MBMesquite::RefSizeTargetCalculator Class Reference
#include <RefSizeTargetCalculator.hpp>
+ Inheritance diagram for MBMesquite::RefSizeTargetCalculator:
+ Collaboration diagram for MBMesquite::RefSizeTargetCalculator:
Public Member Functions
 RefSizeTargetCalculator (ReferenceMesh *reference_mesh, TargetCalculator *tc)
 RefSizeTargetCalculator (ReferenceMesh *reference_mesh)
virtual bool get_3D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 3 > &W_out, MsqError &err)
 Get a target matrix.
virtual bool get_2D_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 2, 2 > &W_out, MsqError &err)
virtual bool get_surface_target (PatchData &pd, size_t element, Sample sample, MsqMatrix< 3, 2 > &W_out, MsqError &err)
virtual bool have_surface_orient () const
 Use 3x2 W for surface elements if true, 2x2 W if false.
Private Member Functions
double average_edge_length (PatchData &pd, size_t element, MsqError &err)
Private Attributes
ReferenceMeshrefMesh
IdealShapeTarget defaultTargets
TargetCalculatorscaledTargets
Detailed Description
Definition at line 43 of file RefSizeTargetCalculator.hpp.
Definition at line 56 of file RefSizeTargetCalculator.cpp.
    : refMesh( reference_mesh ), scaledTargets( tc )
}  //   { init_scale_factors( scaleFactor ); }
Definition at line 61 of file RefSizeTargetCalculator.cpp.
    : refMesh( reference_mesh ), scaledTargets( &defaultTargets )
Member Function Documentation
double MBMesquite::RefSizeTargetCalculator::average_edge_length ( PatchData pd,
size_t  element,
MsqError err
) [private]
Definition at line 66 of file RefSizeTargetCalculator.cpp.
References conn, MBMesquite::edges, MBMesquite::PatchData::element_by_index(), MBMesquite::MsqMeshEntity::get_element_type(), MBMesquite::ReferenceMesh::get_reference_vertex_coordinates(), MBMesquite::PatchData::get_vertex_handles_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::length(), MSQ_ERRZERO, MSQ_SETERR, refMesh, MBMesquite::MsqError::UNSUPPORTED_ELEMENT, and MBMesquite::MsqMeshEntity::vertex_count().
Referenced by get_2D_target(), get_3D_target(), and get_surface_target().
    Vector3D coords[8];
    MsqMeshEntity& elem = pd.element_by_index( element );
    const size_t* conn  = elem.get_vertex_index_array();
    size_t nvtx         = elem.vertex_count();
    if( nvtx > ( sizeof( coords ) / sizeof( coords[0] ) ) )
        MSQ_SETERR( err )( "Invalid element type", MsqError::UNSUPPORTED_ELEMENT );
        return false;
    Mesh::VertexHandle handles[8];
    for( unsigned i = 0; i < nvtx; ++i )
        handles[i] = pd.get_vertex_handles_array()[conn[i]];
    refMesh->get_reference_vertex_coordinates( handles, nvtx, coords, err );
    MSQ_ERRZERO( err );
    EntityTopology type = elem.get_element_type();
    unsigned num_edges  = TopologyInfo::edges( type );
    double len_sum      = 0.0;
    for( unsigned i = 0; i < num_edges; ++i )
        const unsigned* edge = TopologyInfo::edge_vertices( type, i );
        len_sum += ( coords[edge[0]] - coords[edge[1]] ).length();
    return len_sum * ( 1.0 / num_edges );  // scaleFactor[type];
bool MBMesquite::RefSizeTargetCalculator::get_2D_target ( PatchData pd,
size_t  element,
Sample  sample,
MsqMatrix< 2, 2 > &  W_out,
MsqError err
) [virtual]
Parameters:
pdThe current PatchData
elementThe index an element within the patch data.
sampleThe sample point in the element.
W_outThe resulting target matrix.
Implements MBMesquite::TargetCalculator.
Definition at line 128 of file RefSizeTargetCalculator.cpp.
References average_edge_length(), MBMesquite::TargetCalculator::get_2D_target(), MSQ_ERRZERO, and scaledTargets.
    scaledTargets->get_2D_target( pd, element, sample, W, err );
    MSQ_ERRZERO( err );
    double f = average_edge_length( pd, element, err );
    MSQ_ERRZERO( err );
    W *= f;
    return true;
bool MBMesquite::RefSizeTargetCalculator::get_3D_target ( PatchData pd,
size_t  element,
Sample  sample,
MsqMatrix< 3, 3 > &  W_out,
MsqError err
) [virtual]
Parameters:
Definition at line 96 of file RefSizeTargetCalculator.cpp.
References average_edge_length(), MBMesquite::TargetCalculator::get_3D_target(), MSQ_ERRZERO, and scaledTargets.
    scaledTargets->get_3D_target( pd, element, sample, W, err );
    MSQ_ERRZERO( err );
    MSQ_ERRZERO( err );
    W *= f;
    return true;
bool MBMesquite::RefSizeTargetCalculator::get_surface_target ( PatchData pd,
size_t  element,
Sample  sample,
MsqMatrix< 3, 2 > &  W_out,
MsqError err
) [virtual]
Parameters:
Definition at line 112 of file RefSizeTargetCalculator.cpp.
References average_edge_length(), MBMesquite::TargetCalculator::get_surface_target(), MSQ_ERRZERO, and scaledTargets.
    scaledTargets->get_surface_target( pd, element, sample, W, err );
    MSQ_ERRZERO( err );
    MSQ_ERRZERO( err );
    W *= f;
    return true;
virtual bool MBMesquite::RefSizeTargetCalculator::have_surface_orient ( ) const [inline, virtual]
If true, then the targets for surface elements attempt some control of orientation and therefore get_surface_target must be used to get the targets. If false, then the target contains no orientation data and is therefore the same as the corresponding 2D target for surface elements. In this case, get_2D_target should be used.
Definition at line 59 of file RefSizeTargetCalculator.hpp.
References MBMesquite::TargetCalculator::have_surface_orient(), and scaledTargets.
Member Data Documentation
List of all members.
