MBMesquite::SimpleStats Class Reference
Accumulate various statistics for a list of discrete values. More...
#include <SimpleStats.hpp>
Public Member Functions
 SimpleStats ()
double minimum () const
 minimum value
double maximum () const
 maximum value
double average () const
 algebraic mean of values
double rms () const
 root mean squared of values
double variance () const
 variance of values
double standard_deviation () const
 standard deviation of values
void add_value (double value)
 incorporate another value into statistics
void add_squared (double value_squared)
void clear ()
bool empty ()
Private Attributes
double valueSum
double valueSqrSum
double valueMin
double valueMax
unsigned long valueCount
Detailed Description
Definition at line 41 of file SimpleStats.hpp.
Definition at line 38 of file SimpleStats.cpp.
    : valueSum( 0 ), valueSqrSum( 0 ), valueMin( std::numeric_limits< double >::infinity() ),
      valueMax( -std::numeric_limits< double >::infinity() ), valueCount( 0 )
Member Function Documentation
void MBMesquite::SimpleStats::add_squared ( double  value_squared) [inline]
Definition at line 92 of file SimpleStats.hpp.
References value(), valueCount, valueMax, valueMin, valueSqrSum, and valueSum.
Referenced by MBMesquite::MeshUtil::edge_length_distribution().
        double value = sqrt( value_squared );
        valueSum += value;
        valueSqrSum += value_squared;
        if( value < valueMin ) valueMin = value;
        if( value > valueMax ) valueMax = value;
        ++valueCount;
void MBMesquite::SimpleStats::add_value ( double  value) [inline]
Definition at line 82 of file SimpleStats.hpp.
Referenced by MBMesquite::CompareQM::GradStat::add(), MBMesquite::CompareQM::check_value(), and MBMesquite::MeshUtil::lambda_distribution().
        valueSum += value;
        valueSqrSum += value * value;
        ++valueCount;
Definition at line 44 of file SimpleStats.cpp.
References valueCount, valueMax, valueMin, valueSqrSum, and valueSum.
Referenced by MeshUtilTest::test_lambda_distribution().
    valueSum = valueSqrSum = 0;
    valueMin               = std::numeric_limits< double >::infinity();
    valueMax               = -valueMin;
    valueCount             = 0;
double MBMesquite::SimpleStats::variance ( ) const [inline]
variance of values
Definition at line 71 of file SimpleStats.hpp.
References average(), valueCount, and valueSqrSum.
Referenced by standard_deviation(), and MeshUtilTest::test_lambda_distribution().
        return valueSqrSum / valueCount - average() * average();
Member Data Documentation
unsigned long MBMesquite::SimpleStats::valueCount [private]
Definition at line 45 of file SimpleStats.hpp.
Referenced by add_squared(), add_value(), average(), clear(), empty(), rms(), and variance().
Definition at line 44 of file SimpleStats.hpp.
Referenced by add_squared(), add_value(), clear(), and maximum().
Referenced by add_squared(), add_value(), clear(), and minimum().
Referenced by add_squared(), add_value(), clear(), rms(), and variance().
Referenced by add_squared(), add_value(), average(), and clear().
List of all members.
