QualityMetricTester Class Reference
#include <QualityMetricTester.hpp>
+ Collaboration diagram for QualityMetricTester:
Classes
class  PatchXform
Public Types
enum  ElemTypeGroup {
  SIMPLICIES, NON_MIXED_FE, TWO_D, TWO_D_FE,
  THREE_D, THREE_D_FE, THREE_D_NON_MIXED_FE, THREE_D_FE_EXCEPT_SEPTAHEDRON,
  ALL_FE_EXCEPT_SEPTAHEDRON, ALL_FE, ALL
Public Member Functions
void get_ideal_tris (PatchData &pd, bool unit_area)
void get_ideal_quads (PatchData &pd)
void get_ideal_hexes (PatchData &pd)
void get_ideal_element (EntityTopology type, bool unit_area, PatchData &pd, bool first_vertex_fixed=false)
void get_ideal_element (EntityTopology type, bool unit_area, PatchData &pd, int free_vertex_index)
void get_nonideal_element (EntityTopology type, PatchData &pd, bool first_vertex_fixed=false)
void get_nonideal_element (EntityTopology type, PatchData &pd, int free_vertex_index)
void get_degenerate_element (EntityTopology type, PatchData &pd)
void get_zero_element (EntityTopology type, PatchData &pd)
void get_inverted_element (EntityTopology type, PatchData &pd)
 QualityMetricTester (ElemTypeGroup group, const Settings *set=0)
 QualityMetricTester (const EntityTopology *supported_elem_types, size_t supported_elem_types_len, const Settings *set=0)
void ideal_pyramid_base_equals_height (bool flag)
void test_supported_element_types (QualityMetric *qm)
void test_measures_quality (QualityMetric *qm)
void test_measures_vertex_quality (QualityMetric *qm)
void test_domain_deviation_quality (QualityMetric *qm)
void test_gradient_reflects_quality (QualityMetric *qm)
void test_vertex_gradient_reflects_quality (QualityMetric *qm)
void test_domain_deviation_gradient (QualityMetric *qm)
void test_evaluate_unit_element (QualityMetric *qm, EntityTopology type, double value)
void test_evaluate_unit_edge_element (QualityMetric *qm, EntityTopology type, double value)
void test_evaluate_unit_tris_about_vertex (QualityMetric *qm, double expected_val)
void test_evaluate_unit_quads_about_vertex (QualityMetric *qm, double expected_val)
void test_evaluate_unit_hexes_about_vertex (QualityMetric *qm, double expected_val)
void test_evaluate_unit_edge_tris_about_vertex (QualityMetric *qm, double expected_val)
void test_evaluate_inverted_element (QualityMetric *qm, bool should_succeed)
void test_evaluate_degenerate_element (QualityMetric *qm, bool should_succeed)
void test_evaluate_zero_element (QualityMetric *qm, bool should_succeed)
void test_get_element_evaluations (QualityMetric *qm)
void test_get_vertex_evaluations (QualityMetric *qm)
void test_get_sample_evaluations (QualityMetric *qm)
void test_get_edge_evaluations (EdgeQM *qm)
void test_get_in_element_evaluations (ElemSampleQM *qm)
void test_get_indices_fixed (QualityMetric *qm)
void test_get_element_indices (QualityMetric *qm)
void test_get_vertex_indices (QualityMetric *qm)
void test_get_edge_indices (EdgeQM *qm)
void test_get_sample_indices (QualityMetric *qm)
void compare_eval_and_eval_with_indices (QualityMetric *qm)
void compare_eval_and_eval_with_indices (QualityMetric *qm, PatchData &pd)
void compare_eval_with_indices_and_eval_with_gradient (QualityMetric *qm)
void compare_eval_with_indices_and_eval_with_gradient (QualityMetric *qm, PatchData &pd)
void compare_eval_with_indices_and_eval_with_hessian (QualityMetric *qm)
void compare_eval_with_indices_and_eval_with_hessian (QualityMetric *qm, PatchData &pd)
void compare_eval_with_indices_and_eval_with_diagonal (QualityMetric *qm)
void compare_eval_with_indices_and_eval_with_diagonal (QualityMetric *qm, PatchData &pd)
void compare_eval_with_grad_and_eval_with_hessian (QualityMetric *qm)
void compare_eval_with_grad_and_eval_with_hessian (QualityMetric *qm, PatchData &pd)
void compare_eval_with_grad_and_eval_with_diagonal (QualityMetric *qm)
void compare_eval_with_grad_and_eval_with_diagonal (QualityMetric *qm, PatchData &pd)
void compare_eval_with_diag_and_eval_with_hessian (QualityMetric *qm)
void compare_eval_with_diag_and_eval_with_hessian (QualityMetric *qm, PatchData &pd)
void compare_analytical_and_numerical_gradients (QualityMetric *qm)
void compare_analytical_and_numerical_gradients (QualityMetric *qm, PatchData &pd)
void compare_analytical_and_numerical_hessians (QualityMetric *qm)
void compare_analytical_and_numerical_hessians (QualityMetric *qm, PatchData &pd)
void compare_analytical_and_numerical_diagonals (QualityMetric *qm)
void compare_analytical_and_numerical_diagonals (QualityMetric *qm, PatchData &pd)
void test_gradient_with_fixed_vertex (QualityMetric *qm, const Settings *settings=0)
void test_gradient_with_fixed_vertex (EntityTopology type, QualityMetric *qm, const Settings *settings=0)
void test_hessian_with_fixed_vertex (QualityMetric *qm, const Settings *settings=0)
void test_hessian_with_fixed_vertex (EntityTopology type, QualityMetric *qm, const Settings *settings=0)
void test_diagonal_with_fixed_vertex (QualityMetric *qm, const Settings *settings=0)
void test_diagonal_with_fixed_vertex (EntityTopology type, QualityMetric *qm, const Settings *settings=0)
void test_ideal_element_zero_gradient (QualityMetric *qm, bool unit_area)
void test_ideal_element_zero_vertex_gradient (QualityMetric *qm, bool unit_area)
void test_ideal_element_positive_definite_Hessian (QualityMetric *qm, bool unit_area)
void test_symmetric_Hessian_diagonal_blocks (QualityMetric *qm)
void test_location_invariant (QualityMetric *qm, bool untangler=false)
void test_scale_invariant (QualityMetric *qm, bool untangler=false)
void test_orient_invariant (QualityMetric *qm, bool untangler=false)
void test_grad_location_invariant (QualityMetric *qm, bool untangler=false)
void test_grad_orient_invariant (QualityMetric *qm, bool untangler=false)
void test_hessian_location_invariant (QualityMetric *qm, bool untangler=false)
void test_measures_size (QualityMetric *qm, bool unit_area)
void test_measures_in_plane_orientation (QualityMetric *qm)
void test_measures_out_of_plane_orientation (QualityMetric *qm)
void test_transform_invariant (QualityMetric *qm, PatchXform &transform, bool untangler)
void test_grad_transform_invariant (QualityMetric *qm, PatchXform &transform, bool untangler)
void test_hessian_transform_invariant (QualityMetric *qm, PatchXform &transform, bool untangler)
void test_measures_transform (QualityMetric *qm, PatchXform &transform, bool unit_area)
Private Member Functions
bool type_is_supported (EntityTopology type)
void test_type_is_supported (EntityTopology type, QualityMetric *qm)
void test_type_is_not_supported (EntityTopology type, QualityMetric *qm)
Private Attributes
bool degenHexPyramid
 See: ideal_pyramid_base_equals_height()
std::vector< EntityTopologytypes
const SettingsmSettings
PlanarDomain geomPlane
Detailed Description
Definition at line 45 of file QualityMetricTester.hpp.
Member Enumeration Documentation
Enumerator:
SIMPLICIES
NON_MIXED_FE
TWO_D
TWO_D_FE
THREE_D
THREE_D_FE
ALL_FE
ALL
Definition at line 59 of file QualityMetricTester.hpp.
        SIMPLICIES,                     // triangle and tetrahedron
        NON_MIXED_FE,                   // tri, quad, tet, hex
        TWO_D,                          // tri, quad, polygon
        TWO_D_FE,                       // tri, quad
        THREE_D,                        // tet, hex, pyr, wedge, septahedron, polyhedron
        THREE_D_FE,                     // tet, hex, pyr, wedge, septahedron
        THREE_D_NON_MIXED_FE,           // tet, hex,
        THREE_D_FE_EXCEPT_SEPTAHEDRON,  // tet, hex, pyr, wedge
        ALL_FE_EXCEPT_SEPTAHEDRON,      // tri, quad, tet, hex, pyr, wedge
        ALL_FE,                         // everything except polygon and polyhedron
        ALL
    };  // everything (including polyhedron)
Definition at line 92 of file QualityMetricTester.cpp.
    : degenHexPyramid( false ), types( types_in_group( group ) ), mSettings( settings ),
      geomPlane( Vector3D( 0, 0, 1 ), Vector3D( 0, 0, 0 ) )
QualityMetricTester::QualityMetricTester ( const EntityTopology supported_elem_types,
const Settings set = 0
Definition at line 83 of file QualityMetricTester.cpp.
References types.
    : degenHexPyramid( false ), types( len ), mSettings( settings ),
    std::copy( supported_elem_types, supported_elem_types + len, types.begin() );
Member Function Documentation
compare analytical and numerical Hessian diagonal results
Definition at line 1428 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, get_nonideal_element(), mSettings, and types.
