MBMesquite::MsqDebug Class Reference
Run-time activation/deactivation of debug flags. More...
#include <MsqDebug.hpp>
+ Collaboration diagram for MBMesquite::MsqDebug:
Classes
class  FormatPrinter
class  InitializeFlags
Public Types
enum  { WARN = 1, INFO = 2 }
Static Public Member Functions
static void enable (unsigned flag)
 Enable a debug flag.
static void disable (unsigned flag)
 Disable a debug flag.
static void set (unsigned flag, bool state)
 Set a debug flag.
static bool get (unsigned flag)
 Check a debug flag.
static void disable_all ()
 Disable all debug streams.
static std::ostream & get_stream (unsigned flag)
 Get the output stream to be used for a given debug flag.
static void set_stream (unsigned flag, std::ostream &stream)
 Set the output stream to be used for a given debug flag.
Static Private Attributes
static std::vector
< std::ostream * >
streams
static std::vector< bool > flags
static InitializeFlags init
Detailed Description
Author:
Jason Kraftcheck
Date:
2004-10-18
Wrap static functions for managing debug flags and associated output streams. Output is expected do be done using the provided macros MSQ_DBGOUT(), MSQ_PRINT(), and MSQ_DBG().
The default output stream for all flags is cout.
Definition at line 73 of file MsqDebug.hpp.
Member Enumeration Documentation
anonymous enum
Enumerator:
WARN
INFO
Definition at line 77 of file MsqDebug.hpp.
        WARN = 1,
        INFO = 2
Member Function Documentation
static void MBMesquite::MsqDebug::disable ( unsigned  flag) [inline, static]
Definition at line 89 of file MsqDebug.hpp.
        set( flag, false );
Definition at line 102 of file MsqDebug.cpp.
References flags.
Referenced by MBMesquite::VertexMover::loop_over_mesh().
    flags.clear();
static void MBMesquite::MsqDebug::enable ( unsigned  flag) [inline, static]
Definition at line 84 of file MsqDebug.hpp.
Referenced by main(), ParShapeImprover::run(), and MBMesquite::save_or_restore_debug_state().
        set( flag, true );
bool MBMesquite::MsqDebug::get ( unsigned  flag) [static]
Check a debug flag.
Definition at line 81 of file MsqDebug.cpp.
References flags.
Referenced by MBMesquite::MsqDebug::FormatPrinter::print(), and MBMesquite::save_or_restore_debug_state().
    return flag < flags.size() && flags[flag];
std::ostream & MBMesquite::MsqDebug::get_stream ( unsigned  flag) [static]
Definition at line 107 of file MsqDebug.cpp.
References streams.
Referenced by MBMesquite::MsqDebug::FormatPrinter::print().
    if( flag < streams.size() )
        return *streams[flag];
    else
        return std::cout;
void MBMesquite::MsqDebug::set ( unsigned  flag,
bool  state
) [static]
Set a debug flag.
Definition at line 86 of file MsqDebug.cpp.
References flags.
    if( state )
        if( flag >= flags.size() )
            flags.resize( flag + 1 );
        flags[flag] = true;
    else
        if( flag < flags.size() ) flags[flag] = false;
void MBMesquite::MsqDebug::set_stream ( unsigned  flag,
std::ostream &  stream
) [static]
Definition at line 115 of file MsqDebug.cpp.
References streams.
    if( flag >= streams.size() )
        size_t old_size = streams.size();
        streams.resize( flag );
        for( unsigned i = old_size; i < flag; ++i )
            streams[i] = &std::cout;
    streams[flag] = &stream;
Member Data Documentation
std::vector< bool > MBMesquite::MsqDebug::flags [static, private]
Definition at line 132 of file MsqDebug.hpp.
Referenced by disable_all(), get(), and set().
Definition at line 133 of file MsqDebug.hpp.
std::vector< std::ostream * > MBMesquite::MsqDebug::streams [static, private]
Definition at line 131 of file MsqDebug.hpp.
Referenced by get_stream(), and set_stream().
List of all members.
