QualityAssessorTest Class Reference
+ Inheritance diagram for QualityAssessorTest:
+ Collaboration diagram for QualityAssessorTest:
Public Member Functions
void setUp ()
void tearDown ()
 QualityAssessorTest ()
void test_basic_stats_element ()
void test_basic_stats_vertex ()
void test_basic_stats_sample ()
void test_histogram_known_range ()
void test_histogram_unknown_range ()
void test_power_mean ()
void test_invalid_count ()
void test_inverted_count ()
void test_output_control ()
void test_tag_element ()
void test_tag_vertex ()
void test_tag_inverted ()
void test_print_inverted ()
void test_print_stats ()
void test_print_name ()
void test_modify_metric ()
void test_free_only ()
Private Member Functions
 CPPUNIT_TEST_SUITE (QualityAssessorTest)
 CPPUNIT_TEST (test_basic_stats_element)
 CPPUNIT_TEST (test_basic_stats_vertex)
 CPPUNIT_TEST (test_basic_stats_sample)
 CPPUNIT_TEST (test_histogram_known_range)
 CPPUNIT_TEST (test_histogram_unknown_range)
 CPPUNIT_TEST (test_power_mean)
 CPPUNIT_TEST (test_invalid_count)
 CPPUNIT_TEST (test_inverted_count)
 CPPUNIT_TEST (test_output_control)
 CPPUNIT_TEST (test_tag_element)
 CPPUNIT_TEST (test_tag_vertex)
 CPPUNIT_TEST (test_tag_inverted)
 CPPUNIT_TEST (test_print_inverted)
 CPPUNIT_TEST (test_print_stats)
 CPPUNIT_TEST (test_print_name)
 CPPUNIT_TEST (test_modify_metric)
 CPPUNIT_TEST (test_free_only)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
vector< double > vertCoords
vector< double > invertCoords
vector< int > fixedFlags
vector< unsigned long > triConn
vector< unsigned long > invertConn
MeshImpl myMesh
MeshImpl invertedMesh
PlanarDomain myDomain
Settings mySettings
Detailed Description
Definition at line 57 of file QualityAssessorTest.cpp.
Definition at line 93 of file QualityAssessorTest.cpp.
: myDomain( PlanarDomain::XY ) {}
Member Function Documentation
Definition at line 117 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, and vtk_file.
    MsqError err;
    // create the following mesh:
    /*2.0
     *  (3)------------------(2)
     *   |\                __/|
     *   | \       3    __/ / |
     *   |  \        __/   /  |
     *   |   \    __/  4  /   |
     *   |    \ _/       /    |
     *1.0|  0 (4)------(5)  2 |
     *   |    /. \__    .\    |
     *   |   / .    \__5. \   |
     *   |  /  .       \__ \  |
     *   | /   .   1    . \_\ |
     *  (0)------------------(1)
     *0.0     1.0      2.0   3.0
    const char vtk_file[] = "# vtk DataFile Version 3.0\n"
                            "QualityAssessorTest input 1\n"
                            "ASCII\n"
                            "DATASET UNSTRUCTURED_GRID\n"
                            "POINTS 6 float\n"
                            "0 0 0\n"
                            "3 0 0\n"
                            "3 2 0\n"
                            "0 2 0\n"
                            "1 1 0\n"
                            "2 1 0\n"
                            "CELLS 6 24\n"
                            "3 4 3 0\n"
                            "3 0 1 4\n"
                            "3 1 2 5\n"
                            "3 2 3 4\n"
                            "3 4 5 2\n"
                            "3 5 4 1\n"
                            "CELL_TYPES 6\n"
                            "5 5 5 5 5 5\n"
                            "POINT_DATA 6\n"
                            "SCALARS fixed int\n"
                            "LOOKUP_TABLE default\n"
                            "1 1 1 1 0 0\n";
    // define a mesh with two triangles, one of which is inverted wrt the other
    const char invert_file[] = "# vtk DataFile Version 3.0\n"
                               "QualityAssessorTest input 2\n"
                               "ASCII\n"
                               "POINTS 3 float\n"
                               "0 0 0\n"
                               "1 0 0\n"
                               "0 1 0\n"
                               "CELLS 2 8\n"
                               "3 0 1 2\n"
                               "3 0 2 1\n"
                               "CELL_TYPES 2\n"
                               "5 5\n"
                               "POINT_DATA 3\n"
                               "1 1 1\n";
    myMesh.clear();
    invertedMesh.clear();
    const char* tmpname = "QualityAssessorTest.vtk";
    FILE* filp          = fopen( tmpname, "w" );
    CPPUNIT_ASSERT( NULL != filp );
    size_t w = fwrite( vtk_file, sizeof( vtk_file ), 1, filp );
    fclose( filp );
    myMesh.clear();
    myMesh.read_vtk( tmpname, err );
    remove( tmpname );
    CPPUNIT_ASSERT_EQUAL( (size_t)1, w );
    ASSERT_NO_ERROR( err );
    w = fwrite( invert_file, sizeof( invert_file ), 1, filp );
    fclose( filp );
    invertedMesh.read_vtk( tmpname, err );
    remove( tmpname );
Definition at line 207 of file QualityAssessorTest.cpp.