    PatchData pd;
    if( mSettings ) pd.attach_settings( mSettings );
    MsqError err;
    CPPUNIT_ASSERT( !types.empty() );
    for( size_t i = 0; i < types.size(); ++i )
        get_nonideal_element( types[i], pd, true );
        compare_analytical_and_numerical_diagonals( qm, pd );
Definition at line 1385 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::QualityMetric::get_evaluations(), and MSQ_CHKERR.
    MsqPrintError err( std::cout );
    std::vector< size_t > handles, indices1, indices2;
    std::vector< Vector3D > grad1, grad2;
    std::vector< Matrix3D > Hess1;
    std::vector< SymMatrix3D > Hess2;
    double qm_val1, qm_val2;
    bool rval;
    qm->get_evaluations( pd, handles, false, err );
    CPPUNIT_ASSERT( !MSQ_CHKERR( err ) );
    CPPUNIT_ASSERT( !handles.empty() );
    for( size_t j = 0; j < handles.size(); ++j )
        rval = qm->QualityMetric::evaluate_with_Hessian( pd, handles[j], qm_val1, indices1, grad1, Hess1, err );
        CPPUNIT_ASSERT( rval );
        rval = qm->evaluate_with_Hessian_diagonal( pd, handles[j], qm_val2, indices2, grad2, Hess2, err );
        CPPUNIT_ASSERT_DOUBLES_EQUAL( qm_val1, qm_val2, 1e-6 );
        CPPUNIT_ASSERT_EQUAL( indices1.size(), indices2.size() );
        CPPUNIT_ASSERT( !indices1.empty() );
        CPPUNIT_ASSERT_EQUAL( indices1.size() * ( indices1.size() + 1 ) / 2, Hess1.size() );
        CPPUNIT_ASSERT_EQUAL( indices2.size(), Hess2.size() );
        size_t h = 0;
        std::vector< size_t >::iterator it;
        for( unsigned r = 0; r < indices1.size(); ++r )
            it = std::find( indices2.begin(), indices2.end(), indices1[r] );
            CPPUNIT_ASSERT( it != indices2.end() );
            unsigned r2 = it - indices2.begin();
            // if (!utest_mat_equal(Hess1[h],Hess2[r2],0.001))
            //  assert(false);
            CPPUNIT_ASSERT_MATRICES_EQUAL( Hess1[h], Hess2[r2], 0.001 );
            h += indices1.size() - r;
compare analytical and numerical gradient results
Definition at line 1306 of file QualityMetricTester.cpp.
    PatchData pd;
        compare_analytical_and_numerical_gradients( qm, pd );
Definition at line 1269 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::get_evaluations(), and MSQ_CHKERR.
    bool rval;
        rval = qm->QualityMetric::evaluate_with_gradient( pd, handles[j], qm_val1, indices1, grad1, err );
        rval = qm->evaluate_with_gradient( pd, handles[j], qm_val2, indices2, grad2, err );
        std::vector< size_t >::iterator it1, it2;
        for( it1 = indices1.begin(); it1 != indices1.end(); ++it1 )
            it2 = std::find( indices2.begin(), indices2.end(), *it1 );
            CPPUNIT_ASSERT( it2 != indices2.end() );
            size_t idx1 = it1 - indices1.begin();
            size_t idx2 = it2 - indices2.begin();
            CPPUNIT_ASSERT_VECTORS_EQUAL( grad1[idx1], grad2[idx2], 0.01 );
compare analytical and numerical Hessian results
Definition at line 1372 of file QualityMetricTester.cpp.
    PatchData pd;
        compare_analytical_and_numerical_hessians( qm, pd );
Definition at line 1319 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::get_evaluations(), and MSQ_CHKERR.
    std::vector< Matrix3D > Hess1, Hess2;
    bool rval;
        rval = qm->evaluate_with_Hessian( pd, handles[j], qm_val2, indices2, grad2, Hess2, err );
        unsigned h = 0;
            for( unsigned c = r; c < indices1.size(); ++c, ++h )
                it = std::find( indices2.begin(), indices2.end(), indices1[c] );
                unsigned c2 = it - indices2.begin();
                unsigned h2;
                if( r2 <= c2 )
                    h2 = indices2.size() * r - r * ( r + 1 ) / 2 + c;
                else
                    h2 = indices2.size() * c - c * ( c + 1 ) / 2 + r;
                // if (!utest_mat_equal(Hess1[h],Hess2[h2],0.001))
                //  assert(false);
                CPPUNIT_ASSERT_MATRICES_EQUAL( Hess1[h], Hess2[h2], 0.001 );
compare results of evaluate() and evaluate_with_indices() methods
Definition at line 959 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::QualityMetric::evaluate(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), mSettings, MSQ_CHKERR, and types.
    PatchData pd;
    std::vector< size_t > handles, indices;
    bool rval;
        get_ideal_element( types[i], false, pd );
            rval = qm->evaluate( pd, handles[j], qm_val1, err );
            rval = qm->evaluate_with_indices( pd, handles[j], qm_val2, indices, err );
compare results of evaluate_with_Hessian_diagonal() and evaluate_with_Hessian() methods
Definition at line 1256 of file QualityMetricTester.cpp.
Referenced by TQualityMetricTest::test_inverse_mean_ratio_hess_diag().
    PatchData pd;
        compare_eval_with_diag_and_eval_with_hessian( qm, pd );
Definition at line 1214 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::QualityMetric::get_evaluations(), and MSQ_CHKERR.
    std::vector< SymMatrix3D > hess1;
    std::vector< Matrix3D > hess2;
    bool rval;
        rval = qm->evaluate_with_Hessian_diagonal( pd, handles[j], qm_val1, indices1, grad1, hess1, err );
        rval = qm->evaluate_with_Hessian( pd, handles[j], qm_val2, indices2, grad2, hess2, err );
        CPPUNIT_ASSERT_EQUAL( grad1.size(), grad2.size() );
        CPPUNIT_ASSERT_EQUAL( hess2.size(), hess1.size() * ( hess1.size() + 1 ) / 2 );
        unsigned h2step                             = indices2.size();
        std::vector< Matrix3D >::const_iterator h2i = hess2.begin();
        for( size_t k = 0; k < indices2.size(); ++k )
            std::vector< size_t >::iterator it = std::find( indices1.begin(), indices1.end(), indices2[k] );
            CPPUNIT_ASSERT( it != indices1.end() );
            size_t m = it - indices1.begin();
            CPPUNIT_ASSERT_VECTORS_EQUAL( grad1[m], grad2[k], 5e-5 );
            CPPUNIT_ASSERT_MATRICES_EQUAL( Matrix3D( hess1[m] ), *h2i, 5e-5 );
            h2i += h2step--;
compare results of evaluate_with_gradient() and evaluate_with_Hessian_diagonal() methods
Definition at line 1201 of file QualityMetricTester.cpp.
    PatchData pd;
        compare_eval_with_grad_and_eval_with_diagonal( qm, pd );
Definition at line 1167 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::QualityMetric::get_evaluations(), and MSQ_CHKERR.
    std::vector< SymMatrix3D > Hess;
    bool rval;
        rval = qm->evaluate_with_gradient( pd, handles[j], qm_val1, indices1, grad1, err );
        rval = qm->evaluate_with_Hessian_diagonal( pd, handles[j], qm_val2, indices2, grad2, Hess, err );
        for( size_t k = 0; k < indices1.size(); ++k )
            std::vector< size_t >::iterator it = std::find( indices2.begin(), indices2.end(), indices1[k] );
            size_t m = it - indices2.begin();
            CPPUNIT_ASSERT_VECTORS_EQUAL( grad1[k], grad2[m], 1e-6 );
compare results of evaluate_with_gradient() and evaluate_with_Hessian() methods
Definition at line 1154 of file QualityMetricTester.cpp.
    PatchData pd;
        compare_eval_with_grad_and_eval_with_hessian( qm, pd );
Definition at line 1120 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::get_evaluations(), and MSQ_CHKERR.
    std::vector< Matrix3D > Hess;
    bool rval;
        rval = qm->evaluate_with_Hessian( pd, handles[j], qm_val2, indices2, grad2, Hess, err );
compare results of evaluate_with_indices() and evaluate_with_Hessian_diagonal() methods
Definition at line 1107 of file QualityMetricTester.cpp.
    PatchData pd;
        compare_eval_with_indices_and_eval_with_diagonal( qm, pd );
Definition at line 1076 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), MBMesquite::grad(), and MSQ_CHKERR.
    std::vector< Vector3D > grad;
    bool rval;
        rval = qm->evaluate_with_indices( pd, handles[j], qm_val1, indices1, err );
        rval = qm->evaluate_with_Hessian_diagonal( pd, handles[j], qm_val2, indices2, grad, Hess, err );
        std::sort( indices1.begin(), indices1.end() );
        std::sort( indices2.begin(), indices2.end() );
        CPPUNIT_ASSERT( indices1 == indices2 );
compare results of evaluate_with_indices() and evaluate_with_gradient() methods
Definition at line 1019 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, get_ideal_element(), mSettings, and types.
    PatchData pd;
        get_ideal_element( types[i], false, pd, true );
        compare_eval_with_indices_and_eval_with_gradient( qm, pd );
Definition at line 989 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), MBMesquite::grad(), and MSQ_CHKERR.
    bool rval;
        rval = qm->evaluate_with_gradient( pd, handles[j], qm_val2, indices2, grad, err );
compare results of evaluate_with_indices() and evaluate_with_Hessian() methods
Definition at line 1063 of file QualityMetricTester.cpp.
