PowerQualityMetricTest< POWER > Class Template Reference
+ Inheritance diagram for PowerQualityMetricTest< POWER >:
+ Collaboration diagram for PowerQualityMetricTest< POWER >:
Public Member Functions
 PowerQualityMetricTest ()
Protected Member Functions
virtual bool evaluate (PatchData &, size_t, double &, MsqError &)
Private Member Functions
 CPPUNIT_TEST_SUITE (PowerQualityMetricTest< POWER >)
 CPPUNIT_TEST (test_supported_types)
 CPPUNIT_TEST (test_ideal_element_eval)
 CPPUNIT_TEST (test_ideal_element_grad)
 CPPUNIT_TEST (test_non_ideal_eval)
 CPPUNIT_TEST (test_valid_hessian)
 CPPUNIT_TEST (test_inverted_elements)
 CPPUNIT_TEST (test_degenerate_elements)
 CPPUNIT_TEST (test_get_evaluations)
 CPPUNIT_TEST (test_get_element_indices)
 CPPUNIT_TEST (test_get_fixed_indices)
 CPPUNIT_TEST (test_eval_with_indices)
 CPPUNIT_TEST (test_eval_with_gradient)
 CPPUNIT_TEST (test_eval_with_hessian)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
IdealWeightInverseMeanRatio m1
PowerQualityMetric m
Detailed Description
template<int POWER>
class PowerQualityMetricTest< POWER >
Definition at line 328 of file CompositeMetricTest.cpp.
template<int POWER>
PowerQualityMetricTest< POWER >::PowerQualityMetricTest ( ) [inline]
Definition at line 355 of file CompositeMetricTest.cpp.
References mMetric.
                             : m( &m1, POWER )
        mMetric = &m;
Member Function Documentation
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_supported_types  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_ideal_element_eval  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_ideal_element_grad  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_non_ideal_eval  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_valid_hessian  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_inverted_elements  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_degenerate_elements  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_get_evaluations  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_get_element_indices  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_get_fixed_indices  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_eval_with_indices  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_eval_with_gradient  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST ( test_eval_with_hessian  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST_SUITE ( PowerQualityMetricTest< POWER >  ) [private]
template<int POWER>
PowerQualityMetricTest< POWER >::CPPUNIT_TEST_SUITE_END ( ) [private]
template<int POWER>
bool PowerQualityMetricTest< POWER >::evaluate ( PatchData pd,
size_t  h,
double &  val,
MsqError err
) [protected, virtual]
Implements CompositeMetricTestBase.
Definition at line 362 of file CompositeMetricTest.cpp.
References PowerQualityMetricTest< POWER >::evaluate(), and MSQ_ERRFALSE.
Referenced by PowerQualityMetricTest< POWER >::evaluate().
    bool rval = m1.evaluate( pd, h, val, err );
    MSQ_ERRFALSE( err );
    val = std::pow( val, POWER );
    return rval;
Member Data Documentation
template<int POWER>
PowerQualityMetric PowerQualityMetricTest< POWER >::m [private]
Definition at line 349 of file CompositeMetricTest.cpp.
template<int POWER>
IdealWeightInverseMeanRatio PowerQualityMetricTest< POWER >::m1 [private]
Definition at line 348 of file CompositeMetricTest.cpp.
List of all members.
