MBMesquite::SteepestDescent Class Reference
#include <SteepestDescent.hpp>
+ Inheritance diagram for MBMesquite::SteepestDescent:
+ Collaboration diagram for MBMesquite::SteepestDescent:
Public Member Functions
MESQUITE_EXPORT SteepestDescent (ObjectiveFunction *of)
virtual MESQUITE_EXPORT ~SteepestDescent ()
virtual MESQUITE_EXPORT std::string get_name () const
 Get string name for use in diagnostic and status output.
virtual MESQUITE_EXPORT PatchSetget_patch_set ()
MESQUITE_EXPORT bool project_gradient () const
MESQUITE_EXPORT void project_gradient (bool yesno)
Protected Member Functions
virtual MESQUITE_EXPORT void initialize (PatchData &pd, MsqError &err)
virtual MESQUITE_EXPORT void optimize_vertex_positions (PatchData &pd, MsqError &err)
virtual MESQUITE_EXPORT void initialize_mesh_iteration (PatchData &pd, MsqError &err)
virtual MESQUITE_EXPORT void terminate_mesh_iteration (PatchData &pd, MsqError &err)
virtual MESQUITE_EXPORT void cleanup ()
Private Member Functions
 SteepestDescent (const SteepestDescent &pd)
SteepestDescentoperator= (const SteepestDescent &pd)
Private Attributes
bool projectGradient
Detailed Description
This is a very basic implementation of the steepest descent optimization algorythm.
Definition at line 54 of file SteepestDescent.hpp.
Definition at line 57 of file SteepestDescent.cpp.
    : VertexMover( of ), PatchSetUser( true ), projectGradient( false )  //,
// cosineStep(false)
Definition at line 60 of file SteepestDescent.hpp.
Member Function Documentation
void MBMesquite::SteepestDescent::cleanup ( ) [protected, virtual]
Implements MBMesquite::VertexMover.
Definition at line 219 of file SteepestDescent.cpp.
    //  cout << "- Executing SteepestDescent::iteration_end()\n";
std::string MBMesquite::SteepestDescent::get_name ( ) const [virtual]
Implements MBMesquite::Instruction.
Definition at line 47 of file SteepestDescent.cpp.
    return "SteepestDescent";
Reimplemented from MBMesquite::PatchSetUser.
Definition at line 52 of file SteepestDescent.cpp.
void MBMesquite::SteepestDescent::initialize ( PatchData pd,
MsqError err
Definition at line 63 of file SteepestDescent.cpp.
void MBMesquite::SteepestDescent::initialize_mesh_iteration ( PatchData pd,
MsqError err
Definition at line 65 of file SteepestDescent.cpp.
SteepestDescent& MBMesquite::SteepestDescent::operator= ( const SteepestDescent pd) [private]
void MBMesquite::SteepestDescent::optimize_vertex_positions ( PatchData pd,
MsqError err
Definition at line 67 of file SteepestDescent.cpp.
References MBMesquite::TerminationCriterion::accumulate_inner(), MBMesquite::TerminationCriterion::accumulate_patch(), MBMesquite::arrptr(), MBMesquite::MsqError::BARRIER_VIOLATED, MBMesquite::MsqError::clear(), MBMesquite::PatchData::create_vertices_memento(), MBMesquite::MsqError::error_code(), MBMesquite::OFEvaluator::evaluate(), MBMesquite::QualityImprover::get_inner_termination_criterion(), MBMesquite::TerminationCriterion::get_iteration_count(), MBMesquite::PatchData::get_minmax_edge_length(), MBMesquite::VertexMover::get_objective_function_evaluator(), MBMesquite::gradient(), MBMesquite::MsqError::INVALID_ARG, MBMesquite::length_squared(), MBMesquite::PatchData::move_free_vertices_constrained(), MSQ_DBGOUT, MSQ_ERRRTN, MSQ_FUNCTION_TIMER, MSQ_SETERR, norm_squared(), MBMesquite::PatchData::num_free_vertices(), MBMesquite::PatchData::project_gradient(), projectGradient, MBMesquite::PatchData::recreate_vertices_memento(), MBMesquite::PatchData::set_to_vertices_memento(), MBMesquite::TerminationCriterion::terminate(), and MBMesquite::OFEvaluator::update().
    MSQ_FUNCTION_TIMER( "SteepestDescent::optimize_vertex_positions" );
    const int SEARCH_MAX = 100;
    const double c1      = 1e-4;
    // std::vector<Vector3D> unprojected(pd.num_free_vertices());
    std::vector< Vector3D > gradient( pd.num_free_vertices() );
    bool feasible = true;  // bool for OF values
    double min_edge_len, max_edge_len;
    double step_size = 0, original_value = 0, new_value = 0;
    double norm_squared = 0;
    PatchDataVerticesMemento* pd_previous_coords;
    TerminationCriterion* term_crit = get_inner_termination_criterion();
    OFEvaluator& obj_func           = get_objective_function_evaluator();
    // get vertex memento so we can restore vertex coordinates for bad steps.
    pd_previous_coords = pd.create_vertices_memento( err );MSQ_ERRRTN( err );
    // use unique_ptr to automatically delete memento when we exit this function
    std::unique_ptr< PatchDataVerticesMemento > memento_deleter( pd_previous_coords );
    // Evaluate objective function.
