
bool  clear_existing = true
Parameters:
clear_existingIf true only skin vertices are marked as fixed. If false, skin vertices will be marked as fixed in addition to any other vertices already marked as fixed.
Definition at line 326 of file MeshImpl.cpp.
References MSQ_ERRRTN, set_all_fixed_flags(), and set_skin_flags().
Referenced by get_planar_example(), MeshImplTest::load_vtk(), main(), and process_domain_args().
    if( clear_existing )
        set_all_fixed_flags( false, err );MSQ_ERRRTN( err );
    set_skin_flags( true, true, false, err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::read_exodus ( const char *  in_filename,
MBMesquite::MsqError err
Definition at line 594 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::allocate_elements(), MBMesquite::MeshImplData::allocate_vertices(), MBMesquite::arrptr(), clear(), conn, dim, MBMesquite::MsqError::FILE_ACCESS, MBMesquite::MeshImplData::fix_vertex(), MBMesquite::HEXAHEDRON, MBMesquite::MsqError::IO_ERROR, MSQ_CHKERR, MSQ_DBGOUT, MSQ_ERRRTN, MSQ_PRINT, MSQ_SETERR, myMesh, NOT_IMPLEMENTED, numCoords, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::MeshImplData::reset_element(), MBMesquite::MeshImplData::reset_vertex(), MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and MBMesquite::MsqError::UNSUPPORTED_ELEMENT.
Referenced by ExodusTest::check_mesh(), main(), and ExodusTest::test_write().
#ifndef MSQ_USING_EXODUS
    MSQ_SETERR( err )( MsqError::NOT_IMPLEMENTED );
    MSQ_DBGOUT( 1 ) << "Cannot read ExodusII file: " << in_filename << "\n";
    return;
#else
    clear();
    int app_float_size  = sizeof( double );
    int file_float_size = 0;
    float exo_version   = 0;
    int exo_err         = 0;
    // Open the file
    int file_id = ex_open( in_filename, EX_READ, &app_float_size, &file_float_size, &exo_version );
    // Make sure we opened the file correctly
    if( file_id < 0 )
        MSQ_SETERR( err )( MsqError::FILE_ACCESS );
        return;
    // make sure the file is saved as doubles
    if( file_float_size != sizeof( double ) )
        MSQ_SETERR( err )
        ( "File saved with float-sized reals.  Can only read files "
          "saved with doubles.",
        return;
    char title[MAX_LINE_LENGTH];
    int dim, vert_count, elem_count, block_count, ns_count, ss_count;
    // get info about the file
    exo_err = ex_get_init( file_id, title, &dim, &vert_count, &elem_count, &block_count, &ns_count, &ss_count );
    if( exo_err < 0 )
        MSQ_SETERR( err )( "Unable to get entity counts from file.", MsqError::PARSE_ERROR );
        return;
    myMesh->allocate_vertices( vert_count, err );MSQ_ERRRTN( err );
    myMesh->allocate_elements( elem_count, err );MSQ_ERRRTN( err );
    // Now fill in the data
    // Get the vertex coordinates
    std::vector< double > coords( vert_count * 3 );
    double* x_iter = arrptr( coords );
    double* y_iter = &coords[vert_count];
    double* z_iter = &coords[2 * vert_count];
    numCoords      = dim;
    if( dim == 2 )
        exo_err = ex_get_coord( file_id, x_iter, y_iter, 0 );
        memset( z_iter, 0, sizeof( double ) * vert_count );
    else
        exo_err = ex_get_coord( file_id, x_iter, y_iter, z_iter );
    // Make sure it worked
    if( exo_err < 0 )
        MSQ_SETERR( err )
        ( "Unable to retrieve vertex coordinates from file.", MsqError::PARSE_ERROR );
        return;
    // Store vertex coordinates in vertex array
    int i;
    for( i = 0; i < vert_count; ++i )
        myMesh->reset_vertex( i, Vector3D( *( x_iter++ ), *( y_iter++ ), *( z_iter )++ ), false, err );
    coords.clear();
    // Get block list
    std::vector< int > block_ids( block_count );
    exo_err = ex_get_elem_blk_ids( file_id, arrptr( block_ids ) );
    if( exo_err < 0 )
        MSQ_SETERR( err )( "Unable to read block IDs from file.", MsqError::PARSE_ERROR );
        return;
    std::vector< int > conn;
    size_t index = 0;
    for( i = 0; i < block_count; i++ )
        // Get info about this block's elements
        char elem_type_str[MAX_STR_LENGTH];
        int num_block_elems, verts_per_elem, num_atts;
        exo_err =
            ex_get_elem_block( file_id, block_ids[i], elem_type_str, &num_block_elems, &verts_per_elem, &num_atts );
        if( exo_err < 0 )
            MSQ_SETERR( err )( "Unable to read parameters for block.", MsqError::PARSE_ERROR );
            return;
        // Figure out which type of element we're working with
        EntityTopology elem_type;
        for( int j = 0; elem_type_str[j]; j++ )
            elem_type_str[j] = toupper( elem_type_str[j] );
        if( !strncmp( elem_type_str, "TRI", 3 ) )
            elem_type = TRIANGLE;
        else if( !strncmp( elem_type_str, "QUA", 3 ) || !strncmp( elem_type_str, "SHE", 3 ) )
            elem_type = QUADRILATERAL;
        else if( !strncmp( elem_type_str, "HEX", 3 ) )
            elem_type = HEXAHEDRON;
        else if( !strncmp( elem_type_str, "TET", 3 ) )
            elem_type = TETRAHEDRON;
        else if( !strncmp( elem_type_str, "PYRAMID", 7 ) )
            elem_type = PYRAMID;
        else if( !strncmp( elem_type_str, "WEDGE", 5 ) )
            elem_type = PRISM;
        else
            MSQ_SETERR( err )
            ( "Unrecognized element type in block", MsqError::UNSUPPORTED_ELEMENT );
            continue;
        if( conn.size() < (unsigned)( num_block_elems * verts_per_elem ) )
            conn.resize( num_block_elems * verts_per_elem );
        exo_err = ex_get_elem_conn( file_id, block_ids[i], arrptr( conn ) );
        if( exo_err < 0 )
            MSQ_SETERR( err )
            ( "Unable to read element block connectivity.", MsqError::PARSE_ERROR );
            return;
        std::vector< size_t > vertices( verts_per_elem );
        std::vector< int >::iterator conn_iter = conn.begin();
        for( const size_t end = index + num_block_elems; index < end; ++index )
            for( std::vector< size_t >::iterator iter = vertices.begin(); iter != vertices.end(); ++iter, ++conn_iter )
                *iter = *conn_iter - 1;
            myMesh->reset_element( index, vertices, elem_type, err );MSQ_CHKERR( err );
    // Finally, mark boundary nodes
    int num_fixed_nodes = 0;
    int num_dist_in_set = 0;
    if( ns_count > 0 )
        exo_err = ex_get_node_set_param( file_id, 111, &num_fixed_nodes, &num_dist_in_set );
        if( exo_err < 0 )
            MSQ_PRINT( 1 )( "\nError opening nodeset 111, no boundary nodes marked." );
    std::vector< int > fixed_nodes( num_fixed_nodes );
    if( num_fixed_nodes )
        exo_err = ex_get_node_set( file_id, 111, arrptr( fixed_nodes ) );
        if( exo_err < 0 )
            MSQ_SETERR( err )( "Error retrieving fixed nodes.", MsqError::PARSE_ERROR );
    // See if this vertex is marked as a boundary vertex
    for( i = 0; i < num_fixed_nodes; ++i )
        myMesh->fix_vertex( fixed_nodes[i] - 1, true, err );MSQ_CHKERR( err );
    // Finish up
    exo_err = ex_close( file_id );
    if( exo_err < 0 ) MSQ_SETERR( err )( "Error closing Exodus file.", MsqError::IO_ERROR );
#endif
void MBMesquite::MeshImpl::read_vtk ( const char *  in_filename,
Definition at line 1296 of file MeshImpl.cpp.
References MBMesquite::MsqError::clear(), clear(), MBMesquite::FileTokenizer::eof(), MBMesquite::MsqError::FILE_ACCESS, MBMesquite::MsqError::FILE_FORMAT, MBMesquite::MeshImplData::fix_vertex(), MBMesquite::MsqError::IO_ERROR, moab::major, MBMesquite::FileTokenizer::match_token(), MBMesquite::MeshImplData::max_vertex_index(), moab::minor, MSQ_CHKERR, MSQ_ERRRTN, MSQ_SETERR, myMesh, NOT_IMPLEMENTED, MBMesquite::MeshImplData::num_elements(), numCoords, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::MeshImplData::slave_vertex(), tag_to_bool(), tokens, vtk_read_dataset(), and vtk_read_field().
Referenced by VtkTest::check_field_attrib(), BCDTest::compare_bcd(), create_input_mesh(), do_smooth_ho(), do_smoother(), do_test(), exp_1_init(), get_cut_cube_example(), get_hex_3d_part_example(), get_native_mesh(), get_planar_example(), get_sphere_cube_example(), get_sphere_cylinder_example(), MeshImplTest::load_vtk(), main(), SlaveBoundaryVerticesTest::make_mesh(), reference(), run(), run_test(), TagVertexMeshTest::setUp(), MeshInterfaceTest::setUp(), smooth_mixed_mesh(), test(), SphericalGeometryTest::test_cg_mesh_cond_sphere(), BoundedCylinderDomainTest::test_create_curve_from_mesh(), VtkTest::test_elements(), PlanarGeometryTest::test_fit_plane(), SphericalGeometryTest::test_lapl_geo_sphere(), VertexCullingRegressionTest::test_laplacian_smoothing_with_cull(), PlanarGeometryTest::test_plane_quad_tangled(), PlanarGeometryTest::test_plane_tri_tangled(), PlanarGeometryTest::test_plane_tri_xz(), VtkTest::test_read_fixed_attrib(), VtkTest::test_read_quadratic(), VtkTest::test_read_rectilinear_grid(), VtkTest::test_read_simple_scalar_attrib(), VtkTest::test_read_structured_2d_points(), VtkTest::test_read_structured_3d_points(), VtkTest::test_read_structured_grid(), VtkTest::test_read_unstructured(), VtkTest::test_read_vector_attrib(), SphericalGeometryTest::test_smart_lapl_sphere(), VtkTest::test_write(), VtkTest::test_write_field_attrib(), VtkTest::test_write_quadratic(), and uwt().
    int major, minor;
    char vendor_string[257];
    size_t i;
    FILE* file = fopen( filename, "r" );
    if( !file )
        return;
    // Read file header
    if( !fgets( vendor_string, sizeof( vendor_string ), file ) )
        MSQ_SETERR( err )( MsqError::IO_ERROR );
        fclose( file );
        return;
    if( !strchr( vendor_string, '\n' ) || 2 != sscanf( vendor_string, "# vtk DataFile Version %d.%d", &major, &minor ) )
        MSQ_SETERR( err )( MsqError::FILE_FORMAT );
        fclose( file );
        return;
        fclose( file );
        return;
    // VTK spec says this should not exceed 256 chars.
    if( !strchr( vendor_string, '\n' ) )
        MSQ_SETERR( err )
        ( "Vendor string (line 2) exceeds 256 characters.", MsqError::PARSE_ERROR );
        fclose( file );
        return;
    // Check file type
    FileTokenizer tokens( file );
    const char* const file_type_names[] = { "ASCII", "BINARY", 0 };
    int filetype                        = tokens.match_token( file_type_names, err );MSQ_ERRRTN( err );
    if( 2 == filetype )
        MSQ_SETERR( err )
        ( "Cannot read BINARY VTK files -- use ASCII.", MsqError::NOT_IMPLEMENTED );
        return;
    // Clear any existing data
    this->clear();
    const char* outer_block_names[] = { "DATASET", "FIELD", 0 };
    // Read the mesh
    // VTK docs are inconsistant with regard to whether or not
    // a field block should be specified as "FIELD" or "DATASET FIELD",
    // so allow both.
    while( !tokens.eof() )
        int blocktype = tokens.match_token( outer_block_names, err );
        if( MSQ_CHKERR( err ) )
            if( tokens.eof() )
                err.clear();
                break;
            else
                return;
        if( blocktype == 1 )
            vtk_read_dataset( tokens, err );MSQ_ERRRTN( err );
        else
            vtk_read_field( tokens, err );MSQ_ERRRTN( err );
    // Make sure file actually contained some mesh
    if( myMesh->num_elements() == 0 )
        MSQ_SETERR( err )( "File contained no mesh.", MsqError::PARSE_ERROR );
        return;
    // There is no option for a 2-D mesh in VTK files.  Always 3
    numCoords = 3;
    // Convert tag data for fixed nodes to internal bitmap
    std::vector< bool > flags;
    tag_to_bool( "fixed", flags, err );MSQ_ERRRTN( err );
    if( !flags.empty() )
        for( i = 0; i < myMesh->max_vertex_index(); ++i )
            myMesh->fix_vertex( i, flags[i], err );MSQ_ERRRTN( err );
    flags.clear();
    tag_to_bool( "slaved", flags, err );MSQ_ERRRTN( err );
            myMesh->slave_vertex( i, flags[i], err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::release ( ) [virtual]
Instead of deleting a Mesh when you think you are done, call release(). In simple cases, the implementation could just call the destructor. More sophisticated implementations may want to keep the Mesh object to live longer than Mesquite is using it.
