MBMesquite::QualityImprover Class Reference
Base class for all quality improvers. Mote that the PatchData settings are inherited from the PathDataUser class. More...
#include <QualityImprover.hpp>
+ Inheritance diagram for MBMesquite::QualityImprover:
+ Collaboration diagram for MBMesquite::QualityImprover:
Public Member Functions
virtual ~QualityImprover ()
void set_inner_termination_criterion (TerminationCriterion *crit)
void set_outer_termination_criterion (TerminationCriterion *crit)
virtual PatchSetget_patch_set ()=0
virtual void initialize_queue (MeshDomainAssoc *mesh_and_domain, const Settings *settings, MsqError &err)
Protected Member Functions
 QualityImprover ()
TerminationCriterionget_outer_termination_criterion ()
 return the outer termination criterion pointer
TerminationCriterionget_inner_termination_criterion ()
 return the inner termination criterion pointer
Private Attributes
TerminationCriterioninnerTerminationCriterion
TerminationCriterionouterTerminationCriterion
TerminationCriteriondefaultOuterCriterion
TerminationCriteriondefaultInnerCriterion
Detailed Description
Definition at line 59 of file QualityImprover.hpp.
The default constructor initialises a few member variables to default values. This can be reused by concrete class constructor.
Definition at line 60 of file QualityImprover.cpp.
References MBMesquite::TerminationCriterion::add_iteration_limit(), defaultInnerCriterion, defaultOuterCriterion, innerTerminationCriterion, and outerTerminationCriterion.
Member Function Documentation
Definition at line 91 of file QualityImprover.hpp.
Referenced by MBMesquite::VertexMover::loop_over_mesh().
void MBMesquite::QualityImprover::initialize_queue ( MeshDomainAssoc mesh_and_domain,
const Settings settings,
MsqError err
) [virtual]
Called for all instructions in queue before loop_over_mesh is called for any insetruction in queue. Default behavior is to do nothing.
Implements MBMesquite::Instruction.
Reimplemented in MBMesquite::VertexMover.
Definition at line 75 of file QualityImprover.cpp.
References MBMesquite::TerminationCriterion::initialize_queue(), innerTerminationCriterion, MSQ_ERRRTN, and outerTerminationCriterion.
    innerTerminationCriterion->initialize_queue( mesh_and_domain, settings, err );MSQ_ERRRTN( err );
    outerTerminationCriterion->initialize_queue( mesh_and_domain, settings, err );MSQ_ERRRTN( err );
Member Data Documentation
List of all members.
