MBMesquite::MsqFPE Class Reference
Utility class used by InstructionQueue SIGFPE option. More...
#include <MsqFPE.hpp>
Public Member Functions
 MsqFPE (bool enabled)
 Set FPE state.
 ~MsqFPE ()
 Restore FPE state.
Static Public Member Functions
static bool fpe_trap_supported ()
 Check if FPE state manipulation is supported on this platform.
static int get_current_fpe_state ()
static void set_current_fpe_state (int state)
static void enable_trap_fpe ()
Private Member Functions
void * operator new (size_t)
 dummy declaration preventing heap allocation
 MsqFPE (const MsqFPE &)
 dummy declaration preventing default copy constructor
MsqFPEoperator= (const MsqFPE &)
 dummy declaration preventing default assignment operator
Private Attributes
bool isEnabled
int prevState
Detailed Description
This is a simple utility class for enabling floating point exceptions. It provides two functionalities. The first, implemented in the static methods, is a platform-independent mechanism for modifying the the FPE state. The second, implemented in the constructor/destructor, is a utlity for setting and resetting the FPE state. The FPE state is set when the object is created and reset when the object is destroted. The intention is that an instance of this object be declared on the stack such that when the instantiating function returns, the destructor is automatically invoked, restoring the original state.
Definition at line 50 of file MsqFPE.hpp.
MBMesquite::MsqFPE::MsqFPE ( bool  enabled)
Set FPE state.
If enabled == true, floating point exceptions are enabled by the constructor and reset by the destructor. If enabled == false, nothing is done.
Definition at line 138 of file MsqFPE.cpp.
References enable_trap_fpe(), get_current_fpe_state(), isEnabled, and prevState.
Restore FPE state.
Definition at line 147 of file MsqFPE.cpp.
MBMesquite::MsqFPE::MsqFPE ( const MsqFPE ) [private]
Member Function Documentation
Returns:
Enable trapping of INVALID, DIVBYZERO, and OVERFLOW
Definition at line 134 of file MsqFPE.cpp.
Referenced by MsqFPE().
Definition at line 122 of file MsqFPE.cpp.
    return false;
Returns:
An integer representing the current FPE flags
Definition at line 127 of file MsqFPE.cpp.
    return 0;
void* MBMesquite::MsqFPE::operator new ( size_t  ) [private]
MsqFPE& MBMesquite::MsqFPE::operator= ( const MsqFPE ) [private]
void MBMesquite::MsqFPE::set_current_fpe_state ( int  state) [static]
Returns:
Set the FPE flags on the processor
Definition at line 132 of file MsqFPE.cpp.
Member Data Documentation
Saved constructor argument for use in destructor
Definition at line 82 of file MsqFPE.hpp.
Saved FPE state for use in destructor
Definition at line 84 of file MsqFPE.hpp.
List of all members.