    PatchData pd;
        compare_eval_with_indices_and_eval_with_hessian( qm, pd );
Definition at line 1032 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), MBMesquite::grad(), and MSQ_CHKERR.
    bool rval;
        rval = qm->evaluate_with_Hessian( pd, handles[j], qm_val2, indices2, grad, Hess, err );
Collapse first and second vertices of an ideal element
Definition at line 245 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::element_by_index(), get_ideal_element(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), and MBMesquite::PatchData::set_vertex_coordinates().
Referenced by test_evaluate_degenerate_element().
    MsqError err;
    get_ideal_element( type, false, pd );
    const size_t* verts     = pd.element_by_index( 0 ).get_vertex_index_array();
    const MsqVertex* coords = pd.get_vertex_array( err );
    pd.set_vertex_coordinates( coords[verts[1]], verts[0], err );
void QualityMetricTester::get_ideal_element ( EntityTopology  type,
bool  unit_area,
PatchData pd,
Definition at line 182 of file QualityMetricTester.cpp.
References MBMesquite::arrptr(), conn, corners, CPPUNIT_ASSERT, degenHexPyramid, MBMesquite::PatchData::fill(), fixed, geomPlane, MSQ_CHKERR, n, MBMesquite::PatchData::set_domain(), MBMesquite::unit_edge_element(), and MBMesquite::unit_element().
    if( TopologyInfo::dimension( type ) == 2 ) pd.set_domain( &geomPlane );
    const size_t n = TopologyInfo::corners( type );
    const Vector3D* coords =
        unit_area ? unit_element( type, degenHexPyramid ) : unit_edge_element( type, degenHexPyramid );
    CPPUNIT_ASSERT( coords != 0 );
    CPPUNIT_ASSERT( sizeof( double ) * 3 == sizeof( Vector3D ) );
    const double* elem_verts = reinterpret_cast< const double* >( coords );
    bool* fixed = new bool[n];
    std::vector< size_t > conn( n );
    for( size_t i = 0; i < n; ++i )
        conn[i]  = i;
        fixed[i] = ( free_vertex_index >= 0 );
    if( free_vertex_index == -2 )
        fixed[0] = true;
    else if( free_vertex_index >= 0 )
        fixed[free_vertex_index] = false;
    pd.fill( n, elem_verts, 1, type, arrptr( conn ), fixed, err );
    delete[] fixed;
Definition at line 155 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, MBMesquite::PatchData::fill(), fixed, MBMesquite::HEXAHEDRON, and MSQ_CHKERR.
Referenced by test_evaluate_unit_hexes_about_vertex(), test_get_element_evaluations(), test_get_sample_evaluations(), test_get_vertex_evaluations(), test_ideal_element_zero_vertex_gradient(), test_measures_vertex_quality(), and test_vertex_gradient_reflects_quality().
    static const double ideal_hex_verts[] = { 0.0,  0.0,  0.0,  -1.0, 0.0,  0.0,  -1.0, -1.0, 0.0,  0.0,  -1.0, 0.0,
                                              1.0,  -1.0, 0.0,  1.0,  0.0,  0.0,  1.0,  1.0,  0.0,  0.0,  1.0,  0.0,
                                              -1.0, 1.0,  0.0,  0.0,  0.0,  -1.0, -1.0, 0.0,  -1.0, -1.0, -1.0, -1.0,
                                              0.0,  -1.0, -1.0, 1.0,  -1.0, -1.0, 1.0,  0.0,  -1.0, 1.0,  1.0,  -1.0,
                                              0.0,  1.0,  -1.0, -1.0, 1.0,  -1.0, 0.0,  0.0,  1.0,  -1.0, 0.0,  1.0,
                                              -1.0, -1.0, 1.0,  0.0,  -1.0, 1.0,  1.0,  -1.0, 1.0,  1.0,  0.0,  1.0,
                                              1.0,  1.0,  1.0,  0.0,  1.0,  1.0,  -1.0, 1.0,  1.0 };
    static const size_t ideal_hex_elems[] = { 9, 10, 11, 12, 0,  1,  2,  3,  9, 12, 13, 14, 0,  3,  4,  5,
                                              9, 14, 15, 16, 0,  5,  6,  7,  9, 16, 17, 10, 0,  7,  8,  1,
                                              0, 1,  2,  3,  18, 19, 20, 21, 0, 3,  4,  5,  18, 21, 22, 23,
                                              0, 5,  6,  7,  18, 23, 24, 25, 0, 7,  8,  1,  18, 25, 26, 19 };
    bool fixed[27];
    fixed[0] = false;
    for( size_t f = 1; f < 27; ++f )
        fixed[f] = true;
    pd.fill( 27, ideal_hex_verts, 8, HEXAHEDRON, ideal_hex_elems, fixed, err );
Definition at line 129 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, MBMesquite::PatchData::fill(), fixed, geomPlane, MSQ_CHKERR, MBMesquite::QUADRILATERAL, and MBMesquite::PatchData::set_domain().
Referenced by test_domain_deviation_gradient(), test_domain_deviation_quality(), test_evaluate_unit_quads_about_vertex(), test_get_element_evaluations(), test_get_sample_evaluations(), test_get_vertex_evaluations(), test_ideal_element_zero_vertex_gradient(), test_measures_vertex_quality(), and test_vertex_gradient_reflects_quality().
    //            7
    //   8 +------+------+ 6
    //     |      |0     |
    //   1 +------+------+ 5
    //   2 +------+------+ 4
    //            3
    static const double ideal_quad_verts[] = { 0.0, 0.0,  0.0, -1.0, 0.0,  0.0, -1.0, -1.0, 0.0,
                                               0.0, -1.0, 0.0, 1.0,  -1.0, 0.0, 1.0,  0.0,  0.0,
                                               1.0, 1.0,  0.0, 0.0,  1.0,  0.0, -1.0, 1.0,  0.0 };
    static const size_t ideal_quad_elems[] = { 0, 1, 2, 3, 0, 3, 4, 5, 0, 5, 6, 7, 0, 7, 8, 1 };
    const bool fixed[]                     = { false, true, true, true, true, true, true, true, true };
    pd.fill( 9, ideal_quad_verts, 4, QUADRILATERAL, ideal_quad_elems, fixed, err );
void QualityMetricTester::get_ideal_tris ( PatchData pd,
bool  unit_area
Definition at line 98 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, MBMesquite::PatchData::fill(), fixed, geomPlane, MSQ_CHKERR, MBMesquite::MSQ_SQRT_THREE_DIV_TWO, MBMesquite::PatchData::set_domain(), and MBMesquite::TRIANGLE.
Referenced by test_domain_deviation_gradient(), test_domain_deviation_quality(), test_evaluate_unit_edge_tris_about_vertex(), test_evaluate_unit_tris_about_vertex(), test_get_element_evaluations(), test_get_sample_evaluations(), test_get_vertex_evaluations(), test_ideal_element_zero_vertex_gradient(), test_measures_vertex_quality(), and test_vertex_gradient_reflects_quality().
    //      6 ------- 5     .
    //  1 <------X------> 4 .
    //     \    /0\    /    .
    //      2 ------- 3     .
    static const double y3         = MSQ_SQRT_THREE_DIV_TWO;
    double ideal_tri_verts[]       = { 0.0, 0.0, 0.0, -1.0, 0.0, 0.0, -0.5, -y3,  0.0, 0.5, -y3,
                                 0.0, 1.0, 0.0, 0.0,  0.5, y3,  0.0,  -0.5, y3,  0.0 };
    const size_t ideal_tri_elems[] = { 0, 1, 2, 0, 2, 3, 0, 4, 5, 0, 4, 5, 0, 5, 6, 0, 6, 1 };
    const bool fixed[]             = { false, true, true, true, true, true, true };
    if( unit_area )
        const double unit_tri_scale = 2.0 / std::sqrt( 6.0 );
        for( size_t i = 0; i < sizeof( ideal_tri_verts ) / sizeof( double ); ++i )
            ideal_tri_verts[i] *= unit_tri_scale;
    pd.fill( 7, ideal_tri_verts, 6, TRIANGLE, ideal_tri_elems, fixed, err );
Create inverted elements. For tri and tet elements, reflect one vertex about the opposite side. For all other elements, introduce a concave vertex in one of the quadrilateral faces.
Definition at line 307 of file QualityMetricTester.cpp.
References MBMesquite::MsqMeshEntity::check_element_orientation(), CPPUNIT_ASSERT, MBMesquite::PatchData::domain_set(), MBMesquite::PatchData::element_by_index(), get_ideal_element(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::HEXAHEDRON, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::PatchData::set_vertex_coordinates(), moab::sum(), MBMesquite::TETRAHEDRON, and MBMesquite::TRIANGLE.
Referenced by test_evaluate_inverted_element(), test_grad_transform_invariant(), test_hessian_transform_invariant(), and test_transform_invariant().