Definition at line 1288 of file MeshImpl.cpp.
    // delete this;
void MBMesquite::MeshImpl::release_entity_handles ( const EntityHandle handle_array,
size_t  num_handles,
MsqError err
) [virtual]
Tells the mesh that the client is finished with a given entity handle.
Definition at line 1278 of file MeshImpl.cpp.
    // Do nothing
void MBMesquite::MeshImpl::set_all_fixed_flags ( bool  value,
MsqError err
Definition at line 176 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::fix_vertex(), MBMesquite::MeshImplData::is_vertex_valid(), MBMesquite::MeshImplData::max_vertex_index(), MSQ_ERRRTN, and myMesh.
Referenced by mark_skin_fixed().
    for( size_t i = 0; i < myMesh->max_vertex_index(); ++i )
        if( myMesh->is_vertex_valid( i ) )
            myMesh->fix_vertex( i, value, err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::set_all_slaved_flags ( bool  value,
MsqError err
Set value for vertices_get_slaved_flag for all corners nodes to false and for all other nodes to the passed value.
Parameters:
valueValue to set on mid-edge, mid-face, or mid-region nodes.
You must change slave vertex mode to Settings::SLAVED_FLAG for the values returned by vertices_get_slaved_flag to be used during optimization.
Definition at line 187 of file MeshImpl.cpp.
References corners, MBMesquite::MeshImplData::element_connectivity(), MBMesquite::MeshImplData::element_topology(), MBMesquite::MeshImplData::is_element_valid(), MBMesquite::MeshImplData::max_element_index(), MSQ_ERRRTN, myMesh, and MBMesquite::MeshImplData::slave_vertex().
    for( size_t e = 0; e < myMesh->max_element_index(); ++e )
        if( !myMesh->is_element_valid( e ) ) continue;
        // Get element connectivity
        const std::vector< size_t >& verts = myMesh->element_connectivity( e, err );MSQ_ERRRTN( err );
        // Get element properties
        EntityTopology type = myMesh->element_topology( e, err );MSQ_ERRRTN( err );
        unsigned ncorner = TopologyInfo::corners( type );
        for( unsigned i = 0; i < ncorner; ++i )
            myMesh->slave_vertex( verts[i], false, err );MSQ_ERRRTN( err );
        for( unsigned i = ncorner; i < verts.size(); ++i )
void MBMesquite::MeshImpl::set_skin_flags ( bool  corner_fixed_flag,
MsqError err
Set flag values for vertices on the skin (i.e. boundary) of the mesh. Does not modify flags on iterior vertices. Call set_all_fixed _flags and set_all_slaved_flags *before* calling this function to set values on interior vertices.
Parameters:
corner_fixed_flagValue for vertices_get_fixed_flag for vertices at element corners
midnode_fixed_flagValue for vertices_get_fixed_flag for non-corner vertices (i.e. mid-face or mid-element nodes)
midnode_slaved_flagValue for vertices_get_slaved_flag for non-corner vertices (i.e. mid-face or mid-element nodes)
Definition at line 258 of file MeshImpl.cpp.
References conn, dim, MBMesquite::MeshImplData::element_connectivity(), MBMesquite::MeshImplData::element_topology(), MBMesquite::MeshImplData::fix_vertex(), MBMesquite::MeshImplData::is_element_valid(), MBMesquite::is_side_boundary(), MBMesquite::MeshImplData::max_element_index(), midedge, MSQ_ERRRTN, myMesh, n, and MBMesquite::MeshImplData::slave_vertex().
Referenced by get_cut_cube_example(), get_hex_3d_part_example(), get_sphere_cube_example(), get_sphere_cylinder_example(), and mark_skin_fixed().
    // For each element, for each side of that element, check for
    // an adjacent element.
    for( size_t i = 0; i < myMesh->max_element_index(); ++i )
        if( !myMesh->is_element_valid( i ) ) continue;
        const std::vector< size_t >& verts = myMesh->element_connectivity( i, err );
        EntityTopology type = myMesh->element_topology( i, err );
        unsigned dim        = TopologyInfo::dimension( type );
        int sides           = TopologyInfo::adjacent( type, dim - 1 );
        bool midedge, midface, midvol;
        TopologyInfo::higher_order( type, verts.size(), midedge, midface, midvol, err );MSQ_ERRRTN( err );
        const bool midside    = ( dim == 2 && midedge ) || ( dim == 3 && midface );
        const bool midsubside = dim == 3 && midedge;
        // For each side of the element (each edge for surface elems,
        // each face for volume elements)..
        for( int j = 0; j < sides; ++j )
            // Get the vertices of the side as indices into the above 'verts' list.
            unsigned n;  // number of vertices
            const unsigned* conn = TopologyInfo::side_vertices( type, dim - 1, j, n, err );MSQ_ERRRTN( err );
            // if side is on boundary, mark side vertices appropriately
            bool boundary = is_side_boundary( myMesh, i, dim - 1, j, err );MSQ_ERRRTN( err );
            if( boundary )
                // mark corner vertices as fixed
                for( unsigned k = 0; k < n; ++k )
                    myMesh->fix_vertex( verts[conn[k]], corner_fixed_flag, err );MSQ_ERRRTN( err );
                // mark higher-order node in center of side as fixed
                if( midside )
                    unsigned idx = TopologyInfo::higher_order_from_side( type, verts.size(), dim - 1, j, err );MSQ_ERRRTN( err );
                    myMesh->fix_vertex( verts[idx], midnode_fixed_flag, err );MSQ_ERRRTN( err );
                    myMesh->slave_vertex( verts[idx], midnode_slaved_flag, err );MSQ_ERRRTN( err );
                // if side is a face, mark nodes on edges of face as fixed
                if( midsubside )
                        unsigned edge[2] = { conn[k], conn[( k + 1 ) % n] };
                        bool r;
                        unsigned edge_num = TopologyInfo::find_edge( type, edge, r, err );MSQ_ERRRTN( err );
                        unsigned idx = TopologyInfo::higher_order_from_side( type, verts.size(), 1, edge_num, err );MSQ_ERRRTN( err );
        }  // for (j in sides)
    }      // for (i in elems)
TagHandle MBMesquite::MeshImpl::tag_create ( const std::string &  tag_name,
TagType  type,
unsigned  length,
const void *  default_value,
MsqError err
) [virtual]
Create a tag.
Create a user-defined data type that can be attached to any element or vertex in the mesh. For an opaque or undefined type, use type=BYTE and length=sizeof(..).
Parameters:
tag_nameA unique name for the data object
typeThe type of the data
lengthNumber of values per entity (1->scalar, >1 ->vector)
default_valueDefault value to assign to all entities - may be NULL
Returns:
- Handle for tag definition
Definition at line 2575 of file MeshImpl.cpp.
References MBMesquite::MeshImplTags::create(), MBMesquite::TagDescription::FIELD, MBMesquite::MESQUITE_FIELD_TAG, MSQ_ERRZERO, myTags, MBMesquite::TagDescription::SCALAR, size, MBMesquite::MeshImplTags::size_from_tag_type(), MBMesquite::TagDescription::TENSOR, and MBMesquite::TagDescription::VECTOR.
Referenced by main().
    TagDescription::VtkType vtype;
    std::string field;
    switch( length )
        case 1:
            vtype = TagDescription::SCALAR;
            break;
        case 3:
            vtype = TagDescription::VECTOR;
            break;
        case 9:
            vtype = TagDescription::TENSOR;
            break;
        default:
            vtype = TagDescription::FIELD;
            field = MESQUITE_FIELD_TAG;
            break;
    // If tag name contains a space, assume the tag name
    // is a concatenation of the VTK field and member names.
    if( vtype != TagDescription::FIELD && name.find( " " ) != std::string::npos ) vtype = TagDescription::FIELD;
    size_t size = MeshImplTags::size_from_tag_type( type );
    TagDescription desc( name, type, vtype, length * size, field );
    size_t index = myTags->create( desc, defval, err );
    MSQ_ERRZERO( err );
    return (TagHandle)index;
void MBMesquite::MeshImpl::tag_delete ( TagHandle  handle,
MsqError err
) [virtual]
Delete a tag.
Definition at line 2611 of file MeshImpl.cpp.
References MBMesquite::MeshImplTags::destroy(), MSQ_CHKERR, and myTags.
Referenced by tag_to_bool().
    myTags->destroy( (size_t)handle, err );MSQ_CHKERR( err );
TagHandle MBMesquite::MeshImpl::tag_get ( const std::string &  name,
MsqError err
) [virtual]
Definition at line 2616 of file MeshImpl.cpp.
References MBMesquite::MeshImplTags::handle(), MSQ_ERRZERO, MSQ_SETERR, myTags, and MBMesquite::MsqError::TAG_NOT_FOUND.
Referenced by VtkTest::check_field_attrib(), tag_to_bool(), VtkTest::test_read_simple_scalar_attrib(), and VtkTest::test_read_vector_attrib().
    size_t index = myTags->handle( name, err );
    MSQ_ERRZERO( err );
    if( !index ) MSQ_SETERR( err )( MsqError::TAG_NOT_FOUND, "could not find tag \"%s\"", name.c_str() );
void MBMesquite::MeshImpl::tag_get_element_data ( TagHandle  handle,
size_t  num_elems,
const ElementHandle elem_array,
void *  tag_data,
MsqError err
) [virtual]
Get the value of a tag for a list of mesh elements.
Parameters:
handleThe tag
num_elemsLength of elem_array
elem_arrayArray of elements for which to get the tag value.
tag_dataReturn buffer in which to copy tag data, contiguous in memory. This data is expected to be num_elems*tag_length*sizeof(tag_type) bytes.
Definition at line 2642 of file MeshImpl.cpp.
References MBMesquite::MeshImplTags::get_element_data(), MSQ_CHKERR, and myTags.
Referenced by VtkTest::check_field_attrib(), VtkTest::test_read_simple_scalar_attrib(), and VtkTest::test_read_vector_attrib().
    myTags->get_element_data( (size_t)handle, num_elems, (const size_t*)elem_array, values, err );MSQ_CHKERR( err );
void MBMesquite::MeshImpl::tag_get_vertex_data ( TagHandle  handle,
size_t  num_elems,
const VertexHandle node_array,
void *  tag_data,
MsqError err
) [virtual]
Get the value of a tag for a list of mesh vertices.
Parameters:
handleThe tag
elem_arrayArray of vertices for which to get the tag value.
Definition at line 2660 of file MeshImpl.cpp.