    // Always use 'update' version when beginning optimization so that
    // if doing block coordinate descent the OF code knows the set of
    // vertices we are modifying during the optimziation (the subset
    // of the mesh contained in the current patch.)  This has to be
    // done up-front because typically an OF will just store the portion
    // of the OF value (e.g. the numeric contribution to the sum for an
    // averaging OF) for the initial patch.
    feasible = obj_func.update( pd, original_value, gradient, err );MSQ_ERRRTN( err );
    // calculate gradient dotted with itself
    norm_squared = length_squared( gradient );
    // set an error if initial patch is invalid.
    if( !feasible )
        MSQ_SETERR( err )( "SteepestDescent passed invalid initial patch.", MsqError::INVALID_ARG );
        return;
    // use edge length as an initial guess for for step size
    pd.get_minmax_edge_length( min_edge_len, max_edge_len );
    // step_size = max_edge_len / std::sqrt(norm_squared);
    // if (!finite(step_size))  // zero-length gradient
    //  return;
    //  if (norm_squared < DBL_EPSILON)
    //    return;
    if( norm_squared >= DBL_EPSILON ) step_size = max_edge_len / std::sqrt( norm_squared ) * pd.num_free_vertices();
    // The steepest descent loop...
    // We loop until the user-specified termination criteria are met.
    while( !term_crit->terminate() )
        MSQ_DBGOUT( 3 ) << "Iteration " << term_crit->get_iteration_count() << std::endl;
        MSQ_DBGOUT( 3 ) << "  o  original_value: " << original_value << std::endl;
        MSQ_DBGOUT( 3 ) << "  o  grad norm suqared: " << norm_squared << std::endl;
        // Save current vertex coords so that they can be restored if
        // the step was bad.
        pd.recreate_vertices_memento( pd_previous_coords, err );MSQ_ERRRTN( err );
        // Reduce step size until it satisfies Armijo condition
        int counter = 0;
        for( ;; )
            if( ++counter > SEARCH_MAX || step_size < DBL_EPSILON )
                MSQ_DBGOUT( 3 ) << "    o  No valid step found.  Giving Up." << std::endl;
                return;
            // Move vertices to new positions.
            // Note: step direction is -gradient so we pass +gradient and
            //       -step_size to achieve the same thing.
            pd.move_free_vertices_constrained( arrptr( gradient ), gradient.size(), -step_size, err );MSQ_ERRRTN( err );
            // Evaluate objective function for new vertices.  We call the
            // 'evaluate' form here because we aren't sure yet if we want to
            // keep these vertices.  Until we call 'update', we have the option
            // of reverting a block coordinate decent objective function's state
            // to that of the initial vertex coordinates.  However, for block
            // coordinate decent to work correctly, we will need to call an
            // 'update' form if we decide to keep the new vertex coordinates.
            feasible = obj_func.evaluate( pd, new_value, err );
            if( err.error_code() == err.BARRIER_VIOLATED )
                err.clear();  // barrier violated does not represent an actual error here
            MSQ_ERRRTN( err );
            MSQ_DBGOUT( 3 ) << "    o  step_size: " << step_size << std::endl;
            MSQ_DBGOUT( 3 ) << "    o  new_value: " << new_value << std::endl;
            if( !feasible )
                // OF value is invalid, decrease step_size a lot
                step_size *= 0.2;
            else if( new_value > original_value - c1 * step_size * norm_squared )
                // Armijo condition not met.
                step_size *= 0.5;
            else
                // Armijo condition met, stop
                break;
            // undo previous step : restore vertex coordinates
            pd.set_to_vertices_memento( pd_previous_coords, err );MSQ_ERRRTN( err );
        // Re-evaluate objective function to get gradient.
        // Calling the 'update' form here incorporates the new vertex
        // positions into the 'accumulated' value if we are doing a
        // block coordinate descent optimization.
        if( projectGradient )
            // if (cosineStep) {
            //  unprojected = gradient;
            //  pd.project_gradient( gradient, err ); MSQ_ERRRTN(err);
            //  double dot = inner_product( arrptr(gradient), arrptr(unprojected), gradient.size()
            //  ); double lensqr1 = length_squared( gradient ); double lensqr2 = length_squared(
            //  unprojected ); double cossqr = dot * dot / lensqr1 / lensqr2; step_size *=
            //  sqrt(cossqr);
            // else {
            pd.project_gradient( gradient, err );MSQ_ERRRTN( err );
        // Update terination criterion for next iteration.
        // This is necessary for efficiency.  Some values can be adjusted
        // for each iteration so we don't need to re-caculate the value
        // over the entire mesh.
        term_crit->accumulate_patch( pd, err );MSQ_ERRRTN( err );
        term_crit->accumulate_inner( pd, original_value, arrptr( gradient ), err );MSQ_ERRRTN( err );
        // Calculate initial step size for next iteration using step size
        // from this iteration
        step_size *= norm_squared;
        //      break;
        if( norm_squared >= DBL_EPSILON ) step_size /= norm_squared;
Definition at line 67 of file SteepestDescent.hpp.
References projectGradient.
        return projectGradient;
Definition at line 73 of file SteepestDescent.hpp.
        projectGradient = yesno;
void MBMesquite::SteepestDescent::terminate_mesh_iteration ( PatchData pd,
MsqError err
Definition at line 214 of file SteepestDescent.cpp.
    //  cout << "- Executing SteepestDescent::iteration_complete()\n";
Member Data Documentation
List of all members.