    MsqError err;
    MsqMeshEntity& elem     = pd.element_by_index( 0 );
    const size_t* verts     = elem.get_vertex_index_array();
    unsigned i;
    Vector3D sum( 0, 0, 0 );
    //  switch (type) {
    //    case TRIANGLE:
    //      coords[verts[2]] = coords[verts[0]] + coords[verts[1]] - coords[verts[2]];
    //      break;
    //    case QUADRILATERAL:
    //    case PYRAMID:
    //    case HEXAHEDRON:
    //      coords[verts[2]] += 0.75 * (coords[verts[0]] - coords[verts[2]]);
    //      break;
    //    case TETRAHEDRON:
    //      for (i = 0; i < 3; ++i)
    //        sum += coords[verts[i]];
    //      coords[verts[3]] += 0.5*sum - 1.5*coords[verts[3]];
    //      break;
    //    case PRISM:
    //      coords[verts[4]] += 0.75 * (coords[verts[0]] - coords[verts[4]]);
    //      break;
    //    default:
    //      CPPUNIT_ASSERT(false);
    //      break;
    if( type == TRIANGLE )
        pd.set_vertex_coordinates( coords[verts[0]] + coords[verts[1]] - coords[verts[2]], verts[2], err );
    else if( type == QUADRILATERAL || type == PYRAMID || type == HEXAHEDRON )
        pd.set_vertex_coordinates( 0.75 * ( coords[verts[0]] - coords[verts[2]] ), verts[2], err );
    else if( type == TETRAHEDRON )
        for( i = 0; i < 3; ++i )
        pd.set_vertex_coordinates( 0.5 * sum - 1.5 * coords[verts[3]], verts[3], err );
    else if( type == PRISM )
        pd.set_vertex_coordinates( 0.75 * ( coords[verts[0]] - coords[verts[4]] ), verts[4], err );
    else
        CPPUNIT_ASSERT( false );
    if( TopologyInfo::dimension( type ) == 3 || pd.domain_set() )
        int inverted, total;
        elem.check_element_orientation( pd, inverted, total, err );
        CPPUNIT_ASSERT( !err );
        CPPUNIT_ASSERT( total );
void QualityMetricTester::get_nonideal_element ( EntityTopology  type,
PatchData pd,
int  free_vtx_type
Begin with an ideal element, and move the first vertex one half of the distnace to the centroid
Definition at line 221 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::element_by_index(), get_ideal_element(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), n, MBMesquite::PatchData::set_vertex_coordinates(), moab::sum(), and MBMesquite::MsqMeshEntity::vertex_count().
    MsqError err;
    get_ideal_element( type, false, pd, free_vtx_type );
    size_t n                = pd.element_by_index( 0 ).vertex_count();
    for( unsigned i = 0; i < n; ++i )
    sum /= n;
    sum += coords[verts[0]];
    sum *= 0.5;
    pd.set_vertex_coordinates( sum, verts[0], err );
Create element with zero area/volume For quads and hexes, the results are also inverted elements.
Definition at line 257 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, MBMesquite::PatchData::element_by_index(), get_ideal_element(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::HEXAHEDRON, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::PatchData::set_vertex_coordinates(), moab::sum(), MBMesquite::TETRAHEDRON, and MBMesquite::TRIANGLE.
Referenced by test_evaluate_zero_element().
    MsqError err;
    unsigned i;
    switch( type )
        case TRIANGLE:
            pd.set_vertex_coordinates( 0.5 * ( coords[verts[0]] + coords[verts[1]] ), verts[2], err );
            break;
        case QUADRILATERAL:
            pd.set_vertex_coordinates( coords[verts[0]], verts[1], err );
            pd.set_vertex_coordinates( coords[verts[3]], verts[2], err );
            break;
        case TETRAHEDRON:
            pd.set_vertex_coordinates( sum / 3.0, verts[3], err );
            break;
        case PYRAMID:
            for( i = 0; i < 4; ++i )
            pd.set_vertex_coordinates( 0.25 * sum, verts[4], err );
            break;
        case PRISM:
            pd.set_vertex_coordinates( 0.5 * ( coords[verts[3]] + coords[verts[4]] ), verts[5], err );
            break;
        case HEXAHEDRON:
            pd.set_vertex_coordinates( coords[verts[0]], verts[4], err );
            pd.set_vertex_coordinates( coords[verts[1]], verts[5], err );
            pd.set_vertex_coordinates( coords[verts[2]], verts[6], err );
            pd.set_vertex_coordinates( coords[verts[3]], verts[7], err );
            break;
        default:
            break;
Ideal pyramids should be considerd to have a heigth equal to the length of a side, rather than the default which is equilateral triangle faces.
Definition at line 84 of file QualityMetricTester.hpp.
        degenHexPyramid = flag;
compare Hessian diagonal w/ no fixed vertices to Hessian for element with all but one vertex fixed.
Definition at line 2496 of file QualityMetricTester.cpp.
References CPPUNIT_ASSERT, and types.
    for( unsigned i = 0; i < types.size(); ++i )
        test_diagonal_with_fixed_vertex( types[i], qm, settings );
Definition at line 2617 of file QualityMetricTester.cpp.
References ASSERT_NO_ERROR, MBMesquite::PatchData::attach_settings(), conn, corners, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::evaluate_with_Hessian_diagonal(), MBMesquite::QualityMetric::get_evaluations(), get_nonideal_element(), MBMesquite::MsqMeshEntity::get_vertex_indices(), MBMesquite::grad(), MBMesquite::hess(), mSettings, and n.
    PatchData pd;
    if( settings )
        pd.attach_settings( settings );
    else if( mSettings )
    std::vector< size_t > handles, indices, indices_fixed, conn;
    std::vector< Vector3D > grad, grad_fixed;
    std::vector< SymMatrix3D > hess, hess_fixed;
    double val, val_fixed;
    bool rval;
    const int n = TopologyInfo::corners( type );
    get_nonideal_element( type, pd );
    pd.element_by_index( 0 ).get_vertex_indices( conn );
    ASSERT_NO_ERROR( err );
    // For sample-based metrics, it is difficult to set up such that
    // both surface and volume elements have only one sample point.
    // Make things easier by skipping element types with no sample points.
    if( handles.empty() ) return;
    CPPUNIT_ASSERT_EQUAL_MESSAGE( "test only valid for element-based metrics", (size_t)1, handles.size() );
    size_t h = handles[0];
    rval = qm->evaluate_with_Hessian_diagonal( pd, h, val, indices, grad, hess, err );
    CPPUNIT_ASSERT_EQUAL( (size_t)n, indices.size() );
    CPPUNIT_ASSERT_EQUAL( (size_t)n, grad.size() );
    CPPUNIT_ASSERT_EQUAL( (size_t)n, hess.size() );
    for( int i = 0; i < n; ++i )
        get_nonideal_element( type, pd, i );
        h = handles[0];
        rval = qm->evaluate_with_Hessian_diagonal( pd, h, val_fixed, indices_fixed, grad_fixed, hess_fixed, err );
        CPPUNIT_ASSERT_EQUAL( (size_t)1, indices_fixed.size() );
        CPPUNIT_ASSERT_EQUAL( (size_t)1, grad_fixed.size() );
        CPPUNIT_ASSERT_EQUAL( (size_t)1, hess_fixed.size() );
        const size_t j = conn[i];
        CPPUNIT_ASSERT_DOUBLES_EQUAL( val, val_fixed, 1e-5 );
        CPPUNIT_ASSERT_VECTORS_EQUAL( grad[j], grad_fixed.front(), 1e-5 );
        CPPUNIT_ASSERT_MATRICES_EQUAL( hess[j], hess_fixed.front(), 1e-4 );
Test gradient reflects deviation from domain
Definition at line 2022 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_quads(), get_ideal_tris(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::grad(), MBMesquite::PatchData::move_vertex(), mSettings, MSQ_CHKERR, MBMesquite::QUADRILATERAL, MBMesquite::TRIANGLE, and type_is_supported().
    PatchData pd;
    size_t i;
    double qmval;
    bool rval;
    CPPUNIT_ASSERT( type_is_supported( TRIANGLE ) || type_is_supported( QUADRILATERAL ) );
    if( type_is_supported( TRIANGLE ) )
        // get a patch
        get_ideal_tris( pd, false );
        // move the free vertex out of the plane
        pd.move_vertex( Vector3D( 0, 0, 0.2 ), 0, err );
        // find an evaluation that depends on the free vertex
        for( i = 0; i < handles.size(); ++i )
            rval = qm->evaluate_with_gradient( pd, handles[i], qmval, indices, grad, err );
            if( !grad.empty() ) break;
        CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() );   // one free vertex in patch
        CPPUNIT_ASSERT_EQUAL( (size_t)0, indices.front() );  // one free vertex in patch
        CPPUNIT_ASSERT_EQUAL( (size_t)1, grad.size() );
        Vector3D v = qm->get_negate_flag() * Vector3D( 0, 0, 1 );
        CPPUNIT_ASSERT( v % grad[0] > DBL_EPSILON );
    if( type_is_supported( QUADRILATERAL ) )
        // get a patch
        get_ideal_quads( pd );
Test measures deviation from domain
Definition at line 1929 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_quads(), get_ideal_tris(), MBMesquite::QualityMetric::get_negate_flag(), mSettings, MSQ_CHKERR, MBMesquite::PatchData::num_nodes(), MBMesquite::QUADRILATERAL, MBMesquite::PatchData::set_vertex_coordinates(), MBMesquite::TRIANGLE, type_is_supported(), and MBMesquite::PatchData::vertex_by_index().