Definition at line 324 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, MetricLogger::avg(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MetricLogger::dev(), MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::get_results(), MBMesquite::QualityAssessor::loop_over_mesh(), MetricLogger::max(), MetricLogger::min(), MetricLogger::mValues, MetricLogger::no_duplicate_evals(), and MetricLogger::rms().
    AspectRatioGammaQualityMetric metric;
    MetricLogger logger( &metric );
    QualityAssessor qa( &logger );
    qa.disable_printing_results();
    MsqError err;
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &myMesh, &myDomain );
    qa.loop_over_mesh( &mesh_and_domain, &mySettings, err );
    // check didn't evaluate any element more than once
    CPPUNIT_ASSERT( logger.no_duplicate_evals() );
    // check one eval for each element
    vector< Mesh::ElementHandle > elems;
    myMesh.get_all_elements( elems, err );
    CPPUNIT_ASSERT_EQUAL( elems.size(), logger.mValues.size() );
    // check values
    const QualityAssessor::Assessor* results = qa.get_results( &logger );
    CPPUNIT_ASSERT( results != NULL );
    CPPUNIT_ASSERT_EQUAL( (int)elems.size(), results->get_count() );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( logger.min(), results->get_minimum(), 1e-6 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( logger.avg(), results->get_average(), 1e-6 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( logger.rms(), results->get_rms(), 1e-6 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( logger.max(), results->get_maximum(), 1e-6 );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( logger.dev(), results->get_stddev(), 1e-6 );
Definition at line 389 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::PatchData::attach_settings(), MetricLogger::avg(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MetricLogger::dev(), MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::get_results(), MBMesquite::PatchData::get_samples(), MBMesquite::QualityAssessor::loop_over_mesh(), MetricLogger::max(), MetricLogger::min(), MetricLogger::mValues, MetricLogger::no_duplicate_evals(), MBMesquite::PatchData::num_elements(), MBMesquite::NodeSet::num_nodes(), MetricLogger::rms(), MBMesquite::PatchData::set_domain(), MBMesquite::PatchData::set_mesh(), and MBMesquite::PatchData::set_mesh_entities().
    TShapeNB1 tm;
    IdealShapeTarget tc;
    TQualityMetric metric( &tc, &tm );
    MsqError err;
    // check didn't evaluate any sample more than once
    // count total number of sample points in mesh
    vector< Mesh::VertexHandle > free_verts;
    PatchData global_patch;
    global_patch.set_mesh( &myMesh );
    global_patch.set_domain( &myDomain );
    global_patch.attach_settings( &mySettings );
    global_patch.set_mesh_entities( elems, free_verts, err );
    size_t num_samples = 0;
    for( size_t i = 0; i < global_patch.num_elements(); ++i )
        num_samples += global_patch.get_samples( i ).num_nodes();
    // check correct number of metric evaluations
    CPPUNIT_ASSERT_EQUAL( num_samples, logger.mValues.size() );
    // check values
    CPPUNIT_ASSERT_EQUAL( num_samples, (size_t)results->get_count() );
Definition at line 356 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, MetricLogger::avg(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MetricLogger::dev(), MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::get_results(), MBMesquite::QualityAssessor::loop_over_mesh(), MetricLogger::max(), MBMesquite::QualityAssessor::measure_free_samples_only(), MetricLogger::min(), MetricLogger::mValues, MetricLogger::no_duplicate_evals(), and MetricLogger::rms().
