QualityMetricTest Class Reference
+ Inheritance diagram for QualityMetricTest:
+ Collaboration diagram for QualityMetricTest:
Public Member Functions
void setUp ()
void test_fixed_vertex_list ()
void test_remove_fixed_gradients ()
void test_remove_fixed_hessians ()
void test_gradient_constant ()
void test_gradient_linear ()
void test_gradient_parabolic ()
void test_gradient_tau ()
void test_Hessian_constant ()
void test_Hessian_linear ()
void test_Hessian_parabolic ()
void test_Hessian_tau ()
void test_diagonal_constant ()
void test_diagonal_linear ()
void test_diagonal_parabolic ()
void test_diagonal_tau ()
void compare_indices (QualityMetric &qm, PatchData &pd, size_t sample, double value, const std::vector< size_t > &indices)
void compare_gradient (QualityMetric &qm, PatchData &pd, size_t sample, double value, const std::vector< size_t > &indices, const std::vector< Vector3D > &grad)
Private Member Functions
 CPPUNIT_TEST_SUITE (QualityMetricTest)
 CPPUNIT_TEST (test_fixed_vertex_list)
 CPPUNIT_TEST (test_remove_fixed_gradients)
 CPPUNIT_TEST (test_remove_fixed_hessians)
 CPPUNIT_TEST (test_gradient_constant)
 CPPUNIT_TEST (test_gradient_linear)
 CPPUNIT_TEST (test_gradient_parabolic)
 CPPUNIT_TEST (test_gradient_tau)
 CPPUNIT_TEST (test_Hessian_constant)
 CPPUNIT_TEST (test_Hessian_linear)
 CPPUNIT_TEST (test_Hessian_parabolic)
 CPPUNIT_TEST (test_Hessian_tau)
 CPPUNIT_TEST (test_diagonal_constant)
 CPPUNIT_TEST (test_diagonal_linear)
 CPPUNIT_TEST (test_diagonal_parabolic)
 CPPUNIT_TEST (test_diagonal_tau)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
PatchData tri_pd
Detailed Description
Definition at line 46 of file QualityMetricTest.cpp.
Member Function Documentation
void QualityMetricTest::compare_gradient ( QualityMetric qm,
PatchData pd,
size_t  sample,
double  value,
const std::vector< size_t > &  indices,
const std::vector< Vector3D > &  grad
Definition at line 764 of file QualityMetricTest.cpp.
References ASSERT_NO_ERROR, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::EPSILON, and MBMesquite::QualityMetric::evaluate_with_gradient().
    double value2;
    std::vector< size_t > indices2;
    std::vector< Vector3D > grad2;
    MsqError err;
    bool valid = qm.evaluate_with_gradient( pd, sample, value2, indices2, grad2, err );
    ASSERT_NO_ERROR( err );
    CPPUNIT_ASSERT( valid );
    CPPUNIT_ASSERT_DOUBLES_EQUAL( value2, value, EPSILON );
    CPPUNIT_ASSERT_EQUAL( indices2.size(), indices.size() );
    CPPUNIT_ASSERT_EQUAL( indices.size(), grad.size() );
    for( size_t i = 0; i < indices.size(); ++i )
        size_t j = std::find( indices2.begin(), indices2.end(), indices[i] ) - indices2.begin();
        CPPUNIT_ASSERT( j < indices2.size() );  // not found->indices don't match
        CPPUNIT_ASSERT_VECTORS_EQUAL( grad2[j], grad[i], EPSILON );
void QualityMetricTest::compare_indices ( QualityMetric qm,
PatchData pd,
size_t  sample,
double  value,
Definition at line 745 of file QualityMetricTest.cpp.
References ASSERT_NO_ERROR, ASSERT_STD_VECTORS_EQUAL, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::EPSILON, and MBMesquite::QualityMetric::evaluate_with_indices().
    double value2;
    MsqError err;
    bool valid = qm.evaluate_with_indices( pd, sample, value2, indices2, err );
    std::vector< size_t > indices1( indices );
    std::sort( indices1.begin(), indices1.end() );
    std::sort( indices2.begin(), indices2.end() );
    ASSERT_STD_VECTORS_EQUAL( indices2, indices1 );
Definition at line 103 of file QualityMetricTest.cpp.
References CPPUNIT_ASSERT, fixed, MBMesquite::TRIANGLE, and vtx_coords().
    MsqError err;
    const double vtx_coords[]   = { 1, 0, 0, 0, 1, 0, 3, 0, 0, 0, 0, 0, 2, 1, 0 };
    const size_t connectivity[] = { 0, 1, 3, 1, 2, 4 };
    const bool fixed[]          = { false, false, false, true, true };
    tri_pd.fill( 5, vtx_coords, 2, TRIANGLE, connectivity, fixed, err );
    CPPUNIT_ASSERT( !err );
Definition at line 635 of file QualityMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, ELEMENT, MBMesquite::EPSILON, MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::gradient(), and value().