    PatchData pd;
    size_t i;
    double qmval1, qmval2;
    bool rval;
    bool decreasing = false;
    if( qm->get_negate_flag() != 1 )
        CPPUNIT_ASSERT_EQUAL( qm->get_negate_flag(), -1 );
        decreasing = true;
        // get a patch
            rval = qm->evaluate_with_indices( pd, handles[i], qmval1, indices, err );
            if( !indices.empty() ) break;
        const size_t handle = handles[i];
        // rotate patch about origin such that elements are no longer in the plane
        const Matrix3D rot( M_PI / 4.0, Vector3D( 1, 1, 0 ) );
        for( i = 0; i < pd.num_nodes(); ++i )
            pd.set_vertex_coordinates( rot * pd.vertex_by_index( i ), i, err );
        // evaluate for rotated patch
        rval = qm->evaluate( pd, handle, qmval2, err );
        // check quality
        if( decreasing )
            CPPUNIT_ASSERT( qmval1 > qmval2 );
        else
            CPPUNIT_ASSERT( qmval1 < qmval2 );
        // get a patch
        const Matrix3D rot( M_PI / 3.0, Vector3D( 1, 0, 0 ) );
        // check quality
        if( decreasing )
        else
void QualityMetricTester::test_evaluate_degenerate_element ( QualityMetric qm,
bool  should_succeed
Test that evaluation of the metric for degenerate element does not pass back an error condition, and that the returned boolean feasible value is the specified value
Definition at line 1853 of file QualityMetricTester.cpp.
References get_degenerate_element(), mSettings, test_bad_element(), and types.
void QualityMetricTester::test_evaluate_inverted_element ( QualityMetric qm,
bool  should_succeed
Test that evaluation of the metric for an inverted element does not pass back an error condition, and that the returned boolean feasible value is the specified value
Definition at line 1849 of file QualityMetricTester.cpp.
References get_inverted_element(), mSettings, test_bad_element(), and types.
Test evaluation of a single ideal element with unit edge length
Definition at line 471 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), get_ideal_element(), mSettings, and test_evaluate().
    PatchData pd;
    test_evaluate( pd, qm, value );
Test evaluation of metric over patch with one free vertex surrounded by 6 ideal unit-edge-length tris
Definition at line 503 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), get_ideal_tris(), mSettings, and test_evaluate().
    PatchData pd;
Test evaluation of a single ideal element with unit area/volume
Definition at line 463 of file QualityMetricTester.cpp.
    PatchData pd;
    get_ideal_element( type, true, pd );
Test evaluation of metric over patch with one free vertex surrounded by 8 unit-volume hexes
Definition at line 495 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), get_ideal_hexes(), mSettings, and test_evaluate().
Test evaluation of metric over patch with one free vertex surrounded by 4 unit-area quads
Definition at line 487 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), get_ideal_quads(), mSettings, and test_evaluate().
Test evaluation of metric over patch with one free vertex surrounded by 6 ideal unit-area tris
Definition at line 479 of file QualityMetricTester.cpp.
    PatchData pd;
    get_ideal_tris( pd, true );
void QualityMetricTester::test_evaluate_zero_element ( QualityMetric qm,
bool  should_succeed
Test that evaluation of the metric for zero area/volume element does not pass back an error condition, and that the returned boolean feasible value is the specified value
Definition at line 1857 of file QualityMetricTester.cpp.
References get_zero_element(), mSettings, test_bad_element(), and types.
Test method to get samples in an element in the EdgeQM base class
Definition at line 662 of file QualityMetricTester.cpp.
References ASSERT_NO_ERROR, MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, edges, MBMesquite::EdgeQM::get_evaluations(), get_ideal_element(), mSettings, and types.
    PatchData pd;
    std::vector< size_t > handles;
        get_ideal_element( types[i], true, pd );
        handles.clear();
        CPPUNIT_ASSERT_EQUAL( TopologyInfo::edges( types[i] ), (unsigned)handles.size() );
Definition at line 851 of file QualityMetricTester.cpp.
References ASSERT_NO_ERROR, MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, edges, MBMesquite::EdgeQM::evaluate_with_indices(), MBMesquite::EdgeQM::get_evaluations(), get_ideal_element(), MBMesquite::EdgeQM::get_metric_type(), mSettings, MBMesquite::PatchData::num_free_vertices(), and types.
    PatchData pd, pd2;
    if( mSettings )
        pd2.attach_settings( mSettings );
    std::vector< size_t > handles, indices, indices2, verts;
    double qm_val;
    CPPUNIT_ASSERT( qm->get_metric_type() == QualityMetric::VERTEX_BASED );
        // construct patch w/ no free vertices
        get_ideal_element( types[i], false, pd, false );
        CPPUNIT_ASSERT_EQUAL( (size_t)TopologyInfo::edges( types[i] ), handles.size() );
            // evaluate metric
            qm->evaluate_with_indices( pd, handles[j], qm_val, indices, err );
            // evaluation at each edge should depend on at least the two end vertices
            CPPUNIT_ASSERT( indices.size() >= (size_t)2 );
        // construct patch w/ one free vertex
        const size_t fixed_vertex = pd.num_free_vertices();
            // evaluate metric
            CPPUNIT_ASSERT( !indices.empty() );
            // indices should never contain the index of a fixed vertex
            it = std::find( indices.begin(), indices.end(), fixed_vertex );
            CPPUNIT_ASSERT( it == indices.end() );
Test get_evaluatinos() method for element-based metric
Definition at line 511 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::get_evaluations(), get_ideal_hexes(), get_ideal_quads(), get_ideal_tris(), MBMesquite::HEXAHEDRON, mSettings, MSQ_CHKERR, MBMesquite::PatchData::num_elements(), MBMesquite::QUADRILATERAL, MBMesquite::TRIANGLE, and type_is_supported().
    PatchData pd;
    unsigned count = 0;
    if( type_is_supported( HEXAHEDRON ) )
        get_ideal_hexes( pd );
        CPPUNIT_ASSERT_EQUAL( pd.num_elements(), handles.size() );
        std::sort( handles.begin(), handles.end() );
        handles.erase( std::unique( handles.begin(), handles.end() ), handles.end() );
        ++count;
        ++count;
        ++count;
    CPPUNIT_ASSERT( count > 0 );
Test indices from evaluate_with_indices() method
Definition at line 773 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::QualityMetric::get_metric_type(), MBMesquite::MsqMeshEntity::get_vertex_indices(), mSettings, MSQ_CHKERR, MBMesquite::PatchData::num_free_vertices(), and types.
    PatchData pd;
    std::vector< size_t > handles, indices, verts;
    double qm_val;
    CPPUNIT_ASSERT( qm->get_metric_type() == QualityMetric::ELEMENT_BASED );
        // construct patch w/ one fixed vertex
        CPPUNIT_ASSERT_EQUAL( (size_t)1, handles.size() );
        // get vertex list
        verts.clear();
        pd.element_by_index( 0 ).get_vertex_indices( verts );
        // remove fixed vertex
        for( size_t j = 0; j < verts.size(); ++j )
            if( verts[j] >= pd.num_free_vertices() )
                verts.erase( verts.begin() + j );
                break;
        // evaluate metric
        qm->evaluate_with_indices( pd, handles[0], qm_val, indices, err );
        // index list should match vertex list (element metric
        // should depend on all free vertices in element).
        CPPUNIT_ASSERT_EQUAL( verts.size(), indices.size() );
        std::sort( verts.begin(), verts.end() );
        std::sort( indices.begin(), indices.end() );
        CPPUNIT_ASSERT( verts == indices );
Test method to get samples in an element in the ElemSampleQM base class
Definition at line 680 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, MBMesquite::ElemSampleQM::get_element_evaluations(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), mSettings, MSQ_CHKERR, MBMesquite::PatchData::num_elements(), and types.
    PatchData pd;
    std::vector< size_t > handles1, handles2;
    get_ideal_element( types[0], false, pd );
    CPPUNIT_ASSERT( pd.num_elements() == 1 );
    qm->get_evaluations( pd, handles1, false, err );
    CPPUNIT_ASSERT( !handles1.empty() );
    qm->get_element_evaluations( pd, 0, handles2, err );
    CPPUNIT_ASSERT( !handles2.empty() );
    std::sort( handles1.begin(), handles1.end() );
    std::sort( handles2.begin(), handles2.end() );
    CPPUNIT_ASSERT( handles1 == handles2 );
    get_ideal_element( types.back(), false, pd );
Test that evaluate_with_indices returns indices only for free vertices
Definition at line 714 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), corners, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::QualityMetric::get_metric_type(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), mSettings, MSQ_CHKERR, MBMesquite::PatchData::num_free_vertices(), and types.