    LocalSizeQualityMetric metric;
    qa.measure_free_samples_only( false );
    MsqError err;
    // check didn't evaluate any vertex more than once
    vector< Mesh::VertexHandle > verts;
    myMesh.get_all_vertices( verts, err );
    CPPUNIT_ASSERT_EQUAL( verts.size(), logger.mValues.size() );
    // check values
    CPPUNIT_ASSERT_EQUAL( (int)verts.size(), results->get_count() );
Definition at line 1060 of file QualityAssessorTest.cpp.
References MBMesquite::InstructionQueue::add_quality_assessor(), ASSERT_NO_ERROR, conn, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, fixed, MBMesquite::QualityAssessor::Assessor::get_count(), MBMesquite::QualityAssessor::get_results(), mesh, MBMesquite::QUADRILATERAL, MBMesquite::IQInterface::run_instructions(), and MBMesquite::PlanarDomain::XY.
     *   +--+--------o-----o
     *   |   \       |     |    + - fixed
     *   |    \      |     |    o - free
     *   +-----+-----o-----o
    double coords[]      = { 0, 0, 0, 1, 0, 0, 0.5, 1, 0, 0, 1, 0, 2, 0, 0, 3, 0, 0, 3, 1, 0, 2, 1, 0 };
    int fixed[]          = { true, true, true, true, false, false, false, false };
    unsigned long conn[] = { 0, 1, 2, 3, 1, 4, 7, 2, 4, 5, 6, 7 };
    MsqError err;
    ArrayMesh mesh( 3, 8, coords, fixed, 3, QUADRILATERAL, conn );
    ConditionNumberQualityMetric metric;
    QualityAssessor qa_all( &metric, 0, 0.0, false, 0, false );
    QualityAssessor qa_free( &metric, 0, 0.0, true, 0, false );
    InstructionQueue q;
    q.add_quality_assessor( &qa_all, err );
    q.add_quality_assessor( &qa_free, err );
    PlanarDomain xy( PlanarDomain::XY );
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &mesh, &xy );
    q.run_instructions( &mesh_and_domain, err );
    const QualityAssessor::Assessor* data;
    data = qa_all.get_results( &metric );
    CPPUNIT_ASSERT( 0 != data );
    CPPUNIT_ASSERT_EQUAL( 3, data->get_count() );
    data = qa_free.get_results( &metric );
    CPPUNIT_ASSERT_EQUAL( 2, data->get_count() );
Definition at line 437 of file QualityAssessorTest.cpp.
References MBMesquite::QualityAssessor::add_histogram_assessment(), ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::Assessor::get_histogram(), MBMesquite::QualityAssessor::get_results(), MBMesquite::QualityAssessor::Assessor::have_histogram(), MBMesquite::QualityAssessor::loop_over_mesh(), and MetricLogger::mValues.