References MBMesquite::MeshImplTags::get_vertex_data(), MSQ_CHKERR, and myTags.
    myTags->get_vertex_data( (size_t)handle, num_elems, (const size_t*)elem_array, values, err );MSQ_CHKERR( err );
void MBMesquite::MeshImpl::tag_properties ( TagHandle  handle,
std::string &  name_out,
TagType type_out,
unsigned &  length_out,
MsqError err
) [virtual]
Get data type and number of values per entity for tag.
Parameters:
handleTag to get properties of.
name_outPassed back tag name.
type_outPassed back tag type.
length_outPassed back number of values per entity.
Definition at line 2624 of file MeshImpl.cpp.
References MSQ_ERRRTN, myTags, MBMesquite::TagDescription::name, MBMesquite::MeshImplTags::properties(), MBMesquite::TagDescription::size, MBMesquite::MeshImplTags::size_from_tag_type(), and MBMesquite::TagDescription::type.
    const TagDescription& desc = myTags->properties( (size_t)handle, err );MSQ_ERRRTN( err );
    name   = desc.name;
    type   = desc.type;
    length = (unsigned)( desc.size / MeshImplTags::size_from_tag_type( desc.type ) );
void MBMesquite::MeshImpl::tag_set_element_data ( TagHandle  handle,
size_t  num_elems,
const void *  tag_data,
MsqError err
) [virtual]
Set the value of a tag for a list of mesh elements.
Parameters:
handleThe tag
elem_arrayArray of elements for which to set the tag value.
tag_dataTag data for each element, contiguous in memory. This data is expected to be num_elems*tag_length*sizeof(tag_type) bytes.
Definition at line 2633 of file MeshImpl.cpp.
References MSQ_CHKERR, myTags, and MBMesquite::MeshImplTags::set_element_data().
    myTags->set_element_data( (size_t)handle, num_elems, (const size_t*)elem_array, values, err );MSQ_CHKERR( err );
void MBMesquite::MeshImpl::tag_set_vertex_data ( TagHandle  handle,
size_t  num_elems,
MsqError err
) [virtual]
Set the value of a tag for a list of mesh vertices.
Parameters:
handleThe tag
num_elemsLength of node_array
node_arrayArray of vertices for which to set the tag value.
Definition at line 2651 of file MeshImpl.cpp.
References MSQ_CHKERR, myTags, and MBMesquite::MeshImplTags::set_vertex_data().
    myTags->set_vertex_data( (size_t)handle, num_elems, (const size_t*)elem_array, values, err );MSQ_CHKERR( err );
void MBMesquite::MeshImpl::tag_to_bool ( const char *  tag_name,
std::vector< bool > &  vertex_vals,
MsqError err
) [private]
Convert tag data stored on vertices to boolean values. Deletes tag data. Passes back empty result vector if no tag.
Definition at line 1413 of file MeshImpl.cpp.
References MBMesquite::Mesh::BOOL, MBMesquite::Mesh::BYTE, MBMesquite::MsqError::clear(), MBMesquite::Mesh::DOUBLE, MBMesquite::MsqError::FILE_FORMAT, MBMesquite::MeshImplTags::get_vertex_data(), MBMesquite::Mesh::HANDLE, MBMesquite::Mesh::INT, MBMesquite::MeshImplData::max_vertex_index(), MSQ_CHKERR, MSQ_ERRRTN, MSQ_SETERR, myMesh, myTags, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::MeshImplTags::properties(), tag_delete(), tag_get(), MBMesquite::MeshImplTags::tag_has_vertex_data(), and MBMesquite::TagDescription::type.
Referenced by read_vtk().
    TagHandle handle = tag_get( tag_name, err );
    if( !handle || MSQ_CHKERR( err ) )
        err.clear();
        values.clear();
        return;
    size_t i;
    values.resize( myMesh->max_vertex_index(), false );
    const TagDescription& tag_desc = myTags->properties( (size_t)handle, err );MSQ_ERRRTN( err );
    bool havedata = myTags->tag_has_vertex_data( (size_t)handle, err );MSQ_ERRRTN( err );
    if( !havedata )
        MSQ_SETERR( err )
        ( MsqError::FILE_FORMAT, "'%s' attribute on elements, not vertices", tag_name );
        return;
    switch( tag_desc.type )
        case BYTE: {
            char data;
                myTags->get_vertex_data( (size_t)handle, 1, &i, &data, err );MSQ_ERRRTN( err );
                values[i] = !!data;
            break;
        case BOOL: {
                bool data;
                values[i] = data;
            break;
        case INT: {
            int data;
                values[i] = !!data;
            break;
        case DOUBLE: {
            double data;
                values[i] = !!data;
            break;
        case HANDLE: {
            unsigned long data;
                values[i] = !!data;
            break;
        default:
            MSQ_SETERR( err )( MsqError::PARSE_ERROR, "'%s' attribute has invalid type", tag_name );
            return;
    tag_delete( handle, err );
void MBMesquite::MeshImpl::vertex_get_byte ( const VertexHandle  vertex,
unsigned char *  byte,
MsqError err
) [virtual]
Retrieve the byte value for the specified vertex or vertices. The byte value is 0 if it has not yet been set via one of the _set_byte() functions.
Definition at line 1187 of file MeshImpl.cpp.
References MSQ_CHKERR, and vertices_get_byte().
Referenced by MeshInterfaceTest::test_vertex_byte().
    vertices_get_byte( &vertex, byte, 1, err );MSQ_CHKERR( err );
Definition at line 1091 of file MeshImpl.cpp.
References myMesh.
    return new MeshImplVertIter( myMesh );
void MBMesquite::MeshImpl::vertex_set_byte ( VertexHandle  vertex,
unsigned char  byte,
MsqError err
) [virtual]
Each vertex has a byte-sized flag that can be used to store flags. This byte's value is neither set nor used by the mesh implementation. It is intended to be used by Mesquite algorithms. Until a vertex's byte has been explicitly set, its value is 0.
Definition at line 1168 of file MeshImpl.cpp.
References MSQ_CHKERR, and vertices_set_byte().
    vertices_set_byte( &vertex, &byte, 1, err );MSQ_CHKERR( err );
void MBMesquite::MeshImpl::vertex_set_coordinates ( VertexHandle  vertex,
const Vector3D coordinates,
MsqError err
) [virtual]
void MBMesquite::MeshImpl::vertices_get_attached_elements ( const VertexHandle vertex_array,
size_t  num_vertex,
std::vector< ElementHandle > &  elements,
MsqError err
) [virtual]
Get adjacency data for vertices
Parameters:
vertex_arrayArray of vertex handles specifying the list of vertices to retrieve adjacency data for.
num_vertexNumber of vertex handles in #vertex_array
elementsThe array in which to place the handles of elements adjacent to the input vertices.
offsetsFor each vertex in #vertex_array, the value in the corresponding position in this array is the index into #elem_array at which the adjacency list begins for that vertex.
Definition at line 1216 of file MeshImpl.cpp.
References MBMesquite::adj(), MSQ_ERRRTN, myMesh, and MBMesquite::MeshImplData::vertex_adjacencies().
Referenced by main(), MeshImplTest::skin_mesh_2D(), MeshImplTest::skin_mesh_3D(), SlaveBoundaryVerticesTest::test_slaved_common(), and MeshInterfaceTest::test_vertex_get_attached_elements().
    elements.clear();
    offsets.clear();
    offsets.reserve( num_vertices + 1 );
    const VertexHandle* const vtx_end = vertices + num_vertices;
    for( ; vertices < vtx_end; ++vertices )
        const std::vector< size_t >& adj = myMesh->vertex_adjacencies( (size_t)*vertices, err );MSQ_ERRRTN( err );
        prev_offset = prev_offset + adj.size();
        std::transform( adj.begin(), adj.end(), std::back_inserter( elements ), cast_handle< ElementHandle >() );
void MBMesquite::MeshImpl::vertices_get_byte ( const VertexHandle vertex,
unsigned char *  byte_array,
size_t  array_size,
MsqError err
) [virtual]
Definition at line 1173 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::get_vertex_byte(), MSQ_ERRRTN, and myMesh.
Referenced by SlaveBoundaryVerticesTest::test_slaved_common(), MeshInterfaceTest::test_vertex_byte(), and vertex_get_byte().
    for( size_t i = 0; i < array_size; i++ )
        byte_array[i] = myMesh->get_vertex_byte( (size_t)vert_array[i], err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::vertices_get_fixed_flag ( const VertexHandle  vert_array[],
std::vector< bool > &  fixed_flag_array,
size_t  num_vtx,
MsqError err
) [virtual]
Returns true or false, indicating whether the vertex is allowed to be repositioned. True indicates that the vertex is fixed and cannot be moved. Note that this is a read-only property; this flag can't be modified by users of the MBMesquite::Mesh interface.
Definition at line 1112 of file MeshImpl.cpp.
References MSQ_ERRRTN, myMesh, and MBMesquite::MeshImplData::vertex_is_fixed().
Referenced by main(), MeshImplTest::skin_mesh_2D(), MeshImplTest::skin_mesh_3D(), MeshImplTest::skin_mesh_higher_order(), MeshImplTest::skin_mesh_mixed(), VtkTest::test_read_fixed_attrib(), SlaveBoundaryVerticesTest::test_slaved_common(), and MeshInterfaceTest::test_vertex_is_fixed().
    on_bnd.resize( num_vtx );
    for( size_t i = 0; i < num_vtx; ++i )
        on_bnd[i] = myMesh->vertex_is_fixed( (size_t)vert_array[i], err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::vertices_get_slaved_flag ( const VertexHandle  vert_array[],
std::vector< bool > &  slaved_flag_array,
size_t  num_vtx,
MsqError err
) [virtual]
Returns true or false, indicating whether the vertex is a higher-order node that should be slaved to the logical mid-point of the element side it lies on or not, respectively.
Note: This function will never be called unless this behavior is requested by calling: InstructionQueue::set_slaved_ho_node_mode( Settings::SLAVE_FLAG )
Definition at line 1135 of file MeshImpl.cpp.
References MSQ_ERRRTN, myMesh, and MBMesquite::MeshImplData::vertex_is_slaved().
    flags.resize( num_vtx );
        flags[i] = myMesh->vertex_is_slaved( (size_t)vert_array[i], err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::vertices_set_byte ( const VertexHandle vert_array,
const unsigned char *  byte_array,
size_t  array_size,
MsqError err
) [virtual]
Definition at line 1192 of file MeshImpl.cpp.
References MSQ_ERRRTN, myMesh, and MBMesquite::MeshImplData::set_vertex_byte().
Referenced by MeshInterfaceTest::test_vertex_byte(), and vertex_set_byte().
        myMesh->set_vertex_byte( (size_t)vertex[i], byte_array[i], err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::vertices_set_fixed_flag ( const VertexHandle  vert_array[],
const std::vector< bool > &  fixed_flag_array,
size_t  num_vtx,
MsqError err
Definition at line 1124 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::fix_vertex(), MSQ_ERRRTN, and myMesh.
    assert( on_bnd.size() >= num_vtx );
        myMesh->fix_vertex( (size_t)vert_array[i], on_bnd[i], err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::vtk_create_structured_elems ( const long *  dims,
MsqError err
) [private]
Helper function for readers of structured mesh - create elements
Definition at line 1900 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::allocate_elements(), conn, corners, MBMesquite::HEXAHEDRON, MSQ_ERRRTN, MSQ_SETERR, myMesh, NOT_IMPLEMENTED, MBMesquite::QUADRILATERAL, MBMesquite::MeshImplData::reset_element(), and z.
Referenced by vtk_read_rectilinear_grid(), vtk_read_structured_grid(), and vtk_read_structured_points().
    // NOTE: this should be work fine for edges also if
    //      Mesquite ever supports them.  Just add the
    //      type for dimension 1 to the switch statement.
