MBMesquite::TrustRegion Class Reference
#include <TrustRegion.hpp>
+ Inheritance diagram for MBMesquite::TrustRegion:
+ Collaboration diagram for MBMesquite::TrustRegion:
Public Member Functions
MESQUITE_EXPORT TrustRegion (ObjectiveFunction *of)
virtual MESQUITE_EXPORT ~TrustRegion ()
PatchSetget_patch_set ()
MESQUITE_EXPORT std::string get_name () const
 Get string name for use in diagnostic and status output.
Protected Member Functions
virtual void initialize (PatchData &pd, MsqError &err)
virtual void optimize_vertex_positions (PatchData &pd, MsqError &err)
virtual void initialize_mesh_iteration (PatchData &pd, MsqError &err)
virtual void terminate_mesh_iteration (PatchData &pd, MsqError &err)
virtual void cleanup ()
Private Member Functions
void compute_preconditioner (MsqError &err)
void apply_preconditioner (Vector3D *z, Vector3D *r, MsqError &err)
Private Attributes
PatchDataVerticesMementomMemento
MsqHessian mHess
std::vector< Vector3DmGrad
std::vector< Vector3DwVect
std::vector< Vector3DzVect
std::vector< Vector3DdVect
std::vector< Vector3DpVect
std::vector< Vector3DrVect
std::vector< double > preCond
Detailed Description
Definition at line 45 of file TrustRegion.hpp.
Definition at line 64 of file TrustRegion.cpp.
: VertexMover( of ), PatchSetUser( true ), mMemento( 0 ) {}
Definition at line 66 of file TrustRegion.cpp.
References mMemento.
    delete mMemento;
    mMemento = 0;
Member Function Documentation
void MBMesquite::TrustRegion::apply_preconditioner ( Vector3D z,
Vector3D r,
MsqError err
) [private]
Definition at line 142 of file TrustRegion.cpp.
References preCond.
Referenced by optimize_vertex_positions().
#ifndef USE_FN_PC1
    mHessian.apply_preconditioner( z, r, err );
#else
    for( size_t i = 0; i < preCond.size(); ++i )
        z[i] = preCond[i] * r[i];
#endif
void MBMesquite::TrustRegion::cleanup ( ) [protected, virtual]
Implements MBMesquite::VertexMover.
Definition at line 81 of file TrustRegion.cpp.
References MBMesquite::MsqHessian::clear(), dVect, MBMesquite::free_vector(), mGrad, mHess, mMemento, preCond, pVect, rVect, wVect, and zVect.
    // release Memento
    delete mMemento;
    mMemento = 0;
    // release temporary array memory
    mHess.clear();
    free_vector( mGrad );
    free_vector( wVect );
    free_vector( zVect );
    free_vector( dVect );
    free_vector( pVect );
    free_vector( rVect );
    free_vector( preCond );
Definition at line 122 of file TrustRegion.cpp.
References MBMesquite::MsqHessian::get_block(), mHess, preCond, and MBMesquite::MsqHessian::size().
#ifndef USE_FN_PC1
    mHessian.calculate_preconditioner( err );
#else
    double dia;
    preCond.resize( mHess.size() );
    for( size_t i = 0; i < mHess.size(); ++i )
        const Matrix3D& m = *mHess.get_block( i, i );
        dia               = m[0][0] + m[1][1] + m[2][2];
        preCond[i]        = dia < DBL_EPSILON ? 1.0 : 1.0 / dia;
#endif
std::string MBMesquite::TrustRegion::get_name ( ) const [virtual]
Implements MBMesquite::Instruction.
Definition at line 54 of file TrustRegion.cpp.
    return "TrustRegion";
Reimplemented from MBMesquite::PatchSetUser.
Definition at line 59 of file TrustRegion.cpp.
void MBMesquite::TrustRegion::initialize ( PatchData pd,
MsqError err
Definition at line 72 of file TrustRegion.cpp.
References MBMesquite::PatchData::create_vertices_memento(), mMemento, and MSQ_CHKERR.
    mMemento = pd.create_vertices_memento( err );MSQ_CHKERR( err );
void MBMesquite::TrustRegion::initialize_mesh_iteration ( PatchData pd,
MsqError err
Definition at line 77 of file TrustRegion.cpp.
void MBMesquite::TrustRegion::optimize_vertex_positions ( PatchData pd,
MsqError err
Definition at line 158 of file TrustRegion.cpp.
