MBMesquite::VertexPMeanP Class Reference
#include <VertexPMeanP.hpp>
+ Inheritance diagram for MBMesquite::VertexPMeanP:
+ Collaboration diagram for MBMesquite::VertexPMeanP:
Public Member Functions
MESQUITE_EXPORT VertexPMeanP (double p, ElemSampleQM *metric)
virtual MESQUITE_EXPORT ~VertexPMeanP ()
MESQUITE_EXPORT ElemSampleQMget_quality_metric () const
virtual MESQUITE_EXPORT std::string get_name () const
virtual MESQUITE_EXPORT int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
virtual MESQUITE_EXPORT bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
virtual MESQUITE_EXPORT bool evaluate_with_indices (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, MsqError &err)
virtual MESQUITE_EXPORT bool evaluate_with_gradient (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, MsqError &err)
 Get metric value and gradient at a logical location in the patch.
virtual MESQUITE_EXPORT bool evaluate_with_Hessian (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< Matrix3D > &Hessian, MsqError &err)
 Get metric value and deravitives at a logical location in the patch.
virtual MESQUITE_EXPORT bool evaluate_with_Hessian_diagonal (PatchData &pd, size_t handle, double &value, std::vector< size_t > &indices, std::vector< Vector3D > &gradient, std::vector< SymMatrix3D > &Hessian_diagonal, MsqError &err)
Private Attributes
ElemSampleQMmMetric
std::vector< size_t > mHandles
Detailed Description
Definition at line 44 of file VertexPMeanP.hpp.
Definition at line 42 of file VertexPMeanP.cpp.
: PMeanPMetric( p ), mMetric( metric ) {}
Definition at line 44 of file VertexPMeanP.cpp.
Member Function Documentation
bool MBMesquite::VertexPMeanP::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 59 of file VertexPMeanP.cpp.
References MBMesquite::PMeanPMetric::average(), get_quality_metric(), MBMesquite::VertexQM::get_vertex_corner_handles(), mHandles, MSQ_CHKERR, and MSQ_ERRFALSE.
Referenced by PMeanPMetricTest::test_vertex_evaluate().
    mHandles.clear();
    get_vertex_corner_handles( pd, handle, mHandles, err );
    MSQ_ERRFALSE( err );
    bool result = average( pd, get_quality_metric(), mHandles, value, err );
    return !MSQ_CHKERR( err ) && result;
bool MBMesquite::VertexPMeanP::evaluate_with_gradient ( PatchData pd,
size_t  handle,
double &  value,
std::vector< size_t > &  indices,
std::vector< Vector3D > &  gradient,
MsqError err
) [virtual]
Parameters:
pdThe patch.
indicesThe free vertices that the evaluation is a function of, specified as vertex indices in the PatchData.
gradientThe gradient of the metric as a function of the coordinates of the free vertices passed back in the indices list.
Reimplemented from MBMesquite::QualityMetric.
Definition at line 82 of file VertexPMeanP.cpp.
References MBMesquite::PMeanPMetric::average_with_gradient(), get_quality_metric(), MBMesquite::VertexQM::get_vertex_corner_handles(), mHandles, MSQ_CHKERR, and MSQ_ERRFALSE.
    ElemSampleQM* qm = get_quality_metric();
    mHandles.clear();
    bool result = average_with_gradient( pd, qm, mHandles, value, indices, gradient, err );
bool MBMesquite::VertexPMeanP::evaluate_with_Hessian ( PatchData pd,
size_t  handle,
double &  value,
std::vector< Matrix3D > &  Hessian,
MsqError err
) [virtual]
Parameters:
pdThe patch.
HessianThe Hessian of the metric as a function of the coordinates. The Hessian is passed back as the upper-triangular portion of the matrix in row-major order, where each Matrix3D is the portion of the Hessian with respect to the vertices at the corresponding positions in the indices list.
Definition at line 97 of file VertexPMeanP.cpp.
References MBMesquite::PMeanPMetric::average_with_Hessian(), get_quality_metric(), MBMesquite::VertexQM::get_vertex_corner_handles(), mHandles, MSQ_CHKERR, and MSQ_ERRFALSE.
    mHandles.clear();
    bool result = average_with_Hessian( pd, qm, mHandles, value, indices, gradient, Hessian, err );
bool MBMesquite::VertexPMeanP::evaluate_with_Hessian_diagonal ( PatchData pd,
size_t  handle,
double &  value,
std::vector< SymMatrix3D > &  Hessian_diagonal,
MsqError err
) [virtual]
Parameters:
pdThe patch.
Hessian_diagonalThe 3x3 blocks along the diagonal of the Hessian matrix.
Definition at line 113 of file VertexPMeanP.cpp.
References MBMesquite::PMeanPMetric::average_with_Hessian_diagonal(), get_quality_metric(), MBMesquite::VertexQM::get_vertex_corner_handles(), mHandles, MSQ_CHKERR, and MSQ_ERRFALSE.
    mHandles.clear();
    bool result = average_with_Hessian_diagonal( pd, qm, mHandles, value, indices, gradient, diagonal, err );
bool MBMesquite::VertexPMeanP::evaluate_with_indices ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Parameters:
pdThe patch.
Definition at line 68 of file VertexPMeanP.cpp.
References MBMesquite::PMeanPMetric::average_with_indices(), get_quality_metric(), MBMesquite::VertexQM::get_vertex_corner_handles(), mHandles, MSQ_CHKERR, and MSQ_ERRFALSE.
    mHandles.clear();
    bool result = average_with_indices( pd, qm, mHandles, value, indices, err );
std::string MBMesquite::VertexPMeanP::get_name ( ) const [virtual]
Definition at line 46 of file VertexPMeanP.cpp.
References MBMesquite::QualityMetric::get_name(), and mMetric.
    std::string result( "VertexPMeanP(" );
    result += mMetric->get_name();
    result += ")";
    return result;
Definition at line 54 of file VertexPMeanP.cpp.
References MBMesquite::QualityMetric::get_negate_flag(), and mMetric.
    return mMetric->get_negate_flag();
Member Data Documentation
List of all members.