    const double lower = 1.0, upper = 3.0;
    const int intervals = 5;
    QualityAssessor qa;
    qa.add_histogram_assessment( &logger, lower, upper, intervals );
    MsqError err;
    // calculate expected histogram
    std::vector< int > counts( intervals + 2, 0 );
    for( vector< double >::iterator i = logger.mValues.begin(); i != logger.mValues.end(); ++i )
        int bucket = (int)( ( *i - lower ) * intervals / ( upper - lower ) );
        if( bucket < 0 )
            ++counts.front();
        else if( bucket >= intervals )
            ++counts.back();
        else
            ++counts[bucket + 1];
    // check values
    CPPUNIT_ASSERT( results->have_histogram() );
    double r_lower, r_upper;
    vector< int > r_counts;
    results->get_histogram( r_lower, r_upper, r_counts, err );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( lower, r_lower, DBL_EPSILON );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( upper, r_upper, DBL_EPSILON );
    CPPUNIT_ASSERT_EQUAL( intervals + 2, (int)r_counts.size() );
    CPPUNIT_ASSERT_EQUAL( counts.front(), r_counts.front() );
    CPPUNIT_ASSERT_EQUAL( counts.back(), r_counts.back() );
    switch( intervals )
        default:
            for( unsigned i = 11; i < intervals + 1; ++i )
                CPPUNIT_ASSERT_EQUAL( counts[i], r_counts[i] );
        case 10:
            CPPUNIT_ASSERT_EQUAL( counts[10], r_counts[10] );
        case 9:
            CPPUNIT_ASSERT_EQUAL( counts[9], r_counts[9] );
        case 8:
            CPPUNIT_ASSERT_EQUAL( counts[8], r_counts[8] );
        case 7:
            CPPUNIT_ASSERT_EQUAL( counts[7], r_counts[7] );
        case 6:
            CPPUNIT_ASSERT_EQUAL( counts[6], r_counts[6] );
        case 5:
            CPPUNIT_ASSERT_EQUAL( counts[5], r_counts[5] );
        case 4:
            CPPUNIT_ASSERT_EQUAL( counts[4], r_counts[4] );
        case 3:
            CPPUNIT_ASSERT_EQUAL( counts[3], r_counts[3] );
        case 2:
            CPPUNIT_ASSERT_EQUAL( counts[2], r_counts[2] );
        case 1:
            CPPUNIT_ASSERT_EQUAL( counts[1], r_counts[1] );
        case 0:;
Definition at line 510 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::Assessor::get_histogram(), MBMesquite::QualityAssessor::get_results(), MBMesquite::QualityAssessor::Assessor::have_histogram(), MBMesquite::QualityAssessor::loop_over_mesh(), MetricLogger::max(), MetricLogger::min(), and MetricLogger::mValues.
    const int intervals = 10;
    QualityAssessor qa( &logger, intervals );
    MsqError err;
    // check values
    CPPUNIT_ASSERT( r_lower <= logger.min() );
    CPPUNIT_ASSERT( r_upper >= logger.min() );
    // allow some freedom in choice of range, but not more than 30%
    CPPUNIT_ASSERT( ( 0.30 * ( r_upper - r_lower ) ) <= ( logger.max() - logger.min() ) );
    // range must contain all metric values
    CPPUNIT_ASSERT_EQUAL( 0, r_counts.front() );
    CPPUNIT_ASSERT_EQUAL( 0, r_counts.back() );
    std::vector< int > counts( intervals, 0 );
        double fract = ( *i - r_lower ) / ( r_upper - r_lower );
        int bucket;
        if( fabs( fract - 1.0 ) < DBL_EPSILON )
            bucket = intervals - 1;
        else
            bucket = (int)( intervals * fract );
        CPPUNIT_ASSERT( bucket >= 0 );
        CPPUNIT_ASSERT( bucket < intervals );
        ++counts[bucket];
    // QA should have evaluated metric twice, so adjust values
    CPPUNIT_ASSERT_EQUAL( 12, (int)logger.mValues.size() );
    for( vector< int >::iterator j = counts.begin(); j != counts.end(); ++j )
        *j /= 2;
    switch( intervals )
        default:
            for( int i = 10; i < intervals; ++i )
                CPPUNIT_ASSERT_EQUAL( counts[i], r_counts[i + 1] );
        case 10:
            CPPUNIT_ASSERT_EQUAL( counts[9], r_counts[10] );
        case 9:
            CPPUNIT_ASSERT_EQUAL( counts[8], r_counts[9] );
        case 8:
            CPPUNIT_ASSERT_EQUAL( counts[7], r_counts[8] );
        case 7:
            CPPUNIT_ASSERT_EQUAL( counts[6], r_counts[7] );
        case 6:
            CPPUNIT_ASSERT_EQUAL( counts[5], r_counts[6] );
        case 5:
            CPPUNIT_ASSERT_EQUAL( counts[4], r_counts[5] );
        case 4:
            CPPUNIT_ASSERT_EQUAL( counts[3], r_counts[4] );
        case 3:
            CPPUNIT_ASSERT_EQUAL( counts[2], r_counts[3] );
        case 2:
            CPPUNIT_ASSERT_EQUAL( counts[1], r_counts[2] );
        case 1:
            CPPUNIT_ASSERT_EQUAL( counts[0], r_counts[1] );
        case 0:;
Definition at line 629 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::Assessor::get_invalid_element_count(), MBMesquite::QualityAssessor::get_results(), MBMesquite::QualityAssessor::loop_over_mesh(), and MBMesquite::QualityAssessor::measure_free_samples_only().