    PatchData pd1, pd2;
    if( mSettings )
        pd1.attach_settings( mSettings );
    std::vector< size_t > handles1, handles2, indices1, indices2;
    // get element with no fixed vertices
    get_ideal_element( types.back(), false, pd1, false );
    qm->get_evaluations( pd1, handles1, false, err );
    // call evaluate with indices
    size_t handle = handles1.back();
    qm->evaluate_with_indices( pd1, handle, qm_val1, indices1, err );
    // get element with one fixed vertex
    get_ideal_element( types.back(), false, pd2, true );
    qm->get_evaluations( pd2, handles2, false, err );
    // If vertex-based metric, need to find corresponding handle
    // in second patch.  The vertex order changed as a result of
    // one of the vertices beging fixed in the second patch.
    if( qm->get_metric_type() == QualityMetric::VERTEX_BASED )
        const size_t* conn1 = pd1.element_by_index( 0 ).get_vertex_index_array();
        const size_t* conn2 = pd2.element_by_index( 0 ).get_vertex_index_array();
        const size_t len    = TopologyInfo::corners( types.back() );
        const size_t* ptr   = std::find( conn1, conn1 + len, handle );
        handle              = conn2[ptr - conn1];
    qm->evaluate_with_indices( pd2, handle, qm_val2, indices2, err );
    CPPUNIT_ASSERT( !indices2.empty() );
    // make sure we got the same QM value
    // (shoudn't be affected by fixed/non-fixed)
    // should have gotten back one less index (for element-based metrics)
    if( handles1.size() == 1 )
        CPPUNIT_ASSERT_EQUAL( indices1.size(), indices2.size() + 1 );
    // indices2 shouldn't contain any fixed vertices
    CPPUNIT_ASSERT( indices2.back() < pd2.num_free_vertices() );
    // indices2 shouldn/t contain any duplicates
    CPPUNIT_ASSERT( std::unique( indices2.begin(), indices2.end() ) == indices2.end() );
Test get_evaluatinos() method for sample-based metric
Definition at line 596 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::get_evaluations(), get_ideal_hexes(), get_ideal_quads(), get_ideal_tris(), MBMesquite::PatchData::get_samples(), MBMesquite::HEXAHEDRON, mSettings, MSQ_CHKERR, MBMesquite::PatchData::num_elements(), MBMesquite::NodeSet::num_nodes(), MBMesquite::QUADRILATERAL, MBMesquite::TRIANGLE, and type_is_supported().
    PatchData pd;
    unsigned count = 0;
        size_t expected_evals = 0;
        for( size_t i = 0; i < pd.num_elements(); ++i )
            expected_evals += pd.get_samples( i ).num_nodes();
        CPPUNIT_ASSERT_EQUAL( expected_evals, handles.size() );
        ++count;
        ++count;
        ++count;
Definition at line 911 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::QualityMetric::get_metric_type(), MBMesquite::PatchData::get_samples(), MBMesquite::MsqMeshEntity::get_vertex_indices(), mSettings, MSQ_CHKERR, MBMesquite::PatchData::num_free_vertices(), MBMesquite::NodeSet::num_nodes(), and types.
    PatchData pd;
    double qm_val;
        // get evaluation locations
        const size_t count = pd.get_samples( 0 ).num_nodes();
        // should have one evaluation for each sample point
        CPPUNIT_ASSERT_EQUAL( count, handles.size() );
        // get vertex list
        verts.clear();
                break;
        // evaluate metric
        // only one fixed vertex, and presumably every possible evaluation
        // depends on more than one vertex, so should be at least one
        // other, non-fixed, vertex.
        CPPUNIT_ASSERT( indices.size() > 0 );
        // make sure no duplicates
        CPPUNIT_ASSERT( std::unique( indices.begin(), indices.end() ) == indices.end() );
        // check that all indices are in vertex list
        CPPUNIT_ASSERT( indices.size() <= verts.size() );
        for( std::vector< size_t >::iterator j = indices.begin(); j != indices.end(); ++j )
            CPPUNIT_ASSERT( std::find( verts.begin(), verts.end(), *j ) != verts.end() );
Test get_evaluatinos() method for vertex-based metric
Definition at line 558 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::get_evaluations(), get_ideal_hexes(), get_ideal_quads(), get_ideal_tris(), MBMesquite::HEXAHEDRON, mSettings, MSQ_CHKERR, MBMesquite::QUADRILATERAL, MBMesquite::TRIANGLE, and type_is_supported().
    PatchData pd;
    unsigned count = 0;
        ++count;
        ++count;
        ++count;
Test indices from evaluate_with_indices() method, assuming quality at a vertex depends only on edge-connected vertices.
Definition at line 813 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::PatchData::get_adjacent_vertex_indices(), get_ideal_element(), MBMesquite::QualityMetric::get_metric_type(), mSettings, MSQ_CHKERR, MBMesquite::PatchData::num_free_vertices(), and types.
    PatchData pd;
    std::vector< size_t > indices, verts;
    double qm_val;
        // get adjacent vertices
        verts.clear();
        pd.get_adjacent_vertex_indices( 0, verts, err );
                break;
        verts.push_back( 0 );
        // evaluate metric
        qm->evaluate_with_indices( pd, 0, qm_val, indices, err );
        // vertex metric should depend on all adjacent free vertices
void QualityMetricTester::test_grad_location_invariant ( QualityMetric qm,
bool  untangler = false
test that gradient values don't change with element translation
Definition at line 1729 of file QualityMetricTester.cpp.
References test_grad_transform_invariant().
    PatchTranslate xform( Vector3D( 1, 1, -1 ) );
    test_grad_transform_invariant( qm, xform, untangle );
void QualityMetricTester::test_grad_orient_invariant ( QualityMetric qm,
test that gradient values rotate with element rotation
Definition at line 1741 of file QualityMetricTester.cpp.
    // rotate 45 degrees about x-axis
    const double f = std::sqrt( 2.0 ) / 2;
    Matrix3D rotation( 1, 0, 0, 0, f, f, 0, -f, f );
    PatchRotate xform( rotation );
Definition at line 1596 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::get_evaluations(), get_inverted_element(), get_nonideal_element(), mSettings, MSQ_CHKERR, size, types, QualityMetricTester::PatchXform::xform(), and QualityMetricTester::PatchXform::xform_grad().
Referenced by test_grad_location_invariant(), and test_grad_orient_invariant().
    PatchData pd;
    std::vector< size_t > handles, indices2;
    std::vector< Vector3D > grad2;
    double qmval;
    bool rval;
    PlanarDomain dom( Vector3D( 0, 0, 1 ), Vector3D( 0, 0, 0 ) );
    size_t i, j, k;
    for( i = 0; i < types.size(); ++i )
        if( untangle )
            get_inverted_element( types[i], pd );
        else
            get_nonideal_element( types[i], pd );
        // get value(s) for orignal patch
        std::vector< std::vector< Vector3D > > grad1( handles.size() );
        std::vector< std::vector< size_t > > indices1( handles.size() );
        for( j = 0; j < handles.size(); ++j )
            rval = qm->evaluate_with_gradient( pd, handles[j], qmval, indices1[j], grad1[j], err );
            CPPUNIT_ASSERT( !grad1[j].empty() );
        // transform patch
        xform.xform( pd, &dom );
        // compare values
            rval = qm->evaluate_with_gradient( pd, handles[j], qmval, indices2, grad2, err );
            CPPUNIT_ASSERT_EQUAL( indices1[j].size(), indices2.size() );
            CPPUNIT_ASSERT_EQUAL( grad1[j].size(), grad2.size() );
            CPPUNIT_ASSERT( indices1[j] == indices2 );
            xform.xform_grad( grad1[j] );
            for( k = 0; k < grad2.size(); ++k )
                CPPUNIT_ASSERT_VECTORS_EQUAL( grad1[j][k], grad2[k], 1e-3 );
Test that metric value increases (or decreases if negate_flag is -1) as the quality of an element worsens. Compares gradient values for ideal element with unit edge length to the value for the same element with one corner vertex moved 1/2 of the distance towards the element centroid. This test is applicable only for element-based metrics.
Definition at line 2086 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), MBMesquite::grad(), mSettings, MSQ_CHKERR, n, MBMesquite::PatchData::set_vertex_coordinates(), moab::sum(), types, and MBMesquite::MsqMeshEntity::vertex_count().
Referenced by TQualityMetricTest::test_inverse_mean_ratio_grad().
    PatchData pd;
    double qmval;
    bool rval;
        decreasing = true;
        // get a patch
        // make element non-ideal
        for( unsigned j = 0; j < n; ++j )
            sum += coords[verts[j]];
        const Vector3D init_pos = coords[verts[0]];
        const Vector3D new_pos  = 0.5 * coords[verts[0]] + sum / ( 2 * n );
        pd.set_vertex_coordinates( new_pos, verts[0], err );
        // evaluate for non-ideal element
        rval = qm->evaluate_with_gradient( pd, handles[0], qmval, indices, grad, err );
        // find gradient for vertex 0
        std::vector< size_t >::iterator it = std::find( indices.begin(), indices.end(), verts[0] );
        CPPUNIT_ASSERT( it != indices.end() );
        Vector3D g = grad[it - indices.begin()];
        // check gradient direction
        Vector3D v     = init_pos - coords[verts[0]];
        double dotprod = v % g;
        if( decreasing )
            CPPUNIT_ASSERT( dotprod > 1e-6 );
        else
            CPPUNIT_ASSERT( dotprod < -1e-6 );
compare gradient w/ no fixed vertices to gradient for element with all but one vertex fixed.
Definition at line 2482 of file QualityMetricTester.cpp.
        test_gradient_with_fixed_vertex( types[i], qm, settings );
Definition at line 2503 of file QualityMetricTester.cpp.
References ASSERT_NO_ERROR, MBMesquite::PatchData::attach_settings(), conn, corners, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::get_evaluations(), get_nonideal_element(), MBMesquite::MsqMeshEntity::get_vertex_indices(), MBMesquite::grad(), mSettings, and n.
    PatchData pd;
    if( settings )
    bool rval;
    rval = qm->evaluate_with_gradient( pd, h, val, indices, grad, err );
        h = handles[0];
        rval = qm->evaluate_with_gradient( pd, h, val_fixed, indices_fixed, grad_fixed, err );
        CPPUNIT_ASSERT_VECTORS_EQUAL( grad[conn[i]], grad_fixed.front(), 1e-5 );
void QualityMetricTester::test_hessian_location_invariant ( QualityMetric qm,
test that Hessian values don't change with element translation
Definition at line 1735 of file QualityMetricTester.cpp.