    MsqError err;
    std::vector< size_t > indices;
    std::vector< Vector3D > gradient;
    std::vector< SymMatrix3D > Hessian;
    double value;
    size_t ELEMENT = 0;
    ConstantElementMetric constant;
    QualityMetric& qm = constant;
    bool valid = qm.evaluate_with_Hessian_diagonal( tri_pd, ELEMENT, value, indices, gradient, Hessian, err );
    compare_gradient( qm, tri_pd, ELEMENT, value, indices, gradient );
    CPPUNIT_ASSERT_EQUAL( indices.size(), Hessian.size() );
    CPPUNIT_ASSERT_EQUAL( (size_t)2, indices.size() );
    CPPUNIT_ASSERT_MATRICES_EQUAL( SymMatrix3D( 0.0 ), Hessian[0], EPSILON );
    CPPUNIT_ASSERT_MATRICES_EQUAL( SymMatrix3D( 0.0 ), Hessian[1], EPSILON );
Definition at line 658 of file QualityMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, MBMesquite::EPSILON, MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::gradient(), value(), and VERTEX.
    MsqError err;
    double value;
    size_t VERTEX = 0;
    LinearVertexMetric linear;
    QualityMetric& qm = linear;
    bool valid = qm.evaluate_with_Hessian_diagonal( tri_pd, VERTEX, value, indices, gradient, Hessian, err );
    compare_gradient( qm, tri_pd, VERTEX, value, indices, gradient );
    CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() );
Definition at line 679 of file QualityMetricTest.cpp.
    MsqError err;
    double value;
    size_t VERTEX = 0;
    ParabolicVertexMetric parab;
    QualityMetric& qm = parab;
    SymMatrix3D expected( 0.0, 0.0, 0.0, 2.0, 0.0, 0.0 );
    CPPUNIT_ASSERT_MATRICES_EQUAL( expected, Hessian[0], EPSILON );
Definition at line 702 of file QualityMetricTest.cpp.
References MBMesquite::adj(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, MBMesquite::det(), ELEMENT, MBMesquite::EPSILON, MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::gradient(), TriTauMetric::matrix(), MBMesquite::pluseq_scaled_outer_product(), MBMesquite::set_scaled_2nd_deriv_of_det(), swap(), MBMesquite::transpose(), and value().
    MsqError err;
    double value;
    size_t ELEMENT = 1;
    TriTauMetric qm;
    CPPUNIT_ASSERT_EQUAL( (size_t)2, indices.size() );  // two free vertices in triangle
    MsqMatrix< 3, 3 > M = qm.matrix( tri_pd, ELEMENT );
    MsqMatrix< 3, 3 > d2M[6];
    set_scaled_2nd_deriv_of_det( d2M, 2 * ( det( M ) - 1 ), M );
    pluseq_scaled_outer_product( d2M, 2, transpose( adj( M ) ) );
    if( indices[0] == 2 )
        CPPUNIT_ASSERT_EQUAL( (size_t)1, indices[1] );
        std::swap( indices[0], indices[1] );
        std::swap( gradient[0], gradient[1] );
        std::swap( Hessian[0], Hessian[1] );
    else
        CPPUNIT_ASSERT_EQUAL( (size_t)1, indices[0] );
        CPPUNIT_ASSERT_EQUAL( (size_t)2, indices[1] );
    SymMatrix3D exp0( d2M[0]( 0, 0 ), d2M[0]( 0, 1 ), d2M[0]( 0, 2 ), d2M[0]( 1, 1 ), d2M[0]( 1, 2 ), d2M[0]( 2, 2 ) );
    SymMatrix3D exp1( d2M[3]( 0, 0 ), d2M[3]( 0, 1 ), d2M[3]( 0, 2 ), d2M[3]( 1, 1 ), d2M[3]( 1, 2 ), d2M[3]( 2, 2 ) );
    CPPUNIT_ASSERT_MATRICES_EQUAL( exp0, Hessian[0], EPSILON );
    CPPUNIT_ASSERT_MATRICES_EQUAL( exp1, Hessian[1], EPSILON );
Definition at line 286 of file QualityMetricTest.cpp.
References ASSERT_NO_ERROR, conn, CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::PatchData::fill(), fixed, MBMesquite::QualityMetric::fixed_vertex_bitmap(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::PatchData::num_free_vertices(), MBMesquite::QUADRILATERAL, and u.