    MsqError err;
    QualityAssessor qa( &metric );
    const QualityAssessor::Assessor* results = qa.get_results( &metric );
    CPPUNIT_ASSERT( NULL != results );
    // try mesh with only valid elements
    CPPUNIT_ASSERT_EQUAL( 0, results->get_invalid_element_count() );
    // try mesh with one inverted element
    MeshDomainAssoc mesh_and_domain2 = MeshDomainAssoc( &invertedMesh, &myDomain );
    qa.loop_over_mesh( &mesh_and_domain2, &mySettings, err );
    CPPUNIT_ASSERT_EQUAL( 1, results->get_invalid_element_count() );
Definition at line 652 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::get_inverted_element_count(), MBMesquite::QualityAssessor::loop_over_mesh(), and MBMesquite::QualityAssessor::measure_free_samples_only().
    int inverted, samples;
    MsqError err;
    QualityAssessor qa;
    inverted = samples = -1;
    qa.get_inverted_element_count( inverted, samples, err );
    CPPUNIT_ASSERT_EQUAL( 0, inverted );
    CPPUNIT_ASSERT_EQUAL( 0, samples );
    CPPUNIT_ASSERT_EQUAL( 1, inverted );
    CPPUNIT_ASSERT_EQUAL( 1, samples );
Definition at line 791 of file QualityAssessorTest.cpp.
References CPPUNIT_ASSERT, StreamRedirector::have_data(), MBMesquite::QualityAssessor::loop_over_mesh(), StreamRedirector::redirect(), and StreamRedirector::restore().
    // Redirect std::cout, std:cerr, and std::clog
    // so we know when they're written to.
    StreamRedirector redir;
    MsqError err;
    // disable output from constructor
    QualityAssessor qa1( &metric, 0, 0, false, 0, false );
    redir.redirect();
    MeshDomainAssoc mesh_and_domain = MeshDomainAssoc( &invertedMesh, &myDomain );
    qa1.loop_over_mesh( &mesh_and_domain, &mySettings, err );
    redir.restore();
    // make sure nothing was written to output streams
    CPPUNIT_ASSERT( !redir.have_data() );
    // disable output from function
    QualityAssessor qa2( &metric );
    qa2.disable_printing_results();
    redir.redirect();
    qa2.loop_over_mesh( &mesh_and_domain, &mySettings, err );
    redir.restore();
    // send output to alternate stream
    stringstream deststr;
    QualityAssessor qa3( deststr, &metric );
    redir.redirect();
    qa3.loop_over_mesh( &mesh_and_domain, &mySettings, err );
    redir.restore();
    // check that some data was written to specified stream
    CPPUNIT_ASSERT( !deststr.str().empty() );
    // redir destructor should now restore normal output streams
Definition at line 591 of file QualityAssessorTest.cpp.
References MBMesquite::QualityAssessor::add_quality_assessment(), ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::QualityAssessor::Assessor::get_power(), MBMesquite::QualityAssessor::Assessor::get_power_mean(), MBMesquite::QualityAssessor::get_results(), MBMesquite::QualityAssessor::Assessor::have_power_mean(), MBMesquite::QualityAssessor::loop_over_mesh(), and MetricLogger::pmean().