References MBMesquite::TerminationCriterion::accumulate_inner(), MBMesquite::TerminationCriterion::accumulate_patch(), apply_preconditioner(), MBMesquite::arrptr(), MBMesquite::MsqError::BARRIER_VIOLATED, beta, MBMesquite::MsqError::clear(), compute_preconditioner(), dVect, MBMesquite::MsqError::error_code(), MBMesquite::OFEvaluator::evaluate(), MBMesquite::QualityImprover::get_inner_termination_criterion(), MBMesquite::VertexMover::get_objective_function_evaluator(), MBMesquite::MsqHessian::initialize(), MBMesquite::inner(), MBMesquite::MsqError::INVALID_MESH, MBMesquite::length(), MBMesquite::length_squared(), mGrad, mHess, mMemento, MBMesquite::PatchData::move_free_vertices_constrained(), MSQ_ERRRTN, MSQ_SETERR, MBMesquite::negate(), MBMesquite::PatchData::num_free_vertices(), MBMesquite::plus_eq_scaled(), MBMesquite::MsqHessian::product(), pVect, radius, MBMesquite::PatchData::recreate_vertices_memento(), rVect, MBMesquite::PatchData::set_to_vertices_memento(), MBMesquite::TerminationCriterion::terminate(), MBMesquite::times_eq_minus(), MBMesquite::OFEvaluator::update(), wVect, z, and zVect.
    TerminationCriterion& term = *get_inner_termination_criterion();
    OFEvaluator& func          = get_objective_function_evaluator();
    const double cg_tol        = 1e-2;
    const double eta_1         = 0.01;
    const double eta_2         = 0.90;
    const double tr_incr       = 10;
    const double tr_decr_def   = 0.25;
    const double tr_decr_undef = 0.25;
    const double tr_num_tol    = 1e-6;
    const int max_cg_iter      = 10000;
    double radius = 1000; /* delta*delta */
    const int nn = pd.num_free_vertices();
    wVect.resize( nn );
    Vector3D* w = arrptr( wVect );
    zVect.resize( nn );
    Vector3D* z = arrptr( zVect );
    dVect.resize( nn );
    Vector3D* d = arrptr( dVect );
    pVect.resize( nn );
    Vector3D* p = arrptr( pVect );
    rVect.resize( nn );
    Vector3D* r = arrptr( rVect );
    double norm_r, norm_g;
    double alpha, beta, kappa;
    double rz, rzm1;
    double dMp, norm_d, norm_dp1, norm_p;
    double obj, objn;
    int cg_iter;
    bool valid;
    mHess.initialize( pd, err );  // hMesh(mesh);
    valid = func.update( pd, obj, mGrad, mHess, err );MSQ_ERRRTN( err );
    if( !valid )
        MSQ_SETERR( err )( "Initial objective function is not valid", MsqError::INVALID_MESH );
        return;
    compute_preconditioner( err );MSQ_ERRRTN( err );
    pd.recreate_vertices_memento( mMemento, err );MSQ_ERRRTN( err );
    while( !term.terminate() && ( radius > 1e-20 ) )
        norm_r = length_squared( arrptr( mGrad ), nn );
        norm_g = sqrt( norm_r );
        memset( d, 0, 3 * sizeof( double ) * nn );
        memcpy( r, arrptr( mGrad ),
                nn * sizeof( Vector3D ) );  // memcpy(r, mesh->g, 3*sizeof(double)*nn);
        norm_g *= cg_tol;
        apply_preconditioner( z, r, err );MSQ_ERRRTN( err );  // prec->apply(z, r, prec, mesh);
        negate( p, z, nn );
        rz = inner( r, z, nn );
        dMp    = 0;
        norm_p = rz;
        norm_d = 0;
        cg_iter = 0;
        while( ( sqrt( norm_r ) > norm_g ) &&
#ifdef DO_STEEP_DESC
               ( norm_d > tr_num_tol ) &&
#endif
               ( cg_iter < max_cg_iter ) )
            ++cg_iter;
            memset( w, 0, 3 * sizeof( double ) * nn );
            // matmul(w, mHess, p); //matmul(w, mesh, p);
            mHess.product( w, p );
            kappa = inner( p, w, nn );