    // int non_zero[3] = {0,0,0};  // True if dim > 0 for x, y, z respectively
    long elem_dim  = 0;           // Element dimension (2->quad, 3->hex)
    long num_elems = 1;           // Total number of elements
    long vert_per_elem;           // Element connectivity length
    long edims[3] = { 1, 1, 1 };  // Number of elements in each grid direction
    // Populate above data
    for( int d = 0; d < 3; d++ )
        if( dims[d] > 1 )
            // non_zero[elem_dim] = d;
            edims[d] = dims[d] - 1;
            num_elems *= edims[d];
            elem_dim++;
    vert_per_elem = 1 << elem_dim;
    // Get element type from element dimension
    EntityTopology type;
    switch( elem_dim )
            // case 1: type = EDGE;          break;
        case 2:
            break;
        case 3:
            type = HEXAHEDRON;
            break;
        default:
            MSQ_SETERR( err )
            ( "Cannot create structured mesh with elements "
              "of dimension < 2 or > 3.",
            return;
    // Allocate storage for elements
    myMesh->allocate_elements( num_elems, err );MSQ_ERRRTN( err );
    // Offsets of element vertices in grid relative to corner closest to origin
    long k                = dims[0] * dims[1];
    const long corners[8] = { 0, 1, 1 + dims[0], dims[0], k, k + 1, k + 1 + dims[0], k + dims[0] };
    // Populate element list
    std::vector< size_t > conn( vert_per_elem );
    size_t elem_idx = 0;
    for( long z = 0; z < edims[2]; ++z )
        for( long y = 0; y < edims[1]; ++y )
            for( long x = 0; x < edims[0]; ++x )
                const long index = x + y * dims[0] + z * ( dims[0] * dims[1] );
                for( long j = 0; j < vert_per_elem; ++j )
                    conn[j] = index + corners[j];
                myMesh->reset_element( elem_idx++, conn, type, err );MSQ_ERRRTN( err );
void * MBMesquite::MeshImpl::vtk_read_attrib_data ( FileTokenizer file,
TagDescription tag_out,
MsqError err
) [private]
Read actual data for both vtk_read_point_data() and vtk_read_cell_data() Initializes all fields of passed TagDescription
Returns:
NULL if field data, otherwise pointer to malloc'd data.
Definition at line 2035 of file MeshImpl.cpp.
References MBMesquite::TagDescription::COLOR, MBMesquite::TagDescription::FIELD, MBMesquite::FileTokenizer::get_string(), MBMesquite::FileTokenizer::match_token(), MSQ_ERRZERO, MBMesquite::TagDescription::name, MBMesquite::NONE, NORMAL, MBMesquite::TagDescription::SCALAR, MBMesquite::TagDescription::TENSOR, MBMesquite::TagDescription::TEXTURE, MBMesquite::FileTokenizer::unget_token(), MBMesquite::TagDescription::VECTOR, vtk_read_color_attrib(), vtk_read_scalar_attrib(), vtk_read_tensor_attrib(), vtk_read_texture_attrib(), vtk_read_vector_attrib(), and MBMesquite::TagDescription::vtkType.
Referenced by vtk_read_cell_data(), and vtk_read_point_data().
    const char* const type_names[] = { "SCALARS", "COLOR_SCALARS", "VECTORS", "NORMALS", "TEXTURE_COORDINATES",
                                       "TENSORS", "FIELD",
                                       // Some buggy VTK files have empty CELL_DATA/POINT_DATA
                                       // blocks Try to allow them by checking for possible other
                                       // tokens indicating the end of the block
                                       "POINT_DATA", "CELL_DATA", "DATASET", 0 };
    int type = tokens.match_token( type_names, err );
    MSQ_ERRZERO( err );
    if( type > 7 )  // empty CELL_DATA/POINT_DATA block.
        tag.vtkType = TagDescription::NONE;
        tokens.unget_token();
        return 0;
    const char* name = tokens.get_string( err );
    MSQ_ERRZERO( err );
    tag.name = name;
    void* data = 0;
    switch( type )
        case 1:
            data        = vtk_read_scalar_attrib( tokens, count, tag, err );
            tag.vtkType = TagDescription::SCALAR;
            break;
        case 2:
            data        = vtk_read_color_attrib( tokens, count, tag, err );
            tag.vtkType = TagDescription::COLOR;
            break;
        case 3:
            data        = vtk_read_vector_attrib( tokens, count, tag, err );
            tag.vtkType = TagDescription::VECTOR;
            break;
        case 4:
            tag.vtkType = TagDescription::NORMAL;
            break;
        case 5:
            data        = vtk_read_texture_attrib( tokens, count, tag, err );
            tag.vtkType = TagDescription::TEXTURE;
            break;
        case 6:
            data        = vtk_read_tensor_attrib( tokens, count, tag, err );
            tag.vtkType = TagDescription::TENSOR;
            break;
        case 7:
            data        = 0;
            tag.vtkType = TagDescription::FIELD;
            break;
    return data;
void MBMesquite::MeshImpl::vtk_read_cell_data ( FileTokenizer file,
MsqError err
) [private]
Read attribute data for elements
Definition at line 2145 of file MeshImpl.cpp.
References MBMesquite::TagDescription::FIELD, MBMesquite::FileTokenizer::get_integers(), MSQ_CHKERR, MSQ_ERRRTN, myMesh, MBMesquite::TagDescription::name, MBMesquite::MeshImplData::num_elements(), vtk_read_attrib_data(), vtk_read_field_data(), vtk_store_cell_data(), and MBMesquite::TagDescription::vtkType.
Referenced by vtk_read_dataset().
    TagDescription tag;
    void* data = vtk_read_attrib_data( tokens, myMesh->num_elements(), tag, err );
    if( data )  // normal attribute
        vtk_store_cell_data( data, tag, err );
        free( data );MSQ_CHKERR( err );
        return;
    else if( tag.vtkType == TagDescription::FIELD )
        std::string field = tag.name;
        int field_count;
        tokens.get_integers( 1, &field_count, err );MSQ_ERRRTN( err );
        for( int i = 0; i < field_count; ++i )
            data = vtk_read_field_data( tokens, myMesh->num_elements(), field_count, field, tag, err );MSQ_ERRRTN( err );
            free( data );MSQ_ERRRTN( err );
void * MBMesquite::MeshImpl::vtk_read_color_attrib ( FileTokenizer file,
long  count,
MsqError err
) [private]
Read color attribute data Initializes size and type fields of passed TagDescroption
Definition at line 2367 of file MeshImpl.cpp.
References MBMesquite::Mesh::DOUBLE, MBMesquite::FileTokenizer::get_floats(), MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::line_number(), MSQ_CHKERR, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::TagDescription::size, size, and MBMesquite::TagDescription::type.
Referenced by vtk_read_attrib_data().
    long size;
    tokens.get_long_ints( 1, &size, err );
    MSQ_ERRZERO( err );
    if( size < 1 )
        MSQ_SETERR( err )
        ( MsqError::PARSE_ERROR, "Invalid size (%ld) at line %d", size, tokens.line_number() );
        return 0;
    float* data = (float*)malloc( sizeof( float ) * count * size );
    tokens.get_floats( count * size, data, err );
        free( data );
        return 0;
    tag.size = size * sizeof( float );
    tag.type = DOUBLE;
    return data;
void MBMesquite::MeshImpl::vtk_read_dataset ( FileTokenizer file,
MsqError err
) [private]
Read a data block from the file
Definition at line 1490 of file MeshImpl.cpp.
References MBMesquite::MsqError::clear(), MBMesquite::FileTokenizer::eof(), MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::line_number(), MBMesquite::FileTokenizer::match_token(), MSQ_ERRRTN, MSQ_SETERR, myMesh, MBMesquite::MeshImplData::num_elements(), MBMesquite::MeshImplData::num_vertices(), MBMesquite::MsqError::PARSE_ERROR, MBMesquite::FileTokenizer::unget_token(), vtk_read_cell_data(), vtk_read_field(), vtk_read_point_data(), vtk_read_polydata(), vtk_read_rectilinear_grid(), vtk_read_structured_grid(), vtk_read_structured_points(), and vtk_read_unstructured_grid().
    const char* const data_type_names[] = {
        "STRUCTURED_POINTS", "STRUCTURED_GRID", "UNSTRUCTURED_GRID", "POLYDATA", "RECTILINEAR_GRID", "FIELD", 0 };
    int datatype = tokens.match_token( data_type_names, err );MSQ_ERRRTN( err );
    // Ignore FIELD data at beginning of DATASET. As far as I (J.Kraftcheck)
    // understand the VTK documentation, there should never be a FIELD block
    // inside a dataset, except in attribute data.  However, some app somewhere
    // writes them this way, so try to handle them.
    for( ;; )
        tokens.match_token( "FIELD", err );
        if( err )
            err.clear();
            break;
    switch( datatype )
        case 1:
            vtk_read_structured_points( tokens, err );
            break;
        case 2:
            vtk_read_structured_grid( tokens, err );
            break;
        case 3:
            vtk_read_unstructured_grid( tokens, err );
            break;
        case 4:
            vtk_read_polydata( tokens, err );
            break;
        case 5:
            vtk_read_rectilinear_grid( tokens, err );
            break;
        case 6:
            break;
    // Read attribute data
    const char* const block_type_names[] = { "POINT_DATA", "CELL_DATA", "DATASET", 0 };
    int blocktype                        = 0;
        // get POINT_DATA or CELL_DATA
        int new_block_type = tokens.match_token( block_type_names, err );
        if( new_block_type == 3 )  // done reading attributes
            return;
        if( err )
            if( tokens.eof() )
                err.clear();
                break;
            // If next token was neither POINT_DATA nor CELL_DATA,
            // then there's another attribute under the current one.
            if( blocktype )
                err.clear();
            else
                MSQ_ERRRTN( err );
        else
            blocktype = new_block_type;
            long count;
            tokens.get_long_ints( 1, &count, err );MSQ_ERRRTN( err );
            if( blocktype == 1 && (unsigned long)count != myMesh->num_vertices() )
                MSQ_SETERR( err )
                  "Count inconsistent with number of vertices"
                  " at line %d.",
                return;
            else if( blocktype == 2 && (unsigned long)count != myMesh->num_elements() )
                MSQ_SETERR( err )
                  "Count inconsistent with number of elements"
                  " at line %d.",
                return;
            vtk_read_point_data( tokens, err );
        else
            vtk_read_cell_data( tokens, err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::vtk_read_field ( FileTokenizer file,
MsqError err
) [private]
Read file-level field data
Definition at line 2017 of file MeshImpl.cpp.
References MBMesquite::FileTokenizer::get_integers(), MBMesquite::FileTokenizer::get_string(), MSQ_ERRRTN, and vtk_read_field_data().
Referenced by read_vtk(), and vtk_read_dataset().
    // This is not supported yet.
    // Parse the data but throw it away because
    // Mesquite has no internal representation for it.
    std::string name = tokens.get_string( err );MSQ_ERRRTN( err );
    int count;
    tokens.get_integers( 1, &count, err );MSQ_ERRRTN( err );
    for( int i = 0; i < count; i++ )
        TagDescription tag;
        void* ptr = vtk_read_field_data( tokens, 0, 1, "", tag, err );
        if( ptr ) free( ptr );MSQ_ERRRTN( err );
void * MBMesquite::MeshImpl::vtk_read_field_data ( FileTokenizer file,
size_t  count,
size_t  field_count,
const std::string &  field_name,
TagDescription tag,
MsqError err
) [private]
Read field data
Parameters:
countexpected number of tuples, or zero if not known
Definition at line 1963 of file MeshImpl.cpp.
References MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::get_string(), MBMesquite::FileTokenizer::line_number(), MBMesquite::FileTokenizer::match_token(), MBMesquite::TagDescription::member, MSQ_CHKERR, MSQ_ERRZERO, MSQ_SETERR, MBMesquite::TagDescription::name, MBMesquite::MsqError::PARSE_ERROR, sizes, and vtk_read_typed_data().