    const double P1 = 3.0, P2 = 0.5;
    AspectRatioGammaQualityMetric metric1;
    LocalSizeQualityMetric metric2;
    ConditionNumberQualityMetric metric3;
    MetricLogger logger1( &metric1 ), logger2( &metric2 );
    QualityAssessor qa( &metric3 );
    qa.add_quality_assessment( &logger1, 0, P1 );
    qa.add_quality_assessment( &logger2, 0, P2 );
    MsqError err;
    // get results
    const QualityAssessor::Assessor *result1, *result2, *result3;
    result1 = qa.get_results( &logger1 );
    result2 = qa.get_results( &logger2 );
    result3 = qa.get_results( &metric3 );
    CPPUNIT_ASSERT( NULL != result1 );
    CPPUNIT_ASSERT( NULL != result2 );
    CPPUNIT_ASSERT( NULL != result3 );
    // check flags
    CPPUNIT_ASSERT( result1->have_power_mean() );
    CPPUNIT_ASSERT( result2->have_power_mean() );
    CPPUNIT_ASSERT( !result3->have_power_mean() );
    // check values
    CPPUNIT_ASSERT_DOUBLES_EQUAL( P1, result1->get_power(), DBL_EPSILON );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( P2, result2->get_power(), DBL_EPSILON );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( logger1.pmean( P1 ), result1->get_power_mean(), logger1.pmean( P1 ) * DBL_EPSILON );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( logger2.pmean( P2 ), result2->get_power_mean(), logger2.pmean( P2 ) * DBL_EPSILON );
Definition at line 947 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityAssessor::get_inverted_element_count(), MBMesquite::QualityAssessor::loop_over_mesh(), MBMesquite::QualityAssessor::measure_free_samples_only(), and value().
    MsqError err;
    stringstream str;
    QualityAssessor qa( str );
    // get inverted count from QA
    int expected = 0, other = 0;
    qa.get_inverted_element_count( expected, other, err );
    // At some point, expect "n INVERTED" to appear in output,
    // where 'n' is the count of inverted elements.
    int value;
    string prev, curr;
    for( ; str >> curr && curr != "INVERTED"; prev = curr )
    str.str( prev );
    str >> value;
    CPPUNIT_ASSERT_EQUAL( expected, value );
Definition at line 1020 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityAssessor::loop_over_mesh(), and NAME.
    const char* NAME = "test_print_name_NAME";
    // expect QualityAssessor Name to be printed somewhere in output.
    MsqError err;
    stringstream str;
    QualityAssessor qa( str, &metric, 0, 0, false, 0, 0, NAME );
    // seach output for first occurance of name
    string s;
    while( str >> s && s != NAME )
    CPPUNIT_ASSERT_EQUAL( s, string( NAME ) );
Definition at line 974 of file QualityAssessorTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, MBMesquite::ConditionNumberQualityMetric::get_name(), MBMesquite::QualityAssessor::get_results(), MBMesquite::QualityAssessor::loop_over_mesh(), and n.
    MsqError err;
    stringstream str;
    QualityAssessor qa( str, &metric );
    // get results
    // Expect metric name followed by 5 numerical values for statistics,
    // at some point in output.
    // Find occurance of metric name in output
    for( ;; )
        stringstream name( metric.get_name() );
        string s, n;
        name >> n;
        while( str >> s && s != n )
        CPPUNIT_ASSERT( str );
        while( name >> n && str >> s && s == n )
        if( !name ) break;
    // Read stats
    double min_s, max_s, avg_s, rms_s, dev_s;
    str >> min_s >> avg_s >> rms_s >> max_s >> dev_s;
    // The following commented out because they no longer pass due to a change
    //  in the QA Summary format
    // compare results
    //  CPPUNIT_ASSERT_DOUBLES_EQUAL( results->get_minimum(), min_s, min_s * 0.01 );
    //  CPPUNIT_ASSERT_DOUBLES_EQUAL( results->get_average(), avg_s, avg_s * 0.01 );
    //  CPPUNIT_ASSERT_DOUBLES_EQUAL( results->get_rms    (), rms_s, rms_s * 0.01 );
    //  CPPUNIT_ASSERT_DOUBLES_EQUAL( results->get_maximum(), max_s, max_s * 0.01 );
    //  CPPUNIT_ASSERT_DOUBLES_EQUAL( results->get_stddev (), dev_s, dev_s * 0.01 );
Definition at line 832 of file QualityAssessorTest.cpp.