            if( kappa <= 0.0 )
                alpha = ( sqrt( dMp * dMp + norm_p * ( radius - norm_d ) ) - dMp ) / norm_p;
                plus_eq_scaled( d, alpha, p, nn );
                break;
            alpha = rz / kappa;
            norm_dp1 = norm_d + 2.0 * alpha * dMp + alpha * alpha * norm_p;
            if( norm_dp1 >= radius )
                break;
            plus_eq_scaled( r, alpha, w, nn );
            norm_r = length_squared( r, nn );
            rzm1 = rz;
            beta = rz / rzm1;
            times_eq_minus( p, beta, z, nn );
            dMp    = beta * ( dMp + alpha * norm_p );
            norm_p = rz + beta * beta * norm_p;
            norm_d = norm_dp1;
        if( norm_d <= tr_num_tol )
            norm_g    = length( arrptr( mGrad ), nn );
            double ll = 1.0;
            if( norm_g < tr_num_tol ) break;
            if( norm_g > radius ) ll = radius / nurm_g;
            for( int i = 0; i < nn; ++i )
                d[i] = ll * mGrad[i];
#endif
        alpha = inner( arrptr( mGrad ), d, nn );  // inner(mesh->g, d, nn);
        memset( p, 0, 3 * sizeof( double ) * nn );
        // matmul(p, mHess, d); //matmul(p, mesh, d);
        mHess.product( p, d );
        beta  = 0.5 * inner( p, d, nn );
        kappa = alpha + beta;
        /* Put the new point into the locations */
        pd.move_free_vertices_constrained( d, nn, 1.0, err );MSQ_ERRRTN( err );
        valid = func.evaluate( pd, objn, err );
        if( err.error_code() == err.BARRIER_VIOLATED )
            err.clear();  // barrier violated does not represent an actual error here
        MSQ_ERRRTN( err );
        if( !valid )
            /* Function not defined at trial point */
            radius *= tr_decr_undef;
            pd.set_to_vertices_memento( mMemento, err );MSQ_ERRRTN( err );
            continue;
        if( ( fabs( kappa ) <= tr_num_tol ) && ( fabs( objn - obj ) <= tr_num_tol ) )
            kappa = 1;
        else
            kappa = ( objn - obj ) / kappa;
        if( kappa < eta_1 )
            /* Iterate is unacceptable */
            radius *= tr_decr_def;
            continue;
        /* Iterate is acceptable */
        if( kappa >= eta_2 )
            /* Iterate is a very good step, increase radius */
            radius *= tr_incr;
            if( radius > 1e20 )
                radius = 1e20;
        // checks stopping criterion
        term.accumulate_patch( pd, err );MSQ_ERRRTN( err );
        term.accumulate_inner( pd, objn, arrptr( mGrad ), err );MSQ_ERRRTN( err );
void MBMesquite::TrustRegion::terminate_mesh_iteration ( PatchData pd,
MsqError err
Definition at line 79 of file TrustRegion.cpp.
Member Data Documentation
std::vector< Vector3D > MBMesquite::TrustRegion::dVect [private]
Definition at line 70 of file TrustRegion.hpp.
Referenced by cleanup(), and optimize_vertex_positions().
std::vector< Vector3D > MBMesquite::TrustRegion::mGrad [private]
Definition at line 69 of file TrustRegion.hpp.
std::vector< double > MBMesquite::TrustRegion::preCond [private]
Definition at line 71 of file TrustRegion.hpp.
Referenced by apply_preconditioner(), cleanup(), and compute_preconditioner().
std::vector< Vector3D > MBMesquite::TrustRegion::pVect [private]
std::vector< Vector3D > MBMesquite::TrustRegion::rVect [private]
std::vector< Vector3D > MBMesquite::TrustRegion::wVect [private]
std::vector< Vector3D > MBMesquite::TrustRegion::zVect [private]
List of all members.