Referenced by vtk_read_cell_data(), vtk_read_field(), and vtk_read_point_data().
    tag.member = tokens.get_string( err );
    MSQ_ERRZERO( err );
    // If field is a struct containing multiple members, make
    // tag name the concatentation of the field name and member
    // name.
    if( num_fields > 1 )
        tag.name = field_name;
        tag.name += " ";
        tag.name += tag.member;
        tag.member.clear();
    // If field contains only one member, then make the tag
    // name be the field name, and store the member name to
    // preserve it for subsequent writes.
    else
    // Get tuple size and count from the file.
    long sizes[2];
    tokens.get_long_ints( 2, sizes, err );
    MSQ_ERRZERO( err );
    if( sizes[0] < 1 )
        MSQ_SETERR( err )
        ( MsqError::PARSE_ERROR, "Invalid tuple size (%ld) for field data %s at line %d\n", sizes[0], tag.name.c_str(),
        return 0;
    if( sizes[1] < 0 || ( count && (size_t)sizes[1] != count ) )
        MSQ_SETERR( err )
          "Invalid field data length at line %d.  "
          "Cannot map %lu tuples to  %ld entities.\n",
          tokens.line_number(), (unsigned long)count, sizes[1] );
        return 0;
    int type = tokens.match_token( vtk_type_names, err );
    MSQ_ERRZERO( err );
    void* result = vtk_read_typed_data( tokens, type, sizes[0], sizes[1], tag, err );MSQ_CHKERR( err );
    return result;
void MBMesquite::MeshImpl::vtk_read_point_data ( FileTokenizer file,
MsqError err
) [private]
Read attribute data for vertices
Definition at line 2093 of file MeshImpl.cpp.
References MBMesquite::TagDescription::FIELD, MBMesquite::FileTokenizer::get_integers(), MSQ_CHKERR, MSQ_ERRRTN, myMesh, MBMesquite::TagDescription::name, MBMesquite::MeshImplData::num_vertices(), vtk_read_attrib_data(), vtk_read_field_data(), vtk_store_point_data(), and MBMesquite::TagDescription::vtkType.
    TagDescription tag;
    void* data = vtk_read_attrib_data( tokens, myMesh->num_vertices(), tag, err );
        vtk_store_point_data( data, tag, err );
        return;
        int field_count;
            data = vtk_read_field_data( tokens, myMesh->num_vertices(), field_count, field, tag, err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::vtk_read_polydata ( FileTokenizer file,
MsqError err
) [private]
Read polydata mesh
Definition at line 1731 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::allocate_vertices(), MBMesquite::FileTokenizer::get_doubles(), MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::get_newline(), MBMesquite::FileTokenizer::line_number(), MBMesquite::FileTokenizer::match_token(), MSQ_ERRRTN, MSQ_SETERR, myMesh, NOT_IMPLEMENTED, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::MeshImplData::reset_vertex(), MBMesquite::Vector3D::to_array(), vtk_read_polygons(), and vtx().
    long num_verts;
    vector< int > connectivity;
    const char* const poly_data_names[] = { "VERTICES", "LINES", "POLYGONS", "TRIANGLE_STRIPS", 0 };
    tokens.match_token( "POINTS", err );MSQ_ERRRTN( err );
    tokens.get_long_ints( 1, &num_verts, err );MSQ_ERRRTN( err );
    tokens.match_token( vtk_type_names, err );MSQ_ERRRTN( err );
    tokens.get_newline( err );MSQ_ERRRTN( err );
    if( num_verts < 1 )
        MSQ_SETERR( err )
        ( MsqError::PARSE_ERROR, "Invalid point count at line %d", tokens.line_number() );
        return;
    myMesh->allocate_vertices( num_verts, err );MSQ_ERRRTN( err );
    for( size_t vtx = 0; vtx < (size_t)num_verts; ++vtx )
        Vector3D pos;
        tokens.get_doubles( 3, const_cast< double* >( pos.to_array() ), err );MSQ_ERRRTN( err );
        myMesh->reset_vertex( vtx, pos, false, err );MSQ_ERRRTN( err );
    int poly_type = tokens.match_token( poly_data_names, err );MSQ_ERRRTN( err );
    switch( poly_type )
        case 3:
            vtk_read_polygons( tokens, err );MSQ_ERRRTN( err );
            break;
        case 4:
            MSQ_SETERR( err )
            ( MsqError::NOT_IMPLEMENTED, "Unsupported type: triangle strips at line %d", tokens.line_number() );
            return;
        case 1:
        case 2:
            MSQ_SETERR( err )
            ( MsqError::NOT_IMPLEMENTED, "Entities of dimension < 2 at line %d", tokens.line_number() );
            return;
void MBMesquite::MeshImpl::vtk_read_polygons ( FileTokenizer file,
MsqError err
) [private]
Helper function for vtk_read_polydata() - reads polygon subsection
Definition at line 1775 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::allocate_elements(), MBMesquite::arrptr(), conn, MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::get_newline(), MSQ_ERRRTN, myMesh, MBMesquite::POLYGON, MBMesquite::MeshImplData::reset_element(), and size.
Referenced by vtk_read_polydata().
    long size[2];
    tokens.get_long_ints( 2, size, err );MSQ_ERRRTN( err );
    myMesh->allocate_elements( size[0], err );MSQ_ERRRTN( err );
    std::vector< long > conn;
    for( int i = 0; i < size[0]; ++i )
        long count;
        conn.resize( count );
        tokens.get_long_ints( count, arrptr( conn ), err );MSQ_ERRRTN( err );
        myMesh->reset_element( i, conn, POLYGON, err );MSQ_ERRRTN( err );
Read rectilinear grid structured mesh
Definition at line 1679 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::allocate_vertices(), MBMesquite::FileTokenizer::get_doubles(), MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::get_newline(), MBMesquite::FileTokenizer::line_number(), MBMesquite::FileTokenizer::match_token(), MSQ_ERRRTN, MSQ_SETERR, myMesh, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::MeshImplData::reset_vertex(), vtk_create_structured_elems(), and vtx().
    int i, j, k;
    long dims[3];
    const char* labels[] = { "X_COORDINATES", "Y_COORDINATES", "Z_COORDINATES" };
    vector< double > coords[3];
    tokens.match_token( "DIMENSIONS", err );MSQ_ERRRTN( err );
    tokens.get_long_ints( 3, dims, err );MSQ_ERRRTN( err );
    if( dims[0] < 1 || dims[1] < 1 || dims[2] < 1 )
        MSQ_SETERR( err )
        ( MsqError::PARSE_ERROR, "Invalid dimension at line %d", tokens.line_number() );
        return;
    for( i = 0; i < 3; i++ )
        long count;
        tokens.match_token( labels[i], err );MSQ_ERRRTN( err );
        if( count != dims[i] )
            MSQ_SETERR( err )
              "Coordinate count inconsistent with dimensions"
              " at line %d",
            return;
        coords[i].resize( count );
        tokens.get_doubles( count, &coords[i][0], err );MSQ_ERRRTN( err );
    myMesh->allocate_vertices( dims[0] * dims[1] * dims[2], err );MSQ_ERRRTN( err );
    size_t vtx = 0;
    for( k = 0; k < dims[2]; ++k )
        for( j = 0; j < dims[1]; ++j )
            for( i = 0; i < dims[0]; ++i )
                myMesh->reset_vertex( vtx++, Vector3D( coords[0][i], coords[1][j], coords[2][k] ), false, err );MSQ_ERRRTN( err );
    vtk_create_structured_elems( dims, err );MSQ_ERRRTN( err );
void * MBMesquite::MeshImpl::vtk_read_scalar_attrib ( FileTokenizer file,
long  count,
MsqError err
) [private]
Read scalar attribute data Initializes size and type fields of passed TagDescroption
Definition at line 2257 of file MeshImpl.cpp.
References MBMesquite::arrptr(), MBMesquite::Mesh::DOUBLE, MBMesquite::FileTokenizer::get_doubles(), MBMesquite::FileTokenizer::get_floats(), MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::get_string(), MBMesquite::FileTokenizer::line_number(), MBMesquite::FileTokenizer::match_token(), MSQ_ERRZERO, MSQ_SETERR, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::TagDescription::size, size, MBMesquite::TagDescription::type, MBMesquite::FileTokenizer::unget_token(), and vtk_read_typed_data().
    if( !count ) return 0;
    MSQ_ERRZERO( err );
    long size;
    const char* tok = tokens.get_string( err );
    MSQ_ERRZERO( err );
    const char* end = 0;
    size            = strtol( tok, (char**)&end, 0 );
    if( *end )
        size = 1;
    // VTK spec says cannot be greater than 4--do we care?
    if( size < 1 || size > 4 )
        MSQ_SETERR( err )
          "Scalar count out of range [1,4]"
          " at line %d",
        return 0;
    tokens.match_token( "LOOKUP_TABLE", err );
    MSQ_ERRZERO( err );
    MSQ_ERRZERO( err );
    // If no lookup table, just read and return the data
    if( !strcmp( tok, "default" ) )
        void* ptr = vtk_read_typed_data( tokens, type, size, count, desc, err );
        MSQ_ERRZERO( err );
        return ptr;
    // If we got this far, then the data has a lookup
    // table.  First read the lookup table and convert
    // to integers.
    string name = tok;
    vector< long > table( size * count );
    if( type > 0 && type < 10 )  // Is an integer type
        tokens.get_long_ints( table.size(), arrptr( table ), err );
        MSQ_ERRZERO( err );
    else  // Is a real-number type
        for( std::vector< long >::iterator iter = table.begin(); iter != table.end(); ++iter )
            double data;
            tokens.get_doubles( 1, &data, err );
            MSQ_ERRZERO( err );
            *iter = (long)data;
            if( (double)*iter != data )
                MSQ_SETERR( err )
                ( MsqError::PARSE_ERROR, "Invalid lookup index (%.0f) at line %d", data, tokens.line_number() );
                return 0;
    // Now read the data - must be float RGBA color triples
    long table_count;
    MSQ_ERRZERO( err );
    tokens.match_token( name.c_str(), err );
    MSQ_ERRZERO( err );
    tokens.get_long_ints( 1, &table_count, err );
    MSQ_ERRZERO( err );
    vector< float > table_data( table_count * 4 );
    tokens.get_floats( table_data.size(), arrptr( table_data ), err );
    MSQ_ERRZERO( err );
    // Create list from indexed data
    float* data      = (float*)malloc( sizeof( float ) * count * size * 4 );
    float* data_iter = data;
    for( std::vector< long >::iterator idx = table.begin(); idx != table.end(); ++idx )
        if( *idx < 0 || *idx >= table_count )
            MSQ_SETERR( err )
            ( MsqError::PARSE_ERROR, "LOOKUP_TABLE index %ld out of range.", *idx );
            free( data );
            return 0;
        for( int i = 0; i < 4; i++ )
            *data_iter = table_data[4 * *idx + i];
            ++data_iter;
    desc.size = size * 4 * sizeof( float );
    desc.type = DOUBLE;
    return data;
Read structured grid mesh
Definition at line 1638 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::allocate_vertices(), MBMesquite::FileTokenizer::get_doubles(), MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::get_newline(), MBMesquite::FileTokenizer::line_number(), MBMesquite::FileTokenizer::match_token(), MSQ_ERRRTN, MSQ_SETERR, myMesh, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::MeshImplData::reset_vertex(), MBMesquite::Vector3D::to_array(), vtk_create_structured_elems(), and vtx().
    long num_verts, dims[3];
        MSQ_SETERR( err )
        return;
    if( num_verts != ( dims[0] * dims[1] * dims[2] ) )
        MSQ_SETERR( err )
          "Point count not consistent with dimensions "
          "at line %d",
        return;
        Vector3D pos;
Read structured point mesh
Definition at line 1599 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::allocate_vertices(), MBMesquite::FileTokenizer::get_doubles(), MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::get_newline(), MBMesquite::FileTokenizer::line_number(), MBMesquite::FileTokenizer::match_token(), MSQ_ERRRTN, MSQ_SETERR, myMesh, origin, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::MeshImplData::reset_vertex(), vtk_create_structured_elems(), and vtx().
    long i, j, k;
    long dims[3];
    double origin[3], space[3];
        MSQ_SETERR( err )
        return;
    tokens.match_token( "ORIGIN", err );MSQ_ERRRTN( err );
    tokens.get_doubles( 3, origin, err );MSQ_ERRRTN( err );
    const char* const spacing_names[] = { "SPACING", "ASPECT_RATIO", 0 };
    tokens.match_token( spacing_names, err );MSQ_ERRRTN( err );
    tokens.get_doubles( 3, space, err );MSQ_ERRRTN( err );
    size_t vtx = 0;
    Vector3D off( origin[0], origin[1], origin[2] );
                myMesh->reset_vertex( vtx++, off + Vector3D( i * space[0], j * space[1], k * space[2] ), false, err );MSQ_ERRRTN( err );
void * MBMesquite::MeshImpl::vtk_read_tensor_attrib ( FileTokenizer file,
long  count,
MsqError err
) [private]
Read tensor (3x3 matrix) data Initializes size and type fields of passed TagDescroption
Definition at line 2423 of file MeshImpl.cpp.