References MBMesquite::arrptr(), ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::Mesh::DOUBLE, MBMesquite::length(), MBMesquite::QualityAssessor::loop_over_mesh(), MetricLogger::mHandles, MetricLogger::mValues, and u.
    const char* tag_name = "xxxTEST_TAGxxx";
    QualityAssessor qa( &logger, 0, 0, false, tag_name );
    MsqError err;
    TagHandle tag;
    tag = myMesh.tag_get( tag_name, err );
    string name;
    Mesh::TagType type;
    unsigned length;
    myMesh.tag_properties( tag, name, type, length, err );
    CPPUNIT_ASSERT_EQUAL( name, string( tag_name ) );
    CPPUNIT_ASSERT_EQUAL( Mesh::DOUBLE, type );
    CPPUNIT_ASSERT_EQUAL( 1u, length );
    CPPUNIT_ASSERT_EQUAL( logger.mValues.size(), logger.mHandles.size() );
    CPPUNIT_ASSERT( !logger.mValues.empty() );
    vector< double > tag_values( logger.mValues.size() );
    myMesh.tag_get_element_data( tag, logger.mHandles.size(), &logger.mHandles[0], arrptr( tag_values ), err );
    for( unsigned i = 0; i < logger.mValues.size(); ++i )
        CPPUNIT_ASSERT_DOUBLES_EQUAL( logger.mValues[1], tag_values[1], DBL_EPSILON );
Definition at line 903 of file QualityAssessorTest.cpp.
References MBMesquite::arrptr(), ASSERT_NO_ERROR, CPPUNIT_ASSERT_EQUAL, MBMesquite::Mesh::INT, MBMesquite::length(), MBMesquite::QualityAssessor::loop_over_mesh(), and u.
    const char* tag_name = "123INVERT456";
    QualityAssessor qa( false, false, tag_name );
    MsqError err;
    TagHandle tag;
    tag = invertedMesh.tag_get( tag_name, err );
    string name;
    Mesh::TagType type;
    unsigned length;
    invertedMesh.tag_properties( tag, name, type, length, err );
    CPPUNIT_ASSERT_EQUAL( Mesh::INT, type );
    vector< Mesh::ElementHandle > elements;
    invertedMesh.get_all_elements( elements, err );
    // expect two elements, one inverted
    CPPUNIT_ASSERT_EQUAL( (size_t)2, elements.size() );
    int data[2];
    invertedMesh.tag_get_element_data( tag, 2, arrptr( elements ), data, err );
    if( data[0] )
        CPPUNIT_ASSERT_EQUAL( 0, data[1] );
    else
        CPPUNIT_ASSERT_EQUAL( 0, data[0] );
        CPPUNIT_ASSERT_EQUAL( 1, data[1] );
Definition at line 868 of file QualityAssessorTest.cpp.
References MBMesquite::arrptr(), ASSERT_NO_ERROR, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityAssessor::disable_printing_results(), MBMesquite::Mesh::DOUBLE, MBMesquite::length(), MBMesquite::QualityAssessor::loop_over_mesh(), MetricLogger::mHandles, MetricLogger::mValues, and u.
    const char* tag_name = "vertex-test-tag";
    MsqError err;
    TagHandle tag;
    string name;
    Mesh::TagType type;
    unsigned length;
    myMesh.tag_get_vertex_data( tag, logger.mHandles.size(), &logger.mHandles[0], arrptr( tag_values ), err );
Member Data Documentation
vector< int > QualityAssessorTest::fixedFlags [private]
Definition at line 81 of file QualityAssessorTest.cpp.
vector< unsigned long > QualityAssessorTest::invertConn [private]
Definition at line 82 of file QualityAssessorTest.cpp.
vector< double > QualityAssessorTest::invertCoords [private]
Definition at line 80 of file QualityAssessorTest.cpp.
Definition at line 84 of file QualityAssessorTest.cpp.
Definition at line 86 of file QualityAssessorTest.cpp.
vector< unsigned long > QualityAssessorTest::triConn [private]
vector< double > QualityAssessorTest::vertCoords [private]
List of all members.