References test_hessian_transform_invariant().
    test_hessian_transform_invariant( qm, xform, untangle );
Definition at line 1653 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::get_evaluations(), get_inverted_element(), get_nonideal_element(), mSettings, MSQ_CHKERR, size, types, and QualityMetricTester::PatchXform::xform().
Referenced by test_hessian_location_invariant().
    PatchData pd;
    double qmval;
    bool rval;
    size_t i, j, k;
        if( untangle )
        else
        std::vector< std::vector< Matrix3D > > hess1( handles.size() );
            rval = qm->evaluate_with_Hessian( pd, handles[j], qmval, indices1[j], grad1, hess1[j], err );
            CPPUNIT_ASSERT( !hess1[j].empty() );
            rval = qm->evaluate_with_Hessian( pd, handles[j], qmval, indices2, grad2, hess2, err );
            CPPUNIT_ASSERT_EQUAL( hess1[j].size(), hess2.size() );
            for( k = 0; k < hess2.size(); ++k )
                CPPUNIT_ASSERT_MATRICES_EQUAL( hess1[j][k], hess2[k], 1e-3 );
compare Hessian w/ no fixed vertices to Hessian for element with all but one vertex fixed.
Definition at line 2489 of file QualityMetricTester.cpp.
Referenced by TQualityMetricTest::test_inverse_mean_ratio_hess().
        test_hessian_with_fixed_vertex( types[i], qm, settings );
Definition at line 2558 of file QualityMetricTester.cpp.
References ASSERT_NO_ERROR, MBMesquite::PatchData::attach_settings(), conn, corners, CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_MATRICES_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::get_evaluations(), get_nonideal_element(), MBMesquite::MsqMeshEntity::get_vertex_indices(), MBMesquite::grad(), MBMesquite::hess(), mSettings, and n.
    PatchData pd;
    if( settings )
    std::vector< Matrix3D > hess, hess_fixed;
    bool rval;
    rval = qm->evaluate_with_Hessian( pd, h, val, indices, grad, hess, err );
    CPPUNIT_ASSERT_EQUAL( (size_t)( n * ( n + 1 ) / 2 ), hess.size() );
        h = handles[0];
        rval = qm->evaluate_with_Hessian( pd, h, val_fixed, indices_fixed, grad_fixed, hess_fixed, err );
        CPPUNIT_ASSERT_MATRICES_EQUAL( hess[n * j - j * ( j - 1 ) / 2], hess_fixed.front(), 1e-4 );
Test that Hessian is positive-definite for ideal elements
Definition at line 2397 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::grad(), mSettings, MSQ_CHKERR, n, and types.
    PatchData pd;
    double qmval;
    bool rval;
        // get a patch
        get_ideal_element( types[i], unit_area, pd );
            // evaluate
            rval = qm->evaluate_with_Hessian( pd, handles[j], qmval, indices, grad, Hess, err );
            const size_t n = indices.size();
            CPPUNIT_ASSERT_EQUAL( n, grad.size() );
            CPPUNIT_ASSERT_EQUAL( n * ( n + 1 ) / 2, Hess.size() );
            // if necessary, adjust Hessian for negate_flag();
            if( qm->get_negate_flag() == -1 )
                for( size_t k = 0; k < Hess.size(); ++k )
                    Hess[k] *= -1.0;
            // check that all diagonal blocks are positive definite
            size_t h_idx = 0;
            for( size_t k = 0; k < n; h_idx += ( n - k ), ++k )
                CPPUNIT_ASSERT( Hess[h_idx].positive_definite() );
            // check that the entire Hessian is positive definite
            // CPPUNIT_ASSERT( positive_definite( arrptr(Hess), n ) );
        }  // for(j < handles.size())
    }      // for(i < types.size())
Test that gradient values are zero for an ideal element. If 'unit_area' is true, then ideal elements have unit measure, otherwise they have unit edge lengths. This test is applicable only to element-based metrics.
Definition at line 2256 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::grad(), mSettings, MSQ_CHKERR, and types.
    PatchData pd;
    double qmval;
    bool rval;
        // get a patch
            // evaluate
            rval = qm->evaluate_with_gradient( pd, handles[j], qmval, indices, grad, err );
            CPPUNIT_ASSERT_EQUAL( indices.size(), grad.size() );
            // check that all gradients are zero
            for( size_t k = 0; k < grad.size(); ++k )
                CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 0 ), grad[k], 1e-4 );
            }  // for(k < grad.size())
Test that gradient values are zero at the shared vertex in a patch of containing ideal elements. If 'unit_area' is true, then ideal elements have unit measure, otherwise they have unit edge lengths. Test is done only for TRIANGLE, QUADRILATERAL, and HEXAHEDRON element types.
Definition at line 2290 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, CPPUNIT_ASSERT_VECTORS_EQUAL, MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_hexes(), get_ideal_quads(), get_ideal_tris(), MBMesquite::grad(), MBMesquite::HEXAHEDRON, mSettings, MSQ_CHKERR, MBMesquite::QUADRILATERAL, MBMesquite::TRIANGLE, and type_is_supported().
    PatchData pd;
    double qmval;
    bool rval;
    unsigned count = 0;
    for( size_t i = 0; i < 3; ++i )
        // get a patch
        switch( i )
            case 0:
                if( !type_is_supported( TRIANGLE ) ) continue;
                get_ideal_tris( pd, unit_area );
                break;
            case 1:
                if( !type_is_supported( QUADRILATERAL ) ) continue;
                break;
            case 2:
                if( !type_is_supported( HEXAHEDRON ) ) continue;
                break;
            // evaluate
            if( grad.empty() ) continue;
            ++count;
            CPPUNIT_ASSERT_EQUAL( (size_t)1, grad.size() );  // only 1 free vertex in patch
            CPPUNIT_ASSERT_VECTORS_EQUAL( Vector3D( 0, 0, 0 ), grad[0], 1e-4 );
    }      // for(i < 3)
           // make sure we tested something
void QualityMetricTester::test_location_invariant ( QualityMetric qm,
test that metric value is consistent for element translation
Definition at line 1707 of file QualityMetricTester.cpp.
References test_transform_invariant().
    test_transform_invariant( qm, xform, untangle );
test that metric value increases as element orientation changes from ideal
Definition at line 1798 of file QualityMetricTester.cpp.
References test_measures_transform().
    // rotate 45 degrees about z-axis
    Matrix3D rotation( f, -f, 0, f, f, 0, 0, 0, 1 );
    test_measures_transform( qm, xform, false );
Definition at line 1807 of file QualityMetricTester.cpp.
Test that metric value increases (or decreases if negate_flag is -1) as the quality of an element worsens. Compares metric values for ideal element with unit edge length to the value for the same element with one corner vertex moved 1/2 of the distance towards the element centroid. This test is applicable only for element-based metrics.
Definition at line 1862 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::PatchData::element_by_index(), MBMesquite::QualityMetric::evaluate(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::PatchData::get_vertex_array(), MBMesquite::MsqMeshEntity::get_vertex_index_array(), mSettings, MSQ_CHKERR, n, MBMesquite::PatchData::set_vertex_coordinates(), types, and MBMesquite::MsqMeshEntity::vertex_count().
    PatchData pd;
    bool rval;
        decreasing = true;
        // get a patch
        // evaluate for ideal element
        rval = qm->evaluate( pd, handles[0], qmval1, err );
        // calculate element centroid
        Vector3D cent( 0, 0, 0 );
        Vector3D coords0 = coords[verts[0]];
            cent += coords[verts[j]];
        cent /= n;
        // evaluate for non-ideal element (decreased area)
        pd.set_vertex_coordinates( 0.5 * ( cent + coords0 ), verts[0], err );
        rval = qm->evaluate( pd, handles[0], qmval2, err );
        // check values
        if( decreasing )
            CPPUNIT_ASSERT( qmval2 < qmval1 );
        else
            CPPUNIT_ASSERT( qmval2 > qmval1 );
        // evaluate for non-ideal element (increased area)
        pd.set_vertex_coordinates( 3 * coords0 - 2 * cent, verts[0], err );
        // check values
        if( decreasing )
        else
void QualityMetricTester::test_measures_size ( QualityMetric qm,
bool  unit_area
test that metric inceases (decreases) as size deviates from ideal
Definition at line 1791 of file QualityMetricTester.cpp.
    PatchScale s1( 0.5 ), s2( 2.0 );
    test_measures_transform( qm, s1, unit_area );
    test_measures_transform( qm, s2, unit_area );
Definition at line 1750 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::QualityMetric::get_negate_flag(), mSettings, MSQ_CHKERR, types, and QualityMetricTester::PatchXform::xform().
Referenced by test_measures_in_plane_orientation(), test_measures_out_of_plane_orientation(), and test_measures_size().
    PatchData pd;
    bool rval;
        decreasing = true;
        if( decreasing )
        else
Test that metric value increases (or decreases if negate_flag is -1) as the quality of the element worsen. Compares metric values for ideal elements with unit edge length to the value for the same elements with the shared vertex moved 1/2 of the length of one of the adjacent edges. This test is done only for TRIANGLE, QUADRILATERAL, and HEXAHEDRAL element types.