References MBMesquite::FileTokenizer::match_token(), MSQ_ERRZERO, and vtk_read_typed_data().
    MSQ_ERRZERO( err );
    void* result = vtk_read_typed_data( tokens, type, 9, count, tag, err );
    MSQ_ERRZERO( err );
    return result;
void * MBMesquite::MeshImpl::vtk_read_texture_attrib ( FileTokenizer file,
long  count,
MsqError err
) [private]
Read texture attribute data Initializes size and type fields of passed TagDescroption
Definition at line 2403 of file MeshImpl.cpp.
References dim, MBMesquite::FileTokenizer::get_integers(), MBMesquite::FileTokenizer::line_number(), MBMesquite::FileTokenizer::match_token(), MSQ_ERRZERO, MSQ_SETERR, MBMesquite::MsqError::PARSE_ERROR, and vtk_read_typed_data().
    int type, dim;
    tokens.get_integers( 1, &dim, err );
    MSQ_ERRZERO( err );
    MSQ_ERRZERO( err );
    if( dim < 1 || dim > 3 )
        MSQ_SETERR( err )
        ( MsqError::PARSE_ERROR, "Invalid dimension (%d) at line %d.", dim, tokens.line_number() );
        return 0;
    void* result = vtk_read_typed_data( tokens, type, dim, count, tag, err );
    MSQ_ERRZERO( err );
    return result;
void * MBMesquite::MeshImpl::vtk_read_typed_data ( FileTokenizer file,
int  type,
size_t  per_elem,
size_t  num_elem,
MsqError err
) [private]
Read a 2-D array of data of the specified type from the file Initializes size and type fields of passed TagDescroption
Definition at line 2197 of file MeshImpl.cpp.
References MBMesquite::Mesh::BOOL, MBMesquite::Mesh::DOUBLE, MBMesquite::FileTokenizer::get_booleans(), MBMesquite::FileTokenizer::get_doubles(), MBMesquite::FileTokenizer::get_integers(), MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::Mesh::HANDLE, MBMesquite::Mesh::INT, MBMesquite::MsqError::INVALID_ARG, MSQ_CHKERR, MSQ_SETERR, MBMesquite::TagDescription::size, and MBMesquite::TagDescription::type.
Referenced by vtk_read_field_data(), vtk_read_scalar_attrib(), vtk_read_tensor_attrib(), vtk_read_texture_attrib(), and vtk_read_vector_attrib().
    void* data_ptr;
    size_t count = per_elem * num_elem;
    switch( type )
        case 1:
            tag.size = per_elem * sizeof( bool );
            tag.type = BOOL;
            data_ptr = malloc( num_elem * tag.size );
            tokens.get_booleans( count, (bool*)data_ptr, err );
            break;
        case 2:
        case 3:
        case 4:
        case 5:
        case 6:
        case 7:
            tag.size = per_elem * sizeof( int );
            tag.type = INT;
            tokens.get_integers( count, (int*)data_ptr, err );
            break;
        case 8:
        case 9:
            // this is a bit of a hack since MeshImpl doesn't have a LONG type (HANDLE is used by
            // ParallelMesh for long)
            tag.size = per_elem * sizeof( size_t );
            assert( sizeof( long ) == sizeof( size_t ) );
            assert( sizeof( long ) == sizeof( void* ) );
            tag.type = HANDLE;
            tokens.get_long_ints( count, (long*)data_ptr, err );
            break;
        case 10:
        case 11:
            tag.size = per_elem * sizeof( double );
            tag.type = DOUBLE;
            tokens.get_doubles( count, (double*)data_ptr, err );
            break;
        default:
            MSQ_SETERR( err )( "Invalid data type", MsqError::INVALID_ARG );
            return 0;
        free( data_ptr );
        return 0;
    return data_ptr;
Read unstructured mesh
Definition at line 1794 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::allocate_elements(), MBMesquite::MeshImplData::allocate_vertices(), MBMesquite::arrptr(), conn, MBMesquite::MeshImplData::element_connectivity(), MBMesquite::MeshImplData::element_topology(), MBMesquite::VtkTypeInfo::find_type(), MBMesquite::FileTokenizer::get_doubles(), MBMesquite::FileTokenizer::get_long_ints(), MBMesquite::FileTokenizer::get_newline(), MBMesquite::FileTokenizer::line_number(), MBMesquite::FileTokenizer::match_token(), MBMesquite::MIXED, MSQ_ERRRTN, MSQ_SETERR, MBMesquite::VtkTypeInfo::msqType, myMesh, MBMesquite::VtkTypeInfo::name, MBMesquite::VtkTypeInfo::numNodes, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::POLYGON, MBMesquite::MeshImplData::reset_element(), MBMesquite::MeshImplData::reset_vertex(), size, MBMesquite::Vector3D::to_array(), MBMesquite::MsqError::UNSUPPORTED_ELEMENT, MBMesquite::VtkTypeInfo::vtkConnOrder, and vtx().
    long i, num_verts, num_elems[2];
    if( num_verts < 1 )
        MSQ_SETERR( err )
        return;
        Vector3D pos;
    tokens.match_token( "CELLS", err );MSQ_ERRRTN( err );
    tokens.get_long_ints( 2, num_elems, err );MSQ_ERRRTN( err );
    myMesh->allocate_elements( num_elems[0], err );MSQ_ERRRTN( err );
    for( i = 0; i < num_elems[0]; ++i )
        long count;
        myMesh->reset_element( i, conn, MIXED, err );MSQ_ERRRTN( err );
    tokens.match_token( "CELL_TYPES", err );MSQ_ERRRTN( err );
    tokens.get_long_ints( 1, &num_elems[1], err );MSQ_ERRRTN( err );
    if( num_elems[0] != num_elems[1] )
        MSQ_SETERR( err )
          "Number of element types does not match number of elements"
          "at line %d",
        return;
    std::vector< size_t > tconn;
        long type;
        size_t size;
        tokens.get_long_ints( 1, &type, err );MSQ_ERRRTN( err );
        // Check if type is a valid value
        const VtkTypeInfo* info = VtkTypeInfo::find_type( type, err );
        if( err || !info || ( !info->numNodes && type != POLYGON ) )
            MSQ_SETERR( err )
            ( MsqError::PARSE_ERROR, "Invalid cell type %ld at line %d.", type, tokens.line_number() );
            return;
        // Check if Mesquite supports the type
        if( info->msqType == MIXED )
            MSQ_SETERR( err )
            ( MsqError::UNSUPPORTED_ELEMENT, "Unsupported cell type %ld (%s) at line %d.", type, info->name,
            return;
        // If node-ordering is not the same as exodus...
        if( info->vtkConnOrder )
            size = myMesh->element_connectivity( i, err ).size();MSQ_ERRRTN( err );
            if( info->numNodes != size )
                MSQ_SETERR( err )
                ( MsqError::UNSUPPORTED_ELEMENT, "Cell type %ld (%s) for element with %d nodes at Line %d", type,
                  info->name, (int)size, tokens.line_number() );
                return;
            tconn.resize( size );
            const std::vector< size_t >& pconn = myMesh->element_connectivity( i, err );MSQ_ERRRTN( err );
            for( size_t j = 0; j < size; ++j )
                tconn[j] = pconn[info->vtkConnOrder[j]];
            myMesh->reset_element( i, tconn, info->msqType, err );MSQ_ERRRTN( err );
        // Othewise (if node ordering is the same), just set the type.
        else
            myMesh->element_topology( i, info->msqType, err );MSQ_ERRRTN( err );
    }  // for(i)
void * MBMesquite::MeshImpl::vtk_read_vector_attrib ( FileTokenizer file,
long  count,
MsqError err
) [private]
Read vector or normal attribute data Initializes size and type fields of passed TagDescroption
Definition at line 2393 of file MeshImpl.cpp.
    MSQ_ERRZERO( err );
    void* result = vtk_read_typed_data( tokens, type, 3, count, tag, err );
    MSQ_ERRZERO( err );
    return result;
void MBMesquite::MeshImpl::vtk_store_cell_data ( const void *  data,
TagDescription desc,
MsqError err
) [private]
Store data read in vtk_read_cell_data into mesh tags
Definition at line 2170 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::all_elements(), MBMesquite::arrptr(), MBMesquite::MeshImplTags::create(), MBMesquite::MeshImplTags::handle(), MSQ_ERRRTN, MSQ_SETERR, myMesh, myTags, MBMesquite::TagDescription::name, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::MeshImplTags::properties(), and MBMesquite::MeshImplTags::set_element_data().
Referenced by vtk_read_cell_data().
    size_t tag_handle = myTags->handle( tag.name, err );MSQ_ERRRTN( err );
    if( !tag_handle )
        tag_handle = myTags->create( tag, 0, err );MSQ_ERRRTN( err );
    else
        const TagDescription& desc = myTags->properties( tag_handle, err );MSQ_ERRRTN( err );
        if( desc != tag )
            MSQ_SETERR( err )
              "Inconsistent types between element "
              "and vertex attributes named \"%s\"\n",
              tag.name.c_str() );
            return;
    std::vector< size_t > element_handles;
    myMesh->all_elements( element_handles, err );MSQ_ERRRTN( err );
    if( !element_handles.empty() )
        myTags->set_element_data( tag_handle, element_handles.size(), arrptr( element_handles ), data, err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::vtk_store_point_data ( const void *  data,
MsqError err
) [private]
Store data read in vtk_read_point_data into mesh tags
Definition at line 2118 of file MeshImpl.cpp.
References MBMesquite::MeshImplData::all_vertices(), MBMesquite::arrptr(), MBMesquite::MeshImplTags::create(), MBMesquite::MeshImplTags::handle(), MSQ_ERRRTN, MSQ_SETERR, myMesh, myTags, MBMesquite::TagDescription::name, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::MeshImplTags::properties(), and MBMesquite::MeshImplTags::set_vertex_data().
Referenced by vtk_read_point_data().
    if( !tag_handle )
    else
        if( desc != tag )
            MSQ_SETERR( err )
              tag.name.c_str() );
            return;
    std::vector< size_t > vertex_handles;
    myMesh->all_vertices( vertex_handles, err );MSQ_ERRRTN( err );
    if( !vertex_handles.empty() )
        myTags->set_vertex_data( tag_handle, vertex_handles.size(), arrptr( vertex_handles ), data, err );MSQ_ERRRTN( err );
void MBMesquite::MeshImpl::vtk_write_attrib_data ( std::ostream &  file,
const TagDescription desc,
const void *  data,
size_t  count,
MsqError err
) const [private]
Write tag data to VTK attributes
Definition at line 2433 of file MeshImpl.cpp.
