MBMesquite::ShapeImprover Class Reference
Wrapper that implements TMP-based shape improvement. More...
#include <ShapeImprover.hpp>
+ Inheritance diagram for MBMesquite::ShapeImprover:
+ Collaboration diagram for MBMesquite::ShapeImprover:
Public Member Functions
MESQUITE_EXPORT ShapeImprover ()
MESQUITE_EXPORT void set_cpu_time_limit (double seconds)
MESQUITE_EXPORT void set_vertex_movement_limit_factor (double beta)
MESQUITE_EXPORT void set_parallel_iterations (int count)
Protected Member Functions
MESQUITE_EXPORT void run_wrapper (MeshDomainAssoc *mesh_and_domain, ParallelMesh *pmesh, Settings *settings, QualityAssessor *qa, MsqError &err)
Private Attributes
double maxTime
double mBeta
int parallelIterations
Detailed Description
Definition at line 43 of file ShapeImprover.hpp.
Member Function Documentation
void MBMesquite::ShapeImprover::run_wrapper ( MeshDomainAssoc mesh_and_domain,
ParallelMesh pmesh,
Settings settings,
QualityAssessor quality_assessor,
MsqError err
) [protected, virtual]
Function that each wrapper must implement
Implements MBMesquite::Wrapper.
Definition at line 84 of file ShapeImprover.cpp.
References MBMesquite::TerminationCriterion::add_absolute_vertex_movement_edge_length(), MBMesquite::TerminationCriterion::add_cpu_time(), MBMesquite::QualityAssessor::add_quality_assessment(), MBMesquite::InstructionQueue::add_quality_assessor(), MBMesquite::PatchData::attach_settings(), MBMesquite::Mesh::get_all_elements(), MBMesquite::Mesh::get_all_vertices(), MBMesquite::MeshDomainAssoc::get_domain(), MBMesquite::QualityAssessor::get_inverted_element_count(), MBMesquite::MeshDomainAssoc::get_mesh(), MBMesquite::PatchData::get_minmax_edge_length(), maxTime, mBeta, mesh, MSQ_ERRRTN, MBMesquite::InstructionQueue::run_common(), MBMesquite::PatchData::set_domain(), MBMesquite::QualityImprover::set_inner_termination_criterion(), MBMesquite::InstructionQueue::set_master_quality_improver(), MBMesquite::PatchData::set_mesh(), MBMesquite::PatchData::set_mesh_entities(), and MBMesquite::PatchSetUser::use_global_patch().
    // Quality Metrics
    IdealShapeTarget target;
    Mesh* mesh         = mesh_and_domain->get_mesh();
    MeshDomain* domain = mesh_and_domain->get_domain();
    // only calc min edge length if user hasn't set the vertex_movement_limit_factor
    if( !mBeta )
        // Calculate minimum edge length in mesh
        // create a temp global patch to get min edge len from
        PatchData patch;
        patch.set_mesh( mesh );
        patch.set_domain( domain );
        if( settings ) patch.attach_settings( settings );
        std::vector< Mesh::ElementHandle > patch_elems;
        std::vector< Mesh::VertexHandle > patch_verts;
        mesh->get_all_elements( patch_elems, err );
        mesh->get_all_vertices( patch_verts, err );
        patch.set_mesh_entities( patch_elems, patch_verts, err );
        // get min edge length from temp global patch
        double min_edge_len = 0.0, max_edge_len = 0.0;
        patch.get_minmax_edge_length( min_edge_len, max_edge_len );
        mBeta = min_edge_len / 10.0;
    TerminationCriterion inner_b;
    // check for inverted elements
    // create QualityAssessor instance without a Quality Metric
    QualityAssessor check_inverted( false, false );
    InstructionQueue q_invert_check;
    // a QuallityAssessor without a metric will just check for inverted elements and samples
    q_invert_check.add_quality_assessor( &check_inverted, err );
    q_invert_check.run_common( mesh_and_domain, pmesh, settings, err );MSQ_ERRRTN( err );
    int inverted_elems = 0, inverted_samples = 0;
    check_inverted.get_inverted_element_count( inverted_elems, inverted_samples, err );
    if( inverted_elems || inverted_samples )
        // use non barrier shape improvement on tangled mesh
        TShapeNB1 mu_no;
        TQualityMetric metric_no_0( &target, &mu_no );
        ElementPMeanP metric_no( 1.0, &metric_no_0 );
        // QualityAssessor
        qa->add_quality_assessment( &metric_no );
        PMeanPTemplate obj_func_no( 1.0, &metric_no );
        ConjugateGradient improver_no( &obj_func_no );
        improver_no.use_global_patch();
        TerminationCriterion inner_no;
        if( maxTime > 0.0 ) inner_no.add_cpu_time( maxTime );
        inner_no.add_absolute_vertex_movement_edge_length( mBeta );
        improver_no.set_inner_termination_criterion( &inner_no );
        InstructionQueue q_no;
        q_no.add_quality_assessor( qa, err );MSQ_ERRRTN( err );
        q_no.set_master_quality_improver( &improver_no, err );MSQ_ERRRTN( err );
        q_no.run_common( mesh_and_domain, pmesh, settings, err );MSQ_ERRRTN( err );
    else
        // use barrer metric on non-tangled mesh
        Timer totalTimer;
        TShapeB1 mu_b;
        TQualityMetric metric_b_0( &target, &mu_b );
        ElementPMeanP metric_b( 1.0, &metric_b_0 );
        qa->add_quality_assessment( &metric_b );
        PMeanPTemplate obj_func_b( 1.0, &metric_b );
        ConjugateGradient improver_b( &obj_func_b );
        improver_b.use_global_patch();
        if( maxTime > 0.0 ) inner_b.add_cpu_time( maxTime );
        inner_b.add_absolute_vertex_movement_edge_length( mBeta );
        improver_b.set_inner_termination_criterion( &inner_b );
        InstructionQueue q_b;
        q_b.add_quality_assessor( qa, err );MSQ_ERRRTN( err );
        q_b.set_master_quality_improver( &improver_b, err );MSQ_ERRRTN( err );
        q_b.run_common( mesh_and_domain, pmesh, settings, err );MSQ_ERRRTN( err );
Definition at line 68 of file ShapeImprover.cpp.
References maxTime.
Referenced by main().
    assert( limit >= 0.0 );
    maxTime = limit;
Definition at line 74 of file ShapeImprover.cpp.
References parallelIterations.
    if( count < 1 )
        assert( false );
        count = 1;
    parallelIterations = count;
Definition at line 61 of file ShapeImprover.cpp.
References beta, and mBeta.
Referenced by main(), and run_example().
    assert( beta > 0.0 );
    assert( beta < 1.0 );
    mBeta = beta;
Member Data Documentation
Definition at line 83 of file ShapeImprover.hpp.
Referenced by run_wrapper(), and set_cpu_time_limit().
Referenced by run_wrapper(), and set_vertex_movement_limit_factor().
Definition at line 84 of file ShapeImprover.hpp.
Referenced by set_parallel_iterations().
List of all members.