Definition at line 2138 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate(), get_ideal_hexes(), get_ideal_quads(), get_ideal_tris(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::HEXAHEDRON, MBMesquite::PatchData::move_vertex(), mSettings, MSQ_CHKERR, MBMesquite::QUADRILATERAL, MBMesquite::TRIANGLE, and type_is_supported().
    PatchData pd;
    bool rval;
    bool increasing = true;
        increasing = true;
    unsigned count = 0;
        // get a patch
        switch( i )
            case 0:
                break;
            case 1:
                break;
            case 2:
                break;
        ++count;
        rval = qm->evaluate( pd, 0, qmval1, err );
        // move center vertex
        pd.move_vertex( Vector3D( 0.3, 0.3, 0.3 ), 0, err );
        rval = qm->evaluate( pd, 0, qmval2, err );
        // check values
        if( increasing )
        else
void QualityMetricTester::test_orient_invariant ( QualityMetric qm,
test that metric value is consistent for element rotation
Definition at line 1720 of file QualityMetricTester.cpp.
void QualityMetricTester::test_scale_invariant ( QualityMetric qm,
test that metric value is consistent for element scalaing
Definition at line 1713 of file QualityMetricTester.cpp.
    PatchScale scale1( 0.5 ), scale2( 2.0 );
    test_transform_invariant( qm, scale1, untangle );
    test_transform_invariant( qm, scale2, untangle );
Test that metric evaluation succeeds for all supported element types and fails for all unsupported types
Definition at line 433 of file QualityMetricTester.cpp.
References MBMesquite::MIXED, MBMesquite::POLYGON, MBMesquite::POLYHEDRON, MBMesquite::SEPTAHEDRON, test_type_is_not_supported(), test_type_is_supported(), MBMesquite::TRIANGLE, and type_is_supported().
    for( int i = TRIANGLE; i < MIXED; ++i )
        if( i == POLYGON || i == POLYHEDRON || i == SEPTAHEDRON )
            continue;
        else if( type_is_supported( (EntityTopology)i ) )
            test_type_is_supported( (EntityTopology)i, qm );
        else
            test_type_is_not_supported( (EntityTopology)i, qm );
Test that diagonal bocks of Hessian are symetrical
Test that diagonal bocks of Hessian are symmetric
Definition at line 2442 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::grad(), mSettings, MSQ_CHKERR, n, and types.
    PatchData pd;
    double qmval;
    bool rval;
        // get a patch
            // evaluate
            // check that diagonal Hessian blocks are symmetric
            size_t h_idx = 0;
                CPPUNIT_ASSERT_DOUBLES_EQUAL( Hess[h_idx][0][1], Hess[h_idx][1][0], 5e-3 );
                CPPUNIT_ASSERT_DOUBLES_EQUAL( Hess[h_idx][0][2], Hess[h_idx][2][0], 5e-3 );
                CPPUNIT_ASSERT_DOUBLES_EQUAL( Hess[h_idx][1][2], Hess[h_idx][2][1], 5e-3 );
            }  // for(k < Hess.size())
Definition at line 1551 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_DOUBLES_EQUAL, MBMesquite::QualityMetric::evaluate(), MBMesquite::QualityMetric::get_evaluations(), get_inverted_element(), get_nonideal_element(), mSettings, MSQ_CHKERR, types, and QualityMetricTester::PatchXform::xform().
Referenced by test_location_invariant(), test_orient_invariant(), and test_scale_invariant().
    PatchData pd;
    double qmval;
    bool rval;
    size_t i, j;
        if( untangle )
        else
        // get value(s) for ideal element
        std::vector< double > values( handles.size() );
            rval = qm->evaluate( pd, handles[j], values[j], err );
        // compare values for transformed patch
            rval = qm->evaluate( pd, handles[j], qmval, err );
            CPPUNIT_ASSERT_DOUBLES_EQUAL( values[j], qmval, 1e-3 );
Definition at line 404 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::MsqError::error_code(), MBMesquite::QualityMetric::evaluate(), MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::grad(), MBMesquite::hess(), mSettings, and value().
Referenced by test_supported_element_types().
    MsqError err;
    bool rval;
    // create patch containing only elements of sepcified type
    PatchData pd;
    // get list of evaluation locations in patch
    if( err.error_code() == MsqError::UNSUPPORTED_ELEMENT ) return;
    // evaluate the metric at one location
    double value;
    rval = qm->evaluate( pd, handles[0], value, err );
    CPPUNIT_ASSERT_EQUAL( MsqError::UNSUPPORTED_ELEMENT, err.error_code() );
    std::vector< size_t > indices;
    rval = qm->evaluate_with_indices( pd, handles[0], value, indices, err );
    rval = qm->evaluate_with_gradient( pd, handles[0], value, indices, grad, err );
    std::vector< Matrix3D > hess;
    rval = qm->evaluate_with_Hessian( pd, handles[0], value, indices, grad, hess, err );
Definition at line 362 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, MBMesquite::QualityMetric::evaluate(), MBMesquite::QualityMetric::evaluate_with_gradient(), MBMesquite::QualityMetric::evaluate_with_Hessian(), MBMesquite::QualityMetric::evaluate_with_indices(), MBMesquite::QualityMetric::get_evaluations(), get_ideal_element(), MBMesquite::grad(), MBMesquite::hess(), mSettings, MSQ_CHKERR, and value().
    bool rval;
    PatchData pd;
    double value = -HUGE_VAL;
    // if metric returned input value for 'value' try again
    // with a different initial value to verify that the metric
    // is setting 'value' to something.
    if( value == -HUGE_VAL )
        value = 0.0;
        CPPUNIT_ASSERT( !err && rval );
        CPPUNIT_ASSERT( value != 0.0 );
Test that metric value increases (or decreases if negate_flag is -1) as the quality of the element worsen. Compares gradient values for ideal elements with unit edge length to the value for the same elements with the shared vertex moved 1/2 of the length of one of the adjacent edges. This test is done only for TRIANGLE, QUADRILATERAL, and HEXAHEDRAL element types.
Definition at line 2197 of file QualityMetricTester.cpp.
References MBMesquite::PatchData::attach_settings(), CPPUNIT_ASSERT, CPPUNIT_ASSERT_EQUAL, MBMesquite::QualityMetric::evaluate_with_gradient(), get_ideal_hexes(), get_ideal_quads(), get_ideal_tris(), MBMesquite::QualityMetric::get_negate_flag(), MBMesquite::grad(), MBMesquite::HEXAHEDRON, MBMesquite::PatchData::move_vertex(), mSettings, MSQ_CHKERR, MBMesquite::QUADRILATERAL, MBMesquite::TRIANGLE, and type_is_supported().
    PatchData pd;
    if( mSettings ) pd.attach_settings( mSettings );
    double qmval;
    bool rval;
        increasing = false;
    unsigned count = 0;
        // get a patch
        switch( i )
            case 0:
                break;
            case 1:
                break;
            case 2:
                break;
        // evaluate for ideal non-element
        rval = qm->evaluate_with_gradient( pd, 0, qmval, indices, grad, err );
        if( indices.empty() ) continue;
        CPPUNIT_ASSERT_EQUAL( (size_t)1, indices.size() );  // only 1 free vertex
        CPPUNIT_ASSERT_EQUAL( (size_t)0, indices[0] );      // and that vertex is vertex 0
        ++count;
        Vector3D g = grad[0];
        if( increasing )
            CPPUNIT_ASSERT( g[2] > 1e-6 );
        else
            CPPUNIT_ASSERT( g[2] < -1e-6 );
Member Data Documentation
Definition at line 306 of file QualityMetricTester.hpp.
Referenced by compare_analytical_and_numerical_diagonals(), compare_analytical_and_numerical_gradients(), compare_analytical_and_numerical_hessians(), compare_eval_and_eval_with_indices(), compare_eval_with_diag_and_eval_with_hessian(), compare_eval_with_grad_and_eval_with_diagonal(), compare_eval_with_grad_and_eval_with_hessian(), compare_eval_with_indices_and_eval_with_diagonal(), compare_eval_with_indices_and_eval_with_gradient(), compare_eval_with_indices_and_eval_with_hessian(), test_diagonal_with_fixed_vertex(), test_domain_deviation_gradient(), test_domain_deviation_quality(), test_evaluate_degenerate_element(), test_evaluate_inverted_element(), test_evaluate_unit_edge_element(), test_evaluate_unit_edge_tris_about_vertex(), test_evaluate_unit_element(), test_evaluate_unit_hexes_about_vertex(), test_evaluate_unit_quads_about_vertex(), test_evaluate_unit_tris_about_vertex(), test_evaluate_zero_element(), test_get_edge_evaluations(), test_get_edge_indices(), test_get_element_evaluations(), test_get_element_indices(), test_get_in_element_evaluations(), test_get_indices_fixed(), test_get_sample_evaluations(), test_get_sample_indices(), test_get_vertex_evaluations(), test_get_vertex_indices(), test_grad_transform_invariant(), test_gradient_reflects_quality(), test_gradient_with_fixed_vertex(), test_hessian_transform_invariant(), test_hessian_with_fixed_vertex(), test_ideal_element_positive_definite_Hessian(), test_ideal_element_zero_gradient(), test_ideal_element_zero_vertex_gradient(), test_measures_quality(), test_measures_transform(), test_measures_vertex_quality(), test_symmetric_Hessian_diagonal_blocks(), test_transform_invariant(), test_type_is_not_supported(), test_type_is_supported(), and test_vertex_gradient_reflects_quality().
List of all members.
