MsqFreeVertexIndexIteratorTest Class Reference
+ Inheritance diagram for MsqFreeVertexIndexIteratorTest:
+ Collaboration diagram for MsqFreeVertexIndexIteratorTest:
Public Member Functions
void setUp ()
void tearDown ()
 MsqFreeVertexIndexIteratorTest ()
void test_hard_fixed_flags ()
void test_soft_fixed_flags ()
Private Member Functions
 CPPUNIT_TEST_SUITE (MsqFreeVertexIndexIteratorTest)
 CPPUNIT_TEST (test_hard_fixed_flags)
 CPPUNIT_TEST (test_soft_fixed_flags)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
PatchData pd
Detailed Description
Definition at line 63 of file MsqFreeVertexIndexIteratorTest.cpp.
Member Function Documentation
Definition at line 76 of file MsqFreeVertexIndexIteratorTest.cpp.
References MBMesquite::create_six_quads_patch_with_domain().
        MsqPrintError err( cout );
        /*      7____6____5___11
                | 2  |  3 | 5  |
                8-_  |  _-4---10       vertex 1 is at (0,0)
                |  -_0_-  |    |       vertex 11 is at (3,2)
                | 0  |  1 | 4  |
                1----2----3----9
        create_six_quads_patch_with_domain( pd, err );
Definition at line 99 of file MsqFreeVertexIndexIteratorTest.cpp.
References CPPUNIT_ASSERT, MBMesquite::MsqFreeVertexIndexIterator::next(), MBMesquite::MsqFreeVertexIndexIterator::reset(), and MBMesquite::MsqFreeVertexIndexIterator::value().
        int indices[10];
        int i = 0;
        MsqFreeVertexIndexIterator ind( pd, err );
        ind.reset();
        while( ind.next() )
            indices[i] = ind.value();
            //         cout << i << "th free vertex value: " << ind.value() << endl;
            ++i;
        CPPUNIT_ASSERT( i == 2 );  // number of free vertices.
        CPPUNIT_ASSERT( pd.vertex_by_index( indices[0] ).is_free_vertex() );
        CPPUNIT_ASSERT( pd.vertex_by_index( indices[1] ).is_free_vertex() );
Definition at line 118 of file MsqFreeVertexIndexIteratorTest.cpp.
        pd.set_vertex_culled( 0 );
        int indices[10];
        int i = 0;
        ind.reset();
        while( ind.next() )
            ++i;
        CPPUNIT_ASSERT( i == 1 );  // number of free vertices.
Member Data Documentation
List of all members.
