MBMesquite::MsqPlane Class Reference
Plane. More...
#include <MsqGeomPrim.hpp>
+ Collaboration diagram for MBMesquite::MsqPlane:
Public Member Functions
 MsqPlane (const Vector3D &p_normal, double coeff)
 MsqPlane (const Vector3D &p_normal, const Vector3D &p_point)
 MsqPlane (double a, double b, double c, double d)
 ax+by+cz+d=0
const Vector3Dnormal () const
 get unit normal vector for plane
double coefficient () const
 get coefficient term for plane
Vector3D point () const
 Get point on plane closest to origin.
double distance (const Vector3D &p_point) const
 Get distance from point to plane.
Vector3D closest (const Vector3D &p_point) const
 Get closest location on plane to input position.
bool intersect (const MsqPlane &plane, MsqLine &result) const
bool intersect (const MsqLine &line, double &line_param) const
Private Attributes
Vector3D mNormal
 unit normal
double mCoeff
Detailed Description
Plane.
Definition at line 145 of file MsqGeomPrim.hpp.
MBMesquite::MsqPlane::MsqPlane ( const Vector3D p_normal,
double  coeff
Definition at line 117 of file MsqGeomPrim.cpp.
References MBMesquite::Vector3D::length(), mCoeff, and mNormal.
    const double len = p_normal.length();
    mNormal          = p_normal / len;
    mCoeff           = coeff / len;
const Vector3D p_point
Definition at line 124 of file MsqGeomPrim.cpp.
    : mNormal( p_normal / p_normal.length() ), mCoeff( -( mNormal % p_point ) )
MBMesquite::MsqPlane::MsqPlane ( double  a,
double  b,
double  c,
double  d
ax+by+cz+d=0
Definition at line 129 of file MsqGeomPrim.cpp.
                                                           : mNormal( a, b, c ), mCoeff( d )
    const double len = mNormal.length();
    mNormal /= len;
    mCoeff /= len;
Member Function Documentation
Vector3D MBMesquite::MsqPlane::closest ( const Vector3D p_point) const [inline]
Definition at line 182 of file MsqGeomPrim.hpp.
Referenced by MBMesquite::MsqSphere::intersect(), and GeomPrimTest::test_plane_closest_to_point().
        return p_point - normal() * ( normal() % p_point + coefficient() );
double MBMesquite::MsqPlane::coefficient ( ) const [inline]
Definition at line 164 of file MsqGeomPrim.hpp.
Referenced by intersect(), and GeomPrimTest::test_plane_basic().
        return mCoeff;
double MBMesquite::MsqPlane::distance ( const Vector3D p_point) const [inline]
Definition at line 176 of file MsqGeomPrim.hpp.
Referenced by GeomPrimTest::test_plane_distance(), and GeomPrimTest::test_plane_intersect_plane().
        return fabs( normal() % p_point + coefficient() );
bool MBMesquite::MsqPlane::intersect ( const MsqPlane plane,
MsqLine result
) const
Find intersection of this plane with another.
Returns:
false if parallel or invalid plane, true otherwise
Definition at line 136 of file MsqGeomPrim.cpp.
References coefficient(), MBMesquite::det(), moab::dot(), and normal().
Referenced by GeomPrimTest::test_plane_intersect_line(), and GeomPrimTest::test_plane_intersect_plane().
    const double dot = normal() % plane.normal();
    const double det = dot * dot - 1.0;
    if( fabs( det ) < DBL_EPSILON )  // parallel
        return false;
    const double s1 = ( coefficient() - dot * plane.coefficient() ) / det;
    const double s2 = ( plane.coefficient() - dot * coefficient() ) / det;
    result          = MsqLine( s1 * normal() + s2 * plane.normal(), normal() * plane.normal() );
    return true;
bool MBMesquite::MsqPlane::intersect ( const MsqLine line,
double &  line_param
) const
Find point of itersection with a line
Returns:
false if parallel, true otherwise
Definition at line 149 of file MsqGeomPrim.cpp.
References coefficient(), MBMesquite::MsqLine::direction(), moab::dot(), normal(), and MBMesquite::MsqLine::point().
    const double dot = line.direction() % normal();
    if( fabs( dot ) < DBL_EPSILON ) return false;
    result = -( normal() % line.point() + coefficient() ) / dot;
    return true;
const Vector3D& MBMesquite::MsqPlane::normal ( ) const [inline]
Definition at line 158 of file MsqGeomPrim.hpp.
Referenced by intersect(), MBMesquite::MsqSphere::intersect(), GeomPrimTest::test_plane_basic(), and GeomPrimTest::test_plane_intersect_plane().
        return mNormal;
Definition at line 170 of file MsqGeomPrim.hpp.
Referenced by GeomPrimTest::test_plane_basic().
        return -mCoeff * mNormal;
Member Data Documentation
double MBMesquite::MsqPlane::mCoeff [private]
Definition at line 149 of file MsqGeomPrim.hpp.
Referenced by MsqPlane().
unit normal
Definition at line 148 of file MsqGeomPrim.hpp.
List of all members.