    // define a patch of four quads such that
    // the number of fixed vertices in each quad
    // varies from 0 to 3
    /*   2------1-----8
     *   | (0)  | (3) | \
     *   3------0-----7   \
     *   | (1)  | (2) | \   \
     *   4------5-----6   \   \
     *           \____\____\___\__ fixed
    const double coords[] = { 0, 0, 0, 0, 1, 0, -1, 1, 0, -1, 0, 0, -1, -1, 0, 0, -1, 0, 1, -1, 0, 1, 0, 0, 1, 1, 0 };
    const size_t conn[]   = { 0, 1, 2, 3, 3, 4, 5, 0, 6, 7, 0, 5, 0, 7, 8, 1 };
    const bool fixed[]    = { false, false, false, false, false, true, true, true, true };
    MsqPrintError err( std::cout );
    PatchData pd;
    pd.fill( 9, coords, 4, QUADRILATERAL, conn, fixed, err );
    uint32_t bits;
    std::vector< size_t >::iterator it;
    const size_t* verts;
    unsigned i;
    indices.clear();
    bits = QualityMetric::fixed_vertex_bitmap( pd, &pd.element_by_index( 0 ), indices );
    CPPUNIT_ASSERT_EQUAL( (size_t)4, indices.size() );
    CPPUNIT_ASSERT_EQUAL( (uint32_t)0, bits & 0xF );
    CPPUNIT_ASSERT( pd.num_free_vertices() > *std::max_element( indices.begin(), indices.end() ) );
    verts = pd.element_by_index( 0 ).get_vertex_index_array();
    for( i = 0; i < 4; ++i )
        CPPUNIT_ASSERT( std::find( verts, verts + 4, indices[i] ) != verts + 4 );
    indices.clear();
    bits = QualityMetric::fixed_vertex_bitmap( pd, &pd.element_by_index( 1 ), indices );
    CPPUNIT_ASSERT_EQUAL( (size_t)3, indices.size() );
    verts = pd.element_by_index( 1 ).get_vertex_index_array();
        it = std::find( indices.begin(), indices.end(), verts[i] );
        if( verts[i] < pd.num_free_vertices() )
            CPPUNIT_ASSERT( it != indices.end() );
            CPPUNIT_ASSERT_EQUAL( 0u, bits & ( 1 << i ) );
        else
            CPPUNIT_ASSERT( it == indices.end() );
            CPPUNIT_ASSERT_EQUAL( 1u, ( bits >> i ) & 1 );
    indices.clear();
    bits = QualityMetric::fixed_vertex_bitmap( pd, &pd.element_by_index( 2 ), indices );
    verts = pd.element_by_index( 2 ).get_vertex_index_array();
        else
    indices.clear();
    bits = QualityMetric::fixed_vertex_bitmap( pd, &pd.element_by_index( 3 ), indices );
    verts = pd.element_by_index( 3 ).get_vertex_index_array();
        else
Definition at line 426 of file QualityMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, ELEMENT, MBMesquite::EPSILON, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::gradient(), and value().
    MsqError err;
    double value;
    size_t ELEMENT = 0;
    bool valid = qm.evaluate_with_gradient( tri_pd, ELEMENT, value, indices, gradient, err );
    compare_indices( qm, tri_pd, ELEMENT, value, indices );
    CPPUNIT_ASSERT_EQUAL( indices.size(), gradient.size() );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 0 ), gradient[0], EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 0 ), gradient[1], EPSILON );
Definition at line 448 of file QualityMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::EPSILON, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::gradient(), value(), and VERTEX.
    MsqError err;
    double value;
    size_t VERTEX = 0;
    bool valid = qm.evaluate_with_gradient( tri_pd, VERTEX, value, indices, gradient, err );
    compare_indices( qm, tri_pd, VERTEX, value, indices );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1, 0, 0 ), gradient[0], EPSILON );
Definition at line 468 of file QualityMetricTest.cpp.
    const size_t VERTEX = 1;  // pick vertex with non-zero Y-coordinate
    MsqError err;
    double value;
    CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() );  // two free vertices in triangle
    const double expected_y = 2 * tri_pd.vertex_by_index( VERTEX )[1];
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, expected_y, 0 ), gradient[0], EPSILON );
Definition at line 490 of file QualityMetricTest.cpp.
References MBMesquite::adj(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::det(), ELEMENT, MBMesquite::EPSILON, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::gradient(), TriTauMetric::matrix(), MBMesquite::MsqMatrix< R, C >::row(), swap(), MBMesquite::transpose(), and value().
    MsqError err;
    double value;
    size_t ELEMENT = 1;
    TriTauMetric qm;
    MsqMatrix< 3, 3 > dM = transpose( adj( M ) );
    dM *= 2 * ( det( M ) - 1 );
    else
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( dM.row( 0 ).data() ), gradient[0], EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( dM.row( 1 ).data() ), gradient[1], EPSILON );
Definition at line 526 of file QualityMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, ELEMENT, MBMesquite::EPSILON, MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::gradient(), and value().