References MBMesquite::Mesh::BOOL, MBMesquite::Mesh::BYTE, MBMesquite::TagDescription::COLOR, MBMesquite::Mesh::DOUBLE, MBMesquite::TagDescription::FIELD, MBMesquite::get_field_names(), MBMesquite::Mesh::HANDLE, MBMesquite::Mesh::INT, INTERNAL_ERROR, MSQ_ERRRTN, MSQ_SETERR, MBMesquite::TagDescription::name, MBMesquite::TagDescription::NONE, MBMesquite::TagDescription::NORMAL, MBMesquite::TagDescription::SCALAR, MBMesquite::TagDescription::size, MBMesquite::MeshImplTags::size_from_tag_type(), MBMesquite::TagDescription::TENSOR, MBMesquite::TagDescription::TEXTURE, MBMesquite::TagDescription::type, MBMesquite::TagDescription::VECTOR, and MBMesquite::TagDescription::vtkType.
Referenced by write_vtk().
    // [email protected]: we now allow this type to be able to write e.g. GLOBAL_ID for parallel
    // meshes
    if (desc.type == HANDLE)
      MSQ_SETERR(err)("Cannot write HANDLE tag data to VTK file.",
                      MsqError::FILE_FORMAT);
      return;
    TagDescription::VtkType vtk_type = desc.vtkType;
    unsigned vlen                    = desc.size / MeshImplTags::size_from_tag_type( desc.type );
    // guess one from data length if not set
    if( vtk_type == TagDescription::NONE )
        switch( vlen )
            default:
                vtk_type = TagDescription::SCALAR;
                break;
            case 3:
                vtk_type = TagDescription::VECTOR;
                break;
            case 9:
                vtk_type = TagDescription::TENSOR;
                break;
                return;
    // [email protected]: from class Mesh, the typenames below should correspond in order...
    // enum TagType { BYTE, BOOL, INT, DOUBLE, HANDLE };
    const char* const typenames[] = { "unsigned_char", "bit", "int", "double", "unsigned_long" };
    std::string field, member;
    int num_per_line;
    switch( vtk_type )
        case TagDescription::SCALAR:
            num_per_line = vlen;
            file << "SCALARS " << desc.name << " " << typenames[desc.type] << " " << vlen << "\n";
            file << "LOOKUP_TABLE default\n";
            break;
        case TagDescription::COLOR:
            file << "COLOR_SCALARS " << desc.name << " " << vlen << "\n";
            break;
        case TagDescription::VECTOR:
            num_per_line = 3;
            if( vlen != 3 )
                MSQ_SETERR( err )
                ( MsqError::INTERNAL_ERROR, "Tag \"%s\" is labeled as a VTK vector attribute but has %u values.",
                  desc.name.c_str(), vlen );
                return;
            file << "VECTORS " << desc.name << " " << typenames[desc.type] << "\n";
            break;
        case TagDescription::NORMAL:
            num_per_line = 3;
            if( vlen != 3 )
                MSQ_SETERR( err )
                ( MsqError::INTERNAL_ERROR, "Tag \"%s\" is labeled as a VTK normal attribute but has %u values.",
                return;
            file << "NORMALS " << desc.name << " " << typenames[desc.type] << "\n";
            break;
        case TagDescription::TEXTURE:
            file << "TEXTURE_COORDINATES " << desc.name << " " << typenames[desc.type] << " " << vlen << "\n";
            break;
        case TagDescription::TENSOR:
            num_per_line = 3;
            if( vlen != 9 )
                MSQ_SETERR( err )
                ( MsqError::INTERNAL_ERROR, "Tag \"%s\" is labeled as a VTK tensor attribute but has %u values.",
                return;
            file << "TENSORS " << desc.name << " " << typenames[desc.type] << "\n";
            break;
        case TagDescription::FIELD:
            get_field_names( desc, field, member, err );MSQ_ERRRTN( err );
            file << member << " " << vlen << " " << count << " " << typenames[desc.type] << "\n";
            break;
        default:
            MSQ_SETERR( err )( "Unknown VTK attribute type for tag.", MsqError::INTERNAL_ERROR );
            return;
    size_t i, total = count * vlen;
    char* space = new char[num_per_line];
    memset( space, ' ', num_per_line );
    space[num_per_line - 1]    = '\n';
    const unsigned char* odata = (const unsigned char*)data;
    const bool* bdata          = (const bool*)data;
    const int* idata           = (const int*)data;
    const long* ldata          = (const long*)data;
    const double* ddata        = (const double*)data;
    switch( desc.type )
        case BYTE:
            for( i = 0; i < total; ++i )
                file << (unsigned int)odata[i] << space[i % num_per_line];
            break;
        case BOOL:
                file << ( bdata[i] ? '1' : '0' ) << space[i % num_per_line];
            break;
        case INT:
                file << idata[i] << space[i % num_per_line];
            break;
        case DOUBLE:
                file << ddata[i] << space[i % num_per_line];
            break;
        case HANDLE:
                file << ldata[i] << space[i % num_per_line];
            break;
        default:
            MSQ_SETERR( err )( "Unknown tag type.", MsqError::INTERNAL_ERROR );
    delete[] space;
void MBMesquite::MeshImpl::write_exodus ( const char *  out_filename,
MBMesquite::MsqError err
Write mesh to ExodusII file.
Writes an exodus file of the mesh.
Definition at line 788 of file MeshImpl.cpp.
References MBMesquite::arrptr(), conn, MBMesquite::MeshImplData::element_connectivity(), MBMesquite::MeshImplData::element_topology(), MBMesquite::MsqError::FILE_ACCESS, fixed, MBMesquite::MeshImplData::get_vertex_coords(), MBMesquite::HEXAHEDRON, INTERNAL_ERROR, MBMesquite::MsqError::INVALID_STATE, MBMesquite::MsqError::IO_ERROR, MBMesquite::MeshImplData::is_element_valid(), MBMesquite::MeshImplData::is_vertex_valid(), MBMesquite::MeshImplData::max_element_index(), moab::MAX_NODES, MBMesquite::MeshImplData::max_vertex_index(), MBMesquite::MIXED, MSQ_DBGOUT, MSQ_ERRRTN, MSQ_SETERR, myMesh, NOT_IMPLEMENTED, MBMesquite::MeshImplData::num_elements(), MBMesquite::MeshImplData::num_vertices(), numCoords, MBMesquite::MsqError::PARSE_ERROR, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, MBMesquite::MeshImplData::vertex_is_fixed(), MBMesquite::Vector3D::x(), MBMesquite::Vector3D::y(), z, and MBMesquite::Vector3D::z().
Referenced by main(), and ExodusTest::test_write().
    // just return an error if we don't have access to exodus
#ifndef MSQ_USING_EXODUS
    MSQ_SETERR( err )( "Exodus not enabled in this build of Mesquite", MsqError::NOT_IMPLEMENTED );
    MSQ_DBGOUT( 1 ) << "Cannot read ExodusII file: " << out_filename << "\n";
    return;
#else
    size_t i, j, k;
    if( !myMesh || !myMesh->num_vertices() )
        MSQ_SETERR( err )
        ( "No vertices in MeshImpl.  Nothing written to file.", MsqError::PARSE_ERROR );
        return;
    // get some element info
    // We need to know how many of each element type we have.  We
    // are going to create an element block for each element type
    // that exists the mesh.  Block 1 will be tri3; block 2 will be
    // shell; block 3 will be tetra, and block 4 will be hex.
    const unsigned MAX_NODES = 27;
    const unsigned MIN_NODES = 2;
    int counts[MIXED][MAX_NODES + 1];
    memset( counts, 0, sizeof( counts ) );
    for( i = 0; i < myMesh->max_element_index(); ++i )
        EntityTopology type = myMesh->element_topology( i, err );MSQ_ERRRTN( err );
        unsigned nodes = myMesh->element_connectivity( i, err ).size();MSQ_ERRRTN( err );
        if( (unsigned)type >= MIXED || nodes < MIN_NODES || nodes > MAX_NODES )
            MSQ_SETERR( err )( "Invalid element typology.", MsqError::INTERNAL_ERROR );
            return;
        ++counts[type][nodes];
    // Count number of required element blocks
    int block_count = 0;
    for( i = 0; i < MIXED; ++i )
        for( j = MIN_NODES; j < MAX_NODES; ++j )
            if( counts[i][j] ) ++block_count;
    // figure out if we have fixed nodes, if so, we need a nodeset
    int num_fixed_nodes = 0;
        bool fixed = myMesh->is_vertex_valid( i ) && myMesh->vertex_is_fixed( i, err );MSQ_ERRRTN( err );
        num_fixed_nodes += fixed;
    // write doubles instead of floats
    int app_float_size  = sizeof( double );
    int file_float_size = sizeof( double );
    int exo_err         = 0;
    // Create the file.  If it exists, clobber it.  This could be dangerous.
    int file_id = ex_create( out_filename, EX_CLOBBER, &app_float_size, &file_float_size );
    // Make sure we opened the file correctly
    if( file_id < 0 )
        MSQ_SETERR( err )( MsqError::FILE_ACCESS );
        return;
    char title[MAX_LINE_LENGTH] = "Mesquite Export";
    size_t vert_count = myMesh->num_vertices();
    size_t elem_count = myMesh->num_elements();
    int ns_count = 0;
    if( num_fixed_nodes > 0 ) ns_count = 1;
    int ss_count = 0;
    // put the initial info about the file
    exo_err = ex_put_init( file_id, title, numCoords, vert_count, elem_count, block_count, ns_count, ss_count );
    if( exo_err < 0 )
        MSQ_SETERR( err )( "Unable to initialize file data.", MsqError::IO_ERROR );
        return;
    // Gather vertex coordinate data and write to file.
    std::vector< double > coords( vert_count * 3 );
    std::vector< double >::iterator x, y, z;
    x = coords.begin();
    y = x + vert_count;
    z = y + vert_count;
        if( !myMesh->is_vertex_valid( i ) ) continue;
        if( z == coords.end() )
            MSQ_SETERR( err )( "Array overflow", MsqError::INTERNAL_ERROR );
            return;
        Vector3D coords = myMesh->get_vertex_coords( i, err );MSQ_ERRRTN( err );
        *x = coords.x();
        ++x;
        *y = coords.y();
        ++y;
        *z = coords.z();
        ++z;
    if( z != coords.end() )
        MSQ_SETERR( err )( "Counter at incorrect number.", MsqError::INTERNAL_ERROR );
        return;
    // put the coords
    exo_err = ex_put_coord( file_id, arrptr( coords ), &coords[vert_count], &coords[2 * vert_count] );
    if( exo_err < 0 )
        MSQ_SETERR( err )( "Unable to put vertex coordinates in file.", MsqError::IO_ERROR );
        return;
    // put the names of the coordinates
    char* coord_names[] = { "x", "y", "z" };
    exo_err             = ex_put_coord_names( file_id, coord_names );
    // Create element-type arrays indexed by EntityTopology
    const char* tri_name  = "TRI";
    const char* quad_name = "SHELL";
    const char* tet_name  = "TETRA";
    const char* hex_name  = "HEX";
    const char* wdg_name  = "WEDGE";
    const char* pyr_name  = "PYRAMID";
    const char* exo_names[MIXED];
    memset( exo_names, 0, sizeof( exo_names ) );
    exo_names[TRIANGLE]      = tri_name;
    exo_names[QUADRILATERAL] = quad_name;
    exo_names[TETRAHEDRON]   = tet_name;
    exo_names[HEXAHEDRON]    = hex_name;
    exo_names[PRISM]         = wdg_name;
    exo_names[PYRAMID]       = pyr_name;
    unsigned min_nodes[MIXED];
    memset( min_nodes, 0, sizeof( min_nodes ) );
    min_nodes[TRIANGLE]      = 3;
    min_nodes[QUADRILATERAL] = 4;
    min_nodes[TETRAHEDRON]   = 4;
    min_nodes[HEXAHEDRON]    = 8;
    min_nodes[PRISM]         = 6;
    min_nodes[PYRAMID]       = 5;
    // For each element type (topology and num nodes)
    int block_id = 0;
    char name_buf[16];
    int num_atts = 0;
    std::vector< int > conn;
            // Have any of this topo & count combination?
            if( !counts[i][j] ) continue;
            // Is a supported ExodusII type?