    MsqError err;
    std::vector< Matrix3D > Hessian;
    double value;
    size_t ELEMENT = 0;
    bool valid = qm.evaluate_with_Hessian( tri_pd, ELEMENT, value, indices, gradient, Hessian, err );
    CPPUNIT_ASSERT_EQUAL( indices.size() * ( indices.size() + 1 ) / 2, Hessian.size() );
    CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 0.0 ), Hessian[0], EPSILON );
    CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 0.0 ), Hessian[1], EPSILON );
Definition at line 549 of file QualityMetricTest.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, MBMesquite::EPSILON, MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::gradient(), value(), and VERTEX.
    MsqError err;
    double value;
    size_t VERTEX = 0;
    bool valid = qm.evaluate_with_Hessian( tri_pd, VERTEX, value, indices, gradient, Hessian, err );
Definition at line 570 of file QualityMetricTest.cpp.
    MsqError err;
    double value;
    size_t VERTEX = 0;
    Matrix3D expected( 0.0, 0.0, 0.0, 0.0, 2.0, 0.0, 0.0, 0.0, 0.0 );
Definition at line 593 of file QualityMetricTest.cpp.
References MBMesquite::adj(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, MBMesquite::det(), ELEMENT, MBMesquite::EPSILON, MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::gradient(), TriTauMetric::matrix(), MBMesquite::pluseq_scaled_outer_product(), MBMesquite::set_scaled_2nd_deriv_of_det(), swap(), MBMesquite::transpose(), and value().
    MsqError err;
    double value;
    size_t ELEMENT = 1;
    TriTauMetric qm;
        std::swap( Hessian[0], Hessian[2] );
        Hessian[1] = transpose( Hessian[1] );
    else
    CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( d2M[0].data() ), Hessian[0], EPSILON );
    CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( d2M[1].data() ), Hessian[1], EPSILON );
    CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( d2M[3].data() ), Hessian[2], EPSILON );
Definition at line 384 of file QualityMetricTest.cpp.
References CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::PRISM, MBMesquite::QualityMetric::remove_fixed_gradients(), and u.
    // define a list of vectors
    std::vector< Vector3D > grads( 6 );
    grads[0] = Vector3D( 0, 0, 0 );
    grads[1] = Vector3D( 1, 1, 1 );
    grads[2] = Vector3D( 2, 2, 2 );
    grads[3] = Vector3D( 3, 3, 3 );
    grads[4] = Vector3D( 4, 4, 4 );
    grads[5] = Vector3D( 5, 5, 5 );
    // remove the first, third, and last
    uint32_t flags = 1u | 4u | 32u;
    // call function, choose element type w/ correct number of corners
    QualityMetric::remove_fixed_gradients( PRISM, flags, grads );
    // check results
    CPPUNIT_ASSERT_EQUAL( (size_t)3, grads.size() );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 1, 1, 1 ), grads[0], DBL_EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 3, 3, 3 ), grads[1], DBL_EPSILON );
    CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 4, 4, 4 ), grads[2], DBL_EPSILON );
Definition at line 405 of file QualityMetricTest.cpp.
References CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, MBMesquite::hess(), MBMesquite::QUADRILATERAL, MBMesquite::QualityMetric::remove_fixed_hessians(), and u.
    // define Hessian matrix for a quadrilateral
    Matrix3D m[10] = { Matrix3D( 0.0 ), Matrix3D( 1.0 ), Matrix3D( 2.0 ), Matrix3D( 3.0 ), Matrix3D( 4.0 ),
                       Matrix3D( 5.0 ), Matrix3D( 6.0 ), Matrix3D( 7.0 ), Matrix3D( 8.0 ), Matrix3D( 9.0 ) };
    // convert to std::vector
    std::vector< Matrix3D > hess( 10 );
    std::copy( m, m + 10, hess.begin() );
    // mark fist and third vertices as fixed
    uint32_t flags = 1u | 4u;
    // call function to remove grads for fixed vertices
    QualityMetric::remove_fixed_hessians( QUADRILATERAL, flags, hess );
    // the submatrix with the first and third rows/columns removed should be
    // { 4, 6,
    //      9 }
    CPPUNIT_ASSERT_EQUAL( (size_t)3, hess.size() );
    CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 4.0 ), hess[0], DBL_EPSILON );
    CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 6.0 ), hess[1], DBL_EPSILON );
    CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( 9.0 ), hess[2], DBL_EPSILON );
Member Data Documentation
Definition at line 65 of file QualityMetricTest.cpp.
List of all members.