            if( !exo_names[i] )
                MSQ_SETERR( err )
                ( MsqError::INVALID_STATE, "Element topology %d not supported by ExodusII", (int)i );
                return;
            // Construct ExodusII element name from topo & num nodes
            if( j == min_nodes[i] )
                strcpy( name_buf, exo_names[i] );
            else
                sprintf( name_buf, "%s%d", exo_names[i], (int)j );
            // Create element block
            ++block_id;
            exo_err = ex_put_elem_block( file_id, block_id, name_buf, counts[i][j], j, num_atts );
            if( exo_err < 0 )
                MSQ_SETERR( err )( "Error creating the tri block.", MsqError::IO_ERROR );
                return;
            // For each element
            conn.resize( counts[i][j] * j );
            std::vector< int >::iterator iter = conn.begin();
            for( k = 0; k < myMesh->max_element_index(); ++k )
                // If not correct topo, skip it.
                if( !myMesh->is_element_valid( k ) || (unsigned)( myMesh->element_topology( k, err ) ) != i ) continue;MSQ_ERRRTN( err );
                // If not correct number nodes, skip it
                const std::vector< size_t >& elem_conn = myMesh->element_connectivity( k, err );MSQ_ERRRTN( err );
                if( elem_conn.size() != j ) continue;
                // Append element connectivity to list
                for( std::vector< size_t >::const_iterator citer = elem_conn.begin(); citer != elem_conn.end();
                     ++citer, ++iter )
                    assert( iter != conn.end() );
                    *iter = *citer + 1;
            // Make sure everything adds up
            if( iter != conn.end() )
                MSQ_SETERR( err )( MsqError::INTERNAL_ERROR );
                return;
            // Write element block connectivity
            exo_err = ex_put_elem_conn( file_id, block_id, arrptr( conn ) );
            if( exo_err < 0 )
                MSQ_SETERR( err )( "Error writing element connectivity.", MsqError::IO_ERROR );
                return;
    // Finally, mark boundary nodes
        exo_err = ex_put_node_set_param( file_id, 111, num_fixed_nodes, 0 );
        if( exo_err < 0 )
            MSQ_SETERR( err )( "Error while initializing node set.", MsqError::IO_ERROR );
            return;
        int node_id = 0;
        std::vector< int > fixed_nodes( num_fixed_nodes );
        std::vector< int >::iterator iter = fixed_nodes.begin();
        for( i = 0; i < myMesh->max_vertex_index(); ++i )
            ++node_id;
            if( myMesh->vertex_is_fixed( i, err ) )
                if( iter == fixed_nodes.end() )
                    return;
                *iter = node_id;
                ++iter;
        if( iter != fixed_nodes.end() )
            return;
        exo_err = ex_put_node_set( file_id, 111, arrptr( fixed_nodes ) );
        if( exo_err < 0 )
            MSQ_SETERR( err )( "Error while writing node set.", MsqError::IO_ERROR );
            return;
    exo_err = ex_close( file_id );
    if( exo_err < 0 ) MSQ_SETERR( err )( "Error closing Exodus file.", MsqError::IO_ERROR );
#endif
void MBMesquite::MeshImpl::write_vtk ( const char *  out_filename,
Write mesh to VTK file format version 3.0.
Definition at line 377 of file MeshImpl.cpp.
References MBMesquite::arrptr(), MBMesquite::MsqError::clear(), conn, MBMesquite::MeshImplData::element_connectivity(), MBMesquite::MeshImplData::element_topology(), MBMesquite::MsqError::error_code(), MBMesquite::TagDescription::FIELD, MBMesquite::MsqError::FILE_ACCESS, MBMesquite::VtkTypeInfo::find_type(), MBMesquite::MeshImplTags::get_element_data(), MBMesquite::get_field_names(), MBMesquite::MeshImplData::get_vertex_coords(), MBMesquite::MeshImplTags::get_vertex_data(), MBMesquite::MeshImplData::have_slaved_flags(), INTERNAL_ERROR, MBMesquite::MeshImplData::is_element_valid(), MBMesquite::MeshImplData::is_vertex_valid(), MBMesquite::MeshImplData::max_element_index(), MBMesquite::MeshImplData::max_vertex_index(), MBMesquite::VtkTypeInfo::mesquiteToVtkOrder(), MSQ_CHKERR, MSQ_ERRRTN, MSQ_SETERR, MBMesquite::VtkTypeInfo::msqType, myMesh, myTags, MBMesquite::TagDescription::name, MBMesquite::MeshImplData::num_elements(), MBMesquite::MeshImplData::num_vertex_uses(), MBMesquite::MeshImplData::num_vertices(), MBMesquite::POLYGON, MBMesquite::MeshImplTags::properties(), MBMesquite::TagDescription::size, MBMesquite::MeshImplTags::tag_begin(), MBMesquite::MeshImplTags::tag_end(), MBMesquite::MeshImplTags::tag_has_element_data(), MBMesquite::MeshImplTags::tag_has_vertex_data(), MBMesquite::MsqError::TAG_NOT_FOUND, MBMesquite::MeshImplData::vertex_is_fixed(), MBMesquite::MeshImplData::vertex_is_slaved(), vtk_write_attrib_data(), MBMesquite::VtkTypeInfo::vtkType, and MBMesquite::TagDescription::vtkType.
Referenced by BCDTest::compare_bcd(), cond_write_file(), do_smooth_ho(), do_smoother(), do_test(), MeshImplTest::dump_mesh(), main(), run_example(), run_test(), test(), VtkTest::test_write(), VtkTest::test_write_field_attrib(), VtkTest::test_write_quadratic(), uwt(), and write_mesh().
    ofstream file( out_filename );
    if( !file )
        return;
    file.precision( 10 );
    // Write a header
    file << "# vtk DataFile Version 3.0\n";
    file << "Mesquite Mesh\n";
    file << "ASCII\n";
    file << "DATASET UNSTRUCTURED_GRID\n";
    // Write vertex coordinates
    file << "POINTS " << myMesh->num_vertices() << " double\n";
    std::vector< size_t > vertex_indices( myMesh->max_vertex_index() );
    size_t i, count = 0;
        if( myMesh->is_vertex_valid( i ) )
            file << coords[0] << ' ' << coords[1] << ' ' << coords[2] << '\n';
            vertex_indices[i] = count++;
        else
            vertex_indices[i] = myMesh->max_vertex_index();
    // Write out the connectivity table
    size_t elem_idx;
    size_t connectivity_size = myMesh->num_elements() + myMesh->num_vertex_uses();
    file << "CELLS " << myMesh->num_elements() << ' ' << connectivity_size << '\n';
    for( elem_idx = 0; elem_idx < myMesh->max_element_index(); ++elem_idx )
        if( !myMesh->is_element_valid( elem_idx ) ) continue;
        std::vector< size_t > conn = myMesh->element_connectivity( elem_idx, err );MSQ_ERRRTN( err );
        EntityTopology topo = myMesh->element_topology( elem_idx, err );MSQ_ERRRTN( err );
        // If necessary, convert from Exodus to VTK node-ordering.
        const VtkTypeInfo* info = VtkTypeInfo::find_type( topo, conn.size(), err );MSQ_ERRRTN( err );
        if( info->msqType != POLYGON ) info->mesquiteToVtkOrder( conn );
        file << conn.size();
        for( i = 0; i < conn.size(); ++i )
            file << ' ' << vertex_indices[(size_t)conn[i]];
        file << '\n';
    // Write out the element types
    file << "CELL_TYPES " << myMesh->num_elements() << '\n';
        count = myMesh->element_connectivity( elem_idx, err ).size();MSQ_ERRRTN( err );
        const VtkTypeInfo* info = VtkTypeInfo::find_type( topo, count, err );MSQ_ERRRTN( err );
        file << info->vtkType << '\n';
    // Write out which points are fixed.
    file << "POINT_DATA " << myMesh->num_vertices() << "\nSCALARS fixed int\nLOOKUP_TABLE default\n";
        if( myMesh->is_vertex_valid( i ) ) file << ( myMesh->vertex_is_fixed( i, err ) ? "1" : "0" ) << "\n";
    if( myMesh->have_slaved_flags() )
        file << "SCALARS slaved int\nLOOKUP_TABLE default\n";
            if( myMesh->is_vertex_valid( i ) ) file << ( myMesh->vertex_is_slaved( i, err ) ? "1" : "0" ) << "\n";
    // Make pass over the list of tags to:
    // - Check if there are any tags on elements.
    // - Get the list of field names by which to group tag data.
    // - Assign VTK types for tags that have an unknown VTK type.
    MeshImplTags::TagIterator tagiter;
    std::multimap< std::string, size_t > fields;
    bool have_elem_data = false;
    for( tagiter = myTags->tag_begin(); tagiter != myTags->tag_end(); ++tagiter )
        bool haveelem = myTags->tag_has_element_data( *tagiter, err );MSQ_ERRRTN( err );
        if( haveelem ) have_elem_data = true;
        const TagDescription& desc = myTags->properties( *tagiter, err );
        fields.insert( std::multimap< std::string, size_t >::value_type( field, *tagiter ) );
    // Write vertex tag data to vtk attributes, group by field.
    // We already wrote the header line for the POINT_DATA block
    // with the fixed flag, so just write the rest of the tags now.
    std::multimap< std::string, size_t >::iterator f, e;
    f = fields.begin();
    while( f != fields.end() )
        if( !myTags->tag_has_vertex_data( f->second, err ) )
            ++f;
            continue;
        int pcount = 0;
        for( e = f; e != fields.end() && e->first == f->first; ++e )
            if( myTags->tag_has_vertex_data( e->second, err ) ) ++pcount;
        if( !pcount ) continue;
        if( myTags->properties( f->second, err ).vtkType == TagDescription::FIELD )
            file << "FIELD " << f->first << " " << pcount << std::endl;
        else if( pcount > 1 )
            MSQ_SETERR( err )
            ( MsqError::INTERNAL_ERROR, "Tag name \"%s\" conflicts with VTK field name in tag \"%s\"\n",
              f->first.c_str(), myTags->properties( ( ++f )->second, err ).name.c_str() );
            return;
        for( ; f != e; ++f )
            if( !myTags->tag_has_vertex_data( f->second, err ) ) continue;
            const TagDescription& desc = myTags->properties( f->second, err );MSQ_ERRRTN( err );
            std::vector< char > tagdata( myMesh->num_vertices() * desc.size );
            std::vector< char >::iterator iter = tagdata.begin();
                    myTags->get_vertex_data( f->second, 1, &i, &*iter, err );
                    if( err.error_code() == MsqError::TAG_NOT_FOUND )
                        memset( &*iter, 0, desc.size );
                        err.clear();
                    else if( MSQ_CHKERR( err ) )
                        return;
                    iter += desc.size;
            vtk_write_attrib_data( file, desc, arrptr( tagdata ), myMesh->num_vertices(), err );MSQ_ERRRTN( err );
    // If no element tags, then done
    if( !have_elem_data )
        file.close();
        return;
    // Begin element data section
    file << "\nCELL_DATA " << myMesh->num_elements() << "\n";
    // Write element tag data to vtk attributes, group by field.
    f = fields.begin();
        if( !myTags->tag_has_element_data( f->second, err ) )
            ++f;
            continue;
        int pcount = 0;
            if( myTags->tag_has_element_data( e->second, err ) ) ++pcount;
            MSQ_SETERR( err )
            return;
            if( !myTags->tag_has_element_data( f->second, err ) ) continue;
            std::vector< char > tagdata( myMesh->num_elements() * desc.size );
                if( myMesh->is_element_valid( i ) )
                    myTags->get_element_data( f->second, 1, &i, &*iter, err );
                        err.clear();
                        return;
                    iter += desc.size;
            vtk_write_attrib_data( file, desc, arrptr( tagdata ), myMesh->num_elements(), err );MSQ_ERRRTN( err );
    // Close the file
    file.close();
Member Data Documentation
Coordinate values per vertex
Definition at line 412 of file MeshImpl.hpp.
Referenced by get_geometric_dimension(), read_exodus(), read_vtk(), and write_exodus().
List of all members.
